sunrat Posted September 19, 2017 Share Posted September 19, 2017 You know how the swap UUID can get changed and mismatch fstab when you install a new OS in a multiboot setup? Here's a command to check if fstab swap entry is correct: if [ $(grep swap /etc/fstab | awk '{print $1}') == $(blkid | grep swap| awk '{print $2}'|sed s/'"'//g) ]; then echo "All is good";else echo "Swap UUID is different to fstab";fi I saved it to my Zim Desktop Wiki repository of handy tips and commands. Funny story how I came to this - someone posted a command on Debian User Forums purporting to do the same thing. I had a quick look at the command and realised it was comparing 2 identical commands so couldn't possibly flag a mismatch. Of course I had to fix it. 5 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted September 20, 2017 Share Posted September 20, 2017 Well it has never happened to me, but I am all in for insurance so have added it to my ArchWay Zim. An I very nearly understood the command which worries me a tad. I am still a bit confused about some aspects of code writing 1 Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted September 20, 2017 Share Posted September 20, 2017 I still use the /dev/sd* nomenclature on my machines, so I don't have the UUID mixup issue. Quote Link to comment Share on other sites More sharing options...
