Image Resizing in Posts - IPB Forum Style
26 replies to this topic
#1 OFFLINE   alphaomega
alphaomega
    Multithreader
  • PipPipPipPipPipPipPipPip
  • 1,012 posts
Posted 04 May 2012 - 11:13 AM
This thread was branched off from "Show Us Your GNU/Linux Desktop".
I was wanting to post a few screenshots but was having problems
getting the posted image to scale down.
This thread deals with the issue of scaling posted images in a forum post.
Any ideas on how to scale the posted image?
TIA
Edited by alphaomega, 05 May 2012 - 05:19 PM.
#2 OFFLINE   LilBambi
LilBambi
    Australisches Googler
  • 22,548 posts
Posted 04 May 2012 - 12:05 PM
The images for posts is generally limited to 540x540 by the forum software. I am not sure it is actually doing what it is supposed to do however. Let's do a test. I put in an image that is actually 1024x and let's see if I don't manually adjust to 540x whether the software will limit it as is intended to 540x:
Edited by LilBambi, 04 May 2012 - 12:08 PM.
edited size of image down to 540x approx.
Bambi
AKA Fran
#3 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 04 May 2012 - 12:07 PM
It did limit the size by about 1/2, but not to the 540x that is set as the max for images in posts in the forum software.
I will go back and manually resize the image to 540x within the post so it's not incorrect. When I used this picture on another topic, I chose the 500x image rather than this 1024x image which I used for this test.
Hope that helps.
Note I have adjusted within the posting, the image size down to about 540x.
Edited by LilBambi, 04 May 2012 - 12:09 PM.
Bambi
AKA Fran
#4 OFFLINE   alphaomega
alphaomega
    Multithreader
  • 1,012 posts
Posted 04 May 2012 - 12:12 PM
I sort of found a work around (by including the thumbnail as an image along
with a link to the full image). Would really like to get  the scaled image thing
working again.
http://i46.tinypic.com/oh8c4y.jpg
TIA
Cheers
Edited by alphaomega, 05 May 2012 - 05:10 PM.
#5 OFFLINE   alphaomega
alphaomega
    Multithreader
  • 1,012 posts
Posted 04 May 2012 - 12:22 PM
Hope that helps.
So if I post an image that is too large...the forum software will automatically scale it down for me?
On further inspection that appears to be the case on the image in the post about using the mp3 player.
It is originally at 1366x768. The image does appear to be scaled down and when I click on it I get the larger image.
Adding the larger size images to my post above about dark themes....
the image in the post and in the popup appear to be the same size (640x480).
They do not appear to be scaled.
Just curious about how to get it to scale down more than it is now.
Any ideas?
TIA
Edited by alphaomega, 04 May 2012 - 01:05 PM.
#6 OFFLINE   securitybreach
  • 24,423 posts
Posted 04 May 2012 - 01:00 PM
View Postalphaomega, on 04 May 2012 - 12:22 PM, said:
Any ideas?
TIA
Just upload it to imagebam.com and choose the scale size. I usually use 250 to 350 pixels depending on the size I want. Then after you upload it, copy the BB code that is shown to your post.
BTW How did you get the forum's background to black?
Posted ImagePosted Image
Configs/PGP Key/comhack π
#7 OFFLINE   alphaomega
alphaomega
    Multithreader
  • 1,012 posts
Posted 04 May 2012 - 01:17 PM
Thanks...
This is much better.
For the dark forums background I am using the Stylish plugin
in Firefox with the Midnight Surfing - Global Dark Style.
It make every page I visit in Firefox dark.
Cheers
Edited by alphaomega, 05 May 2012 - 05:08 PM.
#8 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 04 May 2012 - 01:30 PM
Josh's plan is much easier as you don't have to worry about it so much.
But you can resize any image in any post after the URL has been provided and it is in the editor to meet Forum Rules.
Just choose a corner (bottom right is generally what I use), then hold/drag the corner of the image toward the upper/left to resize. NOTE: The Editor will show the size as you resize in a little gray box along side as you resize so you can get it to be approximately 540x like I did to match the Forum Rules and still be large enough for folks to see what's in the image.
