ichase Posted February 12, 2013 Share Posted February 12, 2013 Thomas Bächler wrote: With `lvm2 2.02.98-3`, we now utilize `lvmetad` to activate LVM volumesautomatically. This implies the following changes: * The `lvm2` initramfs hook now requires the `udev` hook. * The `use_lvmetad = 1` must be set in `/etc/lvm/lvm.conf`. This is the default now - if you have a `lvm.conf.pacnew` file, you **must** merge this change. * You can restrict the volumes that are activated automatically by setting the `auto_activation_volume_list` in `/etc/lvm/lvm.conf`. If in doubt, leave this option **commented out**. * If you need monitoring (needed for snapshots), run `systemctl enable lvm- monitoring.service`. * The `lvmwait` kernel command line option is no longer needed and has no effect. URL: https://www.archlinux.org/news/changes-to-lvm/ Quote Link to comment Share on other sites More sharing options...
securitybreach Posted February 12, 2013 Share Posted February 12, 2013 Thanks Ian Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 12, 2013 Share Posted February 12, 2013 Bookmarked. Ta . Quote Link to comment Share on other sites More sharing options...
