Guest LilBambi Posted June 15, 2013 Share Posted June 15, 2013 A friend of ours recently got a Windows 8 desktop computer. He has been having issues with "Out of Memory" error which shouldn't be happening. It's a 64-bit Windows 8 with 6 GB RAM. He is not much of a gamer or I would suggest he try some of the Minecraft Java batch file suggestions out there to restrict memory of the game. He just mainly listens to music, surfs the Internet, talks in chat, and does email, mostly. He says that Apple's iTunes is constantly crashing. I suggested that he uninstall iTunes, reboot, and reinstall it to see if that helped. He can't do without iTunes as he has an iPad and has his music local to sync with it. Also suggested that he do a malware scan with Malwarebytes Antimalware to see if it finds anything. Anything else I should suggest? Quote Link to comment Share on other sites More sharing options...
Corrine Posted June 15, 2013 Share Posted June 15, 2013 Did you see Stephen's suggestion about MediaMonkey as a replacement for iTunes at Sysnative (if the problem is iTunes)? Glitchy Itunes 1 Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted June 16, 2013 Share Posted June 16, 2013 Thanks Corrine. I am not at all sure that's what he wants to do. He wants to get this working. And it should. Quote Link to comment Share on other sites More sharing options...
