réjean Posted February 2, 2006 Share Posted February 2, 2006 (edited) Hi everyone!Last night I formatted my whole hd and started reinstalling everything. First I installed Mandriva on hda1 (/) and hda5 (/home) both about 5 Gb each with a 500 Mb Swap partition on hda6. Then I installed PCLinuxOS ( Can you believe that it took over 3h 40 min even before the online updates? ) on hda7 (/) and hda8(/home) also roughly 5GB each. I decided to use its bootloader as the main bootloader ( nicer than mandriva and Konqueror has the tendency to freeze or crash on me all the time ). This morning I installed Xandros on hda3 (2nd primary partition I guess) also close to 5 GB which leaves me with 12 or 13 GB for when SuSE 10.1 will finally be released.Now I can boot in all the distros except for mandriva.When I try to "/sbin/lilo" in PCLinuxOS I get the following: [rejean@XANO21XGB7 ~]$ suPassword:[root@XANO21XGB7 rejean]# /sbin/liloAdded pclinuxos *Added ubuntuWarning: First sector of /dev/hda1 doesn't have a valid boot signatureAdded mandrivaAdded xandros[root@XANO21XGB7 rejean]# Notice btw that Xandros changed the name of the computer but that's ok. I can live with it or go back a few days and see what was Bruno's suggestion to change that.Here is the Mandriva /etc/lilo.conf: # File generated by DrakX/drakboot# WARNING: do not forget to run lilo after modifying this filedefault="linux"boot=/dev/hda1map=/boot/mapkeytable=/boot/us.kltmenu-scheme=wb:bw:wb:bwpromptnowarntimeout=100message=/boot/messageimage=/boot/vmlinuz label="linux" root=/dev/hda1 initrd=/boot/initrd.img append=" acpi=ht resume=/dev/hda6 splash=silent" vga=788image=/boot/vmlinuz label="linux-nonfb" root=/dev/hda1 initrd=/boot/initrd.img append=" acpi=ht resume=/dev/hda6"image=/boot/vmlinuz label="failsafe" root=/dev/hda1 initrd=/boot/initrd.img append=" failsafe acpi=ht resume=/dev/hda6" I thought I would ask before I mess up everything but could it be that all I have to do is change the line: default="linux" to default="mandriva" Edited February 2, 2006 by réjean Quote Link to comment Share on other sites More sharing options...
Bruno Posted February 2, 2006 Share Posted February 2, 2006 Hi RéjeanWhat I would need to see is the /etc/lilo.conf from PCLos ( where you added all the distros )My guess is that you pointed it to: other=/dev/hda1 label="mandrake"But that the lilo of mandrake is NOT in hda1 . . . this means you will have to add mandrake in the oldfashion way BrunoPS: I thought I would ask before I mess up everything but could it be that all I have to do is change the line:CODEdefault="linux"toCODEdefault="mandriva"Nope it is okay like it is now . . . . your mandriva lilo has "Linux" in both places so that is okay Quote Link to comment Share on other sites More sharing options...
réjean Posted February 2, 2006 Author Share Posted February 2, 2006 Thanks Bruno!That did it! It took me quite awhile to figure it out. I think it's because my notes are based on your tutorial "Multiple boot" and Slax doesn't use initrd so I was putting it into the PCLos /etc/lilo.conf but wasn't doing a cp /mnt/mandriva/boot/initrd... /boot/mandriva One more question if I may. I have to change the xorg.conf ( that I know because the desktop is a mess again ) but during the install or the initial opening I was asked if I wanted xorg to open automatically at boot time and I said no. Is it something I can change in MCC? Quote Link to comment Share on other sites More sharing options...
Bruno Posted February 2, 2006 Share Posted February 2, 2006 Glad that part is fixed now One more question if I may. I have to change the xorg.conf ( that I know because the desktop is a mess again ) but during the install or the initial opening I was asked if I wanted xorg to open automatically at boot time and I said no. Is it something I can change in MCC?Yep in the MCC under "boot" there should be a setting that tells the bootloader that you want X to start automatically Bruno Quote Link to comment Share on other sites More sharing options...
