réjean Posted July 20, 2015 Share Posted July 20, 2015 (edited) Hi all! I am presently using a live USB Linux Mint trying to repair my filesystem I have very little luck so far; mint / # blkid mint / # lsblk mint / # fsck fsck from util-linux 2.20.1 fsck.ext4: Unable to resolve 'UUID=f0220344-2591-42e6-baf6-e6be49be4071' mint / # fsck /dev/sda fsck from util-linux 2.20.1 e2fsck 1.42.9 (4-Feb-2014) fsck.ext2: No such file or directory while trying to open /dev/sda Possibly non-existent device? mint / # fsck /dev/sdb fsck from util-linux 2.20.1 e2fsck 1.42.9 (4-Feb-2014) fsck.ext2: No such file or directory while trying to open /dev/sdb Possibly non-existent device? mint / # Now I know the partitions and their content are still there; so any suggestion anyone? Like I said in the other post I reinstalled Linux Mint 17 last night hoping it would solve the problem. The installation went well. Grub was installed on /dev/sda but upon rebooting I got the following; Verifying DMI Pool Data... error: no such device: e2f44f52-8fd1-42ca-a661-9f4ad3f86a79. Entering rescue mode grub rescue> Edited July 20, 2015 by réjean Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 20, 2015 Share Posted July 20, 2015 This error means that your using the wrong UUID. error:no such device: e2f44f52-8fd1-42ca-a661-9f4ad3f86a79 Run blkid to find the correct one. Quote Link to comment Share on other sites More sharing options...
réjean Posted July 20, 2015 Author Share Posted July 20, 2015 (edited) Thanks josh! Now what next? mint@mint ~ $ sudo blkid /dev/loop0: TYPE="squashfs" /dev/sda1: LABEL="System Reserved" UUID="eaa8c559-8024-4c8f-914b-8cbf464b6d51" TYPE="ext4" /dev/sda2: UUID="47387537-47f2-4568-a284-9f25dd5bea8f" TYPE="ext4" /dev/sda5: UUID="f0220344-2591-42e6-baf6-e6be49be4071" TYPE="ext4" /dev/sda6: UUID="f7c60a6b-e33b-45c1-b201-44c22763fb9e" TYPE="swap" /dev/sda7: UUID="443E317E38E48AC0" TYPE="ntfs" /dev/sda8: UUID="349286d9-8878-4184-b72c-9e5e0eb65da0" TYPE="ext4" /dev/sda9: UUID="3f6efbd4-f3fc-43dd-872c-2ee4305edc10" TYPE="ext4" /dev/sda10: UUID="c7b8ba1f-6e0f-426c-8676-d13d836abf69" TYPE="ext4" /dev/sda11: UUID="cf78ad89-6415-48f8-b9dc-93401c01c180" TYPE="ext4" /dev/sda12: UUID="0e5a3c08-8c60-4141-a232-95acc51ef912" TYPE="ext4" /dev/sda13: UUID="9cfd579a-1e91-4bba-a4c9-d2a10a0d74af" TYPE="ext4" /dev/sda14: UUID="5498d2cf-9d68-4f8d-9ca2-8240974d5b37" TYPE="ext4" /dev/sda15: UUID="cafc9f4a-a7b9-4d46-91d3-e08a816800fb" TYPE="ext4" /dev/sda16: UUID="98abcdf8-436a-4d9b-a9fd-612b33f8e42c" TYPE="ext4" /dev/sda17: UUID="f2504d90-fded-4aac-8d1d-00da1c9ab495" TYPE="ext4" /dev/sda18: UUID="ae2a887f-a535-42c9-8974-40a9797b3808" TYPE="ext4" /dev/sdb1: UUID="FEE828A9E82861DF" TYPE="ntfs" /dev/sdb5: UUID="02E456D9E456CE93" TYPE="ntfs" /dev/sdb6: UUID="8814195614194898" TYPE="ntfs" /dev/sdc1: LABEL="Linux Mint 17.2 MATE 64-bit" TYPE="iso9660" /dev/sdc2: SEC_TYPE="msdos" UUID="3006-9304" TYPE="vfat" mint@mint ~ $ I tried; mint mint # mkdir /mnt/mint mint mint # mount f0220344-2591-42e6-baf6-e6be49be4071 /mnt/mint mount: special device f0220344-2591-42e6-baf6-e6be49be4071 does not exist mint mint # getting better; mint mint # mount -t ext4 /dev/sda5 /mnt/mint mint mint # and; mint mint # os-prober /dev/sda1:openSUSE 13.2 (x86_64):SuSE:linux /dev/sda11:Ubuntu 14.04.2 LTS (14.04):Ubuntu:linux /dev/sda14:Mageia 5 (5):Mageia:linux /dev/sda16:PCLinuxOS:PCLinuxOS:linux /dev/sda17:Manjaro Linux (0.8.13):ManjaroLinux:linux /dev/sda5:Linux Mint 17.2 Rafaela (17.2):LinuxMint:linux /dev/sdb1:Windows 7 (loader):Windows:chain grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map. mint