rakemup Posted November 7, 2005 Share Posted November 7, 2005 Helpstartx gets nowhereI did an FTP install of the X86.64 version of Mandriva 2006.My kernel (uname -r) shows 2.6.12-12mdkI downloaded via urpmi: kernel-source 2.6-2.6.12-12mdkIs that the correct source file? I cannot find an exact souce named "kernel-source 2.6.12-12mdk"thanks! Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 7, 2005 Share Posted November 7, 2005 Hi RakemupYou did get the right kernel-source okay ! . . . No worries there.Could you boot up to the text-console and type "root" to login and then type "XFdrake" . . you will get the "configure X tool" . . . . first try if the "test" works with the default driver the wizard picks for you . . . . if it does not, look in the "xorg" section ( totally at the bottom of the list for the graphics cards ) . . there is an "nv-generic" one . . . . please try if that one works . . . . If even that one refuses to work use the "vesa" driver . . . that one is 100% sure to work. BrunoPS: Did you get a GUI before installing the Nvidia drivers ? Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 7, 2005 Author Share Posted November 7, 2005 The vesa driver worked --- momentarily. Now when I boot up I get the splash screen for 1/2 second and then a blank screen for 4 seconds over and over. Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 7, 2005 Share Posted November 7, 2005 I need some more info Rakemup . . . . . 1). You say the "vesa" driver works . . . but how can you then still get the Nvidia splash ? 2). Did you get a GUI before you installed the Nvidia drivers ?3). What driver did you download ? 4). During the install of the driver did you say "No" to the suggestion getting the kernel from Nvidia ? ( Because you did have the source yourself )5). If you reset it to use the "vesa" driver again . . does it boot into a GUI ? Bruno Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 7, 2005 Author Share Posted November 7, 2005 I need some more info Rakemup . . . . . 1). You say the "vesa" driver works . . . but how can you then still get the Nvidia splash ? 2). Did you get a GUI before you installed the Nvidia drivers ?3). What driver did you download ? 4). During the install of the driver did you say "No" to the suggestion getting the kernel from Nvidia ? ( Because you did have the source yourself )5). If you reset it to use the "vesa" driver again . . does it boot into a GUI ? BrunoI'm not getting the Nvidia splash (getting Mandriva2006 background)have not gotten a gui since installing M2006downloaded NVIDIA-linux-x86_64-1.0-7676-pkg2.runI think I said yes to the 'get kernel from Nvidia" --- but that never workedI'm using the vesa driver --- but get the flashing screen Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 7, 2005 Share Posted November 7, 2005 The best you can do is add this urpmi souce: # urpmi.addmedia thac_rpms http://anorien.csc.warwick.ac.uk/mirrors/thac//2006.0/RPMS with hdlist.cz ( Since you did an FTP install you will have contrib already )In the Thacs source there is an updated xorg which will work much better . . . also he has some Nvidia stuff specially for 2006 !What I want you to try is add the thacs source and do: # urmpi.update -a --wget && urpmi --auto-select --wget I hope that will find the update for the xorg files . . . . ( if not we will have to be more specific with the urpmi command, but first try this one . . ) BrunoADDITIONALLY:After that un-install the nvidia drivers with nvidia-installer --uninstall and after that get the "dkms-nvidia-7174-9.mdk2006.0.mde.i586.rpm" by urpmi from the Thacs source . . that should bring a few dependencies for the Nvidia stuff from Thacs as well, but basically you should be set up after that ! Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 7, 2005 Author Share Posted November 7, 2005 The best you can do is add this urpmi souce:# urpmi.addmedia thac_rpms http://anorien.csc.warwick.ac.uk/mirrors/thac//2006.0/RPMS with hdlist.cz ( Since you did an FTP install you will have contrib already )In the Thacs source there is an updated xorg which will work much better . . . also he has some Nvidia stuff specially for 2006 !What I want you to try is add the thacs source and do: # urmpi.update -a --wget && urpmi --auto-select --wget I hope that will find the update for the xorg files . . . . ( if not we will have to be more specific with the urpmi command, but first try this one . . ) BrunoADDITIONALLY:After that un-install the nvidia drivers with nvidia-installer --uninstall and after that get the "dkms-nvidia-7174-9.mdk2006.0.mde.i586.rpm" by urpmi from the Thacs source . . that should bring a few dependencies for the Nvidia stuff from Thacs as well, but basically you should be set up after that ! Ok - I've done all of the above ------ and I've got X. Do I need to go back into XFDrake and change back to the nv-generic driver instead of vesa? Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 7, 2005 Share Posted November 7, 2005 Ok - I've done all of the above ------ and I've got X. Do I need to go back into XFDrake and change back to the nv-generic driver instead of vesa?No no no . . . . . all is well like this, the "kdms nvidia" stuff should have adapted your xorg.conf to use the correct "nvidia" driver already . . . . don't touch anything, just have a look if you see the real nvidia drivers ( not the generic "nv" ) load at boot ( messages, dkms-nvidia ) and if you get the nvidia splash screen . . . . ( If you have X don't touch any files without backing them up first so you can restore if needed ) Bruno Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 7, 2005 Author Share Posted November 7, 2005 woopswhen I reboot I go back to the M-2006 welcome screen flashing on and off.Still have yet to see the nvidia splash screen Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 8, 2005 Author Share Posted November 8, 2005 also:"Modprobe nvidia" returns ---WARNING: etc/modprobe.conf line 10: bad line starting with "nvidia'WARNING: etc/modprobe.conf line 11: bad line starting with "char-major-195*"FATAL: could not open "/lib/modules/2.6.12-12mdk/kernel/drivers/video/nvidia.ko"no such file or directory Quote Link to comment Share on other sites More sharing options...
