Still having Problems with Debian Cinnamon
9 replies to this topic
#1 OFFLINE   mhbell
mhbell
    Posting Prodigy
  • 2,255 posts
Posted 18 April 2019 - 01:13 PM
{SOLVED} Still having Problems with Debian Cinnamon
I started a new post because the other one was getting to long and several things have changed.
I will start off with my computers spec's.
Asus Prime B450M-A/CSM Mother Board
AMD Ryzen 2 2200G CPU with Vega 8 Graphics
16 GB of Ram
Bios (Firmware) 2000
OS Debian Stretch non-free with Cinnamon DE.
Did a clean install of debian and got all of the updates. I did not install the backports at this time. here is what I get when I boot up to the OS. "(Running Software in Rendering Mode)" In Mint and other OS's using the cinnamon DE the only way to solve it was a newer kernel. I am using the 4.19.28 in Mint and it solved the problem and is working fin so far.
When I tried using Liquorix kernel Like sunrat suggested I get the following error when I run the first part.
# Mirrors:
# Unit193 - France
# deb http://mirror.unit193.net/liquorix sid main
# deb-src http://mirror.unit193.net/liquorix sid main
bash: curl: command not found
gpg: no valid OpenPGP data found.
I am not sure what my next step will be. Waiting to hear from the forum members.
Mel
Edited by mhbell, 19 April 2019 - 09:15 PM.
Registered Linux User #239772
#2 ONLINE   securitybreach
  • 24,624 posts
Posted 18 April 2019 - 01:19 PM
16 GB of Ram
# Mirrors:
# Unit193 - France
Mel
"software in rendering mode" means you do not have video acceleration. In other words, you do not have the correct video driver installed so you are using a generic one.
That has zero to do with your kernel.
Link for you https://forums.linux...ic.php?t=159634
Posted ImagePosted Image
Configs/PGP Key/comhack π
#3 ONLINE   securitybreach
  • 24,624 posts
Posted 18 April 2019 - 01:21 PM
You do not have curl installed. Install curl and try again.
#4 OFFLINE   mhbell
mhbell
    Posting Prodigy
  • 2,255 posts
Posted 18 April 2019 - 04:57 PM
16 GB of Ram
# Mirrors:
# Unit193 - France
Mel
First of all Security the reference file above was started in 2014 and mint is a different animal I solved all of my graphics problems in Mint with a new Bios Firmware and a kernel update to 4.19.28 which is the one for mint 19.1 which works with no problems.
Now I am having rendering problems with Debian Cinnamon  non-free version from the debian community. in all of my other cases with the ryzen 2200G the problems have been solved with a kernel update.
I have to disagree with you there. some of the newer kernels have the proper modules for the vega graphics. Now back to my problem.
What do I need to do to get the proper graphics driver for Debian stretch cinnamon DE? Bear in mind I am not using a Graphics card, But the built in graphics in the Ryzen 3 2200G with vega 8 graphics. so I ask anyone what is the solution/ and how do I go about getting it fixed? Other distro's such as Manjaro cinnamon de work out of the box. I really want to solve this problem.
Mel
BTW I got the liquorix kernel 5.0.8.0 which is the one it installed but on boot it stops and freezes at (FBO: switching to amdgpu drm fb from simple) at that point it stops booting and freezes. I will have to purge that kernel and fall back to 4.0.9
#5 ONLINE   securitybreach
  • 24,624 posts
Posted 18 April 2019 - 05:31 PM
Well I was just pointing out that software rendering is a graphical issue, not kernel related. The kernel itself does not provide video drivers because they are provided by the varfious Xorg packages like xf86-video-amdgpu, etc. (if you use the opensource drivers).
Now as far as your issue, Mesa is the driver that the Vega GPU uses along with the xf86-video-amdgpu. These should help and provide more information:
https://www.reddit.c....2F19.x_only.29
https://www.linuxsec...php/AMDGPU.html
#6 OFFLINE   mhbell
mhbell
    Posting Prodigy
  • 2,255 posts
Posted 18 April 2019 - 05:55 PM
Thanks for your help Security. I solved the problem by going to the stretch backports and doing a "Upgrade" then liquorix installed a updated kernel which solved the problem along with a updated mesa. see the remarks below
Remarks:
inxi -Gx
Graphics:
  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
  vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 08:00.0
  Display: x11 server: X.Org 1.19.2 driver: ati,modesetting
  unloaded: amdgpu,fbdev,radeon,vesa resolution: 1280x720~60Hz
  OpenGL:
  renderer: AMD RAVEN (DRM 3.27.0 5.0.0-8.1-liquorix-amd64 LLVM 6.0.0)
  v: 4.5 Mesa 18.2.8 direct render: Yes
Note: the above is for Debian and not Mint. The 5.0.0-8-liquorix-amd64 is the new kernel.
I now have a Frankenstien Debian LoL!
Mel
Edited by mhbell, 18 April 2019 - 07:06 PM.
#7 ONLINE   securitybreach
  • 24,624 posts
Posted 18 April 2019 - 05:56 PM
Good deal. I do not know why LInuxMint didn't provide the correct Mesa driver in the first place. Glad that it is solved anyway :thumbsup:
#8 OFFLINE   raymac46
  • 3,992 posts
Posted 18 April 2019 - 06:13 PM
inxi -Gx
Graphics:
Device-1: AMD Tobago PRO [Radeon R7 360 / R9 360 OEM]
vendor: PC Partner Limited driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: AMD BONAIRE (DRM 2.50.0 4.15.0-47-generic LLVM 7.0.0)
I have the same Mesa version with a plain vanilla 4.15 kernel on LM 19.1
However I am using the amd radeon driver. Modesetting is a rather generic driver that'll work with any GPU.
Edited by raymac46, 18 April 2019 - 06:18 PM.
#9 OFFLINE   mhbell
mhbell
    Posting Prodigy
  • 2,255 posts
Posted 18 April 2019 - 07:00 PM
View Postraymac46, on 18 April 2019 - 06:13 PM, said:
inxi -Gx
Graphics:
This is mine in Linux Mint 19.1 tessa
Mel
Graphics:
  Display: x11 server: X.Org 1.19.6 driver: amdgpu,ati
  unloaded: fbdev,modesetting,radeon,vesa resolution: 1280x720~60Hz
  OpenGL: renderer: AMD RAVEN (DRM 3.27.0 5.0.6-050006-generic LLVM 8.0.0)
  v: 4.5 Mesa 19.0.2 direct render: Yes
You are not using a Ryzen 3 2200G cpu either
Mel
Edited by mhbell, 18 April 2019 - 07:02 PM.
#10 OFFLINE   raymac46
  • 3,992 posts
Posted 19 April 2019 - 06:45 AM
Well it looks to me as if you have the correct driver in Mint but not in Debian. I would expect in both cases to see the amdgpu driver in use since you have a more recent APU.
