NEW UPDATES Debian
debian updates sunrat bruno v.t. eric layton
1631 replies to this topic
#1626 OFFLINE   sunrat
sunrat
  • 5,968 posts
Posted 07 September 2019 - 08:40 PM
The Debian Project                               https://www.debian.org/
Updated Debian 10: 10.1 released                        press@debian.org
September 7th, 2019            https://www.debian.o...s/2019/20190907
The Debian project is pleased to announce the first update of its stable
distribution Debian 10 (codename "buster"). This point release mainly
adds corrections for security issues, along with a few adjustments for
serious problems. Security advisories have already been published
separately and are referenced where available.
Please note that the point release does not constitute a new version of
Debian 10 but only updates some of the packages included. There is no
need to throw away old "buster" media. After installation, packages can
be upgraded to the current versions using an up-to-date Debian mirror.
Those who frequently install updates from security.debian.org won't have
to update many packages, and most such updates are included in the point
release.
New installation images will be available soon at the regular locations.
Upgrading an existing installation to this revision can be achieved by
pointing the package management system at one of Debian's many HTTP
mirrors. A comprehensive list of mirrors is available at:
https://www.debian.org/mirror/list
Miscellaneous Bugfixes
This stable update adds a few important corrections to the following
packages:
| Package                  | Reason                                   |
| acme-tiny [1]            | Handle upcoming ACME protocol change     |
| android-sdk-meta [2]     | New upstream release; fix regex for      |
|                          | adding Debian version to binary packages |
| apt-setup [3]            | Fix preseeding of Secure Apt for local   |
|                          | repositories via apt-setup/localX/       |
| asterisk [4]             | Fix buffer overflow in                   |
|                          | res_pjsip_messaging [AST-2019-002 /      |
|                          | CVE-2019-12827]; fix remote Crash        |
|                          | Vulnerability in chan_sip [AST-2019-     |
|                          | 003 / CVE-2019-13161]                    |
| babeltrace [5]           | Bump ctf symbols depends to post merge   |
|                          | version                                  |
| backup-manager [6]       | Fix purging of remote archives via FTP   |
|                          | or SSH                                   |
| base-files [7]           | Update for the point release             |
| basez [8]                | Properly decode base64url encoded        |
|                          | strings                                  |
| bro [9]                  | Security fixes [CVE-2018-16807 CVE-2018- |
|                          | 17019]                                   |
| bzip2 [10]               | Fix regression uncompressing some files  |
| cacti [11]               | Fix some issues upgrading from the       |
|                          | version in stretch                       |
| calamares-settings-      | Fix permissions for initramfs image when |
| debian [12]              | full-disk encryption is enabled          |
|                          | [CVE-2019-13179]                         |
| ceph [13]                | Rebuild against new libbabeltrace        |
| clamav [14]              | Prevent extraction of non-recursive zip  |
|                          | bombs; new upstream stable release with  |
|                          | security fixes - add scan time limit to  |
|                          | mitigate against zip-bombs [CVE-2019-    |
|                          | 12625]; fix out-of-bounds write within   |
|                          | the NSIS bzip2 library [CVE-2019-12900]  |
| cloudkitty [15]          | Fix build failures with updated          |
|                          | SQLAlchemy                               |
| console-setup [16]       | Fix internationalization issues when     |
|                          | switching locales with Perl >= 5.28      |
| cryptsetup [17]          | Fix support for LUKS2 headers without    |
|                          | any bound keyslot; fix mapped segments   |
|                          | overflow on 32-bit architectures         |
| cups [18]                | Fix multiple security/disclosure issues  |
|                          | - SNMP buffer overflows [CVE-2019-8696   |
|                          | CVE-2019-8675], IPP buffer overflow,     |
|                          | Denial of Service and memory disclosure  |
|                          | issues in the scheduler                  |
| dbconfig-common [19]     | Fix issue caused by change in bash POSIX |
|                          | behaviour                                |
| debian-edu-config [20]   | Use PXE option  "ipappend 2"  for LTSP   |
|                          | client boot; fix sudo-ldap               |
|                          | configuration; fix loss of dynamically   |
|                          | allocated v4 IP address; several fixes   |
|                          | and improvements to debian-edu-          |
|                          | config.fetch-ldap-cert                   |
| debian-edu-doc [21]      | Update Debian Edu Buster and ITIL        |
|                          | manuals and translations                 |
| dehydrated [22]          | Fix fetching of account information;     |
|                          | follow-up fixes for account ID handling  |
|                          | and APIv1 compatibility                  |
| devscripts [23]          | debchange: target buster-backports with  |
|                          | --bpo option                             |
| dma [24]                 | Do not limit TLS connections to using    |
|                          | TLS 1.0                                  |
| dpdk [25]                | New upstream stable release              |
| dput-ng [26]             | Add buster-backports and stretch-        |
|                          | backports-sloppy codenames               |
| e2fsprogs [27]           | Fix e4defrag crashes on 32-bit           |
|                          | architectures                            |
| enigmail [28]            | New upstream release; security fixes     |
|                          | [CVE-2019-12269]                         |
| epiphany-browser [29]    | Ensure that the web extension uses the   |
|                          | bundled copy of libdazzle                |
| erlang-p1-pkix [30]      | Fix handling of GnuTLS certificates      |
| facter [31]              | Fix parsing of Linux route non-key/value |
|                          | flags (e.g. onlink)                      |
| fdroidserver [32]        | New upstream release                     |
