Nov 6 2009, 04:15 PM
Post
#1
![]() Mr. Incredible Group: Forum MVP Posts: 2,910 Joined: 5-April 03 From: Lincoln, NE Member No.: 721 |
I wanted to setup a thread for people to post their tips and tricks for getting things done in Windows 7.
Post your tips in this thread, and I'll maintain a table of contents list in this first post. That way it'll be easy to find the tip you're looking for! Tips: Getting apps to properly hide in the system tray Auto Log-in Keyboard and Mouse tips - Thanks Citadel80 Link to great tutorial site - Thanks zlim Setup a Classic (Windows 2000 style) Start Menu - Thanks goretsky Bring the Quick Launch toolbar back to Windows 7 - Thanks mac Tips Link and other Start Menu replacements - Thanks Frank Golden XP Mode and VirtualPC - Thanks LilBambi Keyboard and Mouse Tips II - Thanks rbdietz This post has been edited by GolfProRM: Dec 14 2009, 11:22 AM -------------------- |
Nov 6 2009, 04:20 PM
Post
#2
Tip: Getting apps to properly hide in the system tray
If you have an app that used to hide away nicely in the system tray, but won't seem to do-so in Windows 7 (e.g. Windows Live Messenger), there's an easy workaround to get it to leave your taskbar. 1. Exit the program completely (you may have to exit it from the system tray). 2. Go to Start Menu, locate the shortcut of the program you wish to "fix." 3. Right click on the shortcut and select Properties. 4. Go to Compatibility tab. 5. Tick the check box for Run this program in compatibility mode for under “Compatibility Mode”, and then select Windows Vista (Service Pack 2) from the drop down list. 6. Click OK. 7. Restart the program Now, when you minimize the program to the tray, it should disappear from the taskbar completely. -------------------- |
Nov 6 2009, 05:29 PM
Post
#3
Message Adept ![]() ![]() ![]() Group: Members Posts: 84 Joined: 28-May 03 Member No.: 1,303 |
Here's a tip for auto log-in in Win7
1. Press the Windows key + R on your keyboard to launch the Run dialog box. 2. Type in control userpasswords2 3. Press Enter. The User Accounts window will display. 4. Uncheck the option Users must enter a user name and password to use this computer 5. Click OK 6. You will then be prompted to enter the current password and confirm it. 7. After doing so, you will no longer be prompted to enter your password upon login. Auto log-in can be a security risk if you are not the only user on a computer! |
Nov 6 2009, 05:33 PM
Post
#4
Here are some keyboard and mouse tips!
Window Management Shortcuts One of the best changes in Windows 7 is the ability to "snap" windows to the side of the screen, maximize them by dragging to the top of the screen, or even move them to another monitor with a shortcut key. Win+Home: Clear all but the active window. Win+Space: All windows become transparent so you can see through to the desktop. Win+Up arrow: Maximize the active window. Shift+Win+Up arrow: Maximize the active window vertically. Win+Down arrow: Minimize the window/Restore the window if it's maximized. Win+Left/Right arrows: Dock the window to each side of the monitor. Shift+Win+Left/Right arrows: Move the window to the monitor on the left or right. You can also interact with windows by dragging them with the mouse: Drag window to the top: Maximize Drag window left/right: Dock the window to fill half of the screen. Shake window back/forth: Minimize everything but the current window. Double-Click Top Window Border (edge): Maximize window vertically. Taskbar Shortcuts In Windows 7, using the Windows key along with the numbers 1-9 will let you interact with