mint # but; mint mint # grub-install /dev/sda grub-probe: error: failed to get canonical path of `/cow'. Installing for i386-pc platform. grub-install.real: error: failed to get canonical path of `/cow'. mint mint # update-grub /usr/sbin/grub-probe: error: failed to get canonical path of `/cow'. mint mint # and I have; mint ~ # df Filesystem 1K-blocks Used Available Use% Mounted on /cow 4087716 92780 3994936 3% / udev 4076344 12 4076332 1% /dev tmpfs 817544 1436 816108 1% /run /dev/sdc 1664640 1664640 0 100% /cdrom /dev/loop0 1622912 1622912 0 100% /rofs none 4 0 4 0% /sys/fs/cgroup tmpfs 4087716 4 4087712 1% /tmp none 5120 0 5120 0% /run/lock none 4087716 76 4087640 1% /run/shm none 102400 36 102364 1% /run/user /dev/sda5 22029812 4958936 15928760 24% /mnt/mint /dev/sda1 32380312 7013604 24293376 23% /mnt/suse Edited July 20, 2015 by réjean Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 20, 2015 Share Posted July 20, 2015 You cannot reinstall grub from the livecd environment without chrooting into whatever installation you want to install grub from sudo mount /dev/sda1 /mntsudo chroot /mnt sudo update-grub2 Replace sda1 with whatever partition your trying to install grub from. Quote Link to comment Share on other sites More sharing options...
réjean Posted July 20, 2015 Author Share Posted July 20, 2015 I tried installing and using "boot repair" ... E: Some index files failed to download. They have been ignored, or old ones used instead. mint ~ # apt-get install -y boot-repair && boot-repair Reading package lists... Done Building dependency tree Reading state information... Done The following extra packages will be installed: boot-sav glade2script Suggested packages: mbr mdadm clean-ubiquity boot-info os-uninstaller Recommended packages: pastebinit boot-sav-extra efibootmgr The following NEW packages will be installed: boot-repair boot-sav glade2script 0 upgraded, 3 newly installed, 0 to remove and 150 not upgraded. Need to get 446 kB of archives. After this operation, 2,925 kB of additional disk space will be used. Get:1 http://ppa.launchpad.net/yannubuntu/boot-repair/ubuntu/ trusty/main glade2script all 3.2.2~ppa47~saucy [42.3 kB] Get:2 http://ppa.launchpad.net/yannubuntu/boot-repair/ubuntu/ trusty/main boot-sav all 4ppa33 [392 kB] Get:3 http://ppa.launchpad.net/yannubuntu/boot-repair/ubuntu/ trusty/main boot-repair all 4ppa33 [11.6 kB] Fetched 446 kB in 1s (284 kB/s) Selecting previously unselected package glade2script. (Reading database ... 175257 files and directories currently installed.) Preparing to unpack .../glade2script_3.2.2~ppa47~saucy_all.deb ... Unpacking glade2script (3.2.2~ppa47~saucy) ... Selecting previously unselected package boot-sav. Preparing to unpack .../boot-sav_4ppa33_all.deb ... Unpacking boot-sav (4ppa33) ... Selecting previously unselected package boot-repair. Preparing to unpack .../boot-repair_4ppa33_all.deb ... Unpacking boot-repair (4ppa33) ... Processing triggers for man-db (2.6.7.1-1ubuntu1) ... Processing triggers for desktop-file-utils (0.22-1ubuntu1) ... Processing triggers for mime-support (3.54ubuntu1.1) ... Setting up glade2script (3.2.2~ppa47~saucy) ... Setting up boot-sav (4ppa33) ... Setting up boot-repair (4ppa33) ... Error creating proxy: The connection is closed (g-io-error-quark, 18) Error creating proxy: The connection is closed (g-io-error-quark, 18) Error creating proxy: The connection is closed (g-io-error-quark, 18) Error creating proxy: The connection is closed (g-io-error-quark, 18) Quote Link to comment Share on other sites More sharing options...
