NEW UPDATES Archlinux
arch linux updates securitybreach
2025 replies to this topic
#1 OFFLINE   securitybreach
  • 23,098 posts
Posted 07 January 2010 - 02:12 AM
I know there are not a lot of Archlinux users right now but there are many that are interested. Bruno posted threads listing the updates for Debian, Slackware, Mandriva, PCLos, etc. So to stay in the spirit, I thought I would start a thread listing the updates for 32bit and 64bit Archlinux core, extra, community, and also the community-maintained AUR repos. Actually all the credit should go to Eric, since he thought of it first.Anyway, since Archlinux is a rolling distros there will be many updates daily. The main updates will have a description of the package but the AUR will not have a description. The reason being is the AUR packages have multiple versions of the same package. You will also notice there will be no security updates. The reason being is that Archlinux does not patch source packages except in rare cases and only if it is a security issue.
Packaging basically consists of fetching the source code from upstream, compiling it with relevant options, making sure that the package will be installed correctly on an Arch system and the main functionality of a package works. Packaging at Arch does not consist of adding new functionality or patches for existing bugs. This is the job of the upstream developer.
http://wiki.archlinu..._Bug_Guidelines
If you do not run Archlinux, you can use this thread to know when new versions of packages become available. They are not updated immediately but usually within a day or so. A lot of the AUR packages are devel or git versions so you can watch those versions as well.So here is the Thu, 07 Jan 2010 updates:
#2 OFFLINE   securitybreach
  • 23,098 posts
Posted 07 January 2010 - 01:53 PM
So here is the Fri, 08 Jan 2010 updates:Main:any  Extra  perl-exiftool 8.03-1         Reader and rewriter of EXIF informations that supports raw files     any  Extra perl-uri 1.52-1            Uniform Resource Identifiers (absolute and relative)any  Core   ca-certificates 20090814-2        Common CA certificates      i686  Core     run-parts 3.2.2-1           run scripts or programs in a directory i686  Extra     openldap 2.4.21-1       LDAP Server     i686  Core     libldap 2.4.21-1       Lightweight Directory Access Protocol (LDAP) client libraries         i686  Core     util-linux-ng 2.16.2-1       Miscellaneous system utilities for Linux      x86_64  Core     run-parts 3.2.2-1      run scripts or programs in a directory     x86_64  Extra   openldap  2.4.21-1        LDAP Server     andrea     x86_64  Core     libldap 2.4.21-1       Lightweight Directory Access Protocol (LDAP) client libraries    x86_64  Core     util-linux-ng 2.16.2-1       Miscellaneous system utilities for Linux     AUR:bsnes 0.059-1 snesfilter 0.008-1 snesreader 0.011-1supergameboy 0.015-1 xf86-video-intel-newest 2.10.0-2 t-prot 2.11-1 libxfce4ui-git 20100102-2 parole-media-player-git 20100107-1 icecat-i18n 3.5.7-1icecat 3.5.7g1-1Thanks
#3 OFFLINE   securitybreach
  • 23,098 posts
Posted 08 January 2010 - 03:10 AM
Updates for Fri, 08 Jan 2010 updates:[/b]Main:i686     Community  e-modules-extra-svn 44918-1     Extra gadgets for e17          i686     Community  e-svn 44948-1     Enlightenment window manager DR17 (aka e17) i686     Community  ecore-svn 44945-1     Ecore is an abstraction layer for e17          i686     Community  edje-svn 44912-1     A graphical design and layout library based on Evas          i686     Community  eet-svn 44906-1     A data storage and compression library          i686     Community  efreet-svn 44905-1     freedesktop.org specifications for e17          i686     Community  eina-svn 44898-1     E17 file chunk reading/writing library          i686     Community  embryo-svn 44547-1     implementation of a C like scripting language for e17          i686     Community  emesene 1.6-1     A pygtk MSN Messenger client          i686     Community  entrance-svn 44929-1     e17 login manager          i686     Community  esmart-svn 44582-1     A collection of evas smart objects.          