NEW UPDATES Archlinux
arch linux updates securitybreach
2026 replies to this topic
#2001 OFFLINE   securitybreach
  • 24,208 posts
Posted 28 December 2016 - 08:20 PM
Updates for Tuesday, December 27, 2016
Any
any Community perl-role-tiny 2.000005-1 Roles. Like a nouvelle cuisine portion size slice of Moose.
any Community perl-moo 2.003000-1 Minimalist Object Orientation (with Moose compatiblity)
any Community python2-cherrypy 8.5.0-3 A pythonic, object-oriented web development framework 2016-12-29
any Community python-cherrypy 8.5.0-3 A pythonic, object-oriented web development framework 2016-12-29
any Community arduino-avr-core 1.6.16-1 Arduino AVR core with upstream avr-gcc and avrdude
any Extra breeze-grub 5.8.5-1 Breeze theme for GRUB
any Extra plasma-workspace-wallpapers 5.8.5-1 Additional wallpapers for the Plasma Workspace
any Extra composer 1.3.0-1 Dependency Manager for PHP
i686
i686 Community nbd 3.15.1-2 tools for network block devices, allowing you to use remote block devices over TCP/IP
i686 Community wireguard-tools 0.0.20161223-2 next generation secure network tunnel
i686 Community wireguard-dkms 0.0.20161223-2 next generation secure network tunnel
i686 Community crystal 0.20.3-1 The Crystal Programming Language
i686 Community syncthing-relaysrv 0.14.17-1 Relay server for Syncthing
i686 Community syncthing 0.14.17-1 Open Source Continuous Replication / Cluster Synchronization Thing
i686 Community sway 0.11-2 i3 compatible window manager for Wayland
i686 Community openbsd-netcat 1.130_1-1 TCP/IP swiss army knife. OpenBSD variant.
i686 Community parity 1.4.7-1 Fast, light, robust Ethereum implementation
i686 Community shadowsocks-libev 2.6.0-1 A lightweight secured socks5 proxy for embedded devices and low end boxes
i686 Community haskell-xml-hamlet 0.4.0.12-14 Hamlet-style quasiquoter for XML content
i686 Community haskell-yesod-default 1.2.0-90 Default config and main functions for your yesod application (deprecated)
i686 Community haskell-yesod-core 1.4.30-6 Creation of type-safe, RESTful web applications.
i686 Community haskell-yesod-persistent 1.4.1.1-5 Some helpers for using Persistent from Yesod.
i686 Community haskell-yesod-static 1.5.1.1-20 Static file serving subsite for Yesod Web Framework.
i686 Community haskell-yesod-form 1.4.9-22 Form handling support for Yesod Web Framework
i686 Community arduino-ctags 5.8_arduino10-1 A mix of ctags and anjuta-tags for the perfect C++ ctags
i686 Community axel 2.12-1 Light command line download accelerator
i686 Community dnscrypt-proxy 1.8.1-1 A tool for securing communications between a client and a DNS resolver
i686 Community python2-gevent 1.2.0-1 Python network library that uses greenlet and libev for easy and scalable concurrency
i686 Community python-gevent 1.2.0-1 Python network library that uses greenlet and libev for easy and scalable concurrency
i686 Community haskell-project-template 0.2.0-40 Specify Haskell project templates and generate files
i686 Community haskell-resourcet 1.1.9-1 Deterministic allocation and freeing of scarce resources.
i686 Community stylish-haskell 0.6.5.0-7 Haskell code prettifier
i686 Community haskell-yaml 0.8.21.1-6 Support for parsing and rendering YAML documents.
i686 Community haskell-conduit 1.2.8-5 Streaming data processing library.
i686 Community haskell-monad-logger 0.3.20.1-2 A class of monads which can log messages.
i686 Community haskell-sandi 0.4.0-8 Data encoding library
i686 Community darcs 2.12.4-9 A distributed, interactive, smart revision control system
i686 Community haskell-hopenpgp 2.5.5-16 Native Haskell implementation of OpenPGP (RFC4880)
i686 Community haskell-wai-extra 3.0.19-8 Provides some basic WAI handlers and middleware.
i686 Community haskell-hpack 0.15.0-12 An alternative format for Haskell packages
i686 Community haskell-persistent-template 2.5.1.6-21 Type-safe, non-relational, multi-backend persistence
i686 Community haskell-cryptohash-conduit 0.1.1-49 cryptohash conduit
i686 Community haskell-persistent-sqlite 2.6-20 Backend for the persistent library using sqlite3
i686 Community idris 0.99-12 Functional Programming Language with Dependent Types
i686 Community haskell-conduit-extra 1.1.15-5 Batteries included conduit: adapters for common libraries.
i686 Community haskell-persistent 2.6-20 Type-safe, multi-backend data serialization
i686 Community haskell-binary-conduit 1.2.4.1-6 Data serialization/deserialization conduit library
i686 Community haskell-cheapskate 0.1.0.5-34 Experimental markdown processor.
i686 Community haskell-wai-app-static 3.1.6.1-19 WAI application for static serving
i686 Community haskell-conduit-combinators 1.0.8.3-8 Commonly used conduit functions, for both chunked and unchunked data
i686 Community haskell-esqueleto 2.4.3-53 Type-safe EDSL for SQL queries on persistent backends.
i686 Community haskell-xml-conduit 1.4.0.2-5 Pure-Haskell utilities for dealing with XML with the conduit package.
i686 Community haskell-store 0.3-3 Fast binary serialization
i686 Community haskell-tagstream-conduit 0.5.5.3-49 Streamlined html tag parser
i686 Community haskell-dns 2.0.10-5 DNS library in Haskell
i686 Extra systemsettings 5.8.5-1 KDE system settings
i686 Extra plasma-wayland-session 5.8.5-1 Plasma Wayland session
i686 Extra breeze-gtk 5.8.5-1 Breeze widget theme for GTK 2 and 3
i686 Extra user-manager 5.8.5-1 A simple system settings module to manage the users of your system
i686 Extra oxygen 5.8.5-1 KDE Oxygen style
i686 Extra kdecoration 5.8.5-1 Plugin based library to create window decorations
i686 Extra kwallet-pam 5.8.5-1 KWallet PAM integration
i686 Extra kdeplasma-addons 5.8.5-1 All kind of addons to improve your Plasma experience
i686 Extra kde-gtk-config 5.8.5-1 GTK2 and GTK3 Configurator for KDE
i686 Extra kactivitymanagerd 5.8.5-1 System service to manage user's activities and track the usage patterns
i686 Extra breeze 5.8.5-1 Artwork, styles and assets for the Breeze visual style for the Plasma Desktop
i686 Extra plasma-integration 5.8.5-1 Qt Platform Theme integration plugins for the Plasma workspaces
i686 Extra kinfocenter 5.8.5-1 A utility that provides information about a computer system
i686 Extra plasma-pa 5.8.5-1 Plasma applet for audio volume management using PulseAudio
i686 Extra kwin 5.8.5-1 KDE Window manager
i686 Extra kwrited 5.8.5-1 KDE daemon listening for wall and write messages
i686 Extra powerdevil 5.8.5-1 Manages the power consumption settings of a Plasma Shell
i686 Extra milou 5.8.5-1 A dedicated search application built on top of Baloo
i686 Extra plasma-workspace 5.8.5-1 KDE Plasma Workspace
i686 Extra libkscreen 5.8.5-1 KDE screen management software
i686 Extra bluedevil 1:5.8.5-1 Integrate the Bluetooth technology within KDE workspace and applications
i686 Extra kde-cli-tools 5.8.5-1 Tools based on KDE Frameworks 5 to better interact with the system
i686 Extra kscreen 5.8.5-1 KDE's screen management software
i686 Extra khotkeys 5.8.5-1 KHotKeys
i686 Extra ksysguard 5.8.5-1 Track and control the processes running in your system
i686 Extra plasma-desktop 5.8.5-1 KDE Plasma Desktop
i686 Extra kscreenlocker 5.8.5-1 Library and components for secure lock screen architecture
i686 Extra oxygen-kde4 5.8.5-1 KDE Oxygen style for KDE4 applications
i686 Extra kmenuedit 5.8.5-1 KDE menu editor
i686 Extra kgamma5 5.8.5-1 Adjust your monitor's gamma settings
i686 Extra drkonqi 5.8.5-1 KDE crash handler
i686 Extra plasma-nm 5.8.5-1 Plasma applet written in QML for managing network connections
i686 Extra libksysguard 5.8.5-1 Libksysguard
i686 Extra kuiserver 5.8.5-1 KDE Progress Info UI server
i686 Extra sddm-kcm 5.8.5-1 KDE Config Module for SDDM
i686 Extra polkit-kde-agent 5.8.5-1 Daemon providing a polkit authentication UI for KDE
i686 Extra plasma-sdk 5.8.5-1 Applications useful for Plasma development
i686 Extra breeze-kde4 5.8.5-1 Breeze widget style for KDE4 applications
i686 Extra kwayland-integration 5.8.5-1 Provides integration plugins for various KDE frameworks for the wayland windowing system
i686 Extra ksshaskpass 5.8.5-1 ssh-add helper that uses kwallet and kpassworddialog
i686 Extra libzmf 0.0.1-1 a library for import of Zoner drawing and bitmap files
i686 Extra lighttpd 1.4.44-1 A secure, fast, compliant and very flexible web-server
i686 Extra clang 3.9.1-1 C language family frontend for LLVM
i686 Extra llvm-libs 3.9.1-1 Low Level Virtual Machine (runtime libraries)
i686 Extra lldb 3.9.1-1 Next generation, high-performance debugger
i686 Extra llvm 3.9.1-1 Low Level Virtual Machine
i686 Extra llvm-ocaml 3.9.1-1 OCaml bindings for LLVM
i686 Extra clang-tools-extra 3.9.1-1 Extra tools built using clang's tooling APIs
i686 Extra python2 2.7.13-1 A high-level scripting language
i686 Extra stellarium 0.15.1-1 A stellarium with great graphics and a nice database of sky-objects
i686 Testing ncurses 6.0+20161224-1 System V Release 4.0 curses emulation library
i686 Testing nghttp2 1.18.0-1 Framing layer of HTTP/2 is implemented as a reusable C library
i686 Community-Testing arduino 1:1.8.0-2 Arduino prototyping platform SDK
i686 Community-Testing arduino-builder 1.3.23-2 A command line tool for compiling Arduino sketches
x86_64
x86_64 Community nbd 3.15.1-2 tools for network block devices, allowing you to use remote block devices over TCP/IP
x86_64 Community wireguard-tools 0.0.20161223-2 next generation secure network tunnel
x86_64 Community wireguard-dkms 0.0.20161223-2 next generation secure network tunnel
x86_64 Community crystal 0.20.3-1 The Crystal Programming Language
x86_64 Community syncthing-relaysrv 0.14.17-1 Relay server for Syncthing
x86_64 Community syncthing 0.14.17-1 Open Source Continuous Replication / Cluster Synchronization Thing
x86_64 Community sway 0.11-2 i3 compatible window manager for Wayland
x86_64 Community openbsd-netcat 1.130_1-1 TCP/IP swiss army knife. OpenBSD variant.
x86_64 Community parity 1.4.7-1 Fast, light, robust Ethereum implementation
x86_64 Community shadowsocks-libev 2.6.0-1 A lightweight secured socks5 proxy for embedded devices and low end boxes
x86_64 Community haskell-xml-hamlet 0.4.0.12-14 Hamlet-style quasiquoter for XML content
x86_64 Community haskell-yesod-default 1.2.0-90 Default config and main functions for your yesod application (deprecated)
x86_64 Community haskell-yesod-core 1.4.30-6 Creation of type-safe, RESTful web applications.
x86_64 Community haskell-yesod-persistent 1.4.1.1-5 Some helpers for using Persistent from Yesod.
x86_64 Community haskell-yesod-static 1.5.1.1-20 Static file serving subsite for Yesod Web Framework.
x86_64 Community haskell-yesod-form 1.4.9-22 Form handling support for Yesod Web Framework
x86_64 Community arduino-ctags 5.8_arduino10-1 A mix of ctags and anjuta-tags for the perfect C++ ctags
x86_64 Community axel 2.12-1 Light command line download accelerator
x86_64 Community dnscrypt-proxy 1.8.1-1 A tool for securing communications between a client and a DNS resolver
x86_64 Community python2-gevent 1.2.0-1 Python network library that uses greenlet and libev for easy and scalable concurrency
x86_64 Community python-gevent 1.2.0-1 Python network library that uses greenlet and libev for easy and scalable concurrency
x86_64 Community haskell-project-template 0.2.0-40 Specify Haskell project templates and generate files
x86_64 Community haskell-resourcet 1.1.9-1 Deterministic allocation and freeing of scarce resources.
x86_64 Community stylish-haskell 0.6.5.0-7 Haskell code prettifier
x86_64 Community haskell-yaml 0.8.21.1-6 Support for parsing and rendering YAML documents.
x86_64 Community haskell-conduit 1.2.8-5 Streaming data processing library.
x86_64 Community haskell-monad-logger 0.3.20.1-2 A class of monads which can log messages.
x86_64 Community haskell-sandi 0.4.0-8 Data encoding library
x86_64 Community darcs 2.12.4-9 A distributed, interactive, smart revision control system
x86_64 Community haskell-hopenpgp 2.5.5-16 Native Haskell implementation of OpenPGP (RFC4880)
x86_64 Community haskell-wai-extra 3.0.19-8 Provides some basic WAI handlers and middleware.
x86_64 Community haskell-hpack 0.15.0-12 An alternative format for Haskell packages
x86_64 Community haskell-persistent-template 2.5.1.6-21 Type-safe, non-relational, multi-backend persistence
x86_64 Community haskell-cryptohash-conduit 0.1.1-49 cryptohash conduit
x86_64 Community haskell-persistent-sqlite 2.6-20 Backend for the persistent library using sqlite3
x86_64 Community idris 0.99-12 Functional Programming Language with Dependent Types
x86_64 Community haskell-conduit-extra 1.1.15-5 Batteries included conduit: adapters for common libraries.
x86_64 Community haskell-persistent 2.6-20 Type-safe, multi-backend data serialization
x86_64 Community haskell-binary-conduit 1.2.4.1-6 Data serialization/deserialization conduit library
x86_64 Community haskell-cheapskate 0.1.0.5-34 Experimental markdown processor.
x86_64 Community haskell-wai-app-static 3.1.6.1-19 WAI application for static serving
x86_64 Community haskell-conduit-combinators 1.0.8.3-8 Commonly used conduit functions, for both chunked and unchunked data
x86_64 Community haskell-esqueleto 2.4.3-53 Type-safe EDSL for SQL queries on persistent backends.
x86_64 Community haskell-xml-conduit 1.4.0.2-5 Pure-Haskell utilities for dealing with XML with the conduit package.
x86_64 Community haskell-store 0.3-3 Fast binary serialization
x86_64 Community haskell-tagstream-conduit 0.5.5.3-49 Streamlined html tag parser
x86_64 Community haskell-dns 2.0.10-5 DNS library in Haskell
x86_64 Extra systemsettings 5.8.5-1 KDE system settings
x86_64 Extra plasma-wayland-session 5.8.5-1 Plasma Wayland session
x86_64 Extra breeze-gtk 5.8.5-1 Breeze widget theme for GTK 2 and 3
x86_64 Extra user-manager 5.8.5-1 A simple system settings module to manage the users of your system
x86_64 Extra oxygen 5.8.5-1 KDE Oxygen style
x86_64 Extra kdecoration 5.8.5-1 Plugin based library to create window decorations
x86_64 Extra kwallet-pam 5.8.5-1 KWallet PAM integration
x86_64 Extra kdeplasma-addons 5.8.5-1 All kind of addons to improve your Plasma experience
x86_64 Extra kde-gtk-config 5.8.5-1 GTK2 and GTK3 Configurator for KDE
x86_64 Extra kactivitymanagerd 5.8.5-1 System service to manage user's activities and track the usage patterns
x86_64 Extra breeze 5.8.5-1 Artwork, styles and assets for the Breeze visual style for the Plasma Desktop
x86_64 Extra plasma-integration 5.8.5-1 Qt Platform Theme integration plugins for the Plasma workspaces
x86_64 Extra kinfocenter 5.8.5-1 A utility that provides information about a computer system
x86_64 Extra plasma-pa 5.8.5-1 Plasma applet for audio volume management using PulseAudio
x86_64 Extra kwin 5.8.5-1 KDE Window manager
x86_64 Extra kwrited 5.8.5-1 KDE daemon listening for wall and write messages
x86_64 Extra powerdevil 5.8.5-1 Manages the power consumption settings of a Plasma Shell
x86_64 Extra milou 5.8.5-1 A dedicated search application built on top of Baloo
x86_64 Extra plasma-workspace 5.8.5-1 KDE Plasma Workspace
x86_64 Extra libkscreen 5.8.5-1 KDE screen management software
x86_64 Extra bluedevil 1:5.8.5-1 Integrate the Bluetooth technology within KDE workspace and applications
x86_64 Extra kde-cli-tools 5.8.5-1 Tools based on KDE Frameworks 5 to better interact with the system
x86_64 Extra kscreen 5.8.5-1 KDE's screen management software
x86_64 Extra khotkeys 5.8.5-1 KHotKeys
x86_64 Extra ksysguard 5.8.5-1 Track and control the processes running in your system
x86_64 Extra plasma-desktop 5.8.5-1 KDE Plasma Desktop
x86_64 Extra kscreenlocker 5.8.5-1 Library and components for secure lock screen architecture
x86_64 Extra oxygen-kde4 5.8.5-1 KDE Oxygen style for KDE4 applications
x86_64 Extra kmenuedit 5.8.5-1 KDE menu editor
x86_64 Extra kgamma5 5.8.5-1 Adjust your monitor's gamma settings
x86_64 Extra drkonqi 5.8.5-1 KDE crash handler
x86_64 Extra plasma-nm 5.8.5-1 Plasma applet written in QML for managing network connections
x86_64 Extra libksysguard 5.8.5-1 Libksysguard
x86_64 Extra kuiserver 5.8.5-1 KDE Progress Info UI server
x86_64 Extra sddm-kcm 5.8.5-1 KDE Config Module for SDDM
x86_64 Extra polkit-kde-agent 5.8.5-1 Daemon providing a polkit authentication UI for KDE
x86_64 Extra plasma-sdk 5.8.5-1 Applications useful for Plasma development
x86_64 Extra breeze-kde4 5.8.5-1 Breeze widget style for KDE4 applications
x86_64 Extra kwayland-integration 5.8.5-1 Provides integration plugins for various KDE frameworks for the wayland windowing system
x86_64 Extra ksshaskpass 5.8.5-1 ssh-add helper that uses kwallet and kpassworddialog
x86_64 Extra stellarium 0.15.1-1 A stellarium with great graphics and a nice database of sky-objects
x86_64 Extra libzmf 0.0.1-1 a library for import of Zoner drawing and bitmap files
x86_64 Extra lighttpd 1.4.44-1 A secure, fast, compliant and very flexible web-server
x86_64 Extra clang 3.9.1-1 C language family frontend for LLVM
x86_64 Extra llvm-libs 3.9.1-1 Low Level Virtual Machine (runtime libraries)
x86_64 Extra lldb 3.9.1-1 Next generation, high-performance debugger
x86_64 Extra llvm 3.9.1-1 Low Level Virtual Machine
x86_64 Extra llvm-ocaml 3.9.1-1 OCaml bindings for LLVM
x86_64 Extra python2 2.7.13-1 A high-level scripting language
x86_64 Extra clang-tools-extra 3.9.1-1 Extra tools built using clang's tooling APIs
x86_64 Multilib lib32-clang 3.9.1-1 C language family frontend for LLVM
x86_64 Multilib lib32-llvm-libs 3.9.1-1 Low Level Virtual Machine (runtime library)(32-bit)
x86_64 Multilib lib32-llvm 3.9.1-1 Low Level Virtual Machine (32-bit)
x86_64 Testing nghttp2 1.18.0-1 Framing layer of HTTP/2 is implemented as a reusable C library
x86_64 Testing ncurses 6.0+20161224-1 System V Release 4.0 curses emulation library
x86_64 Community-Testing arduino 1:1.8.0-2 Arduino prototyping platform SDK
x86_64 Community-Testing arduino-builder 1.3.23-2 A command line tool for compiling Arduino sketches
AUR
pingo 0.49c-1
swc-hosts 0.1.1-1
firefox-developer-de 52.0a2_20161228-1
gog-heroes-of-might-and-magic-3-complete-edition 2.0.1.17-6
tupi-git 0.2.git04.251.gdcd31b64-1
st-zenburn-26px-git r18.ca2114b-1
libreoffice-extension-languagetool 3.6-1
libreoffice-dev-bin 5.3.0.1-1
st-neonwave-git r18.ca2114b-1
python2-numba 0.30.0-1
python-numba 0.30.0-1
python2-llvmlite 0.15.0-1
python-llvmlite 0.15.0-1
autodock-vina 1.1.2-2
scikits-bootstrap-git r38.71f83a2-1
Thanks
Posted ImagePosted Image
Configs/PGP Key/comhack π
#2002 OFFLINE   securitybreach
  • 24,208 posts
Posted 29 December 2016 - 08:38 PM
Updates for Wednesday, December 28, 2016
Any
any Community trash-cli 0.16.12.26-1 Command line trashcan (recycle bin) interface
any Community tt-rss 1:r8045-1 Web-based news feed (RSS/Atom) aggregator
any Community perl-graphviz 2.24-1 GraphViz - Interface to AT&T's GraphViz. Deprecated. See GraphViz2
any Community pm2 2.2.3-1 Production process manager for Node.JS applications with a built-in load balancer
any Community python2-werkzeug 0.11.13-1 Swiss Army knife of Python web development
any Community python-werkzeug 0.11.13-1 Swiss Army knife of Python web development
i686
i686 Community znc 1.6.4-2 An IRC bouncer with modules & scripts support
i686 Community discover 5.8.5-1 A collection of package management tools for KDE
i686 Community fossil 1.36-2 Simple, high-reliability, distributed software configuration management
i686 Community handbrake 1.0.0-4 Multithreaded video transcoder
i686 Community handbrake-cli 1.0.0-4 Multithreaded video transcoder (CLI)
i686 Community mysql-workbench 6.3.8-5 A cross-platform, visual database design tool developed by MySQL
i686 Community haskell-dav 1.3.1-36 RFC 4918 WebDAV support
i686 Community haskell-http-conduit 2.2.3-17 HTTP client package with conduit interface and HTTPS support
i686 Community haskell-yesod-auth 1.4.15-10 Authentication for Yesod.
i686 Community haskell-http-client 0.5.5-1 An HTTP client engine
i686 Community haskell-stack 1.3.2-2 The Haskell Tool Stack (docs and libraries)
i686 Community haskell-pipes-http 1.0.5-3 HTTP client with pipes interface
i686 Community haskell-yesod 1.4.3.1-30 Creation of type-safe, RESTful web applications.
i686 Community stack 1.3.2-2 The Haskell Tool Stack
i686 Community hopenpgp-tools 0.19.4-22 hOpenPGP-based command-line tools
i686 Community haskell-authenticate 1.3.3.2-34 Authentication methods for Haskell web applications.
i686 Community haskell-aws 0.15-4 Amazon Web Services (AWS) for Haskell
i686 Community git-annex 6.20161210-26 Manage files with git, without checking their contents into git
i686 Community haskell-http-client-tls 0.3.3-12 http-client backend using the connection package and tls library
i686 Community hoogle 5.0.7-1 Haskell API Search
i686 Community haskell-shakespeare 2.0.12-3 A toolkit for making compile-time interpolated templates
i686 Community rustup 1.0.0-2 The Rust toolchain installer
i686 Community rust-racer 2.0.2-1
i686 Extra nginx-mainline 1.11.8-1 Lightweight HTTP server and IMAP/POP3 proxy server, mainline release
i686 Extra sbcl 1.3.12-1 Steel Bank Common Lisp
i686 Extra maxima 5.38.1-3 A sophisticated computer algebra system
i686 Extra gst-plugins-bad 1.10.2-2 GStreamer Multimedia Framework Bad Plugins
i686 Extra vlc 2.2.4-6 A multi-platform MPEG, VCD/DVD, and DivX player
i686 Extra avidemux-cli 2.6.15-2 Graphical tool to edit video (filter/re-encode/split)
i686 Extra avidemux-qt 2.6.15-2 Graphical tool to edit video (filter/re-encode/split) - Qt GUI
i686 Extra ffmpeg2.8 2.8.9-2 Complete solution to record, convert and stream audio and video
i686 Extra ffmpeg 1:3.2.2-2 Complete solution to record, convert and stream audio and video
i686 Extra x265 2.2-1 Open Source H265/HEVC video encoder
i686 Extra audacious-plugins 3.8.1-2 Plugins for Audacious
i686 Extra mutter 3.22.2+6+g06f5b6b3e-1 A window manager for GNOME
i686 Extra epiphany 3.22.4-1 A GNOME web browser based on the WebKit rendering engine
i686 Extra qtcreator 4.2.0-3 Lightweight, cross-platform integrated development environment
i686 Extra openbabel 2.4.1-2 A library designed to interconvert between many file formats used in molecular modeling and computational chemistry
i686 Extra kalzium 16.12.0-3 Periodic Table of Elements
i686 Extra python-openbabel 2.4.1-2 A library designed to interconvert between many file formats used in molecular modeling and computational chemistry
i686 Testing elfutils 0.168-1 Utilities to handle ELF object files and DWARF debugging information
i686 Testing libelf 0.168-1 Libraries to handle ELF object files and DWARF debugging information
i686 Testing nftables 1:0.7-1 Netfilter tables userspace tools
i686 Testing openvpn 2.4.0-2 An easy-to-use, robust and highly configurable VPN (Virtual Private Network)
i686 Testing bzip2 1.0.6-6 A high-quality data compression program
i686 Testing curl 7.52.1-2 An URL retrieval utility and library
i686 Testing libgpg-error 1.26-1 Support library for libgcrypt
i686 Community-Testing docker 1:1.12.5-1 Pack, ship and run any application as a lightweight container
i686 Community-Testing haproxy 1.7.1-1 Reliable, high performance TCP/HTTP load balancer
x86_64
x86_64 Community znc 1.6.4-2 An IRC bouncer with modules & scripts support
x86_64 Community discover 5.8.5-1 A collection of package management tools for KDE
x86_64 Community fossil 1.36-2 Simple, high-reliability, distributed software configuration management
x86_64 Community handbrake 1.0.0-4 Multithreaded video transcoder
x86_64 Community handbrake-cli 1.0.0-4 Multithreaded video transcoder (CLI)
x86_64 Community mysql-workbench 6.3.8-5 A cross-platform, visual database design tool developed by MySQL
x86_64 Community haskell-dav 1.3.1-36 RFC 4918 WebDAV support
x86_64 Community haskell-http-conduit 2.2.3-17 HTTP client package with conduit interface and HTTPS support
x86_64 Community haskell-yesod-auth 1.4.15-10 Authentication for Yesod.
x86_64 Community haskell-http-client 0.5.5-1 An HTTP client engine
x86_64 Community haskell-stack 1.3.2-2 The Haskell Tool Stack (docs and libraries)
x86_64 Community haskell-pipes-http 1.0.5-3 HTTP client with pipes interface
x86_64 Community haskell-yesod 1.4.3.1-30 Creation of type-safe, RESTful web applications.
x86_64 Community stack 1.3.2-2 The Haskell Tool Stack
x86_64 Community hopenpgp-tools 0.19.4-22 hOpenPGP-based command-line tools
x86_64 Community haskell-authenticate 1.3.3.2-34 Authentication methods for Haskell web applications.
x86_64 Community haskell-aws 0.15-4 Amazon Web Services (AWS) for Haskell
x86_64 Community git-annex 6.20161210-26 Manage files with git, without checking their contents into git
x86_64 Community haskell-http-client-tls 0.3.3-12 http-client backend using the connection package and tls library
x86_64 Community hoogle 5.0.7-1 Haskell API Search
x86_64 Community haskell-shakespeare 2.0.12-3 A toolkit for making compile-time interpolated templates
x86_64 Community rustup 1.0.0-2 The Rust toolchain installer
x86_64 Community rust-racer 2.0.2-1 Code completion for Rust
x86_64 Extra nginx-mainline 1.11.8-1 Lightweight HTTP server and IMAP/POP3 proxy server, mainline release
x86_64 Extra sbcl 1.3.12-1 Steel Bank Common Lisp
x86_64 Extra maxima 5.38.1-3 A sophisticated computer algebra system
x86_64 Extra gst-plugins-bad 1.10.2-2 GStreamer Multimedia Framework Bad Plugins
x86_64 Extra vlc 2.2.4-6 A multi-platform MPEG, VCD/DVD, and DivX player
x86_64 Extra avidemux-cli 2.6.15-2 Graphical tool to edit video (filter/re-encode/split)
x86_64 Extra avidemux-qt 2.6.15-2 Graphical tool to edit video (filter/re-encode/split) - Qt GUI
x86_64 Extra ffmpeg2.8 2.8.9-2 Complete solution to record, convert and stream audio and video
x86_64 Extra ffmpeg 1:3.2.2-2 Complete solution to record, convert and stream audio and video
x86_64 Extra x265 2.2-1 Open Source H265/HEVC video encoder
x86_64 Extra audacious-plugins 3.8.1-2 Plugins for Audacious
x86_64 Extra mutter 3.22.2+6+g06f5b6b3e-1 A window manager for GNOME
x86_64 Extra epiphany 3.22.4-1 A GNOME web browser based on the WebKit rendering engine
x86_64 Extra qtcreator 4.2.0-3 Lightweight, cross-platform integrated development environment
x86_64 Extra openbabel 2.4.1-2 A library designed to interconvert between many file formats used in molecular modeling and computational chemistry
x86_64 Extra kalzium 16.12.0-3 Periodic Table of Elements
x86_64 Extra python-openbabel 2.4.1-2 A library designed to interconvert between many file formats used in molecular modeling and computational chemistry
x86_64 Testing elfutils 0.168-1 Utilities to handle ELF object files and DWARF debugging information
x86_64 Testing libelf 0.168-1 Libraries to handle ELF object files and DWARF debugging information
x86_64 Testing nftables 1:0.7-1 Netfilter tables userspace tools
x86_64 Testing openvpn 2.4.0-2 An easy-to-use, robust and highly configurable VPN (Virtual Private Network)
x86_64 Testing bzip2 1.0.6-6 A high-quality data compression program
x86_64 Testing curl 7.52.1-2 An URL retrieval utility and library
x86_64 Testing libgpg-error 1.26-1 Support library for libgcrypt
x86_64 Community-Testing haproxy 1.7.1-1 Reliable, high performance TCP/HTTP load balancer
x86_64 Community-Testing docker 1:1.12.5-1 Pack, ship and run any application as a lightweight container
AUR
dasm 2.20.11-1
slf4j 1.7.22-1
jgit 4.6.0.201612231935_r-2
tutanota-electron-git 0.0.1-1
mingw-w64-cairo-bootstrap 1.14.8-1
containerd-git v0.2.3.r201.g437c971-1
docker-registry-git v2.6.0.rc.1.55.g2d500932-1
chromedriver 2.27-1
brave 0.12.15-3
brave-bin 0.12.15-2
brave-git 0.13.0.4879-1
syncplay-git v1.4.0.RC4.r17.gddae114-1
firefox-developer-de 52.0a2_20161229-1
syncplay 1.4.0rc4-1
gcode3d-git df9c77d-1
Thanks
#2003 OFFLINE   securitybreach
  • 24,208 posts
Posted 06 January 2017 - 08:28 PM
Updates for Thursday, January 05, 2016
Any
any Community intellij-idea-community-edition 2:2016.3.2-1 IDE for Java, Groovy and other programming languages with advanced refactoring features
any Community elixir 1.4.0-1 a functional meta-programming aware language built on top of the Erlang VM
any Community drupal 8.2.5-1 A PHP-based content management platform
any Community perl-moo 2.003000-2 Minimalist Object Orientation (with Moose compatiblity)
any Community perl-sub-quote 2.003001-1 efficient generation of subroutines via string eval
any Community mustache-d 0.1.3-1 Moustache template engine for D
any Community nodejs-less 2.7.2-1 A standalone compiler for the LESS CSS language.
i686
i686 Extra vice 3.0-1 The Versatile Commodore 8-bit Emulator
i686 Core dhcpcd 6.11.5-1 RFC2131 compliant DHCP client daemon
i686 Core sqlite 3.16.1-1 A C library that implements an SQL database engine
i686 Core sqlite-tcl 3.16.1-1 sqlite Tcl Extension Architecture (TEA)
i686 Core sqlite-analyzer 3.16.1-1 An analysis program for sqlite3 database files
i686 Core sqlite-doc 3.16.1-1 most of the static HTML files that comprise this website, including all of the SQL Syntax and the C/C++ interface specs and other miscellaneous documentation
i686 Community gammu 1.38.1-1 GNU All Mobile Management Utilities
i686 Community unrtf 0.21.9-2 Command-line program which converts RTF documents to other formats
i686 Community pynac 0.7.3-2 Python version of GiNaC, a C++ library for symbolic mathematical calculations
i686 Community mgba-sdl 0.5.2-1 A Nintendo Gameboy Advance Emulator focusing on both speed and accuracy
i686 Community mgba-qt 0.5.2-1 A Nintendo Gameboy Advance Emulator focusing on both speed and accuracy. Qt5 UI.
i686 Community libmgba 0.5.2-1 Shared library of mGBA
i686 Community atom 1.12.9-1 A hackable text editor for the 21st Century
i686 Community wireguard-dkms 0.0.20170105-1 next generation secure network tunnel
i686 Community wireguard-tools 0.0.20170105-1 next generation secure network tunnel
i686 Community mailutils 3.1.1-1 MUA command line tool (mailx)
i686 Community busybox 1.26.1-1 Utilities for rescue and embedded systems
i686 Community gogglesmm 1.1.5-1 Music Manager and Player
i686 Community tuxguitar 1.4-1 multitrack guitar tablature editor and player
i686 Community lshw B.02.18-2 A small tool to provide detailed information on the hardware configuration of the machine.
i686 Community musl 1.1.16-1 Lightweight implementation of C standard library
i686 Community erlang-unixodbc 19.2-1 Unixodbc support for Erlang
i686 Community erlang 19.2-1 General-purpose concurrent functional programming language developed by Ericsson
i686 Community erlang-nox 19.2-1 General-purpose concurrent functional programming language developed by Ericsson (headless version)
i686 Extra inkscape 0.92.0-2 Professional vector graphics editor
i686 Extra libevdev 1.5.6-1 Wrapper library for evdev devices
i686 Extra irssi 0.8.21-1 Modular text mode IRC client with Perl scripting
i686 Extra gtk3-print-backends 3.22.6-1 Print backends for GTK3
i686 Extra gtk3 3.22.6-1 GObject-based multi-platform GUI toolkit
i686 Extra gtk-update-icon-cache 3.22.6-1 GTK+ icon cache updater
i686 Testing xorg-server-xvfb 1.19.0-4 Virtual framebuffer X server
i686 Testing xorg-server-xwayland 1.19.0-4 run X clients under wayland
i686 Testing xorg-server-common 1.19.0-4 Xorg server common files
i686 Testing xorg-server-xnest 1.19.0-4 A nested X server that runs as an X application
i686 Testing xorg-server-xephyr 1.19.0-4 A nested X server that runs as an X application
i686 Testing xorg-server-devel 1.19.0-4 Development files for the X.Org X server
i686 Testing xorg-server-xdmx 1.19.0-4 Distributed Multihead X Server and utilities
i686 Testing xorg-server 1.19.0-4 Xorg X server
i686 Testing libpng 1.6.28-1 A collection of routines used to create PNG format graphics files
i686 Testing nghttp2 1.18.1-1 Framing layer of HTTP/2 is implemented as a reusable C library
i686 Testing mariadb 10.1.20-3 Fast SQL database server, drop-in replacement for MySQL
i686 Testing mariadb-clients 10.1.20-3 MariaDB client tools
i686 Testing libmariadbclient 10.1.20-3 MariaDB client libraries
i686 Testing mytop 10.1.20-3 Top clone for MariaDB
i686 Community-Testing libev 4.24-1 A full-featured and high-performance event loop
x86_64
x86_64 Core gmp 6.1.2-1 A free library for arbitrary precision arithmetic
x86_64 Core dhcpcd 6.11.5-1 RFC2131 compliant DHCP client daemon
x86_64 Core sqlite 3.16.1-1 A C library that implements an SQL database engine
x86_64 Core sqlite-tcl 3.16.1-1 sqlite Tcl Extension Architecture (TEA)
x86_64 Core sqlite-analyzer 3.16.1-1 An analysis program for sqlite3 database files
x86_64 Core sqlite-doc 3.16.1-1 most of the static HTML files that comprise this website, including all of the SQL Syntax and the C/C++ interface specs and other miscellaneous documentation
x86_64 Community qtox 1.7.1-2 Powerful Tox client written in C++/Qt that follows the Tox design guidelines
x86_64 Community nodejs 7.4.0-1 Evented I/O for V8 javascript
x86_64 Community gammu 1.38.1-1 GNU All Mobile Management Utilities
x86_64 Community unrtf 0.21.9-2 Command-line program which converts RTF documents to other formats
x86_64 Community pynac 0.7.3-2 Python version of GiNaC, a C++ library for symbolic mathematical calculations
x86_64 Community mgba-sdl 0.5.2-1 A Nintendo Gameboy Advance Emulator focusing on both speed and accuracy
x86_64 Community mgba-qt 0.5.2-1 A Nintendo Gameboy Advance Emulator focusing on both speed and accuracy. Qt5 UI.
x86_64 Community libmgba 0.5.2-1 Shared library of mGBA
x86_64 Community atom 1.12.9-1 A hackable text editor for the 21st Century
x86_64 Community wireguard-dkms 0.0.20170105-1 next generation secure network tunnel
x86_64 Community wireguard-tools 0.0.20170105-1 next generation secure network tunnel
x86_64 Community mailutils 3.1.1-1 MUA command line tool (mailx)
x86_64 Community busybox 1.26.1-1 Utilities for rescue and embedded systems
x86_64 Community gogglesmm 1.1.5-1 Music Manager and Player
x86_64 Community tuxguitar 1.4-1 multitrack guitar tablature editor and player
x86_64 Community lshw B.02.18-2 A small tool to provide detailed information on the hardware configuration of the machine.
x86_64 Community musl 1.1.16-1 Lightweight implementation of C standard library
x86_64 Community erlang-unixodbc 19.2-1 Unixodbc support for Erlang
x86_64 Community erlang 19.2-1 General-purpose concurrent functional programming language developed by Ericsson
x86_64 Community erlang-nox 19.2-1 General-purpose concurrent functional programming language developed by Ericsson (headless version)
x86_64 Extra vice 3.0-1 The Versatile Commodore 8-bit Emulator
x86_64 Extra inkscape 0.92.0-2 Professional vector graphics editor
x86_64 Extra libevdev 1.5.6-1 Wrapper library for evdev devices
x86_64 Extra irssi 0.8.21-1 Modular text mode IRC client with Perl scripting
x86_64 Extra gtk3-print-backends 3.22.6-1 Print backends for GTK3
x86_64 Extra gtk3 3.22.6-1 GObject-based multi-platform GUI toolkit
x86_64 Extra gtk-update-icon-cache 3.22.6-1 GTK+ icon cache updater
x86_64 Testing mpfr 3.1.5.p2-1 Multiple-precision floating-point library
x86_64 Testing m4 1.4.18-1 The GNU macro processor
x86_64 Testing flex 2.6.3-1 A tool for generating text-scanning programs
x86_64 Testing xorg-server-xvfb 1.19.0-4 Virtual framebuffer X server
x86_64 Testing xorg-server-xwayland 1.19.0-4 run X clients under wayland
x86_64 Testing xorg-server-common 1.19.0-4 Xorg server common files
x86_64 Testing xorg-server-xnest 1.19.0-4 A nested X server that runs as an X application
x86_64 Testing xorg-server-xephyr 1.19.0-4 A nested X server that runs as an X application
x86_64 Testing xorg-server-devel 1.19.0-4 Development files for the X.Org X server
x86_64 Testing xorg-server-xdmx 1.19.0-4 Distributed Multihead X Server and utilities
x86_64 Testing xorg-server 1.19.0-4 Xorg X server
x86_64 Testing libpng 1.6.28-1 A collection of routines used to create PNG format graphics files
x86_64 Testing nghttp2 1.18.1-1 Framing layer of HTTP/2 is implemented as a reusable C library
x86_64 Testing mariadb 10.1.20-3 Fast SQL database server, drop-in replacement for MySQL
x86_64 Testing mariadb-clients 10.1.20-3 MariaDB client tools
x86_64 Testing libmariadbclient 10.1.20-3 MariaDB client libraries
x86_64 Testing mytop 10.1.20-3 Top clone for MariaDB
x86_64 Community-Testing libev 4.24-1 A full-featured and high-performance event loop
x86_64 Community-Testing thrift 0.10.0-1 Scalable cross-language services framework for IPC/RPC
x86_64 Community-Testing android-tools 7.1.1_r13-1 Android platform tools
x86_64 Multilib-Testing lib32-mesa 13.0.3-1 an open-source implementation of the OpenGL specification (32-bit)
x86_64 Multilib-Testing lib32-mesa-vdpau 13.0.3-1 Mesa VDPAU drivers (32-bit)
x86_64 Multilib-Testing lib32-vulkan-radeon 13.0.3-1 Radeon's Vulkan mesa driver (32-bit)
x86_64 Multilib-Testing lib32-mesa-libgl 13.0.3-1 Mesa 3-D graphics library (32-bit)
x86_64 Multilib-Testing lib32-vulkan-intel 13.0.3-1 Intel's Vulkan mesa driver (32-bit)
AUR
mozilla-firefox-sync-server-git 1.6.0.r1.gd7bd0cf-1
lib32-bluez-libs 5.43-2
lib32-bluez-plugins 5.43-2
sopcast-launcher 0.5.0-1
phive 0.6.2-2
openra-kang kang.a6d416d-1
lltag 0.14.5-1
arm-frc-linux-gnueabi-wpilib-git 1713.bc7ab176-1
meshlab 2016.12-1
acestream-launcher 0.5.0-1
frc-2017 20170106-1
arm-frc-linux-gnueabi-eigen 3.2.0-2
arm-frc-linux-gnueabi-wpilib 2017.1.1-1
hop-git 3.0.0r766.2cd70fb-1
arm-frc-linux-gnueabi-lin
Thanks
#2004 OFFLINE   securitybreach
  • 24,208 posts
Posted 08 January 2017 - 09:01 PM
Updates for Saturday, January 07, 2016
Any
any Community gradle 3.3-1 Powerful build system for the JVM
any Community gradle-src 3.3-1 Powerful build system for the JVM (sources)
any Community gradle-doc 3.3-1 Powerful build system for the JVM (documentation and samples)
any Community gufw 17.04.1-3 Uncomplicated way to manage your Linux firewall
any Community python2-eventlet 0.20.1-1 Highly concurrent networking library
any Community python-eventlet 0.20.1-1 Highly concurrent networking library
any Community sqlmap 1.1-1 Automatic SQL injection and database takeover tool
any Community jupyter-nbconvert 5.0.0-1 A language-agnostic web-based interactive shell/notebook server.
any Community jupyter-notebook 4.3.1-1 The language-agnostic HTML notebook application for Project Jupyter
any Community python2-pyjwt 1.4.2-1 JSON Web Token implementation in Python
any Community python-pyjwt 1.4.2-1 JSON Web Token implementation in Python
any Community python2-pyflakes 1.4.0-1 A lint-like tool for Python to identify common errors quickly without executing code
any Community python-pyflakes 1.4.0-1 A lint-like tool for Python to identify common errors quickly without executing code
any Community python-bottle 0.12.12-1 A fast and simple micro-framework for small web-applications
any Community python2-bottle 0.12.12-1 A fast and simple micro-framework for small web-applications
any Community eslint 3.13.0-1 An AST-based pattern checker for Javascript
any Community dg 1.1.0.20160916-1 A simple language that compiles to CPython bytecode
any Extra deluge 1.3.13+11+g48cedf635-1 A BitTorrent client with multiple user interfaces in a client/server model
i686
i686 Core linux-lts-headers 4.4.40-1 Header files and scripts for building modules for Linux-lts kernel
i686 Core linux-lts 4.4.40-1 The Linux-lts kernel and modules
i686 Core linux-lts-docs 4.4.40-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
i686 Community moneymanagerex 1.3.1-1 An easy-to-use personal finance suite
i686 Community acpi_call-lts 1.1.0-36 A linux kernel module that enables calls to ACPI methods through /proc/acpi/call
i686 Community r8168-lts 8.042-6 A kernel module for Realtek 8168 network cards for linux-lts
i686 Community bbswitch-lts 0.8-25 Kernel module allowing to switch dedicated graphics card on Optimus laptops
i686 Community tp_smapi-lts 0.42-6 Modules for ThinkPad's SMAPI functionality
i686 Community parity 1.4.8-1 Fast, light, robust Ethereum implementation
i686 Community haskell-stack 1.3.2-6 The Haskell Tool Stack (docs and libraries)
i686 Community haskell-criterion 1.1.4.0-13 Robust, reliable performance measurement and analysis
i686 Community haskell-hpack 0.15.0-14 An alternative format for Haskell packages
i686 Community stack 1.3.2-6 The Haskell Tool Stack
i686 Community haskell-glob 0.7.14-1 Globbing library
i686 Community partitionmanager 3.0.1-1 A KDE utility that allows you to manage disks, partitions, and file systems
i686 Community wine 2.0rc4-1 A compatibility layer for running Windows programs
i686 Community haskell-postgresql-binary 0.9.1.1-10 Encoders and decoders for the PostgreSQL's binary format
i686 Community haskell-pointed 5-25 Pointed and copointed data
i686 Community haskell-keys 3.11-24 Keyed functors and containers
i686 Community haskell-free 4.12.4-23 Monads for free
i686 Community haskell-trifecta 1.6.1-6 A modern parser combinator library with convenient diagnostics
i686 Community haskell-monad-journal 0.7.2-11 Pure logger typeclass and monad transformer
i686 Community idris 0.99-14 Functional Programming Language with Dependent Types
i686 Community haskell-tasty-rerun 1.1.6-8 Run tests by filtering the test tree depending on the result of previous test runs
i686 Community haskell-wl-pprint-terminfo 3.7.1.4-3 A color pretty printer with terminfo support
i686 Community git-annex 6.20170101-5 Manage files with git, without checking their contents into git
i686 Community haskell-hasql 0.19.15.2-11 An efficient PostgreSQL driver and a flexible mapping API
i686 Community haskell-adjunctions 4.3-23 Adjunctions and representable functors
i686 Community haskell-vector-instances 3.3.1-28 Orphan Instances for \'Data.Vector\'
i686 Community haskell-wl-pprint-extras 3.5.0.5-3 A free monad based on the Wadler/Leijen pretty printer
i686 Community haskell-hopenpgp 2.5.5-19 Native Haskell implementation of OpenPGP (RFC4880)
i686 Community haskell-ghc-mod 5.6.0.0-14 Happy Haskell Programming (docs and libraries)
i686 Community haskell-kan-extensions 5.0.1-23 Kan extensions, Kan lifts, various forms of the Yoneda lemma, and (co)density (co)monads
i686 Community haskell-profunctors 5.2-21 Profunctors
i686 Community haskell-distributive 0.5.1-1 Distributive functors -- Dual to Traversable
i686 Community haskell-hasql-pool 0.4.1-11 A pool of connections for Hasql
i686 Community haskell-comonad 5-18 Comonads
i686 Community haskell-bifunctors 5.4.1-4 Bifunctors
i686 Community haskell-lens 4.15.1-4 Lenses, Folds and Traversals
i686 Community hopenpgp-tools 0.19.4-25 hOpenPGP-based command-line tools
i686 Community haskell-foldl 1.2.2-3 Composable, streaming, and efficient left folds
i686 Community haskell-store 0.3-6 Fast binary serialization
i686 Community haskell-turtle 1.3.0-7 Shell programming, Haskell-style
i686 Community haskell-descriptive 0.9.4-32 Self-describing consumers/parsers; forms, cmd-line args, JSON, etc.
i686 Community haskell-dav 1.3.1-40 RFC 4918 WebDAV support
i686 Community ghc-mod 5.6.0.0-14 Happy Haskell Programming
i686 Community cgrep 6.6.16-13 A context-aware grep for source codes
i686 Community haskell-optparse-simple 0.0.3-32 Simple interface to optparse-applicative
i686 Community haskell-semigroupoids 5.1-7 Semigroupoids: Category sans id
i686 Community haskell-reducers 3.12.1-21 Semigroups, specialized containers and a general map/reduce framework
i686 Community haskell-either 4.4.1.1-11 An either monad transformer
i686 Community linux-grsec-headers 1:4.8.16.r201701062021-1 Header files and scripts for building modules for Linux-grsec kernel
i686 Community mongodb-tools 3.4.0-1 The MongoDB tools provide import, export, and diagnostic capabilities.
i686 Community linux-grsec-docs 1:4.8.16.r201701062021-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
i686 Community gradm 3.1.201701031918-1 Administration utility for grsecurity's Role Based Access Control (RBAC)
i686 Community perl-mouse 2.4.6-1 Moose minus the antlers
i686 Community linux-grsec 1:4.8.16.r201701062021-1 The Linux kernel and modules with grsecurity/PaX patches
i686 Community ruby-cairo 1.15.4-1 Ruby bindings for cairo
i686 Extra imagemagick-doc 6.9.7.3-1 The ImageMagick documentation (utilities manuals and libraries API)
i686 Extra imagemagick 6.9.7.3-1 An image viewing/manipulation program
i686 Extra vim 8.0.0149-1 Vi Improved, a highly configurable, improved version of the vi text editor
i686 Extra vim-runtime 8.0.0149-1 Runtime for vim and gvim
i686 Extra gvim 8.0.0149-1 Vi Improved, a highly configurable, improved version of the vi text editor (with advanced features, such as a GUI)
i686 Extra harfbuzz-icu 1.4.1-1 OpenType text shaping engine (ICU integration)
i686 Extra harfbuzz 1.4.1-1 OpenType text shaping engine
i686 Extra nvidia-340xx-lts 340.101-2 NVIDIA drivers for linux-lts
i686 Extra nvidia-lts 375.26-2 NVIDIA drivers for linux-lts
i686 Extra nvidia-304xx-lts 304.132-4 NVIDIA drivers for linux-lts, 304xx legacy branch
i686 Extra inkscape 0.92.0-3 Professional vector graphics editor
i686 Extra swig 3.0.11-1 Generate scripting interfaces to C/C++ code
i686 Extra python-numpy 1.11.3-1 Scientific tools for Python
i686 Extra python2-numpy 1.11.3-1 Scientific tools for Python
i686 Testing linux-zen 4.9.1-1 The Linux-zen kernel and modules
i686 Testing linux-zen-headers 4.9.1-1 Header files and scripts for building modules for Linux-zen kernel
i686 Testing linux-zen-docs 4.9.1-1 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
i686 Testing libpulse 9.99.1-1 A featureful, general-purpose sound server (client library)
i686 Testing pulseaudio-zeroconf 9.99.1-1 Zeroconf support for PulseAudio
i686 Testing pulseaudio 9.99.1-1 A featureful, general-purpose sound server
i686 Testing pulseaudio-bluetooth 9.99.1-1 Bluetooth support for PulseAudio
i686 Testing pulseaudio-lirc 9.99.1-1 IR (lirc) support for PulseAudio
i686 Testing pulseaudio-gconf 9.99.1-1 GConf support for PulseAudio
i686 Testing pulseaudio-jack 9.99.1-1 Jack support for PulseAudio
i686 Testing pulseaudio-equalizer 9.99.1-1 Equalizer for PulseAudio
i686 Testing libphonenumber 8.0.0-1 Google's common library for parsing, formatting, and validating international phone numbers
i686 Testing evolution-data-server 3.22.3-2 Centralized access to appointments and contacts
i686 Testing nvidia 375.26-3 NVIDIA drivers for linux
i686 Testing linux-docs 4.9.1-1 Kernel hackers manual - HTML documentation that comes with the Linux kernel
i686 Testing linux 4.9.1-1 The Linux kernel and modules
i686 Testing nvidia-dkms 375.26-3 NVIDIA driver sources for linux
i686 Testing nvidia-340xx-dkms 340.101-6 NVIDIA driver sources for linux, 340xx legacy branch
i686 Testing nvidia-340xx 340.101-6 NVIDIA drivers for linux, 340xx legacy branch
i686 Testing linux-headers 4.9.1-1 Header files and scripts for building modules for Linux kernel
i686 Community-Testing libsigrokdecode 0.4.1-1 Client software that supports various hardware logic analyzers, protocol decoders library
i686 Community-Testing virtualbox-guest-modules-arch 5.1.12-3 Virtualbox guest kernel modules for Arch Kernel
i686 Community-Testing acpi_call 1.1.0-53 A linux kernel module that enables calls to ACPI methods through /proc/acpi/call
i686 Community-Testing bbswitch-dkms 0.8-57 Kernel module allowing to switch dedicated graphics card on Optimus laptops
i686 Community-Testing vhba-module 20161009-4 Kernel module that emulates SCSI devices
i686 Community-Testing bbswitch 0.8-57 Kernel module allowing to switch dedicated graphics card on Optimus laptops
i686 Community-Testing r8168 8.043.01-4 A kernel module for Realtek 8168 network cards
i686 Community-Testing tp_smapi 0.42-7 Modules for ThinkPad's SMAPI functionality
i686 Community-Testing virtualbox-host-modules-arch 5.1.12-3 Virtualbox host kernel modules for Arch Kernel
x86_64
x86_64 Core linux-lts-headers 4.4.40-1 Header files and scripts for building modules for Linux-lts kernel
x86_64 Core linux-lts 4.4.40-1 The Linux-lts kernel and modules
x86_64 Core linux-lts-docs 4.4.40-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
x86_64 Community diffoscope 67-1 Tool for in-depth comparison of files, archives, and directories
x86_64 Community moneymanagerex 1.3.1-1 An easy-to-use personal finance suite
x86_64 Community acpi_call-lts 1.1.0-36 A linux kernel module that enables calls to ACPI methods through /proc/acpi/call
x86_64 Community r8168-lts 8.042-6 A kernel module for Realtek 8168 network cards for linux-lts
x86_64 Community bbswitch-lts 0.8-25 Kernel module allowing to switch dedicated graphics card on Optimus laptops
x86_64 Community tp_smapi-lts 0.42-6 Modules for ThinkPad's SMAPI functionality
x86_64 Community parity 1.4.8-1 Fast, light, robust Ethereum implementation
x86_64 Community haskell-stack 1.3.2-6 The Haskell Tool Stack (docs and libraries)
x86_64 Community haskell-criterion 1.1.4.0-13 Robust, reliable performance measurement and analysis
x86_64 Community haskell-hpack 0.15.0-14 An alternative format for Haskell packages
x86_64 Community stack 1.3.2-6 The Haskell Tool Stack
x86_64 Community haskell-glob 0.7.14-1 Globbing library
x86_64 Community partitionmanager 3.0.1-1 A KDE utility that allows you to manage disks, partitions, and file systems
x86_64 Community haskell-postgresql-binary 0.9.1.1-10 Encoders and decoders for the PostgreSQL's binary format
x86_64 Community haskell-pointed 5-25 Pointed and copointed data
x86_64 Community haskell-keys 3.11-24 Keyed functors and containers
x86_64 Community haskell-free 4.12.4-23 Monads for free
x86_64 Community haskell-trifecta 1.6.1-6 A modern parser combinator library with convenient diagnostics
x86_64 Community haskell-monad-journal 0.7.2-11 Pure logger typeclass and monad transformer
x86_64 Community idris 0.99-14 Functional Programming Language with Dependent Types
x86_64 Community haskell-tasty-rerun 1.1.6-8 Run tests by filtering the test tree depending on the result of previous test runs
x86_64 Community haskell-wl-pprint-terminfo 3.7.1.4-3 A color pretty printer with terminfo support
x86_64 Community git-annex 6.20170101-5 Manage files with git, without checking their contents into git
x86_64 Community haskell-hasql 0.19.15.2-11 An efficient PostgreSQL driver and a flexible mapping API
x86_64 Community haskell-adjunctions 4.3-23 Adjunctions and representable functors
x86_64 Community haskell-vector-instances 3.3.1-28 Orphan Instances for \'Data.Vector\'
x86_64 Community haskell-wl-pprint-extras 3.5.0.5-3 A free monad based on the Wadler/Leijen pretty printer
x86_64 Community haskell-hopenpgp 2.5.5-19 Native Haskell implementation of OpenPGP (RFC4880)
x86_64 Community haskell-ghc-mod 5.6.0.0-14 Happy Haskell Programming (docs and libraries)
x86_64 Community haskell-kan-extensions 5.0.1-23 Kan extensions, Kan lifts, various forms of the Yoneda lemma, and (co)density (co)monads
x86_64 Community haskell-profunctors 5.2-21 Profunctors
x86_64 Community haskell-distributive 0.5.1-1 Distributive functors -- Dual to Traversable
x86_64 Community haskell-hasql-pool 0.4.1-11 A pool of connections for Hasql
x86_64 Community haskell-comonad 5-18 Comonads
x86_64 Community haskell-bifunctors 5.4.1-4 Bifunctors
x86_64 Community haskell-lens 4.15.1-4 Lenses, Folds and Traversals
x86_64 Community hopenpgp-tools 0.19.4-25 hOpenPGP-based command-line tools
x86_64 Community haskell-foldl 1.2.2-3 Composable, streaming, and efficient left folds
x86_64 Community haskell-store 0.3-6 Fast binary serialization
x86_64 Community haskell-turtle 1.3.0-7 Shell programming, Haskell-style
x86_64 Community haskell-descriptive 0.9.4-32 Self-describing consumers/parsers; forms, cmd-line args, JSON, etc.
x86_64 Community haskell-dav 1.3.1-40 RFC 4918 WebDAV support
x86_64 Community ghc-mod 5.6.0.0-14 Happy Haskell Programming
x86_64 Community cgrep 6.6.16-13 A context-aware grep for source codes
x86_64 Community haskell-optparse-simple 0.0.3-32 Simple interface to optparse-applicative
x86_64 Community haskell-semigroupoids 5.1-7 Semigroupoids: Category sans id
x86_64 Community haskell-reducers 3.12.1-21 Semigroups, specialized containers and a general map/reduce framework
x86_64 Community haskell-either 4.4.1.1-11 An either monad transformer
x86_64 Community linux-grsec-headers 1:4.8.16.r201701062021-1 Header files and scripts for building modules for Linux-grsec kernel
x86_64 Community mongodb-tools 3.4.0-1 The MongoDB tools provide import, export, and diagnostic capabilities.
x86_64 Community linux-grsec-docs 1:4.8.16.r201701062021-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
x86_64 Community gradm 3.1.201701031918-1 Administration utility for grsecurity's Role Based Access Control (RBAC)
x86_64 Community perl-mouse 2.4.6-1 Moose minus the antlers
x86_64 Community linux-grsec 1:4.8.16.r201701062021-1 The Linux kernel and modules with grsecurity/PaX patches
x86_64 Community ruby-cairo 1.15.4-1 Ruby bindings for cairo
x86_64 Extra imagemagick-doc 6.9.7.3-1 The ImageMagick documentation (utilities manuals and libraries API)
x86_64 Extra imagemagick 6.9.7.3-1 An image viewing/manipulation program
x86_64 Extra vim 8.0.0149-1 Vi Improved, a highly configurable, improved version of the vi text editor
x86_64 Extra vim-runtime 8.0.0149-1 Runtime for vim and gvim
x86_64 Extra gvim 8.0.0149-1 Vi Improved, a highly configurable, improved version of the vi text editor (with advanced features, such as a GUI)
x86_64 Multilib lib32-alsa-lib 1.1.3-1 An alternative implementation of Linux sound support (32 bit)
x86_64 Extra harfbuzz-icu 1.4.1-1 OpenType text shaping engine (ICU integration)
x86_64 Extra harfbuzz 1.4.1-1 OpenType text shaping engine
x86_64 Extra nvidia-340xx-lts 340.101-2 NVIDIA drivers for linux-lts
x86_64 Extra nvidia-lts 375.26-2 NVIDIA drivers for linux-lts
x86_64 Extra nvidia-304xx-lts 304.132-4 NVIDIA drivers for linux-lts, 304xx legacy branch
x86_64 Extra inkscape 0.92.0-3 Professional vector graphics editor
x86_64 Extra swig 3.0.11-1 Generate scripting interfaces to C/C++ code
x86_64 Extra python-numpy 1.11.3-1 Scientific tools for Python
x86_64 Extra python2-numpy 1.11.3-1 Scientific tools for Python
x86_64 Multilib lib32-mesa-vdpau 13.0.3-1 Mesa VDPAU drivers (32-bit)
x86_64 Multilib lib32-vulkan-radeon 13.0.3-1 Radeon's Vulkan mesa driver (32-bit)
x86_64 Multilib lib32-mesa 13.0.3-1 an open-source implementation of the OpenGL specification (32-bit)
x86_64 Multilib lib32-mesa-libgl 13.0.3-1 Mesa 3-D graphics library (32-bit)
x86_64 Multilib lib32-vulkan-intel 13.0.3-1 Intel's Vulkan mesa driver (32-bit)
x86_64 Multilib wine 2.0rc4-1 A compatibility layer for running Windows programs
x86_64 Testing linux-zen 4.9.1-1 The Linux-zen kernel and modules
x86_64 Testing linux-zen-headers 4.9.1-1 Header files and scripts for building modules for Linux-zen kernel
x86_64 Testing linux-zen-docs 4.9.1-1 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
x86_64 Testing libpulse 9.99.1-1 A featureful, general-purpose sound server (client library)
x86_64 Testing pulseaudio-zeroconf 9.99.1-1 Zeroconf support for PulseAudio
x86_64 Testing pulseaudio 9.99.1-1 A featureful, general-purpose sound server
x86_64 Testing pulseaudio-bluetooth 9.99.1-1 Bluetooth support for PulseAudio
x86_64 Testing pulseaudio-lirc 9.99.1-1 IR (lirc) support for PulseAudio
x86_64 Testing pulseaudio-gconf 9.99.1-1 GConf support for PulseAudio
x86_64 Testing pulseaudio-jack 9.99.1-1 Jack support for PulseAudio
x86_64 Testing pulseaudio-equalizer 9.99.1-1 Equalizer for PulseAudio
x86_64 Testing libphonenumber 8.0.0-1 Google's common library for parsing, formatting, and validating international phone numbers
x86_64 Testing evolution-data-server 3.22.3-2 Centralized access to appointments and contacts
x86_64 Testing nvidia 375.26-3 NVIDIA drivers for linux
x86_64 Testing linux-docs 4.9.1-1 Kernel hackers manual - HTML documentation that comes with the Linux kernel
x86_64 Testing linux 4.9.1-1 The Linux kernel and modules
x86_64 Testing nvidia-dkms 375.26-3 NVIDIA driver sources for linux
x86_64 Testing nvidia-340xx-dkms 340.101-6 NVIDIA driver sources for linux, 340xx legacy branch
x86_64 Testing nvidia-340xx 340.101-6 NVIDIA drivers for linux, 340xx legacy branch
x86_64 Testing linux-headers 4.9.1-1 Header files and scripts for building modules for Linux kernel
x86_64 Community-Testing virtualbox-guest-modules-arch 5.1.12-3 Virtualbox guest kernel modules for Arch Kernel
x86_64 Community-Testing acpi_call 1.1.0-53 A linux kernel module that enables calls to ACPI methods through /proc/acpi/call
x86_64 Community-Testing bbswitch-dkms 0.8-57 Kernel module allowing to switch dedicated graphics card on Optimus laptops
x86_64 Community-Testing vhba-module 20161009-4 Kernel module that emulates SCSI devices
x86_64 Community-Testing bbswitch 0.8-57 Kernel module allowing to switch dedicated graphics card on Optimus laptops
x86_64 Community-Testing r8168 8.043.01-4 A kernel module for Realtek 8168 network cards
x86_64 Community-Testing tp_smapi 0.42-7 Modules for ThinkPad's SMAPI functionality
x86_64 Community-Testing virtualbox-host-modules-arch 5.1.12-3 Virtualbox host kernel modules for Arch Kernel
x86_64 Community-Testing libsigrokdecode 0.4.1-1 Client software that supports various hardware logic analyzers, protocol decoders library
x86_64 Multilib-Testing lib32-libpulse 9.99.1-1 A featureful, general-purpose sound server (32-bit client libraries)
AUR
gerrit 2.13.5-1
adapta-gtk-theme 3.89.2.76-1
vasm 1.7g-1
dwm-cdown-git 0.r1680.5881d23-1
icecat 45.5.1-5
osvr-core-git 0.2.r2263.g8e0ce2e7-1
mikutter 3.5.1-1
latvijas-radio 20170109-1
firefox-developer-de 52.0a2_20170108-1
kde-servicemenus-pdf 0.6-6
tapclean 0.32-1
rust-nightly-bin 1.16.0_2017.01.08-1
openra-kang kang.fed9441-1
cypress 0.18.4-1
python-pyql-git 20161215-1
Thanks
#2005 OFFLINE   securitybreach
  • 24,208 posts
Posted 10 January 2017 - 07:39 PM
Updates for Monday, January 09, 2016
Any
any Community python-click 6.7-1 A simple wrapper around optparse for powerful command line utilities
any Community python2-click 6.7-1 A simple wrapper around optparse for powerful command line utilities
any Community python2-werkzeug 0.11.15-1 Swiss Army knife of Python web development
any Community python-werkzeug 0.11.15-1 Swiss Army knife of Python web development
any Community python-pycountry 17.1.8-1 ISO country, subdivision, language, currency and script definitions and their translations
any Community python2-pycountry 17.1.8-1 ISO country, subdivision, language, currency and script definitions and their translations
any Community android-udev 20170103-1 Udev rules to connect Android devices to your linux box
any Community eric-qt4-i18n-en 17.01-1 en language pack for Eric IDE
any Community eric-qt4-i18n-fr 17.01-1 fr language pack for Eric IDE
any Community eric-i18n-es 17.01-1 es language pack for Eric IDE
any Community eric-common-qt4 17.01-1 A full-featured Python and Ruby IDE in PyQt
any Community eric 17.01-1 A full-featured Python and Ruby IDE in PyQt
any Community eric-qt4-i18n-es 17.01-1 es language pack for Eric IDE
any Community python2-eric-qt4 17.01-1 A full-featured Python and Ruby IDE in PyQt
any Community eric-qt4-i18n-cs 17.01-1 cs language pack for Eric IDE
any Community eric-qt4-i18n-ru 17.01-1 ru language pack for Eric IDE
any Community eric-qt4-i18n-tr 17.01-1 tr language pack for Eric IDE
any Community eric-i18n-zh_cn 17.01-1 zh_CN language pack for Eric IDE
any Community eric-common 17.01-1 A full-featured Python and Ruby IDE in PyQt
any Community eric-i18n-pt 17.01-1 pt language pack for Eric IDE
any Community python2-eric 17.01-1 A full-featured Python and Ruby IDE in PyQt
any Community eric-qt4 17.01-1 A full-featured Python and Ruby IDE in PyQt
any Community eric-i18n-cs 17.01-1 cs language pack for Eric IDE
any Community eric-qt4-i18n-it 17.01-1 it language pack for Eric IDE
any Community eric-i18n-it 17.01-1 it language pack for Eric IDE
any Community eric-i18n-ru 17.01-1 ru language pack for Eric IDE
any Community eric-qt4-i18n-pt 17.01-1 pt language pack for Eric IDE
any Community eric-i18n-fr 17.01-1 fr language pack for Eric IDE
any Community eric-i18n-de 17.01-1 de language pack for Eric IDE
any Community eric-i18n-en 17.01-1 en language pack for Eric IDE
any Community eric-i18n-tr 17.01-1 tr language pack for Eric IDE
any Community eric-qt4-i18n-zh_cn 17.01-1 zh_CN language pack for Eric IDE
any Community eric-qt4-i18n-de 17.01-1 de language pack for Eric IDE
any Community jenkins 2.40-1 Extendable continuous integration server (latest)
any Community python2-more-itertools 2.5.0-1 More routines for operating on iterables, beyond itertools
any Community python-more-itertools 2.5.0-1 More routines for operating on iterables, beyond itertools
any Extra perl-try-tiny 0.28-1 Minimal try/catch with proper localization of $@
i686
i686 Core linux-lts 4.4.41-1 The Linux-lts kernel and modules
i686 Core linux-lts-docs 4.4.41-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
i686 Core linux-lts-headers 4.4.41-1 Header files and scripts for building modules for Linux-lts kernel
i686 Core m4 1.4.18-1 The GNU macro processor
i686 Core flex 2.6.3-1 A tool for generating text-scanning programs
i686 Core mpfr 3.1.5.p2-1 Multiple-precision floating-point library
i686 Community rust-racer 2.0.4-1 Code completion for Rust
i686 Community gitlab 8.15.3-1 Project management and code hosting application
i686 Community audaspace 1.3.0-1 A high level and feature rich audio library written in C++ with language bindings
i686 Community texstudio 2.12.0-1 Integrated writing environment for creating LaTeX documents
i686 Community geth 1.5.6-1 Official golang implementation of the Ethereum protocol
i686 Community parity 1.4.9-1 Fast, light, robust Ethereum implementation
i686 Community libsigrokdecode 0.4.1-1 Client software that supports various hardware logic analyzers, protocol decoders library
i686 Community thrift 0.10.0-1 Scalable cross-language services framework for IPC/RPC
i686 Community android-tools 7.1.1_r13-1 Android platform tools
i686 Community botan 2.0.0-1 Crypto library written in C++
i686 Community python-cchardet 1.1.2-1 Universal encoding detector faster than chardet.
i686 Community python2-cchardet 1.1.2-1 Universal encoding detector faster than chardet.
i686 Community linux-grsec-docs 1:4.8.17.r201701090823-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
i686 Community linux-grsec 1:4.8.17.r201701090823-1 The Linux kernel and modules with grsecurity/PaX patches
i686 Community linux-grsec-headers 1:4.8.17.r201701090823-1 Header files and scripts for building modules for Linux-grsec kernel
i686 Community spectrwm 3.0.2-2 A minimalistic automatic tiling window manager that tries to stay out of the way.
i686 Community firejail 0.9.44.4-1 Linux namespaces sandbox program
i686 Community icoutils 0.31.1-1 Extracts and converts images in MS Windows® icon and cursor files.
i686 Community julius 4.4.2.1-1 A high-performance, two-pass large vocabulary continuous speech recognition decoder software
i686 Community haskell-foldl 1.2.3-1 Composable, streaming, and efficient left folds
i686 Community haskell-turtle 1.3.0-8 Shell programming, Haskell-style
i686 Community gtkwave 3.3.79-1 A wave viewer which reads LXT, LXT2, VZT, GHW and VCD/EVCD files
i686 Extra digikam 5.4.0-1 Digital photo management application for KDE
i686 Extra kipi-plugins 5.4.0-1 A collection of plugins extending the KDE graphics and image applications as digiKam
i686 Extra speech-dispatcher 0.8.6-1 High-level device independent layer for speech synthesis interface
i686 Extra nghttp2 1.18.1-1 Framing layer of HTTP/2 is implemented as a reusable C library
i686 Extra python-lxml 3.7.2-1 Python3 binding for the libxml2 and libxslt libraries
i686 Extra python-lxml-docs 3.7.2-1 Python binding for the libxml2 and libxslt libraries (docs)
i686 Extra python2-lxml 3.7.2-1 Python2 binding for the libxml2 and libxslt libraries
i686 Testing xf86-video-intel 1:2.99.917+747+g028c946d-1 X.org Intel i810/i830/i915/945G/G965+ video drivers
i686 Testing xf86-video-ati 1:7.8.99.r16.gea30d856-1 X.org ati video driver
i686 Testing tslib 1.3-1 Touchscreen Access Library
i686 Testing qt5-base 5.7.1-2 A cross-platform application and UI framework
i686 Testing gnutls 3.5.8-1 A library which provides a secure layer over a reliable transport layer
i686 Testing systemd-sysvcompat 232-7 sysvinit compat for systemd
i686 Testing systemd 232-7 system and service manager
i686 Testing libsystemd 232-7 systemd client libraries
i686 Testing grub 1:2.02.beta3-6 GNU GRand Unified Bootloader (2)
i686 Testing gcc 6.3.1-1 The GNU Compiler Collection - C and C++ frontends
i686 Testing gcc-fortran 6.3.1-1 Fortran front-end for GCC
i686 Testing gcc-go 6.3.1-1 Go front-end for GCC
i686 Testing gcc-libs 6.3.1-1 Runtime libraries shipped by GCC
i686 Testing gcc-objc 6.3.1-1 Objective-C front-end for GCC
i686 Testing gcc-ada 6.3.1-1 Ada front-end for GCC (GNAT)
i686 Community-Testing rofi 1.3.1-1 Popup window switcher roughly based on superswitcher, requiring only xlib and xft
x86_64
x86_64 Core linux-lts 4.4.41-1 The Linux-lts kernel and modules
x86_64 Core linux-lts-docs 4.4.41-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
x86_64 Core linux-lts-headers 4.4.41-1 Header files and scripts for building modules for Linux-lts kernel
x86_64 Core m4 1.4.18-1 The GNU macro processor
x86_64 Core flex 2.6.3-1 A tool for generating text-scanning programs
x86_64 Core mpfr 3.1.5.p2-1 Multiple-precision floating-point library
x86_64 Community rust-racer 2.0.4-1 Code completion for Rust
x86_64 Community gitlab 8.15.3-1 Project management and code hosting application
x86_64 Community audaspace 1.3.0-1 A high level and feature rich audio library written in C++ with language bindings
x86_64 Community texstudio 2.12.0-1 Integrated writing environment for creating LaTeX documents
x86_64 Community geth 1.5.6-1 Official golang implementation of the Ethereum protocol
x86_64 Community parity 1.4.9-1 Fast, light, robust Ethereum implementation
x86_64 Community libsigrokdecode 0.4.1-1 Client software that supports various hardware logic analyzers, protocol decoders library
x86_64 Community thrift 0.10.0-1 Scalable cross-language services framework for IPC/RPC
x86_64 Community android-tools 7.1.1_r13-1 Android platform tools
x86_64 Community botan 2.0.0-1 Crypto library written in C++
x86_64 Community python-cchardet 1.1.2-1 Universal encoding detector faster than chardet.
x86_64 Community rkt 1.22.0-1 App container runtime
x86_64 Community python2-cchardet 1.1.2-1 Universal encoding detector faster than chardet.
x86_64 Community linux-grsec-docs 1:4.8.17.r201701090823-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
x86_64 Community linux-grsec 1:4.8.17.r201701090823-1 The Linux kernel and modules with grsecurity/PaX patches
x86_64 Community linux-grsec-headers 1:4.8.17.r201701090823-1 Header files and scripts for building modules for Linux-grsec kernel
x86_64 Community spectrwm 3.0.2-2 A minimalistic automatic tiling window manager that tries to stay out of the way.
x86_64 Community firejail 0.9.44.4-1 Linux namespaces sandbox program
x86_64 Community icoutils 0.31.1-1 Extracts and converts images in MS Windows® icon and cursor files.
