Dell Latitude XT2
16 replies to this topic
#1 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,628 posts
Posted 23 August 2017 - 12:24 PM
This little guy was bestowed upon me by a friend the other day. It's in excellent condition; is actually running currently with Win Vista. Of course, it will get Slackified pretty soon. ;)
#2 OFFLINE   securitybreach
  • 24,270 posts
Posted 23 August 2017 - 12:44 PM
Very cool!
Posted ImagePosted Image
Configs/PGP Key/comhack π
#3 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,628 posts
Posted 23 August 2017 - 07:19 PM
It was in storage for years. Even the battery took a charge. I was quite surprised.
#4 OFFLINE   securitybreach
  • 24,270 posts
Posted 23 August 2017 - 08:03 PM
Even better :thumbsup:
Is it upgradeable, like the ram and such? Is everything easily accessible or do you have to remove everything just to upgrade ram and such.
#5 OFFLINE   zlim
zlim
    It's me, plodr
  • 7,185 posts
Posted 24 August 2017 - 11:00 AM
Just saw a YouTube video. All you do is remove the battery then take out 2 screws to get the RAM cover off. One slot only so the stick that's in would be replaced with something larger.
Does it have 1GB or 2GB of RAM?
Looks like it takes DDR3-8500
https://www.amazon.c...0/dp/B009256HGU
I get conflicting reports. Someone says the max is 3GB, someone else says 4GB and I've also seen 5GB.
I guess the best is to let Crucial scan the device. Crucial usually gets it correct.
Edited by zlim, 24 August 2017 - 11:05 AM.
Liz
#6 OFFLINE   securitybreach
  • 24,270 posts
Posted 24 August 2017 - 11:53 AM
Well the 3gb max is probably referring to a 32bit installation but I could be wrong. Also, Crucial says the max is 5gb although that doesn't seem right to be as I have never seen a machine where the max ram is an odd number (unless it was 1gb). http://www.crucial.c...atitude-xt2-xfr
#7 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,628 posts
Posted 24 August 2017 - 01:06 PM
Yup. I already downloaded the service manual from Dell (I love Dell's customer support - none better!). I have bigger hdds and lotsa' RAM for this little guy, too. :)
It'll probably be a bit problematic to get the touchscreen portion to work in Linux, but that's OK. I really have no need for that. Also, that little Core2 Duo processor is a workhorse. That's the same processor that is in the Inspiron that you gave me, Josh. I'll have a spare, if needed, since the ol' Inspiron developed display issues a couple years back.
I'm in no hurry to fix this one up. I don't really have a pressing need for it. I'm going to wait a couple months till the weather gets a little more pleasant down here, instead of the current rain forest steam and heat that is now occurring. Once it gets a bit nicer outside, I'll be able to work in my shop without sweat dripping in my eyes and onto the motherboard. ;)
#8 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,628 posts
Posted 24 August 2017 - 01:16 PM
You may be looking at the incorrect video. It's DDR3 RAM (1G+2G = 3G) in two slots. It also has a relatively small hdd (80G - SATA), but I have some compatible "biggies" (250G and 500G) that I can fit in there. It has no DVD bay, so I'll have to install Slackware via a USB DVD player. No problem. I've done it that way before. Works fine.
Dell Support original configuration --> http://www.dell.com/...1/configuration
#9 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,628 posts
Posted 24 August 2017 - 01:19 PM
Oh, I believe that 4G RAM is the max that a Core2 Duo can handle.
#10 OFFLINE   securitybreach
  • 24,270 posts
Posted 24 August 2017 - 01:31 PM
Actually the touchscreen should work on linux. Here is a video of it working on Ubuntu:
Actually, the Core 2 Duo supports up to 16Gb of RAM depending on what the mb can handle.
#11 OFFLINE   securitybreach
  • 24,270 posts
Posted 24 August 2017 - 01:37 PM
Supports single-channel DDR2, providing up to 16 GB max memory support
https://www.intel.co...rief/316663.pdf
    Nocturnal Slacker
  • 21,628 posts
Posted 24 August 2017 - 01:43 PM
Yeah, but that's Ubuntu, not Slackware. ;)
#13 OFFLINE   securitybreach
  • 24,270 posts
Posted 24 August 2017 - 01:46 PM
Well more than likely Xorg is handling it anyway so if your Xorg is half way up to date, it should work fine. You may have to modprobe a module or something though.
#14 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,628 posts
Posted 24 August 2017 - 02:00 PM
Meh... like I said, I really don't have any need for that feature. We'll see...
#15 OFFLINE   raymac46
  • 3,917 posts
Posted 25 August 2017 - 07:21 AM
If the budget permits this is one unit that would really benefit from a cheap SSD. Even the lowest priced ones would make a huge difference.
#16 OFFLINE   securitybreach
  • 24,270 posts
Posted 25 August 2017 - 08:08 AM
Great suggestion!! That would make a world of difference. :thumbsup:
#17 OFFLINE   raymac46
  • 3,917 posts
Posted 25 August 2017 - 09:49 AM
A $50 SSD changed an old Toshiba netbook from a slug nobody wanted to a very useful machine to travel with. And this XT2 has much better hardware.