teacher Posted November 8, 2005 Share Posted November 8, 2005 You might post the lines from your /etc/modprobe.conf so we we can see what it is complaining about. Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 8, 2005 Share Posted November 8, 2005 Hi RakemupWhen you installed the "dkms-nvidia-7174-9.mdk2006.0.mde.i586.rpm" did it install other packages as well ( dependencies ) ?? I am thinking about files like "nvidia-xorg-7174-9.mdk2006.0.mde.i586.rpm"and maybe also "nvidia-devel-7174-9.mdk2006.0.mde.i586.rpm" from the same source.For the time being I would change the driver to "nv" or even "vesa" ( but the generic "nv" should also work now with the new xorg ) so you have X again . . . then we will try to troubleshoot the "nvidia" driver later today when I come back from work. Bruno Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 9, 2005 Author Share Posted November 9, 2005 The only way I can get X is with the vesa driver.Here is my /etc/modprobe.confalias eth0 eth1394remove snd-emu10k1 /sbin/modprobe -r snd-pcm-oss; /sbin/modprobe --first-time -r --ignore-remove snd-emu10k1install snd-emu10k1 /sbin/modprobe --first-time --ignore-install snd-emu10k1 && { /sbin/modprobe snd-pcm-oss; /bin/true; }alias sound-slot-0 snd-emu10k1alias eth2 via-velocityinstall scsi_hostadapter /sbin/modprobe sata_via; /bin/trueinstall usb-interface /sbin/modprobe uhci-hcd; /sbin/modprobe ehci-hcd; /bin/truealias eth1 eth1394alias ieee1394-controller ohci1394nvidiachar-major-195* nvidia Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 9, 2005 Share Posted November 9, 2005 Hi RakemupCan you show me the "cat /etc/modprobe.preload" as well ?? . . . . . Aslo I would like to see the output of "lsmod"Also, is "nvidia-xorg-7174-9.mdk2006.0.mde.i586.rpm" installed too ? Bruno Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 9, 2005 Author Share Posted November 9, 2005 modprobe preload =bttvbt878amd64-agpamd64-agpamd64-agpnvidialsmod=Module Size Used bymd5 4480 1ipv6 244960 8raw 9736 1snd_seq_dummy 3332 0snd_seq_oss 31460 0snd_seq_midi_event 6912 1 snd_seq_osssnd_seq 50520 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi_eventsnd_pcm_oss 51360 0snd_mixer_oss 16384 1 snd_pcm_osssnd_emu10k1 111556 0snd_rawmidi 22688 1 snd_emu10k1snd_seq_device 7952 5 snd_seq_dummy,snd_seq_oss,snd_seq,snd_emu10k1,snd_rawmidisnd_ac97_codec 88516 1 snd_emu10k1snd_pcm 84748 3 snd_pcm_oss,snd_emu10k1,snd_ac97_codecsnd_timer 21000 3 snd_seq,snd_emu10k1,snd_pcmsnd_page_alloc 9360 2 snd_emu10k1,snd_pcmsnd_util_mem 4096 1 snd_emu10k1snd_hwdep 8736 1 snd_emu10k1snd 48896 11 snd_seq_oss,snd_seq,snd_pcm_oss,snd_mixer_oss,snd_emu10k1,snd_rawmidi,snd_seq_device,snd_ac97_codec,snd_pcm,snd_timer,snd_hwdepsoundcore 8352 1 sndvia_velocity 32928 0crc_ccitt 2176 1 via_velocityaf_packet 18316 2floppy 61664 0video 15496 0thermal 12556 0tc1100_wmi 6408 0processor 19528 1 thermalfan 3976 0container 3840 0button 6176 0battery 8840 0ac 4232 0eth1394 18064 0ide_cd 39200 1ohci1394 31052 0ieee1394 350328 2 eth1394,ohci1394loop 14992 0nls_iso8859_1 5376 1ntfs 191240 1bt878 9292 0tvaudio 24356 0bttv 170832 1 bt878video_buf 19972 1 bttvfirmware_class 8960 1 bttvi2c_algo_bit 9096 1 bttvv4l2_common 6528 1 bttvbtcx_risc 4616 1 bttvtveeprom 14488 1 bttvi2c_core 19608 4 