Upgraded to Mint 22
I have just completed the in place upgrade to Mint 22 on my main Linux desktop (home built in 2013.) This was a massive upgrade of close to 3000 packages since you basically have to upgrade both Ubuntu and Mint at the same time. Everything appears to have worked OK. It takes close to an hour, even with an SSD and a quad core CPU. This system runs the Cinnamon desktop. I have to perform a similar upgrade on a laptop runing Xfce. But that is for another day.
The upgrade did mess up my wine configuration so the Amazon Music player I use did not work. I had to reinstall wine and the player but everything works now.
I have now completed the Mint 22 Xfce upgrade on my junk HP Broadwell laptop. It was a simpler installation than the desktop and went very well.
These Mint upgrades have to be run in the terminal to avoid glitches with graphical interfaces, but they do everything including removal of orphaned packages.
ray@ray-HP-Pavilion-Notebook:~$ inxi -Fxz
System:
  Kernel: 6.8.0-39-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
  Desktop: Xfce v: 4.18.1 Distro: Linux Mint 22 Wilma
    base: Ubuntu 24.04 noble
Machine:
  Type: Laptop System: Hewlett-Packard product: HP Pavilion Notebook
    v: Type1ProductConfigId serial: <superuser required>
  Mobo: Hewlett-Packard model: 8092 v: 89.33 serial: <superuser required>
    UEFI: Insyde v: F.82 date: 08/18/2016
Battery:
  ID-1: BAT0 charge: 27.0 Wh (100.0%) condition: 27.0/27.0 Wh (100.0%)
    volts: 16.7 min: 14.8 model: Hewlett-Packard Primary status: charging
CPU:
  Info: dual core model: Intel Core i5-5200U bits: 64 type: MT MCP
    arch: Broadwell rev: 4 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
  Speed (MHz): avg: 833 high: 940 min/max: 500/2700 cores: 1: 798 2: 799
    3: 798 4: 940 bogomips: 17558
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Graphics:
  Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
    v: kernel arch: Gen-8 bus-ID: 00:02.0
  Device-2: Chicony HP Truevision HD driver: uvcvideo type: USB
    bus-ID: 1-3:3
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
    loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915
    resolution: 1366x768~60Hz
  API: EGL v: 1.5 drivers: iris,swrast platforms:
    active: x11,surfaceless,device inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-0ubuntu0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW
    GT2)
Audio:
  Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  Device-2: Intel Wildcat Point-LP High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  API: ALSA v: k6.8.0-39-generic status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active
Network:
  Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
    v: kernel bus-ID: 08:00.0
  IF: wlo1 state: up mac: <filter>
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
    vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 09:00.0
  IF: eno1 state: down mac: <filter>
Bluetooth:
  Device-1: Broadcom BCM43142A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
    bus-ID: 1-7:4
  Report: hciconfig ID: hci0 rfk-id: 2 state: down
    bt-service: enabled,running rfk-block: hardware: no software: yes
    address: <filter>
Drives:
  Local Storage: total: 894.25 GiB used: 118.79 GiB (13.3%)
  ID-1: /dev/sda vendor: Patriot model: Burst Elite 960GB size: 894.25 GiB
Partition:
  ID-1: / size: 878.62 GiB used: 118.79 GiB (13.5%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
  System Temperatures: cpu: 42.0 C mobo: N/A
  Fan Speeds (rpm): N/A
Info:
  Memory: total: 8 GiB available: 7.68 GiB used: 1.48 GiB (19.3%)
  Processes: 245 Uptime: 4m Init: systemd target: graphical (5)
  Packages: 2452 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
  • 2 weeks later...
Completed my third upgrade of Linux Mint today on an Intel Sandy Bridge desktop system that I gave to my youngest granddaughter to do schoolwork at home. I am confident that the upgrade process should work without a hitch if you don't want to do a fresh install.
Well some systems have a problem with Sandy Bridge and sound. Now you can fix it but it doesn't always work out of the box or at least on the last couple of arch installs I did.
