abarbarian Posted April 1, 2013 Share Posted April 1, 2013 I could not get smplayer to open up files in a 16.9 aspect as a default. I could change the aspect of a file through the usual options but this would only be for the file playing. start a new file and I would have to fiddle about again. This is a pain in the neck. I nearly always watch vids in full screen with no black borders at all. Yes I know doing this can cause some distortion but I have never found this to be a problem for my old eyes. So I found a solution as below which works just fine. Hope it helps folks. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted April 1, 2013 Share Posted April 1, 2013 I prefer to use its backend (mplayer) with the same switch (the rare times it is required) but glad to know that you are able to use cli switches on the gui frontend as well. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted April 1, 2013 Author Share Posted April 1, 2013 Took me some time and a few dead ends and lots of restarts of smplayer before I finally got there. After a fruitless serach in the smplayer files it dawned on me that sm was only a front end for mplayer. So I tried a few hunches but none worked. Googling threw up the answer but it was buried in a lot of misdirection. Must have had nine or ten goes before I got to " -aspect 16.9 ". I'm guessing that is to be found in the mplayer man pages. Which if i was a tad more experienced I would have looked in first.Man pages still scare the stuffing out of me. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted April 1, 2013 Share Posted April 1, 2013 Well the grep command works with man pages as well: man mplayer | grep aspect Or you can google "man mplayer" and then just search the page for aspect or whatever you need: http://www.mplayerhq.../mplayer.1.html Quote Link to comment Share on other sites More sharing options...
abarbarian Posted April 2, 2013 Author Share Posted April 2, 2013 I tried both suggestions and like I said man pages give me the willies. I was looking for a solution to the fact that I can not take screen shots. So I tried, man smplayer | grep screenshot which gave me no output.Then I tried man mplayer | grep screenshot s (-vf screenshot only) Take a screenshot. S (-vf screenshot only) Start/stop taking screenshots. <standard input>:6316: warning [p 52, 13.7i, div `an-div', 0.0i]: cannot adjust line screenshot Allows acquiring screenshots of the movie using slave mode com‐ ration file. Make sure that the screenshot filter is added af‐ have an exact screenshot of what you see on the monitor. -vf ass,screenshot Moves SSA/ASS rendering before the screenshot filter. <standard input>:11483: warning [p 80, 24.7i, div `an-div', 0.0i]: cannot adjust line Which does not make any sense to a mortal like me. I know that in smplayer you can use a keystroke or do it from the drop down menue. However the drop down menue is greyed out and the keystrokes do not work. I had a poke around in config files but could not see what was wrong. I'll have to come back to this at a later stage unless someone has a solution. I found a " input.conf " at " /usr/share/smplayer " which contains ## prevent mplayer from messing up our shortcuts RIGHT invalid_command LEFT invalid_command DOWN invalid_command UP invalid_command PGUP invalid_command PGDWN invalid_command - invalid_command + invalid_command ESC invalid_command ENTER invalid_command SPACE pausing_keep invalid_command HOME invalid_command END invalid_command > invalid_command < invalid_command INS invalid_command DEL invalid_command [ invalid_command ] invalid_command { invalid_command } invalid_command BS invalid_command TAB invalid_command . invalid_command # invalid_command @ invalid_command ! invalid_command 9 invalid_command / invalid_command 0 invalid_command * invalid_command 1 invalid_command 2 invalid_command q invalid_command r invalid_command s invalid_command t invalid_command T invalid_command u invalid_command v invalid_command w invalid_command x invalid_command y invalid_command z invalid_command S invalid_command So I guess that has something to do with my problem but it makes no sense to me. No screenshots is no biggie but it would be nice to have the function. Mind you you folks would get sick of me posting new wallpaper pics if I solve the problem. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted April 2, 2013 Share Posted April 2, 2013 It is simple to take a screenshot in mplayer. First play the video with the -vf switch and the screenshot option: $ mplayer -vf screenshot movie.avi Then hit the s key to take a screenshot. If you want to enable the screenshot function by default, add vf=screenshot to ~/.mplayer/config. I just did it and it worked beautifully Quote Link to comment Share on other sites More sharing options...
