Using PCLinuxOS 64 Bit Grub on other Distros
grub
23 replies to this topic
#1 OFFLINE   Frank Woods
Frank Woods
    Message Adept
  • PipPipPip
  • 98 posts
Posted 06 May 2013 - 09:37 AM
I am tired of fooling around with Virtual Box. I would like to install some Distros to my hard drive. Most of the ones that I have tried(All flavors of Mint) and many more have crappy looking Grub Boot Loaders . Most of them are not graphical. How can I add say Mint 14.1 and us PClos 64 bit Grub?
Australis ruins Firefox! Australis should be Abandoned!
#2 OFFLINE   securitybreach
  • 24,263 posts
Posted 06 May 2013 - 10:55 AM
Possibly http://forum.linuxmi...hp?f=61&t=94190
Posted ImagePosted Image
Configs/PGP Key/comhack π
#3 ONLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,619 posts
Posted 06 May 2013 - 11:48 AM
GRUB ain't pretty; sorta' like tires. It does its job.
Multi-booting My Way (Not Necessarily the Easy Way)
#4 OFFLINE   burninbush
burninbush
    Multithreader
  • PipPipPipPipPipPipPipPip
  • 1,279 posts
Posted 06 May 2013 - 01:27 PM
Not clear I understand your question -- but to me it parses like 'I have PCL-64 bit [which is classic grub, not grub2] and I want to add Mint14 to the choices that I see when I boot the computer'.
So, that's easy:  just use a text editor to add the one paragraph [2 - 3 lines] into the PCL's /boot/grub/menu.lst file.  It's just text, open it with kwrite or any text editor.
If you have not yet installed your Mint14, be SURE to inform it to do it's boot install to the partition in which you install, not to the MBR of any disk.
Ultimately, if you want to go completely custom login screen, then you'll need to use the grub commands to display and setup a menu.  And it's worth remembering, any graphic you see on a grub background was put up by grub, not by any distro, no linux is yet running when you see that first boot screen.  It is only after vmlinuz is loaded and running that you will see any output from the distro itself.  (forgive me if you already knew all this)
Editing, look for lines like this below in your menu.lst file ...
title PCL64-2014.04 on sdb5 -- fab good, airlink
kernel (hd1,4)/boot/vmlinuz root=/dev/sdb5 vga=791 acpi=on
initrd (hd1,4)/boot/initrd.img
Note, the 'title' line is what will be displayed on your grub menu at boot.   I use it to add reminders to myself when booting one of my machines that has many distros installed.  The kernel line above could be even shorter by leaving off the last two elements [vga and acpi].   The exact same statements [with correct paths for your install] would also boot a mint14 install.
There's another interesting grub option, after you have told distro#2 to install to its partition root:
title Peppermint
configfile (hd0,N)/boot/grub/menu.lst
which will display whatever graphics and boot options that distro#2 whould have offered if you had let it install to the disk root.  Note, you may have to fiddle with the (hd0,N) bit if you boot from one disk but install to another [second] hard disk.
If I completely misunderstood your question, try again.
#5 OFFLINE   Frank Woods
Frank Woods
    Message Adept
  • PipPipPip
  • 98 posts
Posted 06 May 2013 - 09:10 PM
timeout 60
color black/cyan yellow/cyan
gfxmenu (hd1,4)/boot/gfxmenu
default 0
title linux
kernel (hd1,4)/boot/vmlinuz BOOT_IMAGE=linux root=UUID=b4fea648-a11b-4f7a-9673-343add352410 quiet nokmsboot vmalloc=256M acpi=on resume=UUID=81423d3c-0352-43cb-af91-8da8c046e7ce splash=silent vga=788
title linux-nonfb
kernel (hd1,4)/boot/vmlinuz BOOT_IMAGE=linux-nonfb root=UUID=b4fea648-a11b-4f7a-9673-343add352410 quiet nokmsboot vmalloc=256M acpi=on resume=UUID=81423d3c-0352-43cb-af91-8da8c046e7ce
title failsafe
kernel (hd1,4)/boot/vmlinuz BOOT_IMAGE=failsafe root=UUID=b4fea648-a11b-4f7a-9673-343add352410 quiet nokmsboot failsafe vmalloc=256M acpi=on
title windows
root (hd0,0)
makeactive
chainloader +1
So the above is what I will have to edit?
#6 ONLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,619 posts
Posted 06 May 2013 - 09:50 PM
Yes, you'll have to edit your menu.lst to add the operating systems that you want to show up on the menu at system startup. You have a couple of ways to do this:
1) you can install the individual bootloaders on the /(root) partition of the distributions when you install them, then "chainload" them using GRUB's menu.lst.
or, my way (see link above)
2) manually add the individual distributions' partition and booting data to the menu.lst and direct load them.
There is a third alternative that is pretty cool...
Burninbush posted around here somewhere his method of actually installing GRUB on its own little partition and then setting up the menu.lst from there and booting multiple distros. AHA! Here you go... I found it --> http://forums.scotsn...98
#7 OFFLINE   burninbush
burninbush
    Multithreader
  • 1,279 posts
Posted 06 May 2013 - 11:32 PM
That works like a charm, but is not useful for a disk that has already been partitioned.  I do NOT recommend resizing to create a new first partition -- not even sure that can be done.   If Frank is willing to start over, then I highly recommend my scheme to any linux distro explorer.
But it looks like Frank already has a working menu.lst from his PCL install.  @ Frank, after you get your Mint14 installed, just copy the three-liner example I put above -- fixing partition names to suit -- and it'll work.
