Marsden11 Posted July 27, 2006 Share Posted July 27, 2006 (edited) To diagnose network connectivity status, the Network Diagnostics for Windows XP tool analyzes the following tests: • IP configuration test • Default gateway test • Winsock test • DNS test • Firewall test • Internet connectivity validation test Typically, a support professional will work with you when you run the Network Diagnostics for Windows XP tool to help diagnose network connectivity status. Most home networks use one of the following methods to access or share a single high-speed Internet connection: • A stand-alone router • A home gateway, such as a cable modem together with a router or a DSL modem together with router • A computer that is running Internet Connection Sharing or another form of Network Address Translation (NAT) Download from MSDownload link corrected (Thanks) Edited July 27, 2006 by Marsden11 Quote Link to comment Share on other sites More sharing options...
kkehoe Posted July 27, 2006 Share Posted July 27, 2006 I think you may have posted a different link than you intended. This is the correct one:http://www.microsoft.com/downloads/details...;DisplayLang=enBest of all, it's integrated into the IE Tools menu as "Diagnose Connection Problems". The old "page cannot be displayed" error has been modified to direct you to this diagnostic tool. Quote Link to comment Share on other sites More sharing options...