réjean Posted July 20, 2015 Author Share Posted July 20, 2015 I still have a problem with cow; mint ubuntu # cd /mnt/suse mint suse # ls bin dev home lib64 mnt proc root sbin srv tmp var boot etc lib lost+found opt read-write run selinux sys usr mint suse # grub-install --root-directory=mnt/suse/boot /dev/sda grub-probe: error: failed to get canonical path of `/cow'. Installing for i386-pc platform. Installation finished. No error reported. mint suse # update-grub2 /usr/sbin/grub-probe: error: failed to get canonical path of `/cow'. mint suse # Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 20, 2015 Share Posted July 20, 2015 Did you try to chroot in and repair as noted above? Quote Link to comment Share on other sites More sharing options...
réjean Posted July 20, 2015 Author Share Posted July 20, 2015 Yes ! mint@mint ~ $ sudo mount /dev/sda1 /mntmint@mint ~ $ sudo chroot /mnt:/ # sudo update-grub2sudo: update-grub2: command not found:/ # [code] Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 20, 2015 Share Posted July 20, 2015 Well that looks like you do not have grub installed on that partition. Personally I would just install a distro and have grub find the other distros versus trying to fix this mess. You will probably not fix this anyway so you may as well take the easy route. Unless you have some file you need, I would wipe it all. Quote Link to comment Share on other sites More sharing options...
Hedon James Posted July 20, 2015 Share Posted July 20, 2015 Yes ! mint@mint ~ $ sudo mount /dev/sda1 /mnt mint@mint ~ $ sudo chroot /mnt :/ # sudo update-grub2 sudo: update-grub2: command not found :/ # A little above my pay grade, as I don't completely understand what you're doing, and I'm a little lost with your bazillion partitions, but 2 quick comments which may help or may have absolutely nothing to do with your issue: 1. isn't a hash prompt indicative of "root" users? why are you typing "sudo" when you're already root 2. while you may have version 2 of grub, I believe the package is just called grub; if you're already root, you want to type update-grub if you're a regular user with admin privileges, you want to type sudo update-grub If neither of the above are helpful, I believe Yanni's Boot Repair package would be helpful here, which can be installed from a Live environment: http://www.ubuntugeek.com/boot-repair-simple-tool-to-repair-frequent-boot-problems.html I would give that a shot before I take up SB on his advice. JMO... 4 Quote Link to comment Share on other sites More sharing options...
amenditman Posted July 20, 2015 Share Posted July 20, 2015 HedonJames nailed it. As usual, syntax errors will kill what you are trying to do. 3 Quote Link to comment Share on other sites More sharing options...