| fig2dev [33]             | Do not segfault on circle/half circle    |
|                          | arrowheads with a magnification larger   |
|                          | than 42 [CVE-2019-14275]                 |
| firmware-nonfree [34]    | atheros: Add Qualcomm Atheros QCA9377    |
|                          | rev 1.0 firmware version WLAN.TF.2.1-    |
|                          | 00021-QCARMSWP-1; realtek: Add Realtek   |
|                          | RTL8822CU Bluetooth firmware; atheros:   |
|                          | Revert change of QCA9377 rev 1.0         |
|                          | firmware in 20180518-1; misc-nonfree:    |
|                          | add firmware for MediaTek MT76x0/MT76x2u |
|                          | wireless chips, MediaTek MT7622/MT7668   |
|                          | bluetooth chips, GV100 signed firmware   |
| freeorion [35]           | Fix crash when loading or saving game    |
|                          | data                                     |
| fuse-emulator [36]       | Prefer the X11 backend over the Wayland  |
|                          | one; show the Fuse icon on the GTK       |
|                          | window and About dialog                  |
| fusiondirectory [37]     | Stricter checks on LDAP lookups; add     |
|                          | missing dependency on php-xml            |
| gcab [38]                | Fix corruption when extracting           |
| gdb [39]                 | Rebuild against new libbabeltrace        |
| glib2.0 [40]             | Make GKeyFile settings backend create    |
|                          | ~/.config and configuration files with   |
|                          | restrictive permissions [CVE-2019-13012] |
| gnome-bluetooth [41]     | Avoid GNOME Shell crashes when gnome-    |
|                          | shell-extension-bluetooth-quick-connect  |
|                          | is used                                  |
| gnome-control-           | Fix crash when the Details -> Overview   |
| center [42]              | (info-overview) panel is selected; fix   |
|                          | memory leaks in Universal Access panel;  |
|                          | fix a regression that caused the         |
|                          | Universal Access -> Zoom mouse tracking  |
|                          | options to have no effect; updated       |
|                          | Icelandic and Japanese translations      |
| gnupg2 [43]              | Backport many bug fixes and stability    |
|                          | patches from upstream; use               |
|                          | keys.openpgp.org as the default          |
|                          | keyserver; only import self-signatures   |
|                          | by default                               |
| gnuplot [44]             | Fix incomplete/unsafe initialization of  |
|                          | ARGV array                               |
| gosa [45]                | Stricter checks on LDAP lookups          |
| hfst [46]                | Ensure smoother upgrades from stretch    |
| initramfs-tools [47]     | Disable resume when there are no         |
|                          | suitable swap devices; MODULES=most:     |
|                          | include all keyboard driver modules,     |
|                          | cros_ec_spi and SPI drivers, extcon-     |
|                          | usbc-cros-ec; MODULES=dep: include       |
|                          | extcon drivers                           |
| jython [48]              | Preserve backward compatibility with     |
|                          | Java 7                                   |
| lacme [49]               | Update for removal of unauthenticated    |
|                          | GET support from the Let's Encrypt       |
|                          | ACMEv2 API                               |
| libblockdev [50]         | Use existing cryptsetup API for changing |
|                          | keyslot passphrase                       |
| libdatetime-timezone-    | Update included data                     |
| perl [51]                |                                          |
| libjavascript-           | Add support for  "=>"  operator          |
| beautifier-perl [52]     |                                          |
| libsdl2-image [53]       | Fix buffer overflows [CVE-2019-5058      |
|                          | CVE-2019-5052 CVE-2019-7635]; fix out of |
|                          | bounds access in PCX handling [CVE-2019- |
|                          | 12216 CVE-2019-12217 CVE-2019-12218      |
|                          | CVE-2019-12219 CVE-2019-12220 CVE-2019-  |
|                          | 12221 CVE-2019-12222 CVE-2019-5051]      |
| libtk-img [54]           | Stop using internal copies of JPEG, Zlib |
|                          | and PixarLog codecs, fixing crashes      |
| libxslt [55]             | Fix security framework bypass [CVE-2019- |
|                          | 11068], uninitialized read of xsl:number |
|                          | token [CVE-2019-13117] and uninitialized |
|                          | read with UTF-8 grouping chars           |
|                          | [CVE-2019-13118]                         |
| linux [56]               | New upstream stable release              |
| linux-latest [57]        | Update for 4.19.0-6 kernel ABI           |
| linux-signed-amd64 [58]  | New upstream stable release              |
| linux-signed-arm64 [59]  | New upstream stable release              |
| linux-signed-i386 [60]   | New upstream stable release              |
| lttv [61]                | Rebuild against new libbabeltrace        |
| mapproxy [62]            | Fix WMS Capabilities with Python 3.7     |
| mariadb-10.3 [63]        | New upstream stable release; security    |
|                          | fixes [CVE-2019-2737 CVE-2019-2739       |
|                          | CVE-2019-2740 CVE-2019-2758 CVE-2019-    |
|                          | 2805]; fix segfault on                   |
|                          | 'information_schema' access; rename      |
|                          | 'mariadbcheck' to 'mariadb-check'        |
| musescore [64]           | Disable webkit functionality             |
| ncbi-tools6 [65]         | Repackage without non-free data/UniVec.* |
| ncurses [66]             | Remove  "rep"  from xterm-new and        |
|                          | derived terminfo descriptions            |
| netdata [67]             | Remove Google Analytics from generated   |
|                          | documentation; opt out of sending        |
|                          | anonymous statistics; remove  "sign in"  |
|                          | button                                   |
| newsboat [68]            | Fix use after free issue                 |
| nextcloud-desktop [69]   | Add missing dependency on nextcloud-     |
|                          | desktop-common to nextcloud-desktop-cmd  |
