Hello from Asgard
 Share
Hi folks someFinn told me about you kind and knowledgeable folk so I'm here saying Hello. I'm going to be instaling Arch soon and it seems I may need some help. I have loads of questions and hope you folk can help out. must go as me time on the library pc is nearly out. :pirate:
Welcome Abarbarian!!!You may want to first look at the tutorial I wrote: "Installing and Setting up Archlinux" and the "Beginner's Guide" from the Archwiki http://wiki.archlinux.org/index.php/Beginner's_Guide. I am always here if I am not at work and will be glad to assist you anyway I can.Once again, welcome to the forums :pirate:
There is a net computer in the Åsgard city library? :pirate: Be welcome, Barbier... Barbeer... Barbitu... Barbarian! :P
Course there is. You don't think that rainbow bridge is just for the Valkyries transporting dead heroes do you. It's fibre optic ain't it, asgardians have been fast tracking for eons matey :rolleyes:
Welcome Abarbarian!!!You may want to first look at the tutorial I wrote: "Installing and Setting up Archlinux" and the "Beginner's Guide" from the Archwiki http://wiki.archlinux.org/index.php/Beginner's_Guide. I am always here if I am not at work and will be glad to assist you anyway I can.Once again, welcome to the forums :P
Been reading through them for a couple of weeks now. An very helpful they are too. Me questions will possibly fall outside those guides as I tend to have these marvellous sounding ideas that seem quite tricky to implement. :pirate: Thanks for the welcome. :rolleyes:
Welcome.Arch is great. First try is a little learning curve, it's different from other distros installs.Second and later installs are easy. Just follow those links securitybreach mentioned.I also found these very helpful.http://wiki.archlinux.org/index.php/Offici...x_Install_Guidehttp://wiki.archlinux.org/index.php/Common_ApplicationsReally, anything you need is in the ARCHWIKI http://wiki.archlinux.org/index.php/Main_Page Best distro documentation I've seen.Search function at left in the Navigation pane.Have fun!
 Share
