jeh-vin Posted December 15, 2021 Share Posted December 15, 2021 I messed up my main system real bad a week ago (specifications attached to my profile). I installed and used the wipe command preceded by shred -v /dev/sda . I read many blog posts about these commands to make sure they dont make my laptop unusable. Unfortunately, these two commands also removed ath10k AMD GPU Firmware from my system and now I am figuring out a way to burn the firware into the system and reinstall Arch Linux. My question(s): 1. Apart from these two commands, do any of you Linux nerds know how to wipe a disk without having drastic repurcussions afterwards? 2. How do I get back my missing AMD GPU Firware onto the system? Quote Link to comment Share on other sites More sharing options...
securitybreach Posted December 15, 2021 Share Posted December 15, 2021 Well it depends on how you want to go about it. You can simply use gparted to format the drive and create partitions or you can use dd to erase a drive completely. Now you will need to create the partition table and such afterwards as dd does a low level format. dd if=/dev/zero of=/dev/sdX bs=1M Replace X with drive letter. If you go the dd route, be EXTREMELY CAREFUL to choose the correct drive and look at the command closely before executing as there is no turning back once its started. Gparted would be the safest route. 1 1 1 Quote Link to comment Share on other sites More sharing options...
sunrat Posted December 15, 2021 Share Posted December 15, 2021 If you reinstall Arch, a simple format would suffice to overwrite whatever is on the partition, no need for wipe or anything. I'm not familiar with Arch install routine being a Debian user, but most distros will format the partition as part of the installation process. @securitybreachknows all about Arch. Firmware is included in the operating system, so you will have to add that during or after installation. As mentioned already, Gparted is great for managing, creating, deleting disks and partitions. Easy to use from a live USB or CD such as SystemRescue, Gparted Live, or PartedMagic. First 2 are free, last one is a few bucks. 2 1 Quote Link to comment Share on other sites More sharing options...
raymac46 Posted December 15, 2021 Share Posted December 15, 2021 Linux firmware is not flashed like a BIOS update; it is simply software that is loaded in memory during boot, to work with devices like a wifi chipset. Most of what you need will be in a linux-firmware package you can install if it isn't on the Arch iso. I usually install Arch using a wired connection and get wifi working after the basic Arch software is in place. 1 1 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted December 15, 2021 Share Posted December 15, 2021 Exactly raymac 1 1 Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted December 15, 2021 Share Posted December 15, 2021 By definition, "wiping a drive" means just that. When you use tools/commands that are meant to wipe a drive clean, this is exactly what you will get... a totally wiped clean drive. I'm not sure why you would bother with doing something like this, though? Personally, I would just clean the individual partitions of data or I would remove all partitions and re-partition the drive, then install whatever "new" items need installing. When I upgrade my Slackware OS on my machines, all I do is install the new version of the OS onto my /(root) partition. I NEVER format or change my /home partition. By doing it this way, it saves me much work with regards to my personal data and customizations. Anyway, GNU/Linux is about choices. Find what method is best for you and use that. Welcome to Scots and BATL, by the way! 3 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted December 15, 2021 Share Posted December 15, 2021 7 hours ago, linux screwed me up sadly said: I messed up my main system real bad a week ago (specifications attached to my profile). I installed and used the wipe command preceded by shred -v /dev/sda . I read many blog posts about these commands to make sure they dont make my laptop unusable. Unfortunately, these two commands also removed ath10k AMD GPU Firmware from my system and now I am figuring out a way to burn the firware into the system and reinstall Arch Linux. My question(s): 1. Apart from these two commands, do any of you Linux nerds know how to wipe a disk without having drastic repurcussions afterwards? 2. How do I get back my missing AMD GPU Firware onto the system? The linux-firmware package will provide the ath10k module. 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted December 15, 2021 Share Posted December 15, 2021 For the AMD GPU firmware, you have two choices: xf86-video-ati for opensource driver xf86-video-amdgpu for proprietary driver. The opensource one is from the normal arch repos but the proprietary one is available via the AUR. 2 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted December 15, 2021 Share Posted December 15, 2021 You should get equal performance out of the opensource driver as AMD has a dedicated team that provides the opensource driver. 1 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted December 15, 2021 Share Posted December 15, 2021 I would of answered earlier but got busy at work. 1 Quote Link to comment Share on other sites More sharing options...
raymac46 Posted December 15, 2021 Share Posted December 15, 2021 I was a bit confused here as ath10k is really a wifi driver not GPU. Nevertheless both can be installed at the time of Arch installation. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted December 15, 2021 Share Posted December 15, 2021 1 minute ago, raymac46 said: I was a bit confused here as ath10k is really a wifi driver not GPU. Nevertheless both can be installed at the time of Arch installation. They are different, the ATH10k module is provided by the linux-firmware package. 1 Quote Link to comment Share on other sites More sharing options...
jeh-vin Posted December 16, 2021 Author Share Posted December 16, 2021 Hey everyone! Answered a bit late cuz I was busy with school haha ^~^ Thanks for your answers. Will try all of these steps out to fix the ATH10k module n other firmware. Also will try my best to not be freaked out when I try nerdy stuff. Will post a screenshot or message under this thread when my Arch is setup once again. 1 3 Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted December 16, 2021 Share Posted December 16, 2021 Good for you! That's the proper attitude. After you "tweak till it breaks", as they say, it's always good to get back on the horse. Heh! How's that for mix-and-match analogies? 2 2 Quote Link to comment Share on other sites More sharing options...
sunrat Posted December 16, 2021 Share Posted December 16, 2021 It's also prudent, nay, essential to back up your system to another drive for if/when you "tweak till it breaks" so you can revert a catastrophe in a few minutes. I back up my root filesystem petition with fsarchiver and other data partitions with rsync to external USB HD. Best to run fsarchiver from a separate system such as another dual-boot OS on your same computer or from a live USB system. If that's too geeky you can use something like BackInTime https://wiki.archlinux.org/title/Back_In_Time 1 2 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted December 16, 2021 Share Posted December 16, 2021 I just use Clonzilla (via their live iso) every few months to take a snapshot of my root partition. It's menu driven and easy to use. 1 1 Quote Link to comment Share on other sites More sharing options...
sunrat Posted December 16, 2021 Share Posted December 16, 2021 16 minutes ago, securitybreach said: I just use Clonzilla (via their live iso) every few months to take a snapshot of my root partition. It's menu driven and easy to use. I used Clonezilla religiously for years. Its menu is ok but I found its "mount drive as Clonezilla home" paradigm to be really clumsy, so much that if I wanted to start again or do a second backup it was easier to just reboot the live system than try to unmount/remount. fsarchiver is much simpler, mount the drives and do something like fsarchiver -j3 savefs /backup/location.fsa /dev/sdaX Obviously modify the location and source to suit. 1 1 Quote Link to comment Share on other sites More sharing options...
burninbush Posted February 5 Share Posted February 5 On 12/16/2021 at 8:28 AM, jeh-vin said: Hey everyone! Answered a bit late cuz I was busy with school haha ^~^ Thanks for your answers. Will try all of these steps out to fix the ATH10k module n other firmware. Also will try my best to not be freaked out when I try nerdy stuff. Will post a screenshot or message under this thread when my Arch is setup once again. I would look for my motherboard pc install disk for such items; you won't need any special tools to install it. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 5 Share Posted February 5 8 hours ago, burninbush said: motherboard pc install disk You do not need "motherboard pc install disk" when installing a linux distro. 1 Quote Link to comment Share on other sites More sharing options...