i686     Community  evas-svn 44940-1     A hardware-accelerated canvas API for X-Windows          i686     Community  ewl-svn 44168-1     widget library for e17          i686     Community  e_dbus-svn 44846-1     dbus abstraction layer for e17          i686     Community  ffmpegthumbnailer 2.0.0-1     Lightweight video thumbnailer that can be used by file managers.          i686     Community  libev 3.9-1     A full-featured and high-performance event loop          i686     Community  sakura 2.3.6-1     A terminal emulator based on GTK and VTE        i686     Extra          openbox 3.4.10-1     A window manager for the X11 windowing system     i686     Community  lxappearance 0.4.0-1.0     GTK+ theme switcher of the LXDE Desktop (manages icons and fonts) i686     Community  dfm 0.99.9-2     A graphical file manager including desktop icons    i686     Community  dxpc 3.9.2-1     Differential X Protocol Compressor      i686     Community  echat 0.04beta1-2     vypress compatible ncurses chat i686     Community  fbgrab 1.0-4     A framebuffer screenshot grabber     i686     Community  gliv 1.9.6-2     OpenGL image vieweri686     Community  gnomesu 0.3.1-6     A program that allows a user to su to root in a Gnome environment.i686     Community  gshutdown 0.2-2     An advanced shutdown utilityi686     Community  icoutils 0.28.0-1     Extracts and converts images in MS Windows® icon and cursor filesi686     Community  logwatch 7.3.6-2     Logwatch is a customizable log analysis system.              i686     Community  awesome 3.4.3-2     A tiling window manager initialy based on a dwm code rewriting.      x86_64      Community  dfm 0.99.9-2      A graphical file manager including desktop iconsx86_64     Community   dxpc 3.9.2-1     Differential X Protocol Compressor      x86_64     Community   echat 0.04beta1-2     vypress compatible ncurses chat x86_64     Community   fbgrab 1.0-4     A framebuffer screenshot grabber      x86_64     Community   gliv 1.9.6-2     OpenGL image viewer    x86_64     Community   gnomesu 0.3.1-6     A program that allows a user to su to root in a Gnome environment.         x86_64     Community   gshutdown 0.2-2     An advanced shutdown utility          x86_64     Community   icoutils 0.28.0-1     Extracts and converts images in MS Windows® icon and cursor filesx86_64     Community   logwatch 7.3.6-2     Logwatch is a customizable log analysis system.          x86_64     Community   lxappearance 0.4.0-1.0     GTK+ theme switcher of the LXDE Desktop (manages icons and fonts)    x86_64     Extra            sbcl 1.0.34-1     Steel Bank Common Lisp    x86_64     Community  emesene 1.6-1     A pygtk MSN Messenger client          x86_64     Community  ffmpegthumbnailer 2.0.0-1     Lightweight video thumbnailer that can be used by file managers.          x86_64     Community  libev 3.9-1     A full-featured and high-performance event loop          x86_64     Community  sakura 2.3.6-1     A terminal emulator based on GTK and VTE          x86_64     Extra                    maxima 5.20.1-1     Maxima - a sophisticated computer algebra system              x86_64     Extra          openbox 3.4.10-1     A window manager for the X11 windowing system         x86_64     Community awesome 3.4.3-2     A tiling window manager initialy based on a dwm code rewriting.          AURplaneshift 0.5.0-1 g9led 1-1kernel26-ck 2.6.32.3-4coherence 0.6.6.2-1firefox-beta 3.6rc1-1python-pyev 0.5.3_3.8-1adplug 2.2-1ocp 0.1.18-1helixplayer-nightly-bin 11.1.1.2403-1  realplayer-nightly-bin 11.1.1.2402-1Thanks
#4 OFFLINE   securitybreach
  • 23,098 posts
Posted 08 January 2010 - 02:49 PM