| node-lodash [70]         | Fix prototype pollution [CVE-2019-10744] |
| node-mixin-deep [71]     | Fix prototype pollution issue            |
| nss [72]                 | Fix security issues [CVE-2019-11719      |
|                          | CVE-2019-11727 CVE-2019-11729]           |
| nx-libs [73]             | Fix a number of memory leaks             |
| open-infrastructure-     | Fix container start                      |
| compute-tools [74]       |                                          |
| open-vm-tools [75]       | Correctly handle OS versions of the form |
|                          | "X" , rather than  "X.Y"                 |
| openldap [76]            | Restrict rootDN proxyauthz to its own    |
|                          | databases [CVE-2019-13057]; enforce      |
|                          | sasl_ssf ACL statement on every          |
|                          | connection [CVE-2019-13565]; fix slapo-  |
|                          | rwm to not free original filter when     |
|                          | rewritten filter is invalid              |
| osinfo-db [77]           | Add buster 10.0 information; fix URLs    |
|                          | for stretch download; fix the name of    |
|                          | the parameter used to set the fullname   |
|                          | when generating a preseed file           |
| osmpbf [78]              | Rebuild with protobuf 3.6.1              |
| pam-u2f [79]             | Fix insecure debug file handling         |
|                          | [CVE-2019-12209]; fix debug file         |
|                          | descriptor leak [CVE-2019-12210]; fix    |
|                          | out-of-bounds access; fix segfault       |
|                          | following a failure to allocate a buffer |
| passwordsafe [80]        | Install localisation files in the        |
|                          | correct directory                        |
| piuparts [81]            | Update configurations for the buster     |
|                          | release; fix spurious failure to remove  |
|                          | packages with names ending with '+';     |
|                          | generate separate tarball names for --   |
|                          | merged-usr chroots                       |
| postgresql-common [82]   | Fix  "pg_upgradecluster from postgresql- |
|                          | common 200, 200+deb10u1, 201, and 202    |
|                          | will corrupt the data_directory setting  |
|                          | when used *twice* to upgrade a cluster   |
|                          | (e.g. 9.6 -> 10 -> 11)"                  |
| pulseaudio [83]          | Fix mute state restoring                 |
| puppet-module-           | Fix attempts to write to /etc/init       |
| cinder [84]              |                                          |
| python-autobahn [85]     | Fix pyqrcode build dependencies          |
| python-django [86]       | New upstream security release [CVE-2019- |
|                          | 12781]                                   |
| raspi3-firmware [87]     | Add support for Raspberry Pi Compute     |
|                          | Module 3 (CM3), Raspberry Pi Compute     |
|                          | Module 3 Lite and Raspberry Pi Compute   |
|                          | Module IO Board V3                       |
| reportbug [88]           | Update release names, following buster   |
|                          | release; re-enable stretch-pu requests;  |
|                          | fix crashes with package / version       |
|                          | lookup; add missing dependency on        |
|                          | sensible-utils                           |
| ruby-airbrussh [89]      | Don't throw exception on invalid UTF-8   |
|                          | SSH output                               |
| sdl-image1.2 [90]        | Fix buffer overflows [CVE-2019-5052      |
|                          | CVE-2019-7635], out-of-bounds access     |
|                          | [CVE-2019-12216 CVE-2019-12217 CVE-2019- |
|                          | 12218 CVE-2019-12219 CVE-2019-12220      |
|                          | CVE-2019-12221 CVE-2019-12222 CVE-2019-  |
|                          | 5051]                                    |
| sendmail [91]            | sendmail-bin.postinst, initscript: Let   |
|                          | start-stop-daemon match on pidfile and   |
|                          | executable; sendmail-bin.prerm: Stop     |
|                          | sendmail before removing the             |
|                          | alternatives                             |
| slirp4netns [92]         | New upstream stable release with         |
|                          | security fixes - check sscanf result     |
|                          | when emulating ident [CVE-2019-9824];    |
|                          | fixes heap overflow in included libslirp |
|                          | [CVE-2019-14378]                         |
| systemd [93]             | Network: Fix failure to bring up         |
|                          | interface with Linux kernel 5.2; ask-    |
|                          | password: Prevent buffer overflow when   |
|                          | reading from keyring; network: Behave    |
|                          | more gracefully when IPv6 has been       |
|                          | disabled                                 |
| tzdata [94]              | New upstream release                     |
| unzip [95]               | Fix zip bomb issues [CVE-2019-13232]     |
| usb.ids [96]             | Routine update of USB IDs                |
| warzone2100 [97]         | Fix a segmentation fault when hosting a  |
|                          | multiplayer game                         |
| webkit2gtk [98]          | New upstream stable version; stop        |
|                          | requiring SSE2-capable CPUs              |
| win32-loader [99]        | Rebuild against current packages,        |
|                          | particularly debian-archive-keyring; fix |
|                          | build failure by enforcing a POSIX       |
|                          | locale                                   |
| xymon [100]              | Fix several (server only) security       |
|                          | issues [CVE-2019-13273 CVE-2019-13274    |
|                          | CVE-2019-13451 CVE-2019-13452 CVE-2019-  |
|                          | 13455 CVE-2019-13484 CVE-2019-13485      |
|                          | CVE-2019-13486]                          |
| yubikey-                 | Backport additional security precautions |
| personalization [101]    |                                          |
| z3 [102]                 | Do not set the SONAME of libz3java.so to |
|                          | libz3.so.4                               |
Security Updates
This revision adds the following security updates to the stable release.
