Grogerf Posted February 17, 2008 Share Posted February 17, 2008 Hallo Folks Now I've got a load of clip art on my machine as described here http://forums.scotsnewsletter.com/index.ph...st&p=245758I would like to be able to view it from Konqueror. I can do this by a right-click and 'open with' and then selecting 'Inkscape' but when I left click on the file in Konqueror it opens up with a load of text I've tried looking at the file associations in KDE and put Inkscape as the application for 'svg' files (previously there was no application listed). I moved KWrite and Konqueror below Inkscape on the applications list for svg-xml and svg+xml files - but still no joy , when i left click on the file I still get a load of text rather than the image What am I doing wrong or missing doing to let me click on the file & view the image? Grogerf Quote Link to comment Share on other sites More sharing options...
cybormoron Posted February 17, 2008 Share Posted February 17, 2008 (edited) there's a plugin for konqueror called ksvg, more specifically it's kdegraphics-ksvg. it should be in your repository or you may find a rpm on the web. latest version is Version: 3.5.7-8.1mdv2008.0.thanks for the idea. i just installed this myself and am browsing some cool images. gwenview is a nice image viewer for these.i wonder what issues one might have because of the root ownership? Edited February 17, 2008 by cybormoron Quote Link to comment Share on other sites More sharing options...
Grogerf Posted February 17, 2008 Author Share Posted February 17, 2008 (edited) there's a plugin for konqueror called ksvg, more specifically it's kdegraphics-ksvg. it should be in your repository or you may find a rpm on the web. latest version is Version: 3.5.7-8.1mdv2008.0.thanks for the idea. i just installed this myself and am browsing some cool images. gwenview is a nice image viewer for these.i wonder what issues one might have because of the root ownership?Hallo cybormoron Thanks for your reply I've installed ksvg and it's library using the MCC thanks However I must still be doing something wrong I still only get the text when I left click in Konqueror I can see a preview of some of the files if I select the icon view mode I wonder if I'm expecting too much - I was expecting the file to be opened to show a picture rather than text .I can also middle click & it opens in Inkscape I guess if I add Gwenview to the file associations it will open with Gwenview Grogerf Edited February 17, 2008 by Grogerf Quote Link to comment Share on other sites More sharing options...
Bruno Posted February 17, 2008 Share Posted February 17, 2008 HI Groger . . . . . if you right-click the .svg file and you select "Open With", what options does it list ?- In case there are no options at all chose "Other" and from there select "gwenview" ( tick the box "Remenber application associated for this file" ) and next time it will know what program to use when double-clicking the file. **- In case there are options in the "Open With" menu, please tell us what the options are. Bruno** This is the *safe* way to set file associations Quote Link to comment Share on other sites More sharing options...
Grogerf Posted February 17, 2008 Author Share Posted February 17, 2008 HI Groger . . . . . if you right-click the .svg file and you select "Open With", what options does it list ?- In case there are no options at all chose "Other" and from there select "gwenview" ( tick the box "Remenber application associated for this file" ) and next time it will know what program to use when double-clicking the file.- In case there are options in the "Open With" menu, please tell us what the options are. BrunoHallo Bruno Thanks for your reply When I right click the options are :-Inkscape (I added this one to the file associations) KwriteFSpotEpiphanyFirefoxThanks again Grogerf Quote Link to comment Share on other sites More sharing options...
Bruno Posted February 17, 2008 Share Posted February 17, 2008 Hi GrogerIn case you want to edit the .svg files I would indeed open them in inkscape . . . but if you only want to view the files I would set the preferred association to "gwenview" the way I described above. Bruno Quote Link to comment Share on other sites More sharing options...
striker Posted February 17, 2008 Share Posted February 17, 2008 In the file associations dialog:(1)File name patter=svgKnown Types= svgtab General: Application Preference Order > click Add > select Inkscape (if not available install package Inkscape)tab Embedding:Left Click Action=Show file in separate viewerServices Preferences Order=KOffice Painting and Image Editor Component (kritapart)(2)File name patter=svgKnown Types= svg+xmltab General: Application Preference Order > click Add > select Inkscape (if ot available install package Inkscape)tab Embedding:Left Click Action=Show file in separate viewerServices Preferences Order=KOffice Painting and Image Editor Component (kritapart)This will open up svg files in Inkscape with a left click, except from within Konqueror where it will open them with a left click in krita. Quote Link to comment Share on other sites More sharing options...