x86_64 Community julius 4.4.2.1-1 A high-performance, two-pass large vocabulary continuous speech recognition decoder software
x86_64 Community haskell-foldl 1.2.3-1 Composable, streaming, and efficient left folds
x86_64 Community haskell-turtle 1.3.0-8 Shell programming, Haskell-style
x86_64 Community gtkwave 3.3.79-1 A wave viewer which reads LXT, LXT2, VZT, GHW and VCD/EVCD files
x86_64 Extra digikam 5.4.0-1 Digital photo management application for KDE
x86_64 Extra kipi-plugins 5.4.0-1 A collection of plugins extending the KDE graphics and image applications as digiKam
x86_64 Extra speech-dispatcher 0.8.6-1 High-level device independent layer for speech synthesis interface
x86_64 Extra nghttp2 1.18.1-1 Framing layer of HTTP/2 is implemented as a reusable C library
x86_64 Extra python-lxml 3.7.2-1 Python3 binding for the libxml2 and libxslt libraries
x86_64 Extra python-lxml-docs 3.7.2-1 Python binding for the libxml2 and libxslt libraries (docs)
x86_64 Extra python2-lxml 3.7.2-1 Python2 binding for the libxml2 and libxslt libraries
x86_64 Testing xf86-video-intel 1:2.99.917+747+g028c946d-1 X.org Intel i810/i830/i915/945G/G965+ video drivers
x86_64 Testing xf86-video-ati 1:7.8.99.r16.gea30d856-1 X.org ati video driver
x86_64 Testing tslib 1.3-1 Touchscreen Access Library
x86_64 Testing qt5-base 5.7.1-2 A cross-platform application and UI framework
x86_64 Testing gnutls 3.5.8-1 A library which provides a secure layer over a reliable transport layer
x86_64 Testing systemd-sysvcompat 232-7 sysvinit compat for systemd
x86_64 Testing systemd 232-7 system and service manager
x86_64 Testing libsystemd 232-7 systemd client libraries
x86_64 Testing grub 1:2.02.beta3-6 GNU GRand Unified Bootloader (2)
x86_64 Testing gcc 6.3.1-1 The GNU Compiler Collection - C and C++ frontends
x86_64 Testing gcc-fortran 6.3.1-1 Fortran front-end for GCC
x86_64 Testing gcc-go 6.3.1-1 Go front-end for GCC
x86_64 Testing gcc-libs 6.3.1-1 Runtime libraries shipped by GCC
x86_64 Testing gcc-objc 6.3.1-1 Objective-C front-end for GCC
x86_64 Testing gcc-ada 6.3.1-1 Ada front-end for GCC (GNAT)
x86_64 Community-Testing rofi 1.3.1-1 Popup window switcher roughly based on superswitcher, requiring only xlib and xft
x86_64 Community-Testing arduino-ctags 5.8_arduino11-1 A mix of ctags and anjuta-tags for the perfect C++ ctags
AUR
osdlyrics-git 0.4.99.r825.840afef-1
recipes-git 0.6.0+17+g91e79b3-1
k780-fnkeyctl 1-1
mpd-server-minimal 0.20-1
zoiper 3.3-2
exfalso 3.8.0-1
gtkd 3.5.1-1
bubblewrap-git v0.1.5.r2.g9d368ee-1
jackett 0.7.868-1
eclipse-pydev 5.1.1-2
eclipse-emf 2.12.0-2
i3-gnome-git 5.1.r2.g55ea56b-2
radarr 0.2.0.61-1
wxmaxima-git r3992.c5ea7292-1
vicare-scheme-git 20170110.55c8a4a5-1
Thanks
#2006 OFFLINE   securitybreach
  • 24,208 posts
Posted 11 January 2017 - 08:22 PM
Updates for Tuesday, January 10, 2016
Any
any Community ruby-celluloid-extras 0.20.5-3 Classes to support examples, benchmarks, or add special functionality
any Community ruby-celluloid-essentials 0.20.5-4 Internally used tools, and superstructural dependencies of Celluloid
any Community ruby-paint 2.0.0-3 Ruby paint manages terminal colors and effects
any Community ruby-dbus 0.11.0-3 Ruby module for interaction with D-Bus
any Community ruby-treetop 1.6.8-2 A Ruby-based text parsing and interpretation DSL
any Community ruby-ronn 0.7.3-5 Manual page formatter that generates man pages from markdown
any Community ruby-trollop 2.1.2-4 Commandline option parser for Ruby that just gets out of your way
any Community ruby-packetfu 1.1.11-3 Library for reading and writing packets to an interface or to a libpcap-formatted file
any Community ruby-em-proxy 0.1.9-3 EventMachine Proxy DSL for writing high-performance transparent / intercepting proxies
any Community ruby-net-dns 0.8.0-3 Pure Ruby DNS library, with a clean OO interface and an extensible API
any Community ruby-rspec 3.5.0-2 RSpec meta-gem that depends on the other components
any Community ruby-celluloid 0.17.3-3 Celluloid provides a simple and natural way to build fault-tolerant concurrent programs in Ruby
any Community ruby-diff-lcs 1.2.5-6 Diff::LCS computes the difference between two Enumerable sequences using the McIlroy-Hunt longest common subsequence (LCS) algorithm
any Community ruby-mail 2.6.4-2 A really Ruby Mail handler
any Community ruby-rspec-mocks 3.5.0-2 RSpecs 'test double' framework, with support for stubbing and mocking
any Community taskjuggler3 3.5.0-13 Project Management Software 2016-05-01
any Community ruby-rubydns 1.0.3.af7984c-4 High-performance asynchronous DNS server and resolver for Ruby
any Community ruby-celluloid-supervision 0.20.6-3 Simple finite state machines with integrated Celluloid timeout support
any Community ruby-rainbow 2.2.1-2 Rainbow is extension to ruby's String class adding support for colorizing text on ANSI terminal
any Community ruby-rspec-expectations 3.5.0-2 Provides a readable API to express expected outcomes of a code example
any Community ruby-mime-types-data 3.2016.0521-2 provides a registry for information about MIME media type definitions
any Community ruby-bundler 1.13.7-2 Manages an application's dependencies through its entire life, across many machines, systematically and repeatably.
any Community lolcat 42.24.0-2 Okay, no unicorns. But rainbows!!
any Community ruby-rack 2.0.1-2 Rack provides minimal, modular and adaptable interface for developing web applications in Ruby
any Community ruby-term-ansicolor 1.4.0-2 A ruby library that colors strings using ANSI escape sequences
any Community ruby-celluloid-fsm 0.20.5-3 Simple finite state machines with integrated Celluloid timeout support
any Community ruby-mime-types 3.1-2 MIME Content-Type database
any Community ruby-celluloid-io 0.17.3-3 Evented IO for Celluloid actors
any Community ruby-tins 1.13.0-2 All the stuff that is not good/big enough for a real library
any Community ruby-colorize 0.8.1-3 Ruby string class extension to set color, background and text effect using ANSI escape sequences
any Community ruby-polyglot 0.3.5-4 Allows custom language loaders to be hooked into require
any Community ruby-celluloid-pool 0.20.5-3 Implementation of an actor pool, based on the Celluloid concurrent object framework
any Community ruby-timers 4.1.2-3 Schedule procs to run after a certain time, or at periodic intervals, using any API that accepts a timeout
any Community ruby-rspec-core 3.5.4-2 RSpec runner and formatters
any Community ruby-pkg-config 1.1.7-2 Implementation of pkg-config in ruby
any Community ruby-rspec-support 3.5.0-2 Common code needed by the other RSpec gems. Not intended for direct use
any Community ruby-mustache 1.0.3-2 Mustache is a framework-agnostic way to render logic-free views.
any Community ruby-celluloid-dns 0.17.3-3 Simple finite state machines with integrated Celluloid timeout support
any Community esptool 1.3-1 A cute Python utility to communicate with the ROM bootloader in Espressif ESP8266
any Community beets 1.4.3-2 Flexible music library manager and tagger
any Community menumaker 0.99.10-1 Heuristics-driven menu generator for Deskmenu, FluxBox, IceWM, OpenBox, WindowMaker and XFCE
any Community youtube-dl 2017.01.10-1 A small command-line program to download videos from YouTube.com and a few more sites
any Community lollypop 0.9.224-1 Music player for GNOME
any Community python-munkres 1.0.9-1 Munkres algorithm for Python
any Community python-musicbrainzngs 0.6-2 Python bindings for Musicbrainz' NGS webservice
any Community python2-munkres 1.0.9-1 Munkres algorithm for Python
any Community python2-musicbrainzngs 0.6-2 Python bindings for Musicbrainz' NGS webservice
any Community perlbrew 0.78-1 Manage perl installations in your $HOME
any Community python-docs 3.6.0-1 Set of HTML documentation for python
any Community python-unidecode 0.04.20-1 ASCII transliterations of Unicode text
any Community python2-unidecode 0.04.20-1 ASCII transliterations of Unicode text
any Community asar 0.13.0-1 Creating Electron app packages
any Community reflector 2017-2 A Python 3 module and script to retrieve and filter the latest Pacman mirror list.
any Extra asciidoctor 1.5.5-3 An implementation of AsciiDoc in Ruby
i686
i686 Community kio-gdrive 1.0.5-1 KIO Slave to access Google Drive
i686 Extra ruby-docs 2.4.0-1 Documentation files for ruby
i686 Extra kross-interpreters 16.12.0-2 Language interpreters to enable in-process scripting with Kross
i686 Extra subversion 1.9.5-2 A Modern Concurrent Version Control System
i686 Extra weechat 1.6-3 Fast, light and extensible IRC client (curses UI)
i686 Extra ruby 2.4.0-1 An object-oriented language for quick and easy programming
i686 Extra rrdtool 1.6.0-2 Data logging and graphing application
i686 Community uwsgi-plugin-python 2.0.14-5 Plugin for Python support
i686 Community ruby-gdk_pixbuf2 3.1.0-2 Ruby/GdkPixbuf2 is a Ruby binding of GdkPixbuf-2.x.
i686 Community notmuch-mutt 0.23.3-4 The mail indexer
i686 Community ruby-pango 3.1.0-2 Ruby/Pango is a Ruby binding of pango-1.x.
i686 Community uwsgi-plugin-mono 2.0.14-5 Plugin for mono support
i686 Community ruby-gtk2 3.1.0-2 Ruby/GTK2 is a Ruby binding of GTK+-2.x.
i686 Community uwsgi-plugin-webdav 2.0.14-5 Plugin for webdav support
i686 Community uwsgi-plugin-php 2.0.14-5 Plugin for PHP support
i686 Community mod_proxy_uwsgi 2.0.14-5 Apache uWSGI proxy module
i686 Community ruby-pcaprub 0.12.4-3 Consistent interface to libpcap packet capture library
i686 Community ruby-atk 3.1.0-2 Ruby/ATK is a Ruby binding of ATK-1.0.x.
i686 Community uwsgi-plugin-lua51 2.0.14-5 Plugin for Lua support
i686 Community ruby-glib2 3.1.0-2 Ruby/GLib2 is a Ruby binding of GLib-2.x.
i686 Community metasploit 4.13.12-2 Advanced open-source platform for developing, testing, and using exploit code
i686 Community wpscan 1:2.9.2-2 Black box WordPress vulnerability scanner
i686 Community notmuch 0.23.3-4 Notmuch is not much of an email program
i686 Community uwsgi-plugin-jvm 2.0.14-5 Plugin for Jvm support
i686 Community marisa 0.2.4-8 Static and space-efficient trie data structure library
i686 Community ruby-network_interface 0.0.1-5 Library to get network interface information
i686 Community ruby-shadow 2.5.0-2 Shadow password module
i686 Community uwsgi-plugin-rack 2.0.14-5 Ruby rack plugin
i686 Community ruby-cairo 1.15.4-2 Ruby bindings for cairo
i686 Community perl-marisa 0.2.4-8 Perl language binding for marisa
i686 Community uwsgi-plugin-pypy 2.0.14-5 Plugin for PyPy support
i686 Community notmuch-vim 0.23.3-4 Vim plugins for notmuch
i686 Community uwsgi-plugin-cgi 2.0.14-5 CGI plugin
i686 Community clearsilver 0.10.5-21 clearsilver is a fast, powerful, and language-neutral HTML template system
i686 Community ruby-nio4r 2.0.0-3 Abstract, cross-platform stateful I/O selector API for Ruby
i686 Community uwsgi-plugin-psgi 2.0.14-5 Perl psgi plugin
i686 Community ruby-pg 0.19.0-2 Pg is the Ruby interface to the Postgresql RDBMS
i686 Community ruby-eventmachine 1.2.1-2 EventMachine: fast, simple event-processing library
i686 Community uwsgi-plugin-python2 2.0.14-5 Plugin for Python2 support
i686 Community passenger 5.0.30-2 mod_rails passenger
i686 Community python2-marisa 0.2.4-8 Python 2.x language binding for marisa
i686 Community uwsgi 2.0.14-5 A fast, self-healing and developer/sysadmin-friendly application container server coded in pure C
i686 Community ruby-iconv 1.0.4-5 Wrapper library for iconv
i686 Community ruby-hitimes 1.2.4-3 Fast, high resolution timer library for recording performance metrics
i686 Community notmuch-runtime 0.23.3-4 Runtime for notmuch and notmuch-mutt
i686 Community ruby-gobject-introspection 3.1.0-2 Ruby/GObjectIntrospection is a Ruby binding of GObjectIntrospection.
i686 Community ruby-marisa 0.2.4-8 Ruby language binding for marisa
i686 Community ruby-hpricot 0.8.6-5 A swift, liberal HTML parser with a fantastic library
i686 Community xmms2 0.8DrO_o.919.gece0baf0-7 X-platform Music Multiplexing System 2
i686 Community ruby-rdiscount 2.2.0.1-2 Fast Implementation of Gruber's Markdown in C
i686 Community ruby-ncurses 1.3.1-10 Module for interactive text console applications (ncurses)
i686 Community ruby-gio2 3.1.0-2 Ruby/GIO2 is a Ruby binding of gio-2.x.
i686 Community repose 7.1-1 Arch Linux repo building tool
i686 Testing xorg-server-common 1.19.0-6 Xorg server common files
i686 Testing xorg-server 1.19.0-6 Xorg X server
i686 Testing xorg-server-xvfb 1.19.0-6 Virtual framebuffer X server
i686 Testing xorg-server-xwayland 1.19.0-6 run X clients under wayland
i686 Testing xorg-server-xnest 1.19.0-6 A nested X server that runs as an X application
i686 Testing xorg-server-xephyr 1.19.0-6 A nested X server that runs as an X application
i686 Testing xorg-server-devel 1.19.0-6 Development files for the X.Org X server
i686 Testing xorg-server-xdmx 1.19.0-6 Distributed Multihead X Server and utilities
i686 Extra gnome-online-accounts 3.22.4-1 Single sign-on framework for GNOME
i686 Community yaz 5.20.0-1 A toolkit supporting the development of Z39.50/SRW/SRU clients and servers
i686 Community-Testing virtualbox-guest-modules-arch 5.1.12-4 Virtualbox guest kernel modules for Arch Kernel
i686 Community-Testing acpi_call 1.1.0-54 A linux kernel module that enables calls to ACPI methods through /proc/acpi/call
i686 Community-Testing bbswitch-dkms 0.8-58 Kernel module allowing to switch dedicated graphics card on Optimus laptops
i686 Community-Testing virtualbox-host-modules-arch 5.1.12-4 Virtualbox host kernel modules for Arch Kernel
i686 Community-Testing vhba-module 20161009-5 Kernel module that emulates SCSI devices
i686 Community-Testing bbswitch 0.8-58 Kernel module allowing to switch dedicated graphics card on Optimus laptops
i686 Community-Testing r8168 8.043.01-5 A kernel module for Realtek 8168 network cards
i686 Community-Testing tp_smapi 0.42-8 Modules for ThinkPad's SMAPI functionality
i686 Testing nvidia 375.26-4 NVIDIA drivers for linux
i686 Testing linux 4.9.2-1 The Linux kernel and modules
i686 Testing linux-docs 4.9.2-1 Kernel hackers manual - HTML documentation that comes with the Linux kernel
i686 Testing nvidia-dkms 375.26-4 NVIDIA driver sources for linux
i686 Testing nvidia-340xx 340.101-7 NVIDIA drivers for linux, 340xx legacy branch
i686 Testing linux-headers 4.9.2-1 Header files and scripts for building modules for Linux kernel
i686 Testing nvidia-340xx-dkms 340.101-7 NVIDIA driver sources for linux, 340xx legacy branch
i686 Community renpy 6.99.12.2-1 The Ren'Py Visual Novel Engine
i686 Community renpy-demos 6.99.12.2-1 The Ren'Py Visual Novel Engine
i686 Community ginac 1.7.2-1 C++ library for symbolic calculations
i686 Extra libbluray 0.9.3.r84.05c9fdec-1 Library to access Blu-Ray disks for video playback
i686 Community python2-pygame-sdl2 1:2.1.0.r326.0732c44-1 Reimplementation of portions of the pygame API using SDL2
i686 Community syncthing-relaysrv 0.14.19-1 Relay server for Syncthing
i686 Community syncthing 0.14.19-1 Open Source Continuous Replication / Cluster Synchronization Thing
i686 Community libgexiv2 0.10.4-4 GObject-based wrapper around the Exiv2 library
i686 Community-Testing msgpack-c 2.1.0-1 An efficient object serialization library
i686 Community python-jellyfish 0.5.6-1 A python library for doing approximate and phonetic matching of strings
i686 Community python2-jellyfish 0.5.6-1 A python library for doing approximate and phonetic matching of strings
i686 Community leptonica 1.74-1 Software that is broadly useful for image processing and image analysis applications
i686 Community opensips 2.2.2-1 An Open Source SIP Server able to act as a SIP proxy, registrar, location server, redirect server ...
i686 Community wine-staging 2.0rc4-1 A compatibility layer for running Windows programs - Staging branch
i686 Extra plasma-nm 5.8.5-2 Plasma applet written in QML for managing network connections
i686 Community haskell-hopenpgp 2.5.5-21 Native Haskell implementation of OpenPGP (RFC4880)
i686 Community haskell-pandoc-crossref 0.2.4.1-23 Pandoc filter for cross-references (docs and libraries)
i686 Community haskell-postgresql-binary 0.9.1.1-12 Encoders and decoders for the PostgreSQL's binary format
i686 Community haskell-path 0.5.11-5 Path
i686 Community haskell-warp 3.2.9-8 A fast, light-weight web server for WAI applications.
i686 Community haskell-xml-hamlet 0.4.0.12-17 Hamlet-style quasiquoter for XML content
i686 Community haskell-binary-tagged 0.1.4.2-5 Tagged binary serialisation.
i686 Community haskell-yaml 0.8.21.1-8 Support for parsing and rendering YAML documents.
i686 Community haskell-yesod-auth 1.4.15-14 Authentication for Yesod.
i686 Community haskell-yesod-default 1.2.0-94 Default config and main functions for your yesod application (deprecated)
i686 Community stylish-haskell 0.6.5.0-9 Haskell code prettifier
i686 Community hoogle 5.0.8-3 Haskell API Search
i686 Community haskell-http-api-data 0.3.3-4 Converting to/from HTTP API data like URL pieces, headers and query parameters.
i686 Community haskell-yesod-persistent 1.4.1.1-9 Some helpers for using Persistent from Yesod.
i686 Community haskell-yesod-core 1.4.30-10 Creation of type-safe, RESTful web applications.
i686 Community git-annex 6.20170101-6 Manage files with git, without checking their contents into git
i686 Community haskell-wai-app-static 3.1.6.1-22 WAI application for static serving
i686 Community haskell-doctemplates 0.1.0.2-7 Pandoc-style document templates
i686 Community haskell-aeson-compat 0.3.6-5 Compatibility layer for aeson
i686 Community pandoc-crossref 0.2.4.1-23 Pandoc filter for cross-references
i686 Community haskell-sourcemap 0.1.6-14 Implementation of source maps as proposed by Google and Mozilla.
i686 Community haskell-texmath 0.9-5 Conversion between formats used to represent mathematics.
i686 Community haskell-yesod-static 1.5.1.1-24 Static file serving subsite for Yesod Web Framework.
i686 Community haskell-pandoc-citeproc 0.10.3-10 Supports using pandoc with citeproc (docs and libraries)
i686 Community haskell-wai-extra 3.0.19-10 Provides some basic WAI handlers and middleware.
i686 Community haskell-hpack 0.15.0-15 An alternative format for Haskell packages
i686 Community haskell-persistent-template 2.5.1.6-23 Type-safe, non-relational, multi-backend persistence
i686 Community haskell-http-conduit 2.2.3-20 HTTP client package with conduit interface and HTTPS support
i686 Community haskell-authenticate 1.3.3.2-37 Authentication methods for Haskell web applications.
i686 Community haskell-aws 0.15-7 Amazon Web Services (AWS) for Haskell
i686 Community haskell-aeson-pretty 0.8.2-5 JSON pretty-printing library and command-line tool.
i686 Community haskell-descriptive 0.9.4-33 Self-describing consumers/parsers; forms, cmd-line args, JSON, etc.
i686 Community haskell-dav 1.3.1-41 RFC 4918 WebDAV support
i686 Community pandoc-citeproc 0.10.3-10 Supports using pandoc with citeproc
i686 Community haskell-pandoc-types 1.17.0.4-5 Types for representing a structured document
i686 Community haskell-yesod-form 1.4.9-26 Form handling support for Yesod Web Framework
i686 Community haskell-http2 1.6.2-8 HTTP/2.0 library including frames and HPACK
i686 Community haskell-persistent-sqlite 2.6-22 Backend for the persistent library using sqlite3
i686 Community haskell-bower-json 1.0.0.1-3 Read bower.json from Haskell
i686 Community haskell-yesod 1.4.3.1-34 Creation of type-safe, RESTful web applications.
i686 Community hopenpgp-tools 0.19.4-27 hOpenPGP-based command-line tools
i686 Community haskell-path-io 1.2.2-2 Interface to ‘directory’ package for users of ‘path’
i686 Community haskell-feed 0.3.12.0-2 Interfacing with RSS (v 0.9x, 2.x, 1.0) + Atom feeds.
i686 Community haskell-persistent 2.6-22 Type-safe, multi-backend data serialization
i686 Community haskell-cheapskate 0.1.0.5-36 Experimental markdown processor.
i686 Community haskell-warp-tls 3.2.2-30 HTTP over TLS support for Warp via the TLS package
i686 Community haskell-pandoc 1.19.1-10 Conversion between markup formats (docs and libraries)
i686 Community haskell-esqueleto 2.4.3-55 Type-safe EDSL for SQL queries on persistent backends.
i686 Community haskell-aeson-better-errors 0.9.1.0-5 Better error messages when decoding JSON values.
i686 Community haskell-time-locale-compat 0.1.1.3-1 Compatibility of TimeLocale between old-locale and time-1.5
i686 Community hindent 5.2.2-2 Extensible Haskell pretty printer
i686 Community pandoc 1.19.1-10 Conversion between markup formats
i686 Community haskell-shakespeare 2.0.12.1-3 A toolkit for making compile-time interpolated templates
i686 Community haskell-aeson 1.0.2.1-4 A JSON parsing and encoding library optimized for ease of use and high performance.
i686 Community qtox 1.7.1-3 Powerful Tox client written in C++/Qt that follows the Tox design guidelines
i686 Community toxcore 1:0.1.3-1 Secure, configuration-free, P2P Skype replacement backend
i686 Community haskell-turtle1.2 1.2.8-1 Shell programming, Haskell-style (legacy 1.2 version)
i686 Community haskell-monoid-subclasses 0.4.3.1-1 Subclasses of Monoid
i686 Community haskell-incremental-parser 0.2.5-2 Generic parser library capable of providing partial results from partial input.
i686 Community neovim 0.1.7-2 Fork of Vim aiming to improve user experience, plugins, and GUIs
i686 Community scummvm 1.9.0-2 A 'virtual machine' for several classic graphical point-and-click adventure games.
i686 Extra mpd 0.20.1-1 Flexible, powerful, server-side application for playing music
i686 Testing linux-zen 4.9.2-1 The Linux-zen kernel and modules
i686 Testing linux-zen-headers 4.9.2-1 Header files and scripts for building modules for Linux-zen kernel
i686 Testing linux-zen-docs 4.9.2-1 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
x86_64
x86_64 Community kio-gdrive 1.0.5-1 KIO Slave to access Google Drive
x86_64 Community uwsgi-plugin-python 2.0.14-5 Plugin for Python support
x86_64 Community ruby-gdk_pixbuf2 3.1.0-2 Ruby/GdkPixbuf2 is a Ruby binding of GdkPixbuf-2.x.
x86_64 Community notmuch-mutt 0.23.3-4 The mail indexer
x86_64 Community ruby-pango 3.1.0-2 Ruby/Pango is a Ruby binding of pango-1.x.
x86_64 Community uwsgi-plugin-mono 2.0.14-5 Plugin for mono support
x86_64 Community ruby-gtk2 3.1.0-2 Ruby/GTK2 is a Ruby binding of GTK+-2.x.
x86_64 Community uwsgi-plugin-webdav 2.0.14-5 Plugin for webdav support
x86_64 Community uwsgi-plugin-php 2.0.14-5 Plugin for PHP support
x86_64 Community mod_proxy_uwsgi 2.0.14-5 Apache uWSGI proxy module
x86_64 Community ruby-pcaprub 0.12.4-3 Consistent interface to libpcap packet capture library
x86_64 Community ruby-atk 3.1.0-2 Ruby/ATK is a Ruby binding of ATK-1.0.x.
x86_64 Community uwsgi-plugin-lua51 2.0.14-5 Plugin for Lua support
x86_64 Community ruby-glib2 3.1.0-2 Ruby/GLib2 is a Ruby binding of GLib-2.x.
x86_64 Community metasploit 4.13.12-2 Advanced open-source platform for developing, testing, and using exploit code
x86_64 Community wpscan 1:2.9.2-2 Black box WordPress vulnerability scanner
x86_64 Community notmuch 0.23.3-4 Notmuch is not much of an email program
x86_64 Community uwsgi-plugin-jvm 2.0.14-5 Plugin for Jvm support
x86_64 Community marisa 0.2.4-8 Static and space-efficient trie data structure library
x86_64 Community ruby-network_interface 0.0.1-5 Library to get network interface information
x86_64 Community ruby-shadow 2.5.0-2 Shadow password module
x86_64 Community uwsgi-plugin-rack 2.0.14-5 Ruby rack plugin
x86_64 Community ruby-cairo 1.15.4-2 Ruby bindings for cairo
x86_64 Community perl-marisa 0.2.4-8 Perl language binding for marisa
x86_64 Community uwsgi-plugin-pypy 2.0.14-5 Plugin for PyPy support
x86_64 Community notmuch-vim 0.23.3-4 Vim plugins for notmuch
x86_64 Community uwsgi-plugin-cgi 2.0.14-5 CGI plugin
x86_64 Community clearsilver 0.10.5-21 clearsilver is a fast, powerful, and language-neutral HTML template system
x86_64 Community ruby-nio4r 2.0.0-3 Abstract, cross-platform stateful I/O selector API for Ruby
x86_64 Community uwsgi-plugin-psgi 2.0.14-5 Perl psgi plugin
x86_64 Community ruby-pg 0.19.0-2 Pg is the Ruby interface to the Postgresql RDBMS
x86_64 Community ruby-eventmachine 1.2.1-2 EventMachine: fast, simple event-processing library
x86_64 Community uwsgi-plugin-python2 2.0.14-5 Plugin for Python2 support
x86_64 Community passenger 5.0.30-2 mod_rails passenger
x86_64 Community python2-marisa 0.2.4-8 Python 2.x language binding for marisa
x86_64 Community uwsgi 2.0.14-5 A fast, self-healing and developer/sysadmin-friendly application container server coded in pure C
x86_64 Community ruby-iconv 1.0.4-5 Wrapper library for iconv
x86_64 Community ruby-hitimes 1.2.4-3 Fast, high resolution timer library for recording performance metrics
x86_64 Community notmuch-runtime 0.23.3-4 Runtime for notmuch and notmuch-mutt
x86_64 Community ruby-gobject-introspection 3.1.0-2 Ruby/GObjectIntrospection is a Ruby binding of GObjectIntrospection.
x86_64 Community ruby-marisa 0.2.4-8 Ruby language binding for marisa
x86_64 Community ruby-hpricot 0.8.6-5 A swift, liberal HTML parser with a fantastic library
x86_64 Community xmms2 0.8DrO_o.919.gece0baf0-7 X-platform Music Multiplexing System 2
x86_64 Community ruby-rdiscount 2.2.0.1-2 Fast Implementation of Gruber's Markdown in C
x86_64 Community ruby-ncurses 1.3.1-10 Module for interactive text console applications (ncurses)
x86_64 Community ruby-gio2 3.1.0-2 Ruby/GIO2 is a Ruby binding of gio-2.x.
x86_64 Community repose 7.1-1 Arch Linux repo building tool
x86_64 Community yaz 5.20.0-1 A toolkit supporting the development of Z39.50/SRW/SRU clients and servers
x86_64 Community renpy 6.99.12.2-1 The Ren'Py Visual Novel Engine
x86_64 Community renpy-demos 6.99.12.2-1 The Ren'Py Visual Novel Engine
x86_64 Community ginac 1.7.2-1 C++ library for symbolic calculations
x86_64 Community python2-pygame-sdl2 1:2.1.0.r326.0732c44-1 Reimplementation of portions of the pygame API using SDL2
x86_64 Community syncthing-relaysrv 0.14.19-1 Relay server for Syncthing
x86_64 Community syncthing 0.14.19-1 Open Source Continuous Replication / Cluster Synchronization Thing
x86_64 Community libgexiv2 0.10.4-4 GObject-based wrapper around the Exiv2 library
x86_64 Community python-jellyfish 0.5.6-1 A python library for doing approximate and phonetic matching of strings
x86_64 Community python2-jellyfish 0.5.6-1 A python library for doing approximate and phonetic matching of strings
x86_64 Community leptonica 1.74-1 Software that is broadly useful for image processing and image analysis applications
x86_64 Community opensips 2.2.2-1 An Open Source SIP Server able to act as a SIP proxy, registrar, location server, redirect server ...
x86_64 Community haskell-hopenpgp 2.5.5-21 Native Haskell implementation of OpenPGP (RFC4880)
x86_64 Community haskell-pandoc-crossref 0.2.4.1-23 Pandoc filter for cross-references (docs and libraries)
x86_64 Community haskell-postgresql-binary 0.9.1.1-12 Encoders and decoders for the PostgreSQL's binary format
x86_64 Community haskell-path 0.5.11-5 Path
x86_64 Community haskell-warp 3.2.9-8 A fast, light-weight web server for WAI applications.
x86_64 Community haskell-xml-hamlet 0.4.0.12-17 Hamlet-style quasiquoter for XML content
x86_64 Community haskell-binary-tagged 0.1.4.2-5 Tagged binary serialisation.
x86_64 Community haskell-yaml 0.8.21.1-8 Support for parsing and rendering YAML documents.
x86_64 Community haskell-yesod-auth 1.4.15-14 Authentication for Yesod.
x86_64 Community haskell-yesod-default 1.2.0-94 Default config and main functions for your yesod application (deprecated)
x86_64 Community stylish-haskell 0.6.5.0-9 Haskell code prettifier
x86_64 Community hoogle 5.0.8-3 Haskell API Search
x86_64 Community haskell-http-api-data 0.3.3-4 Converting to/from HTTP API data like URL pieces, headers and query parameters.
x86_64 Community haskell-yesod-persistent 1.4.1.1-9 Some helpers for using Persistent from Yesod.
x86_64 Community haskell-yesod-core 1.4.30-10 Creation of type-safe, RESTful web applications.
x86_64 Community git-annex 6.20170101-6 Manage files with git, without checking their contents into git
x86_64 Community haskell-wai-app-static 3.1.6.1-22 WAI application for static serving
x86_64 Community haskell-doctemplates 0.1.0.2-7 Pandoc-style document templates
x86_64 Community haskell-aeson-compat 0.3.6-5 Compatibility layer for aeson
x86_64 Community pandoc-crossref 0.2.4.1-23 Pandoc filter for cross-references
x86_64 Community haskell-sourcemap 0.1.6-14 Implementation of source maps as proposed by Google and Mozilla.
x86_64 Community haskell-texmath 0.9-5 Conversion between formats used to represent mathematics.
x86_64 Community haskell-yesod-static 1.5.1.1-24 Static file serving subsite for Yesod Web Framework.
x86_64 Community haskell-pandoc-citeproc 0.10.3-10 Supports using pandoc with citeproc (docs and libraries)
x86_64 Community haskell-wai-extra 3.0.19-10 Provides some basic WAI handlers and middleware.
x86_64 Community haskell-hpack 0.15.0-15 An alternative format for Haskell packages
x86_64 Community haskell-persistent-template 2.5.1.6-23 Type-safe, non-relational, multi-backend persistence
x86_64 Community haskell-http-conduit 2.2.3-20 HTTP client package with conduit interface and HTTPS support
x86_64 Community haskell-authenticate 1.3.3.2-37 Authentication methods for Haskell web applications.
x86_64 Community haskell-aws 0.15-7 Amazon Web Services (AWS) for Haskell
x86_64 Community haskell-aeson-pretty 0.8.2-5 JSON pretty-printing library and command-line tool.
x86_64 Community haskell-descriptive 0.9.4-33 Self-describing consumers/parsers; forms, cmd-line args, JSON, etc.
x86_64 Community haskell-dav 1.3.1-41 RFC 4918 WebDAV support
x86_64 Community pandoc-citeproc 0.10.3-10 Supports using pandoc with citeproc
x86_64 Community haskell-pandoc-types 1.17.0.4-5 Types for representing a structured document
x86_64 Community haskell-yesod-form 1.4.9-26 Form handling support for Yesod Web Framework
x86_64 Community haskell-http2 1.6.2-8 HTTP/2.0 library including frames and HPACK
x86_64 Community haskell-persistent-sqlite 2.6-22 Backend for the persistent library using sqlite3
x86_64 Community haskell-bower-json 1.0.0.1-3 Read bower.json from Haskell
x86_64 Community haskell-yesod 1.4.3.1-34 Creation of type-safe, RESTful web applications.
x86_64 Community hopenpgp-tools 0.19.4-27 hOpenPGP-based command-line tools
x86_64 Community haskell-path-io 1.2.2-2 Interface to ‘directory’ package for users of ‘path’
x86_64 Community haskell-feed 0.3.12.0-2 Interfacing with RSS (v 0.9x, 2.x, 1.0) + Atom feeds.
x86_64 Community haskell-persistent 2.6-22 Type-safe, multi-backend data serialization
x86_64 Community haskell-cheapskate 0.1.0.5-36 Experimental markdown processor.
x86_64 Community haskell-warp-tls 3.2.2-30 HTTP over TLS support for Warp via the TLS package
x86_64 Community haskell-pandoc 1.19.1-10 Conversion between markup formats (docs and libraries)
x86_64 Community haskell-esqueleto 2.4.3-55 Type-safe EDSL for SQL queries on persistent backends.
x86_64 Community haskell-aeson-better-errors 0.9.1.0-5 Better error messages when decoding JSON values.
x86_64 Community haskell-time-locale-compat 0.1.1.3-1 Compatibility of TimeLocale between old-locale and time-1.5
x86_64 Community hindent 5.2.2-2 Extensible Haskell pretty printer
x86_64 Community pandoc 1.19.1-10 Conversion between markup formats
x86_64 Community haskell-shakespeare 2.0.12.1-3 A toolkit for making compile-time interpolated templates
x86_64 Community haskell-aeson 1.0.2.1-4 A JSON parsing and encoding library optimized for ease of use and high performance.
x86_64 Community cuda 8.0.44-3 NVIDIA's GPU programming toolkit
x86_64 Community qtox 1.7.1-3 Powerful Tox client written in C++/Qt that follows the Tox design guidelines
x86_64 Community toxcore 1:0.1.3-1 Secure, configuration-free, P2P Skype replacement backend
x86_64 Community haskell-turtle1.2 1.2.8-1 Shell programming, Haskell-style (legacy 1.2 version)
x86_64 Community haskell-monoid-subclasses 0.4.3.1-1 Subclasses of Monoid
x86_64 Community haskell-incremental-parser 0.2.5-2 Generic parser library capable of providing partial results from partial input.
x86_64 Community neovim 0.1.7-2 Fork of Vim aiming to improve user experience, plugins, and GUIs
x86_64 Community scummvm 1.9.0-2 A 'virtual machine' for several classic graphical point-and-click adventure games.
x86_64 Extra ruby-docs 2.4.0-1 Documentation files for ruby
x86_64 Extra kross-interpreters 16.12.0-2 Language interpreters to enable in-process scripting with Kross
x86_64 Extra subversion 1.9.5-2 A Modern Concurrent Version Control System
x86_64 Extra weechat 1.6-3 Fast, light and extensible IRC client (curses UI)
x86_64 Extra ruby 2.4.0-1 An object-oriented language for quick and easy programming
x86_64 Extra rrdtool 1.6.0-2 Data logging and graphing application
x86_64 Extra gnome-online-accounts 3.22.4-1 Single sign-on framework for GNOME
x86_64 Extra libbluray 0.9.3.r84.05c9fdec-1 Library to access Blu-Ray disks for video playback
x86_64 Extra mpd 0.20.1-1 Flexible, powerful, server-side application for playing music
x86_64 Extra plasma-nm 5.8.5-2 Plasma applet written in QML for managing network connections
x86_64 Multilib lib32-harfbuzz 1.4.1-1 OpenType text shaping engine (32-bit)
x86_64 Multilib lib32-harfbuzz-icu 1.4.1-1 OpenType text shaping engine (32-bit, ICU integration)
x86_64 Multilib lib32-freetype2 2.7.1-1 TrueType font rendering library (32-bit)
x86_64 Testing xorg-server-common 1.19.0-6 Xorg server common files
x86_64 Testing xorg-server 1.19.0-6 Xorg X server
x86_64 Testing xorg-server-xvfb 1.19.0-6 Virtual framebuffer X server
x86_64 Testing xorg-server-xwayland 1.19.0-6 run X clients under wayland
x86_64 Testing xorg-server-xnest 1.19.0-6 A nested X server that runs as an X application
x86_64 Testing xorg-server-xephyr 1.19.0-6 A nested X server that runs as an X application
x86_64 Testing xorg-server-devel 1.19.0-6 Development files for the X.Org X server
x86_64 Testing xorg-server-xdmx 1.19.0-6 Distributed Multihead X Server and utilities
x86_64 Testing linux-zen 4.9.2-1 The Linux-zen kernel and modules
x86_64 Testing linux-zen-headers 4.9.2-1 Header files and scripts for building modules for Linux-zen kernel
x86_64 Testing linux-zen-docs 4.9.2-1 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
x86_64 Testing nvidia 375.26-4 NVIDIA drivers for linux
x86_64 Testing linux 4.9.2-1 The Linux kernel and modules
x86_64 Testing linux-docs 4.9.2-1 Kernel hackers manual - HTML documentation that comes with the Linux kernel
x86_64 Testing nvidia-dkms 375.26-4 NVIDIA driver sources for linux
x86_64 Testing nvidia-340xx 340.101-7 NVIDIA drivers for linux, 340xx legacy branch
x86_64 Testing linux-headers 4.9.2-1 Header files and scripts for building modules for Linux kernel
x86_64 Testing nvidia-340xx-dkms 340.101-7 NVIDIA driver sources for linux, 340xx legacy branch
x86_64 Community-Testing bbswitch 0.8-58 Kernel module allowing to switch dedicated graphics card on Optimus laptops
x86_64 Community-Testing virtualbox-guest-modules-arch 5.1.12-4 Virtualbox guest kernel modules for Arch Kernel
x86_64 Community-Testing acpi_call 1.1.0-54 A linux kernel module that enables calls to ACPI methods through /proc/acpi/call
x86_64 Community-Testing bbswitch-dkms 0.8-58 Kernel module allowing to switch dedicated graphics card on Optimus laptops
x86_64 Community-Testing virtualbox-host-modules-arch 5.1.12-4 Virtualbox host kernel modules for Arch Kernel
x86_64 Community-Testing vhba-module 20161009-5 Kernel module that emulates SCSI devices
x86_64 Community-Testing r8168 8.043.01-5 A kernel module for Realtek 8168 network cards
x86_64 Community-Testing tp_smapi 0.42-8 Modules for ThinkPad's SMAPI functionality
x86_64 Community-Testing msgpack-c 2.1.0-1 An efficient object serialization library
x86_64 Multilib-Testing gcc-libs-multilib 6.3.1-1 Runtime libraries shipped by GCC for multilib
x86_64 Multilib-Testing gcc-go-multilib 6.3.1-1 Go front-end for GCC for multilib
x86_64 Multilib-Testing gcc-fortran-multilib 6.3.1-1 Fortran front-end for GCC for multilib
x86_64 Multilib-Testing gcc-multilib 6.3.1-1 The GNU Compiler Collection - C and C++ frontends for multilib
x86_64 Multilib-Testing lib32-gcc-libs 6.3.1-1 Runtime libraries shipped by GCC (32-bit)
x86_64 Multilib-Testing gcc-ada-multilib 6.3.1-1 Ada front-end for GCC (GNAT) for multilib
x86_64 Multilib-Testing gcc-objc-multilib 6.3.1-1 Objective-C front-end for GCC for multilib
AUR
ttf-wireone 1.012-1
insomnia 4.1.1-2
emby-server-beta 3.1.272-1
firefox-developer-de 52.0a2_20170111-1
ttf-nunito 2.0-1
rippled 0.40.1-1
ttf-monda 1.0-2
ttf-cutive-mono 1.001-2
desmume-git 0.9.11.r583.07a68db-2
minikube 0.15.0-1
openra-kang kang.0cacd2b-1
radarr 0.2.0.85-1
python-hdbscan 0.8.4-1
update-hosts-git r279.f5df42d-1
photoqt 1.5-1
Thanks
Posted ImagePosted Image
Configs/PGP Key/comhack π
#2007 OFFLINE   securitybreach
  • 24,208 posts
Posted 13 January 2017 - 07:23 PM
Updates for Thursday, January 12, 2016
Any
any Community unifi 5.3.11-1 Centralized management system for Ubiquiti UniFi AP
any Community openfire 4.1.1-2 High performance XMPP (Jabber) server.
any Community ttf-ubuntu-font-family 0.83-2 Ubuntu font family
any Community ansible-lint 3.4.9-1 Checks playbooks for practices and behaviour that could potentially be improved.
any Community ttf-droid 20121017-5 General-purpose fonts released by Google as part of Android
any Community python-flask-talisman 0.2.1-1 HTTP security headers for Flask
any Community python2-flask-talisman 0.2.1-1 HTTP security headers for Flask
any Community python-cherrypy 8.8.0-1 A pythonic, object-oriented web development framework
any Community python2-cherrypy 8.8.0-1 A pythonic, object-oriented web development framework
any Community sagemath-doc 7.5-1 HTML documentation and inline help for SageMath
any Community sagemath-src 7.5-1 Source files for SageMath
any Community python2-cinderclient 1.10.0-1 OpenStack Block Storage API Client Library
any Community python-cinderclient 1.10.0-1 OpenStack Block Storage API Client Library
any Community python2-keystoneclient 3.9.0-1 Client Library for OpenStack Identity
any Community python-keystoneclient 3.9.0-1 Client Library for OpenStack Identity
any Community python-pandocfilters 1.4.1-1 A python module for writing pandoc filters
any Community python2-pandocfilters 1.4.1-1 A python module for writing pandoc filters
any Community backuppc 3.3.1-6 Enterprise-grade system for backing up Linux, Windows and MacOS PCs
any Community typescript 2.1.5-1 TypeScript is a language for application scale Javascript development
any Community mitmproxy 1.0.2-1 SSL-capable man-in-the-middle HTTP proxy
any Community python2-acme 0.10.0-1 ACME protocol implementation in Python
any Community python-acme 0.10.0-1 ACME protocol implementation in Python
any Community certbot-nginx 0.10.0-1 Nginx plugin for Let’s Encrypt client
any Community certbot-apache 0.10.0-1 Apache plugin for Let’s Encrypt client
any Community certbot 0.10.0-1 A tool to automatically receive and install X.509 certificates to enable TLS on servers. The client will interoperate with the Let’s Encrypt CA which will be issuing browser-trusted certificates for free.
any Community python2-osc-lib 1.3.0-1 OpenStackClient Library
any Community python-osc-lib 1.3.0-1 OpenStackClient Library
any Community mathjax 2.7.0-2
any Extra kde-l10n-hu 16.12.1-1 Hungarian localization for KDE Applications
any Extra kde-l10n-gl 16.12.1-1 Galician localization for KDE Applications
any Extra kde-l10n-ca 16.12.1-1 Catalan localization for KDE Applications
any Extra kde-l10n-is 16.12.1-1 Icelandic localization for KDE Applications
any Extra kde-l10n-nb 16.12.1-1 Norwegian Bokmal localization for KDE Applications
any Extra kde-l10n-sr 16.12.1-1 Serbian localization for KDE Applications
any Extra kde-l10n-it 16.12.1-1 Italian localization for KDE Applications
any Extra kde-l10n-et 16.12.1-1 Estonian localization for KDE Applications
any Extra kde-l10n-eo 16.12.1-1 Esperanto localization for KDE Applications
any Extra kde-l10n-hi 16.12.1-1 Hindi localization for KDE Applications
any Extra kdeedu-data 16.12.1-1 Common data for KDE Edu applications
any Extra kde-l10n-nds 16.12.1-1 Low Saxon localization for KDE Applications
any Extra kde-l10n-wa 16.12.1-1 Walloon localization for KDE Applications
any Extra kde-l10n-pt_br 16.12.1-1 Brazilian Portuguese localization for KDE Applications
any Extra kde-l10n-zh_cn 16.12.1-1 Chinese Simplified localization for KDE Applications
any Extra kde-l10n-pa 16.12.1-1 Panjabi/Punjabi localization for KDE Applications
any Extra kde-l10n-mr 16.12.1-1 Marathi localization for KDE Applications
any Extra kde-l10n-sl 16.12.1-1 Slovenian localization for KDE Applications
any Extra kde-l10n-kk 16.12.1-1 Kazakh localization for KDE Applications
any Extra kde-l10n-ar 16.12.1-1 Arabic localization for KDE Applications
any Extra kde-l10n-lt 16.12.1-1 Lithuanian localization for KDE Applications
any Extra kde-l10n-es 16.12.1-1 Spanish localization for KDE Applications
any Extra kde-l10n-ia 16.12.1-1 Interlingua localization for KDE Applications
any Extra kde-l10n-zh_tw 16.12.1-1 Chinese Traditional localization for KDE Applications
any Extra kde-l10n-he 16.12.1-1 Hebrew localization for KDE Applications
any Extra kde-l10n-en_gb 16.12.1-1 British English localization for KDE Applications
any Extra kde-l10n-cs 16.12.1-1 Czech localization for KDE Applications
any Extra kde-l10n-pl 16.12.1-1 Polish localization for KDE Applications
any Extra kde-l10n-ug 16.12.1-1 Uyghur localization for KDE Applications
any Extra kde-l10n-id 16.12.1-1 Indonesian localization for KDE Applications
any Extra kde-l10n-sk 16.12.1-1 Slovak localization for KDE Applications
any Extra kde-l10n-ru 16.12.1-1 Russian localization for KDE Applications
any Extra kde-l10n-nn 16.12.1-1 Norwegian Nynorsk localization for KDE Applications
any Extra kde-l10n-tr 16.12.1-1 Turkish localization for KDE Applications
any Extra kde-l10n-ga 16.12.1-1 Irish localization for KDE Applications
any Extra kde-l10n-pt 16.12.1-1 Portuguese localization for KDE Applications
any Extra kde-l10n-el 16.12.1-1 Greek localization for KDE Applications
any Extra kde-l10n-ja 16.12.1-1 Japanese localization for KDE Applications
any Extra kde-l10n-ast 16.12.1-1 Asturian localization for KDE Applications
any Extra kde-dev-scripts 16.12.1-1 Scripts and setting files useful during development of KDE software
any Extra kde-l10n-sv 16.12.1-1 Swedish localization for KDE Applications
any Extra kde-l10n-da 16.12.1-1 Danish localization for KDE Applications
any Extra kde-l10n-uk 16.12.1-1 Ukrainian localization for KDE Applications
any Extra kde-l10n-de 16.12.1-1 German localization for KDE Applications
any Extra kde-l10n-fi 16.12.1-1 Finnish localization for KDE Applications
any Extra kdegames-kajongg 16.12.1-1 The ancient Chinese board game for 4 players
any Extra kde-l10n-fr 16.12.1-1 French localization for KDE Applications
any Extra kde-l10n-ca@valencia 16.12.1-1 Catalan (Valencian) localization for KDE Applications
any Extra kde-l10n-km 16.12.1-1 Khmer localization for KDE Applications
any Extra kde-l10n-hr 16.12.1-1 Croatian localization for KDE Applications
any Extra kde-l10n-bs 16.12.1-1 Bosnian localization for KDE Applications
any Extra kde-l10n-fa 16.12.1-1 Farsi localization for KDE Applications
any Extra kde-l10n-bg 16.12.1-1 Bulgarian localization for KDE Applications
any Extra kde-l10n-nl 16.12.1-1 Dutch localization for KDE Applications
any Extra kde-l10n-ro 16.12.1-1 Romanian localization for KDE Applications
any Extra kde-l10n-lv 16.12.1-1 Latvian localization for KDE Applications
any Extra kde-l10n-ko 16.12.1-1 Korean localization for KDE Applications
any Extra kde-l10n-eu 16.12.1-1 Basque localization for KDE Applications
any Extra gnu-free-fonts 20120503-4 A free family of scalable outline fonts
any Extra tex-gyre-fonts 2.005-3 Substitute PostScript fonts in OpenType format
any Extra cantarell-fonts 1:0.0.25-3 Cantarell font family
any Extra adobe-source-serif-pro-fonts 1.017-2 Serif typeface for setting text. Designed to complement Source Sans Pro
any Extra adobe-source-code-pro-fonts 2.030ro+1.050it-3 Monospaced font family for user interface and coding environments
any Extra adobe-source-sans-pro-fonts 2.020ro+1.075it-2 Sans serif font family for user interface environments
any Extra archivetools 1-3 Arch Linux Archive Tools
any Extra python2-ipaddress 1.0.18-1 IPv4/IPv6 manipulation library
i686
i686 Core sed 4.3-1 GNU stream editor
i686 Core libtool 2.4.6-7 A generic library support script
i686 Core libnl 3.2.29-1 Library for applications dealing with netlink sockets
i686 Core gcc 6.3.1-1 The GNU Compiler Collection - C and C++ frontends
i686 Core gcc-fortran 6.3.1-1 Fortran front-end for GCC
i686 Core gcc-go 6.3.1-1 Go front-end for GCC
i686 Core gcc-libs 6.3.1-1 Runtime libraries shipped by GCC
i686 Core gcc-objc 6.3.1-1 Objective-C front-end for GCC
i686 Core gcc-ada 6.3.1-1 Ada front-end for GCC (GNAT)
i686 Community weston 1.12.0-2 Reference implementation of a Wayland compositor
i686 Community picocom 2.2-2 Minimal dumb-terminal emulation program, very much like minicom
i686 Community percona-server-clients 5.7.16_10-3 Percona Server client tools
i686 Community libperconaserverclient 5.7.16_10-3 Percona Server client libraries
i686 Community percona-server 5.7.16_10-3 Drop-in replacement for MySQL that provides improved performance, diagnostics, instrumentation and TokuDB storage engine
i686 Community gearmand 1.1.12-17 Distributed job queue server.
i686 Community metricbeat 5.1.1-2 Server monitoring agent that stores metrics in Elasticsearch
i686 Community filebeat 5.1.1-2 Collects, pre-processes, and forwards log files to remote sources
i686 Community packetbeat 5.1.1-2 Network packet analyzer that ships data to Elasticsearch
i686 Community r8168 8.043.02-1 A kernel module for Realtek 8168 network cards
i686 Community eclib 20161230-3 Includes mwrank (for 2-descent on elliptic curves over Q) and modular symbol code used to create the elliptic curve database
i686 Community lcalc 1.23-15 C++ L-function class library and command line interface
i686 Community xcas 1.2.3.9-2 A free computer algebra system
i686 Community python2-cysignals 1.4.0-4 Interrupt and signal handling for Cython
i686 Community libgiac 1.2.3.9-2 Giac shared library
i686 Community sagemath 7.5-2 Open Source Mathematics Software, free alternative to Magma, Maple, Mathematica, and Matlab
i686 Community python-cysignals 1.4.0-4 Interrupt and signal handling for Cython
i686 Community singular 4.1.0.p1-2 Computer Algebra System for polynomial computations
i686 Community sagemath-jupyter 7.5-2 Jupyter kernel for SageMath
i686 Community qmmp 1.1.6-1 Qt5 based audio-player
i686 Testing foomatic-db-engine 4:4.0.12-3 Foomatic - Foomatic's database engine generates PPD files from the data in Foomatic's XML database. It also contains scripts to directly generate print queues and handle jobs.
i686 Community geckodriver 0.13.0-1 Proxy for using W3C WebDriver-compatible clients to interact with Gecko-based browsers.
i686 Community scummvm-tools 1.9.0-1 A set of tools that enable you to convert, compress and decode game datafiles for ScummVM
i686 Community notmuch 0.23.5-1 Notmuch is not much of an email program
i686 Community notmuch-vim 0.23.5-1 Vim plugins for notmuch
i686 Community astyle 2.06-1 A free, fast and small automatic formatter for C, C++, C#, and Java source code.
i686 Community notmuch-runtime 0.23.5-1 Runtime for notmuch and notmuch-mutt
i686 Community stunnel 5.39-1 A program that allows you to encrypt arbitrary TCP connections inside SSL
i686 Community notmuch-mutt 0.23.5-1 The mail indexer
i686 Community docker 1:1.12.6-1 Pack, ship and run any application as a lightweight container
i686 Community mapnik 3.0.12-4 Free Toolkit for developing mapping applications. Above all Mapnik is about rendering beautiful maps
i686 Community librime 1:1.2.9-4 Rime input method engine
i686 Community python2-tagpy 2013.1-10 Python bindings for TagLib
i686 Community libvolk 1.3-4 The Vector-Optimized Library of Kernels from Gnuradio
i686 Community povray 1:3.7-14 Script based raytracer for creating 3D graphics
i686 Community mygui 3.2.2-10 A multilayer and overlappable GUI System
i686 Community pokerth 1.1.1-15 Open source Texas Hold'em Poker simulator
i686 Community spring 103.0-5 A free 3D real-time-strategy (RTS) game engine
i686 Community 0ad a21-3 Cross-platform, 3D and historically-based real-time strategy game
i686 Community wt 3.3.6-6 a C++ library and application server for developing and deploying web applications
i686 Community widelands 19-4 A realtime strategy game with emphasis on economy and transport
i686 Community cegui 0.8.7-6 A free library providing windowing and widgets for graphics APIs/engines
i686 Community pamixer 1.3.1-5 Pulseaudio command-line mixer like amixer
i686 Community lucene++ 3.0.7-9 C++ port of the popular Java Lucene library
i686 Community facter 3.4.1-6 Collect and display system facts
i686 Community frogatto 1.3.1-21 An old-school 2d platformer game, starring a certain quixotic frog
i686 Community gnuradio-osmosdr 0.1.4-21 Source block for Funcube Dongle, RTL-SDR, USRP, OsmoSDR, BladeRF, HackRF and AirSpy devices
i686 Community openimageio 1.6.14-5 A library for reading and writing images, including classes, utilities, and applications 2017-01-11
i686 Community gqrx 2.6-3 Interactive SDR receiver waterfall for many devices.
i686 Community performous 1.1-6 A free game like "Singstar", "Rockband" or "Stepmania"
i686 Community openvdb 3.2.0-2 A large suite of tools for the efficient storage and manipulation of sparse volumetric data discretized on three-dimensional grids 2016-11-20
i686 Community bitcoin-qt 0.13.2-2 Bitcoin is a peer-to-peer network based digital currency - Qt
i686 Community ogre 1.9.0-16 Scene-oriented, flexible 3D engine written in C++
i686 Community qbittorrent-nox 3.3.10-2 An advanced BitTorrent client programmed in C++, based on Qt toolkit and libtorrent-rasterbar, w/o gui
i686 Community bitcoin-cli 0.13.2-2 Bitcoin is a peer-to-peer network based digital currency - RPC client
i686 Community gource 0.43-12 software version control visualization
i686 Community aegisub 3.2.2-18 A general-purpose subtitle editor with ASS/SSA support
i686 Community libasl 0.1.7-3 Free and open source hardware accelerated multiphysics simulation platform (Advanced Simulation Library)
i686 Community mygui-docs 3.2.2-10 Documentation for mygui
i686 Community wesnoth 1.12.6-4 A turn-based strategy game on a fantasy world
i686 Community gnuradio 3.7.10.1-3 General purpose DSP and SDR toolkit. With drivers for usrp and fcd.
i686 Community freecad 0.16-7 A general purpose 3D CAD modeler
i686 Community libuhd 3.9.5-3 Universal Software Radio Peripheral (USRP) userspace driver 2016-10-19
i686 Community openscad 2015.03.03-8 The programmers solid 3D CAD modeller
i686 Community bitcoin-daemon 0.13.2-2 Bitcoin is a peer-to-peer network based digital currency - daemon
i686 Community schroot 1.6.10-14 Allows users to execute shell commands under different root filesystems. (Successor to dchroot).
i686 Community gnuradio-fcdproplus 3.7.5-7 GNU Radio source block for Funcube Dongle Pro +
i686 Community guitarix2 0.35.2-2 A simple mono guitar amplifier and FX for JACK using Faust
i686 Community gnuradio-iqbal 0.37.2-23 Gnuradio I/Q balancing
i686 Community synfig 1.0.2-8 Professional vector animation program (CLI renderer only) 2017-01-10
i686 Community gnuradio-companion 3.7.10.1-3 GUI frontend for gnuradio and SDR.
i686 Community blender 17:2.78.a-5 A fully integrated 3D graphics creation suite
i686 Community poedit 1.8.11-3 Cross-platform gettext catalogs (.po files) editor
i686 Community glom 1.30.4-5 An easy-to-use database designer and user interface
i686 Community springlobby 0.255-3 A free cross-platform lobby client for the Spring RTS project
i686 Community openmw 0.41.0-2 An open-source engine reimplementation for the role-playing game Morrowind
i686 Community pulseview 0.3.0-5 A Qt based logic analyzer GUI for sigrok
i686 Community ogre-docs 1.9.0-16 Documentation for ogre
i686 Community glob2 0.9.4.4-31 An innovative Real-Time Strategy game which reduces micro-management by automatically assigning tasks to units
i686 Community btfs 2.13-2 A bittorrent filesystem based on FUSE
i686 Community electricsheep 2.7b33-30 A screensaver that realize the collective dream of sleeping computers from all over the internet
i686 Community ncmpcpp 0.7.7-4 Almost exact clone of ncmpc with some new features
i686 Community pingus 0.7.6-20 A Lemmings clone, i.e. a level-based puzzle game.
i686 Community snapper 0.4.1-2 A tool for managing BTRFS and LVM snapshots. It can create, diff and restore snapshots and provides timelined auto-snapping.
i686 Community powerdns 4.0.1-6 Authoritative DNS server
i686 Community leatherman 0.9.1-5 Collection of C++ and CMake utility libraries
i686 Community mupen64plus 2.5-7 Nintendo64 Emulator
i686 Community qbittorrent 3.3.10-2 An advanced BitTorrent client programmed in C++, based on Qt toolkit and libtorrent-rasterbar.
i686 Community openshadinglanguage 1.7.2-5 Advanced shading language for production GI renderers
i686 Community kicad 4.0.5-2 Electronic schematic and printed circuit board (PCB) design tools
i686 Community python2-exiv2 0.3.2-13 pyexiv2 is a Python binding to exiv2, the C++ library for manipulation of EXIF, IPTC and XMP image metadata.
i686 Community easystroke 0.6.0-14 Use mouse gestures to initiate commands and hotkeys.
i686 Community cclive 0.9.3-13 Commandline downloader for popular video websites.
i686 Community bitcoin-tx 0.13.2-2 Bitcoin is a peer-to-peer network based digital currency - Transaction tool
i686 Community powerdns-recursor 4.0.3-6 Resolving DNS server
i686 Community xmonad-contrib 0.12-10 Add-ons for xmonad
i686 Community haskell-hpack 0.16.0-1 An alternative format for Haskell packages
i686 Community haskell-yesod 1.4.4-1 Creation of type-safe, RESTful web applications.
i686 Community darcs 2.12.5-1 A distributed, interactive, smart revision control system
i686 Extra kcalc 16.12.1-1 Scientific Calculator
i686 Extra libktnef 16.12.1-1 API for handling TNEF data
i686 Extra kdegames-ksudoku 16.12.1-1 A logic-based symbol placement puzzle
i686 Extra kdegames-palapeli 16.12.1-1 A single-player jigsaw puzzle game
i686 Extra kate 16.12.1-1 Advanced Text Editor
i686 Extra messagelib 16.12.1-1 KDE PIM messaging library
i686 Extra kgpg 16.12.1-1 A GnuPG frontend
i686 Extra granatier 16.12.1-1 A clone of the classic Bomberman game
i686 Extra kdesdk-kcachegrind 16.12.1-1 Visualization of Performance Profiling Data
i686 Extra kwrite 16.12.1-1 Text Editor
i686 Extra libkdegames 16.12.1-1 Common code and data for many KDE games
i686 Extra krdc 16.12.1-1 Remote Desktop Client
i686 Extra kapptemplate 16.12.1-1 KDE Template Generator
i686 Extra kcontacts 16.12.1-1 Address book API for KDE
i686 Extra akonadi-calendar-tools 16.12.1-1 CLI tools to manage akonadi calendars
i686 Extra cervisia 16.12.1-1 CVS Frontend
i686 Extra filelight 16.12.1-1 View disk usage information
i686 Extra ktuberling 16.12.1-1 A simple constructor game suitable for children and adults alike
i686 Extra kholidays 16.12.1-1 KDE library for regional holiday information
i686 Extra kdeutils-kremotecontrol 16.12.1-1 Configure your remote controls for use with applications
i686 Extra libksieve 16.12.1-1 KDE PIM library for managing sieves
i686 Extra kmahjongg 16.12.1-1 A tile matching game for one or two players
i686 Extra kwave 16.12.1-1 A sound editor for KDE
i686 Extra kfloppy 16.12.1-1 Floppy Formatter
i686 Extra kmix 16.12.1-1 KDE volume control program (experimental KF5 version)
i686 Extra blogilo 16.12.1-1 A KDE blogging client
i686 Extra telepathy-kde-text-ui 16.12.1-1 Telepathy handler for Text Chats
i686 Extra kalzium 16.12.1-1 Periodic Table of Elements
i686 Extra telepathy-kde-contact-runner 16.12.1-1 KRunner plugin for KDE Telepathy
i686 Extra libkcddb 16.12.1-1 KDE CDDB library
i686 Extra libgravatar 16.12.1-1 KDE PIM library providing Gravatar support
i686 Extra kblog 16.12.1-1 A blogging library for KDE
i686 Extra kmbox 16.12.1-1 Library for accessing mail storages in MBox format
i686 Extra dragon 16.12.1-1 A multimedia player where the focus is on simplicity, instead of features
i686 Extra kdegames-kubrick 16.12.1-1 Based on the famous Rubik's Cube
i686 Extra kdewebdev-kommander 16.12.1-1 Executor for Kommander dialogs
i686 Extra kdialog 16.12.1-1 A utility for displaying dialog boxes from shell scripts
i686 Extra akonadi-mime 16.12.1-1 Libraries and daemons to implement basic email handling
i686 Extra kwordquiz 16.12.1-1 Flash Card Trainer
i686 Extra kteatime 16.12.1-1 Tea Cooker
i686 Extra signon-kwallet-extension 16.12.1-1 KWallet signon extension
i686 Extra kdegames-kgoldrunner 16.12.1-1 A game of action and puzzle solving
i686 Extra korganizer 16.12.1-1 Calendar and scheduling Program
i686 Extra kdegames-kspaceduel 16.12.1-1 Each of two possible players controls a satellite spaceship orbiting the sun
i686 Extra grantlee-editor 16.12.1-1 Editor for Grantlee themes
i686 Extra kdenetwork-kppp 16.12.1-1 Internet Dial-Up Tool
i686 Extra kcalcore 16.12.1-1 The KDE calendar access library
i686 Extra killbots 16.12.1-1 A simple game of evading killer robots
i686 Extra kamera 16.12.1-1 KDE integration for gphoto2 cameras
i686 Extra kdeaccessibility-jovie 16.12.1-1 A text to speech application
i686 Extra pim-data-exporter 16.12.1-1 Import and export KDE PIM settings
i686 Extra kdegames-kolf 16.12.1-1 A miniature golf game with 2d top-down view
i686 Extra kdemultimedia-kscd 16.12.1-1 KDE CD player
i686 Extra kdeaccessibility-kmouth 16.12.1-1 Speech Synthesizer Frontend
i686 Extra kdemultimedia-juk 16.12.1-1 A jukebox, tagger and music collection manager
i686 Extra libkcompactdisc 16.12.1-1 A library for interfacing with CDs
i686 Extra telepathy-kde-common-internals 16.12.1-1 Common components for KDE-Telepathy
i686 Extra knotes 16.12.1-1 Popup notes
i686 Extra analitza 16.12.1-1 A library to add mathematical features to your program
i686 Extra calendarsupport 16.12.1-1 Calendar support library
i686 Extra poxml 16.12.1-1 Translates DocBook XML files using gettext po files
i686 Extra ksystemlog 16.12.1-1 System log viewer tool
i686 Extra kdegames-lskat 16.12.1-1 Lieutenant Skat is a fun and engaging card game for two players
i686 Extra kpimtextedit 16.12.1-1 A textedit with PIM-specific features
i686 Extra pim-storage-service-manager 16.12.1-1 KDE PIM storage services configuration UI
i686 Extra kdeutils-sweeper 16.12.1-1 System Cleaner
i686 Extra parley 16.12.1-1 Vocabulary Trainer
i686 Extra eventviews 16.12.1-1 Library for creating events
i686 Extra kmail 16.12.1-1 KDE mail client
i686 Extra kiten 16.12.1-1 Japanese Reference/Study Tool
i686 Extra knetwalk 16.12.1-1 Connect all the terminals to the server, in as few turns as possible
i686 Extra kdenetwork-kget 16.12.1-1 Download Manager
i686 Extra kbruch 16.12.1-1 Exercise Fractions
i686 Extra kapman 16.12.1-1 A clone of the well known game Pac-Man
i686 Extra kaccounts-integration 16.12.1-1 Small system to administer web accounts for the sites and services across the KDE desktop, including: Google, Facebook, Owncloud, IMAP, Jabber and others
i686 Extra kdesdk-dev-utils 16.12.1-1 Small utilities for developers using KDE/Qt libs/frameworks
i686 Extra kdelibs 4.14.28-1 KDE Core Libraries
i686 Extra dolphin 16.12.1-1 File Manager
i686 Extra kturtle 16.12.1-1 Educational Programming Environment
i686 Extra kdf 16.12.1-1 View Disk Usage
i686 Extra kblocks 16.12.1-1 The classic falling blocks game
i686 Extra kdeaccessibility-kmag 16.12.1-1 Screen Magnifier
i686 Extra mailcommon 16.12.1-1 KDE PIM library providing support for mail applications
i686 Extra kdepim-addons 16.12.1-1 Addons for KDE PIM applications
i686 Extra kdegraphics-mobipocket 16.12.1-1 A collection of plugins to handle mobipocket files
i686 Extra kcron 16.12.1-1 Configure and schedule tasks
i686 Extra knavalbattle 16.12.1-1 A ship sinking game
i686 Extra kaccounts-providers 16.12.1-1 Small system to administer web accounts for the sites and services across the KDE desktop, including: Google, Facebook, Owncloud, IMAP, Jabber and others
i686 Extra kcalutils 16.12.1-1 The KDE calendar utility library
i686 Extra okteta 16.12.1-1 Hex Editor
i686 Extra kdemultimedia-kmix 16.12.1-1 KDE volume control program
i686 Extra kbreakout 16.12.1-1 A Breakout-like game
i686 Extra kdewebdev-klinkstatus 16.12.1-1 Link Checker
i686 Extra kdegames-kigo 16.12.1-1 An open-source implementation of the popular Go game
i686 Extra telepathy-kde-approver 16.12.1-1 KDE Channel Approver for Telepathy
i686 Extra kpatience 16.12.1-1 Offers a selection of solitaire card games
i686 Extra telepathy-kde-filetransfer-handler 16.12.1-1 KDE Telepathy file transfer handler
i686 Extra akregator 16.12.1-1 A Feed Reader by KDE
i686 Extra kdiamond 16.12.1-1 A single player puzzle game
i686 Extra ark 16.12.1-1 Archiving Tool
i686 Extra kaddressbook 16.12.1-1 KDE contact manager
i686 Extra kdesdk-thumbnailers 16.12.1-1 Plugins for the thumbnailing system
i686 Extra libkmahjongg 16.12.1-1 Common code, backgrounds and tile sets for games using Mahjongg tiles
i686 Extra telepathy-kde-send-file 16.12.1-1 A File manager plugin to launch a file transfer job with a specified contact
i686 Extra kontactinterface 16.12.1-1 Kontact Plugin Interface Library
i686 Extra libkeduvocdocument 16.12.1-1 Common libraries for KDE Edu applications
i686 Extra libkdepim 16.12.1-1 Libraries for KDE PIM applications
i686 Extra kgeography 16.12.1-1 Geography Trainer
i686 Extra blinken 16.12.1-1 Memory Enhancement Game
i686 Extra bovo 16.12.1-1 A Gomoku like game for two players
i686 Extra kanagram 16.12.1-1 Letter Order Game
i686 Extra libkomparediff2 16.12.1-1 Library to compare files and strings
i686 Extra kio-extras 16.12.1-1 Additional components to increase the functionality of KIO
i686 Extra kmplot 16.12.1-1 Mathematical Function Plotter
i686 Extra telepathy-kde-desktop-applets 16.12.1-1 The KDE-Telepathy Plasma desktop applets
i686 Extra akonadi 16.12.1-1 PIM layer, which provides an asynchronous API to access all kind of PIM data
i686 Extra kmail-account-wizard 16.12.1-1 KMail account wizard
i686 Extra kompare 16.12.1-1 Diff/Patch Frontend
i686 Extra kdegraphics-thumbnailers 16.12.1-1 Thumbnailers for various graphics file formats
i686 Extra ksquares 16.12.1-1 A modeled after the well known pen and paper based game of Dots and Boxes
i686 Extra mbox-importer 16.12.1-1 Import mbox files to KMail
i686 Extra kwalletmanager 16.12.1-1 Wallet management tool
i686 Extra mailimporter 16.12.1-1 Mail importer library
i686 Extra picmi 16.12.1-1 A nonogram logic game for KDE
i686 Extra kdegames-ksirk 16.12.1-1 A computerized version of a well known strategy game
i686 Extra akonadi-notes 16.12.1-1 Libraries and daemons to implement management of notes in Akonadi
i686 Extra konqueror 16.12.1-1 KDE File Manager & Web Browser
i686 Extra akonadiconsole 16.12.1-1 Akonadi management and debugging console
i686 Extra marble-data 16.12.1-1 Data for Marble
i686 Extra pim-sieve-editor 16.12.1-1 Mail sieve editor
i686 Extra kbounce 16.12.1-1 A single player arcade game with the elements of puzzle
i686 Extra spectacle 16.12.1-1 KDE screenshot capture utility
i686 Extra kontact 16.12.1-1 KDE Personal Information Manager
i686 Extra kleopatra 16.12.1-1 Certificate Manager and Unified Crypto GUI
i686 Extra akonadi-search 16.12.1-1 Libraries and daemons to implement searching in Akonadi
i686 Extra ktouch 16.12.1-1 Touch Typing Tutor
i686 Extra umbrello 16.12.1-1 UML modeller
i686 Extra kcharselect 16.12.1-1 Character Selector
i686 Extra telepathy-kde-contact-list 16.12.1-1 KDE Telepathy contact list application
i686 Extra kdenlive 16.12.1-1 A non-linear video editor for Linux using the MLT video framework
i686 Extra kollision 16.12.1-1 A simple ball dodging game
i686 Extra konsole 16.12.1-1 Terminal
i686 Extra telepathy-kde-call-ui 16.12.1-1 Voice/Video Call UI for Telepathy
i686 Extra kross-interpreters 16.12.1-1 Language interpreters to enable in-process scripting with Kross
i686 Extra akonadi-calendar 16.12.1-1 Akonadi calendar integration
i686 Extra akonadi-import-wizard 16.12.1-1 Import data from other mail clients to KMail
i686 Extra kdenetwork-zeroconf-ioslave 16.12.1-1 Network Monitor for DNS-SD services (Zeroconf)
i686 Extra kdewebdev-kfilereplace 16.12.1-1 Search & Replace Tool
i686 Extra kiriki 16.12.1-1 An addictive and fun dice game
i686 Extra kdeaccessibility-kaccessible 16.12.1-1 Provides accessibility services like focus tracking and a screenreader
i686 Extra print-manager 16.12.1-1 A tool for managing print jobs and printers
i686 Extra kfourinline 16.12.1-1 A four-in-a-row game
i686 Extra ktimer 16.12.1-1 Countdown Launcher
i686 Extra kimap 16.12.1-1 Job-based API for interacting with IMAP servers
i686 Extra bomber 16.12.1-1 A single player arcade game
i686 Extra baloo-widgets 16.12.1-1 Widgets for Baloo
i686 Extra kdenetwork-filesharing 16.12.1-1 Properties dialog plugin to share a directory with the local network
i686 Extra klines 16.12.1-1 A simple but highly addictive, one player game
i686 Extra telepathy-kde-integration-module 16.12.1-1 Sits in KDED and takes care of various bits of system integration like setting user to auto-away or handling connection errors
i686 Extra kmines 16.12.1-1 The classic Minesweeper game
i686 Extra kdepim-runtime 16.12.1-1 Extends the functionality of kdepim
i686 Extra okular 16.12.1-1 Document Viewer
i686 Extra kdenetwork-kopete 16.12.1-1 Instant Messenger
i686 Extra kdegraphics-ksaneplugin 16.12.1-1 A scan plugin that implements the scanning
i686 Extra kalarmcal 16.12.1-1 The KAlarm client library
i686 Extra grantleetheme 16.12.1-1 Library for Grantlee theming support
i686 Extra kdebugsettings 16.12.1-1 An application to enable/disable qCDebug
i686 Extra kcolorchooser 16.12.1-1 Color Chooser
i686 Extra kdebase-runtime 16.12.1-1 Plugins and applications necessary for the running of KDE applications
i686 Extra kalgebra 16.12.1-1 Graph Calculator
i686 Extra audiocd-kio 16.12.1-1 Kioslave for accessing audio CDs
i686 Extra telepathy-kde-accounts-kcm 16.12.1-1 KCM Module for configuring Telepathy Instant Messaging Accounts
i686 Extra kdegames-konquest 16.12.1-1 The KDE version of Gnu-Lactic
i686 Extra kalarm 16.12.1-1 Personal alarm scheduler
i686 Extra kqtquickcharts 16.12.1-1 A QtQuick plugin to render beautiful and interactive charts
i686 Extra khelpcenter 16.12.1-1 Application to show KDE Applications' documentation
i686 Extra pimcommon 16.12.1-1 Common libraries for KDE PIM
i686 Extra katomic 16.12.1-1 A fun and educational game built around molecular geometry
i686 Extra incidenceeditor 16.12.1-1 KDE PIM incidence editor
i686 Extra kblackbox 16.12.1-1 A game of hide and seek played on a grid of boxes
i686 Extra kldap 16.12.1-1 LDAP access API for KDE
i686 Extra kidentitymanagement 16.12.1-1 KDE PIM libraries
i686 Extra kfind 16.12.1-1 Find Files/Folders
i686 Extra kolourpaint 16.12.1-1 Paint Program
i686 Extra kdepim-apps-libs 16.12.1-1 KDE PIM mail related libraries
i686 Extra kdegames-kreversi 16.12.1-1 A simple one player strategy game played against the computer
i686 Extra klickety 16.12.1-1 An adaptation of the Clickomania game
i686 Extra libkexiv2 16.12.1-1 A library to manipulate pictures metadata
i686 Extra svgpart 16.12.1-1 A KPart for viewing SVGs
i686 Extra kdewebdev-kimagemapeditor 16.12.1-1 HTML Image Map Editor
i686 Extra artikulate 16.12.1-1 Improve your pronunciation by listening to native speakers
i686 Extra klettres 16.12.1-1 Learn The Alphabet
i686 Extra kdeaccessibility-kmousetool 16.12.1-1 Clicks the mouse for you, reducing the effects of RSI
i686 Extra rocs 16.12.1-1 Graph Theory IDE
i686 Extra libksane 16.12.1-1 An image scanning library
i686 Extra keditbookmarks 16.12.1-1 Bookmark Organizer and Editor
i686 Extra gwenview 16.12.1-1 A fast and easy to use image viewer for KDE
i686 Extra kmailtransport 16.12.1-1 Mail Transport Service
i686 Extra kruler 16.12.1-1 Screen Ruler
i686 Extra lokalize 16.12.1-1 Computer-Aided Translation System
i686 Extra kshisen 16.12.1-1 A solitaire-like game played using the standard set of Mahjong tiles
i686 Extra libkipi 16.12.1-1 An interface to use kipi-plugins from a KDE application
i686 Extra kdegames-ksnakeduel 16.12.1-1 A simple snake duel game
i686 Extra marble 16.12.1-1 Desktop Globe
i686 Extra step 16.12.1-1 Interactive Physical Simulator
i686 Extra libkleo 16.12.1-1 KDE PIM cryptographic library
i686 Extra ffmpegthumbs 16.12.1-1 FFmpeg-based thumbnail creator for video files
i686 Extra libkgeomap 16.12.1-1 A wrapper around world map components for browsing and arranging photos on a map
i686 Extra kig 16.12.1-1 Interactive Geometry
i686 Extra libkface 16.12.1-1 A Qt/C++ wrapper around LibFace library to perform face recognition and detection over pictures
i686 Extra minuet 16.12.1-1 A KDE Software for Music Education
i686 Extra kmime 16.12.1-1 Library for handling mail messages and newsgroup articles
i686 Extra kjumpingcube 16.12.1-1 A simple tactical game
i686 Extra kde-syndication 16.12.1-1 RSS/Atom parser library
i686 Extra dolphin-plugins 16.12.1-1 Extra Dolphin plugins
i686 Extra cantor 16.12.1-1 KDE Frontend to Mathematical Software
i686 Extra khangman 16.12.1-1 Hangman Game
i686 Extra akonadi-contacts 16.12.1-1 Libraries and daemons to implement Contact Management in Akonadi
i686 Extra telepathy-kde-auth-handler 16.12.1-1 Provide UI/KWallet Integration For Passwords and SSL Errors on Account Connect
i686 Extra nvidia-304xx 304.134-1 NVIDIA drivers for linux, 304xx legacy branch
i686 Extra nvidia-304xx-dkms 304.134-1 NVIDIA driver sources for linux, 304xx legacy branch
i686 Extra nvidia-304xx-libgl 304.134-1 NVIDIA drivers libraries symlinks, 304xx legacy branch
i686 Extra opencl-nvidia-304xx 304.134-1 OpenCL implemention for NVIDIA, 304xx legacy branch
i686 Extra nvidia-304xx-utils 304.134-1 NVIDIA drivers utilities and libraries, 304xx legacy branch
i686 Extra appstream 0.10.5-1 Provides a standard for creating app stores across distributions
i686 Extra appstream-qt 0.10.5-1 Qt5 interface for AppStream
i686 Extra liblightdm-qt4 1:1.20.0-2 LightDM Qt client library
i686 Extra lightdm 1:1.20.0-2 A lightweight display manager
i686 Extra liblightdm-qt5 1:1.20.0-2 LightDM Qt client library
i686 Extra bind-tools 9.11.0.P2-1 The ISC DNS tools
i686 Extra bind 9.11.0.P2-1 The ISC DNS Server
i686 Extra kirigami2 2.0.0-1 A QtQuick based components set
i686 Extra lyx 2.2.2-3 An advanced WYSIWYM document processor & LaTeX front-end
i686 Extra licq 1.8.2-13 Advanced graphical ICQ clone and more for Unix
i686 Extra mkvtoolnix-gui 9.7.1-2 Set of tools to create, edit and inspect Matroska files
i686 Extra ceph 10.2.3-2 Distributed, fault-tolerant storage platform delivering object, block, and file system
i686 Extra liborcus 0.11.2-5 File import filter library for spreadsheet documents. 2016-09-21
i686 Extra source-highlight 3.1.8-11 Convert source code to syntax highlighted document
i686 Extra libixion 0.11.1-5 A general purpose formula parser & interpreter 2016-09-21
i686 Extra vigra 1.11.0-6 Computer vision library
i686 Extra mkvtoolnix-cli 9.7.1-2 Set of tools to create, edit and inspect Matroska files
i686 Extra libkolabxml 1.1.6-3 Kolab XML Format Schema Definitions Library
i686 Extra vigra-doc 1.11.0-6 Computer vision library - documentation and examples
i686 Extra akonadi-qt4 1.13.0-12 PIM layer, which provides an asynchronous API to access all kind of PIM data (Qt4 version)
i686 Extra ekiga 4.0.1-23 VOIP/Videoconferencing app with full SIP and H.323 support (GnomeMeeting expanded and renamed)
i686 Extra libtorrent-rasterbar 1:1.1.1-6 A C++ BitTorrent library that aims to be a good alternative to all the other implementations around
i686 Extra evolution-data-server 3.22.3-2 Centralized access to appointments and contacts
i686 Extra libpst-docs 0.6.67-3 Documentation for Outlook .pst file converter
i686 Extra libpst 0.6.67-3 Outlook .pst file converter
i686 Extra boost 1.63.0-1 Free peer-reviewed portable C++ source libraries - development headers
i686 Extra libphonenumber 8.0.0-1 Google's common library for parsing, formatting, and validating international phone numbers
i686 Extra libcmis 0.5.1-5 a C/C++ client library for the CMIS protocol
i686 Extra boost-libs 1.63.0-1 Free peer-reviewed portable C++ source libraries - runtime libraries
i686 Extra hugin 2016.2.0-5 Panorama photo stitcher
i686 Extra libakonadi-qt4 1.13.0-12 Qt4 akonadi libraries
i686 Extra xorg-server 1.19.1-1 Xorg X server
i686 Extra xf86-video-vmware 13.2.1-2 X.org vmware video driver
i686 Extra xorg-server-common 1.19.1-1 Xorg server common files
i686 Extra xf86-video-dummy 0.3.8-1 X.org dummy video driver
i686 Extra xf86-input-wacom 0.34.0-1 X.Org Wacom tablet driver
i686 Extra xf86-input-synaptics 1.9.0-1 Synaptics driver for notebook touchpads
i686 Extra xorg-server-xephyr 1.19.1-1 A nested X server that runs as an X application
i686 Extra xf86-input-void 1.4.1-3 X.org void input driver
i686 Extra xorg-server-xnest 1.19.1-1 A nested X server that runs as an X application
i686 Extra xf86-input-mouse 1.9.2-3 X.org mouse input driver
i686 Extra xorg-server-xvfb 1.19.1-1 Virtual framebuffer X server
i686 Extra xf86-video-nouveau 1.0.13-2 Open Source 2D acceleration driver for nVidia cards
i686 Extra xf86-video-sisusb 0.9.6-8 X.org SiS USB video driver
i686 Extra xf86-video-intel 1:2.99.917+747+g028c946d-1 X.org Intel i810/i830/i915/945G/G965+ video drivers
i686 Extra xorg-server-xdmx 1.19.1-1 Distributed Multihead X Server and utilities
i686 Extra xorg-server-xwayland 1.19.1-1 run X clients under wayland
i686 Extra xf86-input-libinput 0.23.0-1 Generic input driver for the X.Org server based on libinput
i686 Extra xf86-video-amdgpu 1.2.0-2 X.org amdgpu video driver
i686 Extra xf86-video-voodoo 1.2.5-8 X.org 3dfx Voodoo1/Voodoo2 2D video driver
i686 Extra xf86-video-ati 1:7.8.99.r16.gea30d856-1 X.org ati video driver
i686 Extra xf86-input-evdev 2.10.4-2 X.org evdev input driver
i686 Extra xf86-video-fbdev 0.4.4-6 X.org framebuffer video driver
i686 Extra xf86-input-vmmouse 13.1.0-3 X.org VMWare Mouse input driver
i686 Extra xf86-video-openchrome 0.5.0-2 X.Org Openchrome drivers
i686 Extra xf86-input-keyboard 1.9.0-2 X.Org keyboard input driver
i686 Extra xorg-server-devel 1.19.1-1 Development files for the X.Org X server
i686 Extra xf86-video-vesa 2.3.4-3 X.org vesa video driver
i686 Extra xf86-input-elographics 1.4.1-7 X.org Elographics TouchScreen input driver
i686 Testing linux-docs 4.9.3-1 Kernel hackers manual - HTML documentation that comes with the Linux kernel
i686 Testing linux 4.9.3-1 The Linux kernel and modules
i686 Testing linux-headers 4.9.3-1 Header files and scripts for building modules for Linux kernel
i686 Testing nvidia-304xx-dkms 304.134-2 NVIDIA driver sources for linux, 304xx legacy branch
i686 Testing nvidia-304xx 304.134-2 NVIDIA drivers for linux, 304xx legacy branch
i686 Testing php-dblib 7.1.1RC1-1 dblib module for PHP
i686 Testing php-imap 7.1.1RC1-1 imap module for PHP
i686 Testing php 7.1.1RC1-1 A general-purpose scripting language that is especially suited to web development
i686 Testing php-odbc 7.1.1RC1-1 ODBC modules for PHP
i686 Testing php-gd 7.1.1RC1-1 gd module for PHP
i686 Testing php-fpm 7.1.1RC1-1 FastCGI Process Manager for PHP
i686 Testing php-embed 7.1.1RC1-1 Embedded PHP SAPI library
i686 Testing php-apache 7.1.1RC1-1 Apache SAPI for PHP
i686 Testing php-pspell 7.1.1RC1-1 pspell module for PHP
i686 Testing php-mcrypt 7.1.1RC1-1 mcrypt module for PHP
i686 Testing php-enchant 7.1.1RC1-1 enchant module for PHP
i686 Testing php-cgi 7.1.1RC1-1 CGI and FCGI SAPI for PHP
i686 Testing php-phpdbg 7.1.1RC1-1 Interactive PHP debugger
i686 Testing php-pgsql 7.1.1RC1-1 PostgreSQL modules for PHP
i686 Testing php-intl 7.1.1RC1-1 intl module for PHP
i686 Testing php-tidy 7.1.1RC1-1 tidy module for PHP
i686 Testing php-snmp 7.1.1RC1-1 snmp module for PHP
i686 Testing php-xsl 7.1.1RC1-1 xsl module for PHP
i686 Testing php-sqlite 7.1.1RC1-1 sqlite module for PHP
i686 Testing foomatic-db-gutenprint-ppds 5.2.12-1 simplified prebuilt ppd files
i686 Testing gutenprint 5.2.12-1 Top quality printer drivers for POSIX systems
i686 Testing nano 2.7.4-1 Pico editor clone with enhancements
i686 Testing gnutls 3.5.8-2 A library which provides a secure layer over a reliable transport layer
i686 Testing libldap 2.4.44-3 Lightweight Directory Access Protocol (LDAP) client libraries
i686 Testing openldap 2.4.44-3 Lightweight Directory Access Protocol (LDAP) client and server
i686 Testing lz4 1:1.7.5-1 Extremely fast compression algorithm
i686 Community-Testing r8168 8.043.02-2 A kernel module for Realtek 8168 network cards
i686 Community-Testing nrpe 3.0.1-2 Nagios Remote Plugin Executor
x86_64
x86_64 Core sed 4.3-1 GNU stream editor
x86_64 Core libtool 2.4.6-7 A generic library support script
x86_64 Core libnl 3.2.29-1 Library for applications dealing with netlink sockets
x86_64 Core gcc 6.3.1-1 The GNU Compiler Collection - C and C++ frontends
x86_64 Core gcc-fortran 6.3.1-1 Fortran front-end for GCC
x86_64 Core gcc-go 6.3.1-1 Go front-end for GCC
x86_64 Core gcc-libs 6.3.1-1 Runtime libraries shipped by GCC
x86_64 Core gcc-objc 6.3.1-1 Objective-C front-end for GCC
x86_64 Core gcc-ada 6.3.1-1 Ada front-end for GCC (GNAT)
x86_64 Community weston 1.12.0-2 Reference implementation of a Wayland compositor
x86_64 Community picocom 2.2-2 Minimal dumb-terminal emulation program, very much like minicom
x86_64 Community percona-server-clients 5.7.16_10-3 Percona Server client tools
x86_64 Community libperconaserverclient 5.7.16_10-3 Percona Server client libraries
x86_64 Community percona-server 5.7.16_10-3 Drop-in replacement for MySQL that provides improved performance, diagnostics, instrumentation and TokuDB storage engine
x86_64 Community gearmand 1.1.12-17 Distributed job queue server.