The Security Team has already released an advisory for each of these
updates:
| Advisory ID    | Package                  |
| DSA-4477 [103] | zeromq3 [104]            |
| DSA-4478 [105] | dosbox [106]             |
| DSA-4479 [107] | firefox-esr [108]        |
| DSA-4480 [109] | redis [110]              |
| DSA-4481 [111] | ruby-mini-magick [112]   |
| DSA-4482 [113] | thunderbird [114]        |
| DSA-4483 [115] | libreoffice [116]        |
| DSA-4484 [117] | linux [118]              |
| DSA-4484 [119] | linux-signed-i386 [120]  |
| DSA-4484 [121] | linux-signed-arm64 [122] |
| DSA-4484 [123] | linux-signed-amd64 [124] |
| DSA-4486 [125] | openjdk-11 [126]         |
| DSA-4488 [127] | exim4 [128]              |
| DSA-4489 [129] | patch [130]              |
| DSA-4490 [131] | subversion [132]         |
| DSA-4491 [133] | proftpd-dfsg [134]       |
| DSA-4493 [135] | postgresql-11 [136]      |
| DSA-4494 [137] | kconfig [138]            |
| DSA-4495 [139] | linux-signed-amd64 [140] |
| DSA-4495 [141] | linux-signed-arm64 [142] |
| DSA-4495 [143] | linux [144]              |
| DSA-4495 [145] | linux-signed-i386 [146]  |
| DSA-4496 [147] | pango1.0 [148]           |
| DSA-4498 [149] | python-django [150]      |
| DSA-4499 [151] | ghostscript [152]        |
| DSA-4501 [153] | libreoffice [154]        |
| DSA-4502 [155] | ffmpeg [156]             |
| DSA-4503 [157] | golang-1.11 [158]        |
| DSA-4504 [159] | vlc [160]                |
| DSA-4505 [161] | nginx [162]              |
| DSA-4507 [163] | squid [164]              |
| DSA-4508 [165] | h2o [166]                |
| DSA-4509 [167] | apache2 [168]            |
| DSA-4510 [169] | dovecot [170]            |
Removed packages
The following packages were removed due to circumstances beyond our
control:
| Package     | Reason                         |
| pump [171]  | Unmaintained; security issues  |
| rustc [172] | Remove outdated rust-doc cruft |
Debian Installer
The installer has been updated to include the fixes incorporated into
stable by the point release.
URLs
The complete lists of packages that have changed with this revision:
http://ftp.debian.or...uster/ChangeLog
The current stable distribution:
http://ftp.debian.or...n/dists/stable/
Proposed updates to the stable distribution:
http://ftp.debian.or...roposed-updates
stable distribution information (release notes, errata etc.):
https://www.debian.o...eleases/stable/
Security announcements and information:
https://www.debian.org/security/
#1627 OFFLINE   sunrat
sunrat
  • 5,968 posts
Posted 07 September 2019 - 08:42 PM
Updated Debian 9: 9.10 released                         press@debian.org
September 7th, 2019          https://www.debian.o...2019/2019090702
The Debian project is pleased to announce the tenth update of its
oldstable distribution Debian 9 (codename "stretch"). This point release
mainly adds corrections for security issues, along with a few
adjustments for serious problems. Security advisories have already been
published separately and are referenced where available.
Debian 9 but only updates some of the packages included. There is no
need to throw away old "stretch" media. After installation, packages can
release.
