crp Posted May 30, 2007 Share Posted May 30, 2007 what would be the equivalent performance MAC to: # AMD Sempron 3400+ (256KB L2 cache, 1800MHz)# 512MB DDR2 SDRAM# 160GB SATA# DVD-Dual drive (DVD+/-RW)# integrated NVIDEO GeForce6100and to a XPS 410, Intel Core 2 Duo Processor E6320 (1.86GHz,1066FSB) with 4MB cache2GB Dual Channel DDR2 SDRAM at 667MHz - 2 DIMMs 320GB Serial ATA 3Gb/s Hard Drive (7200RPM) w/DataBurst Cacheâ„¢ 256MB nVidia Geforce 7300LE TurboCache DVD-Dual drive (DVD+/-RW) thanks Quote Link to comment Share on other sites More sharing options...
epp_b Posted May 30, 2007 Share Posted May 30, 2007 (edited) What is The Answer to The Ultimate Question Of Life, the Universe and Everything? 42 VLC Edited May 30, 2007 by epp_b Quote Link to comment Share on other sites More sharing options...
crp Posted May 31, 2007 Author Share Posted May 31, 2007 What is The Answer to The Ultimate Question Of Life, the Universe and Everything? 42 VLC so out of the box, no MAC will play WMV ? Quote Link to comment Share on other sites More sharing options...
bjf123 Posted May 31, 2007 Share Posted May 31, 2007 (edited) You can download Microsoft's Windows Media Player here. It's not the latest version, and MS has stopped future development, but it works on my Macs (PPC, not Intel).There's also this plug in to play Windows media files in QuickTime. I haven't used it, so I can't say how well it works. Edited May 31, 2007 by bjf123 Quote Link to comment Share on other sites More sharing options...
epp_b Posted May 31, 2007 Share Posted May 31, 2007 so out of the box, no MAC will play WMV ?I have no idea, but I know that VLC will play WMVs on any platform on which it runs. Quote Link to comment Share on other sites More sharing options...
crp Posted May 31, 2007 Author Share Posted May 31, 2007 ok, might be doable.There are no equivalent MACs of any type to the 2 systems i asked about? Quote Link to comment Share on other sites More sharing options...
bjf123 Posted June 1, 2007 Share Posted June 1, 2007 I'm not much into comparing tech specs, but there are iMacs that closely match the specs of the first system you listed. You can see a comparison of those systems here. Click on Compare Specs. To get the hard drive you're looking for on the second system, I think you need a built to order Mac Pro (BTW, it's Mac, not MAC). You can see the specs for the Mac Pros here. Again, click on Compare Specs. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Scot Posted July 16, 2007 Share Posted July 16, 2007 The answer to your WMV on Mac question is a utility called Flip4Mac:http://www.flip4mac.com/Check it out. It works great.For other Mac software questions like this, you might check Scot's Newsletter's A-List of Mac Software.-- Scot Quote Link to comment Share on other sites More sharing options...