abarbarian Posted April 2, 2013 Author Share Posted April 2, 2013 add vf=screenshot to ~/.mplayer/config. I did that and it crashes smplayer. Several files just cause the player to not react and one file I tried gave a error message. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted April 2, 2013 Share Posted April 2, 2013 I did that and it crashes smplayer. Several files just cause the player to not react and one file I tried gave a error message. Well I do not use smplayer but I just installed it and played a couple of files. It worked just fine although the screenshot function does not seem to work. Is there any reason you do you not want to use just mplayer? Quote Link to comment Share on other sites More sharing options...
securitybreach Posted April 2, 2013 Share Posted April 2, 2013 I did that and it crashes smplayer. Several files just cause the player to not react and one file I tried gave a error message. What is the error you are getting and could you post your ~/.mplayer/config file? Quote Link to comment Share on other sites More sharing options...
abarbarian Posted April 2, 2013 Author Share Posted April 2, 2013 (edited) This is the error log /usr/bin/mplayer -noquiet -nofs -nomouseinput -vc ffh264vdpau,ffmpeg12vdpau,ffwmv3vdpau,ffvc1vdpau,ffodivxvdpau, -lavdopts threads=2 -sub-fuzziness 1 -identify -slave -vo vdpau -ao alsa:device=hw=0.0 -nokeepaspect -hardframedrop -nodr -double -input nodefault-bindings:conf=/dev/null -stop-xscreensaver -wid 16777247 -monitorpixelaspect 1 -ass -embeddedfonts -ass-line-spacing 0 -ass-font-scale 1 -ass-styles /home/bloodaxe/.config/smplayer/styles.ass -fontconfig -font Arial -subfont-autoscale 0 -subfont-osd-scale 20 -subfont-text-scale 20 -subcp enca:en:ISO-8859-1 -subpos 100 -volume 40 -cache 2048 -osdlevel 0 -idx -noslices -channels 2 -af scaletempo,equalizer=0:0:0:0:0:0:0:0:0:0 -softvol -softvol-max 110 -aspect 16:9 /home/bloodaxe/Downloads/T.Files.Fin/MEM0RIES (Katsuhiro Otomo-1995-extra) [DVDRip XviD-ITA ac3 JAP mp3-MultiSub] [skart]/MEM0RIES (Katsuhiro Otomo-1995) [DVDRip XviD-ITA ac3 JAP mp3] [skart].avi parse error at line 11 An this is my mplayer config. # Write your default config options here! vo=vdpau vc=ffmpeg12vdpau,ffwmv3vdpau,ffvc1vdpau,ffh264vdpau,ffodivxvdpau, # Use this for a widescreen monitor, non-square pixels. monitoraspect=16:9 vf=screenshot Reason for smplayer is it is a GUI. me no do cli. Mplayer has a GUI but you have to build it yourself. All I want is a simple player with a couple of simple features.The smplayer site is not very informative. I like Parole but it does not have all the features I want. I may try this XT-7-player. https://aur.archlinu...ges/xt7-player/ Thanks for all your efforts. Edited April 2, 2013 by abarbarian Quote Link to comment Share on other sites More sharing options...
securitybreach Posted April 2, 2013 Share Posted April 2, 2013 If you want a gui app, try VLC!!! VLC will play anything and it is minimal but it also has a ton of functions built in (streaming etc.) Quote Link to comment Share on other sites More sharing options...
securitybreach Posted April 2, 2013 Share Posted April 2, 2013 What are these? vc=ffmpeg12vdpau,ffwmv3vdpau,ffvc1vdpau,ffh264vdpau,ffodivxvdpau I do not use any of that on my config and it plays everything fine: # Write your default config options here! "ao=alsa" vf=screenshot Quote Link to comment Share on other sites More sharing options...