This oldstable update adds a few important corrections to the following
packages:
| Package                 | Reason                                    |
| base-files [1]          | Update for the point release; add         |
|                         | VERSION_CODENAME to os-release            |
| basez [2]               | Properly decode base64url encoded strings |
| biomaj-watcher [3]      | Fix upgrades from jessie to stretch       |
| c-icap-modules [4]      | Add support for clamav 0.101.1            |
| chaosreader [5]         | Add missing dependency on libnet-dns-perl |
| clamav [6]              | New upstream stable release: add scan     |
|                         | time limit to mitigate against zip-bombs  |
|                         | [CVE-2019-12625]; fix out-of-bounds write |
|                         | within the NSIS bzip2 library [CVE-2019-  |
|                         | 12900]                                    |
| corekeeper [7]          | Do not use a world-writable /var/crash    |
|                         | with the dumper script; handle older      |
|                         | versions of the Linux kernel in a safer   |
|                         | way; do not truncate core names for       |
|                         | executables with spaces                   |
| cups [8]                | Fix multiple security/disclosure issues - |
|                         | SNMP buffer overflows [CVE-2019-8696      |
| dansguardian [9]        | Add support for clamav 0.101              |
| dar [10]                | Rebuild to update  "built-using"          |
|                         | packages                                  |
| debian-archive-         | Add buster keys; remove wheezy keys       |
| keyring [11]            |                                           |
| fence-agents [12]       | Fix denial of service issue [CVE-2019-    |
|                         | 10153]                                    |
| fig2dev [13]            | Do not segfault on circle/half circle     |
| fribidi [14]            | Fix right-to-left output in debian-       |
|                         | installer text mode                       |
| fusiondirectory [15]    | Stricter checks on LDAP lookups; add      |
| gettext [16]            | Stop xgettext() from crashing when run    |
|                         | with --its=FILE option                    |
| glib2.0 [17]            | Create directory and file with            |
|                         | restrictive permissions when using the    |
|                         | GKeyfileSettingsBackend [CVE-2019-13012]; |
|                         | avoid buffer read overrun when formatting |
|                         | error messages for invalid UTF-8 in       |
|                         | GMarkup [CVE-2018-16429]; avoid NULL      |
|                         | dereference when parsing invalid GMarkup  |
|                         | with a malformed closing tag not paired   |
|                         | with an opening tag [CVE-2018-16429]      |
| gocode [18]             | gocode-auto-complete-el: Make pre-        |
|                         | dependency on auto-complete-el versioned  |
|                         | to fix upgrades from jessie to stretch    |
| groonga [19]            | Mitigate privilege escalation by changing |
|                         | the owner and group of logs with  "su"    |
|                         | option                                    |
| grub2 [20]              | Fixes for Xen UEFI support                |
| gsoap [21]              | Fix denial of service issue if a server   |
|                         | application is built with the -           |
|                         | DWITH_COOKIES flag [CVE-2019-7659]; fix   |
|                         | issue with DIME protocol receiver and     |
|                         | malformed DIME headers                    |
| gthumb [22]             | Fix double-free bug [CVE-2018-18718]      |
| havp [23]               | Add support for clamav 0.101.1            |
| icu [24]                | Fix segfault in pkgdata command           |
| koji [25]               | Fix SQL injection issue [CVE-2018-        |
|                         | 1002161]; properly validate SCM paths     |
|                         | [CVE-2017-1002153]                        |
| lemonldap-ng [26]       | Fix cross-domain authentication           |
|                         | regression; fix XML external entity       |
|                         | vulnerability                             |
| libcaca [27]            | Fix integer overflow issues [CVE-2018-    |
|                         | 20545 CVE-2018-20546 CVE-2018-20547       |
|                         | CVE-2018-20548 CVE-2018-20549]            |
| libclamunrar [28]       | New upstream stable release               |
| libconvert-units-       | No-change rebuild with fixed version      |
| perl [29]               | number                                    |
| perl [30]               |                                           |
| libebml [31]            | Apply upstream fixes for heap-based       |
|                         | buffer over-reads                         |
| libevent-rpc-perl [32]  | Fix build failure due to expired test SSL |
|                         | certificates                              |
| libgd2 [33]             | Fix uninitialized read in                 |
|                         | gdImageCreateFromXbm [CVE-2019-11038]     |
| libgovirt [34]          | Re-generate test certificates with        |
|                         | expiration date far in the future to      |
|                         | avoid test failures                       |
| librecad [35]           | Fix denial of service via crafted file    |
|                         | [CVE-2018-19105]                          |