the applications pinned to the taskbar in those positionsfor example, the Windows key + 4 combination would launch Outlook in this example, or Win+Alt+4 can be used to get quick access to the Outlook Jump List from the keyboard. You can use any of these shortcut combinations to launch the applications in their respective position on the taskbar, or more: Win+number (1-9): Starts the application pinned to the taskbar in that position, or switches to that program. Shift+Win+number (1-9): Starts a new instance of the application pinned to the taskbar in that position. Ctrl+Win+number (1-9): Cycles through open windows for the application pinned to the taskbar is that position. Alt+Win+number (1-9): Opens the Jump List for the application pinned to the taskbar. Win+T: Focus and scroll through items on the taskbar. Win+B: Focuses the System Tray icons In addition, you can interact with the taskbar using your mouse and a modifier key: Shift+Click on a taskbar button: Open a program or quickly open another instance of a program. Ctrl+Shift+Click on a taskbar button: Open a program as an administrator. Shift+Right-click on a taskbar button: Show the window menu for the program (like XP does). Shift+Right-click on a grouped taskbar button: Show the window menu for the group. Ctrl+Click on a grouped taskbar button: Cycle through the windows of the group. More Useful Hotkeys You Should Know The new hotkey goodness didn't stop with the taskbar and moving windows aroundone of the best new hotkeys in Windows 7 is the fact that you can create a new folder with a hotkey. Just open up any Windows Explorer window, hit the Ctrl+Shift+N shortcut key sequence, and you'll be rewarded with a shiny "New Folder" ready for you to rename. Here's a few more interesting hotkeys for you: Ctrl+Shift+N: Creates a new folder in Windows Explorer. Alt+Up: Goes up a folder level in Windows Explorer. Alt+P: Toggles the preview pane in Windows Explorer. Shift+Right-Click on a file: Adds Copy as Path, which copies the path of a file to the clipboard. Shift+Right-Click on a file: Adds extra hidden items to the Send To menu. Shift+Right-Click on a folder: Adds Command Prompt Here, which lets you easily open a command prompt in that folder. Win+P: Adjust presentation settings for your display. Win+(+/-): Zoom in/out. Win+G: Cycle between the Windows Gadgets on your screen. |
Nov 7 2009, 03:35 PM
Post
#5
![]() Thread Kahuna Group: Forum MVP Posts: 5,067 Joined: 28-May 03 Member No.: 1,336 |
This site has nice tutorials
http://www.sevenforums.com/tutorials/ -------------------- Liz
Registered Linux User # 401459 |
Nov 8 2009, 10:54 AM
Post
#6
![]() Thread Head ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 643 Joined: 10-May 04 Member No.: 2,451 |
They have a Vista Forum as well Liz...
-------------------- Who's winning the Human Race ? ? |
Nov 8 2009, 03:27 PM
Post
#7
I never ran Vista and I only know one person I help with Vista. He has the Win 7 upgrade disk waiting for me to help him upgrade as soon as I gather all the info. I don't want him to be one of those stuck in a reboot loop.
Nov 9 2009, 05:13 AM
Post
#8
![]() Thread Head Group: Forum Moderators Posts: 748 Joined: 5-June 06 From: Southern California Member No.: 4,401 |
Hello,
Here's how to simulate a Windows XP "Classic"/Windows 2000 style Start Menu on a computer running Microsoft Windows 7:
Regards, Aryeh Goretsky -------------------- Dexter is a good dog. Aryeh GoretskyMS-MVP Windows Desktop Experience My blog. |
Nov 9 2009, 05:43 PM
Post
#9
Thanks AG. That's one thing I will probably do.