abarbarian Posted April 2, 2013 Author Share Posted April 2, 2013 vc=ffmpeg12vdpau,ffwmv3vdpau,ffvc1vdpau,ffh264vdpau,ffodivxvdpau Ain't got a clue they were in the file. I'm trialling that x-7-player, just installed it. Looks to be something I can get along with, maybe. There is screenshot function. Will it work ? Might be able to tell if I could find any xt-7-player folders or files apart fromthe ones mentioned in the package build. Oh well onward and threshing about back in the mire. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted April 2, 2013 Author Share Posted April 2, 2013 http://i.imgur.com/tFnJQ9i.jpg Well I got a screenshot from xt-7. Tried with and without vf=screenshot An got a shot both ways, so I deleted it from the config. I'm liking xt-7. Now if only I could find its config file. That will have to be a hunt for tommorow. Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted April 3, 2013 Share Posted April 3, 2013 Another vote for vlc (video lan client) that includes a boat load of codecs. Or GraphicMinimalistic Player (GMPlayer) and GMPlayer ... although it looks to have changed a bit since I used it last. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted April 3, 2013 Author Share Posted April 3, 2013 VLC yup it is a neat program and it can do loads of stuff but I ain't keen. Might give GMPlayer a go one day.Xt-7-player seems to fit the bill for me so I think I will give it a longer trial. Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted April 3, 2013 Share Posted April 3, 2013 Actually, Xt-7-player is just another GUI for MPlayer, like GMPlayer. And looks pretty nice from the Features page. GMPlayer has changed quite a bit from the last time I used it and not sure I like the direction it's gone. Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted April 3, 2013 Share Posted April 3, 2013 Oh, wait. I just didn't like the skins used for GMPlayer on the page. They have no screen shots like they used to. Wish they still had screenshots. Likely still just the great GMPlayer it always was. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted April 3, 2013 Author Share Posted April 3, 2013 Ta LiBambi. Knew it was just a frontend. That was what I was after. Xt-7-player seems neat apart from the cruddy file choosing system. Early days in testing though and there may be a work around. I have not investigated the "library" feature yet which may be an answer. Apart from that it is looking a keeper. Oh, wait. I just didn't like the skins used for GMPlayer on the page. They have no screen shots like they used to. Wish they still had screenshots. Likely still just the great GMPlayer it always was. Or GraphicMinimalistic Player (GMPlayer) and GMPlayer ... although it looks to have changed a bit since I used it last. Which GMPlayer are you talking about ? Or are they both the same thing ? Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted April 3, 2013 Share Posted April 3, 2013 I like that it doesn't automatically do the Library feature. I like a player only. Seems to be the same thing but different skins maybe. LOL! Hard to tell without screenshots on the project pages over at sourceforge. They tend to get slugged down when you add library features. I don't use the Library feature in Winamp either. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted April 3, 2013 Author Share Posted April 3, 2013 I hear you about library's. The Library feature in xt-7 is pants for me. The playlist feature will do very nicely as I tend to do anamie series though it is still a tad lacking in subtlty for me. The ability for a screenshot function that works otb is great. Heres another one. http://i.imgur.com/12vAbuo.jpg Ruorouni Kenshin. Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted April 3, 2013 Share Posted April 3, 2013 Exactly. I like the advanced playlist functionality but not the library part. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted April 3, 2013 Author Share Posted April 3, 2013 I did think of a way to utilise the library. If like me you have several series on the go at once. You could have one folder as the library and one or several folders as playlists. One click folder opening instead of several. Xt-7 seems to be light on resources. With me dual core running at 1 Ghz here is a screen shot, link brings up full size http://i.imgur.com/ag8LaMq.png Quote Link to comment Share on other sites More sharing options...