x86_64 Community rkt 1.22.0-2 App container runtime
x86_64 Community metricbeat 5.1.1-2 Server monitoring agent that stores metrics in Elasticsearch
x86_64 Community filebeat 5.1.1-2 Collects, pre-processes, and forwards log files to remote sources
x86_64 Community packetbeat 5.1.1-2 Network packet analyzer that ships data to Elasticsearch
x86_64 Community r8168 8.043.02-1 A kernel module for Realtek 8168 network cards
x86_64 Community eclib 20161230-3 Includes mwrank (for 2-descent on elliptic curves over Q) and modular symbol code used to create the elliptic curve database
x86_64 Community lcalc 1.23-15 C++ L-function class library and command line interface
x86_64 Community xcas 1.2.3.9-2 A free computer algebra system
x86_64 Community python2-cysignals 1.4.0-4 Interrupt and signal handling for Cython
x86_64 Community libgiac 1.2.3.9-2 Giac shared library
x86_64 Community sagemath 7.5-2 Open Source Mathematics Software, free alternative to Magma, Maple, Mathematica, and Matlab
x86_64 Community python-cysignals 1.4.0-4 Interrupt and signal handling for Cython
x86_64 Community singular 4.1.0.p1-2 Computer Algebra System for polynomial computations
x86_64 Community sagemath-jupyter 7.5-2 Jupyter kernel for SageMath
x86_64 Community qmmp 1.1.6-1 Qt5 based audio-player
x86_64 Community geckodriver 0.13.0-1 Proxy for using W3C WebDriver-compatible clients to interact with Gecko-based browsers.
x86_64 Community scummvm-tools 1.9.0-1 A set of tools that enable you to convert, compress and decode game datafiles for ScummVM
x86_64 Community notmuch 0.23.5-1 Notmuch is not much of an email program
x86_64 Community notmuch-vim 0.23.5-1 Vim plugins for notmuch
x86_64 Community astyle 2.06-1 A free, fast and small automatic formatter for C, C++, C#, and Java source code.
x86_64 Community notmuch-runtime 0.23.5-1 Runtime for notmuch and notmuch-mutt
x86_64 Community stunnel 5.39-1 A program that allows you to encrypt arbitrary TCP connections inside SSL
x86_64 Community notmuch-mutt 0.23.5-1 The mail indexer
x86_64 Community docker 1:1.12.6-1 Pack, ship and run any application as a lightweight container
x86_64 Community mapnik 3.0.12-4 Free Toolkit for developing mapping applications. Above all Mapnik is about rendering beautiful maps
x86_64 Community librime 1:1.2.9-4 Rime input method engine
x86_64 Community python2-tagpy 2013.1-10 Python bindings for TagLib
x86_64 Community libvolk 1.3-4 The Vector-Optimized Library of Kernels from Gnuradio
x86_64 Community povray 1:3.7-14 Script based raytracer for creating 3D graphics
x86_64 Community mygui 3.2.2-10 A multilayer and overlappable GUI System
x86_64 Community pokerth 1.1.1-15 Open source Texas Hold'em Poker simulator
x86_64 Community spring 103.0-5 A free 3D real-time-strategy (RTS) game engine
x86_64 Community 0ad a21-3 Cross-platform, 3D and historically-based real-time strategy game
x86_64 Community wt 3.3.6-6 a C++ library and application server for developing and deploying web applications
x86_64 Community widelands 19-4 A realtime strategy game with emphasis on economy and transport
x86_64 Community cegui 0.8.7-6 A free library providing windowing and widgets for graphics APIs/engines
x86_64 Community pamixer 1.3.1-5 Pulseaudio command-line mixer like amixer
x86_64 Community lucene++ 3.0.7-9 C++ port of the popular Java Lucene library
x86_64 Community facter 3.4.1-6 Collect and display system facts
x86_64 Community frogatto 1.3.1-21 An old-school 2d platformer game, starring a certain quixotic frog
x86_64 Community gnuradio-osmosdr 0.1.4-21 Source block for Funcube Dongle, RTL-SDR, USRP, OsmoSDR, BladeRF, HackRF and AirSpy devices
x86_64 Community openimageio 1.6.14-5 A library for reading and writing images, including classes, utilities, and applications 2017-01-11
x86_64 Community gqrx 2.6-3 Interactive SDR receiver waterfall for many devices.
x86_64 Community performous 1.1-6 A free game like "Singstar", "Rockband" or "Stepmania"
x86_64 Community openvdb 3.2.0-2 A large suite of tools for the efficient storage and manipulation of sparse volumetric data discretized on three-dimensional grids 2016-11-20
x86_64 Community bitcoin-qt 0.13.2-2 Bitcoin is a peer-to-peer network based digital currency - Qt
x86_64 Community ogre 1.9.0-16 Scene-oriented, flexible 3D engine written in C++
x86_64 Community qbittorrent-nox 3.3.10-2 An advanced BitTorrent client programmed in C++, based on Qt toolkit and libtorrent-rasterbar, w/o gui
x86_64 Community bitcoin-cli 0.13.2-2 Bitcoin is a peer-to-peer network based digital currency - RPC client
x86_64 Community gource 0.43-12 software version control visualization
x86_64 Community aegisub 3.2.2-18 A general-purpose subtitle editor with ASS/SSA support
x86_64 Community wiredtiger 2.9.1-1 High performance, scalable, production quality, NoSQL, Open Source extensible platform for data management
x86_64 Community libasl 0.1.7-3 Free and open source hardware accelerated multiphysics simulation platform (Advanced Simulation Library)
x86_64 Community mygui-docs 3.2.2-10 Documentation for mygui
x86_64 Community wesnoth 1.12.6-4 A turn-based strategy game on a fantasy world
x86_64 Community gnuradio 3.7.10.1-3 General purpose DSP and SDR toolkit. With drivers for usrp and fcd.
x86_64 Community mongodb 3.4.1-1 A high-performance, open source, schema-free document-oriented database
x86_64 Community freecad 0.16-7 A general purpose 3D CAD modeler
x86_64 Community zcash 1.0.4-2 Permissionless financial system employing zero-knowledge security
x86_64 Community libuhd 3.9.5-3 Universal Software Radio Peripheral (USRP) userspace driver 2016-10-19
x86_64 Community openscad 2015.03.03-8 The programmers solid 3D CAD modeller
x86_64 Community bitcoin-daemon 0.13.2-2 Bitcoin is a peer-to-peer network based digital currency - daemon
x86_64 Community schroot 1.6.10-14 Allows users to execute shell commands under different root filesystems. (Successor to dchroot).
x86_64 Community gnuradio-fcdproplus 3.7.5-7 GNU Radio source block for Funcube Dongle Pro +
x86_64 Community python-pycuda 2016.1.2-6 Python wrapper for Nvidia CUDA
x86_64 Community guitarix2 0.35.2-2 A simple mono guitar amplifier and FX for JACK using Faust
x86_64 Community gnuradio-iqbal 0.37.2-23 Gnuradio I/Q balancing
x86_64 Community synfig 1.0.2-8 Professional vector animation program (CLI renderer only) 2017-01-10
x86_64 Community gnuradio-companion 3.7.10.1-3 GUI frontend for gnuradio and SDR.
x86_64 Community blender 17:2.78.a-5 A fully integrated 3D graphics creation suite
x86_64 Community poedit 1.8.11-3 Cross-platform gettext catalogs (.po files) editor
x86_64 Community glom 1.30.4-5 An easy-to-use database designer and user interface
x86_64 Community springlobby 0.255-3 A free cross-platform lobby client for the Spring RTS project
x86_64 Community openmw 0.41.0-2 An open-source engine reimplementation for the role-playing game Morrowind
x86_64 Community pulseview 0.3.0-5 A Qt based logic analyzer GUI for sigrok
x86_64 Community ogre-docs 1.9.0-16 Documentation for ogre
x86_64 Community glob2 0.9.4.4-31 An innovative Real-Time Strategy game which reduces micro-management by automatically assigning tasks to units
x86_64 Community btfs 2.13-2 A bittorrent filesystem based on FUSE
x86_64 Community electricsheep 2.7b33-30 A screensaver that realize the collective dream of sleeping computers from all over the internet
x86_64 Community ncmpcpp 0.7.7-4 Almost exact clone of ncmpc with some new features
x86_64 Community pingus 0.7.6-20 A Lemmings clone, i.e. a level-based puzzle game.
x86_64 Community snapper 0.4.1-2 A tool for managing BTRFS and LVM snapshots. It can create, diff and restore snapshots and provides timelined auto-snapping.
x86_64 Community powerdns 4.0.1-6 Authoritative DNS server
x86_64 Community luxrays 1.6-7 Accelerate the ray intersection process by using GPUs
x86_64 Community pycuda-headers 2016.1.2-6 Python wrapper for Nvidia CUDA
x86_64 Community leatherman 0.9.1-5 Collection of C++ and CMake utility libraries
x86_64 Community mupen64plus 2.5-7 Nintendo64 Emulator
x86_64 Community python2-pycuda 2016.1.2-6 Python wrapper for Nvidia CUDA
x86_64 Community qbittorrent 3.3.10-2 An advanced BitTorrent client programmed in C++, based on Qt toolkit and libtorrent-rasterbar.
x86_64 Community openshadinglanguage 1.7.2-5 Advanced shading language for production GI renderers
x86_64 Community kicad 4.0.5-2 Electronic schematic and printed circuit board (PCB) design tools
x86_64 Community python2-exiv2 0.3.2-13 pyexiv2 is a Python binding to exiv2, the C++ library for manipulation of EXIF, IPTC and XMP image metadata.
x86_64 Community easystroke 0.6.0-14 Use mouse gestures to initiate commands and hotkeys.
x86_64 Community cclive 0.9.3-13 Commandline downloader for popular video websites.
x86_64 Community bitcoin-tx 0.13.2-2 Bitcoin is a peer-to-peer network based digital currency - Transaction tool
x86_64 Community luxrender 1.6-6 Rendering system for physically correct, unbiased image synthesis
x86_64 Community powerdns-recursor 4.0.3-6 Resolving DNS server
x86_64 Community xmonad-contrib 0.12-10 Add-ons for xmonad
x86_64 Community haskell-hpack 0.16.0-1 An alternative format for Haskell packages
x86_64 Community haskell-yesod 1.4.4-1 Creation of type-safe, RESTful web applications.
x86_64 Community darcs 2.12.5-1 A distributed, interactive, smart revision control system
x86_64 Extra libwebp 0.5.2-1 WebP library and conversion tools
x86_64 Extra kcalc 16.12.1-1 Scientific Calculator
x86_64 Extra libktnef 16.12.1-1 API for handling TNEF data
x86_64 Extra kdegames-ksudoku 16.12.1-1 A logic-based symbol placement puzzle
x86_64 Extra kdegames-palapeli 16.12.1-1 A single-player jigsaw puzzle game
x86_64 Extra kate 16.12.1-1 Advanced Text Editor
x86_64 Extra messagelib 16.12.1-1 KDE PIM messaging library
x86_64 Extra kgpg 16.12.1-1 A GnuPG frontend
x86_64 Extra granatier 16.12.1-1 A clone of the classic Bomberman game
x86_64 Extra kdesdk-kcachegrind 16.12.1-1 Visualization of Performance Profiling Data
x86_64 Extra kwrite 16.12.1-1 Text Editor
x86_64 Extra libkdegames 16.12.1-1 Common code and data for many KDE games
x86_64 Extra krdc 16.12.1-1 Remote Desktop Client
x86_64 Extra kapptemplate 16.12.1-1 KDE Template Generator
x86_64 Extra kcontacts 16.12.1-1 Address book API for KDE
x86_64 Extra akonadi-calendar-tools 16.12.1-1 CLI tools to manage akonadi calendars
x86_64 Extra cervisia 16.12.1-1 CVS Frontend
x86_64 Extra filelight 16.12.1-1 View disk usage information
x86_64 Extra ktuberling 16.12.1-1 A simple constructor game suitable for children and adults alike
x86_64 Extra kholidays 16.12.1-1 KDE library for regional holiday information
x86_64 Extra kdeutils-kremotecontrol 16.12.1-1 Configure your remote controls for use with applications
x86_64 Extra libksieve 16.12.1-1 KDE PIM library for managing sieves
x86_64 Extra kmahjongg 16.12.1-1 A tile matching game for one or two players
x86_64 Extra kwave 16.12.1-1 A sound editor for KDE
x86_64 Extra kfloppy 16.12.1-1 Floppy Formatter
x86_64 Extra kmix 16.12.1-1 KDE volume control program (experimental KF5 version)
x86_64 Extra blogilo 16.12.1-1 A KDE blogging client
x86_64 Extra telepathy-kde-text-ui 16.12.1-1 Telepathy handler for Text Chats
x86_64 Extra kalzium 16.12.1-1 Periodic Table of Elements
x86_64 Extra telepathy-kde-contact-runner 16.12.1-1 KRunner plugin for KDE Telepathy
x86_64 Extra libkcddb 16.12.1-1 KDE CDDB library
x86_64 Extra libgravatar 16.12.1-1 KDE PIM library providing Gravatar support
x86_64 Extra kblog 16.12.1-1 A blogging library for KDE
x86_64 Extra kmbox 16.12.1-1 Library for accessing mail storages in MBox format
x86_64 Extra dragon 16.12.1-1 A multimedia player where the focus is on simplicity, instead of features
x86_64 Extra kdegames-kubrick 16.12.1-1 Based on the famous Rubik's Cube
x86_64 Extra kdewebdev-kommander 16.12.1-1 Executor for Kommander dialogs
x86_64 Extra kdialog 16.12.1-1 A utility for displaying dialog boxes from shell scripts
x86_64 Extra akonadi-mime 16.12.1-1 Libraries and daemons to implement basic email handling
x86_64 Extra kwordquiz 16.12.1-1 Flash Card Trainer
x86_64 Extra kteatime 16.12.1-1 Tea Cooker
x86_64 Extra signon-kwallet-extension 16.12.1-1 KWallet signon extension
x86_64 Extra kdegames-kgoldrunner 16.12.1-1 A game of action and puzzle solving
x86_64 Extra korganizer 16.12.1-1 Calendar and scheduling Program
x86_64 Extra kdegames-kspaceduel 16.12.1-1 Each of two possible players controls a satellite spaceship orbiting the sun
x86_64 Extra grantlee-editor 16.12.1-1 Editor for Grantlee themes
x86_64 Extra kdenetwork-kppp 16.12.1-1 Internet Dial-Up Tool
x86_64 Extra kcalcore 16.12.1-1 The KDE calendar access library
x86_64 Extra killbots 16.12.1-1 A simple game of evading killer robots
x86_64 Extra kamera 16.12.1-1 KDE integration for gphoto2 cameras
x86_64 Extra kdeaccessibility-jovie 16.12.1-1 A text to speech application
x86_64 Extra pim-data-exporter 16.12.1-1 Import and export KDE PIM settings
x86_64 Extra kdegames-kolf 16.12.1-1 A miniature golf game with 2d top-down view
x86_64 Extra kdemultimedia-kscd 16.12.1-1 KDE CD player
x86_64 Extra kdeaccessibility-kmouth 16.12.1-1 Speech Synthesizer Frontend
x86_64 Extra kdemultimedia-juk 16.12.1-1 A jukebox, tagger and music collection manager
x86_64 Extra libkcompactdisc 16.12.1-1 A library for interfacing with CDs
x86_64 Extra telepathy-kde-common-internals 16.12.1-1 Common components for KDE-Telepathy
x86_64 Extra knotes 16.12.1-1 Popup notes
x86_64 Extra analitza 16.12.1-1 A library to add mathematical features to your program
x86_64 Extra calendarsupport 16.12.1-1 Calendar support library
x86_64 Extra poxml 16.12.1-1 Translates DocBook XML files using gettext po files
x86_64 Extra ksystemlog 16.12.1-1 System log viewer tool
x86_64 Extra kdegames-lskat 16.12.1-1 Lieutenant Skat is a fun and engaging card game for two players
x86_64 Extra kpimtextedit 16.12.1-1 A textedit with PIM-specific features
x86_64 Extra pim-storage-service-manager 16.12.1-1 KDE PIM storage services configuration UI
x86_64 Extra kdeutils-sweeper 16.12.1-1 System Cleaner
x86_64 Extra parley 16.12.1-1 Vocabulary Trainer
x86_64 Extra eventviews 16.12.1-1 Library for creating events
x86_64 Extra kmail 16.12.1-1 KDE mail client
x86_64 Extra kiten 16.12.1-1 Japanese Reference/Study Tool
x86_64 Extra knetwalk 16.12.1-1 Connect all the terminals to the server, in as few turns as possible
x86_64 Extra kdenetwork-kget 16.12.1-1 Download Manager
x86_64 Extra kbruch 16.12.1-1 Exercise Fractions
x86_64 Extra kapman 16.12.1-1 A clone of the well known game Pac-Man
x86_64 Extra kaccounts-integration 16.12.1-1 Small system to administer web accounts for the sites and services across the KDE desktop, including: Google, Facebook, Owncloud, IMAP, Jabber and others
x86_64 Extra kdesdk-dev-utils 16.12.1-1 Small utilities for developers using KDE/Qt libs/frameworks
x86_64 Extra kdelibs 4.14.28-1 KDE Core Libraries
x86_64 Extra dolphin 16.12.1-1 File Manager
x86_64 Extra kturtle 16.12.1-1 Educational Programming Environment
x86_64 Extra kdf 16.12.1-1 View Disk Usage
x86_64 Extra kblocks 16.12.1-1 The classic falling blocks game
x86_64 Extra kdeaccessibility-kmag 16.12.1-1 Screen Magnifier
x86_64 Extra mailcommon 16.12.1-1 KDE PIM library providing support for mail applications
x86_64 Extra kdepim-addons 16.12.1-1 Addons for KDE PIM applications
x86_64 Extra kdegraphics-mobipocket 16.12.1-1 A collection of plugins to handle mobipocket files
x86_64 Extra kcron 16.12.1-1 Configure and schedule tasks
x86_64 Extra knavalbattle 16.12.1-1 A ship sinking game
x86_64 Extra kaccounts-providers 16.12.1-1 Small system to administer web accounts for the sites and services across the KDE desktop, including: Google, Facebook, Owncloud, IMAP, Jabber and others
x86_64 Extra kcalutils 16.12.1-1 The KDE calendar utility library
x86_64 Extra okteta 16.12.1-1 Hex Editor
x86_64 Extra kdemultimedia-kmix 16.12.1-1 KDE volume control program
x86_64 Extra kbreakout 16.12.1-1 A Breakout-like game
x86_64 Extra kdewebdev-klinkstatus 16.12.1-1 Link Checker
x86_64 Extra kdegames-kigo 16.12.1-1 An open-source implementation of the popular Go game
x86_64 Extra telepathy-kde-approver 16.12.1-1 KDE Channel Approver for Telepathy
x86_64 Extra kpatience 16.12.1-1 Offers a selection of solitaire card games
x86_64 Extra telepathy-kde-filetransfer-handler 16.12.1-1 KDE Telepathy file transfer handler
x86_64 Extra akregator 16.12.1-1 A Feed Reader by KDE
x86_64 Extra kdiamond 16.12.1-1 A single player puzzle game
x86_64 Extra ark 16.12.1-1 Archiving Tool
x86_64 Extra kaddressbook 16.12.1-1 KDE contact manager
x86_64 Extra kdesdk-thumbnailers 16.12.1-1 Plugins for the thumbnailing system
x86_64 Extra libkmahjongg 16.12.1-1 Common code, backgrounds and tile sets for games using Mahjongg tiles
x86_64 Extra telepathy-kde-send-file 16.12.1-1 A File manager plugin to launch a file transfer job with a specified contact
x86_64 Extra kontactinterface 16.12.1-1 Kontact Plugin Interface Library
x86_64 Extra libkeduvocdocument 16.12.1-1 Common libraries for KDE Edu applications
x86_64 Extra libkdepim 16.12.1-1 Libraries for KDE PIM applications
x86_64 Extra kgeography 16.12.1-1 Geography Trainer
x86_64 Extra blinken 16.12.1-1 Memory Enhancement Game
x86_64 Extra bovo 16.12.1-1 A Gomoku like game for two players
x86_64 Extra kanagram 16.12.1-1 Letter Order Game
x86_64 Extra libkomparediff2 16.12.1-1 Library to compare files and strings
x86_64 Extra kio-extras 16.12.1-1 Additional components to increase the functionality of KIO
x86_64 Extra kmplot 16.12.1-1 Mathematical Function Plotter
x86_64 Extra telepathy-kde-desktop-applets 16.12.1-1 The KDE-Telepathy Plasma desktop applets
x86_64 Extra akonadi 16.12.1-1 PIM layer, which provides an asynchronous API to access all kind of PIM data
x86_64 Extra kmail-account-wizard 16.12.1-1 KMail account wizard
x86_64 Extra kompare 16.12.1-1 Diff/Patch Frontend
x86_64 Extra kdegraphics-thumbnailers 16.12.1-1 Thumbnailers for various graphics file formats
x86_64 Extra ksquares 16.12.1-1 A modeled after the well known pen and paper based game of Dots and Boxes
x86_64 Extra mbox-importer 16.12.1-1 Import mbox files to KMail
x86_64 Extra kwalletmanager 16.12.1-1 Wallet management tool
x86_64 Extra mailimporter 16.12.1-1 Mail importer library
x86_64 Extra picmi 16.12.1-1 A nonogram logic game for KDE
x86_64 Extra kdegames-ksirk 16.12.1-1 A computerized version of a well known strategy game
x86_64 Extra akonadi-notes 16.12.1-1 Libraries and daemons to implement management of notes in Akonadi
x86_64 Extra konqueror 16.12.1-1 KDE File Manager & Web Browser
x86_64 Extra akonadiconsole 16.12.1-1 Akonadi management and debugging console
x86_64 Extra marble-data 16.12.1-1 Data for Marble
x86_64 Extra pim-sieve-editor 16.12.1-1 Mail sieve editor
x86_64 Extra kbounce 16.12.1-1 A single player arcade game with the elements of puzzle
x86_64 Extra spectacle 16.12.1-1 KDE screenshot capture utility
x86_64 Extra kontact 16.12.1-1 KDE Personal Information Manager
x86_64 Extra kleopatra 16.12.1-1 Certificate Manager and Unified Crypto GUI
x86_64 Extra akonadi-search 16.12.1-1 Libraries and daemons to implement searching in Akonadi
x86_64 Extra ktouch 16.12.1-1 Touch Typing Tutor
x86_64 Extra umbrello 16.12.1-1 UML modeller
x86_64 Extra kcharselect 16.12.1-1 Character Selector
x86_64 Extra telepathy-kde-contact-list 16.12.1-1 KDE Telepathy contact list application
x86_64 Extra kdenlive 16.12.1-1 A non-linear video editor for Linux using the MLT video framework
x86_64 Extra kollision 16.12.1-1 A simple ball dodging game
x86_64 Extra konsole 16.12.1-1 Terminal
x86_64 Extra telepathy-kde-call-ui 16.12.1-1 Voice/Video Call UI for Telepathy
x86_64 Extra kross-interpreters 16.12.1-1 Language interpreters to enable in-process scripting with Kross
x86_64 Extra akonadi-calendar 16.12.1-1 Akonadi calendar integration
x86_64 Extra akonadi-import-wizard 16.12.1-1 Import data from other mail clients to KMail
x86_64 Extra kdenetwork-zeroconf-ioslave 16.12.1-1 Network Monitor for DNS-SD services (Zeroconf)
x86_64 Extra kdewebdev-kfilereplace 16.12.1-1 Search & Replace Tool
x86_64 Extra kiriki 16.12.1-1 An addictive and fun dice game
x86_64 Extra kdeaccessibility-kaccessible 16.12.1-1 Provides accessibility services like focus tracking and a screenreader
x86_64 Extra print-manager 16.12.1-1 A tool for managing print jobs and printers
x86_64 Extra kfourinline 16.12.1-1 A four-in-a-row game
x86_64 Extra ktimer 16.12.1-1 Countdown Launcher
x86_64 Extra kimap 16.12.1-1 Job-based API for interacting with IMAP servers
x86_64 Extra bomber 16.12.1-1 A single player arcade game
x86_64 Extra baloo-widgets 16.12.1-1 Widgets for Baloo
x86_64 Extra kdenetwork-filesharing 16.12.1-1 Properties dialog plugin to share a directory with the local network
x86_64 Extra klines 16.12.1-1 A simple but highly addictive, one player game
x86_64 Extra telepathy-kde-integration-module 16.12.1-1 Sits in KDED and takes care of various bits of system integration like setting user to auto-away or handling connection errors
x86_64 Extra kmines 16.12.1-1 The classic Minesweeper game
x86_64 Extra kdepim-runtime 16.12.1-1 Extends the functionality of kdepim
x86_64 Extra okular 16.12.1-1 Document Viewer
x86_64 Extra kdenetwork-kopete 16.12.1-1 Instant Messenger
x86_64 Extra kdegraphics-ksaneplugin 16.12.1-1 A scan plugin that implements the scanning
x86_64 Extra kalarmcal 16.12.1-1 The KAlarm client library
x86_64 Extra grantleetheme 16.12.1-1 Library for Grantlee theming support
x86_64 Extra kdebugsettings 16.12.1-1 An application to enable/disable qCDebug
x86_64 Extra kcolorchooser 16.12.1-1 Color Chooser
x86_64 Extra kdebase-runtime 16.12.1-1 Plugins and applications necessary for the running of KDE applications
x86_64 Extra kalgebra 16.12.1-1 Graph Calculator
x86_64 Extra audiocd-kio 16.12.1-1 Kioslave for accessing audio CDs
x86_64 Extra telepathy-kde-accounts-kcm 16.12.1-1 KCM Module for configuring Telepathy Instant Messaging Accounts
x86_64 Extra kdegames-konquest 16.12.1-1 The KDE version of Gnu-Lactic
x86_64 Extra kalarm 16.12.1-1 Personal alarm scheduler
x86_64 Extra kqtquickcharts 16.12.1-1 A QtQuick plugin to render beautiful and interactive charts
x86_64 Extra khelpcenter 16.12.1-1 Application to show KDE Applications' documentation
x86_64 Extra pimcommon 16.12.1-1 Common libraries for KDE PIM
x86_64 Extra katomic 16.12.1-1 A fun and educational game built around molecular geometry
x86_64 Extra incidenceeditor 16.12.1-1 KDE PIM incidence editor
x86_64 Extra kblackbox 16.12.1-1 A game of hide and seek played on a grid of boxes
x86_64 Extra kldap 16.12.1-1 LDAP access API for KDE
x86_64 Extra kidentitymanagement 16.12.1-1 KDE PIM libraries
x86_64 Extra kfind 16.12.1-1 Find Files/Folders
x86_64 Extra kolourpaint 16.12.1-1 Paint Program
x86_64 Extra kdepim-apps-libs 16.12.1-1 KDE PIM mail related libraries
x86_64 Extra kdegames-kreversi 16.12.1-1 A simple one player strategy game played against the computer
x86_64 Extra klickety 16.12.1-1 An adaptation of the Clickomania game
x86_64 Extra libkexiv2 16.12.1-1 A library to manipulate pictures metadata
x86_64 Extra svgpart 16.12.1-1 A KPart for viewing SVGs
x86_64 Extra kdewebdev-kimagemapeditor 16.12.1-1 HTML Image Map Editor
x86_64 Extra artikulate 16.12.1-1 Improve your pronunciation by listening to native speakers
x86_64 Extra klettres 16.12.1-1 Learn The Alphabet
x86_64 Extra kdeaccessibility-kmousetool 16.12.1-1 Clicks the mouse for you, reducing the effects of RSI
x86_64 Extra rocs 16.12.1-1 Graph Theory IDE
x86_64 Extra libksane 16.12.1-1 An image scanning library
x86_64 Extra keditbookmarks 16.12.1-1 Bookmark Organizer and Editor
x86_64 Extra gwenview 16.12.1-1 A fast and easy to use image viewer for KDE
x86_64 Extra kmailtransport 16.12.1-1 Mail Transport Service
x86_64 Extra kruler 16.12.1-1 Screen Ruler
x86_64 Extra lokalize 16.12.1-1 Computer-Aided Translation System
x86_64 Extra kshisen 16.12.1-1 A solitaire-like game played using the standard set of Mahjong tiles
x86_64 Extra libkipi 16.12.1-1 An interface to use kipi-plugins from a KDE application
x86_64 Extra kdegames-ksnakeduel 16.12.1-1 A simple snake duel game
x86_64 Extra marble 16.12.1-1 Desktop Globe
x86_64 Extra step 16.12.1-1 Interactive Physical Simulator
x86_64 Extra libkleo 16.12.1-1 KDE PIM cryptographic library
x86_64 Extra ffmpegthumbs 16.12.1-1 FFmpeg-based thumbnail creator for video files
x86_64 Extra libkgeomap 16.12.1-1 A wrapper around world map components for browsing and arranging photos on a map
x86_64 Extra kig 16.12.1-1 Interactive Geometry
x86_64 Extra libkface 16.12.1-1 A Qt/C++ wrapper around LibFace library to perform face recognition and detection over pictures
x86_64 Extra minuet 16.12.1-1 A KDE Software for Music Education
x86_64 Extra kmime 16.12.1-1 Library for handling mail messages and newsgroup articles
x86_64 Extra kjumpingcube 16.12.1-1 A simple tactical game
x86_64 Extra kde-syndication 16.12.1-1 RSS/Atom parser library
x86_64 Extra dolphin-plugins 16.12.1-1 Extra Dolphin plugins
x86_64 Extra cantor 16.12.1-1 KDE Frontend to Mathematical Software
x86_64 Extra khangman 16.12.1-1 Hangman Game
x86_64 Extra akonadi-contacts 16.12.1-1 Libraries and daemons to implement Contact Management in Akonadi
x86_64 Extra telepathy-kde-auth-handler 16.12.1-1 Provide UI/KWallet Integration For Passwords and SSL Errors on Account Connect
x86_64 Extra nvidia-304xx 304.134-1 NVIDIA drivers for linux, 304xx legacy branch
x86_64 Extra nvidia-304xx-dkms 304.134-1 NVIDIA driver sources for linux, 304xx legacy branch
x86_64 Extra nvidia-304xx-libgl 304.134-1 NVIDIA drivers libraries symlinks, 304xx legacy branch
x86_64 Extra opencl-nvidia-304xx 304.134-1 OpenCL implemention for NVIDIA, 304xx legacy branch
x86_64 Extra nvidia-304xx-utils 304.134-1 NVIDIA drivers utilities and libraries, 304xx legacy branch
x86_64 Extra appstream 0.10.5-1 Provides a standard for creating app stores across distributions
x86_64 Extra appstream-qt 0.10.5-1 Qt5 interface for AppStream
x86_64 Extra liblightdm-qt4 1:1.20.0-2 LightDM Qt client library
x86_64 Extra lightdm 1:1.20.0-2 A lightweight display manager
x86_64 Extra liblightdm-qt5 1:1.20.0-2 LightDM Qt client library
x86_64 Extra bind-tools 9.11.0.P2-1 The ISC DNS tools
x86_64 Extra bind 9.11.0.P2-1 The ISC DNS Server
x86_64 Extra kirigami2 2.0.0-1 A QtQuick based components set
x86_64 Extra lyx 2.2.2-3 An advanced WYSIWYM document processor & LaTeX front-end
x86_64 Extra licq 1.8.2-13 Advanced graphical ICQ clone and more for Unix
x86_64 Extra mkvtoolnix-gui 9.7.1-2 Set of tools to create, edit and inspect Matroska files
x86_64 Extra ceph 10.2.3-2 Distributed, fault-tolerant storage platform delivering object, block, and file system
x86_64 Extra liborcus 0.11.2-5 File import filter library for spreadsheet documents. 2016-09-21
x86_64 Extra source-highlight 3.1.8-11 Convert source code to syntax highlighted document
x86_64 Extra libixion 0.11.1-5 A general purpose formula parser & interpreter 2016-09-21
x86_64 Extra vigra 1.11.0-6 Computer vision library
x86_64 Extra mkvtoolnix-cli 9.7.1-2 Set of tools to create, edit and inspect Matroska files
x86_64 Extra libkolabxml 1.1.6-3 Kolab XML Format Schema Definitions Library
x86_64 Extra vigra-doc 1.11.0-6 Computer vision library - documentation and examples
x86_64 Extra akonadi-qt4 1.13.0-12 PIM layer, which provides an asynchronous API to access all kind of PIM data (Qt4 version)
x86_64 Extra ekiga 4.0.1-23 VOIP/Videoconferencing app with full SIP and H.323 support (GnomeMeeting expanded and renamed)
x86_64 Extra libtorrent-rasterbar 1:1.1.1-6 A C++ BitTorrent library that aims to be a good alternative to all the other implementations around
x86_64 Extra evolution-data-server 3.22.3-2 Centralized access to appointments and contacts
x86_64 Extra libpst-docs 0.6.67-3 Documentation for Outlook .pst file converter
x86_64 Extra libpst 0.6.67-3 Outlook .pst file converter
x86_64 Extra boost 1.63.0-1 Free peer-reviewed portable C++ source libraries - development headers
x86_64 Extra libphonenumber 8.0.0-1 Google's common library for parsing, formatting, and validating international phone numbers
x86_64 Extra libcmis 0.5.1-5 a C/C++ client library for the CMIS protocol
x86_64 Extra boost-libs 1.63.0-1 Free peer-reviewed portable C++ source libraries - runtime libraries
x86_64 Extra hugin 2016.2.0-5 Panorama photo stitcher
x86_64 Extra libakonadi-qt4 1.13.0-12 Qt4 akonadi libraries
x86_64 Extra xorg-server 1.19.1-1 Xorg X server
x86_64 Extra xf86-video-vmware 13.2.1-2 X.org vmware video driver
x86_64 Extra xorg-server-common 1.19.1-1 Xorg server common files
x86_64 Extra xf86-video-dummy 0.3.8-1 X.org dummy video driver
x86_64 Extra xf86-input-wacom 0.34.0-1 X.Org Wacom tablet driver
x86_64 Extra xf86-input-synaptics 1.9.0-1 Synaptics driver for notebook touchpads
x86_64 Extra xorg-server-xephyr 1.19.1-1 A nested X server that runs as an X application
x86_64 Extra xf86-input-void 1.4.1-3 X.org void input driver
x86_64 Extra xorg-server-xnest 1.19.1-1 A nested X server that runs as an X application
x86_64 Extra xf86-input-mouse 1.9.2-3 X.org mouse input driver
x86_64 Extra xorg-server-xvfb 1.19.1-1 Virtual framebuffer X server
x86_64 Extra xf86-video-nouveau 1.0.13-2 Open Source 2D acceleration driver for nVidia cards
x86_64 Extra xf86-video-sisusb 0.9.6-8 X.org SiS USB video driver
x86_64 Extra xf86-video-intel 1:2.99.917+747+g028c946d-1 X.org Intel i810/i830/i915/945G/G965+ video drivers
x86_64 Extra xorg-server-xdmx 1.19.1-1 Distributed Multihead X Server and utilities
x86_64 Extra xorg-server-xwayland 1.19.1-1 run X clients under wayland
x86_64 Extra xf86-input-libinput 0.23.0-1 Generic input driver for the X.Org server based on libinput
x86_64 Extra xf86-video-amdgpu 1.2.0-2 X.org amdgpu video driver
x86_64 Extra xf86-video-voodoo 1.2.5-8 X.org 3dfx Voodoo1/Voodoo2 2D video driver
x86_64 Extra xf86-video-ati 1:7.8.99.r16.gea30d856-1 X.org ati video driver
x86_64 Extra xf86-input-evdev 2.10.4-2 X.org evdev input driver
x86_64 Extra xf86-video-fbdev 0.4.4-6 X.org framebuffer video driver
x86_64 Extra xf86-input-vmmouse 13.1.0-3 X.org VMWare Mouse input driver
x86_64 Extra xf86-video-openchrome 0.5.0-2 X.Org Openchrome drivers
x86_64 Extra xf86-input-keyboard 1.9.0-2 X.Org keyboard input driver
x86_64 Extra xorg-server-devel 1.19.1-1 Development files for the X.Org X server
x86_64 Extra xf86-video-vesa 2.3.4-3 X.org vesa video driver
x86_64 Extra xf86-input-elographics 1.4.1-7 X.org Elographics TouchScreen input driver
x86_64 Multilib lib32-nvidia-304xx-utils 304.134-1 NVIDIA drivers utilities (32-bit)
x86_64 Multilib lib32-opencl-nvidia-304xx 304.134-1 OpenCL implemention for NVIDIA (32-bit)
x86_64 Multilib lib32-nvidia-304xx-libgl 304.134-1 NVIDIA drivers libraries symlinks (32-bit)
x86_64 Multilib gcc-go-multilib 6.3.1-1 Go front-end for GCC for multilib
x86_64 Multilib gcc-fortran-multilib 6.3.1-1 Fortran front-end for GCC for multilib
x86_64 Multilib gcc-ada-multilib 6.3.1-1 Ada front-end for GCC (GNAT) for multilib
x86_64 Multilib gcc-libs-multilib 6.3.1-1 Runtime libraries shipped by GCC for multilib
x86_64 Multilib lib32-gcc-libs 6.3.1-1 Runtime libraries shipped by GCC (32-bit)
x86_64 Multilib gcc-multilib 6.3.1-1 The GNU Compiler Collection - C and C++ frontends for multilib
x86_64 Multilib gcc-objc-multilib 6.3.1-1 Objective-C front-end for GCC for multilib
x86_64 Testing linux-docs 4.9.3-1 Kernel hackers manual - HTML documentation that comes with the Linux kernel
x86_64 Testing linux 4.9.3-1 The Linux kernel and modules
x86_64 Testing linux-headers 4.9.3-1 Header files and scripts for building modules for Linux kernel
x86_64 Testing nvidia-304xx-dkms 304.134-2 NVIDIA driver sources for linux, 304xx legacy branch
x86_64 Testing nvidia-304xx 304.134-2 NVIDIA drivers for linux, 304xx legacy branch
x86_64 Testing foomatic-db-engine 4:4.0.12-3 Foomatic - Foomatic's database engine generates PPD files from the data in Foomatic's XML database. It also contains scripts to directly generate print queues and handle jobs.
x86_64 Testing php-dblib 7.1.1RC1-1 dblib module for PHP
x86_64 Testing php-imap 7.1.1RC1-1 imap module for PHP
x86_64 Testing php 7.1.1RC1-1 A general-purpose scripting language that is especially suited to web development
x86_64 Testing php-odbc 7.1.1RC1-1 ODBC modules for PHP
x86_64 Testing php-gd 7.1.1RC1-1 gd module for PHP
x86_64 Testing php-fpm 7.1.1RC1-1 FastCGI Process Manager for PHP
x86_64 Testing php-embed 7.1.1RC1-1 Embedded PHP SAPI library
x86_64 Testing php-apache 7.1.1RC1-1 Apache SAPI for PHP
x86_64 Testing php-pspell 7.1.1RC1-1 pspell module for PHP
x86_64 Testing php-mcrypt 7.1.1RC1-1 mcrypt module for PHP
x86_64 Testing php-enchant 7.1.1RC1-1 enchant module for PHP
x86_64 Testing php-cgi 7.1.1RC1-1 CGI and FCGI SAPI for PHP
x86_64 Testing php-phpdbg 7.1.1RC1-1 Interactive PHP debugger
x86_64 Testing php-pgsql 7.1.1RC1-1 PostgreSQL modules for PHP
x86_64 Testing php-intl 7.1.1RC1-1 intl module for PHP
x86_64 Testing php-tidy 7.1.1RC1-1 tidy module for PHP
x86_64 Testing php-snmp 7.1.1RC1-1 snmp module for PHP
x86_64 Testing php-xsl 7.1.1RC1-1 xsl module for PHP
x86_64 Testing php-sqlite 7.1.1RC1-1 sqlite module for PHP
x86_64 Testing foomatic-db-gutenprint-ppds 5.2.12-1 simplified prebuilt ppd files
x86_64 Testing gutenprint 5.2.12-1 Top quality printer drivers for POSIX systems
x86_64 Testing nano 2.7.4-1 Pico editor clone with enhancements
x86_64 Testing gnutls 3.5.8-2 A library which provides a secure layer over a reliable transport layer
x86_64 Testing libldap 2.4.44-3 Lightweight Directory Access Protocol (LDAP) client libraries
x86_64 Testing openldap 2.4.44-3 Lightweight Directory Access Protocol (LDAP) client and server
x86_64 Testing lz4 1:1.7.5-1 Extremely fast compression algorithm
x86_64 Community-Testing r8168 8.043.02-2 A kernel module for Realtek 8168 network cards
x86_64 Community-Testing nrpe 3.0.1-2 Nagios Remote Plugin Executor
AUR
firefox-aurora 52.0a2.20170113004016-1
hipchat 4.29.4.1662-1
spotio 1.0.2_1.0.47.13.gd8e05b1f.-1
prosody-hg r7822+.4caaa0c185f1+-1
mingw-w64-libsrtp 1.5.4-1
wxmaxima-git r4013.6cc2f04b-1
vicare-scheme-git 20170113.4066f247-1
aosuke-git 20170113-1
linux-rc 4.9.4rc1-1
linux-rc-headers 4.9.4rc1-1
ring-daemon 1:2.1.0.r839.gbc29db5f4-1
opendht 1:1.2.1.r55.ge7295ba-1
adapta-gtk-theme 3.89.2.88-1
spflashtool-bin 5.1648-1
texinfo-svn 7625-1
THanks
Posted ImagePosted Image
Configs/PGP Key/comhack π
#2008 OFFLINE   securitybreach
  • 24,208 posts
Posted 15 January 2017 - 08:46 PM
Updates for Saturday, January 14, 2016
Any
any Community python-bleach 1.5.0-3 An easy whitelist-based HTML-sanitizing tool
any Community python2-bleach 1.5.0-3 An easy whitelist-based HTML-sanitizing tool
any Community python2-signedjson 1.0.0-2 Sign JSON with Ed25519 signatures
any Community python-signedjson 1.0.0-2 Sign JSON with Ed25519 signatures
any Community python-unpaddedbase64 1.1.0-2 Unpadded Base64
any Community python2-unpaddedbase64 1.1.0-2 Unpadded Base64
any Community python2-canonicaljson 1.0.0-2 Canonical JSON
any Community python-canonicaljson 1.0.0-2 Canonical JSON
any Community python2-frozendict 1.2-2 An immutable dictionary
any Community python-frozendict 1.2-2 An immutable dictionary
any Community python-daemonize 2.4.7-2 Library to enable your code run as a daemon process on Unix-like systems
any Community python2-daemonize 2.4.7-2 Library to enable your code run as a daemon process on Unix-like systems
any Community vim-bufexplorer 7.4.12-1 A simple buffer list/switcher for vim
any Community mate-themes 3.22.6-1 Default themes for the MATE desktop
any Community python2-pafy 0.5.3-1 Python API for YouTube
any Community python-pafy 0.5.3-1 Python API for YouTube
any Community sagemath-doc 7.5-3 HTML documentation and inline help for SageMath
any Community sagemath-src 7.5-3 Source files for SageMath
any Community youtube-dl 2017.01.14-1 A small command-line program to download videos from YouTube.com and a few more sites
any Community python-braintree 3.34.0-1 Braintree Python Library
any Community python2-braintree 3.34.0-1 Braintree Python Library
any Community python-phonenumbers 8.0.1-1 Python version of Google's common library for parsing, formatting, storing and validating international phone numbers
any Community python2-phonenumbers 8.0.1-1 Python version of Google's common library for parsing, formatting, storing and validating international phone numbers
any Community ttf-liberation 2.00.1-7 Red Hats Liberation fonts.
any Community vim-latexsuite 1:1.9.0-2 Tools to view, edit, and compile LaTeX documents within Vim.
any Community vim-jedi 0.8.0-3 Vim plugin for jedi, an awesome Python autocompletion.
any Community vim-ultisnips 3.1-3 TextMate-style snippets for Vim.
any Community vim-ctrlp 1.80-1 Fuzzy file, buffer, mru, tag, etc finder.
any Community vim-supertab 2.1-2 A Vim plugin that allows you to use the tab key to do all insert completion.
any Community vim-syntastic 3.8.0-2 Automatic syntax checking for Vim
any Community deepin-go-lib 0.5.3-1 A library containing many useful go routines for things such as glib, gettext, archive, graphic,etc.
any Community python2-jsonpatch 1.15-1 An implementation of the JSON Patch format
any Community python-jsonpatch 1.15-1 An implementation of the JSON Patch format
any Extra adwaita-icon-theme 3.22.0+1+g58cd459e-1 GNOME standard icons
any Extra dkms 2.3-2 Dynamic Kernel Modules System
any Extra ttf-bitstream-vera 1.10-11 Bitstream Vera fonts.
any Extra ttf-hack 2.020-2 A hand groomed and optically balanced typeface based on Bitstream Vera Mono.
any Extra grml-zsh-config 0.13.1-1 grml's zsh setup
any Testing oxygen-icons 1:5.30.0-1 The Oxygen Icon Theme
any Testing oxygen-icons-svg 1:5.30.0-1 The Oxygen Icon Theme (Scalable Vector Graphics)
any Testing kapidox 5.30.0-1 Frameworks API Documentation Tools
any Testing breeze-icons 5.30.0-1 Breeze icon themes
any Testing extra-cmake-modules 5.30.0-1 Extra modules and scripts for CMake
i686
i686 Core lz4 1:1.7.5-1 Extremely fast compression algorithm
i686 Core openldap 2.4.44-3 Lightweight Directory Access Protocol (LDAP) client and server
i686 Core libldap 2.4.44-3 Lightweight Directory Access Protocol (LDAP) client libraries
i686 Community rofi 1.3.1-1 Popup window switcher roughly based on superswitcher, requiring only xlib and xft
i686 Community msgpack-c 2.1.0-1 An efficient object serialization library
i686 Community python2-pynacl 1.0.1-3 Python binding to the Networking and Cryptography (NaCl) library
i686 Community python-pynacl 1.0.1-3 Python binding to the Networking and Cryptography (NaCl) library
i686 Community openscenegraph 3.4.0-5 An Open Source, high performance real-time graphics toolkit
i686 Community remmina 1:1.2.0rcgit.16-2 remote desktop client written in GTK+
i686 Community perl-term-readline-gnu 1.35-1 GNU Readline XS library wrapper
i686 Community pkgconf 1.1.1-1 Light pkg-config replacement
i686 Community zathura-djvu 0.2.6-1 DjVu support for Zathura
i686 Community zathura-pdf-mupdf 0.3.1-1 PDF support for Zathura (MuPDF backend)
i686 Community zathura-ps 0.2.4-1 Adds ps support to zathura by using the libspectre library
i686 Community zathura 0.3.7-1 Minimalistic document viewer
i686 Community zathura-pdf-poppler 0.2.7-1 Adds pdf support to zathura by using the poppler engine
i686 Community ucarp 1.5.2-6 Userspace implementation of the CARP protocol
i686 Community girara 0.2.7-1 User interface library focused on simplicity and minimalism
i686 Community zathura-cb 0.1.6-1 Adds comic book support to zathura
i686 Community vlan 1.9-4 Virtual LAN configuration utility
i686 Community lldpd 0.9.5-3 802.1ab implementation (LLDP) to help you locate neighbors
i686 Community mailman 2.1.23-2 The GNU Mailing List Manager
i686 Community ndisc6 1.0.3-2 Collection of IPv6 networking utilities
i686 Community znc 1.6.4-4 An IRC bouncer with modules & scripts support
i686 Community drbd-utils 8.9.10-1 Userland tools for Distributed Replicated Block Device
i686 Community grafana 4.1.1-1 Gorgeous metric viz, dashboards & editors for Graphite, InfluxDB & OpenTSDB
i686 Community godep 2:77-1 Dependency tool for go
i686 Community ipvsadm 1.29-1 The IP Virtual Server administration utility
i686 Community ruby-cairo 1.15.5-1 Ruby bindings for cairo
i686 Community lockdev 1.0.3_1.6-4 Run-time shared library for locking devices, using _both_ FSSTND and SVr4 methods.
i686 Community minbif 1.0.5-7 An IRC gateway to IM networks that uses libpurple.
i686 Community calcurse 4.2.2-1 A text-based personal organizer.
i686 Community deepin-tool-kit 0.2.1-1 Base development tool of all C++/Qt Developer work on Deepin
i686 Community deepin-daemon 3.0.25-1 Daemon handling the DDE session settings
i686 Community deepin-session-ui 3.0.23-1 Deepin desktop-environment - Session UI module
i686 Community deepin-file-manager 1:1.3.6-2 Deepin File Manager
i686 Community deepin-api 3.0.16-1 Go-lang bingdings for dde-daemon
i686 Community deepin-launcher 4.0.4-1 Deepin desktop-environment - Launcher module
i686 Community deepin-control-center 3.0.24-3 New control center for linux deepin
i686 Community deepin-desktop 4.0.0-4 Deepin desktop-environment - Desktop module
i686 Community startdde 3.0.14-1 starter of deepin desktop environment
i686 Community deepin-notifications 2.3.9-1 System notifications for linuxdeepin desktop environment
i686 Community deepin-dbus-factory 3.0.9-1 GO DBus factory for DDE
i686 Extra dconf-editor 3.22.3-1 dconf Editor
i686 Extra quagga 1.1.0-3 BGP/OSPF/ISIS/RIP/RIPNG routing daemon suite
i686 Extra lirc 1:0.9.4.c-4 Linux Infrared Remote Control utilities
i686 Extra lighttpd 1.4.45-1 A secure, fast, compliant and very flexible web-server
i686 Extra krdc 16.12.1-2 Remote Desktop Client
i686 Testing kcoreaddons 5.30.1-1 Addons to QtCore
i686 Testing nfs-utils 2.1.1-1 Support programs for Network File Systems
i686 Testing ktextwidgets 5.30.0-1 Advanced text editing widgets
i686 Testing khtml 5.30.0-1 KHTML APIs
i686 Testing networkmanager-qt 5.30.0-1 Qt wrapper for NetworkManager API
i686 Testing kwallet 5.30.0-1 Secure and unified container for user passwords
i686 Testing kpackage 5.30.0-1 Framework that lets applications manage user installable packages of non-binary assets
i686 Testing kpeople 5.30.0-1 A library that provides access to all contacts and the people who hold them
i686 Testing bluez-qt 5.30.0-1 Qt wrapper for Bluez 5 DBus API
i686 Testing kdelibs4support 5.30.0-1 Porting aid from KDELibs4
i686 Testing kross 5.30.0-1 Multi-language application scripting
i686 Testing solid 5.30.0-1 Hardware integration and detection
i686 Testing knotifyconfig 5.30.0-1 Configuration system for KNotify
i686 Testing kdeclarative 5.30.0-1 Provides integration of QML and KDE Frameworks
i686 Testing kwayland 5.30.0-1 Qt-style Client and Server library wrapper for the Wayland libraries
i686 Testing kservice 5.30.0-1 Advanced plugin and service introspection
i686 Testing kconfigwidgets 5.30.0-1 Widgets for KConfig
i686 Testing modemmanager-qt 5.30.0-1 Qt wrapper for ModemManager DBus API
i686 Testing kunitconversion 5.30.0-1 Support for unit conversion
i686 Testing prison 5.30.0-1 A barcode API to produce QRCode barcodes and DataMatrix barcodes
i686 Testing kauth 5.30.0-1 Abstraction to system policy and authentication features
i686 Testing baloo 5.30.0-1 A framework for searching and managing metadata
i686 Testing kjs 5.30.0-1 Support for JS scripting in applications
i686 Testing kdesu 5.30.0-1 Integration with su for elevated privileges
i686 Testing kguiaddons 5.30.0-1 Addons to QtGui
i686 Testing kwindowsystem 5.30.0-1 Access to the windowing system
i686 Testing kcrash 5.30.0-1 Support for application crash analysis and bug report from apps
i686 Testing kparts 5.30.0-1 Document centric plugin system
i686 Testing kitemmodels 5.30.0-1 Models for Qt Model/View system
i686 Testing ktexteditor 5.30.0-1 Advanced embeddable text editor
i686 Testing kidletime 5.30.0-1 Monitoring user activity
i686 Testing attica-qt5 5.30.0-1 Qt5 library that implements the Open Collaboration Services API
i686 Testing kconfig 5.30.0-1 Configuration system
i686 Testing kcodecs 5.30.0-1 Provide a collection of methods to manipulate strings using various encodings
i686 Testing kcmutils 5.30.0-1 Utilities for interacting with KCModules
i686 Testing kdesignerplugin 5.30.0-1 Integration of Frameworks widgets in Qt Designer/Creator
i686 Testing kdewebkit 5.30.0-1 KDE Integration for QtWebKit
i686 Testing kded 5.30.0-1 Extensible deamon for providing system level services
i686 Testing kjsembed 5.30.0-1 Embedded JS
i686 Testing sonnet 5.30.0-1 Spelling framework for Qt5
i686 Testing kio 5.30.0-1 Resource and network access abstraction
i686 Testing plasma-framework 5.30.0-1 Plasma library and runtime components based upon KF5 and Qt5
i686 Testing frameworkintegration 5.30.0-1 Framework providing components to allow applications to integrate with a KDE Workspace
i686 Testing kdbusaddons 5.30.0-1 Addons to QtDBus
i686 Testing karchive 5.30.0-1 Qt 5 addon providing access to numerous types of archives
i686 Testing kglobalaccel 5.30.0-1 Add support for global workspace shortcuts
i686 Testing kemoticons 5.30.0-1 Support for emoticons and emoticons themes
i686 Testing kitemviews 5.30.0-1 Widget addons for Qt Model/View
i686 Testing kactivities-stats 5.30.0-1 A library for accessing the usage data collected by the activities system
i686 Testing krunner 5.30.0-1 Framework for providing different actions given a string query
i686 Testing kfilemetadata 5.30.0-1 A library for extracting file metadata
i686 Testing kactivities 5.30.0-1 Core components for the KDE's Activities
i686 Testing ki18n 5.30.0-1 Advanced internationalization framework
i686 Testing kxmlgui 5.30.0-1 User configurable main windows
i686 Testing kplotting 5.30.0-1 Lightweight plotting framework
i686 Testing kiconthemes 5.30.0-1 Support for icon themes
i686 Testing kwidgetsaddons 5.30.0-1 Addons to QtWidgets
i686 Testing threadweaver 5.30.0-1 High-level multithreading framework
i686 Testing syntax-highlighting 5.30.0-1 Syntax highlighting engine for structured text and code
i686 Testing kimageformats 5.30.0-1 Image format plugins for Qt5
i686 Testing kcompletion 5.30.0-1 Text completion helpers and widgets
i686 Testing kjobwidgets 5.30.0-1 Widgets for tracking KJob instances
i686 Testing kinit 5.30.0-1 Process launcher to speed up launching KDE applications
i686 Testing kxmlrpcclient 5.30.0-1 XML-RPC client library for KDE
i686 Testing kpty 5.30.0-1 Pty abstraction
i686 Testing kdnssd 5.30.0-1 Abstraction to system DNSSD features
i686 Testing kmediaplayer 5.30.0-1 Plugin interface for media player features
i686 Testing kbookmarks 5.30.0-1 Support for bookmarks and the XBEL format
i686 Testing knotifications 5.30.0-1 Abstraction for system notifications
i686 Testing kdoctools 5.30.0-1 Documentation generation from docbook
i686 Testing hefur 0.4-10 A standalone and lightweight BitTorrent tracker
i686 Testing protobuf-c 1.2.1-4 Protocol Buffers implementation in C
i686 Testing protobuf 3.1.0-1 Protocol Buffers - Google's data interchange format
i686 Testing libgadu 1.12.1-3 This library implements the client side of the Gadu-Gadu protocol
i686 Testing python-protobuf 3.1.0-1 Python 3 bindings for Google Protocol Buffers
i686 Testing libphonenumber 8.0.0-2 Google's common library for parsing, formatting, and validating international phone numbers
i686 Testing python2-protobuf 3.1.0-1 Python 2 bindings for Google Protocol Buffers
i686 Testing qt5-webengine 5.7.1-2 Provides support for web applications using the Chromium browser project
i686 Testing libarchive 3.2.2-2 library that can create and read several streaming archive formats
i686 Community-Testing clementine 1.3.1-6 A modern music player and library organizer
i686 Community-Testing mumble 1.2.18-2 A voice chat application similar to TeamSpeak
i686 Community-Testing rethinkdb 2.3.5-3 Distributed powerful and scalable NoSQL database
i686 Community-Testing collectd 5.7.0-2 Daemon which collects system performance statistics periodically
i686 Community-Testing umurmur 0.2.16_a-5 Minimalistic Mumble server
i686 Community-Testing hyperion 1.03.2-8 An opensource 'AmbiLight' implementation
i686 Community-Testing mosh 1.2.6-3 Mobile shell, surviving disconnects with local echo and line editing
i686 Community-Testing pokerth 1.1.1-16 Open source Texas Hold'em Poker simulator
i686 Community-Testing powerdns 4.0.1-7 Authoritative DNS server
i686 Community-Testing powerdns-recursor 4.0.3-7 Resolving DNS server
i686 Community-Testing mixxx 2.0.0-6 Free, open source software for digital DJ'ing.
i686 Community-Testing murmur 1.2.18-3 The voice chat application server for Mumble
i686 Community-Testing bitcoin-cli 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - RPC client
i686 Community-Testing bitcoin-qt 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - Qt
i686 Community-Testing bitcoin-tx 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - Transaction tool
i686 Community-Testing bitcoin-daemon 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - daemon
x86_64
x86_64 Core lz4 1:1.7.5-1 Extremely fast compression algorithm
x86_64 Core openldap 2.4.44-3 Lightweight Directory Access Protocol (LDAP) client and server
x86_64 Core libldap 2.4.44-3 Lightweight Directory Access Protocol (LDAP) client libraries
x86_64 Community rofi 1.3.1-1 Popup window switcher roughly based on superswitcher, requiring only xlib and xft
x86_64 Community msgpack-c 2.1.0-1 An efficient object serialization library
x86_64 Community python2-pynacl 1.0.1-3 Python binding to the Networking and Cryptography (NaCl) library
x86_64 Community python-pynacl 1.0.1-3 Python binding to the Networking and Cryptography (NaCl) library
x86_64 Community openscenegraph 3.4.0-5 An Open Source, high performance real-time graphics toolkit
x86_64 Community remmina 1:1.2.0rcgit.16-2 remote desktop client written in GTK+
x86_64 Community perl-term-readline-gnu 1.35-1 GNU Readline XS library wrapper
x86_64 Community pkgconf 1.1.1-1 Light pkg-config replacement
x86_64 Community zathura-djvu 0.2.6-1 DjVu support for Zathura
x86_64 Community zathura-pdf-mupdf 0.3.1-1 PDF support for Zathura (MuPDF backend)
x86_64 Community zathura-ps 0.2.4-1 Adds ps support to zathura by using the libspectre library
x86_64 Community zathura 0.3.7-1 Minimalistic document viewer
x86_64 Community zathura-pdf-poppler 0.2.7-1 Adds pdf support to zathura by using the poppler engine
x86_64 Community ucarp 1.5.2-6 Userspace implementation of the CARP protocol
x86_64 Community girara 0.2.7-1 User interface library focused on simplicity and minimalism
x86_64 Community zathura-cb 0.1.6-1 Adds comic book support to zathura
x86_64 Community vlan 1.9-4 Virtual LAN configuration utility
x86_64 Community lldpd 0.9.5-3 802.1ab implementation (LLDP) to help you locate neighbors
x86_64 Community mailman 2.1.23-2 The GNU Mailing List Manager
x86_64 Community ndisc6 1.0.3-2 Collection of IPv6 networking utilities
x86_64 Community znc 1.6.4-4 An IRC bouncer with modules & scripts support
x86_64 Community drbd-utils 8.9.10-1 Userland tools for Distributed Replicated Block Device
x86_64 Community grafana 4.1.1-1 Gorgeous metric viz, dashboards & editors for Graphite, InfluxDB & OpenTSDB
x86_64 Community godep 2:77-1 Dependency tool for go
x86_64 Community ipvsadm 1.29-1 The IP Virtual Server administration utility
x86_64 Community ruby-cairo 1.15.5-1 Ruby bindings for cairo
x86_64 Community lockdev 1.0.3_1.6-4 Run-time shared library for locking devices, using _both_ FSSTND and SVr4 methods.
x86_64 Community minbif 1.0.5-7 An IRC gateway to IM networks that uses libpurple.
x86_64 Community calcurse 4.2.2-1 A text-based personal organizer.
x86_64 Community deepin-tool-kit 0.2.1-1 Base development tool of all C++/Qt Developer work on Deepin
x86_64 Community deepin-daemon 3.0.25-1 Daemon handling the DDE session settings
x86_64 Community deepin-session-ui 3.0.23-1 Deepin desktop-environment - Session UI module
x86_64 Community deepin-file-manager 1:1.3.6-2 Deepin File Manager
x86_64 Community deepin-api 3.0.16-1 Go-lang bingdings for dde-daemon
x86_64 Community deepin-launcher 4.0.4-1 Deepin desktop-environment - Launcher module
x86_64 Community deepin-control-center 3.0.24-3 New control center for linux deepin
x86_64 Community deepin-desktop 4.0.0-4 Deepin desktop-environment - Desktop module
x86_64 Community startdde 3.0.14-1 starter of deepin desktop environment
x86_64 Community deepin-notifications 2.3.9-1 System notifications for linuxdeepin desktop environment
x86_64 Community deepin-dbus-factory 3.0.9-1 GO DBus factory for DDE
x86_64 Extra dconf-editor 3.22.3-1 dconf Editor
x86_64 Extra quagga 1.1.0-3 BGP/OSPF/ISIS/RIP/RIPNG routing daemon suite
x86_64 Extra lirc 1:0.9.4.c-4 Linux Infrared Remote Control utilities
x86_64 Extra lighttpd 1.4.45-1 A secure, fast, compliant and very flexible web-server
x86_64 Extra krdc 16.12.1-2 Remote Desktop Client
x86_64 Testing kcoreaddons 5.30.1-1 Addons to QtCore
x86_64 Testing nfs-utils 2.1.1-1 Support programs for Network File Systems
x86_64 Testing ktextwidgets 5.30.0-1 Advanced text editing widgets
x86_64 Testing khtml 5.30.0-1 KHTML APIs
x86_64 Testing networkmanager-qt 5.30.0-1 Qt wrapper for NetworkManager API
x86_64 Testing kwallet 5.30.0-1 Secure and unified container for user passwords
x86_64 Testing kpackage 5.30.0-1 Framework that lets applications manage user installable packages of non-binary assets
x86_64 Testing kpeople 5.30.0-1 A library that provides access to all contacts and the people who hold them
x86_64 Testing bluez-qt 5.30.0-1 Qt wrapper for Bluez 5 DBus API
x86_64 Testing kdelibs4support 5.30.0-1 Porting aid from KDELibs4
x86_64 Testing kross 5.30.0-1 Multi-language application scripting
x86_64 Testing solid 5.30.0-1 Hardware integration and detection
x86_64 Testing knotifyconfig 5.30.0-1 Configuration system for KNotify
x86_64 Testing kdeclarative 5.30.0-1 Provides integration of QML and KDE Frameworks
x86_64 Testing kwayland 5.30.0-1 Qt-style Client and Server library wrapper for the Wayland libraries
x86_64 Testing kservice 5.30.0-1 Advanced plugin and service introspection
x86_64 Testing kconfigwidgets 5.30.0-1 Widgets for KConfig
x86_64 Testing modemmanager-qt 5.30.0-1 Qt wrapper for ModemManager DBus API
x86_64 Testing kunitconversion 5.30.0-1 Support for unit conversion
x86_64 Testing prison 5.30.0-1 A barcode API to produce QRCode barcodes and DataMatrix barcodes
x86_64 Testing kauth 5.30.0-1 Abstraction to system policy and authentication features
x86_64 Testing baloo 5.30.0-1 A framework for searching and managing metadata
x86_64 Testing kjs 5.30.0-1 Support for JS scripting in applications
x86_64 Testing kdesu 5.30.0-1 Integration with su for elevated privileges
x86_64 Testing kguiaddons 5.30.0-1 Addons to QtGui
x86_64 Testing kwindowsystem 5.30.0-1 Access to the windowing system
x86_64 Testing kcrash 5.30.0-1 Support for application crash analysis and bug report from apps
x86_64 Testing kparts 5.30.0-1 Document centric plugin system
x86_64 Testing kitemmodels 5.30.0-1 Models for Qt Model/View system
x86_64 Testing ktexteditor 5.30.0-1 Advanced embeddable text editor
x86_64 Testing kidletime 5.30.0-1 Monitoring user activity
x86_64 Testing attica-qt5 5.30.0-1 Qt5 library that implements the Open Collaboration Services API
x86_64 Testing kconfig 5.30.0-1 Configuration system
x86_64 Testing kcodecs 5.30.0-1 Provide a collection of methods to manipulate strings using various encodings
x86_64 Testing kcmutils 5.30.0-1 Utilities for interacting with KCModules
x86_64 Testing kdesignerplugin 5.30.0-1 Integration of Frameworks widgets in Qt Designer/Creator
x86_64 Testing kdewebkit 5.30.0-1 KDE Integration for QtWebKit
x86_64 Testing kded 5.30.0-1 Extensible deamon for providing system level services
x86_64 Testing kjsembed 5.30.0-1 Embedded JS
x86_64 Testing sonnet 5.30.0-1 Spelling framework for Qt5
x86_64 Testing kio 5.30.0-1 Resource and network access abstraction
x86_64 Testing plasma-framework 5.30.0-1 Plasma library and runtime components based upon KF5 and Qt5
x86_64 Testing frameworkintegration 5.30.0-1 Framework providing components to allow applications to integrate with a KDE Workspace
x86_64 Testing kdbusaddons 5.30.0-1 Addons to QtDBus
x86_64 Testing karchive 5.30.0-1 Qt 5 addon providing access to numerous types of archives
x86_64 Testing kglobalaccel 5.30.0-1 Add support for global workspace shortcuts
x86_64 Testing kemoticons 5.30.0-1 Support for emoticons and emoticons themes
x86_64 Testing kitemviews 5.30.0-1 Widget addons for Qt Model/View
x86_64 Testing kactivities-stats 5.30.0-1 A library for accessing the usage data collected by the activities system
x86_64 Testing krunner 5.30.0-1 Framework for providing different actions given a string query
x86_64 Testing kfilemetadata 5.30.0-1 A library for extracting file metadata
x86_64 Testing kactivities 5.30.0-1 Core components for the KDE's Activities
x86_64 Testing ki18n 5.30.0-1 Advanced internationalization framework
x86_64 Testing kxmlgui 5.30.0-1 User configurable main windows
x86_64 Testing kplotting 5.30.0-1 Lightweight plotting framework
x86_64 Testing kiconthemes 5.30.0-1 Support for icon themes
x86_64 Testing kwidgetsaddons 5.30.0-1 Addons to QtWidgets
x86_64 Testing threadweaver 5.30.0-1 High-level multithreading framework
x86_64 Testing syntax-highlighting 5.30.0-1 Syntax highlighting engine for structured text and code
x86_64 Testing kimageformats 5.30.0-1 Image format plugins for Qt5
x86_64 Testing kcompletion 5.30.0-1 Text completion helpers and widgets
x86_64 Testing kjobwidgets 5.30.0-1 Widgets for tracking KJob instances
x86_64 Testing kinit 5.30.0-1 Process launcher to speed up launching KDE applications
x86_64 Testing kxmlrpcclient 5.30.0-1 XML-RPC client library for KDE
x86_64 Testing kpty 5.30.0-1 Pty abstraction
x86_64 Testing kdnssd 5.30.0-1 Abstraction to system DNSSD features
x86_64 Testing kmediaplayer 5.30.0-1 Plugin interface for media player features
x86_64 Testing kbookmarks 5.30.0-1 Support for bookmarks and the XBEL format
x86_64 Testing knotifications 5.30.0-1 Abstraction for system notifications
x86_64 Testing kdoctools 5.30.0-1 Documentation generation from docbook
x86_64 Testing hefur 0.4-10 A standalone and lightweight BitTorrent tracker
x86_64 Testing protobuf-c 1.2.1-4 Protocol Buffers implementation in C
x86_64 Testing protobuf 3.1.0-1 Protocol Buffers - Google's data interchange format
x86_64 Testing libgadu 1.12.1-3 This library implements the client side of the Gadu-Gadu protocol
x86_64 Testing python-protobuf 3.1.0-1 Python 3 bindings for Google Protocol Buffers
x86_64 Testing libphonenumber 8.0.0-2 Google's common library for parsing, formatting, and validating international phone numbers
x86_64 Testing python2-protobuf 3.1.0-1 Python 2 bindings for Google Protocol Buffers
x86_64 Testing qt5-webengine 5.7.1-2 Provides support for web applications using the Chromium browser project
x86_64 Testing libarchive 3.2.2-2 library that can create and read several streaming archive formats
x86_64 Community-Testing clementine 1.3.1-6 A modern music player and library organizer
x86_64 Community-Testing mumble 1.2.18-2 A voice chat application similar to TeamSpeak
x86_64 Community-Testing rethinkdb 2.3.5-3 Distributed powerful and scalable NoSQL database
x86_64 Community-Testing collectd 5.7.0-2 Daemon which collects system performance statistics periodically
x86_64 Community-Testing umurmur 0.2.16_a-5 Minimalistic Mumble server
x86_64 Community-Testing hyperion 1.03.2-8 An opensource 'AmbiLight' implementation
x86_64 Community-Testing mosh 1.2.6-3 Mobile shell, surviving disconnects with local echo and line editing
x86_64 Community-Testing pokerth 1.1.1-16 Open source Texas Hold'em Poker simulator
x86_64 Community-Testing powerdns 4.0.1-7 Authoritative DNS server
x86_64 Community-Testing powerdns-recursor 4.0.3-7 Resolving DNS server
x86_64 Community-Testing mixxx 2.0.0-6 Free, open source software for digital DJ'ing.