tvaudio,bttv,i2c_algo_bit,tveepromvideodev 9472 1 bttvtsdev 7424 0ehci_hcd 28936 0uhci_hcd 29472 0usbcore 114732 3 ehci_hcd,uhci_hcdevdev 9088 0reiserfs 245624 6sd_mod 16408 0sata_via 6660 0libata 41352 1 sata_viascsi_mod 132440 2 sd_mod,libatalooks like "nvidia-xorg-7174-9.mdk2006.0.mde.i586.rpm" is not installed Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 9, 2005 Share Posted November 9, 2005 Hi RakemupPlease first do "urpmi.update -a" then install nvidia-xorg-7174-9.mdk2006.0.mde.i586.rpm, and next please comment out the "nvidia" line in /etc/modprobe.conf ( because you already have it in modprobe.preload ) and the "char-major-195* nvidia" line too . . then reboot and show me "lsmod" again BrunoPS: Is this AMD 64 ?? Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 10, 2005 Author Share Posted November 10, 2005 yes ---- AMD64I did urpmi.update -a.when I try to install the nvidia-xorg-7174 file I get this response: urpmi nvidia-xorg-7174-9.mdk2006.0.mde.i586One of the following packages is needed: 1- libnvidia-opengl1-7676-4.mdk2006.0.mde.i586 : NVIDIA OpenGL libraries (to install) 2- nVidia_GLX-7667-4.mdk2006.0.mde.i586 : NVIDIA module for XFree86 4.0 X server and OpenGL libraries (to install)What is your choice? (1-2)NEITHER works ---- even with --force Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 10, 2005 Share Posted November 10, 2005 Hi RakemupThis is getting complicated . . . . I was not aware it was for AMD 64 and I am not sure we will be able to fix this before the new Xorg ( stable ) is released in December.There was a new xorg ( cvs ) uploaded on thacs yesterday, maybe you could first try upgrading to that one. Next you might try to remove ( with uprme ) the dkms package you installed the day before ( because I think it is i586 ) and get the 64 bits drivers from http://www.nvidia.com/content/drivers/drivers.asp ( make sure you have the 64 bits ones ! ) and try the drivers the usual way. Bruno Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 10, 2005 Author Share Posted November 10, 2005 the dkms package has been removedwhen I try to download from thacs - I get an error messagewhen I downloaded a driver from Nvidia at the start of this --- it was the "LinuxAMD64/EM64T one (1.0-7676) Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 10, 2005 Share Posted November 10, 2005 when I downloaded a driver from Nvidia at the start of this --- it was the "LinuxAMD64/EM64T one (1.0-7676)That should be the correct one . . . . ;)Maybe try to install them again . . . . maybe with the Xorg files you got upgraded last time they will work.Forget about the other files from the Thac-source . . . . he is still changing the lot of them so it can be hard to download. Bruno Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 11, 2005 Author Share Posted November 11, 2005 I re-installed the Nvidia driver --- still no luck. I guess I'll just stick with the vesa driver for a couple of weeks and then try Thacs again.Has anyone out there had success with Nvidia on an AMD64 machine? Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 13, 2005 Author Share Posted November 13, 2005 Is there some way I can request notification ------ when the new Xorg ( stable ) is released ? Quote Link to comment Share on other sites More sharing options...