Nov 10 2009, 09:07 AM
Post
#10
Hello, Here's how to simulate a Windows XP "Classic"/Windows 2000 style Start Menu on a computer running Microsoft Windows 7: Great tip, but I love the windows 7 start menu. Especially the ability to hit the windows key, then start typing to find a program. No need to browse through the whole list. -------------------- |
Nov 13 2009, 02:12 AM
Post
#11
Topic Cop ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 891 Joined: 5-May 03 From: South Eastern Michigan Member No.: 1,114 |
Great tip, but I love the windows 7 start menu. Especially the ability to hit the windows key, then start typing to find a program. No need to browse through the whole list. I like that too. Not knocking the XP start menu but I hardly ever used it. Almost always used the quick launch (no longer available in Win 7) or a desktop icon. Not that I like having to reach for my keyboard but it is really nice that all I need to do is hit one of the windows keys and type a few letters of the program I want to run. [win] cal for instance gets me the Calculator and Calendar at the top of the list. [win] pa gets me paint [win] ph gets me photoshop I'd say that is easier than remembering what these "extra" buttons on my keyboard are for (if they work correctly) -------------------- |
Nov 13 2009, 09:58 AM
Post
#12
![]() Post Master ![]() ![]() ![]() ![]() Group: Members Posts: 167 Joined: 4-April 03 From: Covington, LA USA Member No.: 617 |
I like that too. Not knocking the XP start menu but I hardly ever used it. Almost always used the quick launch (no longer available in Win 7) or a desktop icon. Not that I like having to reach for my keyboard but it is really nice that all I need to do is hit one of the windows keys and type a few letters of the program I want to run. [win] cal for instance gets me the Calculator and Calendar at the top of the list. [win] pa gets me paint [win] ph gets me photoshop I'd say that is easier than remembering what these "extra" buttons on my keyboard are for (if they work correctly) From the 11/12 issue of Windows Secrets: QUOTE Bring the Quick Launch toolbar back to Windows 7
In the Nov. 5 Known Issues column, Ed Kirkpatrick described how he created a custom Windows 7 toolbar to replace the Quick Launch toolbar, which is missing by default in Win7. David Shirly was one of several readers who provided us with instructions for restoring Win7's Quick Launch toolbar: "Regarding Dennis O'Reilly's piece on Windows 7 early adopters: Quick Launch is still available, but it's hidden by default. You have to know where to look: C:\ Users \ username \ AppData \ Roaming \ Microsoft \ Internet Explorer \ Quick Launch "Simply create a new toolbar and point to this location. You'll have to enable 'show hidden files' to find it." -------------------- Mac
"The difference between death and taxes is death doesn't get worse every time Congress meets." -- Will Rogers (1879-1935) |
Nov 13 2009, 11:25 AM
Post
#13
I read that somewhere. No biggy for me though since the interface looks nice without it. I like the application bar (I'm guessing on the name of it) where IE, Windows Explorer, Windows Media Player reside. I especially like the way that multiple windows explorer windows group together and if one is in the process of copying/moving files the icon will have a green hue that moves from the left to the right as the copy progresses.
Nov 14 2009, 12:35 PM
Post
#14
![]() Multithreader ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 26-January 06 Member No.: 4,075 |
I read that somewhere. No biggy for me though since the interface looks nice without it. I like the application bar (I'm guessing on the name of it) where IE, Windows Explorer, Windows Media Player reside. I especially like the way that multiple windows explorer windows group together and if one is in the process of copying/moving files the icon will have a green hue that moves from the left to the right as the copy progresses. Some tips from Terry Blount http://windows7forums.com/blogs/tblount/14...-windows-7.html http://windows7forums.com/blogs/tblount/ XP or Vista style start menu-freebies http://www.vistastartmenu.com/index.html The Vista Start Menu is very slick and customizable. You can set it to start with windows and have it replace the Win 7 menu. It has three skins available. Shown below is the Vista skin. ![]() http://www.csmenu.com/ CSMenu on the other hand is very basic with little chance for customization. Another handy tool is Free Launch Bar-free as well http://download.cnet.com/Free-Launch-Bar/3...4-10333488.html Free launch bar lets you create a Quick launch like taskbar tool. You can create individual menus with shortcuts. Very cool. Shown in the screen shot below is an example of my application of Free Launch Bar. ![]() The expanded menu is filled with various tools apps. The menus are separated by separators and have little black arrow points. I have about 140 shortcuts at my command in 9 menus. The icons without separators are actuall standalone shortcuts for my most frequently apps. Simply clicking on a menu expands it. Hovering your pointer over a menu pops up a balloon tip with the name of the menu. I name the menus based on the shortcuts in them. For instance the menu identified by the camera icon is for imaging apps and is named "Imagers". You can create menus within menus as well. You will see an example of that at the top of the expanded tool menu in the screen shot. There are 4 of them and they have an arrow point to the right like the main menus do. As you can see my desktop is uncluttered with only 22 shortcuts. This post has been edited by Frank Golden: Nov 14 2009, 02:02 PM -------------------- Frank Golden
Acer Aspire as5672WLMi, Core 2 Duo Merom (T7200/2.0 GHz) Centrino, 500 GB Seagate Momentus 7200 rpm (SATA) HDD, 4 GB Corsair DDR2-PC5300 ram, ATi Radeon X1400 (128 MB built-in vram/384 MB system ram), [ XP-SP3 Pro | Win 7 Home Premium | Ubuntu 10.04 LTS & Ubuntu 8.10 64 bit | PCLinuxOS 2010 Gnome & KDE ] Registered Linux User #423741 Registered Ubuntu User # 6235 "Any sufficiently advanced technology is indistinguishable from magic"-Arthur C. Clarke |
Nov 23 2009, 09:03 AM
Post
#15
![]() Message Mogul ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 412 Joined: 5-April 03 From: Hong Kong Member No.: 678 |
-------------------- If you try and take a cat apart to see how it works, the first thing you have on your hands is a non-working cat.