Additional Updates for Fri, 08 Jan 2010:Main: i686i686     Core     kernel26     2.6.32.3-1     The Linux Kernel and modules          i686     Core     kernel26-firmware     2.6.32.3-1     The included firmware files of the Linux Kernel          i686     Core     kernel26-headers     2.6.32.3-1     Header files and scripts for building modules for kernel26          i686     Core     zlib     1.2.3.4-3     compression library implementing the deflate compression method found in gzip and PKZIP          i686     Community     lxappearance     0.4.0-2     GTK+ theme switcher of the LXDE Desktop (manages icons and fonts)          i686     Community     lxappearance     0.4.0-2     GTK+ theme switcher of the LXDE Desktop (manages icons and fonts)          i686     Extra     kdeedu-blinken     4.3.4-3     A memory enhancement game          i686     Extra     kdeedu-data     4.3.4-3     Data for KDE Educational Software          i686     Extra     kdeedu-kalgebra     4.3.4-3     Math Expression Solver and Plotter          i686     Extra     kdeedu-kalzium     4.3.4-3     KDE Periodic Table of Elements          i686     Extra     kdeedu-kanagram     4.3.4-3     KDE Letter Order Game          i686     Extra     kdeedu-kbruch     4.3.4-3     Practice exercises with fractions          i686     Extra     kdeedu-kgeography     4.3.4-3     A Geography Learning Program          i686     Extra     kdeedu-khangman 4.3.4-3      KDE Hangman Game            i686      Extra      kdeedu-kig      4.3.4-3      Explore Geometric Constructions            i686     Extra     kdeedu-kiten     4.3.4-3     Japanese Reference and Study Tool          i686     Extra     kdeedu-klettres     4.3.4-3     a KDE program to learn the alphabet          i686     Extra     kdeedu-kmplot     4.3.4-3     Function Plotter          i686     Extra     kdeedu-kstars     4.3.4-3     Desktop Planetarium          i686     Extra     kdeedu-ktouch     4.3.4-3     Touch Typing Tutor          i686     Extra     kdeedu-kturtle     4.3.4-3     Educational Programming Environment          i686     Extra     kdeedu-kwordquiz     4.3.4-3     A flashcard and vocabulary learning program          i686     Extra     kdeedu-libkdeedu     4.3.4-3     Support library for KDE Educational Softwarei686     Extra     kdeedu-marble     4.3.4-3     Desktop Globe          i686     Extra     kdeedu-parley     4.3.4-3     Vocabulary Trainer          i686     Extra     kdeedu-step     4.3.4-3     Simulate physics experiments          i686     Extra     libqalculate     0.9.7-1     Multi-purpose desktop calculator          i686     Extra     qalculate-gtk     0.9.7-1     GNOME frontend for libqalculate          i686     Extra     qalculate-kde     0.9.7-1     KDE frontend for libqalculate          i686     Extra     vde2     2.2.2-5     Virtual Distributed Ethernet for emulators like qemu       i686     Extra     vde2     2.2.2-5     Virtual Distributed Ethernet for emulators like qemu          X86_64x86_64      Core      kernel26      2.6.32.3-1      The Linux Kernel and modules            x86_64     Core     kernel26-firmware     2.6.32.3-1     The included firmware files of the Linux Kernel          x86_64     Core     kernel26-headers     2.6.32.3-1     Header files and scripts for building modules for kernel26          x86_64     Community     lxappearance     0.4.0-2     GTK+ theme switcher of the LXDE Desktop (manages icons and fonts)     angvp     x86_64     Extra     vde2     2.2.2-5     Virtual Distributed Ethernet for emulators like qemu          x86_64     Extra     maxima     5.20.1-1.1     Maxima - a sophisticated computer algebra system              x86_64     Extra     kdeedu-blinken     4.3.4-3     A memory enhancement game          x86_64     Extra     kdeedu-data     4.3.4-3     Data for KDE Educational Software          x86_64     Extra     kdeedu-kalgebra     4.3.4-3     Math Expression Solver and Plotter          x86_64     Extra     kdeedu-kalzium     4.3.4-3     KDE