Grogerf Posted February 17, 2008 Author Share Posted February 17, 2008 (edited) Hi GrogerIn case you want to edit the .svg files I would indeed open them in inkscape . . . but if you only want to view the files I would set the preferred association to "gwenview" the way I described above.;) BrunoHallo Bruno Thanks for your reply I tried to do as you suggest, but something has gone wrong Now when I left or centre click in Konqueror the file opens with Inkscape , if I right click an select Gwenview from the list (It's at the bottom of the list), Gwenview (& also Krita) seem to freeze up on a .svg file (2_dead_frogs_lumen_desig_01.svg), but Inkscape, firefox and the Gimp open the file without a problem. If I try to stop either Gwenview or Krita after several minutes of them freezing I get the 'not responding' message, with the opportunity to terminate the application The trouble is tha I'm sure that Gwenview opened the same file without a problem before I tried to make this change Is this a KDE problem that I've created Hoping to get out of the hole I seem to have dug myself GrogerfIn the file associations dialog:(1)File name patter=svgKnown Types= svgtab General: Application Preference Order > click Add > select Inkscape (if not available install package Inkscape)tab Embedding:Left Click Action=Show file in separate viewerServices Preferences Order=KOffice Painting and Image Editor Component (kritapart)(2)File name patter=svgKnown Types= svg+xmltab General: Application Preference Order > click Add > select Inkscape (if ot available install package Inkscape)tab Embedding:Left Click Action=Show file in separate viewerServices Preferences Order=KOffice Painting and Image Editor Component (kritapart)This will open up svg files in Inkscape with a left click, except from within Konqueror where it will open them with a left click in krita.Hallo striker Thanks for your reply - looks like a very good idea But - I'd better not try to embark on this idea until I get out of the mess I created somehow when trying to follow Bruno's suggestion Grogerf Edited February 17, 2008 by Grogerf Quote Link to comment Share on other sites More sharing options...
Bruno Posted February 17, 2008 Share Posted February 17, 2008 Okay Groger . . . I did some test and here is what I found: gwenview is not suited to view svg+xml files . . . but "display" does the trick: try this: $ display /usr/share/images/openclipart/animals/scorpion-md-v0.1.svg Now another thing I found is that for every .svg image in /usr/share/images/openclipart/ there is a .png image too . . . so this works too: $ gwenview /usr/share/images/openclipart/animals/scorpion-md-v0.1.png ( and now you will see that the image is on a transparent background )So . . . . . with point and click you can right-click the .png version of the file and open it in gwenview if you want . . . . also you can open the .png file in inkskape if you want to work on it. ( though if I were you I would prefer opening it in The Gimp ) Bruno Quote Link to comment Share on other sites More sharing options...
Grogerf Posted February 18, 2008 Author Share Posted February 18, 2008 Okay Groger . . . I did some test and here is what I found: gwenview is not suited to view svg+xml files . . . but "display" does the trick: try this:$ display /usr/share/images/openclipart/animals/scorpion-md-v0.1.svg Now another thing I found is that for every .svg image in /usr/share/images/openclipart/ there is a .png image too . . . so this works too: $ gwenview /usr/share/images/openclipart/animals/scorpion-md-v0.1.png ( and now you will see that the image is on a transparent background )So . . . . . with point and click you can right-click the .png version of the file and open it in gwenview if you want . . . . also you can open the .png file in inkskape if you want to work on it. ( though if I were you I would prefer opening it in The Gimp ) Bruno Hallo Bruno Thank you for your reply I tried the code for ImagMagick and Gwenview and they both worked 'as advertised' So I didn't destroy Gwenview - that's good to know - thought I was having a 'bad hair day' - that's serious if you're bald like me :hysterical:Thanks for the explanation I've noticed that not all the files have a .png version - don't know why this is , but I guess it could easily be fixed with ImageMagick each time I run into it on an image that I want to use Thanks again for looking into my problem and coming up with the solution Grogerf Quote Link to comment Share on other sites More sharing options...
Bruno Posted February 18, 2008 Share Posted February 18, 2008 Glad we managed to sort out this issue . . . . Bruno Quote Link to comment Share on other sites More sharing options...