x86_64 Community-Testing murmur 1.2.18-3 The voice chat application server for Mumble
x86_64 Community-Testing bitcoin-cli 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - RPC client
x86_64 Community-Testing bitcoin-qt 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - Qt
x86_64 Community-Testing bitcoin-tx 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - Transaction tool
x86_64 Community-Testing bitcoin-daemon 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - daemon
AUR
pointcarrefs r10.0b9c56d-1
flent 1.0.1-1 2017-01-16
xpub 0.1-1 2017-01-16
firefox-developer-de 52.0a2_20170115-1
vokoscreen 2.5.3.beta-1
openlp 2.4.4-2
animewatch-pyqt5-git 4.0.0.r34.05178d5-1
animewatch-pyqt5 4.0.0-0
thinkpad-scripts 4.8.0-1
ruby-twitter 6.0.0-1
ruby-addressable 2.5.0-2
xdo-git 0.5.4-1
openra-kang kang.7855262-1
way-cooler-git 1:v0.4.2.r35.ga4dd326-1
adif2cabrillo 1.0.5-1
Thanks
#2009 OFFLINE   securitybreach
  • 24,208 posts
Posted 16 January 2017 - 07:07 PM
Updates for Sunday, January 15, 2016
Any
any Community ruby2.3-bundler 1.13.7-1 Manages an application's dependencies through its entire life, across many machines, systematically and repeatably.
any Community python-neovim 0.1.13-1 Python 3 client for neovim
any Community python2-neovim 0.1.13-1 Python 2 client for neovim
any Community inxi 2.3.8-1 script to get system information
any Community wordpress 4.7.1-1 Blog tool and publishing platform
any Community qutebrowser 0.9.1-3 A keyboard-driven, vim-like browser based on PyQt5 and QtWebKit
any Community lollypop 0.9.226-1 Music player for GNOME
any Community python2-acme 0.10.1-1 ACME protocol implementation in Python
any Community certbot-apache 0.10.1-1 Apache plugin for Let’s Encrypt client
any Community python-acme 0.10.1-1 ACME protocol implementation in Python
any Community certbot-nginx 0.10.1-1 Nginx plugin for Let’s Encrypt client
any Community certbot 0.10.1-1 A tool to automatically receive and install X.509 certificates to enable TLS on servers. The client will interoperate with the Let’s Encrypt CA which will be issuing browser-trusted certificates for free.
any Community perl-cpanplus 0.9162-1 Ameliorated interface to the CPAN
any Extra xorg-fonts-misc 1.0.3-5 X.org misc fonts
any Extra xorg-fonts-cyrillic 1.0.3-2 X.org cyrillic fonts
any Extra xorg-fonts-type1 7.7-2 X.org Type1 fonts
any Extra xorg-fonts-100dpi 1.0.3-3 X.org 100dpi fonts
any Extra xorg-fonts-75dpi 1.0.3-3 X.org 75dpi fonts
any Testing perl-image-exiftool 10.40-1 Reader and rewriter of EXIF informations that supports raw files
any Testing ttf-croscore 20170112-1 Chrome OS core fonts
any Testing noto-fonts 20170112-1 Google Noto TTF fonts
i686
i686 Core nano 2.7.4-1 Pico editor clone with enhancements
i686 Core gnutls 3.5.8-2 A library which provides a secure layer over a reliable transport layer
i686 Community cegui 0.8.7-7 A free library providing windowing and widgets for graphics APIs/engines
i686 Community ruby2.3 2.3.3-1 An object-oriented language for quick and easy programming
i686 Community ripgrep 0.4.0-1 A search tool that combines the usability of ag with the raw speed of grep
i686 Community linux-grsec 1:4.8.17.r201701151620-1 The Linux kernel and modules with grsecurity/PaX patches
i686 Community linux-grsec-headers 1:4.8.17.r201701151620-1 Header files and scripts for building modules for Linux-grsec kernel
i686 Community linux-grsec-docs 1:4.8.17.r201701151620-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
i686 Community tokei 5.0.6-1 A blazingly fast CLOC(Count Lines Of Code) program
i686 Community minetest-common 0.4.15-1 Common data files for minetest and minetest-server
i686 Community minetest 0.4.15-1 Multiplayer infinite-world block sandbox game
i686 Community minetest-server 0.4.15-1 Server of infinite-world block sandbox game
i686 Community sagemath 7.5.1-1 Open Source Mathematics Software, free alternative to Magma, Maple, Mathematica, and Matlab
i686 Community sagemath-jupyter 7.5.1-1 Jupyter kernel for SageMath
i686 Community highlight 3.34-1 Fast and flexible source code highlighter (CLI version)
i686 Community highlight-gui 3.34-1 Fast and flexible source code highlighter (Qt version)
i686 Community linbox 1.4.2-7 A template library for exact, high-performance linear algebra computation with dense, sparse, and structured matrices over the integers and over finite fields
i686 Community filezilla 3.24.0-1 Fast and reliable FTP, FTPS and SFTP client
i686 Community afl 2.36b-1 Security-oriented fuzzer using compile-time instrumentation and genetic algorithms
i686 Community pantheon-terminal 0.4.0.3-1 The Pantheon Terminal Emulator
i686 Community perl-mouse 2.4.7-1 Moose minus the antlers
i686 Community haskell-turtle 1.3.1-1 Shell programming, Haskell-style
i686 Community haskell-gtk2hs-buildtools 0.13.2.2-1 Tools to build the Gtk2Hs suite of User Interface libraries.
i686 Community atom 1.13.0-2 A hackable text editor for the 21st Century
i686 Community brial 0.8.5-3 Library for polynomials over boolean rings
i686 Community fflas-ffpack 2.2.2-3 A library for dense linear algebra over word-size finite fields
i686 Community apm 1.15.2-1 Atom package manager
i686 Extra python-crypto 2.6.1-5 Collection of cryptographic algorithms and protocols, implemented for use from Python 3.
i686 Extra python2-crypto 2.6.1-5 Collection of cryptographic algorithms and protocols, implemented for use from Python 2.
i686 Extra libvpx 1.6.1-1 VP8 and VP9 codec
i686 Extra nginx-mainline 1.11.8-2 Lightweight HTTP server and IMAP/POP3 proxy server, mainline release
i686 Extra nginx 1.10.2-3 Lightweight HTTP server and IMAP/POP3 proxy server
i686 Extra bitlbee 3.5-1 Brings instant messaging (XMPP, MSN, Yahoo!, AIM, ICQ, Twitter) to IRC
i686 Extra fsarchiver 0.8.1-1 Safe and flexible file-system backup and deployment tool
i686 Extra bubblewrap 0.1.6-1 Unprivileged sandboxing tool
i686 Extra wcslib 5.16-1 A C library that implements the 'World Coordinate System' (WCS) standard in FITS
i686 Extra mpd 0.20.2-1 Flexible, powerful, server-side application for playing music
i686 Extra akonadi 16.12.1-2 PIM layer, which provides an asynchronous API to access all kind of PIM data
i686 Extra system-config-printer 1.5.9-1 A CUPS printer configuration tool and status applet
i686 Extra foomatic-db-gutenprint-ppds 5.2.12-1 simplified prebuilt ppd files
i686 Extra gutenprint 5.2.12-1 Top quality printer drivers for POSIX systems
i686 Extra libinput 1.5.4-1 Input device management and event handling library
i686 Extra foomatic-db-engine 4:4.0.12-3 Foomatic - Foomatic's database engine generates PPD files from the data in Foomatic's XML database. It also contains scripts to directly generate print queues and handle jobs.
i686 Extra libwps 0.4.5-1 a Microsoft Works file word processor format import filter library
i686 Testing linux-zen-headers 4.9.4-1 Header files and scripts for building modules for Linux-zen kernel
i686 Testing linux-zen-docs 4.9.4-1 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
i686 Testing linux-zen 4.9.4-1 The Linux-zen kernel and modules
i686 Testing perl-crypt-openssl-bignum 0.07-1 OpenSSL's multiprecision integer arithmetic
i686 Testing perl 5.24.1-1 A highly capable, feature-rich programming language
i686 Testing fetchmail 6.3.26-5 A remote-mail retrieval utility
x86_64
x86_64 Core nano 2.7.4-1 Pico editor clone with enhancements
x86_64 Core gnutls 3.5.8-2 A library which provides a secure layer over a reliable transport layer
x86_64 Community cegui 0.8.7-7 A free library providing windowing and widgets for graphics APIs/engines
x86_64 Community ruby2.3 2.3.3-1 An object-oriented language for quick and easy programming
x86_64 Community ripgrep 0.4.0-1 A search tool that combines the usability of ag with the raw speed of grep
x86_64 Community linux-grsec 1:4.8.17.r201701151620-1 The Linux kernel and modules with grsecurity/PaX patches
x86_64 Community linux-grsec-headers 1:4.8.17.r201701151620-1 Header files and scripts for building modules for Linux-grsec kernel
x86_64 Community linux-grsec-docs 1:4.8.17.r201701151620-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
x86_64 Community tokei 5.0.6-1 A blazingly fast CLOC(Count Lines Of Code) program
x86_64 Community minetest-common 0.4.15-1 Common data files for minetest and minetest-server
x86_64 Community minetest 0.4.15-1 Multiplayer infinite-world block sandbox game
x86_64 Community minetest-server 0.4.15-1 Server of infinite-world block sandbox game
x86_64 Community sagemath 7.5.1-1 Open Source Mathematics Software, free alternative to Magma, Maple, Mathematica, and Matlab
x86_64 Community sagemath-jupyter 7.5.1-1 Jupyter kernel for SageMath
x86_64 Community highlight 3.34-1 Fast and flexible source code highlighter (CLI version)
x86_64 Community highlight-gui 3.34-1 Fast and flexible source code highlighter (Qt version)
x86_64 Community linbox 1.4.2-7 A template library for exact, high-performance linear algebra computation with dense, sparse, and structured matrices over the integers and over finite fields
x86_64 Community filezilla 3.24.0-1 Fast and reliable FTP, FTPS and SFTP client
x86_64 Community afl 2.36b-1 Security-oriented fuzzer using compile-time instrumentation and genetic algorithms
x86_64 Community pantheon-terminal 0.4.0.3-1 The Pantheon Terminal Emulator
x86_64 Community perl-mouse 2.4.7-1 Moose minus the antlers
x86_64 Community haskell-turtle 1.3.1-1 Shell programming, Haskell-style
x86_64 Community haskell-gtk2hs-buildtools 0.13.2.2-1 Tools to build the Gtk2Hs suite of User Interface libraries.
x86_64 Community atom 1.13.0-2 A hackable text editor for the 21st Century
x86_64 Community brial 0.8.5-3 Library for polynomials over boolean rings
x86_64 Community fflas-ffpack 2.2.2-3 A library for dense linear algebra over word-size finite fields
x86_64 Community apm 1.15.2-1 Atom package manager
x86_64 Extra python-crypto 2.6.1-5 Collection of cryptographic algorithms and protocols, implemented for use from Python 3.
x86_64 Extra python2-crypto 2.6.1-5 Collection of cryptographic algorithms and protocols, implemented for use from Python 2.
x86_64 Extra libvpx 1.6.1-1 VP8 and VP9 codec
x86_64 Extra nginx-mainline 1.11.8-2 Lightweight HTTP server and IMAP/POP3 proxy server, mainline release
x86_64 Extra nginx 1.10.2-3 Lightweight HTTP server and IMAP/POP3 proxy server
x86_64 Extra bitlbee 3.5-1 Brings instant messaging (XMPP, MSN, Yahoo!, AIM, ICQ, Twitter) to IRC
x86_64 Extra fsarchiver 0.8.1-1 Safe and flexible file-system backup and deployment tool
x86_64 Extra bubblewrap 0.1.6-1 Unprivileged sandboxing tool
x86_64 Extra wcslib 5.16-1 A C library that implements the 'World Coordinate System' (WCS) standard in FITS
x86_64 Extra mpd 0.20.2-1 Flexible, powerful, server-side application for playing music
x86_64 Extra akonadi 16.12.1-2 PIM layer, which provides an asynchronous API to access all kind of PIM data
x86_64 Extra system-config-printer 1.5.9-1 A CUPS printer configuration tool and status applet
x86_64 Extra foomatic-db-gutenprint-ppds 5.2.12-1 simplified prebuilt ppd files
x86_64 Extra gutenprint 5.2.12-1 Top quality printer drivers for POSIX systems
x86_64 Extra libinput 1.5.4-1 Input device management and event handling library
x86_64 Extra foomatic-db-engine 4:4.0.12-3 Foomatic - Foomatic's database engine generates PPD files from the data in Foomatic's XML database. It also contains scripts to directly generate print queues and handle jobs.
x86_64 Extra libwps 0.4.5-1 a Microsoft Works file word processor format import filter library
x86_64 Multilib lib32-libnl 3.2.29-1 Library for applications dealing with netlink sockets (32 bit)
x86_64 Multilib lib32-sqlite 3.16.2-1 A C library that implements an SQL database engine (32-bit)
x86_64 Multilib lib32-libelf 0.168-1 Libraries to handle ELF object files and DWARF debugging information (32-bit)
x86_64 Multilib lib32-dbus 1.10.14-1 Freedesktop.org message bus system (32-bit)
x86_64 Multilib lib32-zlib 1.2.11-1 Compression library implementing the deflate compression method found in gzip and PKZIP (32-bit)
x86_64 Multilib lib32-libvpx 1.6.1-1 VP8 and VP9 codec
x86_64 Multilib lib32-flex 2.6.3-1 A tool for generating text-scanning programs
x86_64 Multilib lib32-libwebp 0.5.2-1 WebP library
x86_64 Testing perl 5.24.1-1 A highly capable, feature-rich programming language
x86_64 Testing fetchmail 6.3.26-5 A remote-mail retrieval utility
x86_64 Testing perl-crypt-openssl-bignum 0.07-1 OpenSSL's multiprecision integer arithmetic
x86_64 Testing linux-zen-headers 4.9.4-1 Header files and scripts for building modules for Linux-zen kernel
x86_64 Testing linux-zen-docs 4.9.4-1 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
x86_64 Testing linux-zen 4.9.4-1 The Linux-zen kernel and modules
AUR
python2-sqlalchemy-git 1.1.4.38.g46828cc15-1
python-sqlalchemy-git 1.1.4.38.g46828cc15-1
octave-hg 4.3.0+23054.564e959a0e89-1
genie-git r740.ac163e6-1
apache-spark 2.1.0-1
grive 0.5.0-6
gxplugins-lv2-git r4.aa71176-1
hop-git 3.0.0r787.2eb60ab-1
emacs-org-mode-git 9.0.3.225.gfe9e60d61-1
bbswitch-pf 0.8-37
nvidia-pf 375.26-4
maxima-git 5.39.1.55.gee1445efa-1
linux-pf-headers 4.9.3-1
linux-pf 4.9.3-1
linux-pf-preset-default 4.9.3-1
Thanks
#2010 OFFLINE   securitybreach
  • 24,208 posts
Posted 19 January 2017 - 07:33 PM
Updates for Wednesday, January 18, 2016
Any
any Community python-cherrypy 8.9.1-1 A pythonic, object-oriented web development framework
any Community python2-cherrypy 8.9.1-1 A pythonic, object-oriented web development framework
any Community lollypop 0.9.228-1 Music player for GNOME
any Community intellij-idea-community-edition 2:2016.3.3-1 IDE for Java, Groovy and other programming languages with advanced refactoring features
any Community uwsgitop 0.10-1 uWSGI top-like app
any Community python-netaddr 0.7.19-1 Pure Python network address representation and manipulation library
any Community python2-netaddr 0.7.19-1 Pure Python network address representation and manipulation library
any Community cloc 1.72-1 Count lines of code
any Community shorewall 5.1.0.1-1 An iptables-based firewall for Linux systems
any Community shorewall6 5.1.0.1-1 An iptables-based firewall for Linux systems (with IPv6 support)
any Community shorewall-core 5.1.0.1-1 Core Shorewall libraries
any Community python-docker 2.0.1-1 A Python library for the Docker Engine API
any Community python2-docker 2.0.1-1 A Python library for the Docker Engine API
any Community python2-openstackclient 3.7.0-1 OpenStack Command-line Client
any Community python-openstackclient 3.7.0-1 OpenStack Command-line Client
any Extra ttf-croscore 20170112-1 Chrome OS core fonts
any Extra xorg-mkfontdir 1.0.7-7 Create an index of X font files in a directory
any Extra noto-fonts 20170112-1 Google Noto TTF fonts
any Extra publicsuffix-list 20170118.560.45a2bf8-1 Cross-vendor public domain suffix database
i686
i686 Core libtasn1 4.10-1 The ASN.1 library used in GNUTLS
i686 Core nfs-utils 2.1.1-1 Support programs for Network File Systems
i686 Community mosh 1.2.6-3 Mobile shell, surviving disconnects with local echo and line editing
i686 Community umurmur 0.2.16_a-5 Minimalistic Mumble server
i686 Community pokerth 1.1.1-16 Open source Texas Hold'em Poker simulator
i686 Community bitcoin-daemon 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - daemon
i686 Community bitcoin-qt 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - Qt
i686 Community mumble 1.2.18-2 A voice chat application similar to TeamSpeak
i686 Community hyperion 1.03.2-8 An opensource 'AmbiLight' implementation
i686 Community collectd 5.7.0-2 Daemon which collects system performance statistics periodically
i686 Community rethinkdb 2.3.5-3 Distributed powerful and scalable NoSQL database
i686 Community mixxx 2.0.0-6 Free, open source software for digital DJ'ing.
i686 Community murmur 1.2.18-3 The voice chat application server for Mumble
i686 Community bitcoin-tx 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - Transaction tool
i686 Community clementine 1.3.1-6 A modern music player and library organizer
i686 Community bitcoin-cli 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - RPC client
i686 Community pan 0.141-2 A powerful Newsgroup Article reader
i686 Community sagemath 7.5.1-2 Open Source Mathematics Software, free alternative to Magma, Maple, Mathematica, and Matlab
i686 Community sagemath-jupyter 7.5.1-2 Jupyter kernel for SageMath
i686 Community cdrtools 3.02a07-1 Original cdrtools supporting CD, DVD and BluRay burning
i686 Community pantheon-photos 0.2.1-1 The Pantheon Photos Manager
i686 Community pantheon-files 0.3.1-1 The Pantheon File Manager
i686 Community xmonad 0.12-12 Lightweight X11 tiled window manager written in Haskell
i686 Community xmonad-contrib 0.12-11 Add-ons for xmonad
i686 Community manaplus 1.6.12.24-1 Free OpenSource 2D MMORPG client for Evol Online, The mana world and similar servers
i686 Community sleuthkit 4.4.0-1 File system and media management forensic analysis tools
i686 Community uwsgi-plugin-python 2.0.14-7 Plugin for Python support
i686 Community uwsgi-plugin-mono 2.0.14-7 Plugin for mono support
i686 Community uwsgi-plugin-webdav 2.0.14-7 Plugin for webdav support
i686 Community uwsgi-plugin-php 2.0.14-7 Plugin for PHP support
i686 Community mod_proxy_uwsgi 2.0.14-7 Apache uWSGI proxy module
i686 Community uwsgi-plugin-lua51 2.0.14-7 Plugin for Lua support
i686 Community uwsgi-plugin-jvm 2.0.14-7 Plugin for Jvm support
i686 Community uwsgi-plugin-rack 2.0.14-7 Ruby rack plugin
i686 Community uwsgi-plugin-pypy 2.0.14-7 Plugin for PyPy support
i686 Community uwsgi-plugin-cgi 2.0.14-7 CGI plugin
i686 Community uwsgi-plugin-psgi 2.0.14-7 Perl psgi plugin
i686 Community uwsgi-plugin-python2 2.0.14-7 Plugin for Python2 support
i686 Community uwsgi 2.0.14-7 A fast, self-healing and developer/sysadmin-friendly application container server coded in pure C
i686 Community php-memcache 3.0.8-5 Memcache module for PHP
i686 Community php-memcached 2.2.0-4 PHP extension for interfacing with memcached via libmemcached library
i686 Community php-geoip 1.1.1-2 GeoIP module for PHP
i686 Community xdebug 2.5.0-1 PHP debugging extension
i686 Community diffoscope 69-1 Tool for in-depth comparison of files, archives, and directories
i686 Community python-pcapy 0.11.1-1 Extension module that interfaces with the libpcap packet capture library
i686 Community python2-pcapy 0.11.1-1 Extension module that interfaces with the libpcap packet capture library
i686 Community pngcrush 1.8.11-1 Tool for optimizing the compression of PNG files
i686 Community haxe 3.4.0rc2-1 Cross-platform toolkit and programming language
i686 Community libgiac 1.2.3.13-1 Giac shared library
i686 Community xcas 1.2.3.13-1 A free computer algebra system
i686 Community rustfmt 0.7-1 A tool for formatting Rust code according to style guidelines
i686 Community mate-session-manager 1.16.0-3 The MATE Session Handler
i686 Community obs-studio 17.0.1-1 Free, open source software for live streaming and recording
i686 Community toxcore 1:0.1.4-2 Secure, configuration-free, P2P Skype replacement backend
i686 Community deepin-daemon 3.0.25.2-1 Daemon handling the DDE session settings
i686 Community leatherman 0.10.1-1 Collection of C++ and CMake utility libraries
i686 Community haskell-stack 1.3.2-13 The Haskell Tool Stack (docs and libraries)
i686 Community haskell-lifted-async 0.9.1-1 Run lifted IO operations asynchronously and wait for their results
i686 Community stack 1.3.2-13 The Haskell Tool Stack
i686 Community qtox 1.7.1-4 Powerful Tox client written in C++/Qt that follows the Tox design guidelines
i686 Community deepin-notifications 2.3.10-1 System notifications for linuxdeepin desktop environment
i686 Community haskell-dav 1.3.1-43 RFC 4918 WebDAV support
i686 Community haskell-xml-hamlet 0.4.1-1 Hamlet-style quasiquoter for XML content
i686 Community hoogle 5.0.9-1 Haskell API Search
i686 Community deepin-polkit-agent 0.0.2-1 Deepin Polkit Agent
i686 Community docker-machine 0.9.0-1 Machine management for a container-centric world
i686 Community haskell-yesod 1.4.4-2 Creation of type-safe, RESTful web applications.
i686 Community haskell-yesod-auth 1.4.15-16 Authentication for Yesod.
i686 Community haskell-yesod-default 1.2.0-95 Default config and main functions for your yesod application (deprecated)
i686 Community haskell-hakyll 4.9.3.0-4 A static website compiler library
i686 Community idris 0.99-17 Functional Programming Language with Dependent Types
i686 Community haskell-yesod-core 1.4.30-11 Creation of type-safe, RESTful web applications.
i686 Community haskell-wai-app-static 3.1.6.1-23 WAI application for static serving
i686 Community haskell-yesod-static 1.5.1.1-25 Static file serving subsite for Yesod Web Framework.
i686 Community haskell-yesod-persistent 1.4.1.1-10 Some helpers for using Persistent from Yesod.
i686 Community haskell-yesod-form 1.4.9-27 Form handling support for Yesod Web Framework
i686 Community haskell-wai-extra 3.0.19.1-1 Provides some basic WAI handlers and middleware.
i686 Community haskell-cheapskate 0.1.0.5-37 Experimental markdown processor.
i686 Extra libxkbcommon-x11 0.7.1-1 Keyboard handling library using XKB data for X11 XCB clients
i686 Extra libxkbcommon 0.7.1-1 Keymap handling library for toolkits and window systems
i686 Extra python2-protobuf 3.1.0-1 Python 2 bindings for Google Protocol Buffers
i686 Extra protobuf-c 1.2.1-4 Protocol Buffers implementation in C
i686 Extra hefur 0.4-10 A standalone and lightweight BitTorrent tracker
i686 Extra libgadu 1.12.1-3 This library implements the client side of the Gadu-Gadu protocol
i686 Extra libphonenumber 8.0.0-2 Google's common library for parsing, formatting, and validating international phone numbers
i686 Extra qt5-webengine 5.7.1-2 Provides support for web applications using the Chromium browser project
i686 Extra protobuf 3.1.0-1 Protocol Buffers - Google's data interchange format
i686 Extra python-protobuf 3.1.0-1 Python 3 bindings for Google Protocol Buffers
i686 Extra webkitgtk 2.4.11-4 Legacy Web content engine for GTK+ 3
i686 Extra webkitgtk2 2.4.11-4 Legacy Web content engine for GTK+ 2
i686 Extra avogadrolibs 1.90.0-3 An advanced molecular editor
i686 Extra imagemagick-doc 6.9.7.4-1 The ImageMagick documentation (utilities manuals and libraries API)
i686 Extra imagemagick 6.9.7.4-1 An image viewing/manipulation program
i686 Extra jsoncpp 1.8.0-1 C++ library for interacting with JSON
i686 Extra jsoncpp-doc 1.8.0-1 C++ library for interacting with JSON (documentation)
i686 Extra php-odbc 7.1.1-1 ODBC modules for PHP
i686 Extra php-cgi 7.1.1-1 CGI and FCGI SAPI for PHP
i686 Extra php-intl 7.1.1-1 intl module for PHP
i686 Extra php-pspell 7.1.1-1 pspell module for PHP
i686 Extra php-embed 7.1.1-1 Embedded PHP SAPI library
i686 Extra php-phpdbg 7.1.1-1 Interactive PHP debugger
i686 Extra php 7.1.1-1 A general-purpose scripting language that is especially suited to web development
i686 Extra php-tidy 7.1.1-1 tidy module for PHP
i686 Extra php-apcu 5.1.8-1 A userland caching module for PHP
i686 Extra php-gd 7.1.1-1 gd module for PHP
i686 Extra php-mcrypt 7.1.1-1 mcrypt module for PHP
i686 Extra php-enchant 7.1.1-1 enchant module for PHP
i686 Extra php-imap 7.1.1-1 imap module for PHP
i686 Extra php-fpm 7.1.1-1 FastCGI Process Manager for PHP
i686 Extra php-dblib 7.1.1-1 dblib module for PHP
i686 Extra php-pgsql 7.1.1-1 PostgreSQL modules for PHP
i686 Extra php-apache 7.1.1-1 Apache SAPI for PHP
i686 Extra php-snmp 7.1.1-1 snmp module for PHP
i686 Extra php-sqlite 7.1.1-1 sqlite module for PHP
i686 Extra php-xsl 7.1.1-1 xsl module for PHP
i686 Extra php-apcu-bc 1.0.3-2 APCu Backwards Compatibility Module
i686 Extra weechat 1.7-1 Fast, light and extensible IRC client (curses UI)
i686 Extra bubblewrap 0.1.7-1 Unprivileged sandboxing tool
i686 Extra mencoder 37916-1 Free command line video decoding, encoding and filtering tool
i686 Extra mplayer 37916-1 Media player for Linux
i686 Extra flatpak 0.8.1-1 Application deployment framework for desktop apps
i686 Extra xf86-input-evdev 2.10.5-1 X.org evdev input driver
i686 Extra poppler-qt4 0.51.0-1 Poppler Qt4 bindings
i686 Extra poppler 0.51.0-1 PDF rendering library based on xpdf 3.0
i686 Extra libcups 2.2.2-1 The CUPS Printing System - client libraries and headers
i686 Extra cups 2.2.2-1 The CUPS Printing System - daemon package
i686 Extra poppler-qt5 0.51.0-1 Poppler Qt5 bindings
i686 Extra poppler-glib 0.51.0-1 Poppler glib bindings
i686 Extra nginx 1.10.2-4 Lightweight HTTP server and IMAP/POP3 proxy server
i686 Extra brltty 5.4-5 Braille display driver for Linux/Unix
i686 Testing libpsl 0.17.0-1 Public Suffix List library
i686 Testing cups-pdf 3.0.0-1 PDF printer for cups
i686 Testing sudo 1.8.19.p2-1 Give certain users the ability to run some commands as root
i686 Testing mariadb 10.1.21-1 Fast SQL database server, drop-in replacement for MySQL
i686 Testing mariadb-clients 10.1.21-1 MariaDB client tools
i686 Testing mytop 10.1.21-1 Top clone for MariaDB
i686 Testing libmariadbclient 10.1.21-1 MariaDB client libraries
i686 Community-Testing facter 3.4.2-1 Collect and display system facts
x86_64
x86_64 Core libtasn1 4.10-1 The ASN.1 library used in GNUTLS
x86_64 Core nfs-utils 2.1.1-1 Support programs for Network File Systems
x86_64 Community mosh 1.2.6-3 Mobile shell, surviving disconnects with local echo and line editing
x86_64 Community umurmur 0.2.16_a-5 Minimalistic Mumble server
x86_64 Community pokerth 1.1.1-16 Open source Texas Hold'em Poker simulator
x86_64 Community bitcoin-daemon 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - daemon
x86_64 Community bitcoin-qt 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - Qt
x86_64 Community mumble 1.2.18-2 A voice chat application similar to TeamSpeak
x86_64 Community hyperion 1.03.2-8 An opensource 'AmbiLight' implementation
x86_64 Community collectd 5.7.0-2 Daemon which collects system performance statistics periodically
x86_64 Community rethinkdb 2.3.5-3 Distributed powerful and scalable NoSQL database
x86_64 Community mixxx 2.0.0-6 Free, open source software for digital DJ'ing.
x86_64 Community murmur 1.2.18-3 The voice chat application server for Mumble
x86_64 Community bitcoin-tx 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - Transaction tool
x86_64 Community clementine 1.3.1-6 A modern music player and library organizer
x86_64 Community bitcoin-cli 0.13.2-3 Bitcoin is a peer-to-peer network based digital currency - RPC client
x86_64 Community pan 0.141-2 A powerful Newsgroup Article reader
x86_64 Community sagemath 7.5.1-2 Open Source Mathematics Software, free alternative to Magma, Maple, Mathematica, and Matlab
x86_64 Community sagemath-jupyter 7.5.1-2 Jupyter kernel for SageMath
x86_64 Community cdrtools 3.02a07-1 Original cdrtools supporting CD, DVD and BluRay burning
x86_64 Community pantheon-photos 0.2.1-1 The Pantheon Photos Manager
x86_64 Community pantheon-files 0.3.1-1 The Pantheon File Manager
x86_64 Community luxrender 1.6-7 Rendering system for physically correct, unbiased image synthesis
x86_64 Community luxmark 3.1-4 OpenCL benchmark tool
x86_64 Community luxrays 1.6-8 Accelerate the ray intersection process by using GPUs
x86_64 Community xmonad 0.12-12 Lightweight X11 tiled window manager written in Haskell
x86_64 Community xmonad-contrib 0.12-11 Add-ons for xmonad
x86_64 Community manaplus 1.6.12.24-1 Free OpenSource 2D MMORPG client for Evol Online, The mana world and similar servers
x86_64 Community sleuthkit 4.4.0-1 File system and media management forensic analysis tools
x86_64 Community uwsgi-plugin-python 2.0.14-7 Plugin for Python support
x86_64 Community uwsgi-plugin-mono 2.0.14-7 Plugin for mono support
x86_64 Community uwsgi-plugin-webdav 2.0.14-7 Plugin for webdav support
x86_64 Community uwsgi-plugin-php 2.0.14-7 Plugin for PHP support
x86_64 Community mod_proxy_uwsgi 2.0.14-7 Apache uWSGI proxy module
x86_64 Community uwsgi-plugin-lua51 2.0.14-7 Plugin for Lua support
x86_64 Community uwsgi-plugin-jvm 2.0.14-7 Plugin for Jvm support
x86_64 Community uwsgi-plugin-rack 2.0.14-7 Ruby rack plugin
x86_64 Community uwsgi-plugin-pypy 2.0.14-7 Plugin for PyPy support
x86_64 Community uwsgi-plugin-cgi 2.0.14-7 CGI plugin
x86_64 Community uwsgi-plugin-psgi 2.0.14-7 Perl psgi plugin
x86_64 Community uwsgi-plugin-python2 2.0.14-7 Plugin for Python2 support
x86_64 Community uwsgi 2.0.14-7 A fast, self-healing and developer/sysadmin-friendly application container server coded in pure C
x86_64 Community php-memcache 3.0.8-5 Memcache module for PHP
x86_64 Community php-memcached 2.2.0-4 PHP extension for interfacing with memcached via libmemcached library
x86_64 Community php-geoip 1.1.1-2 GeoIP module for PHP
x86_64 Community xdebug 2.5.0-1 PHP debugging extension
x86_64 Community diffoscope 69-1 Tool for in-depth comparison of files, archives, and directories
x86_64 Community python-pcapy 0.11.1-1 Extension module that interfaces with the libpcap packet capture library
x86_64 Community python2-pcapy 0.11.1-1 Extension module that interfaces with the libpcap packet capture library
x86_64 Community pngcrush 1.8.11-1 Tool for optimizing the compression of PNG files
x86_64 Community haxe 3.4.0rc2-1 Cross-platform toolkit and programming language
x86_64 Community libgiac 1.2.3.13-1 Giac shared library
x86_64 Community xcas 1.2.3.13-1 A free computer algebra system
x86_64 Community rustfmt 0.7-1 A tool for formatting Rust code according to style guidelines
x86_64 Community mate-session-manager 1.16.0-3 The MATE Session Handler
x86_64 Community obs-studio 17.0.1-1 Free, open source software for live streaming and recording
x86_64 Community toxcore 1:0.1.4-2 Secure, configuration-free, P2P Skype replacement backend
x86_64 Community deepin-daemon 3.0.25.2-1 Daemon handling the DDE session settings
x86_64 Community leatherman 0.10.1-1 Collection of C++ and CMake utility libraries
x86_64 Community haskell-stack 1.3.2-13 The Haskell Tool Stack (docs and libraries)
x86_64 Community haskell-lifted-async 0.9.1-1 Run lifted IO operations asynchronously and wait for their results
x86_64 Community stack 1.3.2-13 The Haskell Tool Stack
x86_64 Community qtox 1.7.1-4 Powerful Tox client written in C++/Qt that follows the Tox design guidelines
x86_64 Community deepin-notifications 2.3.10-1 System notifications for linuxdeepin desktop environment
x86_64 Community haskell-dav 1.3.1-43 RFC 4918 WebDAV support
x86_64 Community haskell-xml-hamlet 0.4.1-1 Hamlet-style quasiquoter for XML content
x86_64 Community hoogle 5.0.9-1 Haskell API Search
x86_64 Community deepin-polkit-agent 0.0.2-1 Deepin Polkit Agent
x86_64 Community docker-machine 0.9.0-1 Machine management for a container-centric world
x86_64 Community haskell-yesod 1.4.4-2 Creation of type-safe, RESTful web applications.
x86_64 Community haskell-yesod-auth 1.4.15-16 Authentication for Yesod.
x86_64 Community haskell-yesod-default 1.2.0-95 Default config and main functions for your yesod application (deprecated)
x86_64 Community haskell-hakyll 4.9.3.0-4 A static website compiler library
x86_64 Community idris 0.99-17 Functional Programming Language with Dependent Types
x86_64 Community haskell-yesod-core 1.4.30-11 Creation of type-safe, RESTful web applications.
x86_64 Community haskell-wai-app-static 3.1.6.1-23 WAI application for static serving
x86_64 Community haskell-yesod-static 1.5.1.1-25 Static file serving subsite for Yesod Web Framework.
x86_64 Community haskell-yesod-persistent 1.4.1.1-10 Some helpers for using Persistent from Yesod.
x86_64 Community haskell-yesod-form 1.4.9-27 Form handling support for Yesod Web Framework
x86_64 Community haskell-wai-extra 3.0.19.1-1 Provides some basic WAI handlers and middleware.
x86_64 Community haskell-cheapskate 0.1.0.5-37 Experimental markdown processor.
x86_64 Extra libxkbcommon-x11 0.7.1-1 Keyboard handling library using XKB data for X11 XCB clients
x86_64 Extra libxkbcommon 0.7.1-1 Keymap handling library for toolkits and window systems
x86_64 Extra python2-protobuf 3.1.0-1 Python 2 bindings for Google Protocol Buffers
x86_64 Extra protobuf-c 1.2.1-4 Protocol Buffers implementation in C
x86_64 Extra hefur 0.4-10 A standalone and lightweight BitTorrent tracker
x86_64 Extra libgadu 1.12.1-3 This library implements the client side of the Gadu-Gadu protocol
x86_64 Extra libphonenumber 8.0.0-2 Google's common library for parsing, formatting, and validating international phone numbers
x86_64 Extra qt5-webengine 5.7.1-2 Provides support for web applications using the Chromium browser project
x86_64 Extra protobuf 3.1.0-1 Protocol Buffers - Google's data interchange format
x86_64 Extra python-protobuf 3.1.0-1 Python 3 bindings for Google Protocol Buffers
x86_64 Extra webkitgtk 2.4.11-4 Legacy Web content engine for GTK+ 3
x86_64 Extra webkitgtk2 2.4.11-4 Legacy Web content engine for GTK+ 2
x86_64 Extra avogadrolibs 1.90.0-3 An advanced molecular editor
x86_64 Extra imagemagick-doc 6.9.7.4-1 The ImageMagick documentation (utilities manuals and libraries API)
x86_64 Extra imagemagick 6.9.7.4-1 An image viewing/manipulation program
x86_64 Extra jsoncpp 1.8.0-1 C++ library for interacting with JSON
x86_64 Extra jsoncpp-doc 1.8.0-1 C++ library for interacting with JSON (documentation)
x86_64 Extra php-odbc 7.1.1-1 ODBC modules for PHP
x86_64 Extra php-cgi 7.1.1-1 CGI and FCGI SAPI for PHP
x86_64 Extra php-intl 7.1.1-1 intl module for PHP
x86_64 Extra php-pspell 7.1.1-1 pspell module for PHP
x86_64 Extra php-embed 7.1.1-1 Embedded PHP SAPI library
x86_64 Extra php-phpdbg 7.1.1-1 Interactive PHP debugger
x86_64 Extra php 7.1.1-1 A general-purpose scripting language that is especially suited to web development
x86_64 Extra php-tidy 7.1.1-1 tidy module for PHP
x86_64 Extra php-apcu 5.1.8-1 A userland caching module for PHP
x86_64 Extra php-gd 7.1.1-1 gd module for PHP
x86_64 Extra php-mcrypt 7.1.1-1 mcrypt module for PHP
x86_64 Extra php-enchant 7.1.1-1 enchant module for PHP
x86_64 Extra php-imap 7.1.1-1 imap module for PHP
x86_64 Extra php-fpm 7.1.1-1 FastCGI Process Manager for PHP
x86_64 Extra php-dblib 7.1.1-1 dblib module for PHP
x86_64 Extra php-pgsql 7.1.1-1 PostgreSQL modules for PHP
x86_64 Extra php-apache 7.1.1-1 Apache SAPI for PHP
x86_64 Extra php-snmp 7.1.1-1 snmp module for PHP
x86_64 Extra php-sqlite 7.1.1-1 sqlite module for PHP
x86_64 Extra php-xsl 7.1.1-1 xsl module for PHP
x86_64 Extra php-apcu-bc 1.0.3-2 APCu Backwards Compatibility Module
x86_64 Extra weechat 1.7-1 Fast, light and extensible IRC client (curses UI)
x86_64 Extra bubblewrap 0.1.7-1 Unprivileged sandboxing tool
x86_64 Extra mencoder 37916-1 Free command line video decoding, encoding and filtering tool
x86_64 Extra mplayer 37916-1 Media player for Linux
x86_64 Extra flatpak 0.8.1-1 Application deployment framework for desktop apps
x86_64 Extra xf86-input-evdev 2.10.5-1 X.org evdev input driver
x86_64 Extra poppler-qt4 0.51.0-1 Poppler Qt4 bindings
x86_64 Extra poppler 0.51.0-1 PDF rendering library based on xpdf 3.0
x86_64 Extra libcups 2.2.2-1 The CUPS Printing System - client libraries and headers
x86_64 Extra cups 2.2.2-1 The CUPS Printing System - daemon package
x86_64 Extra poppler-qt5 0.51.0-1 Poppler Qt5 bindings
x86_64 Extra poppler-glib 0.51.0-1 Poppler glib bindings
x86_64 Extra nginx 1.10.2-4 Lightweight HTTP server and IMAP/POP3 proxy server
x86_64 Extra brltty 5.4-5 Braille display driver for Linux/Unix
x86_64 Multilib lib32-libpsl 0.17.0-1 Public Suffix List library
x86_64 Multilib lib32-libpulse 10.0-1 A featureful, general-purpose sound server (32-bit client libraries)
x86_64 Testing libpsl 0.17.0-1 Public Suffix List library
x86_64 Testing cups-pdf 3.0.0-1 PDF printer for cups
x86_64 Testing sudo 1.8.19.p2-1 Give certain users the ability to run some commands as root
x86_64 Testing mariadb 10.1.21-1 Fast SQL database server, drop-in replacement for MySQL
x86_64 Testing mariadb-clients 10.1.21-1 MariaDB client tools
x86_64 Testing mytop 10.1.21-1 Top clone for MariaDB
x86_64 Testing libmariadbclient 10.1.21-1 MariaDB client libraries
x86_64 Community-Testing facter 3.4.2-1 Collect and display system facts
AUR
megasync-daemon-git v2.9.10.0.g2e03defa-1
megasync-cli-git v2.9.10.0.g2e03defa-1
megasync-git v2.9.10.0.g2e03defa-1
python-megasync-git v2.9.10.0.g2e03defa-1
python2-megasync-git v2.9.10.0.g2e03defa-1
libmega-git v2.9.10.0.g2e03defa-1
fuse-megasync-git v2.9.10.0.g2e03defa-1
python-elektra-git 0.8.19.r8926.b9456f4ac-1
python2-elektra-git 0.8.19.r8926.b9456f4ac-1
java-elektra-git 0.8.19.r8926.b9456f4ac-1
ruby-elektra-git 0.8.19.r8926.b9456f4ac-1
lua-elektra-git 0.8.19.r8926.b9456f4ac-1
openra-kang kang.3b0dc75-1
smplayer-themes-svn 16.8.0.r8377-120112
Thanks
Posted ImagePosted Image
Configs/PGP Key/comhack π
#2011 OFFLINE   securitybreach
  • 24,208 posts
Posted 21 January 2017 - 10:43 AM
Updates for Friday, January 20, 2016
Any
any Community abcde 2.8.1-1 A frontend command-line utility that grabs tracks off a CD, encodes them to ogg or mp3 format, and tags them, all in one go.
any Community python2-html5lib-7-9s 0.9999999-3 Python HTML parser/tokenizer based on the WHATWG HTML5 spec (v0.9999999)
any Community python-html5lib-7-9s 0.9999999-3 Python HTML parser/tokenizer based on the WHATWG HTML5 spec (v0.9999999)
any Community python-pydenticon 0.3-2 Library for generating identicons
any Community python2-pydenticon 0.3-2 Library for generating identicons
any Community python-mox3 0.20.0-1 Mock object framework for Python
any Community python2-mox3 0.20.0-1 Mock object framework for Python
any Community python2-oslo-serialization 2.16.0-1 Oslo Serialization library
any Community python-oslo-serialization 2.16.0-1 Oslo Serialization library
any Community etl 0.04.22-1 VoriaETL: C++ STL complementory multiplatform template library
any Community gourmet 0.17.4-5 A simple but powerful recipe-managing application
any Community gnome-activity-journal 0.8.0-10 Tool for easily browsing and finding files on your computer using the Zeitgeist engine
any Community-Testing puppet 4.8.2-1 Server automation framework and application
any Community electrum 2.7.17-1 Lightweight Bitcoin wallet
any Community speedtest-cli 1.0.2-1 Command line interface for testing internet bandwidth using speedtest.net
any Extra xdg-utils 1.1.1-5 Command line tools that assist applications with a variety of desktop integration tasks
any Extra gajim 0.16.6-3 A full featured and easy to use Jabber client
i686
i686 Core gnupg 2.1.17-4 Complete and free implementation of the OpenPGP standard
i686 Core ldns 1.7.0-2 Fast DNS library supporting recent RFCs
i686 Community elfkickers 3.1-1 Collection of ELF utilities (includes sstrip)
i686 Community gnome-hearts 0.3.1-3 A card game for GNOME
i686 Community synfigstudio 1.2.0-1 Professional vector animation program (GUI)
i686 Community pynac 0.7.4-1 Python version of GiNaC, a C++ library for symbolic mathematical calculations
i686 Community sagemath 7.5.1-3 Open Source Mathematics Software, free alternative to Magma, Maple, Mathematica, and Matlab
i686 Community sagemath-jupyter 7.5.1-3 Jupyter kernel for SageMath
i686 Community cellwriter 1.3.5-4 A grid-entry natural handwriting input panel.
i686 Community gobby 0.5.0-4 A collaborative text editor
i686 Community yara 3.5.0-2 Tool aimed at helping malware researchers to identify and classify malware samples
i686 Community kompozer 0.8b3-19 A Dreamweaver style WYSIWYG web editor; Nvu unofficial bug-fix release
i686 Community synfig 1.2.0-1 Professional vector animation program (CLI renderer only)
i686 Community python-py-bcrypt 0.4-2 bcrypt password hashing and key derivation
i686 Community python2-py-bcrypt 0.4-2 bcrypt password hashing and key derivation
i686 Community deepin-qt5integration 0.0.6-1 Deepin Qt5 platform plugin
i686 Community deepin-image-viewer 1.2.1-1 Deepin Image Viewer
i686 Community parity 1.5.0-1 Fast, light, robust Ethereum implementation
i686 Community grumpy 0.aa58aa68-1 Grumpy is a Python to Go source code transcompiler and runtime
i686 Community facter 3.4.2-1 Collect and display system facts
i686 Community cpp-hocon 0.1.4-1 C++ port of the Typesafe Config library
i686 Community deepin-tool-kit 0.2.1-2 Base development tool of all C++/Qt Developer work on Deepin
i686 Community python2-prctl 1.6.1-1 Python(ic) interface to the linux prctl syscall
i686 Community python-prctl 1.6.1-1 Python(ic) interface to the linux prctl syscall
i686 Community synergy 1.8.7-1 Share a single mouse and keyboard between multiple computers
i686 Community iperf3 3.1.5-1 Internet Protocol bandwidth measuring tool
i686 Community awesome 4.0-1 Highly configurable framework window manager
i686 Community xcb-util-xrm 1.2-2 XCB utility functions for the X resource manager
i686 Extra cdrdao 1.2.3-10 Records audio/data CD-Rs in disk-at-once (DAO) mode
i686 Extra qtscriptgenerator 0.2.0-5 A tool that generates Qt bindings for Qt Script
i686 Extra truecrypt 1:7.1a-5 Free open-source cross-platform disk encryption software
i686 Extra amarok 2.8.0-11 The powerful music player for KDE
i686 Extra libnice 0.1.13+156+g1778f79-1 An implementation of the IETF's draft ICE (for p2p UDP data streams)
i686 Extra wxgtk 3.0.2-6 GTK+ implementation of wxWidgets API for GUI
i686 Testing util-linux 2.29.1-1 Miscellaneous system utilities for Linux
i686 Testing libutil-linux 2.29.1-1 util-linux runtime libraries
i686 Testing libinput 1.6.0-1 Input device management and event handling library
i686 Testing linux-lts-docs 4.4.44-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
i686 Testing linux-lts-headers 4.4.44-1 Header files and scripts for building modules for Linux-lts kernel
i686 Testing linux-lts 4.4.44-1 The Linux-lts kernel and modules
i686 Testing ffmpegthumbnailer 2.2.0-1 Lightweight video thumbnailer that can be used by file managers.
i686 Testing polkit 0.113+29+g3272a98-1 Application development toolkit for controlling system-wide privileges
i686 Community-Testing facter 3.5.1-1 Collect and display system facts
x86_64
x86_64 Core gnupg 2.1.17-4 Complete and free implementation of the OpenPGP standard
x86_64 Core ldns 1.7.0-2 Fast DNS library supporting recent RFCs
x86_64 Community elfkickers 3.1-1 Collection of ELF utilities (includes sstrip)
x86_64 Community gnome-hearts 0.3.1-3 A card game for GNOME
x86_64 Community synfigstudio 1.2.0-1 Professional vector animation program (GUI)
x86_64 Community pynac 0.7.4-1 Python version of GiNaC, a C++ library for symbolic mathematical calculations
x86_64 Community sagemath 7.5.1-3 Open Source Mathematics Software, free alternative to Magma, Maple, Mathematica, and Matlab
x86_64 Community sagemath-jupyter 7.5.1-3 Jupyter kernel for SageMath
x86_64 Community cellwriter 1.3.5-4 A grid-entry natural handwriting input panel.
x86_64 Community gobby 0.5.0-4 A collaborative text editor
x86_64 Community yara 3.5.0-2 Tool aimed at helping malware researchers to identify and classify malware samples
x86_64 Community kompozer 0.8b3-19 A Dreamweaver style WYSIWYG web editor; Nvu unofficial bug-fix release
x86_64 Community rkt 1.23.0-1 App container runtime
x86_64 Community synfig 1.2.0-1 Professional vector animation program (CLI renderer only)
x86_64 Community python-py-bcrypt 0.4-2 bcrypt password hashing and key derivation
x86_64 Community python2-py-bcrypt 0.4-2 bcrypt password hashing and key derivation
x86_64 Community deepin-qt5integration 0.0.6-1 Deepin Qt5 platform plugin
x86_64 Community deepin-image-viewer 1.2.1-1 Deepin Image Viewer
x86_64 Community zcash 1.0.5-1 Permissionless financial system employing zero-knowledge security
x86_64 Community parity 1.5.0-1 Fast, light, robust Ethereum implementation
x86_64 Community grumpy 0.aa58aa68-1 Grumpy is a Python to Go source code transcompiler and runtime
x86_64 Community facter 3.4.2-1 Collect and display system facts
x86_64 Community cpp-hocon 0.1.4-1 C++ port of the Typesafe Config library
x86_64 Community deepin-tool-kit 0.2.1-2 Base development tool of all C++/Qt Developer work on Deepin
x86_64 Community python2-prctl 1.6.1-1 Python(ic) interface to the linux prctl syscall
x86_64 Community python-prctl 1.6.1-1 Python(ic) interface to the linux prctl syscall
x86_64 Community synergy 1.8.7-1 Share a single mouse and keyboard between multiple computers
x86_64 Community iperf3 3.1.5-1 Internet Protocol bandwidth measuring tool
x86_64 Community awesome 4.0-1 Highly configurable framework window manager
x86_64 Community xcb-util-xrm 1.2-2 XCB utility functions for the X resource manager
x86_64 Extra cdrdao 1.2.3-10 Records audio/data CD-Rs in disk-at-once (DAO) mode
x86_64 Extra amarok 2.8.0-11 The powerful music player for KDE
x86_64 Extra qtscriptgenerator 0.2.0-5 A tool that generates Qt bindings for Qt Script
x86_64 Extra truecrypt 1:7.1a-5 Free open-source cross-platform disk encryption software
x86_64 Extra libnice 0.1.13+156+g1778f79-1 An implementation of the IETF's draft ICE (for p2p UDP data streams)
x86_64 Extra wxgtk 3.0.2-6 GTK+ implementation of wxWidgets API for GUI
x86_64 Testing util-linux 2.29.1-1 Miscellaneous system utilities for Linux
x86_64 Testing libutil-linux 2.29.1-1 util-linux runtime libraries
x86_64 Testing libinput 1.6.0-1 Input device management and event handling library
x86_64 Testing linux-lts-docs 4.4.44-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
x86_64 Testing linux-lts-headers 4.4.44-1 Header files and scripts for building modules for Linux-lts kernel
x86_64 Testing linux-lts 4.4.44-1 The Linux-lts kernel and modules
x86_64 Testing ffmpegthumbnailer 2.2.0-1 Lightweight video thumbnailer that can be used by file managers.
x86_64 Testing polkit 0.113+29+g3272a98-1 Application development toolkit for controlling system-wide privileges
x86_64 Community-Testing facter 3.5.1-1 Collect and display system facts
x86_64 Multilib-Testing lib32-util-linux 2.29.1-1 Miscellaneous system utilities for Linux (32-bit)
AUR
pingo 0.56-1
texinfo-svn 7638-1
maxima-git 5.39.1.62.gc9bd1333d-1
iran-nastaliq-fonts 20150704-1
krita-git 3.0.91.748.g30441fda12-1
hop-git 3.0.0r800.1ff2ee7-1
gdal1 1.11.5-1
gauche-git 0.9.6.pre1.9680-1
pcmanfm-git r1493.4555839-1
emacs-org-mode-git 9.0.3.255.g7289293e4-1
gandom-fonts 0.4.5-1
riot-web 0.9.6-2
riot-desktop 0.9.6-2
borna-fonts 1.0-1
beignet 1.3.0-1
Thanks
#2012 OFFLINE   securitybreach
  • 24,208 posts
Posted 22 January 2017 - 07:45 PM
Updates for Saturday, January 21, 2016
Any
any Community log4net 2.0.7-1 A tool to help the programmer output log statements to a variety of output targets
any Community smuxi 1.0.5-2 User-friendly and cross-platform IRC client for sophisticated users for GNOME/GTK+ (frontend)
any Community smuxi-server 1.0.5-2 User-friendly and cross-platform IRC client for sophisticated users for GNOME/GTK+ (common files and server)
any Community openbve 1.5.0.9-1 Free-as-in-freedom train simulator placed in the public domain
any Community ttf-linux-libertine-g 20120116-4 Graphite port of Linux Libertine and Linux Biolinum fonts
any Community matrix-synapse 0.18.7-1 Matrix reference homeserver
any Community python2-pysaml2 4.4.0-1 Python implementation of SAML Version 2
any Community python-pysaml2 4.4.0-1 Python implementation of SAML Version 2
any Community python2-pycryptodomex 3.4.3-1 A self-contained Python package of low-level cryptographic primitives
any Community python-pycryptodomex 3.4.3-1 A self-contained Python package of low-level cryptographic primitives
any Community python-pymacaroons-pynacl 0.9.3-1 Macaroon library for Python
any Community python2-pymacaroons-pynacl 0.9.3-1 Macaroon library for Python
any Community python-bleach 1.5.0-5 An easy whitelist-based HTML-sanitizing tool
any Community python2-bleach 1.5.0-5 An easy whitelist-based HTML-sanitizing tool
any Community unifi 5.4.9-1 Centralized management system for Ubiquiti UniFi AP
any Community ferm 2.3.1-1 Tool to maintain complex firewalls
any Community sparkleshare 1.5-3 Collaboration and sharing tool based on git written in C Sharp
any Community glances 2.8-1 CLI curses-based monitoring tool
any Community udiskie 1.5.1-3 Removable disk automounter using udisks
any Community python-minidb 2.0.2-1 A simple SQLite3 store for Python objects
any Community python-xlwt 1.2.0-1 Library to create spreadsheet files compatible with MS Excel 97/2000/XP/2003 XLS files
any Community python2-xlwt 1.2.0-1 Library to create spreadsheet files compatible with MS Excel 97/2000/XP/2003 XLS files
any Community python-envisage 4.6.0-1 Extensible Application Framework
any Community python2-envisage 4.6.0-1 Extensible Application Framework
any Community python2-pandas-datareader 0.3.0-1 Data readers extracted from the pandas codebase
any Community python-pandas-datareader 0.3.0-1 Data readers extracted from the pandas codebase
any Community python2-google-api-python-client 1.6.1-2 Google API Client Library for Python
any Community python-google-api-python-client 1.6.1-2 Google API Client Library for Python
any Community python2-fonttools 3.5.0-1 Converts OpenType and TrueType fonts to and from XML
any Community python-xlsxwriter 0.9.6-2 A Python module for creating Excel XLSX files
any Community python2-xlsxwriter 0.9.6-2 A Python module for creating Excel XLSX files
any Community python-fonttools 3.5.0-1 Converts OpenType and TrueType fonts to and from XML
any Community languagetool 3.6-1 An open source language checker
any Community python-botocore 1.5.4-1 A low-level interface to a growing number of Amazon Web Services
any Community aws-cli 1.11.41-1 Universal Command Line Interface for Amazon Web Services
any Community eslint 3.14.0-1 An AST-based pattern checker for Javascript
any Community python-pytest-runner 2.10.1-1 Invoke py.test as distutils command with dependency resolution
any Community python2-pytest-runner 2.10.1-1 Invoke py.test as distutils command with dependency resolution
any Extra perl-image-exiftool 10.40-1 Reader and rewriter of EXIF informations that supports raw files
any Extra python2-urllib3 1.20-1 HTTP library with thread-safe connection pooling and file post support
any Extra python-urllib3 1.20-1 HTTP library with thread-safe connection pooling and file post support
any Extra python-urllib3-doc 1.20-1 urllib3 Documentation
i686
i686 Core linux-lts 4.4.44-1 The Linux-lts kernel and modules
i686 Core linux-lts-headers 4.4.44-1 Header files and scripts for building modules for Linux-lts kernel
i686 Core linux-lts-docs 4.4.44-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
i686 Core perl 5.24.1-1 A highly capable, feature-rich programming language
i686 Core ed 1.14.1-1 A POSIX-compliant line-oriented text editor
i686 Core sudo 1.8.19.p2-1 Give certain users the ability to run some commands as root
i686 Community lxterminal-gtk3 0.3.0-1 VTE-based terminal emulator (part of LXDE) (GTK+ 3 version)
i686 Community lxterminal 0.3.0-1 VTE-based terminal emulator (part of LXDE)
i686 Community lxpanel 0.9.3-1 Lightweight X11 desktop panel for LXDE
i686 Community lxpanel-gtk3 0.9.3-1 Lightweight X11 desktop panel for LXDE (GTK+ 3 version)
i686 Community pcmanfm-gtk3 1.2.5-1 Extremely fast and lightweight file manager (GTK+ 3 version)
i686 Community pcmanfm 1.2.5-1 Extremely fast and lightweight file manager
i686 Community libfm-extra 1.2.5-1 Extra library for file management
i686 Community libfm 1.2.5-1 Library for file management
i686 Community libfm-gtk2 1.2.5-1 GTK+ 2 library for file management
i686 Community libfm-gtk3 1.2.5-1 GTK+ 3 library for file management
i686 Community budgie-desktop 10.2.9-1 Modern desktop environment from the Solus Project
i686 Community gnokii 0.6.31-11 Tools and user space driver for use with mobile phones
i686 Community java-rxtx 2.2pre2-4 Java library for serial IO
i686 Community spice-vdagent 0.17.0-3 Spice agent for Linux guests
i686 Community rustfmt 0.7.1-1 A tool for formatting Rust code according to style guidelines
i686 Community webkit2-sharp 2.10.9-1 C Sharp bindings for WebKit 2 with GTK+ 3
i686 Community lldpd 0.9.6-1 802.1ab implementation (LLDP) to help you locate neighbors
i686 Community sensors-applet 3.0.0-10 Applet for GNOME Panel to display readings from hardware sensors, including CPU temperature, fan speeds and voltage readings
i686 Community nautilus-actions 3.2.4-3 Configures programs to be launched when files are selected in Nautilus
i686 Community gnac 0.2.4.1-5 Audio converter for GNOME
i686 Community alleyoop 0.9.8-5 Valgrind front-end for the GNOME environment
i686 Community mayavi 4.5.0-4 A 3-dimensional visualizer of scientific data
i686 Community stardict 3.0.6-3 International dictionary software
i686 Community libfm-qt 0.11.2-1 Core library of PCManFM-Qt (Qt binding for libfm)
i686 Community wine 2.0rc6-1 A compatibility layer for running Windows programs
i686 Community haskell-listlike 4.5.1-1 Generic support for list-like structures
i686 Community haskell-process-extras 0.7.1-2 Process extras
i686 Community hoogle 5.0.9-2 Haskell API Search
i686 Community haskell-stack 1.3.2-14 The Haskell Tool Stack (docs and libraries)
i686 Community haskell-conduit-combinators 1.0.8.3-10 Commonly used conduit functions, for both chunked and unchunked data
i686 Community stack 1.3.2-14 The Haskell Tool Stack
i686 Community haskell-mono-traversable 1.0.1.1-1 Type classes for mapping, folding, and traversing monomorphic containers
i686 Community haskell-store 0.3-8 Fast binary serialization
i686 Community toxcore 1:0.1.5-1 Secure, configuration-free, P2P Skype replacement backend
i686 Community tuntox 0.0.6-2 Tunnel TCP connections over the Tox protocol
i686 Community toxic 0.7.2-5 CLI Tox client
i686 Community qtox 1.7.1-5 Powerful Tox client written in C++/Qt that follows the Tox design guidelines
i686 Community libmongoc 1.5.3-1 A client library written in C for MongoDB
i686 Community libbson 1.5.3-1 A BSON utility library.
i686 Community deepin-mutter 3.20.8-1 Base window manager for deepin, fork of gnome mutter
i686 Community tuxcmd 0.6.70-7 A GTK2 file manager with two panels
i686 Community etherape 0.9.14-2 A graphical network monitor for various OSI layers and protocols
i686 Extra gmime 2.6.23-1 Glorious MIME Utility Library
i686 Extra xdg-desktop-portal-gtk 0.5-2 A GTK+ backend for xdg-desktop-portal
i686 Extra cups-pdf 3.0.0-1 PDF printer for cups
i686 Extra xdg-desktop-portal 0.5-2 A portal frontend service for Flatpak
i686 Extra perl-crypt-openssl-bignum 0.07-1 OpenSSL's multiprecision integer arithmetic
i686 Extra samba 4.5.4-1 SMB Fileserver and AD Domain server
i686 Extra smbclient 4.5.4-1 Tools to access a server's filespace and printers via SMB
i686 Extra libwbclient 4.5.4-1 Samba winbind client library
i686 Extra gnome-alsamixer 0.9.7-3 Gnome ALSA mixer
i686 Extra qt5-webkit-ng tp4-1 Classes for a WebKit2 based implementation and a new QML API (maintained fork)
i686 Extra cups-filters 1.13.3-1 OpenPrinting CUPS Filters
i686 Extra vlc 2.2.4-7 A multi-platform MPEG, VCD/DVD, and DivX player
i686 Extra lmdb 0.9.19-1 Symas Lightning Memory-Mapped Database
i686 Extra cmake 3.7.2-1 A cross-platform open-source make system
i686 Extra perl-compress-bzip2 2.25-1 Interface to Bzip2 compression library
i686 Extra opus 1.1.4-1 Totally open, royalty-free, highly versatile audio codec
i686 Extra libqalculate 0.9.10-3 Multi-purpose desktop calculator
i686 Extra xine-lib 1.2.6-12 A multimedia playback engine
i686 Extra wavpack 5.1.0-1 Audio compression format with lossless, lossy and hybrid compression modes
i686 Testing bash 4.4.011-2 The GNU Bourne Again shell
i686 Testing nvidia-340xx-dkms 340.101-9 NVIDIA driver sources for linux, 340xx legacy branch
i686 Testing nvidia-340xx 340.101-9 NVIDIA drivers for linux, 340xx legacy branch
i686 Testing nvidia 375.26-5 NVIDIA drivers for linux
i686 Testing nvidia-304xx 304.134-3 NVIDIA drivers for linux, 304xx legacy branch
i686 Testing nvidia-304xx-dkms 304.134-3 NVIDIA driver sources for linux, 304xx legacy branch
i686 Testing nvidia-dkms 375.26-5 NVIDIA driver sources for linux
i686 Testing kbd 2.0.4-1 Keytable files and keyboard utilities
i686 Testing xfsprogs 4.9.0-1 XFS filesystem utilities
i686 Testing pcre 8.40-1 A library that implements Perl 5-style regular expressions
i686 Testing gssproxy 0.6.1-1 GSSAPI Proxy
i686 Testing libgcrypt 1.7.6-1 General purpose cryptographic library based on the code from GnuPG
i686 Testing linux-docs 4.9.5-1 Kernel hackers manual - HTML documentation that comes with the Linux kernel
i686 Testing linux 4.9.5-1 The Linux kernel and modules
i686 Testing linux-headers 4.9.5-1 Header files and scripts for building modules for Linux kernel
i686 Testing linux-zen-docs 4.9.5-1 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
i686 Testing linux-zen-headers 4.9.5-1 Header files and scripts for building modules for Linux-zen kernel
i686 Testing linux-zen 4.9.5-1 The Linux-zen kernel and modules
i686 Community-Testing bbswitch-dkms 0.8-60 Kernel module allowing to switch dedicated graphics card on Optimus laptops
i686 Community-Testing bbswitch 0.8-60 Kernel module allowing to switch dedicated graphics card on Optimus laptops
i686 Community-Testing acpi_call 1.1.0-55 A linux kernel module that enables calls to ACPI methods through /proc/acpi/call
i686 Community-Testing tp_smapi 0.42-9 Modules for ThinkPad's SMAPI functionality
i686 Community-Testing virtualbox-host-modules-arch 5.1.14-2 Virtualbox host kernel modules for Arch Kernel
i686 Community-Testing virtualbox-guest-modules-arch 5.1.14-2 Virtualbox guest kernel modules for Arch Kernel
i686 Community-Testing r8168 8.043.02-3 A kernel module for Realtek 8168 network cards
i686 Community-Testing vhba-module 20161009-6 Kernel module that emulates SCSI devices
x86_64
x86_64 Core linux-lts 4.4.44-1 The Linux-lts kernel and modules
x86_64 Core linux-lts-headers 4.4.44-1 Header files and scripts for building modules for Linux-lts kernel
x86_64 Core linux-lts-docs 4.4.44-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
x86_64 Core perl 5.24.1-1 A highly capable, feature-rich programming language
x86_64 Core ed 1.14.1-1 A POSIX-compliant line-oriented text editor
x86_64 Core sudo 1.8.19.p2-1 Give certain users the ability to run some commands as root
x86_64 Community haskell-listlike 4.5.1-1 Generic support for list-like structures
x86_64 Community haskell-process-extras 0.7.1-2 Process extras
x86_64 Community hoogle 5.0.9-2 Haskell API Search
x86_64 Community haskell-stack 1.3.2-14 The Haskell Tool Stack (docs and libraries)
x86_64 Community haskell-conduit-combinators 1.0.8.3-10 Commonly used conduit functions, for both chunked and unchunked data
x86_64 Community stack 1.3.2-14 The Haskell Tool Stack
x86_64 Community haskell-mono-traversable 1.0.1.1-1 Type classes for mapping, folding, and traversing monomorphic containers
x86_64 Community haskell-store 0.3-8 Fast binary serialization
x86_64 Community toxcore 1:0.1.5-1 Secure, configuration-free, P2P Skype replacement backend
x86_64 Community tuntox 0.0.6-2 Tunnel TCP connections over the Tox protocol
x86_64 Community toxic 0.7.2-5 CLI Tox client
x86_64 Community qtox 1.7.1-5 Powerful Tox client written in C++/Qt that follows the Tox design guidelines
x86_64 Community libmongoc 1.5.3-1 A client library written in C for MongoDB
x86_64 Community libbson 1.5.3-1 A BSON utility library.