Nov 23 2009, 05:13 PM
Post
#16
![]() Australisches Googler Group: Forum Admins Posts: 11,047 Joined: 19-March 03 From: Virginia Member No.: 100 |
Great tip, but I love the windows 7 start menu. Especially the ability to hit the windows key, then start typing to find a program. No need to browse through the whole list. Me too ... that is one of the really good things they did for sure! But there really are a lot of things to like about Windows 7. -------------------- |
Nov 23 2009, 05:16 PM
Post
#17
I read that somewhere. No biggy for me though since the interface looks nice without it. I like the application bar (I'm guessing on the name of it) where IE, Windows Explorer, Windows Media Player reside. I especially like the way that multiple windows explorer windows group together and if one is in the process of copying/moving files the icon will have a green hue that moves from the left to the right as the copy progresses. Yep, and you can drag anything you want to the application bar so it's really easy. -------------------- |
Nov 23 2009, 05:22 PM
Post
#18
If you have any programs or devices (like an older Palm you really like) that doesn't run in Windows 7 (particularly 64-bit), then be sure to get Windows 7 Ultimate or Professional/Business (prefer Ultimate myself), so you can download the free Windows XPMode and VirtualPC from Microsoft to run them.
This has come in very handy on 64-bit Windows 7 computers running Ultimate where like I mentioned there was an older Palm that they needed support for, or an older version of some software you can't live with out. Very handy indeed. -------------------- |
Dec 13 2009, 11:29 PM
Post
#19
![]() Message Mogul ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 473 Joined: 9-December 04 From: Somewhere in South Dakota Member No.: 2,983 |
Keyboard and Mouse Tips II (Aero must be enabled for items in blue.)
(Citadel80's Keyboard and Mouse Tips - Mostly reformated. Somewhat revised & slightly expanded.) Window & Screen Management: Keyboard Shortcuts
Window Management: Mousing Shortcuts
Taskbar Keyboard Shortcuts
Taskbar Mousing Shortcuts
Windows Explorer Keyboard Short-cuts
Windows Explorer Mousing Short-cuts
Miscellaneous Windows Key Shortcuts
This post has been edited by rbdietz: Dec 17 2009, 07:13 AM |
Dec 14 2009, 06:34 PM
Post
#20
![]() Post Master ![]() ![]() ![]() ![]() Group: Members Posts: 173 Joined: 10-July 03 From: Rockville, Maryland USA Member No.: 1,660 |
If you have any programs or devices (like an older Palm you really like) that doesn't run in Windows 7 (particularly 64-bit), then be sure to get Windows 7 Ultimate or Professional/Business (prefer Ultimate myself), so you can download the free Windows XPMode and VirtualPC from Microsoft to run them. This has come in very handy on 64-bit Windows 7 computers running Ultimate where like I mentioned there was an older Palm that they needed support for, or an older version of some software you can't live with out. Very handy indeed. Virtual PC also runs on Windows 7 Professional as well as the business and ultimate. (provided your bios supports the virtual thing..) FWIW Rich -------------------- Enjoy life each day as if it was your last, Learn something new and pass on your knowledge or
what you learned was wasted. |
Dec 16 2009, 11:01 AM
Post
#21
Here's another site with many really good tips, explained in detail, on customizing/tweaking WIN7 for speed, performance and looks:
TechRadar Thanks to Fred Langa's blogpost for the tip. -------------------- Mac
Dec 16 2009, 12:20 PM
Post
#22
Message Adept ![]() ![]() ![]() Group: Members Posts: 38 Joined: 4-April 03 Member No.: 662 |