| libsdl2-image [36]      | Fix multiple security issues              |
| libthrift-java [37]     | Fix bypass of SASL negotiation [CVE-2018- |
|                         | 1320]                                     |
| libtk-img [38]          | Stop using internal copies of JPEG, Zlib  |
| libu2f-host [39]        | Fix stack memory leak [CVE-2019-9578]     |
| libxslt [40]            | Fix security framework bypass [CVE-2019-  |
|                         | 11068]; fix uninitialized read of         |
|                         | xsl:number token [CVE-2019-13117]; fix    |
|                         | uninitialized read with UTF-8 grouping    |
|                         | chars [CVE-2019-13118]                    |
| linux [41]              | New upstream version with ABI bump;       |
|                         | security fixes [CVE-2015-8553 CVE-2017-   |
|                         | 5967 CVE-2018-20509 CVE-2018-20510        |
|                         | CVE-2018-20836 CVE-2018-5995 CVE-2019-    |
|                         | 11487 CVE-2019-3882]                      |
| linux-latest [42]       | Update for 4.9.0-11 kernel ABI            |
| liquidsoap [43]         | Fix compilation with Ocaml 4.02           |
| llvm-toolchain-7 [44]   | New package to support building new       |
|                         | Firefox versions                          |
| mariadb-10.1 [45]       | New upstream stable release; security     |
|                         | CVE-2019-2740 CVE-2019-2805 CVE-2019-2627 |
|                         | CVE-2019-2614]                            |
| minissdpd [46]          | Prevent a use-after-free vulnerability    |
|                         | that would allow a remote attacker to     |
|                         | crash the process [CVE-2019-12106]        |
| miniupnpd [47]          | Fix denial of service issues [CVE-2019-   |
|                         | 12108 CVE-2019-12109 CVE-2019-12110]; fix |
|                         | information leak [CVE-2019-12107]         |
| mitmproxy [48]          | Blacklist tests that require Internet     |
|                         | access; prevent insertion of unwanted     |
|                         | upper-bound versioned dependencies        |
| monkeysphere [49]       | Fix build failure by updating the tests   |
|                         | to accommodate an updated GnuPG in        |
|                         | stretch now producing a different output  |
| nasm-mozilla [50]       | New package to support building new       |
| ncbi-tools6 [51]        | Repackage without non-free data/UniVec.*  |
| node-growl [52]         | Sanitize input before passing it to exec  |
| node-ws [53]            | Restrict upload size [CVE-2016-10542]     |
| open-vm-tools [54]      | Fix possible security issue with the      |
|                         | permissions of the intermediate staging   |
|                         | directory and path                        |
| openldap [55]           | Restrict rootDN proxyauthz to its own     |
| openssh [56]            | Fix deadlock in key matching              |
| passwordsafe [57]       | Don't install localization files under an |
|                         | extra subdirectory                        |
| pound [58]              | Fix request smuggling via crafted headers |
|                         | [CVE-2016-10711]                          |
| prelink [59]            | Rebuild to update  "built-using"          |
|                         | packages                                  |
| python-clamav [60]      | Add support for clamav 0.101.1            |
| reportbug [61]          | Update release names, following buster    |
|                         | release                                   |
| resiprocate [62]        | Resolve an installation issue with        |
|                         | libssl-dev and --install-recommends       |
| sash [63]               | Rebuild to update  "built-using"          |
|                         | packages                                  |
| sdl-image1.2 [64]       | Fix buffer overflows [CVE-2018-3977       |
|                         | CVE-2019-5058 CVE-2019-5052], out-of-     |
|                         | bounds access [CVE-2019-12216 CVE-2019-   |
|                         | 12217 CVE-2019-12218 CVE-2019-12219       |
|                         | CVE-2019-12220 CVE-2019-12221 CVE-2019-   |
|                         | 12222 CVE-2019-5051]                      |
| signing-party [65]      | Fix unsafe shell call enabling shell      |
|                         | injection via a User ID [CVE-2019-11627]  |
| slurm-llnl [66]         | Fix potential heap overflow on 32-bit     |
|                         | systems [CVE-2019-6438]                   |
| sox [67]                | Fix several security issues [CVE-2019-    |
|                         | 8354 CVE-2019-8355 CVE-2019-8356          |
|                         | CVE-2019-8357 927906 CVE-2019-1010004     |
|                         | CVE-2017-18189 881121 CVE-2017-15642      |
|                         | 882144 CVE-2017-15372 878808 CVE-2017-    |
|                         | 15371 878809 CVE-2017-15370 878810        |
|                         | CVE-2017-11359 CVE-2017-11358 CVE-2017-   |
|                         | 11332                                     |
| systemd [68]            | Do not stop ndisc client in case of       |
|                         | configuration error                       |
| t-digest [69]           | No-change rebuild to avoid re-use of pre- |
|                         | epoch version 3.0-1                       |
| tenshi [70]             | Fix PID file issue that allows local      |
|                         | users to kill arbitrary processes         |