Periodic Table of Elements          x86_64     Extra     kdeedu-kanagram     4.3.4-3     KDE Letter Order Game          x86_64     Extra     kdeedu-kbruch     4.3.4-3     Practice exercises with fractions          x86_64     Extra     kdeedu-kgeography     4.3.4-3     A Geography Learning Program          x86_64     Extra     kdeedu-khangman     4.3.4-3     KDE Hangman Game          x86_64     Extra     kdeedu-kig     4.3.4-3     Explore Geometric Constructions          x86_64     Extra     kdeedu-kiten     4.3.4-3     Japanese Reference and Study Tool          x86_64     Extra     kdeedu-klettres     4.3.4-3     a KDE program to learn the alphabet          x86_64     Extra     kdeedu-kmplot     4.3.4-3     Function Plotter          x86_64     Extra     kdeedu-kstars     4.3.4-3     Desktop Planetarium          x86_64     Extra     kdeedu-ktouch     4.3.4-3     Touch Typing Tutor          x86_64     Extra     kdeedu-kturtle     4.3.4-3     Educational Programming Environment          x86_64     Extra     kdeedu-kwordquiz     4.3.4-3     A flashcard and vocabulary learning program          x86_64     Extra     kdeedu-libkdeedu     4.3.4-3     Support library for KDE Educational Software          x86_64     Extra     kdeedu-marble     4.3.4-3     Desktop Globe          x86_64     Extra     kdeedu-parley     4.3.4-3     Vocabulary Trainer          x86_64     Extra     kdeedu-step     4.3.4-3     Simulate physics experiments          x86_64     Extra     libqalculate     0.9.7-1     Multi-purpose desktop calculator          x86_64     Extra     qalculate-gtk     0.9.7-1     GNOME frontend for libqalculate          x86_64     Extra     qalculate-kde     0.9.7-1     KDE frontend for libqalculate          AURmplayer-rsound-svn libvalhalla 1.0.0-1 yad 0.0.8-1     libplayer 1.0.0-1     transmission-svn-gtk 9894-1     kmymoney 3.95.0-2 perl-cpanplus-dist-arch 0.16-1t-prot 2.12-1     csync 0.43.0-1     exalt-svn 43895-1     Thanks
#5 OFFLINE   securitybreach
  • 23,098 posts
Posted 09 January 2010 - 07:20 PM
Updates for Fri, 09 Jan 2010:Main: i686686      Core      ndiswrapper      1.55-4      Module for NDIS (Windows Network Drivers) drivers supplied by vendors. For stock arch 2.6 kernel.            i686     Core     tiacx     20080210-13     OpenSource module for Texas Instruments ACX100/ACX111 wireless chips. For stock arch 2.6 kernel     i686      Community      gcompris      9.0-2      Educational software suite comprising of numerous activities for children aged 2 to 10      foutrelis      i686     Community     gcompris-data     9.0-2     Data files for GCompris     foutrelis     i686     Community     virtualbox-modules     3.1.2-2     Kernel modules for VirtualBox     ibiru     i686     Community     virtualbox-ose     3.1.2-2     Powerful x86 virtualization for enterprise as well as home use (Open Source Edition)     ibiru     i686     Community     virtualbox-ose-additions     3.1.2-2     Guest Additions for VirtualBox (Open Source Edition)     ibiru     i686     Community     virtualbox-ose-additions-modules     3.1.2-2     Kernel modules for VirtualBox Guest Additions     ibiru     i686     Community     kpovmodeler     1.1.3-3     A graphical editor for povray scenes          i686     Community     acerhk     0.5.35-16     Acer hotkey driver          i686     Community     kaudiocreator     1.2.81-1     A program for ripping and encoding Audio-CDs, encoding files from disk          i686     Community     kcoloredit     2.0.0-4     A usefull tool that makes more easy and fun edit and create color          i686     Community     kfax     3.3.6-1     A fax file viewer for the KDE project          i686     Community     kgraphviewer     2.0.2-4     A Graphviz dot graph file viewer for KDE          i686     Community     kiconedit     4.3.3-1     Icon Editor          i686     Community     speakup     3.1.3-4     Kernel-based screenreader for the Linux console          i686     Community     apvlv     0.0.9-1     A PDF Viewer which behaves like Vim     shusmann     i686     Community     mathomatic     15.0.3-1     General purpose Computer Algebra System written in C     shusmann     i686      Extra      hylafax      6.0.4-1      Fax Server            i686     Extra     nvidia     190.53-3     NVIDIA drivers for kernel26.          