all I need to do is hit one of the windows keys and type a few letters of the program I want to run. [win] cal for instance gets me the Calculator and Calendar at the top of the list. [win] pa gets me paint [win] ph gets me photoshop I've just bought a netbook with Windows 7 Starter. I'm finding the absence of the Quick Launch bar really a problem, and though I followed the instructions elsewhere in this thread to install the Quick Launch Bar, I'm finding it more cumbersome than the one I have on my WinXP Pro desktop. Thus, I am very interested in what you say about using the Windows key, but I can't figure out a way to set it to bring up non-Microsoft programs. Is the [win] ph built in to open photoshop, or did you somehow re-set the Windows key to do that? If the latter, I'd love to know how to do that. I'm not interested in running photoshop on a netbook, but there are a number of less resource-intensive programs I'd like to be able to open with the Windows key. Is this possible? Thanks in advance for your help. |
Dec 16 2009, 06:49 PM
Post
#23
Hi cybernut,
Have you simply tried typing the first few letters of the program you want to run into the search box on the Start Menu? What gets displayed depends on Windows Search service indexing the Start Menu - which it does by default. Unless you've turned off Windows Search or removed the Start Menu from the list of locations being indexed, it should work for any program on the Start Menu. For information about Adding/Removing index locations see - http://www.nirmaltv.com/2009/12/16/how-to-...s-in-windows-7/ HTH |
Dec 16 2009, 08:28 PM
Post
#24
Using Libraries for additional control of the content of Desktop Background Slide Show.
You've got a bunch of themes installed. Several of them are Christmas themes which each include half a dozen or so different Desktop Backgrounds (Wallpaper). Wouldn't you like to include all of the backgrounds from all of those different Christmas themes in your Desktop Background Slide Show? If so, here is how to do it. First, lets make a library to keep track of your seasonal backgrounds.
Next, let's find the content to put in our Seasonal Backgrounds library.
Finally, let's set up our slide show.
This post has been edited by rbdietz: Dec 16 2009, 08:31 PM |
Dec 19 2009, 05:36 PM
Post
#25
Not really a tip but..
MS just recently re-released their "improved" GUI tool to create a USB flash installer for Win 7 all versions. As you may or may not know their original release was found to be in violation of the GNU General Public License v2 (GPLv2) and they removed it from the MS store because of that. This new version is in compliance with GPLv2 and the source code is available. Windows 7 USB/DVD Download Tool Released Under GPLv2 - Port 25: The Open Source Community at Microsoft There are live links to the D/L site and the source code site. I tried the new version (installed on both XP and Win 7 HP) and it worked flawlessly. Created a USB flash installer in less than 10 minutes from Win 7 .iso file. It also has an option to create a DVD installer as well. It won't work from the DVD installer but there are many tools available to convert a Win 7 DVD to an .iso file. If you bought your copy of Win 7 online it will be in an .iso form. The one I use is called ISO Recorder v 2 and is a Windows Power Tool. ISO Recorder v 2 If you purchased the student version of Win 7 from Digital River it will not be an .iso but the individual files that need to be made into an .iso to use Windows 7 USB/DVD Download installer. ISO Recorder can do that as well. This tool is very easy to use and does a great job converting a disk or files to an .iso file. -------------------- Frank Golden
Lo-Fi Version | Time is now: 2nd September 2010 - 09:45 PM |
