mhbell Posted September 2, 2016 Share Posted September 2, 2016 I need a program to create albums for my photos and to organize them. any one know of a linux program that will organize my photo's, make albums and let me put captions on them. something like google picasa. Google no longer supports picasa and is putting everything in google photo's, they are also doing away with apps. TIA Mel Quote Link to comment Share on other sites More sharing options...
abarbarian Posted September 2, 2016 Share Posted September 2, 2016 (edited) I need a program to create albums for my photos and to organize them. any one know of a linux program that will organize my photo's, make albums and let me put captions on them. something like google picasa. Google no longer supports picasa and is putting everything in google photo's, they are also doing away with apps. TIA Mel Imgur may do what you want. You can add stickers to pictures whatever they are, would that be similar to captions ? https://help.imgur.com/hc/en-us/categories/201201803-The-Basics Edited September 2, 2016 by abarbarian 1 Quote Link to comment Share on other sites More sharing options...
Hedon James Posted September 2, 2016 Share Posted September 2, 2016 I'm not much of a user of photo apps, so not sure if I'll be helpful, but I read up a lot on software. So I tend to be AWARE of options, but I'm only familiar with whatever I use. With that said, what functionality are you trying to replace with Picasa? If it's the photo editing, I'd guess that Shotwell or Fotoxx or DigiKam may suit your needs. Or perhaps check out these alternatives: http://www.makeuseof.com/tag/7-picasa-alternatives-made-linux/ If it's the online hosting & sharing, perhaps look into open-source Lychee: https://lychee.electerious.com/ That's about the extent of my knowledge with photo apps... 1 Quote Link to comment Share on other sites More sharing options...
mhbell Posted September 2, 2016 Author Share Posted September 2, 2016 Thanks Guys Imgur is not what I am looking for. Gthumb or maybe Digikam might work. I will check all of them out. Sure hope I can find something that is comparable. Mel . Quote Link to comment Share on other sites More sharing options...
sunrat Posted September 3, 2016 Share Posted September 3, 2016 DigiKam is good if you use KDE. Probably good if you don't anyway but will pull in a few dependencies. Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted September 3, 2016 Share Posted September 3, 2016 I vote for Imgur. 1 Quote Link to comment Share on other sites More sharing options...
Capt.Crow Posted September 3, 2016 Share Posted September 3, 2016 to get where you want .re photos ...imgur is easy peasey All on their server . If you want to keep your stuff at home!!! There must be a way to utilize gwenview . 1 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted September 4, 2016 Share Posted September 4, 2016 Thanks Guys Imgur is not what I am looking for. Gthumb or maybe Digikam might work. I will check all of them out. Sure hope I can find something that is comparable. Mel . This list may help, https://www.g2crowd.com/categories/photo-management/products Quote Link to comment Share on other sites More sharing options...
Capt.Crow Posted September 4, 2016 Share Posted September 4, 2016 www.freeimagehosting.net/ Could this suit your needs Quote Link to comment Share on other sites More sharing options...
