ross549 Posted December 7, 2003 Share Posted December 7, 2003 Does anyone have any sources for cheap, lightweight PIII heatsinks?Thanks,Adam Quote Link to comment Share on other sites More sharing options...
Peachy Posted December 7, 2003 Share Posted December 7, 2003 Bigfoot Computers Quote Link to comment Share on other sites More sharing options...
Cluttermagnet Posted December 7, 2003 Share Posted December 7, 2003 Bigfoot ComputersI dunno-On their website they are offering several heatsinks under the heading "Hot Items This Week". I thought it was a bad thing when a heatsink feels hot. :lol:In my area we have some big company called "Yellow". I see a lot of cabs and also some smaller size delivery trucks that all have the "Yellow" logo on them in large, easy to read type. And of course all of these vehicles are painted orange! Quote Link to comment Share on other sites More sharing options...
ross549 Posted December 8, 2003 Author Share Posted December 8, 2003 Bigfoot ComputersHmm.... theyhave some really high shipping rates to the US.... not good. The heatsinks (w/o fan) should cost less than that. Quote Link to comment Share on other sites More sharing options...
longgone Posted December 10, 2003 Share Posted December 10, 2003 I think that the heatsink/fan combo for the PIII is a socket 370 and I read somewhere (once again, I think) that the same unit works on both the socket 370 and the socket A boards. If you could check on that an verify it, I have several heat sink/fan combos for the socket A that are good for cpu speeds up to 1.5 gig. Since I no longer need them it would be nice to give them a home where they can do something besides sit in the garage. Quote Link to comment Share on other sites More sharing options...
ross549 Posted December 10, 2003 Author Share Posted December 10, 2003 My procs are Slot 1's, so a 370 heatsink will not work. Quote Link to comment Share on other sites More sharing options...
longgone Posted December 10, 2003 Share Posted December 10, 2003 Oh well, I tried, it is the thought that counts. Quote Link to comment Share on other sites More sharing options...
Guest ThunderRiver Posted December 10, 2003 Share Posted December 10, 2003 I doubt mine is a good suggestion, but have you looked into ebay or pricewatch.com ? Quote Link to comment Share on other sites More sharing options...
pc-tecky Posted December 10, 2003 Share Posted December 10, 2003 http://www.spartantech.comhttp://www.microcenter.comhttp://www.zakpc.comhttp://www.sky-pro.nethttp://www.buy.comP-III as in slot 1 or P-III as in Socket 370? There is a very important difference and it's definitely related to CPU clock speed. Slot 1 SECC2 has the four offset holes for the heatsink/fan. Socket 370 and Socket A are typically a heatsink/fan combo and may or may not always be inter-compatable, but I think they typically are. Milage will vary with locations of components on the motherboard . I hope that helps.Actually, using Pricewatch.com to follow most any link of a CPU or motherboard retailer's/distributor's web site to browse around will (85%-95%) get you to their CPU heatsink/fan selection on their site. Good luck. Quote Link to comment Share on other sites More sharing options...
Eric Legge Posted December 16, 2003 Share Posted December 16, 2003 A Google.com search for the type of cooler and the country, such as "slot 1" + cooler + uk, should bring up the links you need. I tried it, and the first link was for a Intel P111 Slot 1 cooler from ebay.co.uk.Substitute "Socket A", "Socket 478", etc. and the country to get what you want.Eric,http://www.legge40.freeserve.co.uk/BuyerBeware.htm Quote Link to comment Share on other sites More sharing options...