Also, if you like a larger image, you can then click the image, click the URL icon and add a link to the larger image that will give more detail and when someone clicks on the image, it will take them to the larger image.
Bambi
AKA Fran
#9 OFFLINE   alphaomega
alphaomega
    Multithreader
  • 1,012 posts
Posted 04 May 2012 - 01:39 PM
Thanks for that information. I was not aware.
I can scale the image in the editor.
However, when I save the changes...
it does not scale down as far I scaled it down in the editor.
The image in the saved post is larger.
I had scaled it down much smaller.
See post #1457 (I can't get the image to scale down any smaller).
http://forums.scotsn...450#entry346221
Edited by alphaomega, 04 May 2012 - 01:44 PM.
#10 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 04 May 2012 - 01:52 PM
As was noted when I put in the 1024x image, it only downsized it to about 50%. There may be some sort of limitation on that. Not sure. I am checking into it with IPS to see why it does that. I would suggest using an image that is the right size or use image ban if you have huge images that won't auto size to meet Forum Rules.
Bambi
AKA Fran
#11 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 04 May 2012 - 02:13 PM
alphaomega, try to add a picture again. I think I got it. I found a topic on IPS about it. I had only set it in one place and had left it to auto resize but didn't specify. Now it should do it to 540px.
Feel free to test it.
I will test it to with my 1024x image again to be sure.
Yes! It did it when I clicked Post. So it is now working! Yea!
NOTE: It doesn't look like it will when you add it but it does it automatically when you post.
Thanks for your patience as I figured it out! :hug:
Bambi
AKA Fran
#12 OFFLINE   alphaomega
alphaomega
    Multithreader
  • 1,012 posts
Posted 04 May 2012 - 07:38 PM
I have managed to scale the image down a little more but the resulting
image in the post is still larger than the size I actually scaled it to.
Scaling appears to wok for me when I am in advanced editing mode
(where the insert link/image work).
That is probably how it is supposed to work and I just need
to make sure I am in advanced editing mode in order to scale
the posted image.  I know I had another problem when it comes
to the advanced editor vs the basic editor.
P.S. At the time I tested it when it would not scale, I was in the more editing options
where there is a save changes option vs a post option. Scaling the image down
when there is a save option appears to work but it does not seem to scale the
image as far down as I actually scaled it.
Thanks for the info.
Cheers
#13 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 04 May 2012 - 10:00 PM
The image I inserted above was originally 758px wide. The forum software automatically resized it when I saved the post.  I did not resize anything. It did it on it's own.
Edited by LilBambi, 04 May 2012 - 10:02 PM.
Bambi
AKA Fran
#14 OFFLINE   alphaomega
alphaomega
    Multithreader
  • 1,012 posts
Posted 04 May 2012 - 10:51 PM
There must be something than I am not quite understanding.
Right now I'm thinking it works like so:
If I post an image larger than 540x540 the forum software will scale it down to within 540x540.
Or I can scale down the image as you explained by grabbing the bottom right corner of the image
in the editor and moving toward the upper left corner of the image.
The original posted image only caught my attention because it was much larger
in the post after the forum upgrade. After the upgrade the original image 1366x768
was still scaled down but not as much as it was before. It was larger than 540x540.
That is when I switched the image until I could figure out how to scale it back down
to around 250x150.
Attempting to scale it down in the editor to around 250x150...when I post
the message...the image only scales down to 540x304. I can not get it
to scale down any smaller.
Of course, now that I have written all this...it will probably work if I try again.
Nope. I can not get it to scale down any smaller when dragging the corner
of the image in the editor.
Edited by alphaomega, 04 May 2012 - 10:56 PM.
#15 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,683 posts
Posted 05 May 2012 - 01:19 PM
You guys need to split off this entire sub-topic about image resizing and move it to the Tips/Tricks Forum Feedback area.
Don't make me come back here and scold you again. ;)
#16 OFFLINE   securitybreach
  • 24,423 posts
Posted 05 May 2012 - 01:43 PM
:hysterical: :bangin:
#17 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 05 May 2012 - 02:40 PM
Will use this post to summarize the added posts from another topic.
Done. Split and merged. Now it's here and folks can just read it over -- I couldn't actually do anything with it so I have my summary post at the top.
Maybe alphaomega could do that in his first post by editing it?