x86_64 Community deepin-mutter 3.20.8-1 Base window manager for deepin, fork of gnome mutter
x86_64 Community tuxcmd 0.6.70-7 A GTK2 file manager with two panels
x86_64 Community etherape 0.9.14-2 A graphical network monitor for various OSI layers and protocols
x86_64 Community lxterminal-gtk3 0.3.0-1 VTE-based terminal emulator (part of LXDE) (GTK+ 3 version)
x86_64 Community lxterminal 0.3.0-1 VTE-based terminal emulator (part of LXDE)
x86_64 Community lxpanel 0.9.3-1 Lightweight X11 desktop panel for LXDE
x86_64 Community lxpanel-gtk3 0.9.3-1 Lightweight X11 desktop panel for LXDE (GTK+ 3 version)
x86_64 Community pcmanfm-gtk3 1.2.5-1 Extremely fast and lightweight file manager (GTK+ 3 version)
x86_64 Community pcmanfm 1.2.5-1 Extremely fast and lightweight file manager
x86_64 Community libfm-extra 1.2.5-1 Extra library for file management
x86_64 Community libfm 1.2.5-1 Library for file management
x86_64 Community libfm-gtk2 1.2.5-1 GTK+ 2 library for file management
x86_64 Community libfm-gtk3 1.2.5-1 GTK+ 3 library for file management
x86_64 Community budgie-desktop 10.2.9-1 Modern desktop environment from the Solus Project
x86_64 Community gnokii 0.6.31-11 Tools and user space driver for use with mobile phones
x86_64 Community java-rxtx 2.2pre2-4 Java library for serial IO
x86_64 Community spice-vdagent 0.17.0-3 Spice agent for Linux guests
x86_64 Community rustfmt 0.7.1-1 A tool for formatting Rust code according to style guidelines
x86_64 Community webkit2-sharp 2.10.9-1 C Sharp bindings for WebKit 2 with GTK+ 3
x86_64 Community lldpd 0.9.6-1 802.1ab implementation (LLDP) to help you locate neighbors
x86_64 Community sensors-applet 3.0.0-10 Applet for GNOME Panel to display readings from hardware sensors, including CPU temperature, fan speeds and voltage readings
x86_64 Community nautilus-actions 3.2.4-3 Configures programs to be launched when files are selected in Nautilus
x86_64 Community gnac 0.2.4.1-5 Audio converter for GNOME
x86_64 Community alleyoop 0.9.8-5 Valgrind front-end for the GNOME environment
x86_64 Community mayavi 4.5.0-4 A 3-dimensional visualizer of scientific data
x86_64 Community stardict 3.0.6-3 International dictionary software
x86_64 Community libfm-qt 0.11.2-1 Core library of PCManFM-Qt (Qt binding for libfm)
x86_64 Extra cups-filters 1.13.3-1 OpenPrinting CUPS Filters
x86_64 Extra vlc 2.2.4-7 A multi-platform MPEG, VCD/DVD, and DivX player
x86_64 Extra lmdb 0.9.19-1 Symas Lightning Memory-Mapped Database
x86_64 Extra cmake 3.7.2-1 A cross-platform open-source make system
x86_64 Extra perl-compress-bzip2 2.25-1 Interface to Bzip2 compression library
x86_64 Extra opus 1.1.4-1 Totally open, royalty-free, highly versatile audio codec
x86_64 Extra libqalculate 0.9.10-3 Multi-purpose desktop calculator
x86_64 Extra xine-lib 1.2.6-12 A multimedia playback engine
x86_64 Extra gmime 2.6.23-1 Glorious MIME Utility Library
x86_64 Extra xdg-desktop-portal-gtk 0.5-2 A GTK+ backend for xdg-desktop-portal
x86_64 Extra cups-pdf 3.0.0-1 PDF printer for cups
x86_64 Extra xdg-desktop-portal 0.5-2 A portal frontend service for Flatpak
x86_64 Extra perl-crypt-openssl-bignum 0.07-1 OpenSSL's multiprecision integer arithmetic
x86_64 Extra samba 4.5.4-1 SMB Fileserver and AD Domain server
x86_64 Extra smbclient 4.5.4-1 Tools to access a server's filespace and printers via SMB
x86_64 Extra libwbclient 4.5.4-1 Samba winbind client library
x86_64 Extra qt5-webkit-ng tp4-1 Classes for a WebKit2 based implementation and a new QML API (maintained fork)
x86_64 Extra wavpack 5.1.0-1 Audio compression format with lossless, lossy and hybrid compression modes
x86_64 Extra gnome-alsamixer 0.9.7-3 Gnome ALSA mixer
xx86_64 Multilib wine 2.0rc6-1 A compatibility layer for running Windows programs
86_64 Testing libgcrypt 1.7.6-1 General purpose cryptographic library based on the code from GnuPG
xx86_64 Testing linux-docs 4.9.5-1 Kernel hackers manual - HTML documentation that comes with the Linux kernel
x86_64 Testing linux 4.9.5-1 The Linux kernel and modules
x86_64 Testing linux-headers 4.9.5-1 Header files and scripts for building modules for Linux kernel
x86_64 Testing linux-zen-docs 4.9.5-1 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
x86_64 Testing linux-zen-headers 4.9.5-1 Header files and scripts for building modules for Linux-zen kernel
x86_64 Testing linux-zen 4.9.5-1 The Linux-zen kernel and modules
x86_64 Testing bash 4.4.011-2 The GNU Bourne Again shell
x86_64 Testing nvidia-340xx-dkms 340.101-9 NVIDIA driver sources for linux, 340xx legacy branch
x86_64 Testing nvidia-340xx 340.101-9 NVIDIA drivers for linux, 340xx legacy branch
x86_64 Testing nvidia 375.26-5 NVIDIA drivers for linux
x86_64 Testing nvidia-304xx 304.134-3 NVIDIA drivers for linux, 304xx legacy branch
x86_64 Testing nvidia-304xx-dkms 304.134-3 NVIDIA driver sources for linux, 304xx legacy branch
x86_64 Testing nvidia-dkms 375.26-5 NVIDIA driver sources for linux
x86_64 Testing kbd 2.0.4-1 Keytable files and keyboard utilities
x86_64 Testing xfsprogs 4.9.0-1 XFS filesystem utilities
x86_64 Testing pcre 8.40-1 A library that implements Perl 5-style regular expressions
x86_64 Testing gssproxy 0.6.1-1 GSSAPI Proxy
x86_64 Community-Testing bbswitch-dkms 0.8-60 Kernel module allowing to switch dedicated graphics card on Optimus laptops
x86_64 Community-Testing bbswitch 0.8-60 Kernel module allowing to switch dedicated graphics card on Optimus laptops
x86_64 Community-Testing acpi_call 1.1.0-55 A linux kernel module that enables calls to ACPI methods through /proc/acpi/call
x86_64 Community-Testing tp_smapi 0.42-9 Modules for ThinkPad's SMAPI functionality
x86_64 Community-Testing virtualbox-host-modules-arch 5.1.14-2 Virtualbox host kernel modules for Arch Kernel
x86_64 Community-Testing virtualbox-guest-modules-arch 5.1.14-2 Virtualbox guest kernel modules for Arch Kernel
x86_64 Community-Testing r8168 8.043.02-3 A kernel module for Realtek 8168 network cards
x86_64 Community-Testing vhba-module 20161009-6 Kernel module that emulates SCSI devices
AUR
linux-libre-pck 4.9.5_gnu.pck1-1
linux-libre-pck-headers 4.9.5_gnu.pck1-1
linux-libre-pck-docs 4.9.5_gnu.pck1-1
linux-libre-grsec-xen 1:4.8.17_gnu.r201701151620-1
linux-libre-grsec-xen-headers 1:4.8.17_gnu.r201701151620-1
linux-libre-grsec-xen-docs 1:4.8.17_gnu.r201701151620-1
linux-libre-grsec-knock 1:4.8.17_gnu.r201701151620-1
linux-libre-grsec-knock-headers 1:4.8.17_gnu.r201701151620-1
linux-libre-grsec-knock-docs 1:4.8.17_gnu.r201701151620-1
linux-libre-grsec 1:4.8.17_gnu.r201701151620-1
linux-libre-grsec-headers 1:4.8.17_gnu.r201701151620-1
linux-libre-grsec-docs 1:4.8.17_gnu.r201701151620-1
linux-libre-lts-knock 4.4.44_gnu-1
linux-libre-lts-knock-headers 4.4.44_gnu-1
linux-libre-lts-knock-docs 4.4.44_gnu-1
Thanks
#2013 OFFLINE   securitybreach
  • 24,208 posts
Posted 29 January 2017 - 07:11 PM
Updates for Saturday, January 28, 2016
Any
any Community python-cryptography-vectors 1.7.2-1 Test vectors for the cryptography package
any Community python2-cryptography-vectors 1.7.2-1 Test vectors for the cryptography package
any Community python2-mockito 1.0.5-1 Spying framework
any Community python-mockito 1.0.5-1 Spying framework
any Community python2-qtawesome 0.4.3-1 Iconic fonts in PyQt and PySide applications
any Community python-qtpy 1.2.1-1 Provides an uniform layer to support PyQt5, PyQt4 and PySide with a single codebase
any Community python2-qtpy 1.2.1-1 Provides an uniform layer to support PyQt5, PyQt4 and PySide with a single codebase
any Community python-qtawesome 0.4.3-1 Iconic fonts in PyQt and PySide applications
any Extra qt5-examples 5.8.0-1 Examples and demos from qt5 documentation
any Extra qt5-translations 5.8.0-1 A cross-platform application and UI framework (Translations)
any Extra qt5-doc 5.8.0-1 A cross-platform application and UI framework (Documentation)
any Extra firefox-i18n-ru 51.0.1-1 Russian language pack for Firefox
any Extra firefox-i18n-gl 51.0.1-1 Galician language pack for Firefox
any Extra firefox-i18n-hsb 51.0.1-1 Upper Sorbian language pack for Firefox
any Extra firefox-i18n-xh 51.0.1-1 Xhosa language pack for Firefox
any Extra firefox-i18n-fa 51.0.1-1 Persian language pack for Firefox
any Extra firefox-i18n-ff 51.0.1-1 Fulah language pack for Firefox
any Extra firefox-i18n-es-es 51.0.1-1 Spanish (Spain) language pack for Firefox
any Extra firefox-i18n-ga-ie 51.0.1-1 Irish language pack for Firefox
any Extra firefox-i18n-sr 51.0.1-1 Serbian language pack for Firefox
any Extra firefox-i18n-hy-am 51.0.1-1 Armenian language pack for Firefox
any Extra firefox-i18n-rm 51.0.1-1 Romansh language pack for Firefox
any Extra firefox-i18n-bn-bd 51.0.1-1 Bengali (Bangladesh) language pack for Firefox
any Extra firefox-i18n-an 51.0.1-1 Aragonese language pack for Firefox
any Extra firefox-i18n-gn 51.0.1-1 Guarani language pack for Firefox
any Extra firefox-i18n-nn-no 51.0.1-1 Norwegian (Nynorsk) language pack for Firefox
any Extra firefox-i18n-bs 51.0.1-1 Bosnian language pack for Firefox
any Extra firefox-i18n-kk 51.0.1-1 Kazakh language pack for Firefox
any Extra firefox-i18n-af 51.0.1-1 Afrikaans language pack for Firefox
any Extra firefox-i18n-ach 51.0.1-1 Acholi language pack for Firefox
any Extra firefox-i18n-en-us 51.0.1-1 English (US) language pack for Firefox
any Extra firefox-i18n-fi 51.0.1-1 Finnish language pack for Firefox
any Extra firefox-i18n-pl 51.0.1-1 Polish language pack for Firefox
any Extra firefox-i18n-uz 51.0.1-1 Uzbek language pack for Firefox
any Extra firefox-i18n-cy 51.0.1-1 Welsh language pack for Firefox
any Extra firefox-i18n-kn 51.0.1-1 Kannada language pack for Firefox
any Extra firefox-i18n-vi 51.0.1-1 Vietnamese language pack for Firefox
any Extra firefox-i18n-ast 51.0.1-1 Asturian language pack for Firefox
any Extra firefox-i18n-eo 51.0.1-1 Esperanto language pack for Firefox
any Extra firefox-i18n-ml 51.0.1-1 Malayalam language pack for Firefox
any Extra firefox-i18n-el 51.0.1-1 Greek language pack for Firefox
any Extra firefox-i18n-cak 51.0.1-1 Maya Kaqchikel language pack for Firefox
any Extra firefox-i18n-pa-in 51.0.1-1 Punjabi (India) language pack for Firefox
any Extra firefox-i18n-en-za 51.0.1-1 English (South African) language pack for Firefox
any Extra firefox-i18n-th 51.0.1-1 Thai language pack for Firefox
any Extra firefox-i18n-tr 51.0.1-1 Turkish language pack for Firefox
any Extra firefox-i18n-es-ar 51.0.1-1 Spanish (Argentina) language pack for Firefox
any Extra firefox-i18n-si 51.0.1-1 Sinhala language pack for Firefox
any Extra firefox-i18n-hu 51.0.1-1 Hungarian language pack for Firefox
any Extra firefox-i18n-dsb 51.0.1-1 Lower Sorbian language pack for Firefox
any Extra firefox-i18n-gd 51.0.1-1 Gaelic (Scotland) language pack for Firefox
any Extra firefox-i18n-nl 51.0.1-1 Dutch language pack for Firefox
any Extra firefox-i18n-et 51.0.1-1 Estonian language pack for Firefox
any Extra firefox-i18n-eu 51.0.1-1 Basque language pack for Firefox
any Extra firefox-i18n-cs 51.0.1-1 Czech language pack for Firefox
any Extra firefox-i18n-pt-br 51.0.1-1 Portuguese (Brazilian) language pack for Firefox
any Extra firefox-i18n-zh-tw 51.0.1-1 Chinese (Traditional) language pack for Firefox
any Extra firefox-i18n-mai 51.0.1-1 Maithili language pack for Firefox
any Extra firefox-i18n-lij 51.0.1-1 Ligurian language pack for Firefox
any Extra firefox-i18n-ms 51.0.1-1 Malay language pack for Firefox
any Extra firefox-i18n-ca 51.0.1-1 Catalan language pack for Firefox
any Extra firefox-i18n-da 51.0.1-1 Danish language pack for Firefox
any Extra firefox-i18n-uk 51.0.1-1 Ukrainian language pack for Firefox
any Extra firefox-i18n-mk 51.0.1-1 Macedonian language pack for Firefox
any Extra firefox-i18n-bn-in 51.0.1-1 Bengali (India) language pack for Firefox
any Extra firefox-i18n-te 51.0.1-1 Telugu language pack for Firefox
any Extra firefox-i18n-ta 51.0.1-1 Tamil language pack for Firefox
any Extra firefox-i18n-br 51.0.1-1 Breton language pack for Firefox
any Extra firefox-i18n-bg 51.0.1-1 Bulgarian language pack for Firefox
any Extra firefox-i18n-he 51.0.1-1 Hebrew language pack for Firefox
any Extra firefox-i18n-sk 51.0.1-1 Slovak language pack for Firefox
any Extra firefox-i18n-zh-cn 51.0.1-1 Chinese (Simplified) language pack for Firefox
any Extra firefox-i18n-ko 51.0.1-1 Korean language pack for Firefox
any Extra firefox-i18n-pt-pt 51.0.1-1 Portuguese (Portugal) language pack for Firefox
any Extra firefox-i18n-hi-in 51.0.1-1 Hindi (India) language pack for Firefox
any Extra firefox-i18n-es-mx 51.0.1-1 Spanish (Mexico) language pack for Firefox
any Extra firefox-i18n-en-gb 51.0.1-1 English (British) language pack for Firefox
any Extra firefox-i18n-or 51.0.1-1 Oriya language pack for Firefox
any Extra firefox-i18n-fy-nl 51.0.1-1 Frisian language pack for Firefox
any Extra firefox-i18n-km 51.0.1-1 Khmer language pack for Firefox
any Extra firefox-i18n-lt 51.0.1-1 Lithuanian language pack for Firefox
any Extra firefox-i18n-nb-no 51.0.1-1 Norwegian (Bokmål) language pack for Firefox
any Extra firefox-i18n-mr 51.0.1-1 Marathi language pack for Firefox
any Extra firefox-i18n-as 51.0.1-1 Assamese language pack for Firefox
any Extra firefox-i18n-id 51.0.1-1 Indonesian language pack for Firefox
any Extra firefox-i18n-it 51.0.1-1 Italian language pack for Firefox
any Extra firefox-i18n-gu-in 51.0.1-1 Gujarati (India) language pack for Firefox
any Extra firefox-i18n-fr 51.0.1-1 French language pack for Firefox
any Extra firefox-i18n-es-cl 51.0.1-1 Spanish (Chile) language pack for Firefox
any Extra firefox-i18n-sq 51.0.1-1 Albanian language pack for Firefox
any Extra firefox-i18n-sv-se 51.0.1-1 Swedish language pack for Firefox
any Extra firefox-i18n-hr 51.0.1-1 Croatian language pack for Firefox
any Extra firefox-i18n-ro 51.0.1-1 Romanian language pack for Firefox
any Extra firefox-i18n-sl 51.0.1-1 Slovenian language pack for Firefox
any Extra firefox-i18n-ja 51.0.1-1 Japanese language pack for Firefox
any Extra firefox-i18n-is 51.0.1-1 Icelandic language pack for Firefox
any Extra firefox-i18n-son 51.0.1-1 Songhai language pack for Firefox
any Extra firefox-i18n-az 51.0.1-1 Azerbaijani language pack for Firefox
any Extra firefox-i18n-lv 51.0.1-1 Latvian language pack for Firefox
any Extra firefox-i18n-ar 51.0.1-1 Arabic language pack for Firefox
any Extra firefox-i18n-de 51.0.1-1 German language pack for Firefox
any Extra python-setuptools 1:34.0.3-1 Easily download, build, install, upgrade, and uninstall Python packages
any Extra python2-setuptools 1:34.0.3-1 Easily download, build, install, upgrade, and uninstall Python packages
any Extra libreoffice-fresh-eo 5.2.5-1 Esperanto language pack for LibreOffice Fresh
any Extra libreoffice-fresh-pt-BR 5.2.5-1 Portuguese (Brasil) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-fr 5.2.5-1 French language pack for LibreOffice Fresh
any Extra libreoffice-fresh-br 5.2.5-1 Breton language pack for LibreOffice Fresh
any Extra libreoffice-fresh-dz 5.2.5-1 Dzongkha language pack for LibreOffice Fresh
any Extra libreoffice-fresh-et 5.2.5-1 Estonian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-am 5.2.5-1 Amharic language pack for LibreOffice Fresh
any Extra libreoffice-fresh-vi 5.2.5-1 Vietnamese language pack for LibreOffice Fresh
any Extra libreoffice-fresh-gu 5.2.5-1 Gujarati language pack for LibreOffice Fresh
any Extra libreoffice-fresh-id 5.2.5-1 Indonesian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-lv 5.2.5-1 Latvian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ja 5.2.5-1 Japanese language pack for LibreOffice Fresh
any Extra libreoffice-fresh-te 5.2.5-1 Telugu language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sr 5.2.5-1 Serbian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ca-valencia 5.2.5-1 Catalan (Valencia) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-pa-IN 5.2.5-1 Punjabi (India) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-hi 5.2.5-1 Hindi language pack for LibreOffice Fresh
any Extra libreoffice-fresh-oc 5.2.5-1 Occitan language pack for LibreOffice Fresh
any Extra libreoffice-fresh-km 5.2.5-1 Khmer (Cambodia) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-kk 5.2.5-1 Kazakh language pack for LibreOffice Fresh
any Extra libreoffice-fresh-nr 5.2.5-1 Ndebele (South) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ca 5.2.5-1 Catalan language pack for LibreOffice Fresh
any Extra libreoffice-fresh-my 5.2.5-1 Burmese language pack for LibreOffice Fresh
any Extra libreoffice-fresh-nn 5.2.5-1 Norwegian Nynorsk language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sr-Latn 5.2.5-1 Serbian (Latin) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-af 5.2.5-1 Afrikaans language pack for LibreOffice Fresh
any Extra libreoffice-fresh-si 5.2.5-1 Singhalese language pack for LibreOffice Fresh
any Extra libreoffice-fresh-brx 5.2.5-1 Bodo language pack for LibreOffice Fresh
any Extra libreoffice-fresh-tr 5.2.5-1 Turkish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-bn 5.2.5-1 Bengali language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sa-IN 5.2.5-1 Sanskrit (India) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-rw 5.2.5-1 Kinyarwanda language pack for LibreOffice Fresh
any Extra libreoffice-fresh-kn 5.2.5-1 Kannada language pack for LibreOffice Fresh
any Extra libreoffice-fresh-pt 5.2.5-1 Portuguese language pack for LibreOffice Fresh
any Extra libreoffice-fresh-es 5.2.5-1 Spanish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-en-ZA 5.2.5-1 English (ZA) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sid 5.2.5-1 Sidama language pack for LibreOffice Fresh
any Extra libreoffice-fresh-gl 5.2.5-1 Galician language pack for LibreOffice Fresh
any Extra libreoffice-fresh-lo 5.2.5-1 Lao language pack for LibreOffice Fresh
any Extra libreoffice-fresh-nl 5.2.5-1 Dutch language pack for LibreOffice Fresh
any Extra libreoffice-fresh-cy 5.2.5-1 Welsh language pack for LibreOffice Fresh
any Extra libreoffice-fresh-it 5.2.5-1 Italian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sat 5.2.5-1 Santali language pack for LibreOffice Fresh
any Extra libreoffice-fresh-de 5.2.5-1 German language pack for LibreOffice Fresh
any Extra libreoffice-fresh-fi 5.2.5-1 Finnish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-hu 5.2.5-1 Hungarian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-he 5.2.5-1 Hebrew language pack for LibreOffice Fresh
any Extra libreoffice-fresh-lt 5.2.5-1 Lithuanian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-en-GB 5.2.5-1 English (GB) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-zh-CN 5.2.5-1 Chinese (simplified) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-bg 5.2.5-1 Bulgarian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-pl 5.2.5-1 Polish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-om 5.2.5-1 Oromo language pack for LibreOffice Fresh
any Extra libreoffice-fresh-tg 5.2.5-1 Tajik language pack for LibreOffice Fresh
any Extra libreoffice-fresh-bs 5.2.5-1 Bosnian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-tt 5.2.5-1 Tatar language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ko 5.2.5-1 Korean language pack for LibreOffice Fresh
any Extra libreoffice-fresh-st 5.2.5-1 Southern Sotho language pack for LibreOffice Fresh
any Extra libreoffice-fresh-zh-TW 5.2.5-1 Chinese (traditional) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-uk 5.2.5-1 Ukrainian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-mr 5.2.5-1 Marathi language pack for LibreOffice Fresh
any Extra libreoffice-fresh-da 5.2.5-1 Danish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-mai 5.2.5-1 Maithili language pack for LibreOffice Fresh
any Extra libreoffice-fresh-lb 5.2.5-1 Luxembourgish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ro 5.2.5-1 Romanian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ar 5.2.5-1 Arabic language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ml 5.2.5-1 Malayalam language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ru 5.2.5-1 Russian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ss 5.2.5-1 Swati language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ast 5.2.5-1 Asturianu language pack for LibreOffice Fresh
any Extra libreoffice-fresh-th 5.2.5-1 Thai language pack for LibreOffice Fresh
any Extra libreoffice-fresh-mni 5.2.5-1 Manipuri language pack for LibreOffice Fresh
any Extra libreoffice-fresh-uz 5.2.5-1 Uzbek language pack for LibreOffice Fresh
any Extra libreoffice-fresh-is 5.2.5-1 Icelandic language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ga 5.2.5-1 Irish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-tn 5.2.5-1 Tswana language pack for LibreOffice Fresh
any Extra libreoffice-fresh-el 5.2.5-1 Greek language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sd 5.2.5-1 Sindhi language pack for LibreOffice Fresh
any Extra libreoffice-fresh-fa 5.2.5-1 Persian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ka 5.2.5-1 Georgian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-be 5.2.5-1 Belarusian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-bn-IN 5.2.5-1 Bengali (India) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-or 5.2.5-1 Oriya language pack for LibreOffice Fresh
any Extra libreoffice-fresh-nb 5.2.5-1 Norwegian Bokmal language pack for LibreOffice Fresh
any Extra libreoffice-fresh-kmr-Latn 5.2.5-1 Kurdish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-cs 5.2.5-1 Czech language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sw-TZ 5.2.5-1 Swahili (Tanzania) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-zu 5.2.5-1 Zulu language pack for LibreOffice Fresh
any Extra libreoffice-fresh-as 5.2.5-1 Assamese (India) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-hr 5.2.5-1 Croatian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-eu 5.2.5-1 Basque language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sv 5.2.5-1 Swedish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sl 5.2.5-1 Slovenian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ve 5.2.5-1 Venda language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ta 5.2.5-1 Tamil language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ts 5.2.5-1 Tsonga language pack for LibreOffice Fresh
any Extra libreoffice-fresh-bo 5.2.5-1 Tibetan language pack for LibreOffice Fresh
any Extra libreoffice-fresh-mn 5.2.5-1 Mongolian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sq 5.2.5-1 Albanien language pack for LibreOffice Fresh
any Extra libreoffice-fresh-kok 5.2.5-1 Konkani language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sk 5.2.5-1 Slovak language pack for LibreOffice Fresh
any Extra libreoffice-fresh-xh 5.2.5-1 Xhosa language pack for LibreOffice Fresh
any Extra libreoffice-fresh-gd 5.2.5-1 Gaelic (Scottish) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-mk 5.2.5-1 Macedonian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-dgo 5.2.5-1 Dogri language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ne 5.2.5-1 Nepali language pack for LibreOffice Fresh
any Extra libreoffice-fresh-nso 5.2.5-1 Northern Sotho language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ug 5.2.5-1 Uighur language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ks 5.2.5-1 Kashmiri language pack for LibreOffice Fresh
any Extra tomcat7 7.0.75-1 Open source implementation of the Java Servlet 3.0 and JavaServer Pages 2.2 technologies
any Extra tomcat8 8.0.41-1 Open source implementation of the Java Servlet 3.1 and JavaServer Pages 2.3 technologies
i686
i686 Core nss 3.28.1-1 Network Security Services
i686 Core ca-certificates-mozilla 3.28.1-1 Mozilla's set of trusted CA certificates
i686 Core openssl 1.0.2.k-1 The Open Source toolkit for Secure Sockets Layer and Transport Layer Security
i686 Community skrooge 2.7.0-2 A personal finances manager for KDE
i686 Community deepin-qt5integration 0.0.6-2 Deepin Qt5 platform plugin
i686 Community deepin-tool-kit 0.2.1-3 Base development tool of all C++/Qt Developer work on Deepin
i686 Community lxqt-qtplugin 0.11.0-2 LXQt platform integration for Qt
i686 Community qt5ct 0.29-4 Qt5 Configuration Utility
i686 Community fcitx-qt5 1.0.6-3 Qt5 IM Module for Fcitx
i686 Community planarity 3.0.0.5-1 A library for implementing graph algorithms
i686 Community fzf 0.16.2-1 Command-line fuzzy finder
i686 Community gmerlin 1.2.0-8 Multimedia architecture for Linux
i686 Community muine 0.8.11-3 A music player written in C Sharp
i686 Community seamonkey 2.46-2 SeaMonkey internet suite
i686 Community consul 0.7.3-1 A tool for service discovery, monitoring and configuration.
i686 Community gambas3-gb-web 3.9.2-1 CGI component
i686 Community gambas3-gb-ncurses 3.9.2-1 Ncurses component
i686 Community gambas3-gb-qt5-opengl 3.9.2-1 Qt5 toolkit OpenGL component
i686 Community gambas3-gb-pcre 3.9.2-1 PCRE component
i686 Community gambas3-gb-db-sqlite2 3.9.2-1 Sqlite2 database access component
i686 Community gambas3-devel 3.9.2-1 Development environment
i686 Community gambas3-gb-form-editor 3.9.2-1 Editor component
i686 Community gambas3-gb-httpd 3.9.2-1 Embedded HTTP server for the interpreter
i686 Community gambas3-gb-crypt 3.9.2-1 MD5/DES crypting component
i686 Community gambas3-gb-image-io 3.9.2-1 Input/Output image component
i686 Community gambas3-gb-util 3.9.2-1 Miscellaneous utility functions component
i686 Community gambas3-gb-sdl 3.9.2-1 SDL component
i686 Community gambas3-gb-form-dialog 3.9.2-1 Form dialog component
i686 Community gambas3-gb-db-sqlite3 3.9.2-1 Sqlite3 database access component
i686 Community gambas3-script 3.9.2-1 Scripter and server programs support
i686 Community gambas3-gb-cairo 3.9.2-1 Cairo component
i686 Community gambas3-gb-sdl2 3.9.2-1 SDL2 component
i686 Community gambas3-gb-map 3.9.2-1 Display maps component
i686 Community gambas3-gb-gtk 3.9.2-1 GTK+ toolkit component
i686 Community gambas3-gb-xml-xslt 3.9.2-1 XML-XSLT component
i686 Community gambas3-gb-libxml 3.9.2-1 libxml2 component
i686 Community gambas3-gb-logging 3.9.2-1 Flexible log message handling component
i686 Community gambas3-gb-mysql 3.9.2-1 Mysql extra component
i686 Community gambas3-gb-opengl-glsl 3.9.2-1 GLSL component
i686 Community gambas3-gb-chart 3.9.2-1 Chart component
i686 Community gambas3-gb-image 3.9.2-1 Image component
i686 Community gambas3-gb-sdl2-audio 3.9.2-1 SDL2 audio component
i686 Community gambas3-gb-option 3.9.2-1 Getopt component
i686 Community gambas3-gb-signal 3.9.2-1 POSIX Signals component
i686 Community gambas3-gb-qt4-opengl 3.9.2-1 Qt4 toolkit OpenGL component
i686 Community gambas3-gb-image-imlib 3.9.2-1 Imlib component
i686 Community gambas3-gb-pdf 3.9.2-1 PDF component
i686 Community gambas3-gb-db 3.9.2-1 Database access component
i686 Community gambas3-gb-args 3.9.2-1 Command-line options analyzer component
i686 Community gambas3-gb-opengl-sge 3.9.2-1 Simple OpenGL game engine component
i686 Community gambas3-gb-form-stock 3.9.2-1 Default stock icons component
i686 Community gambas3-gb-util-web 3.9.2-1 Miscellaneous web utility functions component
i686 Community gambas3-gb-mime 3.9.2-1 MIME message component
i686 Community gambas3-gb-form-terminal 3.9.2-1 Terminal component
i686 Community gambas3-gb-desktop-x11 3.9.2-1 X-Window library support component
i686 Community gambas3-gb-openssl 3.9.2-1 Openssl component
i686 Community gambas3-gb-report 3.9.2-1 Report component
i686 Community gambas3-gb-db-postgresql 3.9.2-1 PostgreSQL database access component
i686 Community gambas3-gb-gtk3 3.9.2-1 GTK3 toolkit component
i686 Community gambas3-gb-settings 3.9.2-1 Setting component
i686 Community gambas3-gb-markdown 3.9.2-1 Convert the Gambas markdown syntax to HTML
i686 Community gambas3-gb-net 3.9.2-1 Network component
i686 Community gambas3-gb-qt4 3.9.2-1 Qt4 toolkit component
i686 Community gambas3-gb-net-curl 3.9.2-1 Curl component
i686 Community gambas3-gb-eval-highlight 3.9.2-1 Expression evaluator highlight component
i686 Community gambas3-gb-dbus 3.9.2-1 DBUS component
i686 Community gambas3-gb-desktop 3.9.2-1 Desktop component
i686 Community gambas3-gb-compress 3.9.2-1 Compression support component
i686 Community gambas3-gb-xml-rpc 3.9.2-1 XML-RPC component
i686 Community gambas3-gb-qt4-webkit 3.9.2-1 Qt4 toolkit webkit component
i686 Community gambas3-gb-net-pop3 3.9.2-1 POP3 component
i686 Community gambas3-gb-scanner 3.9.2-1 Scanimage frontend component
i686 Community gambas3-gb-image-effect 3.9.2-1 Image effect component
i686 Community gambas3-runtime 3.9.2-1 Runtime environment
i686 Community gambas3-gb-form 3.9.2-1 Form component
i686 Community gambas3-gb-opengl-glu 3.9.2-1 GL Utility component
i686 Community gambas3-gb-media 3.9.2-1 Simplified interface to the GStreamer library component
i686 Community gambas3-gb-db-odbc 3.9.2-1 ODBC database access component
i686 Community gambas3-gb-opengl 3.9.2-1 OpenGL component
i686 Community gambas3-gb-xml 3.9.2-1 XML component
i686 Community gambas3-gb-openal 3.9.2-1 OpenAL 3D audio component
i686 Community gambas3-gb-data 3.9.2-1 Data containers component
i686 Community gambas3-gb-sdl-sound 3.9.2-1 SDL sound component
i686 Community gambas3-gb-desktop-gnome 3.9.2-1 Desktop component for Gnome
i686 Community gambas3-gb-memcached 3.9.2-1 Memcached client component
i686 Community gambas3-gb-net-smtp 3.9.2-1 SMTP component
i686 Community gambas3-gb-qt5-webkit 3.9.2-1 Qt5 toolkit webkit component
i686 Community gambas3-gb-gtk-opengl 3.9.2-1 GTK+ toolkit OpenGL component
i686 Community gambas3-gb-vb 3.9.2-1 Visual Basic transitional component
i686 Community gambas3-gb-db-mysql 3.9.2-1 MySQL database access component
i686 Community gambas3-gb-media-form 3.9.2-1 Media player control component
i686 Community gambas3-gb-db-form 3.9.2-1 Database form component
i686 Community gambas3-gb-web-form 3.9.2-1 web form component
i686 Community gambas3-gb-gmp 3.9.2-1 Arbitrary precision arithmetic component
i686 Community gambas3-gb-qt4-ext 3.9.2-1 Qt4 toolkit extended component
i686 Community gambas3-gb-complex 3.9.2-1 Complex numbers component
i686 Community gambas3-gb-qt5 3.9.2-1 Qt5 toolkit component
i686 Community gambas3-gb-form-mdi 3.9.2-1 Form MDI component
i686 Community gambas3-gb-clipper 3.9.2-1 Polygon clipping component
i686 Community gambas3-gb-gsl 3.9.2-1 The GNU Scientific Library component
i686 Community gambas3-ide 3.9.2-1 Integrated Development Environment
i686 Community gambas3-gb-inotify 3.9.2-1 Filesystem events monitoring component
i686 Community gambas3-gb-v4l 3.9.2-1 Video4linux component
i686 Community gambas3-gb-xml-html 3.9.2-1 HTML generator component
i686 Community wine-staging-nine 2.0-1 A compatibility layer for running Windows programs - Staging branch with the gallium-nine patches
i686 Community utox 0.12.1-2 Lightweight Tox client
i686 Community libfilteraudio 0.0.1-3 An easy to use audio filtering library made from webrtc code
i686 Community fcitx-libpinyin 0.4.1-1 Fcitx Wrapper for libpinyin, Library to deal with pinyin
i686 Community gitlab 8.16.3-1 Project management and code hosting application
i686 Community avr-gdb 7.12.1-1 The GNU Debugger for AVR
i686 Community aarch64-linux-gnu-gdb 7.12.1-1 The GNU Debugger for the ARM64 target
i686 Community arm-none-eabi-gdb 7.12.1-1 The GNU Debugger for the ARM EABI (bare-metal) target
i686 Community kio-gdrive 1.1.0-1 KIO Slave to access Google Drive
i686 Extra kanagram 16.12.1-2 Letter Order Game
i686 Extra konqueror 16.12.1-2 KDE File Manager & Web Browser
i686 Extra knotifyconfig 5.30.0-2 Configuration system for KNotify
i686 Extra ktextwidgets 5.30.0-2 Advanced text editing widgets
i686 Extra knotifications 5.30.0-2 Abstraction for system notifications
i686 Extra python2-pyqt5 5.7.1-3 A set of Python 2.x bindings for the Qt5 toolkit
i686 Extra plasma-integration 5.8.5-5 Qt Platform Theme integration plugins for the Plasma workspaces
i686 Extra kwin 5.8.5-3 KDE Window manager
i686 Extra pyqt5-common 5.7.1-3 Common PyQt files shared between python-pyqt5 and python2-pyqt5
i686 Extra akonadi 16.12.1-3 PIM layer, which provides an asynchronous API to access all kind of PIM data
i686 Extra gcin 2.8.4-5 Input method server supporting various input methods
i686 Extra python-pyqt5 5.7.1-3 A set of Python 3.x bindings for the Qt5 toolkit
i686 Extra qt5-graphicaleffects 5.8.0-1 Graphical effects for use with Qt Quick 2
i686 Extra qt5-serialbus 5.8.0-1 Qt module for general purpose serial bus access
i686 Extra qt5-connectivity 5.8.0-1 Provides access to Bluetooth hardware
i686 Extra qt5-gamepad 5.8.0-1 Adds support for getting events from gamepad devices
i686 Extra qt5-quickcontrols 5.8.0-1 Reusable Qt Quick based UI controls to create classic desktop-style user interfaces
i686 Extra qt5-charts 5.8.0-1 Provides a set of easy to use chart components
i686 Extra qt5-virtualkeyboard 5.8.0-1 Virtual keyboard framework
i686 Extra qt5-multimedia 5.8.0-1 Classes for audio, video, radio and camera functionality
i686 Extra qt5-serialport 5.8.0-1 Provides access to hardware and virtual serial ports
i686 Extra qt5-3d 5.8.0-1 C++ and QML APIs for easy inclusion of 3D graphics
i686 Extra qt5-datavis3d 5.8.0-1 Qt Data Visualization module
i686 Extra qt5-websockets 5.8.0-1 Provides WebSocket communication compliant with RFC 6455
i686 Extra qt5-imageformats 5.8.0-1 Plugins for additional image formats: TIFF, MNG, TGA, WBMP
i686 Extra qt5-sensors 5.8.0-1 Provides access to sensor hardware and motion gesture recognition
i686 Extra qt5-location 5.8.0-1 Provides access to position, satellite and area monitoring classes
i686 Extra qt5-xmlpatterns 5.8.0-1 Support for XPath, XQuery, XSLT and XML schema validation
i686 Extra qt5-canvas3d 5.8.0-1 A Javascript 3D rendering API for Qt Quick
i686 Extra qt5-webchannel 5.8.0-1 Provides access to QObject or QML objects from HTML clients for seamless integration of Qt applications with HTML/Javascript clients
i686 Extra qt5-declarative 5.8.0-1 Classes for QML and Javascript languages
i686 Extra qt5-wayland 5.8.0-1 Provides APIs for Wayland
i686 Extra qt5-webengine 5.8.0-1 Provides support for web applications using the Chromium browser project
i686 Extra qt5-base 5.8.0-2 A cross-platform application and UI framework
i686 Extra qt5-webview 5.8.0-1 Provides a way to display web content in a QML application
i686 Extra qt5-quickcontrols2 5.8.0-1 Next generation user interface controls based on Qt Quick
i686 Extra qt5-webkit 5.8.0-1 Classes for a WebKit2 based implementation and a new QML API
i686 Extra qt5-scxml 5.8.0-1 Static and runtime integration of SCXML models into Qt code
i686 Extra qt5-tools 5.8.0-1 A cross-platform application and UI framework (Development Tools, QtHelp)
i686 Extra qt5-svg 5.8.0-1 Classes for displaying the contents of SVG files
i686 Extra qt5-x11extras 5.8.0-1 Provides platform-specific APIs for X11
i686 Extra qt5-script 5.8.0-1 Classes for making Qt applications scriptable. Provided for Qt 4.x compatibility
i686 Extra qt5-networkauth 5.8.0-1 Network authentication module
i686 Extra qt5-speech 5.8.0-1 Qt module to make text to speech and speech recognition easy
i686 Extra flatpak 0.8.2-1 Application deployment framework for desktop apps
i686 Extra network-manager-applet 1.4.4-3 Applet for managing network connections
i686 Extra networkmanager-vpnc 1.2.4-2 NetworkManager VPN plugin for VPNC
i686 Extra networkmanager-openconnect 1.2.4-2 NetworkManager VPN plugin for OpenConnect
i686 Extra nm-connection-editor 1.4.4-3 NetworkManager GUI connection editor and widgets
i686 Extra networkmanager-openvpn 1.2.8-2 NetworkManager VPN plugin for OpenVPN
i686 Extra networkmanager-pptp 1.2.4-2 NetworkManager VPN plugin for PPTP
i686 Extra linux-zen 4.9.6-1 The Linux-zen kernel and modules
i686 Extra thunderbird 45.7.0-1 Standalone mail and news reader from mozilla.org
i686 Extra firefox 51.0.1-1 Standalone web browser from mozilla.org
i686 Extra linux-zen-docs 4.9.6-1 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
i686 Extra linux-zen-headers 4.9.6-1 Header files and scripts for building modules for Linux-zen kernel
i686 Extra empathy 3.12.12+69+g841af5f32-1 A GNOME instant messaging client using the Telepathy framework
i686 Extra geoclue2 2.4.5-1 Modular geoinformation service built on the D-Bus messaging system
i686 Extra system-config-printer 1.5.9-2 A CUPS printer configuration tool and status applet
i686 Extra libreoffice-fresh 5.2.5-1 LibreOffice branch which contains new features and program enhancements
i686 Extra xf86-video-ati 1:7.8.99.r23.gd611d21d-1 X.org ati video driver
i686 Extra libreoffice-fresh-sdk 5.2.5-1 Software Development Kit for LibreOffice Fresh
i686 Extra fetchmail 6.3.26-5 A remote-mail retrieval utility
i686 Extra gdb-common 7.12.1-1 The GNU Debugger
i686 Extra gdb 7.12.1-1 The GNU Debugger
i686 Extra libcanberra 0.30-8 A small and lightweight implementation of the XDG Sound Theme Specification
i686 Extra libcanberra-gstreamer 0.30-8 GStreamer plugin for libcanberra
i686 Extra libcanberra-pulse 0.30-8 PulseAudio plugin for libcanberra
i686 Testing libcups 2.2.2-2 The CUPS Printing System - client libraries and headers
i686 Testing cups 2.2.2-2 The CUPS Printing System - daemon package
i686 Testing libdrm 2.4.75-1 Userspace interface to kernel DRM services
x86_64
x86_64 Core nss 3.28.1-1 Network Security Services
x86_64 Core ca-certificates-mozilla 3.28.1-1 Mozilla's set of trusted CA certificates
x86_64 Core openssl 1.0.2.k-1 The Open Source toolkit for Secure Sockets Layer and Transport Layer Security
x86_64 Extra kanagram 16.12.1-2 Letter Order Game
x86_64 Extra konqueror 16.12.1-2 KDE File Manager & Web Browser
x86_64 Extra knotifyconfig 5.30.0-2 Configuration system for KNotify
x86_64 Extra ktextwidgets 5.30.0-2 Advanced text editing widgets
x86_64 Extra knotifications 5.30.0-2 Abstraction for system notifications
x86_64 Community skrooge 2.7.0-2 A personal finances manager for KDE
x86_64 Community deepin-qt5integration 0.0.6-2 Deepin Qt5 platform plugin
x86_64 Community deepin-tool-kit 0.2.1-3 Base development tool of all C++/Qt Developer work on Deepin
x86_64 Community lxqt-qtplugin 0.11.0-2 LXQt platform integration for Qt
x86_64 Community qt5ct 0.29-4 Qt5 Configuration Utility
x86_64 Community fcitx-qt5 1.0.6-3 Qt5 IM Module for Fcitx
x86_64 Extra qt5-graphicaleffects 5.8.0-1 Graphical effects for use with Qt Quick 2
x86_64 Extra qt5-serialbus 5.8.0-1 Qt module for general purpose serial bus access
x86_64 Extra qt5-connectivity 5.8.0-1 Provides access to Bluetooth hardware
x86_64 Extra qt5-gamepad 5.8.0-1 Adds support for getting events from gamepad devices
x86_64 Extra qt5-quickcontrols 5.8.0-1 Reusable Qt Quick based UI controls to create classic desktop-style user interfaces
x86_64 Extra qt5-charts 5.8.0-1 Provides a set of easy to use chart components
x86_64 Extra qt5-virtualkeyboard 5.8.0-1 Virtual keyboard framework
x86_64 Extra qt5-multimedia 5.8.0-1 Classes for audio, video, radio and camera functionality
x86_64 Extra python2-pyqt5 5.7.1-3 A set of Python 2.x bindings for the Qt5 toolkit
x86_64 Extra qt5-serialport 5.8.0-1 Provides access to hardware and virtual serial ports
x86_64 Extra qt5-3d 5.8.0-1 C++ and QML APIs for easy inclusion of 3D graphics
x86_64 Extra qt5-datavis3d 5.8.0-1 Qt Data Visualization module
x86_64 Extra plasma-integration 5.8.5-5 Qt Platform Theme integration plugins for the Plasma workspaces
x86_64 Extra qt5-websockets 5.8.0-1 Provides WebSocket communication compliant with RFC 6455
x86_64 Extra kwin 5.8.5-3 KDE Window manager
x86_64 Extra qt5-imageformats 5.8.0-1 Plugins for additional image formats: TIFF, MNG, TGA, WBMP
x86_64 Extra qt5-sensors 5.8.0-1 Provides access to sensor hardware and motion gesture recognition
x86_64 Extra qt5-location 5.8.0-1 Provides access to position, satellite and area monitoring classes
x86_64 Extra qt5-xmlpatterns 5.8.0-1 Support for XPath, XQuery, XSLT and XML schema validation
x86_64 Extra pyqt5-common 5.7.1-3 Common PyQt files shared between python-pyqt5 and python2-pyqt5
x86_64 Extra qt5-canvas3d 5.8.0-1 A Javascript 3D rendering API for Qt Quick
x86_64 Extra qt5-webchannel 5.8.0-1 Provides access to QObject or QML objects from HTML clients for seamless integration of Qt applications with HTML/Javascript clients
x86_64 Extra qt5-declarative 5.8.0-1 Classes for QML and Javascript languages
x86_64 Extra akonadi 16.12.1-3 PIM layer, which provides an asynchronous API to access all kind of PIM data
x86_64 Extra qt5-wayland 5.8.0-1 Provides APIs for Wayland
x86_64 Extra qt5-webengine 5.8.0-1 Provides support for web applications using the Chromium browser project
x86_64 Extra qt5-base 5.8.0-2 A cross-platform application and UI framework
x86_64 Extra qt5-webview 5.8.0-1 Provides a way to display web content in a QML application
x86_64 Extra qt5-quickcontrols2 5.8.0-1 Next generation user interface controls based on Qt Quick
x86_64 Extra qt5-webkit 5.8.0-1 Classes for a WebKit2 based implementation and a new QML API
x86_64 Extra qt5-scxml 5.8.0-1 Static and runtime integration of SCXML models into Qt code
x86_64 Extra qt5-tools 5.8.0-1 A cross-platform application and UI framework (Development Tools, QtHelp)
x86_64 Extra qt5-svg 5.8.0-1 Classes for displaying the contents of SVG files
x86_64 Extra gcin 2.8.4-5 Input method server supporting various input methods
x86_64 Extra python-pyqt5 5.7.1-3 A set of Python 3.x bindings for the Qt5 toolkit
x86_64 Extra qt5-x11extras 5.8.0-1 Provides platform-specific APIs for X11
x86_64 Extra qt5-script 5.8.0-1 Classes for making Qt applications scriptable. Provided for Qt 4.x compatibility
x86_64 Extra qt5-networkauth 5.8.0-1 Network authentication module
x86_64 Extra qt5-speech 5.8.0-1 Qt module to make text to speech and speech recognition easy
x86_64 Community planarity 3.0.0.5-1 A library for implementing graph algorithms
x86_64 Community fzf 0.16.2-1 Command-line fuzzy finder
x86_64 Community gmerlin 1.2.0-8 Multimedia architecture for Linux
x86_64 Extra flatpak 0.8.2-1 Application deployment framework for desktop apps
x86_64 Extra network-manager-applet 1.4.4-3 Applet for managing network connections
x86_64 Extra networkmanager-vpnc 1.2.4-2 NetworkManager VPN plugin for VPNC
x86_64 Extra networkmanager-openconnect 1.2.4-2 NetworkManager VPN plugin for OpenConnect
x86_64 Extra nm-connection-editor 1.4.4-3 NetworkManager GUI connection editor and widgets
x86_64 Extra networkmanager-openvpn 1.2.8-2 NetworkManager VPN plugin for OpenVPN
x86_64 Extra networkmanager-pptp 1.2.4-2 NetworkManager VPN plugin for PPTP
x86_64 Community muine 0.8.11-3 A music player written in C Sharp
x86_64 Extra linux-zen 4.9.6-1 The Linux-zen kernel and modules
x86_64 Extra thunderbird 45.7.0-1 Standalone mail and news reader from mozilla.org
x86_64 Extra firefox 51.0.1-1 Standalone web browser from mozilla.org
x86_64 Extra linux-zen-docs 4.9.6-1 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
x86_64 Extra linux-zen-headers 4.9.6-1 Header files and scripts for building modules for Linux-zen kernel
x86_64 Community seamonkey 2.46-2 SeaMonkey internet suite
x86_64 Extra empathy 3.12.12+69+g841af5f32-1 A GNOME instant messaging client using the Telepathy framework
x86_64 Extra geoclue2 2.4.5-1 Modular geoinformation service built on the D-Bus messaging system
x86_64 Community consul 0.7.3-1 A tool for service discovery, monitoring and configuration.
x86_64 Community gambas3-gb-web 3.9.2-1 CGI component
x86_64 Community gambas3-gb-ncurses 3.9.2-1 Ncurses component
x86_64 Community gambas3-gb-qt5-opengl 3.9.2-1 Qt5 toolkit OpenGL component
x86_64 Community gambas3-gb-pcre 3.9.2-1 PCRE component
x86_64 Community gambas3-gb-db-sqlite2 3.9.2-1 Sqlite2 database access component
x86_64 Community gambas3-devel 3.9.2-1 Development environment
x86_64 Community gambas3-gb-form-editor 3.9.2-1 Editor component
x86_64 Community gambas3-gb-httpd 3.9.2-1 Embedded HTTP server for the interpreter
x86_64 Community gambas3-gb-crypt 3.9.2-1 MD5/DES crypting component
x86_64 Community gambas3-gb-image-io 3.9.2-1 Input/Output image component
x86_64 Community gambas3-gb-util 3.9.2-1 Miscellaneous utility functions component
x86_64 Community gambas3-gb-sdl 3.9.2-1 SDL component
x86_64 Community gambas3-gb-form-dialog 3.9.2-1 Form dialog component
x86_64 Community gambas3-gb-db-sqlite3 3.9.2-1 Sqlite3 database access component
x86_64 Community gambas3-script 3.9.2-1 Scripter and server programs support
x86_64 Community gambas3-gb-cairo 3.9.2-1 Cairo component
x86_64 Community gambas3-gb-sdl2 3.9.2-1 SDL2 component
x86_64 Community gambas3-gb-map 3.9.2-1 Display maps component
x86_64 Community gambas3-gb-gtk 3.9.2-1 GTK+ toolkit component
x86_64 Community gambas3-gb-xml-xslt 3.9.2-1 XML-XSLT component
x86_64 Community gambas3-gb-libxml 3.9.2-1 libxml2 component
x86_64 Community gambas3-gb-logging 3.9.2-1 Flexible log message handling component
x86_64 Community gambas3-gb-mysql 3.9.2-1 Mysql extra component
x86_64 Community gambas3-gb-opengl-glsl 3.9.2-1 GLSL component
x86_64 Community gambas3-gb-chart 3.9.2-1 Chart component
x86_64 Community gambas3-gb-sdl2-audio 3.9.2-1 SDL2 audio component
x86_64 Community gambas3-gb-option 3.9.2-1 Getopt component
x86_64 Community gambas3-gb-signal 3.9.2-1 POSIX Signals component
x86_64 Community gambas3-gb-qt4-opengl 3.9.2-1 Qt4 toolkit OpenGL component
x86_64 Community gambas3-gb-image-imlib 3.9.2-1 Imlib component
x86_64 Community gambas3-gb-pdf 3.9.2-1 PDF component
x86_64 Community gambas3-gb-db 3.9.2-1 Database access component
x86_64 Community gambas3-gb-args 3.9.2-1 Command-line options analyzer component
x86_64 Community gambas3-gb-opengl-sge 3.9.2-1 Simple OpenGL game engine component
x86_64 Community gambas3-gb-form-stock 3.9.2-1 Default stock icons component
x86_64 Community gambas3-gb-util-web 3.9.2-1 Miscellaneous web utility functions component
x86_64 Community gambas3-gb-mime 3.9.2-1 MIME message component
x86_64 Community gambas3-gb-form-terminal 3.9.2-1 Terminal component
x86_64 Community gambas3-gb-desktop-x11 3.9.2-1 X-Window library support component
x86_64 Community gambas3-gb-openssl 3.9.2-1 Openssl component
x86_64 Community gambas3-gb-report 3.9.2-1 Report component
x86_64 Community gambas3-gb-db-postgresql 3.9.2-1 PostgreSQL database access component
x86_64 Community gambas3-gb-gtk3 3.9.2-1 GTK3 toolkit component
x86_64 Community gambas3-gb-settings 3.9.2-1 Setting component
x86_64 Community gambas3-gb-markdown 3.9.2-1 Convert the Gambas markdown syntax to HTML
x86_64 Community gambas3-gb-net 3.9.2-1 Network component
x86_64 Community gambas3-gb-qt4 3.9.2-1 Qt4 toolkit component
x86_64 Community gambas3-gb-net-curl 3.9.2-1 Curl component
x86_64 Community gambas3-gb-eval-highlight 3.9.2-1 Expression evaluator highlight component
x86_64 Community gambas3-gb-dbus 3.9.2-1 DBUS component
x86_64 Community gambas3-gb-desktop 3.9.2-1 Desktop component
x86_64 Community gambas3-gb-compress 3.9.2-1 Compression support component
x86_64 Community gambas3-gb-xml-rpc 3.9.2-1 XML-RPC component
x86_64 Community gambas3-gb-qt4-webkit 3.9.2-1 Qt4 toolkit webkit component
x86_64 Community gambas3-gb-net-pop3 3.9.2-1 POP3 component
x86_64 Community gambas3-gb-scanner 3.9.2-1 Scanimage frontend component
x86_64 Community gambas3-gb-image-effect 3.9.2-1 Image effect component
x86_64 Community gambas3-runtime 3.9.2-1 Runtime environment
x86_64 Community gambas3-gb-form 3.9.2-1 Form component
x86_64 Community gambas3-gb-opengl-glu 3.9.2-1 GL Utility component
x86_64 Community gambas3-gb-media 3.9.2-1 Simplified interface to the GStreamer library component
x86_64 Community gambas3-gb-db-odbc 3.9.2-1 ODBC database access component
x86_64 Community gambas3-gb-opengl 3.9.2-1 OpenGL component
x86_64 Community gambas3-gb-xml 3.9.2-1 XML component
x86_64 Community gambas3-gb-openal 3.9.2-1 OpenAL 3D audio component
x86_64 Community gambas3-gb-data 3.9.2-1 Data containers component
x86_64 Community gambas3-gb-sdl-sound 3.9.2-1 SDL sound component
x86_64 Community gambas3-gb-desktop-gnome 3.9.2-1 Desktop component for Gnome
x86_64 Community gambas3-gb-image 3.9.2-1 Image component
x86_64 Community gambas3-gb-memcached 3.9.2-1 Memcached client component
x86_64 Community gambas3-gb-net-smtp 3.9.2-1 SMTP component
x86_64 Community gambas3-gb-qt5-webkit 3.9.2-1 Qt5 toolkit webkit component
x86_64 Community gambas3-gb-gtk-opengl 3.9.2-1 GTK+ toolkit OpenGL component
x86_64 Community gambas3-gb-vb 3.9.2-1 Visual Basic transitional component
x86_64 Community gambas3-gb-db-mysql 3.9.2-1 MySQL database access component
x86_64 Community gambas3-gb-media-form 3.9.2-1 Media player control component
x86_64 Community gambas3-gb-db-form 3.9.2-1 Database form component
x86_64 Community gambas3-gb-web-form 3.9.2-1 web form component
x86_64 Community gambas3-gb-gmp 3.9.2-1 Arbitrary precision arithmetic component
x86_64 Community gambas3-gb-qt4-ext 3.9.2-1 Qt4 toolkit extended component
x86_64 Community gambas3-gb-complex 3.9.2-1 Complex numbers component
x86_64 Community gambas3-gb-qt5 3.9.2-1 Qt5 toolkit component
x86_64 Community gambas3-gb-form-mdi 3.9.2-1 Form MDI component
x86_64 Community gambas3-gb-clipper 3.9.2-1 Polygon clipping component
x86_64 Community gambas3-gb-gsl 3.9.2-1 The GNU Scientific Library component
x86_64 Community gambas3-ide 3.9.2-1 Integrated Development Environment
x86_64 Community gambas3-gb-inotify 3.9.2-1 Filesystem events monitoring component
x86_64 Community gambas3-gb-v4l 3.9.2-1 Video4linux component
x86_64 Community gambas3-gb-xml-html 3.9.2-1 HTML generator component
x86_64 Multilib wine-staging-nine 2.0-1 A compatibility layer for running Windows programs - Staging branch with the gallium-nine patches
x86_64 Extra system-config-printer 1.5.9-2 A CUPS printer configuration tool and status applet
x86_64 Extra libreoffice-fresh 5.2.5-1 LibreOffice branch which contains new features and program enhancements
x86_64 Extra xf86-video-ati 1:7.8.99.r23.gd611d21d-1 X.org ati video driver
x86_64 Extra libreoffice-fresh-sdk 5.2.5-1 Software Development Kit for LibreOffice Fresh
x86_64 Testing libcups 2.2.2-2 The CUPS Printing System - client libraries and headers
x86_64 Testing cups 2.2.2-2 The CUPS Printing System - daemon package
x86_64 Community utox 0.12.1-2 Lightweight Tox client
x86_64 Community libfilteraudio 0.0.1-3 An easy to use audio filtering library made from webrtc code
x86_64 Multilib-Testing lib32-libdrm 2.4.75-1 Userspace interface to kernel DRM services (32-bit)
x86_64 Testing libdrm 2.4.75-1 Userspace interface to kernel DRM services
x86_64 Extra fetchmail 6.3.26-5 A remote-mail retrieval utility
x86_64 Community fcitx-libpinyin 0.4.1-1 Fcitx Wrapper for libpinyin, Library to deal with pinyin
x86_64 Community gitlab 8.16.3-1 Project management and code hosting application
x86_64 Community avr-gdb 7.12.1-1 The GNU Debugger for AVR
x86_64 Community aarch64-linux-gnu-gdb 7.12.1-1 The GNU Debugger for the ARM64 target
x86_64 Community arm-none-eabi-gdb 7.12.1-1 The GNU Debugger for the ARM EABI (bare-metal) target
x86_64 Extra gdb-common 7.12.1-1 The GNU Debugger
x86_64 Extra gdb 7.12.1-1 The GNU Debugger
x86_64 Community kio-gdrive 1.1.0-1 KIO Slave to access Google Drive
x86_64 Extra libcanberra 0.30-8 A small and lightweight implementation of the XDG Sound Theme Specification
x86_64 Extra libcanberra-gstreamer 0.30-8 GStreamer plugin for libcanberra
x86_64 Extra libcanberra-pulse 0.30-8 PulseAudio plugin for libcanberra
AUR
mpv-semifull-git 0.23.0.r164.g954625c165-1
openra-kang kang.2b72352-1
prosody-hg r7878+.2fdb7b3648d8+-1
ffmpeg-semifull-git N.83277.gc4a3526b57-1
cleanupdate-git 0.6-5
cura-git 2.3.0.1354.g35cbedc5-1
cura-fdm-materials-git cura.2.3.0.7.g96f68f3-1
liri-shell-git 20161016.c2269e8-1
liri-wayland-git 20170127.86184df-1
qt-sdk-raspberry-pi 5.8.0-9
gambit-c-git 4.8.7.r11.g0209073-1
hop-git 3.0.0r822.b60c4eb-1
eclipse-pmd 4.0.11-2
qmplay2-git 17.01.24-1
emacs-org-mode-git 9.0.4.247.g401eecb52-1
Thanks
Posted ImagePosted Image
Configs/PGP Key/comhack π
#2014 OFFLINE   securitybreach
  • 24,208 posts
Posted 01 February 2017 - 11:28 PM
Updates for Wednesday, January 31, 2016
Any
any Community python2-gflags 3.1.1-1 Commandline flags module for Python
any Community closure-compiler 20170124-1 Performs checking, instrumentation and optimizations on Javascript code.
any Community python-gflags 3.1.1-1 Commandline flags module for Python
any Community salt 2016.11.2-1 Central system and configuration manager
any Community spampd 2.30-13 Spamassassin Proxy Daemon
any Testing plasma-workspace-wallpapers 5.9.0-1 Additional wallpapers for the Plasma Workspace
any Testing breeze-grub 5.9.0-1 Breeze theme for GRUB
i686
i686 Core libutil-linux 2.29.1-1 util-linux runtime libraries
i686 Core util-linux 2.29.1-1 Miscellaneous system utilities for Linux
i686 Core systemd-sysvcompat 232-8 sysvinit compat for systemd
i686 Core systemd 232-8 system and service manager
i686 Core libsystemd 232-8 systemd client libraries
i686 Community libcec 4.0.2-1 Pulse-Eight's libcec for the Pulse-Eight USB-CEC adapter
i686 Community php-mongodb 1.2.5-1 MongoDB driver for PHP
i686 Community clipgrab 3.6.3-1 A video downloader and converter for YouTube, Veoh, DailyMotion, MyVideo, ...
i686 Community blender 17:2.78.a-7 A fully integrated 3D graphics creation suite
i686 Community python-pyside 1.2.4-6 Provides LGPL Qt bindings for Python and related tools for binding generation (Python 3 version)
i686 Community python-pyside-common 1.2.4-6 Provides LGPL Qt bindings for Python and related tools for binding generation (Common Files)
i686 Community python2-pyside 1.2.4-6 Provides LGPL Qt bindings for Python and related tools for binding generation (Python 2 version)
i686 Community opensubdiv 3.1.1-1 An Open-Source subdivision surface library
i686 Community sssd 1.15.0-1 System Security Services Daemon
i686 Community lxc 1:2.0.7-1 Linux Containers
i686 Extra krita 3.1.2.1-1 Edit and paint images
i686 Extra qt5-speech 5.8.0-2 Qt module to make text to speech and speech recognition easy
i686 Testing plasma-pa 5.9.0-1 Plasma applet for audio volume management using PulseAudio
i686 Testing kwallet-pam 5.9.0-1 KWallet PAM integration
i686 Testing oxygen-kde4 5.9.0-1 KDE Oxygen style for KDE4 applications
i686 Testing plasma-workspace 5.9.0-1 KDE Plasma Workspace
i686 Testing kdecoration 5.9.0-1 Plugin based library to create window decorations
i686 Testing kactivitymanagerd 5.9.0-1 System service to manage user's activities and track the usage patterns
i686 Testing polkit-kde-agent 5.9.0-1 Daemon providing a polkit authentication UI for KDE
i686 Testing user-manager 5.9.0-1 A simple system settings module to manage the users of your system
i686 Testing plasma-desktop 5.9.0-1 KDE Plasma Desktop
i686 Testing kde-gtk-config 5.9.0-1 GTK2 and GTK3 Configurator for KDE
i686 Testing breeze 5.9.0-1 Artwork, styles and assets for the Breeze visual style for the Plasma Desktop
i686 Testing khotkeys 5.9.0-1 KHotKeys
i686 Testing kwin 5.9.0-1 KDE Window manager
i686 Testing kscreenlocker 5.9.0-1 Library and components for secure lock screen architecture
i686 Testing ksysguard 5.9.0-1 Track and control the processes running in your system
i686 Testing oxygen 5.9.0-1 KDE Oxygen style
i686 Testing kde-cli-tools 5.9.0-1 Tools based on KDE Frameworks 5 to better interact with the system
i686 Testing systemsettings 5.9.0-1 KDE system settings
i686 Testing kscreen 5.9.0-1 KDE's screen management software
i686 Testing powerdevil 5.9.0-1 Manages the power consumption settings of a Plasma Shell
i686 Testing kinfocenter 5.9.0-1 A utility that provides information about a computer system
i686 Testing sddm-kcm 5.9.0-1 KDE Config Module for SDDM
i686 Testing drkonqi 5.9.0-1 KDE crash handler
i686 Testing libksysguard 5.9.0-1 Libksysguard
i686 Testing kmenuedit 5.9.0-1 KDE menu editor
i686 Testing kwrited 5.9.0-1 KDE daemon listening for wall and write messages
i686 Testing kdeplasma-addons 5.9.0-1 All kind of addons to improve your Plasma experience
i686 Testing plasma-nm 5.9.0-1 Plasma applet written in QML for managing network connections
i686 Testing milou 5.9.0-1 A dedicated search application built on top of Baloo
i686 Testing kgamma5 5.9.0-1 Adjust your monitor's gamma settings
i686 Testing breeze-gtk 5.9.0-1 Breeze widget theme for GTK 2 and 3
i686 Testing plasma-sdk 5.9.0-1 Applications useful for Plasma development
i686 Testing kwayland-integration 5.9.0-1 Provides integration plugins for various KDE frameworks for the wayland windowing system
i686 Testing bluedevil 1:5.9.0-1 Integrate the Bluetooth technology within KDE workspace and applications
i686 Testing kuiserver 5.9.0-1 KDE Progress Info UI server
i686 Testing ksshaskpass 5.9.0-1 ssh-add helper that uses kwallet and kpassworddialog
i686 Testing breeze-kde4 5.9.0-1 Breeze widget style for KDE4 applications
i686 Testing libkscreen 5.9.0-1 KDE screen management software
i686 Testing plasma-wayland-session 5.9.0-1 Plasma Wayland session
i686 Testing plasma-integration 5.9.0-1 Qt Platform Theme integration plugins for the Plasma workspaces
i686 Community-Testing discover 5.9.0-1 A collection of package management tools for KDE
x86_64
x86_64 Core libutil-linux 2.29.1-1 util-linux runtime libraries
x86_64 Core util-linux 2.29.1-1 Miscellaneous system utilities for Linux
x86_64 Core systemd-sysvcompat 232-8 sysvinit compat for systemd
x86_64 Core systemd 232-8 system and service manager
x86_64 Core libsystemd 232-8 systemd client libraries
x86_64 Community libcec 4.0.2-1 Pulse-Eight's libcec for the Pulse-Eight USB-CEC adapter
x86_64 Community php-mongodb 1.2.5-1 MongoDB driver for PHP
x86_64 Community clipgrab 3.6.3-1 A video downloader and converter for YouTube, Veoh, DailyMotion, MyVideo, ...
x86_64 Community blender 17:2.78.a-7 A fully integrated 3D graphics creation suite
x86_64 Community python-pyside 1.2.4-6 Provides LGPL Qt bindings for Python and related tools for binding generation (Python 3 version)
x86_64 Community python-pyside-common 1.2.4-6 Provides LGPL Qt bindings for Python and related tools for binding generation (Common Files)
x86_64 Community python2-pyside 1.2.4-6 Provides LGPL Qt bindings for Python and related tools for binding generation (Python 2 version)
x86_64 Community opensubdiv 3.1.1-1 An Open-Source subdivision surface library
x86_64 Community lxc 1:2.0.7-1 Linux Containers
x86_64 Community sssd 1.15.0-1 System Security Services Daemon
x86_64 Extra krita 3.1.2.1-1 Edit and paint images
x86_64 Extra qt5-speech 5.8.0-2 Qt module to make text to speech and speech recognition easy
x86_64 Multilib lib32-util-linux 2.29.1-1 Miscellaneous system utilities for Linux (32-bit)
x86_64 Testing plasma-pa 5.9.0-1 Plasma applet for audio volume management using PulseAudio
x86_64 Testing kwallet-pam 5.9.0-1 KWallet PAM integration
x86_64 Testing oxygen-kde4 5.9.0-1 KDE Oxygen style for KDE4 applications
x86_64 Testing plasma-workspace 5.9.0-1 KDE Plasma Workspace
x86_64 Testing kdecoration 5.9.0-1 Plugin based library to create window decorations
x86_64 Testing kactivitymanagerd 5.9.0-1 System service to manage user's activities and track the usage patterns
x86_64 Testing polkit-kde-agent 5.9.0-1 Daemon providing a polkit authentication UI for KDE
x86_64 Testing user-manager 5.9.0-1 A simple system settings module to manage the users of your system
x86_64 Testing plasma-desktop 5.9.0-1 KDE Plasma Desktop
x86_64 Testing kde-gtk-config 5.9.0-1 GTK2 and GTK3 Configurator for KDE
x86_64 Testing breeze 5.9.0-1 Artwork, styles and assets for the Breeze visual style for the Plasma Desktop
x86_64 Testing kwin 5.9.0-1 KDE Window manager
x86_64 Testing kscreenlocker 5.9.0-1 Library and components for secure lock screen architecture
x86_64 Testing ksysguard 5.9.0-1 Track and control the processes running in your system
x86_64 Testing oxygen 5.9.0-1 KDE Oxygen style
x86_64 Testing kde-cli-tools 5.9.0-1 Tools based on KDE Frameworks 5 to better interact with the system
x86_64 Testing systemsettings 5.9.0-1 KDE system settings
x86_64 Testing kscreen 5.9.0-1 KDE's screen management software
x86_64 Testing powerdevil 5.9.0-1 Manages the power consumption settings of a Plasma Shell
x86_64 Testing kinfocenter 5.9.0-1 A utility that provides information about a computer system
x86_64 Testing sddm-kcm 5.9.0-1 KDE Config Module for SDDM
x86_64 Testing drkonqi 5.9.0-1 KDE crash handler
x86_64 Testing kmenuedit 5.9.0-1 KDE menu editor
x86_64 Testing kwrited 5.9.0-1 KDE daemon listening for wall and write messages
x86_64 Testing kdeplasma-addons 5.9.0-1 All kind of addons to improve your Plasma experience
x86_64 Testing plasma-nm 5.9.0-1 Plasma applet written in QML for managing network connections
x86_64 Testing milou 5.9.0-1 A dedicated search application built on top of Baloo
x86_64 Testing kgamma5 5.9.0-1 Adjust your monitor's gamma settings
x86_64 Testing breeze-gtk 5.9.0-1 Breeze widget theme for GTK 2 and 3
x86_64 Testing plasma-sdk 5.9.0-1 Applications useful for Plasma development
x86_64 Testing kwayland-integration 5.9.0-1 Provides integration plugins for various KDE frameworks for the wayland windowing system
x86_64 Testing bluedevil 1:5.9.0-1 Integrate the Bluetooth technology within KDE workspace and applications
x86_64 Testing kuiserver 5.9.0-1 KDE Progress Info UI server
x86_64 Testing ksshaskpass 5.9.0-1 ssh-add helper that uses kwallet and kpassworddialog
x86_64 Testing breeze-kde4 5.9.0-1 Breeze widget style for KDE4 applications
x86_64 Testing libkscreen 5.9.0-1 KDE screen management software
x86_64 Testing plasma-wayland-session 5.9.0-1 Plasma Wayland session
x86_64 Testing plasma-integration 5.9.0-1 Qt Platform Theme integration plugins for the Plasma workspaces
x86_64 Community-Testing discover 5.9.0-1 A collection of package management tools for KDE
AUR
exfat-utils-autodetect 1.2.5-1
rust-nightly 1.16.0_2017.02.02-1
emacs-org-mode-git 9.0.4.263.gf157283c1-1
auctex-git 11.90.22.g6c91dba2-1
tex2page-git 20170128-1
roswell 17.1.8.73-1
nginx-mainline-libressl 1.11.9-1
mssql-tools 14.0.2.0-2
mssql-msodbcsql 13.1.3.0-1
textext-hg r270.f3aa796691ed-1
todoman 2.0.1-1
ryver-desktop 1.2.0-1
hhvm-hack-git 3.17.2-1
php-imagick 3.4.3-1
lily 1.0-0
Thanks
#2015 OFFLINE   securitybreach
  • 24,208 posts
Posted 06 February 2017 - 07:23 PM
Updates for Sunday, February 5th, 2017
Any
any Community libretro-overlays 106-1 Collection of overlays for libretro
any Community udiskie 1.5.1-4 Removable disk automounter using udisks
any Community urbanterror-data 2:4.3.2-2 A team-based tactical shooter based on the Quake 3 Engine (data files)
any Community acorn 4.0.8-1 A tiny, fast Javascript parser, written completely in Javascript.
any Community python2-waitress 1.0.2-1 Waitress WSGI server
any Community python-waitress 1.0.2-1 Waitress WSGI server
any Community retroarch-autoconfig-udev 1110-1 udev joypad autoconfig for RetroArch
any Community retroarch-assets-xmb 378-1 XMB menu assets for RetroArch
any Extra gajim 0.16.7-1 A full featured and easy to use Jabber client
any Extra iso-codes 3.74-1 Lists of the country, language, and currency names
any Extra intltool 0.51.0-2 The internationalization tool collection
any Extra perl-exporter-tiny 0.044-1 an exporter with the features of Sub::Exporter but only core dependencies
any Extra fsharp 4.0.1.21-1 The Open Edition of the F# compiler, core library and tools
any Extra tomcat8 8.0.41-2 Open source implementation of the Java Servlet 3.1 and JavaServer Pages 2.3 technologies
any Extra tomcat7 7.0.75-2 Open source implementation of the Java Servlet 3.0 and JavaServer Pages 2.2 technologies\
any Testing python2-pyasn1 0.2.1-1 ASN.1 library for Python 2
any Testing python-pyasn1 0.2.1-1 ASN.1 library for Python 3
i686
i686 Core grub 1:2.02.rc1-1 GNU GRand Unified Bootloader (2)
i686 Core linux-lts-headers 4.4.47-1 Header files and scripts for building modules for Linux-lts kernel
i686 Core linux-lts 4.4.47-1 The Linux-lts kernel and modules
i686 Core linux-lts-docs 4.4.47-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
i686 Community libgiac 1.2.3.21-1 Giac shared library
i686 Community xcas 1.2.3.21-1 A free computer algebra system
i686 Community kpmcore 3.0.3-1 Library for managing partitions
i686 Community libretro-nestopia 721-1 Nintendo Entertainment System core
i686 Community libretro-mgba 4278-1 Nintendo Game Boy Advance core
i686 Community fzf 0.16.4-1 Command-line fuzzy finder
i686 Community urbanterror 2:4.3.2-2 A team-based tactical shooter based on the Quake 3 Engine
i686 Community haskell-lexer 1.0.1-1 A fully compliant Haskell 98 lexer.
i686 Community deepin-terminal 2.1.10-1 Default terminal emulation application for Deepin
i686 Community haskell-hxt 9.3.1.16-1 A collection of tools for processing XML with Haskell.
i686 Community haskell-hxt-regex-xmlschema 9.2.0.3-1 A regular expression library for W3C XML Schema regular expressions
i686 Community utox 0.12.2-3 Lightweight Tox client
i686 Community libretro-mednafen-psx 1430-1 Sony PlayStation core
i686 Community libretro-mednafen-psx-hw 1430-1 Sony PlayStation core
i686 Community libretro-genesis-plus-gx 1111-1 Sega MS/GG/MD/CD core
i686 Community libretro-gambatte 635-1 Nintendo Game Boy/Game Boy Color core
i686 Community libretro-desmume 5301-1 Nintendo DS core
i686 Community libretro-bsnes 499-1 Super Nintendo Entertainment System cores
i686 Community mx 1.4.7+13+g24efb0cc-1 A widget toolkit using Clutter
i686 Community haskell-tagstream-conduit 0.5.5.3-52 Streamlined html tag parser
i686 Community haskell-xml-hamlet 0.4.1-3 Hamlet-style quasiquoter for XML content
i686 Community haskell-xml-conduit 1.4.0.3-1 Pure-Haskell utilities for dealing with XML with the conduit package.
i686 Community haskell-hxt-unicode 9.0.2.4-1 Unicode en-/decoding functions for utf8, iso-latin-* and other encodings
i686 Community haskell-hxt-charproperties 9.2.0.1-1 Character properties and classes for XML and Unicode
i686 Extra wget 1.19-1 A network utility to retrieve files from the Web
i686 Extra gnumeric 1.12.33-1 A GNOME Spreadsheet Program
i686 Extra glib-perl 1.324-1 Perl wrappers for glib 2.x, including GObject
i686 Extra goffice 0.10.33-1 A GLib/GTK+ set of document-centric objects and charting library
i686 Extra p7zip 16.02-3 Command-line file archiver with high compression ratio
i686 Extra rhythmbox 3.4.1-2 Music playback and management application
i686 Extra lablgtk2 2.18.5-4 An Objective Caml interface to gtk2
i686 Extra cairomm 1.12.2-1 C++ bindings to Cairo vector graphics library
i686 Extra exempi 2.4.2-1 A library to parse XMP metadata
x86_64
x86_64 Core grub 1:2.02.rc1-1 GNU GRand Unified Bootloader (2)
x86_64 Core linux-lts-headers 4.4.47-1 Header files and scripts for building modules for Linux-lts kernel
x86_64 Core linux-lts 4.4.47-1 The Linux-lts kernel and modules
x86_64 Core linux-lts-docs 4.4.47-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
x86_64 Community libgiac 1.2.3.21-1 Giac shared library
x86_64 Community xcas 1.2.3.21-1 A free computer algebra system
x86_64 Community kpmcore 3.0.3-1 Library for managing partitions
x86_64 Community libretro-reicast 2550-1 Sega Dreamcast core
x86_64 Community libretro-nestopia 721-1 Nintendo Entertainment System core
x86_64 Community libretro-mupen64plus 4427-1 Nintendo 64 core
x86_64 Community libretro-mgba 4278-1 Nintendo Game Boy Advance core
x86_64 Community fzf 0.16.4-1 Command-line fuzzy finder
x86_64 Community urbanterror 2:4.3.2-2 A team-based tactical shooter based on the Quake 3 Engine
x86_64 Community haskell-lexer 1.0.1-1 A fully compliant Haskell 98 lexer.
x86_64 Community deepin-terminal 2.1.10-1 Default terminal emulation application for Deepin
x86_64 Community haskell-hxt 9.3.1.16-1 A collection of tools for processing XML with Haskell.
x86_64 Community haskell-hxt-regex-xmlschema 9.2.0.3-1 A regular expression library for W3C XML Schema regular expressions
x86_64 Community libretro-mednafen-psx 1430-1 Sony PlayStation core
x86_64 Community libretro-mednafen-psx-hw 1430-1 Sony PlayStation core
x86_64 Community libretro-genesis-plus-gx 1111-1 Sega MS/GG/MD/CD core
x86_64 Community libretro-gambatte 635-1 Nintendo Game Boy/Game Boy Color core
x86_64 Community libretro-desmume 5301-1 Nintendo DS core
x86_64 Community libretro-bsnes 499-1 Super Nintendo Entertainment System cores
x86_64 Community libretro-blastem 940-1 Sega Mega Drive core
x86_64 Community mx 1.4.7+13+g24efb0cc-1 A widget toolkit using Clutter
x86_64 Community haskell-tagstream-conduit 0.5.5.3-52 Streamlined html tag parser
x86_64 Community haskell-xml-hamlet 0.4.1-3 Hamlet-style quasiquoter for XML content
x86_64 Community haskell-xml-conduit 1.4.0.3-1 Pure-Haskell utilities for dealing with XML with the conduit package.
