Factory Reset HP Notebook
hp notebook windows 7 factory reset
1 reply to this topic
#1 OFFLINE   Purhonen
Purhonen
    Post Master
  • PipPipPipPip
  • 122 posts
Posted 27 February 2018 - 01:17 AM
Iím donating an HP G60t-200 notebook with Windows 7 (HE) and want to reset it to original factory condition.
HP Support page says do the following to access the Recovery Manager:
- Click Start, type recovery in the search field, and select HP Recovery Manager to run recovery from the D drive.
- Turn on the power and press F11 to run recovery without starting Windows (on some models esc key and then F11 key ).
- Insert the customer-created Recovery disc in disc drive and turn the power on to boot from the DVD disc.
- Insert replacement the Recovery disc purchased from HP, and turn the power on to boot from the DVD disc.
The Recovery Manager is supposed to look like this:
https://support.hp.c...6/c03573444.jpg
The problem I have is I canít get to the Manager.
Also, I do not have any of the discs they mention in the 3rd and 4th steps.
I thought I could simply do a reset using the Recovery partition that came installed in the HD. But how do I access it?
Thanks, Steve
#2 OFFLINE   raymac46
  • 3,970 posts
Posted 27 February 2018 - 09:17 AM
I think you are going to need the recovery disks.
https://support.hp.c...cument/bph07143
If they were never made you might be able to create them now.
Windows 10 style resets are not possible with Windows 7 or Vista.
Edited by raymac46, 27 February 2018 - 09:18 AM.
Also tagged with one or more of these keywords: hp notebook, windows 7, factory reset
