Microsoft Edge: Did you know about Repair/Reset?
1 reply to this topic
#1 OFFLINE   Corrine
Corrine
    The Mystical Rose
  • 4,397 posts
Posted 06 June 2018 - 03:58 PM
There have been so many changes and additions to Windows 10, I can't keep track of them all.  I ran into an issue with Microsoft Edge opening the startup tabs but not loading the pages and being completely unresponsive.  After a quick search, I discovered Repair/Reset was added with the Windows 10 Fall Creators Update (version 1709) and it is easy to use.
  • Click Start (Windows icon) > the Settings icon and select Apps > Apps and Features.
  • Scroll down to Microsoft Edge & click it.
  • Select Advanced options.
  • Try Repair first and if that doesn't work, select Reset.
In my case, Repair didn't work but Reset did.  The only thing I had to do after the repair was to re-activate the extensions.
#2 OFFLINE   crp
crp
  • 3,169 posts
Posted 10 June 2018 - 07:25 PM
i would like to use Edge more on my pc, but it is just too slow - and there are still website incompatibility problems.
MSFT really needs to rip Edge out the OS and make it stand alone.
ps: I do use it as default pdf viewer. VERY nice at doing that.
Edited by crp, 10 June 2018 - 07:25 PM.
