imranj Posted March 30, 2003 Share Posted March 30, 2003 Hi ,ppl i have by mistakenly nuked my partition where all the software copies and mail archives where stored say d:now what happened was i wanted the d: to be merged with e:, so used partiton magic to do so, but d: has some errorsit refused to carry out the partition merger, which is fine, i could have gone for chkdisk but before i could do thatmy d: just disappeared from the drive, although its still intact i can in now way re-assign the drive letter to it.So before i go nuking it for good i want to retrieve the data, so is their any free software which can achieve the objectivein the mean time as i dont have any cash for making a new purchase....? Quote Link to comment Share on other sites More sharing options...
Guest ComputerBob Posted March 30, 2003 Share Posted March 30, 2003 Yikes, that's scary stuff! Sorry to hear about your problem. You didn't say whether your drive was FAT32 or NTFS. but WebAttack has several commercial data recovery applications -- some of them include a free trial:http://www.webattack.com/Shareware/system/...arecovery.shtmlThey also have a few freeware data recovery applications:http://www.webattack.com/Freeware/system/f...arecovery.shtmlI hope you can find one that solves your problem quickly! Quote Link to comment Share on other sites More sharing options...
Peachy Posted March 31, 2003 Share Posted March 31, 2003 Use ptedit from the Partition Magic boot disk. Look at your partitions and check that they have the correct partition type and the sizes are correct. Your data is still there, but the MBR may no longer be correct. Quote Link to comment Share on other sites More sharing options...
Guest ThunderRiver Posted March 31, 2003 Share Posted March 31, 2003 If you know how to use Linux, you could get Knoppix from http://www.knoppix.net/ Boot Knoppix off the CD, and then mount the partitions either FAT32 or NTFS, and then try to move all the files from the faulty partitions to a new one. Please keep in mind that it is very very risky to copy files to NTFS partitions because the Write feature is not very reliable. I would suggest you copy all your files to a FAT32 partitions. Quote Link to comment Share on other sites More sharing options...
