How do you do backups in XP?
jeffw_00
HI - I have 5 WIN98SE PCs - I do incrementals every night, and fulls every week. I use PKZIP (command line - it's all automated) and store the zip files on a different machine than the one backed up. I've completely and easily restored trashed disks with a simple set of PKZIP restore comments.I'm told this won't cut it for XP, because not all the information is in the files, some is 'hidden' or in file tables or some such? If so - what's the best way in XP to replicate my automated backups? (preferably without paying a bundle for software).I hope my expectations aren't too high - XP should be step forward, I would think 8-}/j
  • Replies 111
  • jeffw_00
    28
  • James M. Fisher
    27
  • Peachy
    24
  • Ed_P
    18
Win 98 has files & folders hidden and etc also. The Font folder being one that comes to mine.I think most Win XP users use an imaging type of backup such as Drive Image or BootitNT.Regardless of which product you use I recommend you partition your hard drives such that your data files/My Documents folder are located on a partition/drive separate from your OS and App files. In addition to making it easier to do restores & recoveries backups can be easier also.
James M. Fisher
This is all good advice from EdP , jeffw_00. :happyroll: I highly recommend an imaging program for XP. DriveImage is my particular favourite, but I have used Ghost from DOS with no problems.There's a good article on Planning Your Partitions here.I always refer folks to Fred Langa's excellent (and thorough!) Backup articles here:http://www.langa.com/backups/backups(1).htm
Thanks guys - but unfortunately many of our financial apps keep the data where they please. I'll look at DriveImage, but no one has said whether PKZIP was sufficient or not?(i.e., is the PC more than the sum of all the files on the disk?)/j
I don't think many of us have used PKZIP since we stopped using DOS so it's hard to say. If the Win XP systems will be using NTFS file systems will PKZIP support it? Will your financial apps? You may want to talk to your programmers and see if they will work. You can also ask them to make the apps more Windows compliant so you can move the data files around.
IMO Yes. It's the marriage of some of those files to the hardware that comprises the pc.Take a backup of a pc and restore it to a new computer and there's a good chance it won't boot except in Safe mode.I'll be dipped!I just did a quick search of the 'net and PKWare still exists and apparently so to does PKZip. And their website indicates that it's Windows version supports 98/Me/NT4/2000/XP. So, whether PKZip will handle all your needs, I don't know. I think you're more familiar with it than we are so let us know how it works for you. Edited by EdP
Ed - let me ask it this way - if I take a complete backup of an XP PC's disk (not a bit-by-bit image, but files and folders, as if I used xcopy or pkzip), expand that backup to another disk, and then swap that disk into the original PC - will it boot and work normally? For 98Se I've proved the answer is yes (except for a few games that recorded the disk sector they were installed to, and thus needed re-installation). For XP - why shouldn't the answer be "YES" too?/j
I've tried this several times and my answer is a resounding NO!Windows Registry seems to be the main stumbling block. Product registration keys and hardware driver differences have also caused major headaches.A bit-by-bit copy is all I have found to be reliable for whole-disk backups... Another reason being that (I've not used Pkzip for years, so don't know about it...) MSBackup and NTBackup have file-size limitations that got in the way.What I do is a complete Ghost image of the drive weekly, putting it on DVD's. Then weekly I also do an NTBackup of all data and directories that I might need to grab a copy of the data that has changed after an accounting boo-boo or something. Then, nightly I have NTBackup do an incremental backup of the drive(s)... My backups go to a different computer on the network. Most of this, other than the Ghosting, is done with Scheduled tasks and I never have to think about it...Hope this helps..d|:^)Dick
Guys - I'm apparently explaining myself very badly. You al sound like what you're hearing is that I want to copy my hard disk, somehow change the hardware (upgrade it, move to a different machine, etc), and then run the new hardware off a restored disk.No!What I want to do is backup my disk to another disk, and then replace the first disk with the 2nd one in the original machine (because, after I did the backup, the first disk died).For this not to work means there's something more to the system than the hardware, and the data contained in the file structure. I.e., there's something important on the disk that can't be extracted by a hierarchical xcopy. Something that Ghost captures but we mere mortals cannot. This is not the case for 98SE and frankly I'm surprised that people claim it IS the case for XP. THe registry, drivers, etc., are all just FILES which can be copied and restored. Some are suggesting that XP uses something in addition to what is stored in files, so that the state of a machine cannot be captures with a complete copy of its file system. (I use the word "copy" rather than "image" because an "image" implies all the bits on the drive, rather than all the bits in all the accessible files on the drive). If I have to spring $70 for ghost when I upgrade to XP, so be it, but I'd like to understand what it is that ghost captures off the disk that a copy or pkzip cannot.thanks for your patience/j
:o And I even quoted where you said that...I, like you, have done that on 98 machines, but have not tried it on XP.If you could get PKzip to copy all (ALL) the running windows files, through shadowing or something, then maybe it would work...Can you run PKzip from PC-Dos or something prior to XP booting up? That way you could copy the Windows files without getting a "file cannot be copied because it is in use" thingamawhacker...Sorry for the oversight in my original post.d|:^)Dick
Hi - i don't want to boot from else where as I want it to be automated. I saw on a forum that the issue might be that the boot sector for an XP machine needs to be specially initialized - a high-end program like ghost takes care of this, but at $70/machine - there's gotta be a better way. Maybe after I magically "SYS" a new hard disk I can put the PKimage on it and be on my way. maybe not/j
James M. Fisher
What about a "drive copy" type program? Often these come bundled with a new drive and/or can be freely downloaded from the drive-makers' site.Regarding "SYS": XP does have the "fixmbr" command, but it has to be run from the Recovery Console: http://tinyurl.com/w98
Start > Programs > Accessories > System Tools > BackupYou don't have to have a tape drive to use Backup: it can save to a file or directly to CD-R/DVD+/-R/RW. It also backs up the Registry. This is what you would do to do what you used to do with Windows 98. The only problem here is you have to first re-install Winddows XP on the new drive.