réjean Posted July 20, 2015 Author Share Posted July 20, 2015 Yeah! Boot repair worked! I don't know why it didn't this morning but this time it did. I'm replying from PCLinuxOS but I saw all the entries in the bootloader and I assume the MBR has been fixed completely. Thanks everyone! I can tell you 2 things; 1. I have 2X 1tb hd with a 500 GB storage partition on each and I'll make sure my important stuff is in both. 2. I will unplugged the hd I use the most (sda) before I attempt to install Arch and install it on the other drive which as only Win XP which is broken and Win 7 which I use only for playing games once in a while. about the syntax; I used 'sudo' only once as root after I had chrooted and it was kindda out of despair. 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 20, 2015 Share Posted July 20, 2015 good deal 1 Quote Link to comment Share on other sites More sharing options...
Hedon James Posted July 21, 2015 Share Posted July 21, 2015 Yeah! Boot repair worked! I don't know why it didn't this morning but this time it did. I'm replying from PCLinuxOS but I saw all the entries in the bootloader and I assume the MBR has been fixed completely. Thanks everyone! I can tell you 2 things; 1. I have 2X 1tb hd with a 500 GB storage partition on each and I'll make sure my important stuff is in both. 2. I will unplugged the hd I use the most (sda) before I attempt to install Arch and install it on the other drive which as only Win XP which is broken and Win 7 which I use only for playing games once in a while. about the syntax; I used 'sudo' only once as root after I had chrooted and it was kindda out of despair. we've all been there once or twice. and when I say "we", what I really mean is "me". glad you got it worked out, as that would have a real beast to start over and reconstruct! 2 Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted July 21, 2015 Share Posted July 21, 2015 Trash my mbr? H3LL NO! Ain't never done that... more than 10 or 50 times. 2 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 21, 2015 Share Posted July 21, 2015 Trash my mbr? H3LL NO! Ain't never done that... more than 10 or 50 times. Yeah but most of us are not dealing with 10+ distros... It's a lot easier with 1 or 2 OSs 1 Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted July 21, 2015 Share Posted July 21, 2015 Once I got the hang of tending to all the animals on my distro farm back then, I was OK. I actually haven't trashed an mbr since around 2006 sometime. Now watch... now that I've said that, I'll trash the one on my shop system when I try to install that FreeBSD I downloaded/burned the other night. 1 Quote Link to comment Share on other sites More sharing options...
Hedon James Posted July 21, 2015 Share Posted July 21, 2015 Once I got the hang of tending to all the animals on my distro farm back then, I was OK. I actually haven't trashed an mbr since around 2006 sometime. Now watch... now that I've said that, I'll trash the one on my shop system when I try to install that FreeBSD I downloaded/burned the other night. oh, you have sooo jinxed yourself! might wanna bookmark this thread and have your favorite LiveCD on standby! 2 Quote Link to comment Share on other sites More sharing options...
réjean Posted July 21, 2015 Author Share Posted July 21, 2015 Trash my mbr? H3LL NO! Ain't never done that... more than 10 or 50 times. Yeah but most of us are not dealing with 10+ distros... It's a lot easier with 1 or 2 OSs Well only 6 to be precise with their own /home partition each plus a 500 Gb storage. I didn't care too much about the dozen or two .iso files I keep for playing in Virtual Box but it's the rest I was most concerned about ( photos from friends and relatives, bookmarks, etc.) I used to put them on a DVD every 6 months or so but with 2 Tb hds I thought I was ok until I realized that I should have them duplicated on each hard drive in case I have to format a whole drive. Boot Repair is definitely a software to keep in mind if something similar happens again, which it will. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 21, 2015 Share Posted July 21, 2015 Well I have a bunch of OSs and distros in vbox: 1 Quote Link to comment Share on other sites More sharing options...