Edited by LilBambi, 05 May 2012 - 02:48 PM.
Bambi
AKA Fran
#18 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,683 posts
Posted 05 May 2012 - 02:59 PM
As posted on the original thread:
If this were my personal board, I wouldn't care much. However, on a tech support type board like this one, it's really confusing to the readers to see shredded off-topic threads when they're searching for solutions to their issues. Granted, they wouldn't be searching too much on this thread for solutions, but...
Oh, and never let it be said that I'm just being a jack-booted thug staffer... I am OFTEN guilty of steering threads into the ditch around here. :(
#19 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 05 May 2012 - 03:06 PM
it was a great idea Eric! I was thinking of how to do it myself. It was just so intermixed. :hysterical:
It really did need doing. :thumbsup:
Bambi
AKA Fran
#20 OFFLINE   alphaomega
alphaomega
    Multithreader
  • 1,012 posts
Posted 05 May 2012 - 05:33 PM
Okay, thanks for splitting the thread.
The only issue I still can't figure out is:
How to scale an image down to 250x150 by dragging the
bottom right corner and moving to the top left.
Here is a screenshot of what it looks like when I'm in
the editor and scaling the image:
This is what it looks like once I actually post the message:
So how do I scale it down even more?
Edited by alphaomega, 05 May 2012 - 06:01 PM.
#21 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 05 May 2012 - 05:54 PM
Looks like it reized it down to 540x to me.
Bambi
AKA Fran
#22 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 05 May 2012 - 06:02 PM
I would think that going down to a thumbnail is not necessary if it's resizing it for you to a workable size.
Likely the picture is just too big to start with. You are starting with a picture that is 1366 × 768 pixels.
But let's see:
OK resized to approximately 300x ... let's see if it stays there.
Nope. It goes to the 540x.
OK, using the full editor, I resized it to approx. 300x and centered it.
Let's see what happens.
Bambi
AKA Fran
#23 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 05 May 2012 - 06:10 PM
Nope. You have to have a thumbnail to get a thumbnail. That picture is just way too big. The software knows it's bigger than 540x and auto resizes to 540x.
OK, let's try a real thumbnail image and see what happens.
Two that are smaller than the required size:
Thumbnail 100x (I expect this will be fine with no resizing)
320x image ( I expect this to be fine as is with no resizing)
And now one that is larger than the forum required size:
640x image (which should be auto resized to 540x)
Yep. The one I expected to be resized, was resized to: 505px × 335px and the others were left as they were.
Hope that helps alphaomega. :teehee:
Bambi
AKA Fran
#24 OFFLINE   alphaomega
alphaomega
    Multithreader
  • 1,012 posts
Posted 05 May 2012 - 06:17 PM
Exactly.
I tried to scale down the smaller image in post #20 even smaller
(original is within 540x540) and it did not work.
I tried to scale down the larger image in post  #20 to within 250x150
(original is 1366x768) and it only gets scaled down to within 540x540.
So trying to scale an image by dragging the bottom right corner
and moving to the upper left corner in the editor only scales the
image while in the editor.
Once the image is posted it is not scaled down as it was in the editor.
It appears to follow these rules:
If an image is over 540x540 it gets scaled down to within 540x540.
If an image is already within 540x540 it is shown unscaled.
So the option to scale an image in the editor by dragging the corner
would appear to be pointless.
I wanted to scale something larger than 540x540 to something
way smaller than 540x540. It appeared to be possible using
the editor and dragging the corner of the image but it is not.
P.S. just caught your post before mine...
Yes, it's clear.
If I want to scale the image that small I have to scale it myself as the
forum software appears to only scale things larger than 540x540.
Cheers and Thanks
Edited by alphaomega, 05 May 2012 - 06:23 PM.
#25 OFFLINE   LilBambi
LilBambi
  • 22,548 posts
Posted 05 May 2012 - 06:36 PM
Well, it was not pointless until we changed it to 540x to prevent images going too large. Then it would resize them but if it was too large only 50% max.
If someone uses images that are too big, the image will now be auto resized to meet Forum Rules max of 540x regardless.
If it is a smaller than 540x image, the image's size will be honored.
Bambi
AKA Fran