x86_64 Community haskell-hxt-unicode 9.0.2.4-1 Unicode en-/decoding functions for utf8, iso-latin-* and other encodings
x86_64 Community haskell-hxt-charproperties 9.2.0.1-1 Character properties and classes for XML and Unicode
x86_64 Community utox 0.12.2-3 Lightweight Tox client
x86_64 Extra wget 1.19-1 A network utility to retrieve files from the Web
x86_64 Extra gnumeric 1.12.33-1 A GNOME Spreadsheet Program
x86_64 Extra glib-perl 1.324-1 Perl wrappers for glib 2.x, including GObject
x86_64 Extra goffice 0.10.33-1 A GLib/GTK+ set of document-centric objects and charting library
x86_64 Extra p7zip 16.02-3 Command-line file archiver with high compression ratio
x86_64 Extra rhythmbox 3.4.1-2 Music playback and management application
x86_64 Extra lablgtk2 2.18.5-4 An Objective Caml interface to gtk2
x86_64 Extra cairomm 1.12.2-1 C++ bindings to Cairo vector graphics library
x86_64 Extra exempi 2.4.2-1 A library to parse XMP metadata
AUR
vicare-scheme-git 20170206.2ee22aec-1
wire-desktop 2.11.2707-1
ccd2cue 0.5-1.1
plex-media-server-plexpass-dvr 1.2.0.3167-1
plex-media-server-plexpass-hwenc 1.4.0.3224-1
zfs-linux-lts 0.6.5.9_4.4.47_1-1
zfs-utils-linux-lts 0.6.5.9_4.4.47_1-1
spl-linux-lts 0.6.5.9_4.4.47_1-1
spl-utils-linux-lts 0.6.5.9_4.4.47_1-1
zfs-linux-git 0.7.0_rc3_r73_g582cc0141_4.9.7_1-1
zfs-utils-linux-git 0.7.0_rc3_r73_g582cc0141_4.9.7_1-1
spl-linux-git 0.7.0_rc3_r2_g9704820_4.9.7_1-1
spl-utils-linux-git 0.7.0_rc3_r2_g9704820_4.9.7_1-1
zfs-linux 0.6.5.9_4.9.7_1-1
zfs-utils-linux 0.6.5.9_4.9.7_1-1
Thanks
#2016 OFFLINE   securitybreach
  • 24,208 posts
Posted 12 February 2017 - 03:51 PM
Updates for Saturday, February 11th, 2017
Any
any Core pacman-mirrorlist 20170211-1 Arch Linux mirror list for use by pacman
any Community unifi 5.4.11-1 Centralized management system for Ubiquiti UniFi AP
any Community glances 2.8.2-1 CLI curses-based monitoring tool
any Community youtube-dl 2017.02.11-1 A small command-line program to download videos from YouTube.com and a few more sites
any Community python2-sure 1.4.1-2 HTTP client mock for Python
any Community python-sure 1.4.1-2 HTTP client mock for Python
any Community libretro-shaders-cg 661-2 Collection of shaders for libretro
any Community libretro-shaders-glsl 661-2 Collection of shaders for libretro
any Community libretro-shaders-slang 661-2 Collection of shaders for libretro
any Community python-jsbeautifier 1.6.9-1 Javascript unobfuscator and beautifier
any Community python2-jsbeautifier 1.6.9-1 Javascript unobfuscator and beautifier
any Community terminator 1.90-2 Terminal emulator that supports tabs and grids
any Community python2-google-api-python-client 1.6.2-1 Google API Client Library for Python
any Community python-google-api-python-client 1.6.2-1 Google API Client Library for Python
any Community python-openpyxl 2.4.2-1 A Python library to read/write Excel 2007 xlsx/xlsm files
any Community python2-openpyxl 2.4.2-1 A Python library to read/write Excel 2007 xlsx/xlsm files
any Community create_ap 0.4.6-1 A shell script to create a NATed/Bridged Software Access Point
any Community snap-pac 0.9-1 Pacman hooks that use snapper to create pre/post btrfs snapshots like openSUSE's YaST
any Community aarch64-linux-gnu-glibc 2.25-1 GNU C Library ARM64 target
any Community docky 2.2.1.1-3 Full fledged dock application that makes opening common applications and managing windows easier and quicker
any Testing oxygen-icons-svg 1:5.31.0-1 The Oxygen Icon Theme (Scalable Vector Graphics)
any Testing kapidox 5.31.0-1 Frameworks API Documentation Tools
any Testing extra-cmake-modules 5.31.0-1 Extra modules and scripts for CMake
any Testing breeze-icons 5.31.0-1 Breeze icon themes
any Testing oxygen-icons 1:5.31.0-1 The Oxygen Icon Theme
any Community-Testing puppet 4.9.2-1 Server automation framework and application
i686
i686 Core pcre 8.40-1 A library that implements Perl 5-style regular expressions
i686 Community ngircd 24-1 Next Generation IRC Daemon
i686 Community weston 1.12.0-3 Reference implementation of a Wayland compositor
i686 Community emby-server 3.2.1-1 Bring together your videos, music, photos, and live television
i686 Community mednafen 0.9.42-1 Command-line multi-system gaming emulator
i686 Community usbip 4.9-2 An USB device sharing system over IP network
i686 Community cpupower 4.9-2 Linux kernel tool to examine and tune power saving related features of your processor
i686 Community perf 4.9-2 Linux kernel performance auditing tool
i686 Community tmon 4.9-2 Monitoring and Testing Tool for Linux kernel thermal subsystem
i686 Community linux-tools-meta 4.9-2 Linux kernel tools meta package
i686 Community x86_energy_perf_policy 4.9-2 Read or write MSR_IA32_ENERGY_PERF_BIAS
i686 Community cgroup_event_listener 4.9-2 Simple listener of cgroup events
i686 Community libtraceevent 4.9-2 Linux kernel trace event library
i686 Community turbostat 4.9-2 Report processor frequency and idle statistics
i686 Community python-pyodbc 4.0.5-1 ODBC module for Python 3.x
i686 Community python2-pyodbc 4.0.5-1 ODBC module for Python 2.x
i686 Community haskell-stmonadtrans 0.4.3-1 A monad transformer version of the ST monad
i686 Community agda 2.5.2-4 A dependently typed functional programming language and proof assistant
i686 Community haskell-equivalence 0.3.2-2 Maintaining an equivalence relation implemented as union-find using STT.
i686 Community syncthing-inotify 0.8.5-1 Inotify file watcher for Syncthing
i686 Community python-statsmodels 0.8.0-1 Statistical computations and models for use with SciPy
i686 Community python2-statsmodels 0.8.0-1 Statistical computations and models for use with SciPy
i686 Community python-blosc 1.5.0-1 A Python wrapper for the extremely fast Blosc compression library
i686 Community python2-blosc 1.5.0-1 A Python wrapper for the extremely fast Blosc compression library
i686 Community python-numexpr 2.6.2-1 Fast numerical array expression evaluator for Python, NumPy, PyTables, pandas
i686 Community python2-numexpr 2.6.2-1 Fast numerical array expression evaluator for Python, NumPy, PyTables, pandas
i686 Community arduino-builder 1.3.24-1 A command line tool for compiling Arduino sketches
i686 Community python-psutil 5.1.3-1 A cross-platform process and system utilities module for Python
i686 Community python2-psutil 5.1.3-1 A cross-platform process and system utilities module for Python2
i686 Community gnome-do 0.95.3-4 Quickly search for many items present on your desktop or the web, and perform useful actions on those items
i686 Community haskell-tasty-hunit 0.9.2-15 HUnit support for the Tasty test framework.
i686 Community haskell-dav 1.3.1-51 RFC 4918 WebDAV support
i686 Community haskell-xcffib 0.5.1-4 A cffi-based python binding for X
i686 Community stylish-haskell 0.7.1.0-6 Haskell code prettifier
i686 Community haskell-tasty-quickcheck 0.8.4-18 QuickCheck support for the Tasty test framework.
i686 Community haskell-tasty 0.11.1-2 Modern and extensible testing framework
i686 Community haskell-hjsmin 0.2.0.2-4 Haskell implementation of a javascript minifier
i686 Community haskell-criterion 1.1.4.0-17 Robust, reliable performance measurement and analysis
i686 Community haskell-tasty-rerun 1.1.6-11 Run tests by filtering the test tree depending on the result of previous test runs
i686 Community haskell-wai-app-static 3.1.6.1-30 WAI application for static serving
i686 Community git-repair 1.20161118-2 Repairs a damaged git repisitory
i686 Community haskell-turtle 1.3.1-3 Shell programming, Haskell-style
i686 Community haskell-optparse-simple 0.0.3-34 Simple interface to optparse-applicative
i686 Community haskell-optparse-applicative 0.13.1.0-1 Utilities and combinators for parsing command line options
i686 Extra clamav 0.99.2-3 Anti-virus toolkit for Unix
i686 Extra shared-mime-info 1.8-1 Freedesktop.org Shared MIME Info
i686 Extra xf86-video-intel 1:2.99.917+757+g93942b7d-1 X.org Intel i810/i830/i915/945G/G965+ video drivers
i686 Extra xfce4-netload-plugin 1.3.1-1 A netload plugin for the Xfce panel
i686 Extra xfce4-systemload-plugin 1.2.1-1 A system load plugin for the Xfce4 panel
i686 Extra thunar 1.6.10.177.g97b3ae5c-1 Modern file manager for Xfce
i686 Extra radvd 2.16-1 IPv6 Router Advertisement Daemon
i686 Extra quagga 1.2.0-1 BGP/OSPF/ISIS/RIP/RIPNG routing daemon suite
i686 Extra ffmpeg2.8 2.8.11-1 Complete solution to record, convert and stream audio and video
i686 Extra xorg-server 1.19.1-2 Xorg X server
i686 Extra xorg-server-xephyr 1.19.1-2 A nested X server that runs as an X application
i686 Extra xorg-server-common 1.19.1-2 Xorg server common files
i686 Extra xorg-server-xnest 1.19.1-2 A nested X server that runs as an X application
i686 Extra xorg-server-xvfb 1.19.1-2 Virtual framebuffer X server
i686 Extra xorg-server-xdmx 1.19.1-2 Distributed Multihead X Server and utilities
i686 Extra xorg-server-xwayland 1.19.1-2 run X clients under wayland
i686 Extra xorg-server-devel 1.19.1-2 Development files for the X.Org X server
i686 Testing btrfs-progs 4.9.1-1 Btrfs filesystem utilities
i686 Testing knotifications 5.31.0-1 Abstraction for system notifications
i686 Testing kidletime 5.31.0-1 Monitoring user activity
i686 Testing kio 5.31.0-1 Resource and network access abstraction
i686 Testing kservice 5.31.0-1 Advanced plugin and service introspection
i686 Testing kdnssd 5.31.0-1 Abstraction to system DNSSD features
i686 Testing kwindowsystem 5.31.0-1 Access to the windowing system
i686 Testing karchive 5.31.0-1 Qt 5 addon providing access to numerous types of archives
i686 Testing solid 5.31.0-1 Hardware integration and detection
i686 Testing kcodecs 5.31.0-1 Provide a collection of methods to manipulate strings using various encodings
i686 Testing kimageformats 5.31.0-1 Image format plugins for Qt5
i686 Testing kbookmarks 5.31.0-1 Support for bookmarks and the XBEL format
i686 Testing kcmutils 5.31.0-1 Utilities for interacting with KCModules
i686 Testing kcompletion 5.31.0-1 Text completion helpers and widgets
i686 Testing baloo 5.31.0-1 A framework for searching and managing metadata
i686 Testing kwidgetsaddons 5.31.0-1 Addons to QtWidgets
i686 Testing kcoreaddons 5.31.0-1 Addons to QtCore
i686 Testing kunitconversion 5.31.0-1 Support for unit conversion
i686 Testing kxmlrpcclient 5.31.0-1 XML-RPC client library for KDE
i686 Testing plasma-framework 5.31.0-1 Plasma library and runtime components based upon KF5 and Qt5
i686 Testing kdeclarative 5.31.0-1 Provides integration of QML and KDE Frameworks
i686 Testing kinit 5.31.0-1 Process launcher to speed up launching KDE applications
i686 Testing kglobalaccel 5.31.0-1 Add support for global workspace shortcuts
i686 Testing frameworkintegration 5.31.0-1 Framework providing components to allow applications to integrate with a KDE Workspace
i686 Testing kemoticons 5.31.0-1 Support for emoticons and emoticons themes
i686 Testing kitemviews 5.31.0-1 Widget addons for Qt Model/View
i686 Testing kparts 5.31.0-1 Document centric plugin system
i686 Testing attica-qt5 5.31.0-1 Qt5 library that implements the Open Collaboration Services API
i686 Testing kdoctools 5.31.0-1 Documentation generation from docbook
i686 Testing networkmanager-qt 5.31.0-1 Qt wrapper for NetworkManager API
i686 Testing kded 5.31.0-1 Extensible deamon for providing system level services
i686 Testing modemmanager-qt 5.31.0-1 Qt wrapper for ModemManager DBus API
i686 Testing ktexteditor 5.31.0-1 Advanced embeddable text editor
i686 Testing kdelibs4support 5.31.0-1 Porting aid from KDELibs4
i686 Testing kdesignerplugin 5.31.0-1 Integration of Frameworks widgets in Qt Designer/Creator
i686 Testing sonnet 5.31.0-1 Spelling framework for Qt5
i686 Testing kdbusaddons 5.31.0-1 Addons to QtDBus
i686 Testing kauth 5.31.0-1 Abstraction to system policy and authentication features
i686 Testing kdewebkit 5.31.0-1 KDE Integration for QtWebKit
i686 Testing kguiaddons 5.31.0-1 Addons to QtGui
i686 Testing kpeople 5.31.0-1 A library that provides access to all contacts and the people who hold them
i686 Testing kplotting 5.31.0-1 Lightweight plotting framework
i686 Testing kactivities-stats 5.31.0-1 A library for accessing the usage data collected by the activities system
i686 Testing kpty 5.31.0-1 Pty abstraction
i686 Testing kmediaplayer 5.31.0-1 Plugin interface for media player features
i686 Testing threadweaver 5.31.0-1 High-level multithreading framework
i686 Testing syntax-highlighting 5.31.0-1 Syntax highlighting engine for structured text and code
i686 Testing kitemmodels 5.31.0-1 Models for Qt Model/View system
i686 Testing kactivities 5.31.0-1 Core components for the KDE's Activities
i686 Testing ki18n 5.31.0-1 Advanced internationalization framework
i686 Testing kwayland 5.31.0-1 Qt-style Client and Server library wrapper for the Wayland libraries
i686 Testing prison 5.31.0-1 A barcode API to produce QRCode barcodes and DataMatrix barcodes
i686 Testing ktextwidgets 5.31.0-1 Advanced text editing widgets
i686 Testing kjobwidgets 5.31.0-1 Widgets for tracking KJob instances
i686 Testing kconfig 5.31.0-1 Configuration system
i686 Testing knotifyconfig 5.31.0-1 Configuration system for KNotify
i686 Testing kpackage 5.31.0-1 Framework that lets applications manage user installable packages of non-binary assets
i686 Testing knewstuff 5.31.0-1 Support for downloading application assets from the network
i686 Testing kfilemetadata 5.31.0-1 A library for extracting file metadata
i686 Testing kjsembed 5.31.0-1 Embedded JS
i686 Testing kiconthemes 5.31.0-1 Support for icon themes
i686 Testing bluez-qt 5.31.0-1 Qt wrapper for Bluez 5 DBus API
i686 Testing kconfigwidgets 5.31.0-1 Widgets for KConfig
i686 Testing kjs 5.31.0-1 Support for JS scripting in applications
i686 Testing kdesu 5.31.0-1 Integration with su for elevated privileges
i686 Testing kxmlgui 5.31.0-1 User configurable main windows
i686 Testing kwallet 5.31.0-1 Secure and unified container for user passwords
i686 Testing krunner 5.31.0-1 Framework for providing different actions given a string query
i686 Testing khtml 5.31.0-1 KHTML APIs
i686 Testing kross 5.31.0-1 Multi-language application scripting
i686 Testing kcrash 5.31.0-1 Support for application crash analysis and bug report from apps
i686 Community-Testing facter 3.6.1-1 Collect and display system facts
x86_64
x86_64 Core pcre 8.40-1 A library that implements Perl 5-style regular expressions
x86_64 Community ngircd 24-1 Next Generation IRC Daemon
x86_64 Community weston 1.12.0-3 Reference implementation of a Wayland compositor
x86_64 Community emby-server 3.2.1-1 Bring together your videos, music, photos, and live television
x86_64 Community mednafen 0.9.42-1 Command-line multi-system gaming emulator
x86_64 Community usbip 4.9-2 An USB device sharing system over IP network
x86_64 Community cpupower 4.9-2 Linux kernel tool to examine and tune power saving related features of your processor
x86_64 Community perf 4.9-2 Linux kernel performance auditing tool
x86_64 Community tmon 4.9-2 Monitoring and Testing Tool for Linux kernel thermal subsystem
x86_64 Community linux-tools-meta 4.9-2 Linux kernel tools meta package
x86_64 Community x86_energy_perf_policy 4.9-2 Read or write MSR_IA32_ENERGY_PERF_BIAS
x86_64 Community cgroup_event_listener 4.9-2 Simple listener of cgroup events
x86_64 Community libtraceevent 4.9-2 Linux kernel trace event library
x86_64 Community turbostat 4.9-2 Report processor frequency and idle statistics
x86_64 Community python-pyodbc 4.0.5-1 ODBC module for Python 3.x
x86_64 Community python2-pyodbc 4.0.5-1 ODBC module for Python 2.x
x86_64 Community haskell-stmonadtrans 0.4.3-1 A monad transformer version of the ST monad
x86_64 Community agda 2.5.2-4 A dependently typed functional programming language and proof assistant
x86_64 Community haskell-equivalence 0.3.2-2 Maintaining an equivalence relation implemented as union-find using STT.
x86_64 Community syncthing-inotify 0.8.5-1 Inotify file watcher for Syncthing
x86_64 Community python-statsmodels 0.8.0-1 Statistical computations and models for use with SciPy
x86_64 Community python2-statsmodels 0.8.0-1 Statistical computations and models for use with SciPy
x86_64 Community python-blosc 1.5.0-1 A Python wrapper for the extremely fast Blosc compression library
x86_64 Community python2-blosc 1.5.0-1 A Python wrapper for the extremely fast Blosc compression library
x86_64 Community python-numexpr 2.6.2-1 Fast numerical array expression evaluator for Python, NumPy, PyTables, pandas
x86_64 Community python2-numexpr 2.6.2-1 Fast numerical array expression evaluator for Python, NumPy, PyTables, pandas
x86_64 Community arduino-builder 1.3.24-1 A command line tool for compiling Arduino sketches
x86_64 Community python-psutil 5.1.3-1 A cross-platform process and system utilities module for Python
x86_64 Community python2-psutil 5.1.3-1 A cross-platform process and system utilities module for Python2
x86_64 Community arduino-ctags 5.8_arduino11-1 A mix of ctags and anjuta-tags for the perfect C++ ctags
x86_64 Community gnome-do 0.95.3-4 Quickly search for many items present on your desktop or the web, and perform useful actions on those items
x86_64 Community haskell-tasty-hunit 0.9.2-15 HUnit support for the Tasty test framework.
x86_64 Community haskell-dav 1.3.1-51 RFC 4918 WebDAV support
x86_64 Community haskell-xcffib 0.5.1-4 A cffi-based python binding for X
x86_64 Community stylish-haskell 0.7.1.0-6 Haskell code prettifier
x86_64 Community haskell-tasty-quickcheck 0.8.4-18 QuickCheck support for the Tasty test framework.
x86_64 Community haskell-tasty 0.11.1-2 Modern and extensible testing framework
x86_64 Community haskell-hjsmin 0.2.0.2-4 Haskell implementation of a javascript minifier
x86_64 Community haskell-criterion 1.1.4.0-17 Robust, reliable performance measurement and analysis
x86_64 Community haskell-tasty-rerun 1.1.6-11 Run tests by filtering the test tree depending on the result of previous test runs
x86_64 Community haskell-wai-app-static 3.1.6.1-30 WAI application for static serving
x86_64 Community git-repair 1.20161118-2 Repairs a damaged git repisitory
x86_64 Community haskell-turtle 1.3.1-3 Shell programming, Haskell-style
x86_64 Community haskell-optparse-simple 0.0.3-34 Simple interface to optparse-applicative
x86_64 Community haskell-optparse-applicative 0.13.1.0-1 Utilities and combinators for parsing command line options
x86_64 Extra clamav 0.99.2-3 Anti-virus toolkit for Unix
x86_64 Extra shared-mime-info 1.8-1 Freedesktop.org Shared MIME Info
x86_64 Extra xf86-video-intel 1:2.99.917+757+g93942b7d-1 X.org Intel i810/i830/i915/945G/G965+ video drivers
x86_64 Extra xfce4-netload-plugin 1.3.1-1 A netload plugin for the Xfce panel
x86_64 Extra xfce4-systemload-plugin 1.2.1-1 A system load plugin for the Xfce4 panel
x86_64 Extra thunar 1.6.10.177.g97b3ae5c-1 Modern file manager for Xfce
x86_64 Extra radvd 2.16-1 IPv6 Router Advertisement Daemon
x86_64 Extra quagga 1.2.0-1 BGP/OSPF/ISIS/RIP/RIPNG routing daemon suite
x86_64 Extra ffmpeg2.8 2.8.11-1 Complete solution to record, convert and stream audio and video
x86_64 Extra xorg-server 1.19.1-2 Xorg X server
x86_64 Extra xorg-server-xephyr 1.19.1-2 A nested X server that runs as an X application
x86_64 Extra xorg-server-common 1.19.1-2 Xorg server common files
x86_64 Extra xorg-server-xnest 1.19.1-2 A nested X server that runs as an X application
x86_64 Extra xorg-server-xvfb 1.19.1-2 Virtual framebuffer X server
x86_64 Extra xorg-server-xdmx 1.19.1-2 Distributed Multihead X Server and utilities
x86_64 Extra xorg-server-xwayland 1.19.1-2 run X clients under wayland
x86_64 Extra xorg-server-devel 1.19.1-2 Development files for the X.Org X server
x86_64 Testing btrfs-progs 4.9.1-1 Btrfs filesystem utilities
x86_64 Testing knotifications 5.31.0-1 Abstraction for system notifications
x86_64 Testing kidletime 5.31.0-1 Monitoring user activity
x86_64 Testing kio 5.31.0-1 Resource and network access abstraction
x86_64 Testing kservice 5.31.0-1 Advanced plugin and service introspection
x86_64 Testing kdnssd 5.31.0-1 Abstraction to system DNSSD features
x86_64 Testing kwindowsystem 5.31.0-1 Access to the windowing system
x86_64 Testing karchive 5.31.0-1 Qt 5 addon providing access to numerous types of archives
x86_64 Testing solid 5.31.0-1 Hardware integration and detection
x86_64 Testing kcodecs 5.31.0-1 Provide a collection of methods to manipulate strings using various encodings
x86_64 Testing kimageformats 5.31.0-1 Image format plugins for Qt5
x86_64 Testing kbookmarks 5.31.0-1 Support for bookmarks and the XBEL format
x86_64 Testing kcmutils 5.31.0-1 Utilities for interacting with KCModules
x86_64 Testing kcompletion 5.31.0-1 Text completion helpers and widgets
x86_64 Testing baloo 5.31.0-1 A framework for searching and managing metadata
x86_64 Testing kwidgetsaddons 5.31.0-1 Addons to QtWidgets
x86_64 Testing kcoreaddons 5.31.0-1 Addons to QtCore
x86_64 Testing kunitconversion 5.31.0-1 Support for unit conversion
x86_64 Testing kxmlrpcclient 5.31.0-1 XML-RPC client library for KDE
x86_64 Testing plasma-framework 5.31.0-1 Plasma library and runtime components based upon KF5 and Qt5
x86_64 Testing kdeclarative 5.31.0-1 Provides integration of QML and KDE Frameworks
x86_64 Testing kinit 5.31.0-1 Process launcher to speed up launching KDE applications
x86_64 Testing kglobalaccel 5.31.0-1 Add support for global workspace shortcuts
x86_64 Testing frameworkintegration 5.31.0-1 Framework providing components to allow applications to integrate with a KDE Workspace
x86_64 Testing kemoticons 5.31.0-1 Support for emoticons and emoticons themes
x86_64 Testing kitemviews 5.31.0-1 Widget addons for Qt Model/View
x86_64 Testing kparts 5.31.0-1 Document centric plugin system
x86_64 Testing attica-qt5 5.31.0-1 Qt5 library that implements the Open Collaboration Services API
x86_64 Testing kdoctools 5.31.0-1 Documentation generation from docbook
x86_64 Testing networkmanager-qt 5.31.0-1 Qt wrapper for NetworkManager API
x86_64 Testing kded 5.31.0-1 Extensible deamon for providing system level services
x86_64 Testing modemmanager-qt 5.31.0-1 Qt wrapper for ModemManager DBus API
x86_64 Testing ktexteditor 5.31.0-1 Advanced embeddable text editor
x86_64 Testing kdelibs4support 5.31.0-1 Porting aid from KDELibs4
x86_64 Testing kdesignerplugin 5.31.0-1 Integration of Frameworks widgets in Qt Designer/Creator
x86_64 Testing sonnet 5.31.0-1 Spelling framework for Qt5
x86_64 Testing kdbusaddons 5.31.0-1 Addons to QtDBus
x86_64 Testing kauth 5.31.0-1 Abstraction to system policy and authentication features
x86_64 Testing kdewebkit 5.31.0-1 KDE Integration for QtWebKit
x86_64 Testing kguiaddons 5.31.0-1 Addons to QtGui
x86_64 Testing kpeople 5.31.0-1 A library that provides access to all contacts and the people who hold them
x86_64 Testing kplotting 5.31.0-1 Lightweight plotting framework
x86_64 Testing kactivities-stats 5.31.0-1 A library for accessing the usage data collected by the activities system
x86_64 Testing kpty 5.31.0-1 Pty abstraction
x86_64 Testing kmediaplayer 5.31.0-1 Plugin interface for media player features
x86_64 Testing threadweaver 5.31.0-1 High-level multithreading framework
x86_64 Testing syntax-highlighting 5.31.0-1 Syntax highlighting engine for structured text and code
x86_64 Testing kitemmodels 5.31.0-1 Models for Qt Model/View system
x86_64 Testing kactivities 5.31.0-1 Core components for the KDE's Activities
x86_64 Testing ki18n 5.31.0-1 Advanced internationalization framework
x86_64 Testing kwayland 5.31.0-1 Qt-style Client and Server library wrapper for the Wayland libraries
x86_64 Testing prison 5.31.0-1 A barcode API to produce QRCode barcodes and DataMatrix barcodes
x86_64 Testing ktextwidgets 5.31.0-1 Advanced text editing widgets
x86_64 Testing kjobwidgets 5.31.0-1 Widgets for tracking KJob instances
x86_64 Testing kconfig 5.31.0-1 Configuration system
x86_64 Testing knotifyconfig 5.31.0-1 Configuration system for KNotify
x86_64 Testing kpackage 5.31.0-1 Framework that lets applications manage user installable packages of non-binary assets
x86_64 Testing knewstuff 5.31.0-1 Support for downloading application assets from the network
x86_64 Testing kfilemetadata 5.31.0-1 A library for extracting file metadata
x86_64 Testing kjsembed 5.31.0-1 Embedded JS
x86_64 Testing kiconthemes 5.31.0-1 Support for icon themes
x86_64 Testing bluez-qt 5.31.0-1 Qt wrapper for Bluez 5 DBus API
x86_64 Testing kconfigwidgets 5.31.0-1 Widgets for KConfig
x86_64 Testing kjs 5.31.0-1 Support for JS scripting in applications
x86_64 Testing kdesu 5.31.0-1 Integration with su for elevated privileges
x86_64 Testing kxmlgui 5.31.0-1 User configurable main windows
x86_64 Testing kwallet 5.31.0-1 Secure and unified container for user passwords
x86_64 Testing krunner 5.31.0-1 Framework for providing different actions given a string query
x86_64 Testing khtml 5.31.0-1 KHTML APIs
x86_64 Testing kross 5.31.0-1 Multi-language application scripting
x86_64 Testing kcrash 5.31.0-1 Support for application crash analysis and bug report from apps
x86_64 Community-Testing facter 3.6.1-1 Collect and display system facts
AUR
freeter 0.13.0-4
e4rat-lite-git 2.7.r87.0881c2e-4
leocad 17.02-1
moneymanagerex-git 1.3.0.r125.f70094d3-1
python2-fafclient-icetest 0.12.1-1
xnviewmp-system-libs 0.84-3
gvim-gtk2 8.0.0329-1
ghp-import 0.5.4-1
mpv-ahjolinna-git 0.24.0.r0.g3739d1318f-1
tibia 11.10.4445-1
universal-gcode-sender 1.0.9-1
kodi-addon-screensaver-apple-aerial 1.4.0-1
howdoi 1.1.9-1
ignore 0.1.4-1
mvnsh 1.1.0-1
Thanks
#2017 OFFLINE   securitybreach
  • 24,208 posts
Posted 15 February 2017 - 07:53 PM
Updates for Wednesday, February 14th, 2017
Any
any Community postfixadmin 3.0.2-1 A web based interface used to manage mailboxes, virtual domains and aliases created for Postfix
any Community ansible-lint 3.4.11-1 Checks playbooks for practices and behaviour that could potentially be improved.
any Community youtube-dl 2017.02.14-1 A small command-line program to download videos from YouTube.com and a few more sites
any Community python2-btchip 0.1.19-1 Python library to communicate with BTChip dongle
any Community electrum 2.7.18-1 Lightweight Bitcoin wallet
any Community parallel 20170122-1 A shell tool for executing jobs in parallel
any Community meson 0.38.1-1 High productivity build system
any Community python-unittest-mixins 1.2.1-1 Helpful mixins for unittest classes
any Community python2-unittest-mixins 1.2.1-1 Helpful mixins for unittest classes
any Community browserify 14.1.0-1 browser-side require() the node way
any Community python-requests-toolbelt 0.7.1-1 A toolbelt of useful classes and functions to be used with python-requests.
any Community python2-requests-toolbelt 0.7.1-1 A toolbelt of useful classes and functions to be used with python-requests.
any Community retext 7.0.0-1 A simple editor for Markdown and ReStructuredText markup languages
any Community sugar-activity-jukebox 32-1 Media player for Sugar
any Community sugar-activity-terminal 44-1 Terminal emulator for Sugar
any Community sugar-activity-log 37-1 Sugar activity to view system log files
any Community sugar-activity-imageviewer 62-1 Image viewer for Sugar
any Community sugar-activity-read 117-1 Sugar activity to read books
any Community sugar-activity-chat 83-1 Sugar activity for text chatting
any Community sugar-activity-write 97-1 Sugar activity to edit texts
any Community sugar-activity-browse 200-1 Sugar activity to browse the internet
any Extra plasma-workspace-wallpapers 5.9.2-1 Additional wallpapers for the Plasma Workspace
any Extra breeze-grub 5.9.2-1 Breeze theme for GRUB
any Extra geoip-database-extra 20170207-1 GeoLite city/ASN geolocation databases compiled by MaxMind
any Extra geoip-database 20170207-1 GeoLite country geolocation database compiled by MaxMind
i686
i686 Core gnutls 3.5.9-1 A library which provides a secure layer over a reliable transport layer
i686 Core bash 4.4.012-1 The GNU Bourne Again shell
i686 Core ncurses 6.0+20170128-1 System V Release 4.0 curses emulation library
i686 Core libnl 3.2.29-2 Library for applications dealing with netlink sockets
i686 Core readline 7.0.003-1 GNU readline library
i686 Community picard 1.4-1 Official MusicBrainz tagger
i686 Community discover 5.9.2-1 A collection of package management tools for KDE
i686 Community haskell-lifted-async 0.9.1.1-3 Run lifted IO operations asynchronously and wait for their results
i686 Community haskell-pandoc 1.19.2.1-9 Conversion between markup formats (docs and libraries)
i686 Community haskell-store 0.3-17 Fast binary serialization
i686 Community haskell-yesod-core 1.4.31-8 Creation of type-safe, RESTful web applications.
i686 Community haskell-yesod-static 1.5.1.1-38 Static file serving subsite for Yesod Web Framework.
i686 Community haskell-yaml 0.8.21.2-3 Support for parsing and rendering YAML documents.
i686 Community stylish-haskell 0.7.1.0-7 Haskell code prettifier
i686 Community haskell-project-template 0.2.0-45 Specify Haskell project templates and generate files
i686 Community haskell-resourcet 1.1.9-2 Deterministic allocation and freeing of scarce resources.
i686 Community haskell-yesod-persistent 1.4.1.1-23 Some helpers for using Persistent from Yesod.
i686 Community haskell-lifted-base 0.2.3.10-1 lifted IO operations from the base library
i686 Community haskell-stack 1.3.2-34 The Haskell Tool Stack (docs and libraries)
i686 Community haskell-cryptohash-conduit 0.1.1-56 cryptohash conduit
i686 Community haskell-yesod-form 1.4.10-5 Form handling support for Yesod Web Framework
i686 Community haskell-cheapskate 0.1.0.5-41 Experimental markdown processor.
i686 Community haskell-monad-logger 0.3.20.1-8 A class of monads which can log messages.
i686 Community haskell-conduit 1.2.9-2 Streaming data processing library.
i686 Community haskell-pandoc-crossref 0.2.4.2-5 Pandoc filter for cross-references (docs and libraries)
i686 Community haskell-hpack 0.16.0-5 An alternative format for Haskell packages
i686 Community darcs 2.12.5-7 A distributed, interactive, smart revision control system
i686 Community haskell-hopenpgp 2.5.5-30 Native Haskell implementation of OpenPGP (RFC4880)
i686 Community haskell-yesod 1.4.4-17 Creation of type-safe, RESTful web applications.
i686 Community hopenpgp-tools 0.19.4-41 hOpenPGP-based command-line tools
i686 Community haskell-persistent-template 2.5.1.6-29 Type-safe, non-relational, multi-backend persistence
i686 Community pandoc 1.19.2.1-9 Conversion between markup formats
i686 Community purescript 0.10.6-6 PureScript Programming Language Compiler
i686 Community hoogle 5.0.9-13 Haskell API Search
i686 Community haskell-conduit-extra 1.1.15-10 Batteries included conduit: adapters for common libraries.
i686 Community haskell-http-conduit 2.2.3-27 HTTP client package with conduit interface and HTTPS support
i686 Community haskell-dns 2.0.10-13 DNS library in Haskell
i686 Community haskell-sandi 0.4.0-10 Data encoding library
i686 Community pax-utils 1.2.2-1 ELF related utils for ELF 32/64 binaries that can check files for security relevant properties
i686 Community stack 1.3.2-34 The Haskell Tool Stack
i686 Community haskell-persistent-sqlite 2.6-28 Backend for the persistent library using sqlite3
i686 Community haskell-wai-extra 3.0.19.1-5 Provides some basic WAI handlers and middleware.
i686 Community npapi-vlc 2.2.5-1 The modern VLC Mozilla (NPAPI) plugin
i686 Community idris 0.99-27 Functional Programming Language with Dependent Types
i686 Community haskell-wai-app-static 3.1.6.1-31 WAI application for static serving
i686 Community haskell-persistent 2.6-28 Type-safe, multi-backend data serialization
i686 Community haskell-binary-conduit 1.2.4.1-8 Data serialization/deserialization conduit library
i686 Community haskell-enclosed-exceptions 1.0.2-3 Catching all exceptions from within an enclosed computation
i686 Community python2-hidapi 0.7.99.20-1 A Cython interface to the hidapi from signal11/hidapi
i686 Community hindent 5.2.2-9 Extensible Haskell pretty printer
i686 Community haskell-esqueleto 2.5.1-6 Type-safe EDSL for SQL queries on persistent backends.
i686 Community pandoc-crossref 0.2.4.2-5 Pandoc filter for cross-references
i686 Community haskell-conduit-combinators 1.1.0-4 Commonly used conduit functions, for both chunked and unchunked data
i686 Community haskell-yesod-default 1.2.0-107 Default config and main functions for your yesod application (deprecated)
i686 Community python-hidapi 0.7.99.20-1 A Cython interface to the hidapi from signal11/hidapi
i686 Community displaycal 3.2.3.0-1 Open Source Display Calibration and Characterization powered by Argyll CMS (Formerly known as dispcalGUI)
i686 Community iperf3 3.1.6-1 Internet Protocol bandwidth measuring tool
i686 Community php-memcached 3.0.2-1 PHP extension for interfacing with memcached via libmemcached library
i686 Community wireguard-tools 0.0.20170214-1 next generation secure network tunnel
i686 Community wireguard-dkms 0.0.20170214-1 next generation secure network tunnel
i686 Community geth 1.5.9-1 Official golang implementation of the Ethereum protocol
i686 Community kio-gdrive 1.1.1-1 KIO Slave to access Google Drive
i686 Community abuse 0.8-8 Side-scroller action game that pits you against ruthless alien killers
i686 Community r8168 8.044.02-1 A kernel module for Realtek 8168 network cards
i686 Community r8168-lts 8.044.02-1 A kernel module for Realtek 8168 network cards for linux-lts
i686 Community wine-staging-nine 2.1-1 A compatibility layer for running Windows programs - Staging branch with the gallium-nine patches
i686 Community qupzilla 2.1.1-1 Cross-platform QtWebEngine browser
i686 Community haskell-hasql-transaction 0.5-1 A composable abstraction over the retryable transactions for Hasql
i686 Community haskell-lens-aeson 1.0.0.5-1 Law-abiding lenses for aeson
i686 Community python2-pyodbc 4.0.6-1 ODBC module for Python 2.x
i686 Community python-pyodbc 4.0.6-1 ODBC module for Python 3.x
i686 Community linux-grsec-docs 1:4.9.9.r201702122044-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
i686 Community linux-grsec 1:4.9.9.r201702122044-1 The Linux kernel and modules with grsecurity/PaX patches
i686 Community linux-grsec-headers 1:4.9.9.r201702122044-1 Header files and scripts for building modules for Linux-grsec kernel
i686 Community haskell-postgresql-binary 0.9.3-1 Encoders and decoders for the PostgreSQL's binary format
i686 Community haskell-hasql 0.19.16-4 An efficient PostgreSQL driver and a flexible mapping API
i686 Community haskell-hasql-pool 0.4.1-19 A pool of connections for Hasql
i686 Extra php-imap 7.1.2-1 imap module for PHP
i686 Extra php-gd 7.1.2-1 gd module for PHP
i686 Extra php-xsl 7.1.2-1 xsl module for PHP
i686 Extra php-cgi 7.1.2-1 CGI and FCGI SAPI for PHP
i686 Extra php-dblib 7.1.2-1 dblib module for PHP
i686 Extra php-embed 7.1.2-1 Embedded PHP SAPI library
i686 Extra php-intl 7.1.2-1 intl module for PHP
i686 Extra php-sqlite 7.1.2-1 sqlite module for PHP
i686 Extra php-phpdbg 7.1.2-1 Interactive PHP debugger
i686 Extra php-pspell 7.1.2-1 pspell module for PHP
i686 Extra php-pgsql 7.1.2-1 PostgreSQL modules for PHP
i686 Extra php-odbc 7.1.2-1 ODBC modules for PHP
i686 Extra php 7.1.2-1 A general-purpose scripting language that is especially suited to web development
i686 Extra php-enchant 7.1.2-1 enchant module for PHP
i686 Extra php-apache 7.1.2-1 Apache SAPI for PHP
i686 Extra php-snmp 7.1.2-1 snmp module for PHP
i686 Extra php-tidy 7.1.2-1 tidy module for PHP
i686 Extra php-fpm 7.1.2-1 FastCGI Process Manager for PHP
i686 Extra php-mcrypt 7.1.2-1 mcrypt module for PHP
i686 Extra linux-zen 4.9.9-1 The Linux-zen kernel and modules
i686 Extra linux-zen-docs 4.9.9-1 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
i686 Extra linux-zen-headers 4.9.9-1 Header files and scripts for building modules for Linux-zen kernel
i686 Extra flatpak 0.8.3-1 Application deployment framework for desktop apps
i686 Extra kwallet-pam 5.9.2-1 KWallet PAM integration
i686 Extra libksysguard 5.9.2-1 Libksysguard
i686 Extra powerdevil 5.9.2-1 Manages the power consumption settings of a Plasma Shell
i686 Extra oxygen-kde4 5.9.2-1 KDE Oxygen style for KDE4 applications
i686 Extra polkit-kde-agent 5.9.2-1 Daemon providing a polkit authentication UI for KDE
i686 Extra kdeplasma-addons 5.9.2-1 All kind of addons to improve your Plasma experience
i686 Extra plasma-workspace 5.9.2-1 KDE Plasma Workspace
i686 Extra kde-gtk-config 5.9.2-1 GTK2 and GTK3 Configurator for KDE
i686 Extra ksshaskpass 5.9.2-1 ssh-add helper that uses kwallet and kpassworddialog
i686 Extra kdecoration 5.9.2-1 Plugin based library to create window decorations
i686 Extra bluedevil 1:5.9.2-1 Integrate the Bluetooth technology within KDE workspace and applications
i686 Extra kscreen 5.9.2-1 KDE's screen management software
i686 Extra kwrited 5.9.2-1 KDE daemon listening for wall and write messages
i686 Extra breeze 5.9.2-1 Artwork, styles and assets for the Breeze visual style for the Plasma Desktop
i686 Extra khotkeys 5.9.2-1 KHotKeys
i686 Extra breeze-gtk 5.9.2-1 Breeze widget theme for GTK 2 and 3
i686 Extra ksysguard 5.9.2-1 Track and control the processes running in your system
i686 Extra libkscreen 5.9.2-1 KDE screen management software
i686 Extra kinfocenter 5.9.2-1 A utility that provides information about a computer system
i686 Extra oxygen 5.9.2-1 KDE Oxygen style
i686 Extra kgamma5 5.9.2-1 Adjust your monitor's gamma settings
i686 Extra kde-cli-tools 5.9.2-1 Tools based on KDE Frameworks 5 to better interact with the system
i686 Extra drkonqi 5.9.2-1 KDE crash handler
i686 Extra kwayland-integration 5.9.2-1 Provides integration plugins for various KDE frameworks for the wayland windowing system
i686 Extra systemsettings 5.9.2-1 KDE system settings
i686 Extra milou 5.9.2-1 A dedicated search application built on top of Baloo
i686 Extra plasma-desktop 5.9.2-1 KDE Plasma Desktop
i686 Extra plasma-integration 5.9.2-1 Qt Platform Theme integration plugins for the Plasma workspaces
i686 Extra plasma-nm 5.9.2-1 Plasma applet written in QML for managing network connections
i686 Extra kactivitymanagerd 5.9.2-1 System service to manage user's activities and track the usage patterns
i686 Extra kuiserver 5.9.2-1 KDE Progress Info UI server
i686 Extra sddm-kcm 5.9.2-1 KDE Config Module for SDDM
i686 Extra user-manager 5.9.2-1 A simple system settings module to manage the users of your system
i686 Extra plasma-wayland-session 5.9.2-1 Plasma Wayland session
i686 Extra plasma-pa 5.9.2-1 Plasma applet for audio volume management using PulseAudio
i686 Extra kscreenlocker 5.9.2-1 Library and components for secure lock screen architecture
i686 Extra breeze-kde4 5.9.2-1 Breeze widget style for KDE4 applications
i686 Extra kwin 5.9.2-1 KDE Window manager
i686 Extra kmenuedit 5.9.2-1 KDE menu editor
i686 Extra plasma-sdk 5.9.2-1 Applications useful for Plasma development
i686 Extra xfce4-taskmanager 1.2.0-1 Easy to use task manager
i686 Extra xmlsec 1.2.23-1 XML Security Library is a C library based on LibXML2
i686 Extra hitori 3.22.1-1 GTK+ application to generate and let you play games of Hitori
i686 Extra libmikmod 3.3.10-1 A portable sound library
i686 Extra xfce4-notifyd 0.3.5-1 Notification daemon for the Xfce desktop
i686 Extra thunar 1.6.11-1 Modern file manager for Xfce
i686 Testing nvidia-lts 378.13-1 NVIDIA drivers for linux-lts
i686 Testing nvidia-dkms 378.13-1 NVIDIA driver sources for linux
i686 Testing nvidia 378.13-1 NVIDIA drivers for linux
i686 Testing nvidia-utils 378.13-1 NVIDIA drivers utilities
i686 Testing nvidia-libgl 378.13-1 NVIDIA drivers libraries symlinks
i686 Testing opencl-nvidia 378.13-1 OpenCL implemention for NVIDIA
i686 Testing bash 4.4.012-2 The GNU Bourne Again shell
i686 Testing xorg-server-xdmx 1.19.1-5 Distributed Multihead X Server and utilities
i686 Testing xorg-server 1.19.1-5 Xorg X server
i686 Testing xorg-server-devel 1.19.1-5 Development files for the X.Org X server
i686 Testing xorg-server-xvfb 1.19.1-5 Virtual framebuffer X server
i686 Testing xorg-server-xnest 1.19.1-5 A nested X server that runs as an X application
i686 Testing xorg-server-common 1.19.1-5 Xorg server common files
i686 Testing xorg-server-xwayland 1.19.1-5 run X clients under wayland
i686 Testing xorg-server-xephyr 1.19.1-5 A nested X server that runs as an X application
x86_64
x86_64 Core gnutls 3.5.9-1 A library which provides a secure layer over a reliable transport layer
x86_64 Core bash 4.4.012-1 The GNU Bourne Again shell
x86_64 Core ncurses 6.0+20170128-1 System V Release 4.0 curses emulation library
x86_64 Core libnl 3.2.29-2 Library for applications dealing with netlink sockets
x86_64 Core readline 7.0.003-1 GNU readline library
x86_64 Community discover 5.9.2-1 A collection of package management tools for KDE
x86_64 Community picard 1.4-1 Official MusicBrainz tagger
x86_64 Community haskell-lifted-async 0.9.1.1-3 Run lifted IO operations asynchronously and wait for their results
x86_64 Community haskell-pandoc 1.19.2.1-9 Conversion between markup formats (docs and libraries)
x86_64 Community haskell-store 0.3-17 Fast binary serialization
x86_64 Community haskell-yesod-core 1.4.31-8 Creation of type-safe, RESTful web applications.
x86_64 Community haskell-yesod-static 1.5.1.1-38 Static file serving subsite for Yesod Web Framework.
x86_64 Community haskell-yaml 0.8.21.2-3 Support for parsing and rendering YAML documents.
x86_64 Community stylish-haskell 0.7.1.0-7 Haskell code prettifier
x86_64 Community haskell-project-template 0.2.0-45 Specify Haskell project templates and generate files
x86_64 Community haskell-resourcet 1.1.9-2 Deterministic allocation and freeing of scarce resources.
x86_64 Community haskell-yesod-persistent 1.4.1.1-23 Some helpers for using Persistent from Yesod.
x86_64 Community haskell-lifted-base 0.2.3.10-1 lifted IO operations from the base library
x86_64 Community haskell-stack 1.3.2-34 The Haskell Tool Stack (docs and libraries)
x86_64 Community haskell-cryptohash-conduit 0.1.1-56 cryptohash conduit
x86_64 Community haskell-yesod-form 1.4.10-5 Form handling support for Yesod Web Framework
x86_64 Community haskell-cheapskate 0.1.0.5-41 Experimental markdown processor.
x86_64 Community haskell-monad-logger 0.3.20.1-8 A class of monads which can log messages.
x86_64 Community haskell-conduit 1.2.9-2 Streaming data processing library.
x86_64 Community haskell-pandoc-crossref 0.2.4.2-5 Pandoc filter for cross-references (docs and libraries)
x86_64 Community haskell-hpack 0.16.0-5 An alternative format for Haskell packages
x86_64 Community darcs 2.12.5-7 A distributed, interactive, smart revision control system
x86_64 Community haskell-hopenpgp 2.5.5-30 Native Haskell implementation of OpenPGP (RFC4880)
x86_64 Community haskell-yesod 1.4.4-17 Creation of type-safe, RESTful web applications.
x86_64 Community hopenpgp-tools 0.19.4-41 hOpenPGP-based command-line tools
x86_64 Community haskell-persistent-template 2.5.1.6-29 Type-safe, non-relational, multi-backend persistence
x86_64 Community pandoc 1.19.2.1-9 Conversion between markup formats
x86_64 Community purescript 0.10.6-6 PureScript Programming Language Compiler
x86_64 Community hoogle 5.0.9-13 Haskell API Search
x86_64 Community haskell-conduit-extra 1.1.15-10 Batteries included conduit: adapters for common libraries.
x86_64 Community haskell-http-conduit 2.2.3-27 HTTP client package with conduit interface and HTTPS support
x86_64 Community haskell-dns 2.0.10-13 DNS library in Haskell
x86_64 Community haskell-sandi 0.4.0-10 Data encoding library
x86_64 Community pax-utils 1.2.2-1 ELF related utils for ELF 32/64 binaries that can check files for security relevant properties
x86_64 Community stack 1.3.2-34 The Haskell Tool Stack
x86_64 Community haskell-persistent-sqlite 2.6-28 Backend for the persistent library using sqlite3
x86_64 Community haskell-wai-extra 3.0.19.1-5 Provides some basic WAI handlers and middleware.
x86_64 Community npapi-vlc 2.2.5-1 The modern VLC Mozilla (NPAPI) plugin
x86_64 Community idris 0.99-27 Functional Programming Language with Dependent Types
x86_64 Community haskell-wai-app-static 3.1.6.1-31 WAI application for static serving
x86_64 Community haskell-persistent 2.6-28 Type-safe, multi-backend data serialization
x86_64 Community haskell-binary-conduit 1.2.4.1-8 Data serialization/deserialization conduit library
x86_64 Community haskell-enclosed-exceptions 1.0.2-3 Catching all exceptions from within an enclosed computation
x86_64 Community python2-hidapi 0.7.99.20-1 A Cython interface to the hidapi from signal11/hidapi
x86_64 Community hindent 5.2.2-9 Extensible Haskell pretty printer
x86_64 Community haskell-esqueleto 2.5.1-6 Type-safe EDSL for SQL queries on persistent backends.
x86_64 Community pandoc-crossref 0.2.4.2-5 Pandoc filter for cross-references
x86_64 Community haskell-conduit-combinators 1.1.0-4 Commonly used conduit functions, for both chunked and unchunked data
x86_64 Community haskell-yesod-default 1.2.0-107 Default config and main functions for your yesod application (deprecated)
x86_64 Community python-hidapi 0.7.99.20-1 A Cython interface to the hidapi from signal11/hidapi
x86_64 Community displaycal 3.2.3.0-1 Open Source Display Calibration and Characterization powered by Argyll CMS (Formerly known as dispcalGUI)
x86_64 Community iperf3 3.1.6-1 Internet Protocol bandwidth measuring tool
x86_64 Community php-memcached 3.0.2-1 PHP extension for interfacing with memcached via libmemcached library
x86_64 Community wireguard-tools 0.0.20170214-1 next generation secure network tunnel
x86_64 Community wireguard-dkms 0.0.20170214-1 next generation secure network tunnel
x86_64 Community geth 1.5.9-1 Official golang implementation of the Ethereum protocol
x86_64 Community kio-gdrive 1.1.1-1 KIO Slave to access Google Drive
x86_64 Community abuse 0.8-8 Side-scroller action game that pits you against ruthless alien killers
x86_64 Community r8168 8.044.02-1 A kernel module for Realtek 8168 network cards
x86_64 Community r8168-lts 8.044.02-1 A kernel module for Realtek 8168 network cards for linux-lts
x86_64 Community qupzilla 2.1.1-1 Cross-platform QtWebEngine browser
x86_64 Community haskell-hasql-transaction 0.5-1 A composable abstraction over the retryable transactions for Hasql
x86_64 Community haskell-lens-aeson 1.0.0.5-1 Law-abiding lenses for aeson
x86_64 Community python2-pyodbc 4.0.6-1 ODBC module for Python 2.x
x86_64 Community python-pyodbc 4.0.6-1 ODBC module for Python 3.x
x86_64 Community linux-grsec-docs 1:4.9.9.r201702122044-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
x86_64 Community linux-grsec 1:4.9.9.r201702122044-1 The Linux kernel and modules with grsecurity/PaX patches
x86_64 Community linux-grsec-headers 1:4.9.9.r201702122044-1 Header files and scripts for building modules for Linux-grsec kernel
x86_64 Community haskell-postgresql-binary 0.9.3-1 Encoders and decoders for the PostgreSQL's binary format
x86_64 Community haskell-hasql 0.19.16-4 An efficient PostgreSQL driver and a flexible mapping API
x86_64 Community haskell-hasql-pool 0.4.1-19 A pool of connections for Hasql
x86_64 Extra php-imap 7.1.2-1 imap module for PHP
x86_64 Extra php-gd 7.1.2-1 gd module for PHP
x86_64 Extra php-xsl 7.1.2-1 xsl module for PHP
x86_64 Extra php-cgi 7.1.2-1 CGI and FCGI SAPI for PHP
x86_64 Extra php-dblib 7.1.2-1 dblib module for PHP
x86_64 Extra php-embed 7.1.2-1 Embedded PHP SAPI library
x86_64 Extra php-intl 7.1.2-1 intl module for PHP
x86_64 Extra php-sqlite 7.1.2-1 sqlite module for PHP
x86_64 Extra php-phpdbg 7.1.2-1 Interactive PHP debugger
x86_64 Extra php-pspell 7.1.2-1 pspell module for PHP
x86_64 Extra php-pgsql 7.1.2-1 PostgreSQL modules for PHP
x86_64 Extra php-odbc 7.1.2-1 ODBC modules for PHP
x86_64 Extra php 7.1.2-1 A general-purpose scripting language that is especially suited to web development
x86_64 Extra php-enchant 7.1.2-1 enchant module for PHP
x86_64 Extra php-apache 7.1.2-1 Apache SAPI for PHP
x86_64 Extra php-snmp 7.1.2-1 snmp module for PHP
x86_64 Extra php-tidy 7.1.2-1 tidy module for PHP
x86_64 Extra php-fpm 7.1.2-1 FastCGI Process Manager for PHP
x86_64 Extra php-mcrypt 7.1.2-1 mcrypt module for PHP
x86_64 Extra linux-zen 4.9.9-1 The Linux-zen kernel and modules
x86_64 Extra linux-zen-docs 4.9.9-1 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
x86_64 Extra linux-zen-headers 4.9.9-1 Header files and scripts for building modules for Linux-zen kernel
x86_64 Extra flatpak 0.8.3-1 Application deployment framework for desktop apps
x86_64 Extra kwallet-pam 5.9.2-1 KWallet PAM integration
x86_64 Extra libksysguard 5.9.2-1 Libksysguard
x86_64 Extra powerdevil 5.9.2-1 Manages the power consumption settings of a Plasma Shell
x86_64 Extra oxygen-kde4 5.9.2-1 KDE Oxygen style for KDE4 applications
x86_64 Extra polkit-kde-agent 5.9.2-1 Daemon providing a polkit authentication UI for KDE
x86_64 Extra kdeplasma-addons 5.9.2-1 All kind of addons to improve your Plasma experience
x86_64 Extra plasma-workspace 5.9.2-1 KDE Plasma Workspace
x86_64 Extra kde-gtk-config 5.9.2-1 GTK2 and GTK3 Configurator for KDE
x86_64 Extra ksshaskpass 5.9.2-1 ssh-add helper that uses kwallet and kpassworddialog
x86_64 Extra kdecoration 5.9.2-1 Plugin based library to create window decorations
x86_64 Extra bluedevil 1:5.9.2-1 Integrate the Bluetooth technology within KDE workspace and applications
x86_64 Extra kscreen 5.9.2-1 KDE's screen management software
x86_64 Extra kwrited 5.9.2-1 KDE daemon listening for wall and write messages
x86_64 Extra breeze 5.9.2-1 Artwork, styles and assets for the Breeze visual style for the Plasma Desktop
x86_64 Extra khotkeys 5.9.2-1 KHotKeys
x86_64 Extra breeze-gtk 5.9.2-1 Breeze widget theme for GTK 2 and 3
x86_64 Extra ksysguard 5.9.2-1 Track and control the processes running in your system
x86_64 Extra libkscreen 5.9.2-1 KDE screen management software
x86_64 Extra kinfocenter 5.9.2-1 A utility that provides information about a computer system
x86_64 Extra oxygen 5.9.2-1 KDE Oxygen style
x86_64 Extra kgamma5 5.9.2-1 Adjust your monitor's gamma settings
x86_64 Extra kde-cli-tools 5.9.2-1 Tools based on KDE Frameworks 5 to better interact with the system
x86_64 Extra drkonqi 5.9.2-1 KDE crash handler
x86_64 Extra kwayland-integration 5.9.2-1 Provides integration plugins for various KDE frameworks for the wayland windowing system
x86_64 Extra systemsettings 5.9.2-1 KDE system settings
x86_64 Extra milou 5.9.2-1 A dedicated search application built on top of Baloo
x86_64 Extra plasma-desktop 5.9.2-1 KDE Plasma Desktop
x86_64 Extra plasma-integration 5.9.2-1 Qt Platform Theme integration plugins for the Plasma workspaces
x86_64 Extra plasma-nm 5.9.2-1 Plasma applet written in QML for managing network connections
x86_64 Extra kactivitymanagerd 5.9.2-1 System service to manage user's activities and track the usage patterns
x86_64 Extra kuiserver 5.9.2-1 KDE Progress Info UI server
x86_64 Extra sddm-kcm 5.9.2-1 KDE Config Module for SDDM
x86_64 Extra user-manager 5.9.2-1 A simple system settings module to manage the users of your system
x86_64 Extra plasma-wayland-session 5.9.2-1 Plasma Wayland session
x86_64 Extra plasma-pa 5.9.2-1 Plasma applet for audio volume management using PulseAudio
x86_64 Extra kscreenlocker 5.9.2-1 Library and components for secure lock screen architecture
x86_64 Extra breeze-kde4 5.9.2-1 Breeze widget style for KDE4 applications
x86_64 Extra kwin 5.9.2-1 KDE Window manager
x86_64 Extra kmenuedit 5.9.2-1 KDE menu editor
x86_64 Extra plasma-sdk 5.9.2-1 Applications useful for Plasma development
x86_64 Extra xfce4-taskmanager 1.2.0-1 Easy to use task manager
x86_64 Extra xmlsec 1.2.23-1 XML Security Library is a C library based on LibXML2
x86_64 Extra hitori 3.22.1-1 GTK+ application to generate and let you play games of Hitori
x86_64 Extra libmikmod 3.3.10-1 A portable sound library
x86_64 Extra xfce4-notifyd 0.3.5-1 Notification daemon for the Xfce desktop
x86_64 Extra thunar 1.6.11-1 Modern file manager for Xfce
x86_64 Multilib wine-staging-nine 2.1-1 A compatibility layer for running Windows programs - Staging branch with the gallium-nine patches
x86_64 Multilib lib32-libmikmod 3.3.10-1 A portable sound library.
x86_64 Testing nvidia-lts 378.13-1 NVIDIA drivers for linux-lts
x86_64 Testing nvidia-dkms 378.13-1 NVIDIA driver sources for linux
x86_64 Testing nvidia 378.13-1 NVIDIA drivers for linux
x86_64 Testing nvidia-utils 378.13-1 NVIDIA drivers utilities
x86_64 Testing nvidia-libgl 378.13-1 NVIDIA drivers libraries symlinks
x86_64 Testing opencl-nvidia 378.13-1 OpenCL implemention for NVIDIA
x86_64 Testing bash 4.4.012-2 The GNU Bourne Again shell
x86_64 Testing xorg-server-xdmx 1.19.1-5 Distributed Multihead X Server and utilities
x86_64 Testing xorg-server 1.19.1-5 Xorg X server
x86_64 Testing xorg-server-devel 1.19.1-5 Development files for the X.Org X server
x86_64 Testing xorg-server-xvfb 1.19.1-5 Virtual framebuffer X server
x86_64 Testing xorg-server-xnest 1.19.1-5 A nested X server that runs as an X application
x86_64 Testing xorg-server-common 1.19.1-5 Xorg server common files
x86_64 Testing xorg-server-xwayland 1.19.1-5 run X clients under wayland
x86_64 Testing xorg-server-xephyr 1.19.1-5 A nested X server that runs as an X application
x86_64 Multilib-Testing lib32-nvidia-utils 378.13-1 NVIDIA drivers utilities (32-bit)
x86_64 Multilib-Testing lib32-nvidia-libgl 378.13-1 NVIDIA drivers libraries symlinks (32-bit)
x86_64 Multilib-Testing lib32-opencl-nvidia 378.13-1 OpenCL implemention for NVIDIA (32-bit)
AUR
xlog 2.0.14-2
nginx-mainline-waf 1.11.10-1
lib32-assimp 3.3.1-1
xfhell 3.2-2
vmware-workstation 12.5.2_4638234-8
sdrangel-git r1688.7e6ab820-1
xdemorse 2.9-5
openra-kang kang.86c0f87-1
virtualbox-ck-host-modules 5.1.14-3
virtualbox-ck-guest-modules 5.1.14-3
nvidia-304xx-ck 304.134-6
nvidia-340xx-ck 340.101-8
nvidia-ck 1:375.26-7
broadcom-wl-ck 6.30.223.271-35
cm256cc-git r80.c89bada-1
Thanks
Posted ImagePosted Image
Configs/PGP Key/comhack π
#2018 OFFLINE   securitybreach
  • 24,208 posts
Posted 19 February 2017 - 07:44 PM
Updates for Saturday, February 18th, 2017
Any
any Community nextcloud-app-contacts 1.5.3-3 Contacts app for nextcloud
any Community python-raven 6.0.0-1 Python client for Sentry
any Community python2-raven 6.0.0-1 Python client for Sentry
any Community npm-check-updates 2.10.3-1 Find newer versions of dependencies than what your package.json or bower.json allows
any Extra gnome-doc-utils 0.20.10+16+gc03cc09-1 Documentation utilities for Gnome
any Extra fixesproto 5.0+9+g4292ec1-1 X11 Fixes extension wire protocol
any Extra bcprov 1.56-1 Java cryptography APIs (Bouncy Castle)
any Extra python-chardet 2.3.0-4 Python3 module for character encoding auto-detection
any Extra python2-chardet 2.3.0-4 Python2 module for character encoding auto-detection
i686
i686 Community ccache 3.3.4-1 A compiler cache
i686 Community keepassxc 2.1.2-2 Cross-platform community-driven port of Keepass password manager
i686 Community atom 1.14.3-1 A hackable text editor for the 21st Century
i686 Community haskell-yesod 1.4.4-20 Creation of type-safe, RESTful web applications.
i686 Community haskell-yesod-persistent 1.4.1.1-26 Some helpers for using Persistent from Yesod.
i686 Community haskell-persistent-template 2.5.1.6-30 Type-safe, non-relational, multi-backend persistence
i686 Community haskell-yesod-form 1.4.10-8 Form handling support for Yesod Web Framework
i686 Community haskell-yesod-auth 1.4.16-15 Authentication for Yesod.
i686 Community git-annex 6.20170214-2 Manage files with git, without checking their contents into git
i686 Community haskell-yesod-default 1.2.0-110 Default config and main functions for your yesod application (deprecated)
i686 Community haskell-yesod-core 1.4.31-11 Creation of type-safe, RESTful web applications.
i686 Community haskell-yesod-static 1.5.1.1-41 Static file serving subsite for Yesod Web Framework.
i686 Community haskell-persistent-sqlite 2.6-29 Backend for the persistent library using sqlite3
i686 Community purescript 0.10.7-2 PureScript Programming Language Compiler
i686 Community haskell-persistent 2.6-29 Type-safe, multi-backend data serialization
i686 Community haskell-esqueleto 2.5.1-7 Type-safe EDSL for SQL queries on persistent backends.
i686 Community haskell-monad-logger 0.3.20.2-1 A class of monads which can log messages.
i686 Community kamoso 3.2.2-1 A webcam recorder from KDE community
i686 Community gost 2.3-1 GO Simple Tunnel
i686 Community haskell-configurator 0.3.0.0-1 Configuration management
i686 Community linux-grsec 1:4.9.10.r201702162016-1 The Linux kernel and modules with grsecurity/PaX patches
i686 Community linux-grsec-headers 1:4.9.10.r201702162016-1 Header files and scripts for building modules for Linux-grsec kernel
i686 Community linux-grsec-docs 1:4.9.10.r201702162016-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
i686 Community deepin-qt5integration 0.0.7-2 Deepin Qt5 platform plugin
i686 Community gnome-flashback 3.22.0-2 GNOME Flashback session
i686 Community erlang-nox 19.2.3-1 General-purpose concurrent functional programming language developed by Ericsson (headless version)
i686 Community mypaint 1.2.1-2 A fast and easy painting application for digital painters, with brush dynamics
i686 Community couchdb 2.0.0-6 A document-oriented database that can be queried and indexed in a MapReduce fashion using JSON
i686 Extra mlt 6.4.1-4 An open source multimedia framework
i686 Extra mlt-python-bindings 6.4.1-4 An open source multimedia framework
i686 Extra jre7-openjdk-headless 7.u131_2.6.9-1 OpenJDK Java 7 headless runtime environment
i686 Extra openjdk7-doc 7.u131_2.6.9-1 OpenJDK Java 7 documentation
i686 Extra jre7-openjdk 7.u131_2.6.9-1 OpenJDK Java 7 full runtime environment
i686 Extra jdk7-openjdk 7.u131_2.6.9-1 OpenJDK Java 7 development kit
i686 Extra openjdk7-src 7.u131_2.6.9-1 OpenJDK Java 7 sources
i686 Extra imagemagick-doc 6.9.7.9-1 The ImageMagick documentation (utilities manuals and libraries API)
i686 Extra imagemagick 6.9.7.9-1 An image viewing/manipulation program
i686 Extra alsa-utils 1.1.3-2 An alternative implementation of Linux sound support
i686 Extra uhttpmock 0.5.0-2 HTTP web service mocking project for projects which use libsoup
i686 Extra xdg-user-dirs-gtk 0.10+9+g5b7efc6-1 Creates user dirs and asks to relocalize them
i686 Extra xawtv 3.104+3+gc438af7-1 A simple Xaw-based TV program which uses the bttv driver or video4linux
i686 Extra autogen 5.18.12-1 A tool designed to simplify the creation and maintenance of programs that contain large amounts of repetitious text
i686 Extra libdc1394 2.2.5-1 High level programming interface to control IEEE 1394 based cameras
i686 Extra poppler-glib 0.52.0-1 Poppler glib bindings
i686 Extra poppler-qt4 0.52.0-1 Poppler Qt4 bindings
i686 Extra cups-filters 1.13.4-1 OpenPrinting CUPS Filters
i686 Extra poppler 0.52.0-1 PDF rendering library based on xpdf 3.0
i686 Extra poppler-qt5 0.52.0-1 Poppler Qt5 bindings
i686 Extra telepathy-salut 0.8.1-4 A link-local XMPP connection manager for Telepathy
i686 Testing gnupg 2.1.18-2 Complete and free implementation of the OpenPGP standard
i686 Testing libssh-docs 0.7.4-2 Documentation for libssh
i686 Testing libssh 0.7.4-2 Library for accessing ssh client services through C libraries
i686 Testing wget 1.19.1-2 A network utility to retrieve files from the Web
i686 Testing syslog-ng 3.9.1-2 Next-generation syslogd with advanced networking and filtering capabilities
i686 Community-Testing linux-grsec-headers 1:4.9.11.r201702181444-1 Header files and scripts for building modules for Linux-grsec kernel
i686 Community-Testing linux-grsec 1:4.9.11.r201702181444-1 The Linux kernel and modules with grsecurity/PaX patches
i686 Community-Testing linux-grsec-docs 1:4.9.11.r201702181444-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
x86_64
x86_64 Community couchdb 2.0.0-6 A document-oriented database that can be queried and indexed in a MapReduce fashion using JSON
x86_64 Community ccache 3.3.4-1 A compiler cache
x86_64 Community keepassxc 2.1.2-2 Cross-platform community-driven port of Keepass password manager
x86_64 Community atom 1.14.3-1 A hackable text editor for the 21st Century
x86_64 Community haskell-yesod 1.4.4-20 Creation of type-safe, RESTful web applications.
x86_64 Community haskell-yesod-persistent 1.4.1.1-26 Some helpers for using Persistent from Yesod.
x86_64 Community haskell-persistent-template 2.5.1.6-30 Type-safe, non-relational, multi-backend persistence
x86_64 Community haskell-yesod-form 1.4.10-8 Form handling support for Yesod Web Framework
x86_64 Community haskell-yesod-auth 1.4.16-15 Authentication for Yesod.
x86_64 Community git-annex 6.20170214-2 Manage files with git, without checking their contents into git
x86_64 Community haskell-yesod-default 1.2.0-110 Default config and main functions for your yesod application (deprecated)
x86_64 Community haskell-yesod-core 1.4.31-11 Creation of type-safe, RESTful web applications.
x86_64 Community haskell-yesod-static 1.5.1.1-41 Static file serving subsite for Yesod Web Framework.
x86_64 Community haskell-persistent-sqlite 2.6-29 Backend for the persistent library using sqlite3
x86_64 Community purescript 0.10.7-2 PureScript Programming Language Compiler
x86_64 Community haskell-persistent 2.6-29 Type-safe, multi-backend data serialization
x86_64 Community haskell-esqueleto 2.5.1-7 Type-safe EDSL for SQL queries on persistent backends.
x86_64 Community haskell-monad-logger 0.3.20.2-1 A class of monads which can log messages.
x86_64 Community kamoso 3.2.2-1 A webcam recorder from KDE community
x86_64 Community gost 2.3-1 GO Simple Tunnel
x86_64 Community haskell-configurator 0.3.0.0-1 Configuration management
x86_64 Community linux-grsec 1:4.9.10.r201702162016-1 The Linux kernel and modules with grsecurity/PaX patches
x86_64 Community linux-grsec-headers 1:4.9.10.r201702162016-1 Header files and scripts for building modules for Linux-grsec kernel
x86_64 Community linux-grsec-docs 1:4.9.10.r201702162016-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
x86_64 Community deepin-qt5integration 0.0.7-2 Deepin Qt5 platform plugin
x86_64 Community gnome-flashback 3.22.0-2 GNOME Flashback session
x86_64 Community erlang-nox 19.2.3-1 General-purpose concurrent functional programming language developed by Ericsson (headless version)
x86_64 Community mypaint 1.2.1-2 A fast and easy painting application for digital painters, with brush dynamics
x86_64 Extra mlt 6.4.1-4 An open source multimedia framework
x86_64 Extra mlt-python-bindings 6.4.1-4 An open source multimedia framework
x86_64 Extra jre7-openjdk-headless 7.u131_2.6.9-1 OpenJDK Java 7 headless runtime environment
x86_64 Extra openjdk7-doc 7.u131_2.6.9-1 OpenJDK Java 7 documentation
x86_64 Extra jre7-openjdk 7.u131_2.6.9-1 OpenJDK Java 7 full runtime environment
x86_64 Extra jdk7-openjdk 7.u131_2.6.9-1 OpenJDK Java 7 development kit
x86_64 Extra openjdk7-src 7.u131_2.6.9-1 OpenJDK Java 7 sources
x86_64 Extra imagemagick-doc 6.9.7.9-1 The ImageMagick documentation (utilities manuals and libraries API)
x86_64 Extra imagemagick 6.9.7.9-1 An image viewing/manipulation program
x86_64 Extra alsa-utils 1.1.3-2 An alternative implementation of Linux sound support
x86_64 Extra uhttpmock 0.5.0-2 HTTP web service mocking project for projects which use libsoup
x86_64 Extra xdg-user-dirs-gtk 0.10+9+g5b7efc6-1 Creates user dirs and asks to relocalize them
x86_64 Extra xawtv 3.104+3+gc438af7-1 A simple Xaw-based TV program which uses the bttv driver or video4linux
x86_64 Extra autogen 5.18.12-1 A tool designed to simplify the creation and maintenance of programs that contain large amounts of repetitious text
x86_64 Extra libdc1394 2.2.5-1 High level programming interface to control IEEE 1394 based cameras
x86_64 Extra poppler-glib 0.52.0-1 Poppler glib bindings
x86_64 Extra poppler-qt4 0.52.0-1 Poppler Qt4 bindings
x86_64 Extra cups-filters 1.13.4-1 OpenPrinting CUPS Filters
x86_64 Extra poppler 0.52.0-1 PDF rendering library based on xpdf 3.0
x86_64 Extra poppler-qt5 0.52.0-1 Poppler Qt5 bindings
x86_64 Extra telepathy-salut 0.8.1-4 A link-local XMPP connection manager for Telepathy
x86_64 Testing gnupg 2.1.18-2 Complete and free implementation of the OpenPGP standard
x86_64 Testing libssh-docs 0.7.4-2 Documentation for libssh
x86_64 Testing libssh 0.7.4-2 Library for accessing ssh client services through C libraries
x86_64 Testing wget 1.19.1-2 A network utility to retrieve files from the Web
x86_64 Testing syslog-ng 3.9.1-2 Next-generation syslogd with advanced networking and filtering capabilities
x86_64 Community-Testing linux-grsec-docs 1:4.9.11.r201702181444-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
x86_64 Community-Testing linux-grsec-headers 1:4.9.11.r201702181444-1 Header files and scripts for building modules for Linux-grsec kernel
x86_64 Community-Testing linux-grsec 1:4.9.11.r201702181444-1 The Linux kernel and modules with grsecurity/PaX patches
AUR
npapi-vlc-gtk3 2.2.5-1
mingw-w64-glib2 2.50.3-1
jriver-media-center 22.0.75-1
sc-im 0.5.0-1
openra-kang kang.c5ed7f1-1
micropython-git 1:1.8.7.292.g3d739eb39-1
mingw-w64-dbus 1.10.16-1
cropgui-git b3a00e-1
nvidia-beta-dkms 378.13-1
tari800 3.1.0-2
openvpn-git 2.4.rc2.r31.g6ddc43d1-1
vis-standalone-git 0.2.r781.gc22d020-1
vis-single-git 0.2.r781.gc22d020-1
mandelbulber2-git 20161205-2
vis-git 0.2.r781.gc22d020-1
Thanks
#2019 OFFLINE   securitybreach
  • 24,208 posts
Posted 24 February 2017 - 08:02 PM
Updates for Thursday, February 23rd, 2017
Any
any Community archlinux-appstream-data 20170223-1 Arch Linux application database for AppStream-based software centers
any Community youtube-dl 2017.02.22-1 A small command-line program to download videos from YouTube.com and a few more sites
any Community matrix-synapse 0.19.2-1 Matrix reference homeserver
any Community udiskie 1.6.0-1 Removable disk automounter using udisks
any Community python2-praw 4.4.0-1 Python Reddit API Wrapper that allows for simple access to reddit's API
any Community python-praw 4.4.0-1 Python Reddit API Wrapper that allows for simple access to reddit's API
any Community python2-prawcore 0.8.0-1 Low-level communication layer for PRAW 4+.
any Community python-prawcore 0.8.0-1 Low-level communication layer for PRAW 4+.
any Community deepin-desktop-schemas 3.1.1-1 GSettings deepin desktop-wide schemas
any Community python-botocore 1.5.16-1 A low-level interface to a growing number of Amazon Web Services
any Community aws-cli 1.11.53-1 Universal Command Line Interface for Amazon Web Services
any Community scrapy 1.3.2-1 A fast high-level scraping and web crawling framework.
any Community python-case 1.5.3-1 Python unittest Utilities
any Community python2-case 1.5.3-1 Python unittest Utilities
any Community python-pydispatcher 2.0.5-2 Multi-producer-multi-consumer signal dispatching mechanism
any Community python2-pydispatcher 2.0.5-2 Multi-producer-multi-consumer signal dispatching mechanism
any Community python2-parsel 1.1.0-1 Parsel is a library to extract data from HTML and XML using XPath and CSS selectors
any Community python-parsel 1.1.0-1 Parsel is a library to extract data from HTML and XML using XPath and CSS selectors
any Community typescript 2.2.1-1 TypeScript is a language for application scale Javascript development
any Community eslint 3.16.1-1 An AST-based pattern checker for Javascript
any Community python2-phonenumbers 8.3.1-1 Python version of Google's common library for parsing, formatting, storing and validating international phone numbers
any Community python-phonenumbers 8.3.1-1 Python version of Google's common library for parsing, formatting, storing and validating international phone numbers
any Community mitmproxy 2.0.0-1 SSL-capable man-in-the-middle HTTP proxy
any Community python-kaitaistruct 0.6-1 Kaitai Struct declarative parser generator for binary data: runtime library for Python
any Community python2-kaitaistruct 0.6-1 Kaitai Struct declarative parser generator for binary data: runtime library for Python
any Extra hunspell-en 2017.01.22-2 English (US, UK, etc.) hunspell dictionaries
any Extra hunspell-en_CA 2017.01.22-2 CA English hunspell dictionaries
any Extra hunspell-en_US 2017.01.22-2 US English hunspell dictionaries
any Extra hunspell-en_GB 2017.01.22-2 GB English hunspell dictionaries
any Extra hunspell-en_AU 2017.01.22-2 AU English hunspell dictionaries
any Testing linux-firmware 20170217.12987ca-2 Firmware files for Linux
i686
i686 Community gitlab-runner 1.11.0-1 The official GitLab CI runner written in Go
i686 Community gst-editing-services 1.10.4-1 GStreamer editing services
i686 Community mosquitto 1.4.11-1 An Open Source MQTT v3.1/v3.1.1 Broker
i686 Community python2-pynormaliz 1.5-1 A Python interface to Normaliz
i686 Community python-pynormaliz 1.5-1 A Python interface to Normaliz
i686 Community bumblebee 3.2.1-13 NVIDIA Optimus support for Linux through VirtualGL
i686 Community fio 2.18-1 Scriptable I/O tool for storage benchmarks and drive testing
i686 Community git-annex 6.20170214-7 Manage files with git, without checking their contents into git
i686 Community haskell-persistent-sqlite 2.6.0.1-1 Backend for the persistent library using sqlite3
i686 Community wireguard-tools 0.0.20170223-1 next generation secure network tunnel
i686 Community wireguard-dkms 0.0.20170223-1 next generation secure network tunnel
i686 Community rust-racer 2.0.6-1 Code completion for Rust
i686 Community deepin-session-ui 3.0.27-1 Deepin desktop-environment - Session UI module
i686 Community deepin-api 3.1.2-1 Go-lang bindings for dde-daemon
i686 Community perl-mouse 2.4.9-1 Moose minus the antlers
i686 Community deepin-launcher 4.0.7-1 Deepin desktop-environment - Launcher module
i686 Community normaliz 3.2.1-1 A tool for computations in affine monoids, vector configurations, lattice polytopes, and rational cones.