teacher Posted November 13, 2005 Share Posted November 13, 2005 Just keep an eye on the forum - or subscribe to it for daily notifications or rss feed. I don't know a way to tell directly. It does seem to be pretty nice. I only have one thing I don't like about it from playing with the unstable rc. Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 13, 2005 Share Posted November 13, 2005 Hi RakemupThe latest version on the Thac source is "6.9-1.cvs20051107.1.mdk2006.0.mde" . . . you can update your Thac source and get that version.If even that ones fails to be nice with the Nvidia drivers I will make a note to PM you when the "stable" is on the Thac mirror ( I am sure it will be there first ) BrunoPS: I think you installed 2006 from the x86_64 tree ( and not from amd64 because that one is only in cooker ) . . . so maybe you should get the Linux IA64 drives from Nvidia and not the AMD64/EM64T ones. It is just a wild guess, but your install is a x86 one and for the 586 ( 32 bits) we always take the IA32 drivers ( yep I know that IA is intell ) even with an AMD CPU . . . can you follow my thoughts ? Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 14, 2005 Author Share Posted November 14, 2005 still doesn't workI will just wait for the AMD64 version of 2006thanks anyway Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 14, 2005 Share Posted November 14, 2005 The official ISOs are available Rakemup:ftp://ftp.nluug.nl/pub/os/Linux/distr/Man.../x86_64/2006.0/I would try these first . . and get the IA64 driver from NvidiaB) Bruno Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 16, 2005 Author Share Posted November 16, 2005 The official ISOs are available Rakemup:ftp://ftp.nluug.nl/pub/os/Linux/distr/Man.../x86_64/2006.0/I would try these first . . and get the IA64 driver from NvidiaB) BrunoOK - thought I'd try one more time. I did a fresh install of 2006 x86_64 from the iso files on CD. I downloaded the IA64 driver from Nvidia. When I try to run it I get the error msg: "this file is for Linux ia64 .... you appear to be running Linux X86_64.ert/modprobe.preload =bttvbt878amd64-agpamd64-agpamd64-agplsmod =Module Size Used byisofs 32992 0vfat 12288 0fat 46896 1 vfatvia_velocity 32928 0crc_ccitt 2176 1 via_velocitymd5 4480 1ipv6 244960 8raw 9736 1snd_seq_dummy 3332 0snd_seq_oss 31460 0snd_seq_midi_event 6912 1 snd_seq_osssnd_seq 50520 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi_eventsnd_pcm_oss 51360 0snd_mixer_oss 16384 1 snd_pcm_osssnd_emu10k1 111556 0snd_rawmidi 22688 1 snd_emu10k1snd_seq_device 7952 5 snd_seq_dummy,snd_seq_oss,snd_seq,snd_emu10k1,snd_rawmidisnd_ac97_codec 88516 1 snd_emu10k1snd_pcm 84748 3 snd_pcm_oss,snd_emu10k1,snd_ac97_codecsnd_timer 21000 3 snd_seq,snd_emu10k1,snd_pcmsnd_page_alloc 9360 2 snd_emu10k1,snd_pcmsnd_util_mem 4096 1 snd_emu10k1snd_hwdep 8736 1 snd_emu10k1snd 48896 11 snd_seq_oss,snd_seq,snd_pcm_oss,snd_mixer_oss,snd_emu10k1,snd_rawmidi,snd_seq_device,snd_ac97_codec,snd_pcm,snd_timer,snd_hwdepsoundcore 8352 1 sndaf_packet 18316 0floppy 61664 0eth1394 18064 0video 15496 0thermal 12556 0tc1100_wmi 6408 0processor 19528 1 thermalfan 3976 0container 3840 0button 6176 0battery 8840 0ac 4232 0ide_cd 39200 0ohci1394 31052 0ieee1394 350328 2 eth1394,ohci1394loop 14992 0nls_iso8859_1 5376 1ntfs 191240 1bt878 9292 0tvaudio 24356 0bttv 170832 1 bt878video_buf 19972 1 bttvfirmware_class 8960 1 bttvi2c_algo_bit 9096 1 bttvv4l2_common 6528 1 bttvbtcx_risc 4616 1 bttvtveeprom 14488 1 bttvi2c_core 19608 4 tvaudio,bttv,i2c_algo_bit,tveepromvideodev 9472 1 bttvtsdev 7424 0ehci_hcd 28936 0uhci_hcd 29472 0usbcore 114732 3 ehci_hcd,uhci_hcdevdev 9088 0reiserfs 245624 6sd_mod 16408 0sata_via 6660 0libata 41352 1 sata_viascsi_mod 132440 2 sd_mod,libata Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 16, 2005 Share Posted November 16, 2005 I have to admit that you did get the correct drivers the first time indeed and that the IA64 are the wrong ones . . . . Bruno Quote Link to comment Share on other sites More sharing options...
rakemup Posted November 16, 2005 Author Share Posted November 16, 2005 I have to admit that you did get the correct drivers the first time indeed and that the IA64 are the wrong ones . . . . BrunoI now have the X86_64 driver and the kernel source code installed. The module seems to have been built for nvidia --- but vesa is the only way I can get X. Quote Link to comment Share on other sites More sharing options...
Bruno Posted November 16, 2005 Share Posted November 16, 2005 . . . . . . I will send you a PM as soon as the new "stable" Xorg is available . . . . . I think that is all we can do right now Bruno Quote Link to comment Share on other sites More sharing options...