#8 OFFLINE   Frank Woods
Frank Woods
    Message Adept
  • PipPipPip
  • 98 posts
Posted 07 May 2013 - 12:57 PM
I will be starting over as I really messed up my PC. I lost 15 GB of music, all of my documents and videos. Linux had nothing to do with this. But I don't understand your 3 liner example?
#9 OFFLINE   Frank Woods
Frank Woods
    Message Adept
  • PipPipPip
  • 98 posts
Posted 07 May 2013 - 05:15 PM
Well I have PCl 64 Installed. I think I am going to try to install Mint, I got nothing left to lose but time.
#10 OFFLINE   Frank Woods
Frank Woods
    Message Adept
  • PipPipPip
  • 98 posts
Posted 07 May 2013 - 06:52 PM
Well I sort of got it working . It had its own Grub but I could not remember what the lines were when I got into PCl. I tried the "Redo-Mbr" thing but it did not work. So I am back where I started with Windows and PClinuxOS 64
#11 ONLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,619 posts
Posted 07 May 2013 - 10:04 PM
Practice makes perfect. ;)
#12 OFFLINE   Frank Woods
Frank Woods
    Message Adept
  • PipPipPip
  • 98 posts
Posted 08 May 2013 - 09:05 AM
Yes , I had it so I could see its logon screen  from PClos but it would not accept and keystrokes. There was a bunch of code that flew by then the login. I probably had too much code in it.
#13 OFFLINE   securitybreach
  • 24,263 posts
Posted 08 May 2013 - 10:07 AM
Sorry for your loss :thumbsdown:
Next time, backup backup backup!!!
#14 ONLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,619 posts
Posted 08 May 2013 - 01:17 PM
Oh, yeah... been here, done this. :(
Yup. After trashing a few partitions when installing a distro here and there, I learned this lesson, too.
#15 OFFLINE   burninbush
burninbush
    Multithreader
  • 1,279 posts
Posted 08 May 2013 - 01:22 PM
Well -- you don't really need to understand it; what I wanted you to do was to highlight the text I provided [3 lines] and then paste them into the PCL menu.lst.  And then, edit correct the partition numbers to match where you actually installed your Mint distro.
The 'Title' line I already explained.
The 'kernel' line just tells grub where to find the vmlinuz of the Mint [or whatever other] distro, and then tells the kernel which is its root partition.
The 'initrd' line similarly tells grub where to find the initrd.img file for Mint.
The example I provided is stripped-down to the simplest possible grub syntax -- but it works.   In the usual case, grub is only visible for a couple seconds while you select which distro choice to boot -- not much point in making it pretty.
#16 OFFLINE   Frank Woods
Frank Woods
    Message Adept
  • PipPipPip
  • 98 posts
Posted 08 May 2013 - 05:47 PM
Well I can do that by just allowing the Mint grub to be installed in SDA
#17 OFFLINE   Frank Woods
Frank Woods
    Message Adept
  • PipPipPip
  • 98 posts
Posted 08 May 2013 - 08:49 PM
I have given up on this. I will go back to using a VB.
#18 ONLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,619 posts
Posted 08 May 2013 - 08:58 PM
Hi Frank,
It's a personal choice, of course. It just depends on your motivation/needs. If you just want to run a usable Linux on your systems somewhere for fun, then VB is fine and dandy. If you're looking to learn, then you really need to actually install Linux on a hard drive with all the risks of failure that come with that option. In my opinion, this is the best way to learn. Install it, tweak it, bend it, break it... learn how to fix it.
Like I said, though... it's a personal thing. Do what's best for you.
Later...
~Eric
#19 OFFLINE   Frank Woods
Frank Woods
    Message Adept
  • PipPipPip
  • 98 posts
Posted 08 May 2013 - 09:37 PM
Well I do have PClinuxOS 64 Bit installed. I just can't seem to get another distro to boot. I may try again later. Thanks for all of you guys help.
#20 ONLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,619 posts
Posted 08 May 2013 - 09:47 PM
I seem to have pulled a muscle in my back helping my brother move into his new digs down here in Tampa after his recent move down from Fairfax, VA this past weekend. It only bothers me when I'm sitting at this desk hunched over this keyboard. Later on, when I can stand to sit here for a bit longer, we'll walk you though this again.
Until then...
#21 OFFLINE   burninbush
burninbush
    Multithreader
  • 1,279 posts
Posted 08 May 2013 - 10:38 PM
Yes, you could, and then it would boot to Mint only - and Mint uses grub2, good luck figuring that out.
#22 OFFLINE   Frank Woods
Frank Woods
    Message Adept
  • PipPipPip
  • 98 posts
Posted 09 May 2013 - 08:17 AM
I know, that does not work.
#23 OFFLINE   Frank Woods
Frank Woods
    Message Adept
  • PipPipPip
  • 98 posts
Posted 09 May 2013 - 10:03 AM
Well I finally got it. From PCloss I got into Mints Grub and edited the proper stuff and placed it in PClos's Grub. I put the correct info in but it made it Chainloader 2 which is fine for me. Thanks VT for all of the help.
#24 OFFLINE   securitybreach
  • 24,263 posts
Posted 09 May 2013 - 10:26 AM
Excellent, you go it working!! I do not know a whole lot about grub as I usually set it up and do not mess with it further hence why I wasnt able to help.
Also tagged with one or more of these keywords: grub