|                         | [CVE-2017-11746]                          |
| tzdata [71]             | New upstream release                      |
| unzip [72]              | Fix incorrect parsing of 64-bit values in |
|                         | fileio.c; fix zip-bomb issues [CVE-2019-  |
|                         | 13232]                                    |
| usbutils [73]           | Update USB ID list                        |
| xymon [74]              | Fix several (server only) security issues |
|                         | [CVE-2019-13273 CVE-2019-13274 CVE-2019-  |
|                         | 13451 CVE-2019-13452 CVE-2019-13455       |
|                         | CVE-2019-13484 CVE-2019-13485 CVE-2019-   |
|                         | 13486]                                    |
| yubico-piv-tool [75]    | Fix security issues [CVE-2018-14779       |
|                         | CVE-2018-14780]                           |
| z3 [76]                 | Do not set the SONAME of libz3java.so to  |
|                         | libz3.so.4                                |
| zfs-auto-snapshot [77]  | Make cron jobs exit silently after        |
|                         | package removal                           |
| zsh [78]                | Rebuild to update  "built-using"          |
|                         | packages                                  |
Security Updates
This revision adds the following security updates to the oldstable
release. The Security Team has already released an advisory for each of
these updates:
| DSA-4435 [79]  | libpng1.6 [80]           |
| DSA-4436 [81]  | imagemagick [82]         |
| DSA-4437 [83]  | gst-plugins-base1.0 [84] |
| DSA-4438 [85]  | atftp [86]               |
| DSA-4439 [87]  | postgresql-9.6 [88]      |
| DSA-4440 [89]  | bind9 [90]               |
| DSA-4441 [91]  | symfony [92]             |
| DSA-4442 [93]  | cups-filters [94]        |
| DSA-4442 [95]  | ghostscript [96]         |
| DSA-4443 [97]  | samba [98]               |
| DSA-4444 [99]  | linux [100]              |
| DSA-4445 [101] | drupal7 [102]            |
| DSA-4446 [103] | lemonldap-ng [104]       |
| DSA-4447 [105] | intel-microcode [106]    |
| DSA-4448 [107] | firefox-esr [108]        |
| DSA-4449 [109] | ffmpeg [110]             |
| DSA-4450 [111] | wpa [112]                |
| DSA-4451 [113] | thunderbird [114]        |
| DSA-4452 [115] | jackson-databind [116]   |
| DSA-4453 [117] | openjdk-8 [118]          |
| DSA-4454 [119] | qemu [120]               |
| DSA-4455 [121] | heimdal [122]            |
| DSA-4456 [123] | exim4 [124]              |
| DSA-4457 [125] | evolution [126]          |
| DSA-4458 [127] | cyrus-imapd [128]        |
| DSA-4459 [129] | vlc [130]                |
| DSA-4460 [131] | mediawiki [132]          |
| DSA-4461 [133] | zookeeper [134]          |
| DSA-4462 [135] | dbus [136]               |
| DSA-4463 [137] | znc [138]                |
| DSA-4464 [139] | thunderbird [140]        |
| DSA-4465 [141] | linux [142]              |
| DSA-4466 [143] | firefox-esr [144]        |
| DSA-4467 [145] | vim [146]                |
| DSA-4468 [147] | php-horde-form [148]     |
| DSA-4469 [149] | libvirt [150]            |
| DSA-4470 [151] | pdns [152]               |
| DSA-4471 [153] | thunderbird [154]        |
| DSA-4472 [155] | expat [156]              |
| DSA-4473 [157] | rdesktop [158]           |
| DSA-4475 [159] | openssl [160]            |
| DSA-4475 [161] | openssl1.0 [162]         |
| DSA-4476 [163] | python-django [164]      |
| DSA-4477 [165] | zeromq3 [166]            |
| DSA-4478 [167] | dosbox [168]             |
| DSA-4480 [169] | redis [170]              |
| DSA-4481 [171] | ruby-mini-magick [172]   |
| DSA-4482 [173] | thunderbird [174]        |
| DSA-4483 [175] | libreoffice [176]        |
| DSA-4485 [177] | openjdk-8 [178]          |
| DSA-4487 [179] | neovim [180]             |
| DSA-4488 [181] | exim4 [182]              |
| DSA-4489 [183] | patch [184]              |
| DSA-4490 [185] | subversion [186]         |
| DSA-4491 [187] | proftpd-dfsg [188]       |
| DSA-4492 [189] | postgresql-9.6 [190]     |
| DSA-4494 [191] | kconfig [192]            |
| DSA-4498 [193] | python-django [194]      |
| DSA-4499 [195] | ghostscript [196]        |
| DSA-4501 [197] | libreoffice [198]        |
| DSA-4504 [199] | vlc [200]                |
| DSA-4505 [201] | nginx [202]              |
| DSA-4506 [203] | qemu [204]               |
| DSA-4509 [205] | apache2 [206]            |
| DSA-4510 [207] | dovecot [208]            |
Removed packages
control:
| Package         | Reason                                             |
| pump [209]      | Unmaintained; security issues                      |
| teeworlds [210] | Security issues; incompatible with current servers |
Debian Installer
oldstable by the point release.
URLs
http://ftp.debian.or...retch/ChangeLog
The current oldstable distribution:
http://ftp.debian.or...ists/oldstable/
Proposed updates to the oldstable distribution:
oldstable distribution information (release notes, errata etc.):
https://www.debian.o...ases/oldstable/
Debian Security Advisory DSA-4518-1                   security@debian.org
https://www.debian.org/security/                     Salvatore Bonaccorso
September 07, 2019                    https://www.debian.org/security/faq
Package        : ghostscript
CVE ID         : CVE-2019-14811 CVE-2019-14812 CVE-2019-14813 CVE-2019-14817
It was discovered that various procedures in Ghostscript, the GPL
PostScript/PDF interpreter, do not properly restrict privileged calls,
which could result in bypass of file system restrictions of the dSAFER
sandbox.
For the oldstable distribution (stretch), these problems have been fixed
in version 9.26a~dfsg-0+deb9u5.
For the stable distribution (buster), these problems have been fixed in
version 9.27~dfsg-2+deb10u2.
