willie_in_pr Posted June 21, 2003 Share Posted June 21, 2003 loadqm, is there a way to keep it from loading? I know it is part of msn messenger and I have messenger only load when I want it to but why does loadqm load without messenger and i can't find a way to stop it. every time I stop it it comes back on next reboot. Quote Link to comment Share on other sites More sharing options...
Autotec Posted June 21, 2003 Share Posted June 21, 2003 The easiest way is to click Start, then Run. Type: msconfig and click OK. Click the last tab on the right labeled "Startup". You'll find it in there. Just uncheck the box next to it and be sure to click "Apply". It's not really necessary that you reboot right then. That ought to do it Quote Link to comment Share on other sites More sharing options...
willie_in_pr Posted June 21, 2003 Author Share Posted June 21, 2003 thanks autotec I think that will do the trick. I also did a search for loadqm on my harddrive and found the loadqm.exe file and deleted it between the two I hope it is gone forever, thanks Quote Link to comment Share on other sites More sharing options...
Autotec Posted June 21, 2003 Share Posted June 21, 2003 You're welcome. I'm glad it helped Quote Link to comment Share on other sites More sharing options...
