V.T. Eric Layton Posted August 22, 2012 Posted August 22, 2012 Recently, I started seeing a bluish tinge to faces and other light colored objects in Flash videos, particularly on YouTube. The problem is that Adobe's Flash plugin uses hardware acceleration by default. It doesn't work will with Nvidia, evidently. The quick fix for me is to just Right click on a vid and choose Options, then uncheck "Use Hardware Acceleration". Here is some discussion about this at the Nvidia forums --> http://www.nvnews.net/vbulletin/showthread.php?p=2541629#post2541629 1 Quote
V.T. Eric Layton Posted September 20, 2012 Author Posted September 20, 2012 I got tired of having to reset my flash settings to disable hardware accelleration after every cookies/cache dump so I just reverted to the old flash plugin "Square" (10.2) from September 2010. Worked fine then. Works fine now. 1 Quote