i686 Community borg 1.0.10-1 Deduplicating backup program with compression and authenticated encryption
i686 Community python2-peewee 2.8.7-1 a little orm
i686 Community python2-bcrypt 3.1.3-1 Modern password hashing for your software and your servers
i686 Community phonegap 6.4.4-1 PhoneGap command-line interface and node.js library
i686 Community python-bcrypt 3.1.3-1 Modern password hashing for your software and your servers
i686 Community python-peewee 2.8.7-1 a little orm
i686 Community linux-grsec-headers 1:4.9.11.r201702222257-1 Header files and scripts for building modules for Linux-grsec kernel
i686 Community linux-grsec-docs 1:4.9.11.r201702222257-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
i686 Community mlite 0.2.23-1 Useful classes originating from MeeGo Touch
i686 Community linux-grsec 1:4.9.11.r201702222257-1 The Linux kernel and modules with grsecurity/PaX patches
i686 Community crash 7.1.8-1 Linux kernel crashdump analysis tool
i686 Extra gst-libav 1.10.4-1 GStreamer Multimedia Framework ffmpeg Plugin
i686 Extra gst-plugins-ugly 1.10.4-1 GStreamer Multimedia Framework Ugly Plugins
i686 Extra gst-python 1.10.4-1 GStreamer Python 3 binding overrides
i686 Extra gst-python2 1.10.4-1 GStreamer Python 2 binding overrides
i686 Extra gstreamer-vaapi 1.10.4-1 GStreamer Multimedia Framework VAAPI Plugin
i686 Extra gst-plugins-good 1.10.4-1 GStreamer Multimedia Framework Good Plugins
i686 Extra gst-plugins-bad 1.10.4-1 GStreamer Multimedia Framework Bad Plugins
i686 Extra gst-plugins-base-libs 1.10.4-1 GStreamer Multimedia Framework Base Plugin libraries
i686 Extra gst-plugins-base 1.10.4-1 GStreamer Multimedia Framework Base Plugins
i686 Extra gstreamer 1.10.4-1 GStreamer Multimedia Framework
i686 Extra libtracker-sparql 1.10.5-1 Desktop-neutral user information store, search tool and indexer (SPARQL library)
i686 Extra tracker 1.10.5-1 Desktop-neutral user information store, search tool and indexer
i686 Extra mesa-vdpau 17.0.0-2 Mesa VDPAU drivers
i686 Extra vulkan-intel 17.0.0-2 Intel's Vulkan mesa driver
i686 Extra mesa 17.0.0-2 an open-source implementation of the OpenGL specification
i686 Extra mesa-libgl 17.0.0-2 Mesa 3-D graphics library
i686 Extra vulkan-radeon 17.0.0-2 Radeon's Vulkan mesa driver
i686 Extra libva-mesa-driver 17.0.0-2 VA-API implementation for gallium
i686 Extra opencl-mesa 17.0.0-2 OpenCL support for AMD/ATI Radeon mesa drivers
i686 Extra opencl-nvidia-304xx 304.135-3 OpenCL implemention for NVIDIA, 304xx legacy branch
i686 Extra nvidia-304xx-utils 304.135-3 NVIDIA drivers utilities and libraries, 304xx legacy branch
i686 Extra opencl-nvidia-340xx 340.102-5 OpenCL implemention for NVIDIA
i686 Extra nvidia-340xx-utils 340.102-5 NVIDIA drivers utilities
i686 Extra x2goplugin 4.1.0.0-1 provides X2Go Client as QtBrowser-based Mozilla plugin
i686 Extra x2goclient 4.1.0.0-1 a graphical client (Qt4) for the X2Go system
i686 Extra libinput 1.6.2-1 Input device management and event handling library
i686 Extra x2goplugin-provider 4.1.0.0-1 an example configuration for providing the X2Go Plugin via an Apache webserver
i686 Extra phonon-qt4-gstreamer 4.9.0-2 Phonon GStreamer backend for Qt4
i686 Extra phonon-qt5-vlc 0.9.1-1 Phonon VLC backend for Qt5
i686 Extra phonon-qt4 4.9.1-2 The multimedia framework for KDE4
i686 Extra phonon-qt5 4.9.1-2 The multimedia framework for KF5
i686 Extra phonon-qt5-gstreamer 4.9.0-2 Phonon GStreamer backend for Qt5
i686 Extra phonon-qt4-vlc 0.9.1-1 Phonon VLC backend for Qt4
i686 Extra nvidia-304xx 304.135-1 NVIDIA drivers for linux, 304xx legacy branch
i686 Extra nvidia-304xx-dkms 304.135-1 NVIDIA driver sources for linux, 304xx legacy branch
i686 Extra nvidia-304xx-lts 304.135-1 NVIDIA drivers for linux-lts, 304xx legacy branch
i686 Extra openmpi 1.10.6-1 High performance message passing library (MPI)
i686 Testing libutil-linux 2.29.2-1 util-linux runtime libraries
i686 Testing util-linux 2.29.2-1 Miscellaneous system utilities for Linux
i686 Testing nano 2.7.5-1 Pico editor clone with enhancements
x86_64
x86_64 Community gitlab-runner 1.11.0-1 The official GitLab CI runner written in Go
x86_64 Community gst-editing-services 1.10.4-1 GStreamer editing services
x86_64 Community mosquitto 1.4.11-1 An Open Source MQTT v3.1/v3.1.1 Broker
x86_64 Community python2-pynormaliz 1.5-1 A Python interface to Normaliz
x86_64 Community python-pynormaliz 1.5-1 A Python interface to Normaliz
x86_64 Community bumblebee 3.2.1-13 NVIDIA Optimus support for Linux through VirtualGL
x86_64 Community fio 2.18-1 Scriptable I/O tool for storage benchmarks and drive testing
x86_64 Community git-annex 6.20170214-7 Manage files with git, without checking their contents into git
x86_64 Community haskell-persistent-sqlite 2.6.0.1-1 Backend for the persistent library using sqlite3
x86_64 Community wireguard-tools 0.0.20170223-1 next generation secure network tunnel
x86_64 Community wireguard-dkms 0.0.20170223-1 next generation secure network tunnel
x86_64 Community rust-racer 2.0.6-1 Code completion for Rust
x86_64 Community deepin-session-ui 3.0.27-1 Deepin desktop-environment - Session UI module
x86_64 Community deepin-api 3.1.2-1 Go-lang bindings for dde-daemon
x86_64 Community perl-mouse 2.4.9-1 Moose minus the antlers
x86_64 Community deepin-launcher 4.0.7-1 Deepin desktop-environment - Launcher module
x86_64 Community normaliz 3.2.1-1 A tool for computations in affine monoids, vector configurations, lattice polytopes, and rational cones.
x86_64 Community borg 1.0.10-1 Deduplicating backup program with compression and authenticated encryption
x86_64 Community python2-peewee 2.8.7-1 a little orm
x86_64 Community python2-bcrypt 3.1.3-1 Modern password hashing for your software and your servers
x86_64 Community phonegap 6.4.4-1 PhoneGap command-line interface and node.js library
x86_64 Community python-bcrypt 3.1.3-1 Modern password hashing for your software and your servers
x86_64 Community python-peewee 2.8.7-1 a little orm
x86_64 Community linux-grsec-headers 1:4.9.11.r201702222257-1 Header files and scripts for building modules for Linux-grsec kernel
x86_64 Community linux-grsec-docs 1:4.9.11.r201702222257-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
x86_64 Community mlite 0.2.23-1 Useful classes originating from MeeGo Touch
x86_64 Community linux-grsec 1:4.9.11.r201702222257-1 The Linux kernel and modules with grsecurity/PaX patches
x86_64 Community crash 7.1.8-1 Linux kernel crashdump analysis tool
x86_64 Extra gst-libav 1.10.4-1 GStreamer Multimedia Framework ffmpeg Plugin
x86_64 Extra gst-plugins-ugly 1.10.4-1 GStreamer Multimedia Framework Ugly Plugins
x86_64 Extra gst-python 1.10.4-1 GStreamer Python 3 binding overrides
x86_64 Extra gst-python2 1.10.4-1 GStreamer Python 2 binding overrides
x86_64 Extra gstreamer-vaapi 1.10.4-1 GStreamer Multimedia Framework VAAPI Plugin
x86_64 Extra gst-plugins-good 1.10.4-1 GStreamer Multimedia Framework Good Plugins
x86_64 Extra gst-plugins-bad 1.10.4-1 GStreamer Multimedia Framework Bad Plugins
x86_64 Extra gst-plugins-base-libs 1.10.4-1 GStreamer Multimedia Framework Base Plugin libraries
x86_64 Extra gst-plugins-base 1.10.4-1 GStreamer Multimedia Framework Base Plugins
x86_64 Extra gstreamer 1.10.4-1 GStreamer Multimedia Framework
x86_64 Extra libtracker-sparql 1.10.5-1 Desktop-neutral user information store, search tool and indexer (SPARQL library)
x86_64 Extra tracker 1.10.5-1 Desktop-neutral user information store, search tool and indexer
x86_64 Extra mesa-vdpau 17.0.0-2 Mesa VDPAU drivers
x86_64 Extra vulkan-intel 17.0.0-2 Intel's Vulkan mesa driver
x86_64 Extra mesa 17.0.0-2 an open-source implementation of the OpenGL specification
x86_64 Extra mesa-libgl 17.0.0-2 Mesa 3-D graphics library
x86_64 Extra vulkan-radeon 17.0.0-2 Radeon's Vulkan mesa driver
x86_64 Extra libva-mesa-driver 17.0.0-2 VA-API implementation for gallium
x86_64 Extra opencl-mesa 17.0.0-2 OpenCL support for AMD/ATI Radeon mesa drivers
x86_64 Extra opencl-nvidia-304xx 304.135-3 OpenCL implemention for NVIDIA, 304xx legacy branch
x86_64 Extra nvidia-304xx-utils 304.135-3 NVIDIA drivers utilities and libraries, 304xx legacy branch
x86_64 Extra opencl-nvidia-340xx 340.102-5 OpenCL implemention for NVIDIA
x86_64 Extra nvidia-340xx-utils 340.102-5 NVIDIA drivers utilities
x86_64 Extra x2goplugin 4.1.0.0-1 provides X2Go Client as QtBrowser-based Mozilla plugin
x86_64 Extra x2goclient 4.1.0.0-1 a graphical client (Qt4) for the X2Go system
x86_64 Extra libinput 1.6.2-1 Input device management and event handling library
x86_64 Extra x2goplugin-provider 4.1.0.0-1 an example configuration for providing the X2Go Plugin via an Apache webserver
x86_64 Extra phonon-qt4-gstreamer 4.9.0-2 Phonon GStreamer backend for Qt4
x86_64 Extra phonon-qt5-vlc 0.9.1-1 Phonon VLC backend for Qt5
x86_64 Extra phonon-qt4 4.9.1-2 The multimedia framework for KDE4
x86_64 Extra phonon-qt5 4.9.1-2 The multimedia framework for KF5
x86_64 Extra phonon-qt5-gstreamer 4.9.0-2 Phonon GStreamer backend for Qt5
x86_64 Extra phonon-qt4-vlc 0.9.1-1 Phonon VLC backend for Qt4
x86_64 Extra nvidia-304xx 304.135-1 NVIDIA drivers for linux, 304xx legacy branch
x86_64 Extra nvidia-304xx-dkms 304.135-1 NVIDIA driver sources for linux, 304xx legacy branch
x86_64 Extra nvidia-304xx-lts 304.135-1 NVIDIA drivers for linux-lts, 304xx legacy branch
x86_64 Extra openmpi 1.10.6-1 High performance message passing library (MPI)
x86_64 Multilib lib32-mesa-vdpau 17.0.0-2 Mesa VDPAU drivers (32-bit)
x86_64 Multilib lib32-vulkan-radeon 17.0.0-2 Radeon's Vulkan mesa driver (32-bit)
x86_64 Multilib lib32-mesa 17.0.0-2 an open-source implementation of the OpenGL specification (32-bit)
x86_64 Multilib lib32-mesa-libgl 17.0.0-2 Mesa 3-D graphics library (32-bit)
x86_64 Multilib lib32-vulkan-intel 17.0.0-2 Intel's Vulkan mesa driver (32-bit)
x86_64 Multilib lib32-nvidia-340xx-utils 340.102-3 NVIDIA drivers utilities (32-bit)
x86_64 Multilib lib32-opencl-nvidia-340xx 340.102-3 OpenCL implemention for NVIDIA (32-bit)
x86_64 Multilib lib32-nvidia-304xx-utils 304.135-2 NVIDIA drivers utilities (32-bit)
x86_64 Multilib lib32-opencl-nvidia-304xx 304.135-2 OpenCL implemention for NVIDIA (32-bit)
x86_64 Testing libutil-linux 2.29.2-1 util-linux runtime libraries
x86_64 Testing util-linux 2.29.2-1 Miscellaneous system utilities for Linux
x86_64 Testing nano 2.7.5-1 Pico editor clone with enhancements
x86_64 Multilib-Testing lib32-util-linux 2.29.2-1 Miscellaneous system utilities for Linux (32-bit)
AUR
openfx-gmic-bin 1.01-2
tor-browser-bin 6.5-2
cin-bin 5.1-201731
htmlunit 2.25-1
firejail-extras 0.9.44-18
webmc 0.4-1
gstreamer0.10-ugly 0.10.19-27
gstreamer0.10-ugly-plugins 0.10.19-27
gstreamer0.10-good 0.10.31-27
gstreamer0.10-good-plugins 0.10.31-27
gstreamer0.10-bad 0.10.23-36
gstreamer0.10-bad-plugins 0.10.23-36
gstreamer0.10 0.10.36-16
hop-git 3.0.0r878.24bf063-1
unbound-dnstap 1.6.1-1
Thanks
#2020 OFFLINE   securitybreach
  • 24,208 posts
Posted 28 February 2017 - 02:52 PM
Updates for Monday, February 27th, 2017
Any
any Community man-pages-ru 4.05_2306_2240_20161008-1 Russian Linux man pages
any Community nextcloud 11.0.2-1 A cloud server to store your files centrally on a hardware controlled by you
any Community flightgear-data 2017.1.1-1 Base-Data for the opensource flight-simulator.
any Community tesseract-data-ara 4.00-1 Tesseract OCR data (ara)
any Community tesseract-data-nld 4.00-1 Tesseract OCR data (nld)
any Community tesseract-data-frk 4.00-1 Tesseract OCR data (frk)
any Community tesseract-data-uig 4.00-1 Tesseract OCR data (uig)
any Community tesseract-data-pus 4.00-1 Tesseract OCR data (pus)
any Community tesseract-data-kat 4.00-1 Tesseract OCR data (kat)
any Community tesseract-data-lav 4.00-1 Tesseract OCR data (lav)
any Community tesseract-data-ukr 4.00-1 Tesseract OCR data (ukr)
any Community tesseract-data-khm 4.00-1 Tesseract OCR data (khm)
any Community tesseract-data-spa_old 4.00-1 Tesseract OCR data (spa_old)
any Community tesseract-data-chi_tra 4.00-1 Tesseract OCR data (chi_tra)
any Community tesseract-data-dan 4.00-1 Tesseract OCR data (dan)
any Community tesseract-data-kor 4.00-1 Tesseract OCR data (kor)
any Community tesseract-data-ell 4.00-1 Tesseract OCR data (ell)
any Community tesseract-data-aze_cyrl 4.00-1 Tesseract OCR data (aze_cyrl)
any Community tesseract-data-hun 4.00-1 Tesseract OCR data (hun)
any Community tesseract-data-ceb 4.00-1 Tesseract OCR data (ceb)
any Community tesseract-data-aze 4.00-1 Tesseract OCR data (aze)
any Community tesseract-data-eus 4.00-1 Tesseract OCR data (eus)
any Community tesseract-data-amh 4.00-1 Tesseract OCR data (amh)
any Community tesseract-data-urd 4.00-1 Tesseract OCR data (urd)
any Community tesseract-data-mkd 4.00-1 Tesseract OCR data (mkd)
any Community tesseract-data-tha 4.00-1 Tesseract OCR data (tha)
any Community tesseract-data-deu 4.00-1 Tesseract OCR data (deu)
any Community tesseract-data-hin 4.00-1 Tesseract OCR data (hin)
any Community tesseract-data-syr 4.00-1 Tesseract OCR data (syr)
any Community tesseract-data-tir 4.00-1 Tesseract OCR data (tir)
any Community tesseract-data-sin 4.00-1 Tesseract OCR data (sin)
any Community tesseract-data-san 4.00-1 Tesseract OCR data (san)
any Community tesseract-data-est 4.00-1 Tesseract OCR data (est)
any Community tesseract-data-uzb 4.00-1 Tesseract OCR data (uzb)
any Community tesseract-data-swe 4.00-1 Tesseract OCR data (swe)
any Community tesseract-data-kir 4.00-1 Tesseract OCR data (kir)
any Community tesseract-data-gle 4.00-1 Tesseract OCR data (gle)
any Community tesseract-data-slk 4.00-1 Tesseract OCR data (slk)
any Community tesseract-data-bod 4.00-1 Tesseract OCR data (bod)
any Community tesseract-data-epo 4.00-1 Tesseract OCR data (epo)
any Community tesseract-data-fra 4.00-1 Tesseract OCR data (fra)
any Community tesseract-data-bul 4.00-1 Tesseract OCR data (bul)
any Community tesseract-data-bos 4.00-1 Tesseract OCR data (bos)
any Community tesseract-data-jpn 4.00-1 Tesseract OCR data (jpn)
any Community tesseract-data-ron 4.00-1 Tesseract OCR data (ron)
any Community tesseract-data-msa 4.00-1 Tesseract OCR data (msa)
any Community tesseract-data-ita 4.00-1 Tesseract OCR data (ita)
any Community tesseract-data-ces 4.00-1 Tesseract OCR data (ces)
any Community tesseract-data-glg 4.00-1 Tesseract OCR data (glg)
any Community tesseract-data-swa 4.00-1 Tesseract OCR data (swa)
any Community tesseract-data-mar 4.00-1 Tesseract OCR data (mar)
any Community tesseract-data-ben 4.00-1 Tesseract OCR data (ben)
any Community tesseract-data-cat 4.00-1 Tesseract OCR data (cat)
any Community tesseract-data-hrv 4.00-1 Tesseract OCR data (hrv)
any Community tesseract-data-yid 4.00-1 Tesseract OCR data (yid)
any Community tesseract-data-kaz 4.00-1 Tesseract OCR data (kaz)
any Community tesseract-data-tur 4.00-1 Tesseract OCR data (tur)
any Community tesseract-data-ita_old 4.00-1 Tesseract OCR data (ita_old)
any Community tesseract-data-pol 4.00-1 Tesseract OCR data (pol)
any Community tesseract-data-nep 4.00-1 Tesseract OCR data (nep)
any Community tesseract-data-afr 4.00-1 Tesseract OCR data (afr)
any Community tesseract-data-slk_frak 4.00-1 Tesseract OCR data (slk_frak)
any Community tesseract-data-ori 4.00-1 Tesseract OCR data (ori)
any Community tesseract-data-grc 4.00-1 Tesseract OCR data (grc)
any Community tesseract-data-tgk 4.00-1 Tesseract OCR data (tgk)
any Community tesseract-data-chi_sim 4.00-1 Tesseract OCR data (chi_sim)
any Community tesseract-data-guj 4.00-1 Tesseract OCR data (guj)
any Community tesseract-data-heb 4.00-1 Tesseract OCR data (heb)
any Community tesseract-data-pan 4.00-1 Tesseract OCR data (pan)
any Community tesseract-data-ind 4.00-1 Tesseract OCR data (ind)
any Community tesseract-data-kat_old 4.00-1 Tesseract OCR data (kat_old)
any Community tesseract-data-tam 4.00-1 Tesseract OCR data (tam)
any Community tesseract-data-slv 4.00-1 Tesseract OCR data (slv)
any Community tesseract-data-mya 4.00-1 Tesseract OCR data (mya)
any Community tesseract-data-por 4.00-1 Tesseract OCR data (por)
any Community tesseract-data-tgl 4.00-1 Tesseract OCR data (tgl)
any Community tesseract-data-srp 4.00-1 Tesseract OCR data (srp)
any Community tesseract-data-kur 4.00-1 Tesseract OCR data (kur)
any Community tesseract-data-tel 4.00-1 Tesseract OCR data (tel)
any Community tesseract-data-lat 4.00-1 Tesseract OCR data (lat)
any Community tesseract-data-equ 4.00-1 Tesseract OCR data (equ)
any Community tesseract-data-cym 4.00-1 Tesseract OCR data (cym)
any Community tesseract-data-bel 4.00-1 Tesseract OCR data (bel)
any Community tesseract-data-vie 4.00-1 Tesseract OCR data (vie)
any Community tesseract-data-fas 4.00-1 Tesseract OCR data (fas)
any Community tesseract-data-sqi 4.00-1 Tesseract OCR data (sqi)
any Community tesseract-data-isl 4.00-1 Tesseract OCR data (isl)
any Community tesseract-data-eng 4.00-1 Tesseract OCR data (eng)
any Community tesseract-data-mlt 4.00-1 Tesseract OCR data (mlt)
any Community tesseract-data-spa 4.00-1 Tesseract OCR data (spa)
any Community tesseract-data-enm 4.00-1 Tesseract OCR data (enm)
any Community tesseract-data-srp_latn 4.00-1 Tesseract OCR data (srp_latn)
any Community tesseract-data-iku 4.00-1 Tesseract OCR data (iku)
any Community tesseract-data-mal 4.00-1 Tesseract OCR data (mal)
any Community tesseract-data-asm 4.00-1 Tesseract OCR data (asm)
any Community tesseract-data-kan 4.00-1 Tesseract OCR data (kan)
any Community tesseract-data-deu_frak 4.00-1 Tesseract OCR data (deu_frak)
any Community tesseract-data-uzb_cyrl 4.00-1 Tesseract OCR data (uzb_cyrl)
any Community tesseract-data-jav 4.00-1 Tesseract OCR data (jav)
any Community tesseract-data-dan_frak 4.00-1 Tesseract OCR data (dan_frak)
any Community tesseract-data-nor 4.00-1 Tesseract OCR data (nor)
any Community tesseract-data-dzo 4.00-1 Tesseract OCR data (dzo)
any Community tesseract-data-hat 4.00-1 Tesseract OCR data (hat)
any Community tesseract-data-lao 4.00-1 Tesseract OCR data (lao)
any Community tesseract-data-lit 4.00-1 Tesseract OCR data (lit)
any Community cacti 1.0.4-1 complete network graphing solution designed to harness the power of RRDTool's data storage and graphing functionality
any Community tesseract-data-rus 4.00-1 Tesseract OCR data (rus)
any Community tesseract-data-fin 4.00-1 Tesseract OCR data (fin)
any Community tesseract-data-frm 4.00-1 Tesseract OCR data (frm)
any Community tesseract-data-chr 4.00-1 Tesseract OCR data (chr)
any Community python-pycryptodomex 3.4.5-1 A self-contained Python package of low-level cryptographic primitives
any Community python2-pycryptodomex 3.4.5-1 A self-contained Python package of low-level cryptographic primitives
any Community python2-sphinx 1.5.3-1 Python2 documentation generator
any Community python-sphinx 1.5.3-1 Python3 documentation generator
any Community python-ghp-import 0.5.5-1 Copy your docs directly to the gh-pages branch
any Community zsh-completions 0.23.0-1 Additional completion definitions for Zsh
any Community python-txaio 2.6.1-1 Utilities to support code that runs unmodified on Twisted and asyncio
any Community python2-txaio 2.6.1-1 Utilities to support code that runs unmodified on Twisted and asyncio
any Community python-faker 0.7.9-1 Faker generates fake data for you.
any Community diff-so-fancy 0.11.3-1 Good-looking diffs with diff-highlight and more
any Community python2-faker 0.7.9-1 Faker generates fake data for you.
any Community jenkins 2.48-1 Extendable continuous integration server (latest)
any Community python-karellen-geventws 1.0.2-1 Websocket handler for the gevent pywsgi server, a Python network library
i686
i686 Core linux-lts 4.4.52-1 The Linux-lts kernel and modules
i686 Core linux-lts-headers 4.4.52-1 Header files and scripts for building modules for Linux-lts kernel
i686 Core linux-lts-docs 4.4.52-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
i686 Core iproute2-doc 4.10.0-2 IP Routing Utilities documentation
i686 Core iproute2 4.10.0-2 IP Routing Utilities
i686 Core kmod 24-1 Linux kernel module management tools and library
i686 Core curl 7.53.1-1 An URL retrieval utility and library
i686 Community libwebsockets 2.1.1-1 C library for websocket clients and servers
i686 Community arb 2.10.0-1 C library for arbitrary-precision floating-point ball arithmetic
i686 Community android-file-transfer 3.1-1 Android MTP client with minimalistic UI
i686 Community qcad 3.16.5.0-1 A 2D CAD package based upon Qt
i686 Community sdlmame 0.183-1 A port of the popular Multiple Arcade Machine Emulator using SDL with OpenGL support.
i686 Community simgear 2017.1.1-1 A set of open-source libraries designed to be used as building blocks for quickly assembling 3d simulations, games, and visualization applications.
i686 Community flightgear 2017.1.1-1 An open-source, multi-platform flight simulator
i686 Community blender 17:2.78.c-1 A fully integrated 3D graphics creation suite
i686 Community linux-grsec-headers 1:4.9.13.r201702270729-1 Header files and scripts for building modules for Linux-grsec kernel
i686 Community linux-grsec-docs 1:4.9.13.r201702270729-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
i686 Community linux-grsec 1:4.9.13.r201702270729-1 The Linux kernel and modules with grsecurity/PaX patches
i686 Community swi-prolog 7.4.0_rc2-1 Prolog environment
i686 Community parole 0.9.1-1 A modern media player based on the GStreamer framework
i686 Community 0ad a21-4 Cross-platform, 3D and historically-based real-time strategy game
i686 Community gloox 1.0.19-1 C++ libraries for development of Jabber client/component/server
i686 Community smlnj 110.80-3 Compiler for Standard ML, from New Jersey
i686 Community dovecot 2.2.28-1 An IMAP and POP3 server written with security primarily in mind
i686 Community pigeonhole 0.4.17-1 Sieve implementation for Dovecot
i686 Community python-cchardet 1.1.3-1 Universal encoding detector faster than chardet.
i686 Community python2-cchardet 1.1.3-1 Universal encoding detector faster than chardet.
i686 Community virtualbox-guest-modules-arch 5.1.14-7 Virtualbox guest kernel modules for Arch Kernel
i686 Community virtualbox-host-modules-arch 5.1.14-7 Virtualbox host kernel modules for Arch Kernel
i686 Community virtualbox-guest-utils-nox 5.1.14-3 VirtualBox Guest userspace utilities without X support
i686 Community virtualbox-ext-vnc 5.1.14-3 VirtualBox VNC extension pack
i686 Community virtualbox-guest-dkms 5.1.14-3 VirtualBox Guest kernel modules sources
i686 Community virtualbox-host-dkms 5.1.14-3 VirtualBox Host kernel modules sources
i686 Community virtualbox-sdk 5.1.14-3 VirtualBox Software Developer Kit (SDK)
i686 Community virtualbox 5.1.14-3 Powerful x86 virtualization for enterprise as well as home use
i686 Community virtualbox-guest-utils 5.1.14-3 VirtualBox Guest userspace utilities
i686 Community python2-pyodbc 4.0.13-1 ODBC module for Python 2.x
i686 Community python-pyodbc 4.0.13-1 ODBC module for Python 3.x
i686 Community python-pyscard 1.9.5-1 Framework for building smart card aware applications in Python
i686 Community python-cx_freeze 5.0.1-1 Utilities for freezing Python scripts into executables
i686 Community dart 1.22.1-1 The dart programming language SDK
i686 Community python2-cx_freeze 5.0.1-1 Utilities for freezing Python scripts into executables
i686 Extra pango 1.40.4-1 A library for layout and rendering of text
i686 Extra file-roller 3.22.3-1 Create and modify archives
i686 Extra perl-autovivification 0.16-3 Lexically disable autovivification.
i686 Extra libktnef 16.12.2-2 API for handling TNEF data
i686 Extra opencl-nvidia-304xx 304.135-5 OpenCL implemention for NVIDIA, 304xx legacy branch
i686 Extra nvidia-304xx-utils 304.135-5 NVIDIA drivers utilities and libraries, 304xx legacy branch
i686 Extra libfbclient 2.5.7.27050-1 Client library for Firebird.
i686 Extra opencl-nvidia-340xx 340.102-7 OpenCL implemention for NVIDIA
i686 Extra nvidia-340xx-utils 340.102-7 NVIDIA drivers utilities
i686 Extra nvidia-utils 378.13-3 NVIDIA drivers utilities
i686 Extra opencl-nvidia 378.13-3 OpenCL implemention for NVIDIA
i686 Extra git 2.12.0-1 the fast distributed version control system
i686 Extra nvidia-libgl 378.13-3 NVIDIA drivers libraries symlinks
i686 Testing nvidia-lts 378.13-3 NVIDIA drivers for linux-lts
i686 Testing nvidia-340xx-lts 340.102-3 NVIDIA drivers for linux-lts
i686 Testing nvidia-304xx-lts 304.135-2 NVIDIA drivers for linux-lts, 304xx legacy branch
i686 Testing linux-lts-docs 4.9.13-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
i686 Testing linux-lts 4.9.13-1 The Linux-lts kernel and modules
i686 Testing linux-lts-headers 4.9.13-1 Header files and scripts for building modules for Linux-lts kernel
i686 Testing hwloc 1.11.6-1 Portable Hardware Locality is a portable abstraction of hierarchical architectures
i686 Testing nvidia-340xx-utils 340.102-8 NVIDIA drivers utilities
i686 Testing libva-mesa-driver 17.0.0-3 VA-API implementation for gallium
i686 Testing nvidia-304xx-utils 304.135-6 NVIDIA drivers utilities and libraries, 304xx legacy branch
i686 Testing vulkan-intel 17.0.0-3 Intel's Vulkan mesa driver
i686 Testing mesa 17.0.0-3 an open-source implementation of the OpenGL specification
i686 Testing opencl-nvidia-304xx 304.135-6 OpenCL implemention for NVIDIA, 304xx legacy branch
i686 Testing nvidia-utils 378.13-5 NVIDIA drivers utilities
i686 Testing vulkan-radeon 17.0.0-3 Radeon's Vulkan mesa driver
i686 Testing opencl-mesa 17.0.0-3 OpenCL support for AMD/ATI Radeon mesa drivers
i686 Testing mesa-vdpau 17.0.0-3 Mesa VDPAU drivers
i686 Testing opencl-nvidia-340xx 340.102-8 OpenCL implemention for NVIDIA
i686 Testing libglvnd 0.2.999+g4ba53457-1 The GL Vendor-Neutral Dispatch library
i686 Testing opencl-nvidia 378.13-5 OpenCL implemention for NVIDIA
i686 Testing syslinux 6.03-7 Collection of boot loaders that boot from FAT, ext2/3/4 and btrfs filesystems, from CDs and via PXE
i686 Testing nghttp2 1.20.0-1 Framing layer of HTTP/2 is implemented as a reusable C library
i686 Testing libarchive 3.3.1-4 library that can create and read several streaming archive formats
i686 Testing libvoikko 4.1-1 A spelling and grammar checker, hyphenator and collection of related linguistic data for Finnish language
i686 Community-Testing bbswitch-lts 0.8-28 Kernel module allowing to switch dedicated graphics card on Optimus laptops
i686 Community-Testing acpi_call-lts 1.1.0-39 A linux kernel module that enables calls to ACPI methods through /proc/acpi/call
i686 Community-Testing tp_smapi-lts 0.42-9 Modules for ThinkPad's SMAPI functionality
i686 Community-Testing r8168-lts 8.044.02-3 A kernel module for Realtek 8168 network cards for linux-lts
i686 Community-Testing bumblebee 3.2.1-15 NVIDIA Optimus support for Linux through VirtualGL
i686 Community-Testing primus 20151110-7 Faster OpenGL offloading for Bumblebee
i686 Community-Testing stlink 1.3.1-1 Firmware programmer for STM32 STLINK v1/v2 protocol
i686 Community-Testing virtualbox-guest-modules-arch 5.1.14-9 Virtualbox guest kernel modules for Arch Kernel
i686 Community-Testing virtualbox-host-modules-arch 5.1.14-9 Virtualbox host kernel modules for Arch Kernel
i686 Community-Testing libmatio 1.5.10-1 C library with a fortran 90/95 module interface for reading/writing MATLAB MAT-files
x86_64
x86_64 Core linux-lts 4.4.52-1 The Linux-lts kernel and modules
x86_64 Core linux-lts-headers 4.4.52-1 Header files and scripts for building modules for Linux-lts kernel
x86_64 Core linux-lts-docs 4.4.52-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
x86_64 Core iproute2-doc 4.10.0-2 IP Routing Utilities documentation
x86_64 Core iproute2 4.10.0-2 IP Routing Utilities
x86_64 Core kmod 24-1 Linux kernel module management tools and library
x86_64 Core curl 7.53.1-1 An URL retrieval utility and library
x86_64 Community arb 2.10.0-1 C library for arbitrary-precision floating-point ball arithmetic
x86_64 Community android-file-transfer 3.1-1 Android MTP client with minimalistic UI
x86_64 Community qcad 3.16.5.0-1 A 2D CAD package based upon Qt
x86_64 Community sdlmame 0.183-1 A port of the popular Multiple Arcade Machine Emulator using SDL with OpenGL support.
x86_64 Community flightgear 2017.1.1-1 An open-source, multi-platform flight simulator
x86_64 Community simgear 2017.1.1-1 A set of open-source libraries designed to be used as building blocks for quickly assembling 3d simulations, games, and visualization applications.
x86_64 Community blender 17:2.78.c-1 A fully integrated 3D graphics creation suite
x86_64 Community linux-grsec-headers 1:4.9.13.r201702270729-1 Header files and scripts for building modules for Linux-grsec kernel
x86_64 Community linux-grsec-docs 1:4.9.13.r201702270729-1 Kernel hackers manual - HTML documentation that comes with the Linux-grsec kernel
x86_64 Community linux-grsec 1:4.9.13.r201702270729-1 The Linux kernel and modules with grsecurity/PaX patches
x86_64 Community swi-prolog 7.4.0_rc2-1 Prolog environment
x86_64 Community smlnj 110.80-3 Compiler for Standard ML, from New Jersey
x86_64 Community 0ad a21-4 Cross-platform, 3D and historically-based real-time strategy game
x86_64 Community parole 0.9.1-1 A modern media player based on the GStreamer framework
x86_64 Community gloox 1.0.19-1 C++ libraries for development of Jabber client/component/server
x86_64 Community dovecot 2.2.28-1 An IMAP and POP3 server written with security primarily in mind
x86_64 Community pigeonhole 0.4.17-1 Sieve implementation for Dovecot
x86_64 Community python-cchardet 1.1.3-1 Universal encoding detector faster than chardet.
x86_64 Community python2-cchardet 1.1.3-1 Universal encoding detector faster than chardet.
x86_64 Community virtualbox-guest-modules-arch 5.1.14-7 Virtualbox guest kernel modules for Arch Kernel
x86_64 Community virtualbox-host-modules-arch 5.1.14-7 Virtualbox host kernel modules for Arch Kernel
x86_64 Community virtualbox-guest-utils-nox 5.1.14-3 VirtualBox Guest userspace utilities without X support
x86_64 Community virtualbox-ext-vnc 5.1.14-3 VirtualBox VNC extension pack
x86_64 Community virtualbox-guest-dkms 5.1.14-3 VirtualBox Guest kernel modules sources
x86_64 Community virtualbox-host-dkms 5.1.14-3 VirtualBox Host kernel modules sources
x86_64 Community virtualbox-sdk 5.1.14-3 VirtualBox Software Developer Kit (SDK)
x86_64 Community virtualbox 5.1.14-3 Powerful x86 virtualization for enterprise as well as home use
x86_64 Community virtualbox-guest-utils 5.1.14-3 VirtualBox Guest userspace utilities
x86_64 Community python2-pyodbc 4.0.13-1 ODBC module for Python 2.x
x86_64 Community python-pyodbc 4.0.13-1 ODBC module for Python 3.x
x86_64 Community python-pyscard 1.9.5-1 Framework for building smart card aware applications in Python
x86_64 Community python-cx_freeze 5.0.1-1 Utilities for freezing Python scripts into executables
x86_64 Community dart 1.22.1-1 The dart programming language SDK
x86_64 Community python2-cx_freeze 5.0.1-1 Utilities for freezing Python scripts into executables
x86_64 Community libwebsockets 2.1.1-1 C library for websocket clients and servers
x86_64 Extra perl-autovivification 0.16-3 Lexically disable autovivification.
x86_64 Extra libktnef 16.12.2-2 API for handling TNEF data
x86_64 Extra opencl-nvidia-304xx 304.135-5 OpenCL implemention for NVIDIA, 304xx legacy branch
x86_64 Extra nvidia-304xx-utils 304.135-5 NVIDIA drivers utilities and libraries, 304xx legacy branch
x86_64 Extra libfbclient 2.5.7.27050-1 Client library for Firebird.
x86_64 Extra opencl-nvidia-340xx 340.102-7 OpenCL implemention for NVIDIA
x86_64 Extra nvidia-340xx-utils 340.102-7 NVIDIA drivers utilities
x86_64 Extra nvidia-utils 378.13-3 NVIDIA drivers utilities
x86_64 Extra opencl-nvidia 378.13-3 OpenCL implemention for NVIDIA
x86_64 Extra git 2.12.0-1 the fast distributed version control system
x86_64 Extra nvidia-libgl 378.13-3 NVIDIA drivers libraries symlinks
x86_64 Extra pango 1.40.4-1 A library for layout and rendering of text
x86_64 Extra file-roller 3.22.3-1 Create and modify archives
x86_64 Multilib lib32-libglvnd 0.1.1.20161028-1.1 The GL Vendor-Neutral Dispatch library
x86_64 Testing nvidia-lts 378.13-3 NVIDIA drivers for linux-lts
x86_64 Testing nvidia-340xx-lts 340.102-3 NVIDIA drivers for linux-lts
x86_64 Testing nvidia-304xx-lts 304.135-2 NVIDIA drivers for linux-lts, 304xx legacy branch
x86_64 Testing linux-lts-docs 4.9.13-1 Kernel hackers manual - HTML documentation that comes with the Linux-lts kernel
x86_64 Testing linux-lts 4.9.13-1 The Linux-lts kernel and modules
x86_64 Testing linux-lts-headers 4.9.13-1 Header files and scripts for building modules for Linux-lts kernel
x86_64 Testing hwloc 1.11.6-1 Portable Hardware Locality is a portable abstraction of hierarchical architectures
x86_64 Testing nvidia-340xx-utils 340.102-8 NVIDIA drivers utilities
x86_64 Testing libva-mesa-driver 17.0.0-3 VA-API implementation for gallium
x86_64 Testing nvidia-304xx-utils 304.135-6 NVIDIA drivers utilities and libraries, 304xx legacy branch
x86_64 Testing vulkan-intel 17.0.0-3 Intel's Vulkan mesa driver
x86_64 Testing mesa 17.0.0-3 an open-source implementation of the OpenGL specification
x86_64 Testing opencl-nvidia-304xx 304.135-6 OpenCL implemention for NVIDIA, 304xx legacy branch
x86_64 Testing nvidia-utils 378.13-5 NVIDIA drivers utilities
x86_64 Testing vulkan-radeon 17.0.0-3 Radeon's Vulkan mesa driver
x86_64 Testing opencl-mesa 17.0.0-3 OpenCL support for AMD/ATI Radeon mesa drivers
x86_64 Testing mesa-vdpau 17.0.0-3 Mesa VDPAU drivers
x86_64 Testing opencl-nvidia-340xx 340.102-8 OpenCL implemention for NVIDIA
x86_64 Testing libglvnd 0.2.999+g4ba53457-1 The GL Vendor-Neutral Dispatch library
x86_64 Testing opencl-nvidia 378.13-5 OpenCL implemention for NVIDIA
x86_64 Testing syslinux 6.03-7 Collection of boot loaders that boot from FAT, ext2/3/4 and btrfs filesystems, from CDs and via PXE
x86_64 Testing nghttp2 1.20.0-1 Framing layer of HTTP/2 is implemented as a reusable C library
x86_64 Testing libarchive 3.3.1-4 library that can create and read several streaming archive formats
x86_64 Testing libvoikko 4.1-1 A spelling and grammar checker, hyphenator and collection of related linguistic data for Finnish language
x86_64 Community-Testing bbswitch-lts 0.8-28 Kernel module allowing to switch dedicated graphics card on Optimus laptops
x86_64 Community-Testing acpi_call-lts 1.1.0-39 A linux kernel module that enables calls to ACPI methods through /proc/acpi/call
x86_64 Community-Testing tp_smapi-lts 0.42-9 Modules for ThinkPad's SMAPI functionality
x86_64 Community-Testing r8168-lts 8.044.02-3 A kernel module for Realtek 8168 network cards for linux-lts
x86_64 Community-Testing bumblebee 3.2.1-15 NVIDIA Optimus support for Linux through VirtualGL
x86_64 Community-Testing primus 20151110-7 Faster OpenGL offloading for Bumblebee
x86_64 Community-Testing stlink 1.3.1-1 Firmware programmer for STM32 STLINK v1/v2 protocol
x86_64 Community-Testing virtualbox-guest-modules-arch 5.1.14-9 Virtualbox guest kernel modules for Arch Kernel
x86_64 Community-Testing virtualbox-host-modules-arch 5.1.14-9 Virtualbox host kernel modules for Arch Kernel
x86_64 Community-Testing libmatio 1.5.10-1 C library with a fortran 90/95 module interface for reading/writing MATLAB MAT-files
x86_64 Multilib-Testing lib32-vulkan-intel 17.0.0-3 Intel's Vulkan mesa driver (32-bit)
x86_64 Multilib-Testing lib32-nvidia-utils 378.13-2 NVIDIA drivers utilities (32-bit)
x86_64 Multilib-Testing lib32-opencl-nvidia 378.13-2 OpenCL implemention for NVIDIA (32-bit)
x86_64 Multilib-Testing lib32-libglvnd 0.2.999+g4ba53457-1 The GL Vendor-Neutral Dispatch library
x86_64 Multilib-Testing lib32-mesa-vdpau 17.0.0-3 Mesa VDPAU drivers (32-bit)
x86_64 Multilib-Testing lib32-vulkan-radeon 17.0.0-3 Radeon's Vulkan mesa driver (32-bit)
x86_64 Multilib-Testing lib32-mesa 17.0.0-3 an open-source implementation of the OpenGL specification (32-bit)
AUR
linux-libre-grsec-xen 1:4.9.13_gnu.r201702270729-1
linux-libre-grsec-xen-headers 1:4.9.13_gnu.r201702270729-1
linux-libre-grsec-xen-docs 1:4.9.13_gnu.r201702270729-1
linux-libre-grsec-knock 1:4.9.13_gnu.r201702270729-1
linux-libre-grsec-knock-headers 1:4.9.13_gnu.r201702270729-1
linux-libre-grsec-knock-docs 1:4.9.13_gnu.r201702270729-1
linux-libre-grsec 1:4.9.13_gnu.r201702270729-1
linux-libre-grsec-headers 1:4.9.13_gnu.r201702270729-1
linux-libre-grsec-docs 1:4.9.13_gnu.r201702270729-1
find-the-command 1.1.1-1
ulauncher-git 2.0.14.r0.gbdf867f-1
linux-libre-lts 4.9.13_gnu-1
linux-libre-lts-headers 4.9.13_gnu-1
linux-libre-lts-docs 4.9.13_gnu-1
yah3c 0.6.3-1
Thanks
#2021 OFFLINE   securitybreach
  • 24,208 posts
Posted 12 March 2017 - 09:24 AM
Updates for Saturday, March 11th, 2017
Any
any Testing breeze-icons 5.32.0-1 Breeze icon themes
any Testing oxygen-icons 1:5.32.0-1 The Oxygen Icon Theme
any Testing kapidox 5.32.0-1 Frameworks API Documentation Tools
any Testing oxygen-icons-svg 1:5.32.0-1 The Oxygen Icon Theme (Scalable Vector Graphics)
any Testing extra-cmake-modules 5.32.0-1 Extra modules and scripts for CMake
any Testing mkinitcpio 23-1 Modular initramfs image creation utility
any Community shorewall 5.1.2.3-1 An iptables-based firewall for Linux systems
any Community python2-stevedore 1.21.0-1 Manage dynamic plugins for Python applications
any Community shorewall6 5.1.2.3-1 An iptables-based firewall for Linux systems (with IPv6 support)
any Community shorewall-core 5.1.2.3-1 Core Shorewall libraries
any Community python-stevedore 1.21.0-1 Manage dynamic plugins for Python applications
any Community python2-jmespath 0.9.2-1 A query language for JSON
any Community python-jmespath 0.9.2-1 A query language for JSON
any Community uglify-js 2.8.12-1 Javascript parser, mangler/compressor and beautifier toolkit
any Extra python-setuptools 1:34.3.2-1 Easily download, build, install, upgrade, and uninstall Python packages
any Extra python2-setuptools 1:34.3.2-1 Easily download, build, install, upgrade, and uninstall Python packages
any Community kicad-library 4.0.6-1 Kicad component and footprint libraries
any Community kicad-library-3d 4.0.6-1 Kicad 3D render model libraries
any Extra noto-fonts-emoji 20170310-1 Google Noto emoji fonts
any Extra vulkan-html-docs 1:1.0.43-1 Vulkan html documentation
any Extra vulkan-headers 1:1.0.43-1 Vulkan header files
any Community ttf-anonymous-pro 1.003-3 A family of four fixed-width fonts designed especially with coding in mind
any Community tamsyn-font 1.11-2 A monospaced bitmap font for the console and X11
any Community dina-font 2.92-6 A monospace bitmap font, primarily aimed at programmers
any Community streamlink 0.4.0-2 CLI program that launches streams from various streaming services in a custom video player (livestreamer fork)
i686
i686 Community retroarch 1.5.0-1 Reference frontend for the libretro API
i686 Community emby-server 3.2.7-1 Bring together your videos, music, photos, and live television
i686 Community haskell-yesod-auth 1.4.17-7 Authentication for Yesod.
i686 Community haskell-mime-mail 0.4.13.1-1 Compose MIME email messages.
i686 Community haskell-hlint 1.9.41-3 Source code suggestions (docs and libraries)
i686 Community hoogle 5.0.9-23 Haskell API Search
i686 Community haskell-cmdargs 0.10.15-1 Command line argument processing
i686 Community purescript 0.10.7-11 PureScript Programming Language Compiler
i686 Community hlint 1.9.41-3 Source code suggestions
i686 Community haskell-aeson-pretty 0.8.2-7 JSON pretty-printing library and command-line tool.
i686 Community haskell-ghc-mod 5.7.0.0-13 Happy Haskell Programming (docs and libraries)
i686 Community cgrep 6.6.16-19 A context-aware grep for source codes
i686 Community ghc-mod 5.7.0.0-13 Happy Haskell Programming
i686 Community deepin-terminal 2.2.3-1 Default terminal emulation application for Deepin
i686 Community kicad 4.0.6-1 Electronic schematic and printed circuit board (PCB) design tools
i686 Community atom 1.15.0-1 A hackable text editor for the 21st Century
i686 Community kaffeine 2.0.9-1 KDE media player
i686 Community apm 1.17.0-1 Atom package manager
i686 Community haskell-texmath 0.9.3-1 Conversion between formats used to represent mathematics.
i686 Community cmatrix 1.2a-12 A curses-based scrolling 'Matrix'-like screen
i686 Extra smb4k 2.0.0-1 A KDE program that browses samba shares
i686 Extra libxslt 1.1.29+41+gdf5330d1-1 XML stylesheet transformation library
i686 Extra libmatroska 1.4.7-1 Matroska library
i686 Extra libva-intel-driver 1.7.3-2 VA-API implementation for Intel G45 and HD Graphics family
i686 Extra kexi 3.0.1-1 A visual database applications creator
i686 Extra harfbuzz-icu 1.4.5-1 OpenType text shaping engine (ICU integration)
i686 Extra harfbuzz 1.4.5-1 OpenType text shaping engine
i686 Extra kreport 3.0.1-1 A framework for creation and generation of reports in multiple formats
i686 Extra kproperty 3.0.1-1 A property editing framework with editor widget similar to what is known from Qt Designer
i686 Extra kdb 3.0.1-1 A database connectivity and creation framework for various database vendors
i686 Extra ostree 2017.3-1 Operating system and container binary deployment and upgrades
i686 Extra gnome-online-accounts 3.22.5-1 Single sign-on framework for GNOME
i686 Extra libva 1.7.3-2 Video Acceleration (VA) API for Linux
i686 Extra mesa 17.0.1-2 an open-source implementation of the OpenGL specification
i686 Extra mesa-vdpau 17.0.1-2 Mesa VDPAU drivers
i686 Extra libglvnd 0.2.999+g4ba53457-1 The GL Vendor-Neutral Dispatch library
i686 Extra vulkan-intel 17.0.1-2 Intel's Vulkan mesa driver
i686 Extra nvidia-utils 378.13-5 NVIDIA drivers utilities
i686 Extra opencl-nvidia 378.13-5 OpenCL implemention for NVIDIA
i686 Extra libva-mesa-driver 17.0.1-2 VA-API implementation for gallium
i686 Extra opencl-mesa 17.0.1-2 OpenCL support for AMD/ATI Radeon mesa drivers
i686 Extra vulkan-radeon 17.0.1-2 Radeon's Vulkan mesa driver
i686 Extra vulkan-validation-layers 1.0.42.0-1 Vulkan Software Development Kit
i686 Extra vulkan-icd-loader 1.0.42.0-1 Vulkan Installable Client Driver (ICD) Loader
i686 Testing kwallet 5.32.0-1 Secure and unified container for user passwords
i686 Testing knotifications 5.32.0-1 Abstraction for system notifications
i686 Testing kactivities 5.32.0-1 Core components for the KDE's Activities
i686 Testing kdelibs4support 5.32.0-1 Porting aid from KDELibs4
i686 Testing kservice 5.32.0-1 Advanced plugin and service introspection
i686 Testing kdesignerplugin 5.32.0-1 Integration of Frameworks widgets in Qt Designer/Creator
i686 Testing kimageformats 5.32.0-1 Image format plugins for Qt5
i686 Testing kbookmarks 5.32.0-1 Support for bookmarks and the XBEL format
i686 Testing baloo 5.32.0-1 A framework for searching and managing metadata
i686 Testing kcmutils 5.32.0-1 Utilities for interacting with KCModules
i686 Testing kcompletion 5.32.0-1 Text completion helpers and widgets
i686 Testing threadweaver 5.32.0-1 High-level multithreading framework
i686 Testing plasma-framework 5.32.0-1 Plasma library and runtime components based upon KF5 and Qt5
i686 Testing kcoreaddons 5.32.0-1 Addons to QtCore
i686 Testing kunitconversion 5.32.0-1 Support for unit conversion
i686 Testing kitemmodels 5.32.0-1 Models for Qt Model/View system
i686 Testing attica-qt5 5.32.0-1 Qt5 library that implements the Open Collaboration Services API
i686 Testing syntax-highlighting 5.32.0-1 Syntax highlighting engine for structured text and code
i686 Testing kcrash 5.32.0-1 Support for application crash analysis and bug report from apps
i686 Testing kactivities-stats 5.32.0-1 A library for accessing the usage data collected by the activities system
i686 Testing krunner 5.32.0-1 Framework for providing different actions given a string query
i686 Testing networkmanager-qt 5.32.0-1 Qt wrapper for NetworkManager API
i686 Testing knotifyconfig 5.32.0-1 Configuration system for KNotify
i686 Testing kjsembed 5.32.0-1 Embedded JS
i686 Testing kitemviews 5.32.0-1 Widget addons for Qt Model/View
i686 Testing modemmanager-qt 5.32.0-1 Qt wrapper for ModemManager DBus API
i686 Testing kpackage 5.32.0-1 Framework that lets applications manage user installable packages of non-binary assets
i686 Testing kwayland 5.32.0-1 Qt-style Client and Server library wrapper for the Wayland libraries
i686 Testing kded 5.32.0-1 Extensible deamon for providing system level services
i686 Testing kdesu 5.32.0-1 Integration with su for elevated privileges
i686 Testing kjs 5.32.0-1 Support for JS scripting in applications
i686 Testing kjobwidgets 5.32.0-1 Widgets for tracking KJob instances
i686 Testing kdnssd 5.32.0-1 Abstraction to system DNSSD features
i686 Testing kdeclarative 5.32.0-1 Provides integration of QML and KDE Frameworks
i686 Testing kauth 5.32.0-1 Abstraction to system policy and authentication features
i686 Testing kguiaddons 5.32.0-1 Addons to QtGui
i686 Testing frameworkintegration 5.32.0-1 Framework providing components to allow applications to integrate with a KDE Workspace
i686 Testing kdewebkit 5.32.0-1 KDE Integration for QtWebKit
i686 Testing kross 5.32.0-1 Multi-language application scripting
i686 Testing kdbusaddons 5.32.0-1 Addons to QtDBus
i686 Testing kidletime 5.32.0-1 Monitoring user activity
i686 Testing bluez-qt 5.32.0-1 Qt wrapper for Bluez 5 DBus API
i686 Testing kxmlrpcclient 5.32.0-1 XML-RPC client library for KDE
i686 Testing ki18n 5.32.0-1 Advanced internationalization framework
i686 Testing kemoticons 5.32.0-1 Support for emoticons and emoticons themes
i686 Testing kglobalaccel 5.32.0-1 Add support for global workspace shortcuts
i686 Testing kinit 5.32.0-1 Process launcher to speed up launching KDE applications
i686 Testing kparts 5.32.0-1 Document centric plugin system
i686 Testing karchive 5.32.0-1 Qt 5 addon providing access to numerous types of archives
i686 Testing khtml 5.32.0-1 KHTML APIs
i686 Testing kfilemetadata 5.32.0-1 A library for extracting file metadata
i686 Testing kcodecs 5.32.0-1 Provide a collection of methods to manipulate strings using various encodings
i686 Testing knewstuff 5.32.0-1 Support for downloading application assets from the network
i686 Testing solid 5.32.0-1 Hardware integration and detection
i686 Testing kwidgetsaddons 5.32.0-1 Addons to QtWidgets
i686 Testing kplotting 5.32.0-1 Lightweight plotting framework
i686 Testing kpeople 5.32.0-1 A library that provides access to all contacts and the people who hold them
i686 Testing kmediaplayer 5.32.0-1 Plugin interface for media player features
i686 Testing kxmlgui 5.32.0-1 User configurable main windows
i686 Testing sonnet 5.32.0-1 Spelling framework for Qt5
i686 Testing kiconthemes 5.32.0-1 Support for icon themes
i686 Testing ktextwidgets 5.32.0-1 Advanced text editing widgets
i686 Testing kwindowsystem 5.32.0-1 Access to the windowing system
i686 Testing ktexteditor 5.32.0-1 Advanced embeddable text editor
i686 Testing prison 5.32.0-1 A barcode API to produce QRCode barcodes and DataMatrix barcodes
i686 Testing kconfig 5.32.0-1 Configuration system
i686 Testing kconfigwidgets 5.32.0-1 Widgets for KConfig
i686 Testing kpty 5.32.0-1 Pty abstraction
i686 Testing kdoctools 5.32.0-1 Documentation generation from docbook
i686 Testing gpgme 1.8.0-2 A C wrapper library for GnuPG
i686 Testing qgpgme 1.8.0-2 Qt bindings for GPGme
i686 Testing systemd 233-1 system and service manager
i686 Testing libsystemd 233-1 systemd client libraries
i686 Testing systemd-sysvcompat 233-1 sysvinit compat for systemd
i686 Testing linux-zen 4.10.1-2 The Linux-zen kernel and modules
i686 Testing linux-zen-headers 4.10.1-2 Header files and scripts for building modules for Linux-zen kernel
i686 Testing linux-zen-docs 4.10.1-2 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
x86_64
x86_64 Core flex 2.6.3-2 A tool for generating text-scanning programs
x86_64 Extra libqalculate 0.9.11-1 Multi-purpose desktop calculator
x86_64 Extra step 16.12.3-2 Interactive Physical Simulator
x86_64 Extra cantor 16.12.3-2 KDE Frontend to Mathematical Software
x86_64 Extra drkonqi 5.9.3-2 KDE crash handler
x86_64 Extra qalculate-gtk 0.9.11-1 GNOME frontend for libqalculate
x86_64 Extra maxima 5.38.1-4 A sophisticated computer algebra system
x86_64 Extra plasma-workspace 5.9.3-2 KDE Plasma Workspace
x86_64 Extra kuiserver 5.9.3-2 KDE Progress Info UI server
x86_64 Extra plasma-wayland-session 5.9.3-2 Plasma Wayland session
x86_64 Extra sbcl 1.3.15-1 Steel Bank Common Lisp
x86_64 Community python-selenium 3.3.0-1 Python binding for Selenium Remote Control
x86_64 Community python2-selenium 3.3.0-1 Python binding for Selenium Remote Control
x86_64 Community haskell-pandoc-crossref 0.2.5.0-7 Pandoc filter for cross-references (docs and libraries)
x86_64 Community pandoc-crossref 0.2.5.0-7 Pandoc filter for cross-references
x86_64 Community haskell-hakyll 4.9.5.1-19 A static website compiler library
x86_64 Community haskell-juicypixels 3.2.8.1-1 Picture loading/serialization (in png, jpeg, bitmap, gif, tga, tiff and radiance)
x86_64 Community pandoc 1.19.2.1-21 Conversion between markup formats
x86_64 Community haskell-pandoc-citeproc 0.10.4.1-12 Supports using pandoc with citeproc (docs and libraries)
x86_64 Community haskell-pandoc 1.19.2.1-21 Conversion between markup formats (docs and libraries)
x86_64 Community pandoc-citeproc 0.10.4.1-12 Supports using pandoc with citeproc
x86_64 Community kphotoalbum 5.2-1 KDE Photo Album, picture collection manager
x86_64 Community wings3d 2.1.5-1 3D modeling program
x86_64 Community ppsspp-qt 1.3-2 A PSP emulator written in C++
x86_64 Community ppsspp 1.3-2 A PSP emulator written in C++
x86_64 Community retroarch 1.5.0-1 Reference frontend for the libretro API
x86_64 Community emby-server 3.2.7-1 Bring together your videos, music, photos, and live television
x86_64 Community kicad 4.0.6-1 Electronic schematic and printed circuit board (PCB) design tools
x86_64 Community atom 1.15.0-1 A hackable text editor for the 21st Century
x86_64 Community kaffeine 2.0.9-1 KDE media player
x86_64 Community apm 1.17.0-1 Atom package manager
x86_64 Community primus 20151110-7 Faster OpenGL offloading for Bumblebee
x86_64 Community bumblebee 3.2.1-15 NVIDIA Optimus support for Linux through VirtualGL
x86_64 Community haskell-texmath 0.9.3-1 Conversion between formats used to represent mathematics.
x86_64 Community cmatrix 1.2a-12 A curses-based scrolling 'Matrix'-like screen
x86_64 Community haskell-yesod-auth 1.4.17-7 Authentication for Yesod.
x86_64 Community haskell-mime-mail 0.4.13.1-1 Compose MIME email messages.
x86_64 Community haskell-hlint 1.9.41-3 Source code suggestions (docs and libraries)
x86_64 Community hoogle 5.0.9-23 Haskell API Search
x86_64 Community haskell-cmdargs 0.10.15-1 Command line argument processing
x86_64 Community purescript 0.10.7-11 PureScript Programming Language Compiler
x86_64 Community hlint 1.9.41-3 Source code suggestions
x86_64 Community haskell-aeson-pretty 0.8.2-7 JSON pretty-printing library and command-line tool.
x86_64 Community haskell-ghc-mod 5.7.0.0-13 Happy Haskell Programming (docs and libraries)
x86_64 Community cgrep 6.6.16-19 A context-aware grep for source codes
x86_64 Community ghc-mod 5.7.0.0-13 Happy Haskell Programming
x86_64 Community deepin-terminal 2.2.3-1 Default terminal emulation application for Deepin
x86_64 Extra imagemagick 6.9.8.0-1 An image viewing/manipulation program
x86_64 Extra imagemagick-doc 6.9.8.0-1 The ImageMagick documentation (utilities manuals and libraries API)
x86_64 Extra smb4k 2.0.0-1 A KDE program that browses samba shares
x86_64 Extra libxslt 1.1.29+41+gdf5330d1-1 XML stylesheet transformation library
x86_64 Extra libmatroska 1.4.7-1 Matroska library
x86_64 Extra libva-intel-driver 1.7.3-2 VA-API implementation for Intel G45 and HD Graphics family
x86_64 Extra kexi 3.0.1-1 A visual database applications creator
x86_64 Extra harfbuzz-icu 1.4.5-1 OpenType text shaping engine (ICU integration)
x86_64 Extra harfbuzz 1.4.5-1 OpenType text shaping engine
x86_64 Extra kreport 3.0.1-1 A framework for creation and generation of reports in multiple formats
x86_64 Extra kproperty 3.0.1-1 A property editing framework with editor widget similar to what is known from Qt Designer
x86_64 Extra kdb 3.0.1-1 A database connectivity and creation framework for various database vendors
x86_64 Extra ostree 2017.3-1 Operating system and container binary deployment and upgrades
x86_64 Extra gnome-online-accounts 3.22.5-1 Single sign-on framework for GNOME
x86_64 Extra libva 1.7.3-2 Video Acceleration (VA) API for Linux
x86_64 Extra mesa 17.0.1-2 an open-source implementation of the OpenGL specification
x86_64 Extra mesa-vdpau 17.0.1-2 Mesa VDPAU drivers
x86_64 Extra libglvnd 0.2.999+g4ba53457-1 The GL Vendor-Neutral Dispatch library
x86_64 Extra vulkan-intel 17.0.1-2 Intel's Vulkan mesa driver
x86_64 Extra nvidia-utils 378.13-5 NVIDIA drivers utilities
x86_64 Extra opencl-nvidia 378.13-5 OpenCL implemention for NVIDIA
x86_64 Extra libva-mesa-driver 17.0.1-2 VA-API implementation for gallium
x86_64 Extra opencl-mesa 17.0.1-2 OpenCL support for AMD/ATI Radeon mesa drivers
x86_64 Extra vulkan-radeon 17.0.1-2 Radeon's Vulkan mesa driver
x86_64 Extra vulkan-validation-layers 1.0.42.0-1 Vulkan Software Development Kit
x86_64 Extra vulkan-icd-loader 1.0.42.0-1 Vulkan Installable Client Driver (ICD) Loader
x86_64 Multilib lib32-sqlite 3.17.0-1 A C library that implements an SQL database engine (32-bit)
x86_64 Multilib lib32-libtasn1 4.10-1 The ASN.1 library used in GNUTLS (32 bit)
x86_64 Multilib lib32-e2fsprogs 1.43.4-1 Ext2 filesystem libraries (32-bit)
x86_64 Multilib lib32-dbus 1.10.16-1 Freedesktop.org message bus system (32-bit)
x86_64 Multilib lib32-libepoxy 1.4.1-1 Library handling OpenGL function pointer management
x86_64 Multilib lib32-libgudev 231-1 GObject bindings for libudev
x86_64 Multilib lib32-wayland 1.13.0-1 A computer display server protocol
x86_64 Multilib lib32-libnm-glib 1.6.2-1 NetworkManager client library (legacy)
x86_64 Multilib lib32-libnm 1.6.2-1 NetworkManager client library
x86_64 Multilib lib32-libnewt 0.52.19-2 Not Erik's Windowing Toolkit - text mode windowing with slang
x86_64 Multilib lib32-opencl-nvidia 378.13-2 OpenCL implemention for NVIDIA (32-bit)
x86_64 Multilib lib32-nvidia-utils 378.13-2 NVIDIA drivers utilities (32-bit)
x86_64 Multilib lib32-vulkan-radeon 17.0.1-2 Radeon's Vulkan mesa driver (32-bit)
x86_64 Multilib lib32-mesa 17.0.1-2 an open-source implementation of the OpenGL specification (32-bit)
x86_64 Multilib lib32-mesa-vdpau 17.0.1-2 Mesa VDPAU drivers (32-bit)
x86_64 Multilib lib32-libglvnd 0.2.999+g4ba53457-1 The GL Vendor-Neutral Dispatch library
x86_64 Multilib lib32-vulkan-intel 17.0.1-2 Intel's Vulkan mesa driver (32-bit)
x86_64 Multilib lib32-vulkan-validation-layers 1.0.42.0-1 Vulkan Software Development Kit
x86_64 Multilib lib32-vulkan-icd-loader 1.0.42.0-1 Vulkan Installable Client Driver (ICD) Loader
x86_64 Testing libzip 1.2.0-1 A C library for reading, creating, and modifying zip archives
x86_64 Testing knetattach 5.9.3-3 Wizard which makes it easier to integrate network resources with the Plasma Desktop
x86_64 Testing plasma-desktop 5.9.3-3 KDE Plasma Desktop
x86_64 Testing kio 5.32.0-2 Resource and network access abstraction
x86_64 Testing kwallet 5.32.0-1 Secure and unified container for user passwords
x86_64 Testing knotifications 5.32.0-1 Abstraction for system notifications
x86_64 Testing kactivities 5.32.0-1 Core components for the KDE's Activities
x86_64 Testing kdelibs4support 5.32.0-1 Porting aid from KDELibs4
x86_64 Testing kservice 5.32.0-1 Advanced plugin and service introspection
x86_64 Testing kdesignerplugin 5.32.0-1 Integration of Frameworks widgets in Qt Designer/Creator
x86_64 Testing kimageformats 5.32.0-1 Image format plugins for Qt5
x86_64 Testing kbookmarks 5.32.0-1 Support for bookmarks and the XBEL format
x86_64 Testing baloo 5.32.0-1 A framework for searching and managing metadata
x86_64 Testing kcmutils 5.32.0-1 Utilities for interacting with KCModules
x86_64 Testing kcompletion 5.32.0-1 Text completion helpers and widgets
x86_64 Testing threadweaver 5.32.0-1 High-level multithreading framework
x86_64 Testing plasma-framework 5.32.0-1 Plasma library and runtime components based upon KF5 and Qt5
x86_64 Testing kcoreaddons 5.32.0-1 Addons to QtCore
x86_64 Testing kunitconversion 5.32.0-1 Support for unit conversion
x86_64 Testing kitemmodels 5.32.0-1 Models for Qt Model/View system
x86_64 Testing attica-qt5 5.32.0-1 Qt5 library that implements the Open Collaboration Services API
x86_64 Testing syntax-highlighting 5.32.0-1 Syntax highlighting engine for structured text and code
x86_64 Testing kcrash 5.32.0-1 Support for application crash analysis and bug report from apps
x86_64 Testing kactivities-stats 5.32.0-1 A library for accessing the usage data collected by the activities system
x86_64 Testing krunner 5.32.0-1 Framework for providing different actions given a string query
x86_64 Testing networkmanager-qt 5.32.0-1 Qt wrapper for NetworkManager API
x86_64 Testing knotifyconfig 5.32.0-1 Configuration system for KNotify
x86_64 Testing kjsembed 5.32.0-1 Embedded JS
x86_64 Testing kitemviews 5.32.0-1 Widget addons for Qt Model/View
x86_64 Testing modemmanager-qt 5.32.0-1 Qt wrapper for ModemManager DBus API
x86_64 Testing kpackage 5.32.0-1 Framework that lets applications manage user installable packages of non-binary assets
x86_64 Testing kwayland 5.32.0-1 Qt-style Client and Server library wrapper for the Wayland libraries
x86_64 Testing kded 5.32.0-1 Extensible deamon for providing system level services
x86_64 Testing kdesu 5.32.0-1 Integration with su for elevated privileges
x86_64 Testing kjs 5.32.0-1 Support for JS scripting in applications
x86_64 Testing kjobwidgets 5.32.0-1 Widgets for tracking KJob instances
x86_64 Testing kdnssd 5.32.0-1 Abstraction to system DNSSD features
x86_64 Testing kdeclarative 5.32.0-1 Provides integration of QML and KDE Frameworks
x86_64 Testing kauth 5.32.0-1 Abstraction to system policy and authentication features
x86_64 Testing kguiaddons 5.32.0-1 Addons to QtGui
x86_64 Testing frameworkintegration 5.32.0-1 Framework providing components to allow applications to integrate with a KDE Workspace
x86_64 Testing kdewebkit 5.32.0-1 KDE Integration for QtWebKit
x86_64 Testing kross 5.32.0-1 Multi-language application scripting
x86_64 Testing kdbusaddons 5.32.0-1 Addons to QtDBus
x86_64 Testing kidletime 5.32.0-1 Monitoring user activity
x86_64 Testing bluez-qt 5.32.0-1 Qt wrapper for Bluez 5 DBus API
x86_64 Testing kxmlrpcclient 5.32.0-1 XML-RPC client library for KDE
x86_64 Testing ki18n 5.32.0-1 Advanced internationalization framework
x86_64 Testing kemoticons 5.32.0-1 Support for emoticons and emoticons themes
x86_64 Testing kglobalaccel 5.32.0-1 Add support for global workspace shortcuts
x86_64 Testing kinit 5.32.0-1 Process launcher to speed up launching KDE applications
x86_64 Testing kparts 5.32.0-1 Document centric plugin system
x86_64 Testing karchive 5.32.0-1 Qt 5 addon providing access to numerous types of archives
x86_64 Testing khtml 5.32.0-1 KHTML APIs
x86_64 Testing kfilemetadata 5.32.0-1 A library for extracting file metadata
x86_64 Testing kcodecs 5.32.0-1 Provide a collection of methods to manipulate strings using various encodings
x86_64 Testing knewstuff 5.32.0-1 Support for downloading application assets from the network
x86_64 Testing solid 5.32.0-1 Hardware integration and detection
x86_64 Testing kwidgetsaddons 5.32.0-1 Addons to QtWidgets
x86_64 Testing kplotting 5.32.0-1 Lightweight plotting framework
x86_64 Testing kpeople 5.32.0-1 A library that provides access to all contacts and the people who hold them
x86_64 Testing kmediaplayer 5.32.0-1 Plugin interface for media player features
x86_64 Testing kxmlgui 5.32.0-1 User configurable main windows
x86_64 Testing sonnet 5.32.0-1 Spelling framework for Qt5
x86_64 Testing kiconthemes 5.32.0-1 Support for icon themes
x86_64 Testing ktextwidgets 5.32.0-1 Advanced text editing widgets
x86_64 Testing kwindowsystem 5.32.0-1 Access to the windowing system
x86_64 Testing ktexteditor 5.32.0-1 Advanced embeddable text editor
x86_64 Testing prison 5.32.0-1 A barcode API to produce QRCode barcodes and DataMatrix barcodes
x86_64 Testing kconfig 5.32.0-1 Configuration system
x86_64 Testing kconfigwidgets 5.32.0-1 Widgets for KConfig
x86_64 Testing kpty 5.32.0-1 Pty abstraction
x86_64 Testing kdoctools 5.32.0-1 Documentation generation from docbook
x86_64 Testing gpgme 1.8.0-2 A C wrapper library for GnuPG
x86_64 Testing qgpgme 1.8.0-2 Qt bindings for GPGme
x86_64 Testing systemd 233-1 system and service manager
x86_64 Testing libsystemd 233-1 systemd client libraries
x86_64 Testing systemd-sysvcompat 233-1 sysvinit compat for systemd
x86_64 Testing linux-zen 4.10.1-2 The Linux-zen kernel and modules
x86_64 Testing linux-zen-headers 4.10.1-2 Header files and scripts for building modules for Linux-zen kernel
x86_64 Testing linux-zen-docs 4.10.1-2 Kernel hackers manual - HTML documentation that comes with the Linux-zen kernel
AUR
poseidon-browser-git r115.4126a9e-1
urh 1.6.0-1
qt5.6-webkit 5.6.2-1
qt5.6 5.6.2-3
python2-pyteomics 3.4.1-1
python-pyteomics 3.4.1-1
imagemagick-full 7.0.5.2-1
imagemagick-full-doc 7.0.5.2-1
pingo 0.71e-1
infornography-git 0.4.r5.g794cd65-1
firefox-gtk2 52.0-2
linux-ck 4.10.2-1
linux-ck-headers 4.10.2-1
linux-bfq 4.10.2-1
linux-bfq-headers 4.10.2-1
Thanks
Posted ImagePosted Image
Configs/PGP Key/comhack π
#2022 OFFLINE   securitybreach
  • 24,208 posts
Posted 16 April 2017 - 02:22 PM
Updates for Saturday, April 15th, 2017
Any
any Community yarn 0.23.2-1 Fast, reliable, and secure dependency management
any Community python-autobahn 0.18.2-1 Real-time framework for Web, Mobile & Internet of Things
any Community python2-autobahn 0.18.2-1 Real-time framework for Web, Mobile & Internet of Things
any Community jmol 14.13.1-1 a Java 3D viewer for chemical structures
any Community youtube-dl 2017.04.15-1 A small command-line program to download videos from YouTube.com and a few more sites
any Extra texlive-core 2016.42515-3 TeX Live core distribution
i686
i686 Core ca-certificates-mozilla 3.30.1-1 Mozilla's set of trusted CA certificates
i686 Core nss 3.30.1-1 Network Security Services
i686 Community ccid 1.4.26-1 A generic USB Chip/Smart Card Interface Devices driver
i686 Community dmd 1:2.074.0-1 The D programming language reference compiler
i686 Community libphobos 1:2.074.0-1 The Phobos standard library for D programming language.
i686 Community libphobos-devel 1:2.074.0-1 The Phobos standard library for D programming language. Modules and static library.
i686 Community dub 1.2.2-1 Developer package manager for D programming language
i686 Community libmatekbd 1.18.2-1 MATE keyboard library
i686 Community yaml-cpp 0.5.3-3 YAML parser and emitter in C++, written around the YAML 1.2 spec
i686 Community python2-cysignals 1.6.2-1 Interrupt and signal handling for Cython
i686 Community python-cysignals 1.6.2-1 Interrupt and signal handling for Cython
i686 Community haskell-hlint 1.9.41-9 Source code suggestions (docs and libraries)
i686 Community haskell-src-meta 0.7.0.1-10 Parse source to template-haskell abstract syntax
i686 Community stylish-haskell 0.7.1.0-19 Haskell code prettifier
i686 Community haskell-ghc-mod 5.7.0.0-24 Happy Haskell Programming (docs and libraries)
i686 Community hoogle 5.0.9-45 Haskell API Search
i686 Community hindent 5.2.2-23 Extensible Haskell pretty printer
i686 Community haskell-src-exts 1.18.2-5 Manipulating Haskell source: abstract syntax, lexer, parser, and pretty-printer
i686 Community ghc-mod 5.7.0.0-24 Happy Haskell Programming
i686 Community hlint 1.9.41-9 Source code suggestions
i686 Community haskell-cpphs 1.20.5-1 A liberalised re-implementation of cpp, the C pre-processor.
i686 Community haskell-interpolatedstring-perl6 1.0.0-13 QuasiQuoter for Perl6-style multi-line interpolated strings
i686 Community calibre 2.83.0-1 Ebook management application
i686 Community haskell-yesod-default 1.2.0-129 Default config and main functions for your yesod application (deprecated)
i686 Community haskell-yesod-auth 1.4.17-28 Authentication for Yesod.
i686 Community haskell-warp 3.2.11.2-1 A fast, light-weight web server for WAI applications.
i686 Community haskell-warp-tls 3.2.3-17 HTTP over TLS support for Warp via the TLS package
i686 Community haskell-wai-app-static 3.1.6.1-48 WAI application for static serving
i686 Community haskell-yesod-persistent 1.4.2-19 Some helpers for using Persistent from Yesod.
i686 Community haskell-hakyll 4.9.5.1-42 A static website compiler library
i686 Community haskell-yesod 1.4.5-22 Creation of type-safe, RESTful web applications.
i686 Community haskell-yesod-static 1.5.2-20 Static file serving subsite for Yesod Web Framework.
i686 Community haskell-yesod-form 1.4.11-24 Form handling support for Yesod Web Framework
i686 Community haskell-yesod-core 1.4.33-5 Creation of type-safe, RESTful web applications.
