V.T. Eric Layton Posted June 22, 2009 Share Posted June 22, 2009 If you have multiple hard drives on your system and have Windows installed on the 1st partition (where it must be to operate) of your non-boot (1st) drive, then you have to make a few changes in how you boot using GRUB. Let's say you have two SATA drives. In GRUBspeak, they are (hd0) and (hd1). And let's say that your primary operating system (Linux) is on (hd0) and your Windows is on (hd1). To chainload Windows with GRUB you'll need an entry similar to this: title Windowsroot (hd1,0)savedefaultmap (hd0) (hd1)map (hd1) (hd0)chainloader +1 What the "map" entries do is to trick GRUB into thinking that Windows is on the 1st hard drive.Now here's a recent problem I had...Last night, after a weekend long install-fest, I realized that my Windows installation would not boot using GRUB. To check Windows integrity, I used fdisk to set a bootable flag on my secondary SATA drive (where Windows is located). This will force a bypass of GRUB on my primary drive and boot the secondary drive directly using whatever bootloader is present in the MBR of that drive (in this case, Windows bootloader). The Windows installation booted fine this way. That told me that my GRUB - menu.lst entry for Windows was not correct.I had never booted this installation of Windows since installing it. It's there to play games on my system and that's about it. My Windows doesn't even have Network capabilities enabled. Anyway, I have a unique situation on my system because it's a hybrid of EIDE and SATA drives. GRUB gets confused on how it identifies my SATA drive because of this. It calls my 1st SATA (hd0), which is correct. However, it thinks my 2nd SATA is (hd2), which would normally be the designation for a third SATA drive, not a second one. This really confused me too, when I first started adding entries to my menu.lst for booting alternate operating systems. I've gotten used to it by now, though.The problem with my Windows menu.lst entry was that the drives were misidentified (my boo-boo). To get it to work on my system, I had to make my entry thus: title Windowsroot (hd2,0)savedefaultmap (hd0)(hd2)map (hd2)(hd0)chainloader +1 That did the trick. I can now load S.T.A.L.K.E.R. Shadow of Chernobyl and go kill some mutants. ;)Have while you're learning. Quote Link to comment Share on other sites More sharing options...
sunrat Posted June 23, 2009 Share Posted June 23, 2009 Good info. I make life easy by having Windows on the first partition of the first drive, and not mixing SATA and IDE drives (I put IDE in external USB boxes).And I can't imagine why you have savedefault in your GRUB entry. Why would you ever want Doze to start automatically when it was the last OS booted? Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted June 23, 2009 Author Share Posted June 23, 2009 Myeh... the stock Debian menu.lst had it that way. I just never changed it. And it doesn't work anyway because Winduhs definitely does NOT auto-boot on my system. The default boot OS is ALWAYS Slackware. Quote Link to comment Share on other sites More sharing options...
sunrat Posted June 23, 2009 Share Posted June 23, 2009 Myeh... the stock Debian menu.lst had it that way. I just never changed it. And it doesn't work anyway because Winduhs definitely does NOT auto-boot on my system. The default boot OS is ALWAYS Slackware. savedefault works for me. I only have it for Lenny, my main OS. Of course you also need default saved in the "default" entry near the top.I use Sidux' GRUB as it's prettier, and if I have a number as default it changes whenever I add a new kernel in Sidux - ie. regularly. Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted June 23, 2009 Author Share Posted June 23, 2009 I just fixed it. Quote Link to comment Share on other sites More sharing options...
