V.T. Eric Layton Posted October 6, 2015 Share Posted October 6, 2015 I posted somewhere around here about recently obtaining a little Dell D420 netbook. I installed Slack in it and have it on the counter in my kitchen. When I received the little lappy, I was told that the battery was bad. I confirmed that. When I turned the machine on while plugged into the AC adapter, it would boot/run normally, but the usually green battery light was a blinking yellow. $ cat /proc/acpi/battery/BAT0/state [indent=2]present: yes[/indent] [indent=2]capacity state: OK[/indent] [indent=2]charging state: charging[/indent] [indent=2]present rate: 1 mA[/indent] [indent=2]remaining capacity: 1410 mAh[/indent] [indent=2]present voltage: 10411 mV [/indent] Now, the above was with the adapter that I received with the laptop. I plugged in the adapter that I normally use with my ericslaptop01 on my office desk. The laptop battery immediately came on green solid and the graphical indicator (xfce4-power-manager) says that the battery is at 32% and charging with full charge in 1hr, 20 minutes. Here's the command line output for this adapter: [size=4]$ cat /proc/acpi/battery/BAT0/state[/size] [indent=2]present: yes[/indent] [indent=2]capacity state: OK[/indent] [indent=2]charging state: charging[/indent] [indent=2]present rate: 2485 mA[/indent] [indent=2]remaining capacity: 1945 mAh[/indent] [indent=2]present voltage: 11225 mV [/indent] It's obvious from the difference in the current draw on the original adapter (1 ma) compared to the second adapter (2485 mA) that there is some sort of AC adapter issue? Right? Odd, though... I checked the output of the original adapter. It was 19.95 vdc, which is correct. Even though it will run the little netbook on AC just fine, it doesn't seem to be supplying enough current to charge the battery. Hmm... odd. I think I'm going to try that original adapter on another laptop (my Inspiron 1521) and see what happens. Stand by... Nope. Current draw on charge still 1 mA. I guess that adapter is caputski. I can use it to power the laptop, but it doesn't have enough juice to charge the battery. It might have enough to maintain the battery when the unit is off, though. We'll see... Later... ===== You know, I HATE the updates to the board software a few months back that caused all these tag display bugs in the UBBcode. It just SUCKS! I'm not even going to edit to fix the above. I don't care anymore. 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted October 6, 2015 Share Posted October 6, 2015 Neat. I assume by adapter, you mean the cable and brick or what? Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted October 6, 2015 Author Share Posted October 6, 2015 Yup. This thing... Quote Link to comment Share on other sites More sharing options...
lewmur Posted October 6, 2015 Share Posted October 6, 2015 I posted somewhere around here about recently obtaining a little Dell D420 netbook. I installed Slack in it and have it on the counter in my kitchen. When I received the little lappy, I was told that the battery was bad. I confirmed that. When I turned the machine on while plugged into the AC adapter, it would boot/run normally, but the usually green battery light was a blinking yellow. $ cat /proc/acpi/battery/BAT0/state [indent=2]present: yes[/indent] [indent=2]capacity state: OK[/indent] [indent=2]charging state: charging[/indent] [indent=2]present rate: 1 mA[/indent] [indent=2]remaining capacity: 1410 mAh[/indent] [indent=2]present voltage: 10411 mV [/indent] Now, the above was with the adapter that I received with the laptop. I plugged in the adapter that I normally use with my ericslaptop01 on my office desk. The laptop battery immediately came on green solid and the graphical indicator (xfce4-power-manager) says that the battery is at 32% and charging with full charge in 1hr, 20 minutes. Here's the command line output for this adapter: [size=4]$ cat /proc/acpi/battery/BAT0/state[/size] [indent=2]present: yes[/indent] [indent=2]capacity state: OK[/indent] [indent=2]charging state: charging[/indent] [indent=2]present rate: 2485 mA[/indent] [indent=2]remaining capacity: 1945 mAh[/indent] [indent=2]present voltage: 11225 mV [/indent] It's obvious from the difference in the current draw on the original adapter (1 ma) compared to the second adapter (2485 mA) that there is some sort of AC adapter issue? Right? Odd, though... I checked the output of the original adapter. It was 19.95 vdc, which is correct. Even though it will run the little netbook on AC just fine, it doesn't seem to be supplying enough current to charge the battery. Hmm... odd. I think I'm going to try that original adapter on another laptop (my Inspiron 1521) and see what happens. Stand by... Nope. Current draw on charge still 1 mA. I guess that adapter is caputski. I can use it to power the laptop, but it doesn't have enough juice to charge the battery. It might have enough to maintain the battery when the unit is off, though. We'll see... Later... ===== You know, I HATE the updates to the board software a few months back that caused all these tag display bugs in the UBBcode. It just SUCKS! I'm not even going to edit to fix the above. I don't care anymore. A/C bricks have gotten so cheap on eBay that I'd buy one just on spec. 1 Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted October 6, 2015 Author Share Posted October 6, 2015 A/C bricks have gotten so cheap on eBay that I'd buy one just on spec. Yup. Found one just a few minutes ago. Brand new Dell OEM 65 Watt just like the original for $11.95 w/ free shipping. Should be here before the end of the week. 3 Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted October 8, 2015 Author Share Posted October 8, 2015 Received that little Dell charger. It's working fine! Wow. I ordered this early on the morning of the 6th. I received it in today's (the 8th) mail. Amazing how fast they ship stuff nowadays. 2 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted October 10, 2015 Share Posted October 10, 2015 Received that little Dell charger. It's working fine! Wow. I ordered this early on the morning of the 6th. I received it in today's (the 8th) mail. Amazing how fast they ship stuff nowadays. Woot!! 1 Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted October 12, 2015 Share Posted October 12, 2015 That is great news! Quote Link to comment Share on other sites More sharing options...