i686 Community purescript 0.11.1-12 PureScript Programming Language Compiler
i686 Community git-annex 6.20170321-20 Manage files with git, without checking their contents into git
i686 Community haskell-dbus 0.10.13-1 A client library for the D-Bus IPC system
i686 Community haskell-fdo-notify 0.3.1-11 Desktop Notifications client
i686 Extra libsndfile 1.0.28-1 A C library for reading and writing files containing sampled sound
i686 Extra opencore-amr 0.1.5-1 Open source implementation of the Adaptive Multi Rate (AMR) speech codec
i686 Extra libssh-docs 0.7.5-1 Documentation for libssh
i686 Extra libssh 0.7.5-1 Library for accessing ssh client services through C libraries
i686 Extra konversation 1.7-1 A user-friendly and fully-featured IRC client
i686 Testing bc 1.07.1-1 An arbitrary precision calculator language
i686 Testing python-pyqt5 5.8.2-1 A set of Python 3.x bindings for the Qt5 toolkit
i686 Testing python2-pyqt5 5.8.2-1 A set of Python 2.x bindings for the Qt5 toolkit
i686 Testing pyqt5-common 5.8.2-1 Common PyQt files shared between python-pyqt5 and python2-pyqt5
i686 Testing python-sip 4.19.2-1 Python 3.x SIP bindings for C and C++ libraries
i686 Testing python2-sip 4.19.2-1 Python 2.x SIP bindings for C and C++ libraries
i686 Testing sip 4.19.2-1 A tool that makes it easy to create Python bindings for C and C++ libraries
i686 Community-Testing calibre 2.83.0-2 Ebook management application
i686 Community-Testing nzbget 18.1-1 Download from Usenet using .nzb files
x86_64
x86_64 Core ca-certificates-mozilla 3.30.1-1 Mozilla's set of trusted CA certificates
x86_64 Core nss 3.30.1-1 Network Security Services
x86_64 Community ccid 1.4.26-1 A generic USB Chip/Smart Card Interface Devices driver
x86_64 Extra libsndfile 1.0.28-1 A C library for reading and writing files containing sampled sound
x86_64 Extra opencore-amr 0.1.5-1 Open source implementation of the Adaptive Multi Rate (AMR) speech codec
x86_64 Extra libssh-docs 0.7.5-1 Documentation for libssh
x86_64 Extra libssh 0.7.5-1 Library for accessing ssh client services through C libraries
x86_64 Extra konversation 1.7-1 A user-friendly and fully-featured IRC client
x86_64 Community dmd 1:2.074.0-1 The D programming language reference compiler
x86_64 Community libphobos 1:2.074.0-1 The Phobos standard library for D programming language.
x86_64 Community libphobos-devel 1:2.074.0-1 The Phobos standard library for D programming language. Modules and static library.
x86_64 Community dub 1.2.2-1 Developer package manager for D programming language
x86_64 Community libmatekbd 1.18.2-1 MATE keyboard library
x86_64 Community yaml-cpp 0.5.3-3 YAML parser and emitter in C++, written around the YAML 1.2 spec
x86_64 Community python2-cysignals 1.6.2-1 Interrupt and signal handling for Cython
x86_64 Community python-cysignals 1.6.2-1 Interrupt and signal handling for Cython
x86_64 Community haskell-hlint 1.9.41-9 Source code suggestions (docs and libraries)
x86_64 Community haskell-src-meta 0.7.0.1-10 Parse source to template-haskell abstract syntax
x86_64 Community stylish-haskell 0.7.1.0-19 Haskell code prettifier
x86_64 Community haskell-ghc-mod 5.7.0.0-24 Happy Haskell Programming (docs and libraries)
x86_64 Community hoogle 5.0.9-45 Haskell API Search
x86_64 Community hindent 5.2.2-23 Extensible Haskell pretty printer
x86_64 Community haskell-src-exts 1.18.2-5 Manipulating Haskell source: abstract syntax, lexer, parser, and pretty-printer
x86_64 Community ghc-mod 5.7.0.0-24 Happy Haskell Programming
x86_64 Community hlint 1.9.41-9 Source code suggestions
x86_64 Community haskell-cpphs 1.20.5-1 A liberalised re-implementation of cpp, the C pre-processor.
x86_64 Community haskell-interpolatedstring-perl6 1.0.0-13 QuasiQuoter for Perl6-style multi-line interpolated strings
x86_64 Community calibre 2.83.0-1 Ebook management application
x86_64 Community haskell-yesod-default 1.2.0-129 Default config and main functions for your yesod application (deprecated)
x86_64 Community haskell-yesod-auth 1.4.17-28 Authentication for Yesod.
x86_64 Community haskell-warp 3.2.11.2-1 A fast, light-weight web server for WAI applications.
x86_64 Community haskell-warp-tls 3.2.3-17 HTTP over TLS support for Warp via the TLS package
x86_64 Community haskell-wai-app-static 3.1.6.1-48 WAI application for static serving
x86_64 Community haskell-yesod-persistent 1.4.2-19 Some helpers for using Persistent from Yesod.
x86_64 Community haskell-hakyll 4.9.5.1-42 A static website compiler library
x86_64 Community haskell-yesod 1.4.5-22 Creation of type-safe, RESTful web applications.
x86_64 Community haskell-yesod-static 1.5.2-20 Static file serving subsite for Yesod Web Framework.
x86_64 Community haskell-yesod-form 1.4.11-24 Form handling support for Yesod Web Framework
x86_64 Community haskell-yesod-core 1.4.33-5 Creation of type-safe, RESTful web applications.
x86_64 Community purescript 0.11.1-12 PureScript Programming Language Compiler
x86_64 Community git-annex 6.20170321-20 Manage files with git, without checking their contents into git
x86_64 Community haskell-dbus 0.10.13-1 A client library for the D-Bus IPC system
x86_64 Community haskell-fdo-notify 0.3.1-11 Desktop Notifications client
x86_64 Testing bc 1.07.1-1 An arbitrary precision calculator language
x86_64 Testing python-pyqt5 5.8.2-1 A set of Python 3.x bindings for the Qt5 toolkit
x86_64 Testing python2-pyqt5 5.8.2-1 A set of Python 2.x bindings for the Qt5 toolkit
x86_64 Testing pyqt5-common 5.8.2-1 Common PyQt files shared between python-pyqt5 and python2-pyqt5
x86_64 Testing python-sip 4.19.2-1 Python 3.x SIP bindings for C and C++ libraries
x86_64 Testing python2-sip 4.19.2-1 Python 2.x SIP bindings for C and C++ libraries
x86_64 Testing sip 4.19.2-1 A tool that makes it easy to create Python bindings for C and C++ libraries
x86_64 Community-Testing calibre 2.83.0-2 Ebook management application
x86_64 Community-Testing nzbget 18.1-1 Download from Usenet using .nzb files
AUR
soltrack 2.1-1
xfce4-session-devel 4.13.0-1
xfwm4-devel 4.13.0-1
subsonic 6.0-2
godot-bin 2.1.3-1
firefox-ublock-origin 1.12.1-1
openbazaard-git v0.5.4.r33.gb37549f-1
performer-git 1.0.r352.0ec3d4d-1.2
openbazaar-git v2.0.2.r96.gfde26a29-1
urh 1.6.2.3-1
mystudio 3.1.5-1
android-udev-git 20170416.r0.g18e609e-1
perl-statistics-descriptive 3.0612-1
g4l 0.53-1
you-get-git 0.4.715.20170416.1567-1
THanks
#2023 OFFLINE   securitybreach
  • 24,208 posts
Posted 09 May 2017 - 08:27 PM
Updates for Monday, May 8th, 2017
Any
any Community puppet 4.10.0-1 Server automation framework and application
any Community yubikey-manager 0.3.3-1 Python library and command line tool for configuring a YubiKey
any Community youtube-dl 2017.05.07-1 A small command-line program to download videos from YouTube.com and a few more sites
any Community python2-blessed 1.14.2-1 A thin, practical wrapper around terminal styling, screen positioning, and keyboard input
any Community python-arrow 0.10.0-1 Better dates and times for Python
any Community python2-django-q 0.8.0-1 A multiprocessing distributed task queue for Django
any Community python-blessed 1.14.2-1 A thin, practical wrapper around terminal styling, screen positioning, and keyboard input
any Community python-django-q 0.8.0-1 A multiprocessing distributed task queue for Django
any Community python2-arrow 0.10.0-1 Better dates and times for Python
any Community python-django-picklefield 0.3.2-1 A pickled object field for Django
any Community python2-django-picklefield 0.3.2-1 A pickled object field for Django
any Community kde-development-environment-meta 20170224-1 Metapackage to install a full KDE development environment
any Community mate-icon-theme-faenza 1.18.1-1 Faenza icon theme for MATE
any Community jenkins 2.59-1 Extendable continuous integration server (latest)
any Community uglify-js 3.0.1-1 Javascript parser, mangler/compressor and beautifier toolkit
i686
i686 Community sway 0.13.0-1 i3 compatible window manager for Wayland
i686 Community wlc 0.0.9-1 Wayland Compositor Library
i686 Community uboot-tools 2017.05-1 U-Boot bootloader utility tools
i686 Community vagrant-substrate 605.0566498-1 Substrate layer for Vagrant
i686 Community facter 3.6.3-1 Collect and display system facts
i686 Community vagrant 1.9.4-1 Build and distribute virtualized development environments
i686 Community eom 1.18.2-1 An image viewing and cataloging program for MATE
i686 Community owncloud-client 2.3.2-1 ownCloud client based on mirall
i686 Community nrpe 3.1.0-2 Nagios Remote Plugin Executor
i686 Community mpv 1:0.25.0-3 a free, open source, and cross-platform media player
i686 Community yaz 5.21.1-1 A toolkit supporting the development of Z39.50/SRW/SRU clients and servers
i686 Community pantheon-terminal 0.4.1-1 The Pantheon Terminal Emulator
i686 Community racket-minimal 6.9-1 Minimal Racket installation, without DrRacket.
i686 Community racket 6.9-1 A full-spectrum language with DrRacket IDE. Formerly known as PLT Scheme.
i686 Community racket-docs 6.9-1 Docs for the full-spectrum language formerly known as PLT Scheme.
i686 Community granite 0.4.1-1 Library that extends Gtk+
i686 Community qtox 1.10.0-1 Powerful Tox client written in C++/Qt that follows the Tox design guidelines
i686 Community smtube 17.5.0-1 A small youtube browser
i686 Community mate-terminal 1.18.1-1 The MATE Terminal Emulator
i686 Community pluma 1.18.2-1 A powerful text editor for MATE
i686 Community mate-utils 1.18.2-1 Common MATE utilities for viewing disk usage, logs and fonts, taking screenshots, managing dictionaries and searching files
i686 Community haskell-yesod-auth 1.4.17-42 Authentication for Yesod.
i686 Community haskell-persistent-sqlite 2.6.2-19 Backend for the persistent library using sqlite3
i686 Community haskell-yesod 1.4.5-36 Creation of type-safe, RESTful web applications.
i686 Community haskell-yesod-form 1.4.11-38 Form handling support for Yesod Web Framework
i686 Community haskell-http-api-data 0.3.7-1 Converting to/from HTTP API data like URL pieces, headers and query parameters.
i686 Community haskell-yesod-persistent 1.4.2-33 Some helpers for using Persistent from Yesod.
i686 Community haskell-persistent 2.6.1-20 Type-safe, multi-backend data serialization
i686 Community haskell-esqueleto 2.5.1-29 Type-safe EDSL for SQL queries on persistent backends.
i686 Community haskell-persistent-template 2.5.2-21 Type-safe, non-relational, multi-backend persistence
i686 Extra libetpan 1.8-1 A portable middleware for email access
x86_64
x86_64 Community sway 0.13.0-1 i3 compatible window manager for Wayland
x86_64 Community wlc 0.0.9-1 Wayland Compositor Library
x86_64 Community uboot-tools 2017.05-1 U-Boot bootloader utility tools
x86_64 Community vagrant-substrate 605.0566498-1 Substrate layer for Vagrant
x86_64 Community facter 3.6.3-1 Collect and display system facts
x86_64 Community vagrant 1.9.4-1 Build and distribute virtualized development environments
x86_64 Community eom 1.18.2-1 An image viewing and cataloging program for MATE
x86_64 Community owncloud-client 2.3.2-1 ownCloud client based on mirall
x86_64 Community nrpe 3.1.0-2 Nagios Remote Plugin Executor
x86_64 Community mpv 1:0.25.0-3 a free, open source, and cross-platform media player
x86_64 Community yaz 5.21.1-1 A toolkit supporting the development of Z39.50/SRW/SRU clients and servers
x86_64 Community pantheon-terminal 0.4.1-1 The Pantheon Terminal Emulator
x86_64 Community racket-minimal 6.9-1 Minimal Racket installation, without DrRacket.
x86_64 Community racket 6.9-1 A full-spectrum language with DrRacket IDE. Formerly known as PLT Scheme.
x86_64 Community racket-docs 6.9-1 Docs for the full-spectrum language formerly known as PLT Scheme.
x86_64 Community granite 0.4.1-1 Library that extends Gtk+
x86_64 Community qtox 1.10.0-1 Powerful Tox client written in C++/Qt that follows the Tox design guidelines
x86_64 Community smtube 17.5.0-1 A small youtube browser
x86_64 Community mate-terminal 1.18.1-1 The MATE Terminal Emulator
x86_64 Community pluma 1.18.2-1 A powerful text editor for MATE
x86_64 Community mate-utils 1.18.2-1 Common MATE utilities for viewing disk usage, logs and fonts, taking screenshots, managing dictionaries and searching files
x86_64 Community haskell-yesod-auth 1.4.17-42 Authentication for Yesod.
x86_64 Community haskell-persistent-sqlite 2.6.2-19 Backend for the persistent library using sqlite3
x86_64 Community haskell-yesod 1.4.5-36 Creation of type-safe, RESTful web applications.
x86_64 Community haskell-yesod-form 1.4.11-38 Form handling support for Yesod Web Framework
x86_64 Community haskell-http-api-data 0.3.7-1 Converting to/from HTTP API data like URL pieces, headers and query parameters.
x86_64 Community haskell-yesod-persistent 1.4.2-33 Some helpers for using Persistent from Yesod.
x86_64 Community haskell-persistent 2.6.1-20 Type-safe, multi-backend data serialization
x86_64 Community haskell-esqueleto 2.5.1-29 Type-safe EDSL for SQL queries on persistent backends.
x86_64 Community haskell-persistent-template 2.5.2-21 Type-safe, non-relational, multi-backend persistence
x86_64 Extra libetpan 1.8-1 A portable middleware for email access
x86_64 Multilib lib32-json-glib 1.2.8-1 JSON library built on GLib
x86_64 Multilib lib32-jansson 2.10-1 C library for encoding, decoding and manipulating JSON data
x86_64 Multilib lib32-flex 2.6.4-1 A tool for generating text-scanning programs
x86_64 Multilib lib32-colord 1.3.5-1 System daemon for managing color devices
x86_64 Multilib lib32-at-spi2-atk 2.24.0-1 A GTK+ module that bridges ATK to D-Bus at-spi
x86_64 Multilib lib32-at-spi2-core 2.24.0-1 Protocol definitions and daemon for D-Bus at-spi
x86_64 Community-Testing erlang-unixodbc 20.0rc-1 Unixodbc support for Erlang
x86_64 Community-Testing erlang 20.0rc-1 General-purpose concurrent functional programming language developed by Ericsson
AUR
vertrux-icon-theme 0.1-1
firefox-developer-de 54.0a2_20170509-1
openorienteering-mapper-git 0.7.0.RC2.r3528.8e25c8b9-1
autoupdate 3-1
linux-lts44 4.4.67-1
linux-lts44-headers 4.4.67-1
linux-lts44-docs 4.4.67-1
metabat 0.32.4-1
opensnitch-git r106.89ea71f-1
firefox-kde-opensuse 53.0.2-1
tailor 0.12.0-1
keepass-password-counter 0.1-1
sidef-git 3.01-1
sidef 3.01-1
tiddlydesktop 0.0.8-1
Thanks
#2024 OFFLINE   securitybreach
  • 24,208 posts
Posted 15 May 2017 - 06:11 PM
Updates for Monday, May 15th, 2017
Any
any Community rabbitmq 3.6.9-2 Highly reliable and performant enterprise messaging implementation of AMQP written in Erlang/OTP
any Community rebar 1:2.6.1-3 A sophisticated build-tool for Erlang projects that follows OTP principles.
any Community python-parsedatetime 2.4-1 Parse human-readable date/time strings.
any Community cordova 7.0.1-1 Cordova command line interface tool
any Community python2-parsedatetime 2.4-1 Parse human-readable date/time strings.
any Community python-augeas 0.5.0-1 Pure python bindings for augeas
any Community arc-kde 20170423-1 Arc theme for KDE Plasma 5
any Community spyder3 3.1.4-1 Scientific PYthon Development EnviRonment providing MATLAB-like features for Python 3.x series.
any Community spyder 3.1.4-1 Scientific PYthon Development EnviRonment providing MATLAB-like features for Python 2.x series.
any Community jmol 14.15.4-1 a Java 3D viewer for chemical structures
any Community python2-freezegun 0.3.9-1 Let your Python tests travel through time
any Community python-freezegun 0.3.9-1 Let your Python tests travel through time
any Community python2-funcy 1.7.4-1 A fancy and practical functional tools
any Community python-funcy 1.7.4-1 A fancy and practical functional tools
any Community python-jsbeautifier 1.6.14-1 Javascript unobfuscator and beautifier
any Community python2-jsbeautifier 1.6.14-1 Javascript unobfuscator and beautifier
any Extra libreoffice-fresh-oc 5.3.3-1 Occitan language pack for LibreOffice Fresh
any Extra libreoffice-fresh-bg 5.3.3-1 Bulgarian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-my 5.3.3-1 Burmese language pack for LibreOffice Fresh
any Extra libreoffice-fresh-nn 5.3.3-1 Norwegian Nynorsk language pack for LibreOffice Fresh
any Extra libreoffice-fresh-si 5.3.3-1 Singhalese language pack for LibreOffice Fresh
any Extra libreoffice-fresh-be 5.3.3-1 Belarusian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-bs 5.3.3-1 Bosnian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sa-IN 5.3.3-1 Sanskrit (India) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-br 5.3.3-1 Breton language pack for LibreOffice Fresh
any Extra libreoffice-fresh-eu 5.3.3-1 Basque language pack for LibreOffice Fresh
any Extra libreoffice-fresh-st 5.3.3-1 Southern Sotho language pack for LibreOffice Fresh
any Extra libreoffice-fresh-es 5.3.3-1 Spanish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sid 5.3.3-1 Sidama language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sv 5.3.3-1 Swedish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-km 5.3.3-1 Khmer (Cambodia) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-mai 5.3.3-1 Maithili language pack for LibreOffice Fresh
any Extra libreoffice-fresh-da 5.3.3-1 Danish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sl 5.3.3-1 Slovenian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-cy 5.3.3-1 Welsh language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ss 5.3.3-1 Swati language pack for LibreOffice Fresh
any Extra libreoffice-fresh-bo 5.3.3-1 Tibetan language pack for LibreOffice Fresh
any Extra libreoffice-fresh-lt 5.3.3-1 Lithuanian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sr 5.3.3-1 Serbian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-mni 5.3.3-1 Manipuri language pack for LibreOffice Fresh
any Extra libreoffice-fresh-gd 5.3.3-1 Gaelic (Scottish) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-nso 5.3.3-1 Northern Sotho language pack for LibreOffice Fresh
any Extra libreoffice-fresh-pl 5.3.3-1 Polish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-is 5.3.3-1 Icelandic language pack for LibreOffice Fresh
any Extra libreoffice-fresh-eo 5.3.3-1 Esperanto language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ne 5.3.3-1 Nepali language pack for LibreOffice Fresh
any Extra libreoffice-fresh-om 5.3.3-1 Oromo language pack for LibreOffice Fresh
any Extra libreoffice-fresh-brx 5.3.3-1 Bodo language pack for LibreOffice Fresh
any Extra libreoffice-fresh-nr 5.3.3-1 Ndebele (South) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-el 5.3.3-1 Greek language pack for LibreOffice Fresh
any Extra libreoffice-fresh-kk 5.3.3-1 Kazakh language pack for LibreOffice Fresh
any Extra libreoffice-fresh-hi 5.3.3-1 Hindi language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ko 5.3.3-1 Korean language pack for LibreOffice Fresh
any Extra libreoffice-fresh-tr 5.3.3-1 Turkish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-pt-BR 5.3.3-1 Portuguese (Brasil) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-lb 5.3.3-1 Luxembourgish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-en-ZA 5.3.3-1 English (ZA) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-as 5.3.3-1 Assamese (India) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-uk 5.3.3-1 Ukrainian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-zh-TW 5.3.3-1 Chinese (traditional) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-or 5.3.3-1 Oriya language pack for LibreOffice Fresh
any Extra libreoffice-fresh-en-GB 5.3.3-1 English (GB) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-et 5.3.3-1 Estonian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ast 5.3.3-1 Asturianu language pack for LibreOffice Fresh
any Extra libreoffice-fresh-bn 5.3.3-1 Bengali language pack for LibreOffice Fresh
any Extra libreoffice-fresh-th 5.3.3-1 Thai language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ga 5.3.3-1 Irish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-vi 5.3.3-1 Vietnamese language pack for LibreOffice Fresh
any Extra libreoffice-fresh-zh-CN 5.3.3-1 Chinese (simplified) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-zu 5.3.3-1 Zulu language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ug 5.3.3-1 Uighur language pack for LibreOffice Fresh
any Extra libreoffice-fresh-bn-IN 5.3.3-1 Bengali (India) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ru 5.3.3-1 Russian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ka 5.3.3-1 Georgian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-af 5.3.3-1 Afrikaans language pack for LibreOffice Fresh
any Extra libreoffice-fresh-hr 5.3.3-1 Croatian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-tt 5.3.3-1 Tatar language pack for LibreOffice Fresh
any Extra libreoffice-fresh-fa 5.3.3-1 Persian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-xh 5.3.3-1 Xhosa language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ro 5.3.3-1 Romanian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-kn 5.3.3-1 Kannada language pack for LibreOffice Fresh
any Extra libreoffice-fresh-mk 5.3.3-1 Macedonian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-nb 5.3.3-1 Norwegian Bokmal language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sq 5.3.3-1 Albanien language pack for LibreOffice Fresh
any Extra libreoffice-fresh-lo 5.3.3-1 Lao language pack for LibreOffice Fresh
any Extra libreoffice-fresh-it 5.3.3-1 Italian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-fi 5.3.3-1 Finnish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-te 5.3.3-1 Telugu language pack for LibreOffice Fresh
any Extra libreoffice-fresh-he 5.3.3-1 Hebrew language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sd 5.3.3-1 Sindhi language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sat 5.3.3-1 Santali language pack for LibreOffice Fresh
any Extra libreoffice-fresh-de 5.3.3-1 German language pack for LibreOffice Fresh
any Extra libreoffice-fresh-nl 5.3.3-1 Dutch language pack for LibreOffice Fresh
any Extra libreoffice-fresh-am 5.3.3-1 Amharic language pack for LibreOffice Fresh
any Extra libreoffice-fresh-dz 5.3.3-1 Dzongkha language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ca 5.3.3-1 Catalan language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sk 5.3.3-1 Slovak language pack for LibreOffice Fresh
any Extra libreoffice-fresh-tg 5.3.3-1 Tajik language pack for LibreOffice Fresh
any Extra libreoffice-fresh-fr 5.3.3-1 French language pack for LibreOffice Fresh
any Extra libreoffice-fresh-cs 5.3.3-1 Czech language pack for LibreOffice Fresh
any Extra libreoffice-fresh-kmr-Latn 5.3.3-1 Kurdish language pack for LibreOffice Fresh
any Extra libreoffice-fresh-pa-IN 5.3.3-1 Punjabi (India) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-pt 5.3.3-1 Portuguese language pack for LibreOffice Fresh
any Extra libreoffice-fresh-uz 5.3.3-1 Uzbek language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ja 5.3.3-1 Japanese language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ks 5.3.3-1 Kashmiri language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ve 5.3.3-1 Venda language pack for LibreOffice Fresh
any Extra libreoffice-fresh-tn 5.3.3-1 Tswana language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ta 5.3.3-1 Tamil language pack for LibreOffice Fresh
any Extra libreoffice-fresh-hu 5.3.3-1 Hungarian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-mr 5.3.3-1 Marathi language pack for LibreOffice Fresh
any Extra libreoffice-fresh-rw 5.3.3-1 Kinyarwanda language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sr-Latn 5.3.3-1 Serbian (Latin) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-gu 5.3.3-1 Gujarati language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ar 5.3.3-1 Arabic language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ml 5.3.3-1 Malayalam language pack for LibreOffice Fresh
any Extra libreoffice-fresh-dgo 5.3.3-1 Dogri language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ts 5.3.3-1 Tsonga language pack for LibreOffice Fresh
any Extra libreoffice-fresh-mn 5.3.3-1 Mongolian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-gl 5.3.3-1 Galician language pack for LibreOffice Fresh
any Extra libreoffice-fresh-lv 5.3.3-1 Latvian language pack for LibreOffice Fresh
any Extra libreoffice-fresh-kok 5.3.3-1 Konkani language pack for LibreOffice Fresh
any Extra libreoffice-fresh-ca-valencia 5.3.3-1 Catalan (Valencia) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-sw-TZ 5.3.3-1 Swahili (Tanzania) language pack for LibreOffice Fresh
any Extra libreoffice-fresh-id 5.3.3-1 Indonesian language pack for LibreOffice Fresh
any Extra archivetools 2-1 Arch Linux Archive Tools
any Extra python2-backports.functools_lru_cache 1.4-2 Backport of functools.lru_cache from Python 3.3
any Community-Testing certbot-apache 0.14.0-2 Apache plugin for Let’s Encrypt client
any Community-Testing python-augeas 1.0.2-1 Python bindings for Augeas
any Community-Testing certbot-nginx 0.14.0-2 Nginx plugin for Let’s Encrypt client
any Community-Testing certbot 0.14.0-2 A tool to automatically receive and install X.509 certificates to enable TLS on servers. The client will interoperate with the Let’s Encrypt CA which will be issuing browser-trusted certificates for free.
i686
i686 Community wings3d 2.1.5-2 3D modeling program
i686 Community ejabberd 17.04-2 Jabber server written in Erlang
i686 Community couchdb 2.0.0-14 A document-oriented database that can be queried and indexed in a MapReduce fashion using JSON
i686 Community yaws 2.0.4-3 Web server/framework written in Erlang
i686 Community erlang-cl 1.2.1-4 OpenCL binding for Erlang
i686 Community erlang-sdl 1.3.1-2 SDL and OpenGL bindings for Erlang
i686 Community chicken 4.12.0-2 Feature rich R5RS Scheme compiler and interpreter
i686 Community normaliz 3.3.0-1 A tool for computations in affine monoids, vector configurations, lattice polytopes, and rational cones.
i686 Community python-pytables 3.4.2-1 A package for managing hierarchical datasets and designed to efficiently and easily cope with extremely large amounts of data
i686 Community python2-pytables 3.4.2-1 A package for managing hierarchical datasets and designed to efficiently and easily cope with extremely large amounts of data
i686 Community opendht 1:1.3.3-1 A C++11 implementation of the Kademlia DHT (Distributed Hash Table)
i686 Community haskell-aws 0.16-30 Amazon Web Services (AWS) for Haskell
i686 Community haskell-yesod-auth 1.4.17.1-2 Authentication for Yesod.
i686 Community haskell-dav 1.3.1-93 RFC 4918 WebDAV support
i686 Community haskell-http-conduit 2.2.3.1-26 HTTP client package with conduit interface and HTTPS support
i686 Community haskell-http-client-tls 0.3.4.2-1 http-client backend using the connection package and tls library
i686 Community haskell-pipes-http 1.0.5-30 HTTP client with pipes interface
i686 Community purescript 0.11.4-6 PureScript Programming Language Compiler
i686 Community haskell-authenticate 1.3.3.2-76 Authentication methods for Haskell web applications.
i686 Community hoogle 5.0.12-4 Haskell API Search
i686 Community argon2 20161029-2 A password-hashing function (reference C implementation)
i686 Community python-ruamel-yaml 0.14.12-1 YAML parser/emitter that supports roundtrip preservation of comments, seq/map flow style, and map key order
i686 Community qt5ct 0.32-1 Qt5 Configuration Utility
i686 Community haskell-yesod-form 1.4.12-1 Form handling support for Yesod Web Framework
i686 Extra libreoffice-fresh-sdk 5.3.3-1 Software Development Kit for LibreOffice Fresh
i686 Extra libreoffice-fresh 5.3.3-1 LibreOffice branch which contains new features and program enhancements
i686 Extra xfce4-terminal 0.8.5.1-1 A modern terminal emulator primarily for the Xfce desktop environment
i686 Extra libmm-glib 1.6.6-1 ModemManager library
i686 Extra modemmanager 1.6.6-1 Mobile broadband modem management service
i686 Extra windowmaker 0.95.8-1 An X11 window manager with a NEXTSTEP look and feel
i686 Extra mono-basic 4.6-1 Mono Visual Basic.NET compiler
i686 Extra mono 5.0.0.100-1 Free implementation of the .NET platform including runtime and compiler
i686 Extra xsp 4.4-1 A simple webserver based on mono - provides ASP.NET support
i686 Testing mariadb 10.1.23-2 Fast SQL database server, drop-in replacement for MySQL
i686 Testing mariadb-clients 10.1.23-2 MariaDB client tools
i686 Testing libmariadbclient 10.1.23-2 MariaDB client libraries
i686 Testing mytop 10.1.23-2 Top clone for MariaDB
i686 Community-Testing xapps 1.0.3-1 Common library for X-Apps project
i686 Testing freetype2 2.8-2 Font rasterization library
i686 Testing freetype2-demos 2.8-2 Freetype tools and demos
x86_64
x86_64 Community wings3d 2.1.5-2 3D modeling program
x86_64 Community ejabberd 17.04-2 Jabber server written in Erlang
x86_64 Community couchdb 2.0.0-14 A document-oriented database that can be queried and indexed in a MapReduce fashion using JSON
x86_64 Community yaws 2.0.4-3 Web server/framework written in Erlang
x86_64 Community erlang-cl 1.2.1-4 OpenCL binding for Erlang
x86_64 Community erlang-sdl 1.3.1-2 SDL and OpenGL bindings for Erlang
x86_64 Community chicken 4.12.0-2 Feature rich R5RS Scheme compiler and interpreter
x86_64 Community linux-hardened-docs 4.11.1.a-1 Kernel hackers manual - HTML documentation that comes with the Linux-hardened kernel
x86_64 Community linux-hardened-headers 4.11.1.a-1 Header files and scripts for building modules for Linux-hardened kernel
x86_64 Community linux-hardened 4.11.1.a-1 The Linux-hardened kernel and modules
x86_64 Community normaliz 3.3.0-1 A tool for computations in affine monoids, vector configurations, lattice polytopes, and rational cones.
x86_64 Community python-pytables 3.4.2-1 A package for managing hierarchical datasets and designed to efficiently and easily cope with extremely large amounts of data
x86_64 Community python2-pytables 3.4.2-1 A package for managing hierarchical datasets and designed to efficiently and easily cope with extremely large amounts of data
x86_64 Community opendht 1:1.3.3-1 A C++11 implementation of the Kademlia DHT (Distributed Hash Table)
x86_64 Community haskell-aws 0.16-30 Amazon Web Services (AWS) for Haskell
x86_64 Community haskell-yesod-auth 1.4.17.1-2 Authentication for Yesod.
x86_64 Community haskell-dav 1.3.1-93 RFC 4918 WebDAV support
x86_64 Community haskell-http-conduit 2.2.3.1-26 HTTP client package with conduit interface and HTTPS support
x86_64 Community haskell-http-client-tls 0.3.4.2-1 http-client backend using the connection package and tls library
x86_64 Community haskell-pipes-http 1.0.5-30 HTTP client with pipes interface
x86_64 Community purescript 0.11.4-6 PureScript Programming Language Compiler
x86_64 Community haskell-authenticate 1.3.3.2-76 Authentication methods for Haskell web applications.
x86_64 Community hoogle 5.0.12-4 Haskell API Search
x86_64 Community argon2 20161029-2 A password-hashing function (reference C implementation)
x86_64 Community python-ruamel-yaml 0.14.12-1 YAML parser/emitter that supports roundtrip preservation of comments, seq/map flow style, and map key order
x86_64 Community qt5ct 0.32-1 Qt5 Configuration Utility
x86_64 Extra libreoffice-fresh-sdk 5.3.3-1 Software Development Kit for LibreOffice Fresh
x86_64 Extra libreoffice-fresh 5.3.3-1 LibreOffice branch which contains new features and program enhancements
x86_64 Extra xfce4-terminal 0.8.5.1-1 A modern terminal emulator primarily for the Xfce desktop environment
x86_64 Community haskell-yesod-form 1.4.12-1 Form handling support for Yesod Web Framework
x86_64 Testing freetype2 2.8-2 Font rasterization library
x86_64 Testing freetype2-demos 2.8-2 Freetype tools and demos
x86_64 Extra libmm-glib 1.6.6-1 ModemManager library
x86_64 Extra modemmanager 1.6.6-1 Mobile broadband modem management service
x86_64 Extra windowmaker 0.95.8-1 An X11 window manager with a NEXTSTEP look and feel
x86_64 Extra mono-basic 4.6-1 Mono Visual Basic.NET compiler
x86_64 Extra mono 5.0.0.100-1 Free implementation of the .NET platform including runtime and compiler
x86_64 Extra xsp 4.4-1 A simple webserver based on mono - provides ASP.NET support
x86_64 Testing mariadb 10.1.23-2 Fast SQL database server, drop-in replacement for MySQL
x86_64 Testing mariadb-clients 10.1.23-2 MariaDB client tools
x86_64 Testing libmariadbclient 10.1.23-2 MariaDB client libraries
x86_64 Testing mytop 10.1.23-2 Top clone for MariaDB
x86_64 Community-Testing xapps 1.0.3-1 Common library for X-Apps project
AUR
radium 4.8.3-1
social-engineer-toolkit 7.6.3-1
mingw-w64-libdxfrw 0.6.3-1
recap-git 0.9.14.r41.g19ad54d-1
ofxstatement 0.6.1-1
culmus 0.131-1
perl-vcg 0.5-2
perl-par 1.015-1
runescape-launcher 2.2.4-2
tomita-parser 1.0.73-1
tribler 7.0.0rc2-1
python-orange 3.4.2-1
fades 6.0-1.1
gog-owlboy 2.0.0.1-1
gog-stardew-valley 2.6.0.7-1
Thanks
#2025 OFFLINE   securitybreach
  • 24,208 posts
Posted 31 May 2017 - 07:54 PM
Updates for Tuesday, May 30th, 2017
Any
any Core ipw2200-fw 3.1-6 Firmware for the Intel PRO/Wireless 2200BG
any Core ipw2100-fw 1.3-8 Intel Centrino Drivers firmware for IPW2100
any Community docx2txt 1.4-3 Recovers text from DOCX files, with good formatting.
any Community puppet 4.10.1-1 Server automation framework and application
any Community jmol 14.17.1-1 a Java 3D viewer for chemical structures
any Community python-tblib 1.3.2-1 Python traceback fiddling library
any Community python2-tblib 1.3.2-1 Python traceback fiddling library
any Community beets 1.4.3-3 Flexible music library manager and tagger
any Community scapy3k 0.21-1 Powerful interactive packet manipulation program written in Python 3
any Community strip-nondeterminism 0.034-1 Tool for stripping bits of non-deterministic information from files
any Community ruby-native-package-installer 1.0.2-1 native-package-installer helps to install native packages on "gem install"
any Testing breeze-grub 5.10.0-1 Breeze theme for GRUB
any Testing plasma-meta 5.10-1 Meta package to install KDE Plasma
any Testing plasma-workspace-wallpapers 5.10.0-1 Additional wallpapers for the Plasma Workspace
i686
i686 Core sudo 1.8.20.p1-1 Give certain users the ability to run some commands as root
i686 Core krb5 1.15.1-1 The Kerberos network authentication system
i686 Core linux-headers 4.11.3-1 Header files and scripts for building modules for Linux kernel
i686 Core linux 4.11.3-1 The Linux kernel and modules
i686 Core linux-docs 4.11.3-1 Kernel hackers manual - HTML documentation that comes with the Linux kernel
i686 Community scrot 0.8.17-1 Simple command-line screenshot utility for X
i686 Community maxima-ecl 5.40.0-1 A sophisticated computer algebra system (compiled against ecl)
i686 Community vagrant 1.9.5-1 Build and distribute virtualized development environments
i686 Community minitube 2.7-1 A native YouTube client in Qt. Watch YouTube videos without Flash Player
i686 Community heimdall 1.4.2-1 Tool suite used to flash firmware (aka ROMs) onto Samsung mobile devices
i686 Community devilspie 0.23-1 Window matching utility for X
i686 Community scite 3.7.5-1 Editor with facilities for building and running programs
i686 Community xmobar 0.24.5-1 A Minimalistic Text Based Status Bar
i686 Community libgiac 1.2.3.47-1 Giac shared library
i686 Community xcas 1.2.3.47-1 A free computer algebra system
i686 Community diffoscope 82-1 Tool for in-depth comparison of files, archives, and directories
i686 Community ncmpcpp 0.8-1 Almost exact clone of ncmpc with some new features
i686 Community python2-rpy2 2.8.6-1 A very simple, yet robust, Python interface to the R Programming Language.
i686 Community python-rpy2 2.8.6-1 A very simple, yet robust, Python interface to the R Programming Language.
i686 Community qt5ct 0.33-1 Qt5 Configuration Utility
i686 Community yaz 5.22.0-1 A toolkit supporting the development of Z39.50/SRW/SRU clients and servers
i686 Community hopenpgp-tools 0.19.4-96 hOpenPGP-based command-line tools
i686 Community purescript 0.11.4-15 PureScript Programming Language Compiler
i686 Community haskell-pandoc-crossref 0.2.5.0-45 Pandoc filter for cross-references (docs and libraries)
i686 Community haskell-yesod-default 1.2.0-149 Default config and main functions for your yesod application (deprecated)
i686 Community haskell-yesod-auth 1.4.17.1-12 Authentication for Yesod.
i686 Community haskell-aws 0.16-36 Amazon Web Services (AWS) for Haskell
i686 Community idris 1.0-24 Functional Programming Language with Dependent Types
i686 Community haskell-hasql 0.19.18-21 An efficient PostgreSQL driver and a flexible mapping API
i686 Community haskell-wai-logger 2.3.0-15 A logging system for WAI
i686 Community haskell-wai-websockets 3.0.1.1-18 Provide a bridge between WAI and the websockets package.
i686 Community haskell-skylighting 0.1.1.5-18 Syntax highlighting library
i686 Community haskell-http-client 0.5.6.1-6 An HTTP client engine
i686 Community haskell-pandoc 1.19.2.1-59 Conversion between markup formats (docs and libraries)
i686 Community haskell-data-textual 0.3.0.2-10 Human-friendly textual representations.
i686 Community haskell-wai 3.2.1.1-15 Web Application Interface.
i686 Community haskell-wai-app-static 3.1.6.1-62 WAI application for static serving
i686 Community haskell-esqueleto 2.5.2-4 Type-safe EDSL for SQL queries on persistent backends.
i686 Community haskell-websockets 0.10.0.0-12 A sensible and clean way to write WebSocket-capable servers in Haskell.
i686 Community haskell-cheapskate 0.1.0.5-60 Experimental markdown processor.
i686 Community pandoc 1.19.2.1-59 Conversion between markup formats
i686 Community hoogle 5.0.12-10 Haskell API Search
i686 Community haskell-stack 1.4.0-57 The Haskell Tool Stack (docs and libraries)
i686 Community haskell-http-types 0.9.1-10 Generic HTTP types for Haskell (for both client and server code).
i686 Community pandoc-crossref 0.2.5.0-45 Pandoc filter for cross-references
i686 Community haskell-http-api-data 0.3.7.1-4 Converting to/from HTTP API data like URL pieces, headers and query parameters.
i686 Community haskell-http-client-tls 0.3.4.2-4 http-client backend using the connection package and tls library
i686 Community haskell-warp-tls 3.2.3-28 HTTP over TLS support for Warp via the TLS package
i686 Community haskell-tagstream-conduit 0.5.5.3-70 Streamlined html tag parser
i686 Community haskell-persistent 2.6.1-26 Type-safe, multi-backend data serialization
i686 Community haskell-network-ip 0.3-11 Internet Protocol data structures
i686 Community haskell-http2 1.6.3-6 HTTP/2.0 library including frames and HPACK
i686 Community haskell-pipes-http 1.0.5-34 HTTP client with pipes interface
i686 Community haskell-text-latin1 0.3-4 Latin-1 (including ASCII) utility functions
i686 Community haskell-hakyll 4.9.5.1-65 A static website compiler library
i686 Community haskell-case-insensitive 1.2.0.10-1 Case insensitive string comparison
i686 Community haskell-text-printer 0.5-5 Abstract interface for text builders/printers.
i686 Community haskell-yesod-core 1.4.33-25 Creation of type-safe, RESTful web applications.
i686 Community haskell-dav 1.3.1-100 RFC 4918 WebDAV support
i686 Community haskell-yesod 1.4.5-48 Creation of type-safe, RESTful web applications.
i686 Community haskell-persistent-sqlite 2.6.2-25 Backend for the persistent library using sqlite3
i686 Community git-annex 6.20170519-10 Manage files with git, without checking their contents into git
i686 Community stack 1.4.0-57 The Haskell Tool Stack
i686 Community haskell-yesod-persistent 1.4.2-42 Some helpers for using Persistent from Yesod.
i686 Community pandoc-citeproc 0.10.4.1-54 Supports using pandoc with citeproc
i686 Community haskell-yesod-static 1.5.2-41 Static file serving subsite for Yesod Web Framework.
i686 Community haskell-wai-extra 3.0.19.1-23 Provides some basic WAI handlers and middleware.
i686 Community haskell-warp 3.2.12-4 A fast, light-weight web server for WAI applications.
i686 Community haskell-pandoc-citeproc 0.10.4.1-54 Supports using pandoc with citeproc (docs and libraries)
i686 Community haskell-yesod-form 1.4.12-8 Form handling support for Yesod Web Framework
i686 Community haskell-postgresql-binary 0.12.1-15 Encoders and decoders for the PostgreSQL's binary format
i686 Community haskell-authenticate 1.3.3.2-82 Authentication methods for Haskell web applications.
i686 Community haskell-http-conduit 2.2.3.1-32 HTTP client package with conduit interface and HTTPS support
i686 Community haskell-persistent-template 2.5.2-27 Type-safe, non-relational, multi-backend persistence
i686 Community haskell-hasql-transaction 0.5-27 A composable abstraction over the retryable transactions for Hasql
i686 Community haskell-hasql-pool 0.4.1-45 A pool of connections for Hasql
i686 Community movit 1.5.1-1 The modern video toolkit
i686 Community syncthing 0.14.29-1 Open Source Continuous Replication / Cluster Synchronization Thing
i686 Community syncthing-relaysrv 0.14.29-1 Relay server for Syncthing
i686 Community percona-server 5.7.18_15-1 Drop-in replacement for MySQL that provides improved performance, diagnostics, instrumentation and TokuDB storage engine
i686 Community percona-server-clients 5.7.18_15-1 Percona Server client tools
i686 Community libperconaserverclient 5.7.18_15-1 Percona Server client libraries
i686 Community owl-lisp 0.1.14-1 Simple purely functional lisp
i686 Community python2-yara 3.6.0-1 Tool aimed at helping malware researchers to identify and classify malware samples
i686 Community python-yara 3.6.0-1 Tool aimed at helping malware researchers to identify and classify malware samples
i686 Community yara 3.6.0-1 Tool aimed at helping malware researchers to identify and classify malware samples
i686 Community maim 5.4.63-1 Utility to take a screenshot using imlib2
i686 Community umurmur 0.2.17-1 Minimalistic Mumble server
i686 Community gimp-plugin-gmic 2.0.0-1 Gimp plugin for the G'MIC image processing framework
i686 Community zart 2.0.0-1 A GUI for G'MIC real-time manipulations on the output of a webcam
i686 Community gmic 2.0.0-1 GREYC's Magic Image Converter: image processing framework
i686 Community toxic 0.8.0-1 CLI Tox client
i686 Community haskell-conduit-combinators 1.1.1-17 Commonly used conduit functions, for both chunked and unchunked data
i686 Community haskell-http-date 0.0.6.1-19 HTTP Date parser/formatter
i686 Community haskell-monad-logger 0.3.24-5 A class of monads which can log messages.
i686 Community haskell-openpgp-asciiarmor 0.1-11 OpenPGP (RFC4880) ASCII Armor codec
i686 Community haskell-xml-conduit 1.4.0.4-12 Pure-Haskell utilities for dealing with XML with the conduit package.
i686 Community haskell-insert-ordered-containers 0.2.1.0-10 Associative containers retating insertion order for traversals.
i686 Community haskell-dns 2.0.10-25 DNS library in Haskell
i686 Community haskell-lens-aeson 1.0.1-6 Law-abiding lenses for aeson
i686 Community haskell-cassava 0.4.5.1-11 A CSV parsing and encoding library
i686 Community haskell-conduit-extra 1.1.16-4 Batteries included conduit: adapters for common libraries.
i686 Community haskell-scientific 0.3.4.13-1 Numbers represented using scientific notation
i686 Community haskell-email-validate 2.2.0-19 Validating an email address string against RFC 5322
i686 Community haskell-shakespeare 2.0.13-4 A toolkit for making compile-time interpolated templates
i686 Community haskell-aeson 1.1.2.0-3 A JSON parsing and encoding library optimized for ease of use and high performance.
i686 Community ghc-mod 5.8.0.0-1 Happy Haskell Programming
i686 Community haskell-microlens-aeson 2.2.0.1-4 Law-abiding lenses for Aeson, using microlens
i686 Community haskell-xcffib 0.5.1-20 A cffi-based python binding for X
i686 Community haskell-cryptohash-conduit 0.1.1-76 cryptohash conduit
i686 Community cblrepo 0.24.0-19 Tool to maintain a database of CABAL packages and their dependencies
i686 Community haskell-pandoc-types 1.17.0.5-12 Types for representing a structured document
i686 Community haskell-attoparsec 0.13.1.0-9 Fast combinator parsing for bytestrings and text
i686 Community haskell-uri-bytestring 0.2.3.1-8 Haskell URI parsing as ByteStrings
i686 Community haskell-xss-sanitize 0.3.5.7-17 sanitize untrusted HTML to prevent XSS attacks
i686 Community haskell-yaml 0.8.23-3 Support for parsing and rendering YAML documents.
i686 Community haskell-parsers 0.12.4-18 Parsing combinators
i686 Community haskell-hit 0.6.3-32 Git operations in haskell
i686 Community haskell-cryptonite-conduit 0.2.0-19 Conduit bridge for cryptonite
i686 Community haskell-data-serializer 0.3-8 Common API for serialization libraries
i686 Community haskell-aeson-pretty 0.8.2-19 JSON pretty-printing library and command-line tool.
i686 Community haskell-aeson-better-errors 0.9.1.0-17 Better error messages when decoding JSON values.
i686 Community haskell-statistics 0.13.3.0-35 A library of statistical types, data, and functions
i686 Community haskell-configurator 0.3.0.0-8 Configuration management
i686 Community haskell-aeson-compat 0.3.6-17 Compatibility layer for aeson
i686 Community stylish-haskell 0.7.1.0-28 Haskell code prettifier 2017-05-07
i686 Community haskell-criterion 1.1.4.0-36 Robust, reliable performance measurement and analysis
i686 Community haskell-project-template 0.2.0-56 Specify Haskell project templates and generate files
i686 Community darcs 2.12.5-32 A distributed, interactive, smart revision control system
i686 Community haskell-css-text 0.1.2.2-10 CSS parser and renderer.
i686 Community haskell-descriptive 0.9.4-50 Self-describing consumers/parsers; forms, cmd-line args, JSON, etc.
i686 Community haskell-doctemplates 0.1.0.2-18 Pandoc-style document templates
i686 Community haskell-trifecta 1.6.2.1-20 A modern parser combinator library with convenient diagnostics
i686 Community haskell-binary-tagged 0.1.4.2-19 Tagged binary serialisation.
i686 Community hindent 5.2.3-6 Extensible Haskell pretty printer
i686 Community haskell-texmath 0.9.4-8 Conversion between formats used to represent mathematics.
i686 Community haskell-hlint 2.0.8-1 Source code suggestions (docs and libraries)
i686 Community haskell-xml-hamlet 0.4.1-23 Hamlet-style quasiquoter for XML content
i686 Community haskell-path 0.5.13-8 Path
i686 Community haskell-attoparsec-iso8601 1.0.0.0-3 Parsing of ISO 8601 dates, originally from aeson
i686 Community hlint 2.0.8-1 Source code suggestions
i686 Community haskell-hpack 0.17.0-16 An alternative format for Haskell packages
i686 Community haskell-path-io 1.2.2-15 Interface to ‘directory’ package for users of ‘path’
i686 Community haskell-sourcemap 0.1.6-25 Implementation of source maps as proposed by Google and Mozilla.
i686 Community haskell-ghc-mod 5.8.0.0-1 Happy Haskell Programming (docs and libraries)
i686 Community haskell-bower-json 1.0.0.1-15 Read bower.json from Haskell
i686 Community haskell-hopenpgp 2.5.5-68 Native Haskell implementation of OpenPGP (RFC4880)
i686 Community haskell-turtle 1.3.4-1 Shell programming, Haskell-style
i686 Extra mutt 1.8.3-1 Small but very powerful text-based mail client
i686 Extra geoclue2 2.4.7-1 Modular geoinformation service built on the D-Bus messaging system
i686 Extra gnome-online-accounts 3.24.1-1 Single sign-on framework for GNOME
i686 Extra ispell 3.4.00-1 An interactive spell-checking program for Unix
i686 Extra imagemagick-doc 6.9.8.8-1 The ImageMagick documentation (utilities manuals and libraries API)
i686 Extra imagemagick 6.9.8.8-1 An image viewing/manipulation program
i686 Extra libva-intel-driver 1.8.2-1 VA-API implementation for Intel G45 and HD Graphics family
i686 Extra libva 1.8.2-1 Video Acceleration (VA) API for Linux
i686 Extra ffmpeg 1:3.3.1-9 Complete solution to record, convert and stream audio and video
i686 Extra xorg-xdriinfo 1.0.5-2 Query configuration information of DRI drivers
i686 Testing plasma-workspace 5.10.0-2 KDE Plasma Workspace
i686 Testing plasma-wayland-session 5.10.0-2 Plasma Wayland session
i686 Testing drkonqi 5.10.0-2 KDE crash handler
i686 Testing kuiserver 5.10.0-2 KDE Progress Info UI server
i686 Testing libqalculate 0.9.12-1 Multi-purpose desktop calculator
i686 Testing cantor 17.04.1-2 KDE Frontend to Mathematical Software
i686 Testing step 17.04.1-2 Interactive Physical Simulator
i686 Testing qalculate-gtk 0.9.12-1 GNOME frontend for libqalculate
i686 Testing kscreenlocker 5.10.0-1 Library and components for secure lock screen architecture
i686 Testing kgamma5 5.10.0-1 Adjust your monitor's gamma settings
i686 Testing kwallet-pam 5.10.0-1 KWallet PAM integration
i686 Testing plasma-desktop 5.10.0-1 KDE Plasma Desktop
i686 Testing breeze 5.10.0-1 Artwork, styles and assets for the Breeze visual style for the Plasma Desktop
i686 Testing kinfocenter 5.10.0-1 A utility that provides information about a computer system
i686 Testing breeze-gtk 5.10.0-1 Breeze widget theme for GTK 2 and 3
i686 Testing kdecoration 5.10.0-1 Plugin based library to create window decorations
i686 Testing systemsettings 5.10.0-1 KDE system settings
i686 Testing oxygen-kde4 5.10.0-1 KDE Oxygen style for KDE4 applications
i686 Testing kdeplasma-addons 5.10.0-1 All kind of addons to improve your Plasma experience
i686 Testing powerdevil 5.10.0-1 Manages the power consumption settings of a Plasma Shell
i686 Testing knetattach 5.10.0-1 Wizard which makes it easier to integrate network resources with the Plasma Desktop
i686 Testing plasma-nm 5.10.0-1 Plasma applet written in QML for managing network connections
i686 Testing khotkeys 5.10.0-1 KHotKeys
i686 Testing kwayland-integration 5.10.0-1 Provides integration plugins for various KDE frameworks for the wayland windowing system
i686 Testing kde-gtk-config 5.10.0-1 GTK2 and GTK3 Configurator for KDE
i686 Testing libksysguard 5.10.0-1 Libksysguard
i686 Testing kwin 5.10.0-1 KDE Window manager
i686 Testing kmenuedit 5.10.0-1 KDE menu editor
i686 Testing plasma-sdk 5.10.0-1 Applications useful for Plasma development
i686 Testing polkit-kde-agent 5.10.0-1 Daemon providing a polkit authentication UI for KDE
i686 Testing bluedevil 1:5.10.0-1 Integrate the Bluetooth technology within KDE workspace and applications
i686 Testing discover 5.10.0-1 KDE and Plasma resources management GUI
i686 Testing libkscreen 5.10.0-1 KDE screen management software
i686 Testing kscreen 5.10.0-1 KDE's screen management software
i686 Testing kactivitymanagerd 5.10.0-1 System service to manage user's activities and track the usage patterns
i686 Testing ksysguard 5.10.0-1 Track and control the processes running in your system
i686 Testing breeze-kde4 5.10.0-1 Breeze widget style for KDE4 applications
i686 Testing ksshaskpass 5.10.0-1 ssh-add helper that uses kwallet and kpassworddialog
i686 Testing kwrited 5.10.0-1 KDE daemon listening for wall and write messages
i686 Testing milou 5.10.0-1 A dedicated search application built on top of Baloo
i686 Testing kde-cli-tools 5.10.0-1 Tools based on KDE Frameworks 5 to better interact with the system
i686 Testing plasma-pa 5.10.0-1 Plasma applet for audio volume management using PulseAudio
i686 Testing sddm-kcm 5.10.0-1 KDE Config Module for SDDM
i686 Testing oxygen 5.10.0-1 KDE Oxygen style
i686 Testing xdg-desktop-portal-kde 5.10.0-1 A backend implementation for xdg-desktop-portal using Qt/KF5
i686 Testing plasma-integration 5.10.0-1 Qt Platform Theme integration plugins for the Plasma workspaces
i686 Testing user-manager 5.10.0-1 A simple system settings module to manage the users of your system
i686 Testing sqlite-tcl 3.19.2-2 sqlite Tcl Extension Architecture (TEA)
i686 Testing sqlite-analyzer 3.19.2-2 An analysis program for sqlite3 database files
i686 Testing sqlite-doc 3.19.2-2 most of the static HTML files that comprise this website, including all of the SQL Syntax and the C/C++ interface specs and other miscellaneous documentation
i686 Testing sqlite 3.19.2-2 A C library that implements an SQL database engine
i686 Testing fuse3 3.0.2-1 A library that makes it possible to implement a filesystem in a userspace program.
i686 Testing fuse-common 3.0.2-1 Common files for fuse2/3 packages
x86_64
x86_64 Core krb5 1.15.1-1 The Kerberos network authentication system
x86_64 Core linux-headers 4.11.3-1 Header files and scripts for building modules for Linux kernel
x86_64 Core linux 4.11.3-1 The Linux kernel and modules
x86_64 Core linux-docs 4.11.3-1 Kernel hackers manual - HTML documentation that comes with the Linux kernel
x86_64 Core sudo 1.8.20.p1-1 Give certain users the ability to run some commands as root
x86_64 Community scrot 0.8.17-1 Simple command-line screenshot utility for X
x86_64 Community maxima-ecl 5.40.0-1 A sophisticated computer algebra system (compiled against ecl)
x86_64 Community vagrant 1.9.5-1 Build and distribute virtualized development environments
x86_64 Community minitube 2.7-1 A native YouTube client in Qt. Watch YouTube videos without Flash Player
x86_64 Community heimdall 1.4.2-1 Tool suite used to flash firmware (aka ROMs) onto Samsung mobile devices
x86_64 Community devilspie 0.23-1 Window matching utility for X
x86_64 Community scite 3.7.5-1 Editor with facilities for building and running programs
x86_64 Community xmobar 0.24.5-1 A Minimalistic Text Based Status Bar
x86_64 Community libgiac 1.2.3.47-1 Giac shared library
x86_64 Community xcas 1.2.3.47-1 A free computer algebra system
x86_64 Community diffoscope 82-1 Tool for in-depth comparison of files, archives, and directories
x86_64 Community ncmpcpp 0.8-1 Almost exact clone of ncmpc with some new features
x86_64 Community python2-rpy2 2.8.6-1 A very simple, yet robust, Python interface to the R Programming Language.
x86_64 Community python-rpy2 2.8.6-1 A very simple, yet robust, Python interface to the R Programming Language.
x86_64 Community qt5ct 0.33-1 Qt5 Configuration Utility
x86_64 Community yaz 5.22.0-1 A toolkit supporting the development of Z39.50/SRW/SRU clients and servers
x86_64 Community hopenpgp-tools 0.19.4-96 hOpenPGP-based command-line tools
x86_64 Community purescript 0.11.4-15 PureScript Programming Language Compiler
x86_64 Community haskell-pandoc-crossref 0.2.5.0-45 Pandoc filter for cross-references (docs and libraries)
x86_64 Community haskell-yesod-default 1.2.0-149 Default config and main functions for your yesod application (deprecated)
x86_64 Community haskell-yesod-auth 1.4.17.1-12 Authentication for Yesod.
x86_64 Community haskell-aws 0.16-36 Amazon Web Services (AWS) for Haskell
x86_64 Community idris 1.0-24 Functional Programming Language with Dependent Types
x86_64 Community haskell-hasql 0.19.18-21 An efficient PostgreSQL driver and a flexible mapping API
x86_64 Community haskell-wai-logger 2.3.0-15 A logging system for WAI
x86_64 Community haskell-wai-websockets 3.0.1.1-18 Provide a bridge between WAI and the websockets package.
x86_64 Community haskell-skylighting 0.1.1.5-18 Syntax highlighting library
x86_64 Community haskell-http-client 0.5.6.1-6 An HTTP client engine
x86_64 Community ppsspp-headless 1.4.2-1 A PSP emulator written in C++
x86_64 Community haskell-pandoc 1.19.2.1-59 Conversion between markup formats (docs and libraries)
x86_64 Community haskell-data-textual 0.3.0.2-10 Human-friendly textual representations.
x86_64 Community haskell-wai 3.2.1.1-15 Web Application Interface.
x86_64 Community haskell-wai-app-static 3.1.6.1-62 WAI application for static serving
x86_64 Community haskell-esqueleto 2.5.2-4 Type-safe EDSL for SQL queries on persistent backends.
x86_64 Community haskell-websockets 0.10.0.0-12 A sensible and clean way to write WebSocket-capable servers in Haskell.
x86_64 Community haskell-cheapskate 0.1.0.5-60 Experimental markdown processor.
x86_64 Community pandoc 1.19.2.1-59 Conversion between markup formats
x86_64 Community hoogle 5.0.12-10 Haskell API Search
x86_64 Community haskell-stack 1.4.0-57 The Haskell Tool Stack (docs and libraries)
x86_64 Community haskell-http-types 0.9.1-10 Generic HTTP types for Haskell (for both client and server code).
x86_64 Community pandoc-crossref 0.2.5.0-45 Pandoc filter for cross-references
x86_64 Community ppsspp 1.4.2-1 A PSP emulator written in C++
x86_64 Community haskell-http-api-data 0.3.7.1-4 Converting to/from HTTP API data like URL pieces, headers and query parameters.
x86_64 Community haskell-http-client-tls 0.3.4.2-4 http-client backend using the connection package and tls library
x86_64 Community haskell-warp-tls 3.2.3-28 HTTP over TLS support for Warp via the TLS package
x86_64 Community haskell-tagstream-conduit 0.5.5.3-70 Streamlined html tag parser
x86_64 Community haskell-persistent 2.6.1-26 Type-safe, multi-backend data serialization
x86_64 Community haskell-network-ip 0.3-11 Internet Protocol data structures
x86_64 Community haskell-http2 1.6.3-6 HTTP/2.0 library including frames and HPACK
x86_64 Community haskell-pipes-http 1.0.5-34 HTTP client with pipes interface
x86_64 Community haskell-text-latin1 0.3-4 Latin-1 (including ASCII) utility functions
x86_64 Community haskell-hakyll 4.9.5.1-65 A static website compiler library
x86_64 Community haskell-case-insensitive 1.2.0.10-1 Case insensitive string comparison
x86_64 Community haskell-text-printer 0.5-5 Abstract interface for text builders/printers.
x86_64 Community haskell-yesod-core 1.4.33-25 Creation of type-safe, RESTful web applications.
x86_64 Community haskell-dav 1.3.1-100 RFC 4918 WebDAV support
x86_64 Community haskell-yesod 1.4.5-48 Creation of type-safe, RESTful web applications.
x86_64 Community haskell-persistent-sqlite 2.6.2-25 Backend for the persistent library using sqlite3
x86_64 Community git-annex 6.20170519-10 Manage files with git, without checking their contents into git
x86_64 Community stack 1.4.0-57 The Haskell Tool Stack
x86_64 Community haskell-yesod-persistent 1.4.2-42 Some helpers for using Persistent from Yesod.
x86_64 Community pandoc-citeproc 0.10.4.1-54 Supports using pandoc with citeproc
x86_64 Community haskell-yesod-static 1.5.2-41 Static file serving subsite for Yesod Web Framework.
x86_64 Community haskell-wai-extra 3.0.19.1-23 Provides some basic WAI handlers and middleware.
x86_64 Community haskell-warp 3.2.12-4 A fast, light-weight web server for WAI applications.
x86_64 Community haskell-pandoc-citeproc 0.10.4.1-54 Supports using pandoc with citeproc (docs and libraries)
x86_64 Community haskell-yesod-form 1.4.12-8 Form handling support for Yesod Web Framework
x86_64 Community ppsspp-qt 1.4.2-1 A PSP emulator written in C++
x86_64 Community haskell-postgresql-binary 0.12.1-15 Encoders and decoders for the PostgreSQL's binary format
x86_64 Community haskell-authenticate 1.3.3.2-82 Authentication methods for Haskell web applications.
x86_64 Community haskell-http-conduit 2.2.3.1-32 HTTP client package with conduit interface and HTTPS support
x86_64 Community haskell-persistent-template 2.5.2-27 Type-safe, non-relational, multi-backend persistence
x86_64 Community haskell-hasql-transaction 0.5-27 A composable abstraction over the retryable transactions for Hasql
x86_64 Community haskell-hasql-pool 0.4.1-45 A pool of connections for Hasql
x86_64 Community movit 1.5.1-1 The modern video toolkit
x86_64 Community syncthing 0.14.29-1 Open Source Continuous Replication / Cluster Synchronization Thing
x86_64 Community syncthing-relaysrv 0.14.29-1 Relay server for Syncthing
x86_64 Community percona-server 5.7.18_15-1 Drop-in replacement for MySQL that provides improved performance, diagnostics, instrumentation and TokuDB storage engine
x86_64 Community percona-server-clients 5.7.18_15-1 Percona Server client tools
x86_64 Community libperconaserverclient 5.7.18_15-1 Percona Server client libraries
x86_64 Community owl-lisp 0.1.14-1 Simple purely functional lisp
x86_64 Community python2-yara 3.6.0-1 Tool aimed at helping malware researchers to identify and classify malware samples
x86_64 Community python-yara 3.6.0-1 Tool aimed at helping malware researchers to identify and classify malware samples
x86_64 Community yara 3.6.0-1 Tool aimed at helping malware researchers to identify and classify malware samples
x86_64 Community maim 5.4.63-1 Utility to take a screenshot using imlib2
x86_64 Community umurmur 0.2.17-1 Minimalistic Mumble server
x86_64 Community linux-hardened-headers 4.11.3.c-1 Header files and scripts for building modules for Linux-hardened kernel
x86_64 Community linux-hardened 4.11.3.c-1 The Linux-hardened kernel and modules
x86_64 Community linux-hardened-docs 4.11.3.c-1 Kernel hackers manual - HTML documentation that comes with the Linux-hardened kernel
x86_64 Community gimp-plugin-gmic 2.0.0-1 Gimp plugin for the G'MIC image processing framework
x86_64 Community zart 2.0.0-1 A GUI for G'MIC real-time manipulations on the output of a webcam
x86_64 Community gmic 2.0.0-1 GREYC's Magic Image Converter: image processing framework
x86_64 Community toxic 0.8.0-1 CLI Tox client
x86_64 Community haskell-conduit-combinators 1.1.1-17 Commonly used conduit functions, for both chunked and unchunked data
x86_64 Community haskell-http-date 0.0.6.1-19 HTTP Date parser/formatter
x86_64 Community haskell-monad-logger 0.3.24-5 A class of monads which can log messages.
x86_64 Community haskell-openpgp-asciiarmor 0.1-11 OpenPGP (RFC4880) ASCII Armor codec
x86_64 Community haskell-xml-conduit 1.4.0.4-12 Pure-Haskell utilities for dealing with XML with the conduit package.
x86_64 Community haskell-insert-ordered-containers 0.2.1.0-10 Associative containers retating insertion order for traversals.
x86_64 Community haskell-dns 2.0.10-25 DNS library in Haskell
x86_64 Community haskell-lens-aeson 1.0.1-6 Law-abiding lenses for aeson
x86_64 Community haskell-cassava 0.4.5.1-11 A CSV parsing and encoding library
x86_64 Community haskell-conduit-extra 1.1.16-4 Batteries included conduit: adapters for common libraries.
x86_64 Community haskell-scientific 0.3.4.13-1 Numbers represented using scientific notation
x86_64 Community haskell-email-validate 2.2.0-19 Validating an email address string against RFC 5322
x86_64 Community haskell-shakespeare 2.0.13-4 A toolkit for making compile-time interpolated templates
x86_64 Community haskell-aeson 1.1.2.0-3 A JSON parsing and encoding library optimized for ease of use and high performance.
x86_64 Community ghc-mod 5.8.0.0-1 Happy Haskell Programming
x86_64 Community haskell-microlens-aeson 2.2.0.1-4 Law-abiding lenses for Aeson, using microlens
x86_64 Community haskell-xcffib 0.5.1-20 A cffi-based python binding for X
x86_64 Community haskell-cryptohash-conduit 0.1.1-76 cryptohash conduit
x86_64 Community cblrepo 0.24.0-19 Tool to maintain a database of CABAL packages and their dependencies
x86_64 Community haskell-pandoc-types 1.17.0.5-12 Types for representing a structured document
x86_64 Community haskell-attoparsec 0.13.1.0-9 Fast combinator parsing for bytestrings and text
x86_64 Community haskell-uri-bytestring 0.2.3.1-8 Haskell URI parsing as ByteStrings
x86_64 Community haskell-xss-sanitize 0.3.5.7-17 sanitize untrusted HTML to prevent XSS attacks
x86_64 Community haskell-yaml 0.8.23-3 Support for parsing and rendering YAML documents.
x86_64 Community haskell-parsers 0.12.4-18 Parsing combinators
x86_64 Community haskell-hit 0.6.3-32 Git operations in haskell
x86_64 Community haskell-cryptonite-conduit 0.2.0-19 Conduit bridge for cryptonite
x86_64 Community haskell-data-serializer 0.3-8 Common API for serialization libraries
x86_64 Community haskell-aeson-pretty 0.8.2-19 JSON pretty-printing library and command-line tool.
x86_64 Community haskell-aeson-better-errors 0.9.1.0-17 Better error messages when decoding JSON values.
x86_64 Community haskell-statistics 0.13.3.0-35 A library of statistical types, data, and functions
x86_64 Community haskell-configurator 0.3.0.0-8 Configuration management
x86_64 Community haskell-aeson-compat 0.3.6-17 Compatibility layer for aeson
x86_64 Community stylish-haskell 0.7.1.0-28 Haskell code prettifier 2017-05-07
x86_64 Community haskell-criterion 1.1.4.0-36 Robust, reliable performance measurement and analysis
x86_64 Community haskell-project-template 0.2.0-56 Specify Haskell project templates and generate files
x86_64 Community darcs 2.12.5-32 A distributed, interactive, smart revision control system
x86_64 Community haskell-css-text 0.1.2.2-10 CSS parser and renderer.
x86_64 Community haskell-descriptive 0.9.4-50 Self-describing consumers/parsers; forms, cmd-line args, JSON, etc.
x86_64 Community haskell-doctemplates 0.1.0.2-18 Pandoc-style document templates
x86_64 Community haskell-trifecta 1.6.2.1-20 A modern parser combinator library with convenient diagnostics
x86_64 Community haskell-binary-tagged 0.1.4.2-19 Tagged binary serialisation.
x86_64 Community hindent 5.2.3-6 Extensible Haskell pretty printer
x86_64 Community haskell-texmath 0.9.4-8 Conversion between formats used to represent mathematics.
x86_64 Community haskell-hlint 2.0.8-1 Source code suggestions (docs and libraries)
x86_64 Community haskell-xml-hamlet 0.4.1-23 Hamlet-style quasiquoter for XML content
x86_64 Community haskell-path 0.5.13-8 Path
x86_64 Community haskell-attoparsec-iso8601 1.0.0.0-3 Parsing of ISO 8601 dates, originally from aeson
x86_64 Community hlint 2.0.8-1 Source code suggestions
x86_64 Community haskell-hpack 0.17.0-16 An alternative format for Haskell packages
x86_64 Community haskell-path-io 1.2.2-15 Interface to ‘directory’ package for users of ‘path’
x86_64 Community haskell-sourcemap 0.1.6-25 Implementation of source maps as proposed by Google and Mozilla.
x86_64 Community haskell-ghc-mod 5.8.0.0-1 Happy Haskell Programming (docs and libraries)
x86_64 Community haskell-bower-json 1.0.0.1-15 Read bower.json from Haskell
x86_64 Community haskell-hopenpgp 2.5.5-68 Native Haskell implementation of OpenPGP (RFC4880)
x86_64 Community haskell-turtle 1.3.4-1 Shell programming, Haskell-style
x86_64 Extra mutt 1.8.3-1 Small but very powerful text-based mail client
x86_64 Extra geoclue2 2.4.7-1 Modular geoinformation service built on the D-Bus messaging system
x86_64 Extra gnome-online-accounts 3.24.1-1 Single sign-on framework for GNOME
x86_64 Extra ispell 3.4.00-1 An interactive spell-checking program for Unix
x86_64 Extra imagemagick-doc 6.9.8.8-1 The ImageMagick documentation (utilities manuals and libraries API)
x86_64 Extra imagemagick 6.9.8.8-1 An image viewing/manipulation program
x86_64 Extra libva-intel-driver 1.8.2-1 VA-API implementation for Intel G45 and HD Graphics family
x86_64 Extra libva 1.8.2-1 Video Acceleration (VA) API for Linux
x86_64 Extra ffmpeg 1:3.3.1-9 Complete solution to record, convert and stream audio and video
x86_64 Extra xorg-xdriinfo 1.0.5-2 Query configuration information of DRI drivers
x86_64 Testing plasma-workspace 5.10.0-2 KDE Plasma Workspace
x86_64 Testing plasma-wayland-session 5.10.0-2 Plasma Wayland session
x86_64 Testing drkonqi 5.10.0-2 KDE crash handler
x86_64 Testing kuiserver 5.10.0-2 KDE Progress Info UI server
x86_64 Testing libqalculate 0.9.12-1 Multi-purpose desktop calculator
x86_64 Testing cantor 17.04.1-2 KDE Frontend to Mathematical Software
x86_64 Testing step 17.04.1-2 Interactive Physical Simulator
x86_64 Testing qalculate-gtk 0.9.12-1 GNOME frontend for libqalculate
x86_64 Testing kscreenlocker 5.10.0-1 Library and components for secure lock screen architecture
x86_64 Testing kgamma5 5.10.0-1 Adjust your monitor's gamma settings
x86_64 Testing kwallet-pam 5.10.0-1 KWallet PAM integration
x86_64 Testing plasma-desktop 5.10.0-1 KDE Plasma Desktop
x86_64 Testing breeze 5.10.0-1 Artwork, styles and assets for the Breeze visual style for the Plasma Desktop
x86_64 Testing kinfocenter 5.10.0-1 A utility that provides information about a computer system
x86_64 Testing breeze-gtk 5.10.0-1 Breeze widget theme for GTK 2 and 3
x86_64 Testing kdecoration 5.10.0-1 Plugin based library to create window decorations
x86_64 Testing systemsettings 5.10.0-1 KDE system settings
x86_64 Testing oxygen-kde4 5.10.0-1 KDE Oxygen style for KDE4 applications
x86_64 Testing kdeplasma-addons 5.10.0-1 All kind of addons to improve your Plasma experience
x86_64 Testing powerdevil 5.10.0-1 Manages the power consumption settings of a Plasma Shell
x86_64 Testing knetattach 5.10.0-1 Wizard which makes it easier to integrate network resources with the Plasma Desktop
x86_64 Testing plasma-nm 5.10.0-1 Plasma applet written in QML for managing network connections
x86_64 Testing khotkeys 5.10.0-1 KHotKeys
x86_64 Testing kwayland-integration 5.10.0-1 Provides integration plugins for various KDE frameworks for the wayland windowing system
x86_64 Testing kde-gtk-config 5.10.0-1 GTK2 and GTK3 Configurator for KDE
x86_64 Testing libksysguard 5.10.0-1 Libksysguard
x86_64 Testing kwin 5.10.0-1 KDE Window manager
x86_64 Testing kmenuedit 5.10.0-1 KDE menu editor
x86_64 Testing plasma-sdk 5.10.0-1 Applications useful for Plasma development
x86_64 Testing polkit-kde-agent 5.10.0-1 Daemon providing a polkit authentication UI for KDE
x86_64 Testing bluedevil 1:5.10.0-1 Integrate the Bluetooth technology within KDE workspace and applications
x86_64 Testing discover 5.10.0-1 KDE and Plasma resources management GUI
x86_64 Testing libkscreen 5.10.0-1 KDE screen management software
x86_64 Testing kscreen 5.10.0-1 KDE's screen management software
x86_64 Testing kactivitymanagerd 5.10.0-1 System service to manage user's activities and track the usage patterns
x86_64 Testing ksysguard 5.10.0-1 Track and control the processes running in your system
x86_64 Testing breeze-kde4 5.10.0-1 Breeze widget style for KDE4 applications
x86_64 Testing ksshaskpass 5.10.0-1 ssh-add helper that uses kwallet and kpassworddialog
x86_64 Testing kwrited 5.10.0-1 KDE daemon listening for wall and write messages
x86_64 Testing milou 5.10.0-1 A dedicated search application built on top of Baloo
x86_64 Testing kde-cli-tools 5.10.0-1 Tools based on KDE Frameworks 5 to better interact with the system
x86_64 Testing plasma-pa 5.10.0-1 Plasma applet for audio volume management using PulseAudio
x86_64 Testing sddm-kcm 5.10.0-1 KDE Config Module for SDDM
x86_64 Testing oxygen 5.10.0-1 KDE Oxygen style
x86_64 Testing xdg-desktop-portal-kde 5.10.0-1 A backend implementation for xdg-desktop-portal using Qt/KF5
x86_64 Testing plasma-integration 5.10.0-1 Qt Platform Theme integration plugins for the Plasma workspaces
x86_64 Testing user-manager 5.10.0-1 A simple system settings module to manage the users of your system
x86_64 Testing sqlite-tcl 3.19.2-2 sqlite Tcl Extension Architecture (TEA)
x86_64 Testing sqlite-analyzer 3.19.2-2 An analysis program for sqlite3 database files
x86_64 Testing sqlite-doc 3.19.2-2 most of the static HTML files that comprise this website, including all of the SQL Syntax and the C/C++ interface specs and other miscellaneous documentation
x86_64 Testing sqlite 3.19.2-2 A C library that implements an SQL database engine
x86_64 Testing fuse3 3.0.2-1 A library that makes it possible to implement a filesystem in a userspace program.
x86_64 Testing fuse-common 3.0.2-1 Common files for fuse2/3 packages
AUR
ramme 3.2.2-1
souffle-git r1390.2b4ccd0-1
jcdk-classic 3.0.5u1-2
jcdk-classic-doc 3.0.5u1-2
gogs-dev-git 0.11.12.0529+10+612a7e76f-1
mingw-w64-fontconfig 2.12.3-1
python-rofi 1.0.1-2
rshare 0.1.8-1
spirv-headers 1.2-1
noice-git 0.6.r2.g2f11fc5-1
dotnet-cli-git 2.0.0_preview2_006127-1
python2-humanize 0.5.1-3
python-eddy 0.2.5-1
bmusb 0.5.2-2
veusz 1.26
Thanks
Posted ImagePosted Image
Configs/PGP Key/comhack π
Also tagged with one or more of these keywords: arch linux, updates, securitybreach