Frank Golden Posted June 24, 2009 Share Posted June 24, 2009 (edited) An aside here. While it is true that Windows XP needs to be on the first partition of any drive to work, Win 7 can be anywhere.I have it installed on sda10 with XP at sda1.All this is installed on my main internal drive with several linux distros. Hardy at sda5 is where menu.lst is and the entry for Windows automatically created when I installed Hardy after XP. Later installing Win 7 wiped out my Grub and replaced it with Win 7/older version of Windows boot menu. Using super grub to restore Grub to sda5 created a hybrid menu where clicking on the Windows menu item brings up the Win 7/ older version of Windows menu.No fussing around with creating chainload entries etc. Edited June 24, 2009 by Frank Golden Quote Link to comment Share on other sites More sharing options...
mhbell Posted June 28, 2009 Share Posted June 28, 2009 An aside here. While it is true that Windows XP needs to be on the first partition of any drive to work, Win 7 can be anywhere.No fussing around with creating chainload entries etc.Hello FrankCorrect me if I am wrong. I believe that win XP can be anywhere on the drive Including a second hard drive, But only the Boot loader has to be on the first partition, Unless you are using a 3rd party boot manager like boot it NT.Mel Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted June 28, 2009 Author Share Posted June 28, 2009 The Windows XP disk will not let you install on any partition but #1 as far as I can remember. That's been my experience. I don't have time at the moment to Google documentation about this, though. I could always be wrong, but I distinctly remember the Windows XP installation not allowing me to put Windows anywhere but partition #1. I could be wrong. It's happened before. Quote Link to comment Share on other sites More sharing options...
mhbell Posted June 29, 2009 Share Posted June 29, 2009 (edited) The Windows XP disk will not let you install on any partition but #1 as far as I can remember. That's been my experience. I don't have time at the moment to Google documentation about this, though. I could always be wrong, but I distinctly remember the Windows XP installation not allowing me to put Windows anywhere but partition #1. I could be wrong. It's happened before. Sorry Eric, But you are wrong. It can be done as I have done it. You can put XP on any primary partition as long as the boot loader (boot.ini), (NTLDR) and another file I forget which one, is on the C drive (1st Partition) or if you use a Boot manager such as Boot-it-NG Boot magic or have Vista Installed. It can also be installed on a Logical Partition but that is a little more involved.Example: Not using any add-in boot-manager utils, you can install the actual OS itself - its system folders/files - to a logical drive..., but the actual boot/start-up files "must" be in the active Primary partition... The ARC/path-statement will point to the correct location of the ntldr etc. and thus boot the OS (XP - or W2K/NT) that is installed in other than the active Primary...I have a feeling that even using a decent boot-util the same condition applies. The only difference being that the boot-util slips itself into the active Primary etc., replaces the NT style boot-menu and efffectively controls what boots and how...Take a look at the Boot.ini file in the windows C drive to get a better picture of what is going on. It is hidden so you will have to change the attributes.Mel Edited June 29, 2009 by mhbell Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted June 29, 2009 Author Share Posted June 29, 2009 (edited) Hmmm... well, you learn sumthin' new ever day. Yup! :w00t:From Microsoft: Also, you must have 30 MB free space on the first primary system partition for installation. The first primary system partition is the disk volume that contains the hardware-specific files that you must have to start Windows. For example, the primary system partition contains the Ntldr, Boot.ini, and Ntdetect.com files. http://support.microsoft.com/kb/326583/en-usH3ll, for that you basically must install Windows on the first partition.. at least part of it. Either that or make a first partition that is 30Meg so you can have this stuff on it. You won't be able to put anything else with that data, like another non-Windows OS. Either way the FIRST PARTITION MUST BE USED BY WINDOWS, so I'm basically correct... technically speaking. Edited June 29, 2009 by V.T. Eric Layton Quote Link to comment Share on other sites More sharing options...
Frank Golden Posted June 29, 2009 Share Posted June 29, 2009 Hmmm... well, you learn sumthin' new ever day. Yup! :w00t:From Microsoft:http://support.microsoft.com/kb/326583/en-usH3ll, for that you basically must install Windows on the first partition.. at least part of it. Either that or make a first partition that is 30Meg so you can have this stuff on it. You won't be able to put anything else with that data, like another non-Windows OS. Either way the FIRST PARTITION MUST BE USED BY WINDOWS, so I'm basically correct... technically speaking.Yep Eric you are correct, With Win 7 you can install to any suitable partition on your drive. No messing around with where ntldr or other needed files are installed. All done for you by the installer. Quote Link to comment Share on other sites More sharing options...
