ichase Posted December 22, 2012 Share Posted December 22, 2012 In the process of installing 64 bit Arch Linux on one of my laptops. When I try to install wireless_tools it fails because Gaetan Bisson's signature keeps failing. I have done the following: pacman-key --init pacman-key --populate archlinux pacman-key --refresh keys **Which fails because key 048F79BC389414FA2E12FB72399B3580B79583C5 not found on keyserver** I even ran a script that Gaeton mentioned in a thread I found curl https://archlinux.org/ {developers,trustedusers}/ | awk -F|" '(/pgp.mit.edu/) {sub(/.*search=0x/,"");print $1}' | xargs pacman-key --recv-keys But that comes back with --recv-keys requires an argument. So I do a -u at the end to update the trustdb of pacman but that comes back with curl: (6) Could not resolve host: developers; Name or service not known curl: (6) Could not resolve host: trustedusers; Name or service not known gpg: missing argument for option "-u" ==> ERROR: Remote key not fetched correctly from keyserver Did not run into this problem last week when I installed 32 bit arch on an old HP. Any thoughts? Thanks, Ian Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted December 22, 2012 Share Posted December 22, 2012 Does this help? Quote Link to comment Share on other sites More sharing options...
securitybreach Posted December 22, 2012 Share Posted December 22, 2012 I would follow that link that Fran gave as it has a few suggestions/fixes for this issue. Quote Link to comment Share on other sites More sharing options...
ichase Posted December 22, 2012 Author Share Posted December 22, 2012 Just changing siglevel to None fixed the issue. I should have known that. Was looking to deep into the issue instead of looking for the simple solution. Thank you 1 Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted December 23, 2012 Share Posted December 23, 2012 Glad one of the suggestions in the link worked for you! I hear ya! Love simple fixes! Quote Link to comment Share on other sites More sharing options...
ichase Posted December 23, 2012 Author Share Posted December 23, 2012 Here on my 64 bit Arch Linux lappy, Firefox is "synced" up with my other lappy and all is well. A few small things I need to figure out but so far, running well. 1 Quote Link to comment Share on other sites More sharing options...