James M. Fisher
Well, not directly to CD-R/RW/DVD. ;)First create the Backup file to another partition, then burn to a medium using third-party software. http://www.winnetmag.com/WindowsStorage/Ar...rage_24412.htmlhttp://support.microsoft.com/default.aspx?...b;EN-US;q315255
Yes you can if you format the media using packet-writing software like DirectCD, Drag To Disc or whatever Nero calls theirs. But only in XP and not in Windows 2000. :o
JeffW_00,A light just went on in this old head!I have my parents computer set up with an extra hard drive just sitting there waiting for the inevitable crash - I actually installed Windows onto it as a master drive, then put it in the slave slot and installed windows on another drive that is now the master. (Since it is on the same computer, I don't think you will be violating the EULA installing it on both hard drives - if this concerns you, check it out first.)I then do a complete backup to it using backup every night. So, that drive is sitting there with nothing but a clean install of windows on it, and the backup files.If/when the primary drive crashes, I simply change the cable over, make the slave the master and run backup to restore everything to its original location.Now - their computer is 98 - and I have done it and it works great... Not sure that it would in XP, but cannot think of why not...d|:^)DickEDIT: The light just dimmed a bit - if you have multiple machines, even with hard drives as cheap as they are nowadays, it might be cost prohibitive...
James M. Fisher
I did not realize that NTBackup could use DirectCD-type software to store the file. Good to know!
I'm not wild about imaging myself. I would rather make a small backup of My Documents and the System State, do a clean install and use the restore features in NTbackup.MY problem with image files is that they capture every bit... even the bad ones so if your system is not 100% healthy... you image the crap as well as the good stuff. I seriously try to limit my use of 3rd party utilities... I prefer to use what ships with Windows in an effort to keep the code as simple as possible. Why and code complexity to an already maze of code?My method is a Slipstreamed CD with XP and SP2. Load all the software and drivers; configure to my liking. Fire up NTbackup and Restore MY Docs, Documents and Settings folder and System State. In this whole process, the machine is physically disconnected from my network which includes the Internet. (Can't pickup crap from network or Internet.) After the restore is complete, I make a new backup of My Docs, Documents and Settings and System State. After that, it is just Incremental backups each night. The individual backup files are stored on 2 different machines with RAID5 arays in my network... The problem with Imaging software is that not all programs can capture a true image. If there are files and handles open, the image software can't access those files. With hard drives soon approaching half a terrabyte, who really cares about zip files and compression. It is only an issue if you are sharing really large files across the Internet.
James M. Fisher
I have used DriveImage since v4 as well as Ghost and have never had a problem in this regard. Previous versions of DI would boot to DOS to image the system partition, but with v7, this is no longer an issue.It has always been on my "Windows Wishlist" that MS replace (or supplement) Backup with a simple image creator.
They did... Volume Shadow Copy in 2003 Server.It backs up files that are open for exclusive access.It provides backups of volumes that reflect the state of those volumes at the instant the backup is started, even if the data changes while the backup is in progress. This feature makes sure that all the data in the backup is internally consistent and reflects the state of the volumes at a single point in time.It notifies programs and services that a backup is about to occur, which allows them to prepare for the backup by cleaning up on-disk structures and by flushing caches and log files.