#1628 OFFLINE   sunrat
sunrat
  • 5,968 posts
Posted 08 September 2019 - 08:32 PM
Updated Debian 9: 9.11 released                         press@debian.org
September 8th, 2019            https://www.debian.o...s/2019/20190908
The Debian project is pleased to announce the eleventh update of its
This point release is primarily an update to the recently-released 9.10,
in order to resolve a critical problem with the installer that was
discovered during image testing.
release.
packages:
| Package                        | Reason                             |
| base-files [1]                 | Update for the point release       |
| bogl [2]                       | Call iswspace instead of isspace,  |
|                                | fixes crash on U+FEFF              |
| debian-installer [3]           | Rebuild against proposed-updates   |
| debian-installer-netboot-      | Rebuild against proposed-updates   |
| images [4]                     |                                    |
    1: https://packages.deb.../src:base-files
    2: https://packages.debian.org/src:bogl
    3: https://packages.deb...ebian-installer
    4: https://packages.deb...-netboot-images
Debian Installer
#1629 OFFLINE   sunrat
sunrat
  • 5,968 posts
Posted 09 September 2019 - 02:47 AM
Debian Security Advisory DSA-4519-1                   security@debian.org
https://www.debian.org/security/                       Moritz Muehlenhoff
September 08, 2019                    https://www.debian.org/security/faq
Package        : libreoffice
CVE ID         : CVE-2019-9854
It was discovered that the code fixes for LibreOffice to address
CVE-2019-9852 were not complete. Additional information can be found at
https://www.libreoff.../CVE-2019-9854/
For the oldstable distribution (stretch), this problem has been fixed
in version 1:5.2.7-1+deb9u11.
For the stable distribution (buster), this problem has been fixed in
version 1:6.1.5-3+deb10u4.
#1630 OFFLINE   sunrat
sunrat
  • 5,968 posts
Posted 09 September 2019 - 08:07 PM
Debian Security Advisory DSA-4520-1                   security@debian.org
September 09, 2019                    https://www.debian.org/security/faq
Package        : trafficserver
CVE ID         : CVE-2019-9512 CVE-2019-9514 CVE-2019-9515 CVE-2019-9518
Several vulnerabilities were discovered in the HTTP/2 code of Apache
Traffic Server, a reverse and forward proxy server, which could result
in denial of service.
The fixes are too intrusive to backport to the version in the oldstable
distribution (stretch). An upgrade to Debian stable (buster) is
recommended instead.
version 8.0.2+ds-1+deb10u1.
Debian Security Advisory DSA-4521-1                   security@debian.org
Package        : docker.io
CVE ID         : CVE-2019-13139 CVE-2019-13509 CVE-2019-14271
Three security vulnerabilities have been discovered in the Docker
container runtime: Insecure loading of NSS libraries in "docker cp"
could result in execution of code with root privileges, sensitive data
could be logged in debug mode and there was a command injection
vulnerability in the "docker build" command.
version 18.09.1+dfsg1-7.1+deb10u1.
#1631 OFFLINE   sunrat
sunrat
  • 5,968 posts
Posted 15 September 2019 - 08:20 PM
Debian Security Advisory DSA-4522-1                   security@debian.org
https://www.debian.org/security/                            Hugo Lefeuvre
September 15, 2019                    https://www.debian.org/security/faq
Package        : faad2
CVE ID         : CVE-2018-19502 CVE-2018-19503 CVE-2018-19504 CVE-2018-20194
                 CVE-2018-20195 CVE-2018-20197 CVE-2018-20198 CVE-2018-20357
                 CVE-2018-20358 CVE-2018-20359 CVE-2018-20361 CVE-2018-20362
                 CVE-2019-15296
Debian Bug     : 914641
Multiple vulnerabilities have been discovered in faad2, the Freeware Advanced
Audio Coder. These vulnerabilities might allow remote attackers to cause
denial-of-service, or potentially execute arbitrary code if crafted MPEG AAC
files are processed.
in version 2.8.0~cvs20161113-1+deb9u2.
Debian Security Advisory DSA-4523-1                   security@debian.org
Package        : thunderbird
CVE ID         : CVE-2019-11739 CVE-2019-11740 CVE-2019-11742 CVE-2019-11743
                 CVE-2019-11744 CVE-2019-11746 CVE-2019-11752
Multiple security issues have been found in Thunderbird which could
potentially result in the execution of arbitrary code, cross-site
scripting, information disclosure and a covert content attack on S/MIME
encryption using a crafted multipart/alternative message.
in version 1:60.9.0-1~deb9u1.
version 1:60.9.0-1~deb10u1.
#1632 OFFLINE   sunrat
sunrat
  • 5,968 posts
Posted Yesterday, 12:47 AM
Debian Security Advisory DSA-4524-1                   security@debian.org
September 16, 2019                    https://www.debian.org/security/faq
Package        : dino-im
CVE ID         : CVE-2019-16235 CVE-2019-16236 CVE-2019-16237
Multiple vulnerabilities have been discovered in the Dino XMPP client,
which could allow spoofing message, manipulation of a user's roster
(contact list) and unauthorised sending of message carbons.
version 0.0.git20181129-1+deb10u1.
Also tagged with one or more of these keywords: debian, updates, sunrat, bruno, v.t. eric layton
