MX-16 released!
mx mx-16 debian
59 replies to this topic
#51 OFFLINE   réjean
réjean
  • 4,473 posts
Posted 03 February 2017 - 09:42 PM
Major drawback!
Just realized there are no language layouts! My main distro needs them when I write to my friend's connections.
registered linux user #374889
#52 OFFLINE   abarbarian
  • 5,433 posts
Posted 06 February 2017 - 06:52 AM
Does anyone know if  a MX-16 Live USB will show up or install on a UEFI pc ? :>
Install ARCH
"I did and I'm really happy"
#53 ONLINE   raymac46
  • 3,529 posts
Posted 06 February 2017 - 09:06 AM
https://mxlinux.org/wiki/system/uefi
This deals more with installation, but I would assume if you have an option for boot priority (F12 or F8) you'll be able to get a USB stick running.
Registered Linux User 445659
#54 OFFLINE   sunrat
sunrat
  • 5,431 posts
Posted 06 February 2017 - 05:15 PM
UEFI boot works fine on my system. Additionally to the advice in the wiki, I had to change one setting in the boot setup menu to "Other OS" from "Windows".
For some reason GRUB did not install properly and defaulted to KXStudio GRUB, from which I could boot MX-16. That was easily fixed by reinstalling GRUB from the booted MX.
Main points are -
- GPT partition scheme unless you want to use Legacy (CSM) boot.
- Disable Secure Boot
- Disable Fast Boot
- Check for Windows-centric settings.
#55 OFFLINE   abarbarian
  • 5,433 posts
Posted 07 February 2017 - 06:59 AM
Main points are -
- Disable Fast Boot
Thanks guys. My pc is set up for dual booting with linux.  I am trying to run MX-16 as a LIVE USB on it which is not working. Your information has I think helped. The version of MX-16 I have is a 32Bit as that is all the Dell can run and so that is what I have on the usb. Seems that 32Bit versions need LEGACY bios and my Skylake pc is set up as UEFI.
So I will have a fiddle and see if i can get this to work.
MX-15 32-bit UEFI Installation
Scenario: All Linux Environment
Use Steps 1 & 2 for installation preparation.
Step 3: Linux Installation
The MX-15 32-bit Linux installer requires the following UEFI firmware configuration. Make your changes by access your UEFI firmware Setup utility.
  • Legacy BIOS Boot ON. Enable BIOS compatibility boot mode (e.g., CSM, Legacy BIOS OPROM).
:shifty:
Edited by abarbarian, 07 February 2017 - 07:00 AM.
Install ARCH
#56 ONLINE   raymac46
  • 3,529 posts
Posted 07 February 2017 - 05:19 PM
Just set up MX-16 in a Virtual Machine as a guest on Windows 10. It looks terrific. All the Guest Additions were set up so I got a full screen right out of the box.
#57 OFFLINE   abarbarian
  • 5,433 posts
Posted 15 February 2017 - 08:48 AM
Figured out how to get my usb-c showing up in the boot menu for my Skylake mobo. Wrote the MX-16 to the usb and when I try to use it it stalls and shows a warning,
"isolinux.bin missing or corrupt"
tried writing the image to the stick twice and the .iso passes its MD5 check.
What am I missing folks. Apart from several grey cells. :hmm:
Install ARCH
#58 OFFLINE   sunrat
sunrat
  • 5,431 posts
Posted 15 February 2017 - 07:08 PM
How did you write the image to usb?
#59 OFFLINE   securitybreach
  • 23,331 posts
Posted 15 February 2017 - 07:30 PM
Yea, it sounds like it may have not been written correctly :thumbsup:
#60 OFFLINE   abarbarian
  • 5,433 posts
Posted 20 February 2017 - 12:28 PM
Well guys I used the "dd" command, same one I use for all similar tasks.
I'll give it another whirl. I only want to see what MX-16 runs like from a usb-c/3 usb stick on a modern Skylake set up just out of interest. :breakfast:
I think I will try another download of the 64 bit to see if that cures the problem.
Install ARCH
Also tagged with one or more of these keywords: mx, mx-16, debian
