The remote device won't accept the connection
15 replies to this topic
#1 OFFLINE   zillah
zillah
    Thread Head
  • PipPipPipPipPipPip
  • 572 posts
Posted 06 November 2017 - 03:01 AM
Dear folk
I have my work laptop windows 10 that joined a work domain and I have my desktop windows 7 that on workgroup.
At home and from my work laptop I used to access a shared folder on my desktop to do backup.
Now whenever I tried to access the shard folder  the error below pops up
https://imgur.com/a/2GSZw
Desktop has avast security and I did disable that
Thx
#2 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,700 posts
Posted 10 November 2017 - 10:33 AM
Zillah,
I apologize for the lack of response here to your query. I'm not a Windows user much these days, so I'm not up-to-date on that fun OS. We do have some Windows pros here, though. I would hope that someone sees your post and offers some bit of advice regarding your problem.
Regards,
~Eric
#3 OFFLINE   zillah
zillah
    Thread Head
  • 572 posts
Posted 10 November 2017 - 02:58 PM
Thanks Eric
#4 OFFLINE   goretsky
goretsky
    Posting Prodigy
  • 2,047 posts
Posted 14 November 2017 - 05:06 AM
Hello,
Is each computer able to see each other via the ping and traceroute commands?
Have you checked with your IT department at work to see if they have made any changes to network connectivity rules recently?
Regards,
Aryeh Goretsky
Dexter is a good dog.
Aryeh Goretsky
#5 OFFLINE   zillah
zillah
    Thread Head
  • 572 posts
Posted 14 November 2017 - 05:31 AM
Thanks Aryeh
If I disable the Avast on Desktop  form my work laptop I can ping the desktop,,,,I didn't try the traceroute command.
Physical change to the laptop hasn't been done unless via pushing through online,I doubt but not sure
Regards
#6 OFFLINE   Peachy
Peachy
    Anarquista De Sartorial
  • 5,448 posts
Posted 14 November 2017 - 07:53 PM
If your Windows 10 has been upgraded to the Fall Creators Update then it's possible your SMBv1 client has been disabled. You will have to turn it back on by going into the Control Panel > Programs and Features > Turn Windows features on or off > SMB 1.0/CIFS File Sharing Support. This is the new default behaviour on Windows 10 Pro and Home systems that get updated. If you have Enterprise Microsoft doesn't disable SMBv1 if it already turned on. The reason is to prevent people from being victimized by WannaCry-like ransomware.
#7 OFFLINE   zillah
zillah
    Thread Head
  • 572 posts
Posted 17 November 2017 - 04:04 PM
I checked the option and it is enabled not disabled
Thx
#8 OFFLINE   Peachy
Peachy
  • 5,448 posts
Posted 18 November 2017 - 05:22 PM
Thx
Hmm. Okay, then how about we check for network connectivity? Can you ping the IP address of your remote work computer from the laptop? Also are you doing this when on your work network or over a VPN?
#9 OFFLINE   zillah
zillah
    Thread Head
  • 572 posts
Posted 18 November 2017 - 07:52 PM
I am doing that at home not work from my work latop can ping my home deaktop when i disable avast internet security on my deakto,,, means i am doing at my home LAN
I am not doing that from work nor via VPN
#10 OFFLINE   Peachy
Peachy
  • 5,448 posts
Posted 19 November 2017 - 09:12 PM
How about re-mapping the network share but use the IP address of your desktop rather than the host name? It might be that NetBIOS name resolution has been disabled somewhere.
#11 OFFLINE   goretsky
goretsky
    Posting Prodigy
  • 2,047 posts
Posted 20 November 2017 - 03:37 AM
Hello,
Have you asked your IT department at work if they have made any changes to file sharing on your work computer recently?
Regards,
Aryeh Goretsky
Aryeh Goretsky
#12 OFFLINE   zillah
zillah
    Thread Head
  • 572 posts
Posted 25 November 2017 - 05:24 AM
Sorry Peachy didn't receive an email notification to your reply
Yes did try below
Method 5: Enable NetBIOS over TCP/IP
https://appuals.com/...-was-not-found/
Thx
Sorry goretsky didn't receive an email notification , yes I did ask him but it seems to me he has no idea
Thx
#13 OFFLINE   zillah
zillah
    Thread Head
  • 572 posts
Posted 26 November 2017 - 03:50 AM
Hi All
I just realized another laptop at home which has windows 10 installed and it is not part of a domain , it is part of work group can't access the shared folder on the desktop as well.
Only laptop with Windows 7 installed can access the shared folders
#14 OFFLINE   goretsky
goretsky
    Posting Prodigy
  • 2,047 posts
Posted 27 November 2017 - 04:03 AM
Hello,
If you open a PowerShell prompt on each computer and issue the following commands, what do they return?
Get-SmbServerConfiguration | Select EnableSMB1Protocol
Get-SmbServerConfiguration | Select EnableSMB2Protocol
Regards,
Aryeh Goretsky
Aryeh Goretsky
#15 OFFLINE   zillah
zillah
    Thread Head
  • 572 posts
Posted 27 November 2017 - 04:15 AM
Hi it say unknown command
#16 OFFLINE   goretsky
goretsky
    Posting Prodigy
  • 2,047 posts
Posted 28 November 2017 - 04:26 AM
Hello,
Try running PowerShell (filename: powershell.exe) as an Administrator and then re-running the two commands in it.
Regards,
Aryeh Goretsky
Aryeh Goretsky