réjean Posted July 21, 2015 Author Share Posted July 21, 2015 Once I got the hang of tending to all the animals on my distro farm back then, I was OK. I actually haven't trashed an mbr since around 2006 sometime. Now watch... now that I've said that, I'll trash the one on my shop system when I try to install that FreeBSD I downloaded/burned the other night. oh, you have sooo jinxed yourself! might wanna bookmark this thread and have your favorite LiveCD on standby! and remember about Boot Repair. I used to be able to repair my problems with http://www.supergrubdisk.org/ (never heard of Rescatux before but it looks cool) but this time it wouldn't work for me. Also before he passed away we ( or I should say me because he saved my butt so many times) had Bruno to come to the rescue ( not that you, Eric, Josh and many others are not doing your best. I really appreciate your help and dedication). 2 Quote Link to comment Share on other sites More sharing options...
réjean Posted July 21, 2015 Author Share Posted July 21, 2015 Well I have a bunch of OSs and distros in vbox: Wow That's a lot too. Is there any way I can get Win 10 (for free) and, like you, just use it in Vbox when my friends and relatives decide to switch to it and mess up there machine, so I can help them. Like I said at the beginning of this thread or the other one I do have Win 7 on the 2nt hd but use it only to play a few games and never online so I don't really need Win 10 for myself. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 21, 2015 Share Posted July 21, 2015 Well you can still get the technical preview and if you have a Windows 7-8.1 license, you can get the upgrade for free. Quote Link to comment Share on other sites More sharing options...
réjean Posted July 21, 2015 Author Share Posted July 21, 2015 Thanks! I do have the technical preview. Quote Link to comment Share on other sites More sharing options...
Hedon James Posted July 21, 2015 Share Posted July 21, 2015 Well I have a bunch of OSs and distros in vbox: I love your dark theme! Very easy to read, plus it looks cool! I also note your Mac OSX Mavericks VM. I've had a hard time installing that one, but not sure we can talk about it here. If we can't, can we PM? Just looking to compare notes and tips & tricks...if we can. I don't want to violate TOS here. 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 21, 2015 Share Posted July 21, 2015 Well I an at work now but I'll hit you up when I get hone around 2200cst Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted July 21, 2015 Share Posted July 21, 2015 Well I have a bunch of OSs and distros in vbox: Virtual doesn't count, you wuss techie. 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 21, 2015 Share Posted July 21, 2015 I see no point in having multiple distros installed versus virtually running them. Heck most servers nowadays are virtual If you have the power, why not use it? Quote Link to comment Share on other sites More sharing options...
burninbush Posted July 22, 2015 Share Posted July 22, 2015 (edited) Yeah! Boot repair worked! I don't know why it didn't this morning but this time it did. I'm replying from PCLinuxOS but I saw all the entries in the bootloader and I assume the MBR has been fixed completely. Thanks everyone! I can tell you 2 things; 1. I have 2X 1tb hd with a 500 GB storage partition on each and I'll make sure my important stuff is in both. 2. I will unplugged the hd I use the most (sda) before I attempt to install Arch and install it on the other drive which as only Win XP which is broken and Win 7 which I use only for playing games once in a while. about the syntax; I used 'sudo' only once as root after I had chrooted and it was kindda out of despair. Great news! Now that it's working again, this would be a good time to take copies of the MBR sector from both disks, and store them on a usbstick. Ideal situation is to find some old but still good usbstick, maybe 512mb, and install onto it a copy of Puppy or Porteus. Test that it boots well, and store your mbr backups on it, along with whatever other important boot files [menu.lst, grub.cfg, etc]. Then put it away and you'll have a first response the next time your mbrs get trashed. #dd if=/dev/sda of=tera1.mbr bs=512 count=1 #dd if=/dev/sdb of=tera2.mbr bs=512 count=1 and to restore just reverse the if and the of labels, for example #dd of=/dev/sda if=tera1.mbr bs=512 count=1 and if you later change anything in the partition layouts, then do a new mbr capture. Edited July 22, 2015 by burninbush 2 Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted July 22, 2015 Share Posted July 22, 2015 I see no point in having multiple distros installed versus virtually running them. Heck most servers nowadays are virtual If you have the power, why not use it? Feel the force, Luke! 2 Quote Link to comment Share on other sites More sharing options...