Ok - ummm - al lot of discussion here - dicknite - for a long time I've had my machines do a weekly copy of the windows directory to another directory ON THE SAME DRIVE. Then, whenever windows gets corrupted, I do a couple of renames in DOS-before-windows and I'm back in business.I've seen a lot of comments (including one from the PKZIP people) who say I can use anything to backup everything but the O/S - and a few people here say - re-install the O/S and then restore everything else from backup - but.....1) If I re-install the O/S, then I get a new registry, aren't all my APPs hosed?2) Where IS the O/S? Which directories?3) My sense, at least for 98, is that the O/S directories get changed everytime I install an app (and like, every time I run one). So - i don't think this works.also - I don't think recovery console comes with the home edition.also also -my backups are disk to disk, not to removable media (they're unattended, so natch)So although you've all shared, and that's good. I'm not sure I'm closer to answering my original question except to buy (5 copies?) of Ghost.../j
James M. Fisher
Yes, you will need to reinstall the apps.
Usually /Windows, but it depends which version and if it is an upgrade or not. The OS also has files on the root drive (usually C:)
No. The registry gets changed, some files may be dropped in the System folder however.
Sure do. It has to be installed though.http://support.microsoft.com/default.aspx?...kb;EN-US;307654
Well, like Marsden11 said, slipstreamed SP2 XP CD. Or in my case DVD so that you can unattend install all your favourite apps. As you acquire new apps, just add it to the source tree of your CD/DVD and burn a new one. Rewriteable media is perfect for this kind of job.
James M. Fisher
If I ever get a DVD burner, I'm gonna ask you again about doing this!
thanks guys - but clearly you run simpler environments than I do - re-installing all the apps (>50 maybe > 70) would take days, and no doubt they would overwrite config and app-specific index files with blank ones. I backup over 20GB of data each week so I don't know how I would backup to DVD unattended. Seems that everyone 'knows' you can't back up the OS with a simple file backup. But no one seems to know why (sigh). - that's why Ghost is going to charge me bucks for something I probably could do myself with lesser tools, if only I knew the secret...long day - going to bed nowgoodnight & thanks anyhoo/j
That's why I think NTbackup will work because it also backsup the registry state. I've got VMware so maybe I will do an experiment... :hmm:Okay, NTBackup's Backup Wizard has the choice backing up all information on the computer and then will create a recovery disk to restore the information in the event of a major failure. I hadn't seen this before. So you could theoretically start with a clean install and then use the recovery disk to restore the data. That would be the ticket... :thumbsdown:
I think the problem jeffw_00 is that few of us use the new PKZip so we don't know it's capabilities. How do you currently perform recovery with it. You've said you want to restore the backed up files to a new hard drive and that the backups are over 20GBs, so what environment do you use to do the restore today? Do you boot to DOS and do the restore? Do you connect the new hard drive to a machine connected to your LAN and do the restore? Do you use a USB drive? etc. Older backup/restore sw usually booted to DOS to perform the restore. DOS doesn't support native file writing to NTFS drives which is the preferred format for Win XP. Some imaging sw allows you to restore NTFS drives via DOS cause it looks at the physical attributes of the drive rather than the logical attribute of the file system. Some newer backup/restore sw allow you to perform the backup under Windows, they also allow you to restore under Windows. But that means that Windows has to be installed prior to the restore. Or Windows has to be up and the restore sw has to be able to access the drive to be restored as either a 2ndary drive or as a networked drive. Does PKZip support restoring to networked drives?One option, before buying a replacement for PKZip is try using it to perform the type of restore you desire on one machine. If it works, keep it. If not .....As for reinstalling all your apps taking days, unless you are buying 500MHz machines it should be considerably faster if you use a scripting install concept like Peachy does. All the steps are that you would manually initiate or respond to are scripted and once started it just runs unattended until done. It may take several hours but hardly days.Have you checked to see if all 70 of those apps will run under XP? A major stumbling block for older apps is the NTFS file system. But if you use FAT32 under XP they may run fine. I have some old DOS games that I maintain on a FAT partition for that very reason.
Forget PKZip - assume for the sake of argument I'm just doing a file copy to a like-sized partition over the network, and then to do a restore I hook a virgin drive to the remote machine and do another file copy. This is how I backup and restore win98se machines and it has worked for me several times. Sorry, I didn't mean the PKZIP thing to be a diversion.You have a point about older (tax programs) and NTFS - perhaps I'll just leave everything FAT-32 - some of these programs are DOS programs from the early 90s.This is why I've stayed with WIN98SE for so long - seems like you have to throw a lot away with XP (although, the upgrade advisor didn't raise any flags....)thanks/j
From an existing OS connected to a LAN but how is the remote machine accessing the LAN? It must have been booted from something/somewhere? What OS is it booted to?