i686     Extra     partitionmanager     1.0.1-1     A KDE 4 utility that allows you to manage disks, partitions, and file systems.          i686     Extra     kmldonkey     2.0.2-4     An MLDonkey frontend for KDE          i686     Extra     mercurial     1.4.2-1     A scalable distributed SCM tool          i686     Extra     fcpci     31107-51     AVM ISDN driver for FRITZ PCI isdn cards. For stock arch 2.6 kernel.          i686     Extra     fcpcmcia     31107-49     AVM ISDN driver for FRITZ PCMCIA isdn cards. For stock arch 2.6 kernel          i686     Extra     intel-536ep     2.56.76.0-63     Intel Modem Drivers for 536EP chipset. For stock arch 2.6 kernel          i686     Extra     intel-537     2.60.80.0-65     Intel Modem Drivers for 537 chipsets. For stock arch 2.6 kernel          i686     Extra     lirc     0.8.6-3     Linux Infrared Remote Control kernel modules for stock arch kernel     hugo     i686     Extra     madwifi     0.9.4.4100-2     Madwifi drivers for Atheros wireless chipsets. For stock arch 2.6 kernel          i686     Extra     martian     20080625-8     Alternative driver for the Agere Systems PCI WinModem.          i686     Extra     nouveau-drm     0.0.15_20091220-2     nvidia opensource X driver     andyrtr     i686     Extra     nvidia-173xx     173.14.22-3     NVIDIA drivers for kernel26, 173xx branch.          i686     Extra     nvidia-96xx     96.43.14-3     NVIDIA drivers for kernel26, 96xx branch.          i686     Extra     slmodem     2.9.11-49     Drivers for the Smartlink winmodems. For stock arch 2.6 kernel          i686     Extra     aufs2     2.6.32_20091203-2     Another Unionfs Implementation      X86_64x86_64      Core      ndiswrapper      1.55-4      Module for NDIS (Windows Network Drivers) drivers supplied by vendors. For stock arch 2.6 kernel.  x86_64     Core     tiacx     20080210-13     OpenSource module for Texas Instruments ACX100/ACX111 wireless chips. For stock arch 2.6 kernelx86_64      Community      gcompris      9.0-2      Educational software suite comprising of numerous activities for children aged 2 to 10 x86_64     Community     gcompris-data     9.0-2     Data files for GCompris x86_64     Community     apvlv     0.0.9-1     A PDF Viewer which behaves like Vimx86_64     Community     mathomatic     15.0.3-1     General purpose Computer Algebra System written in Cx86_64      Extra      hylafax      6.0.4-1      Fax Server x86_64     Extra     nvidia     190.53-3     NVIDIA drivers for kernel26. x86_64     Extra     partitionmanager     1.0.1-1     A KDE 4 utility that allows you to manage disks, partitions, and file systems.     x86_64     Extra     mercurial     1.4.2-1     A scalable distributed SCM tool     x86_64     Extra     fcpci     31107-51     AVM ISDN driver for FRITZ PCI isdn cards. For stock arch 2.6 kernel.     x86_64     Extra     fcpcmcia     31107-49     AVM ISDN driver for FRITZ PCMCIA isdn cards. For stock arch 2.6 kernel     x86_64     Extra     lirc     0.8.6-3     Linux Infrared Remote Control kernel modules for stock arch kernel     x86_64     Extra     madwifi     0.9.4.4100-2     Madwifi drivers for Atheros wireless chipsets. For stock arch 2.6 kernel     x86_64     Extra     nouveau-drm     0.0.15_20091220-2     nvidia opensource X driverx86_64     Extra     nvidia-173xx     173.14.22-3     NVIDIA drivers for kernel26, 173xx branch.x86_64     Extra     nvidia-96xx     96.43.14-3     NVIDIA drivers for kernel26, 96xx branch.x86_64     Extra     aufs2     2.6.32_20091203-2     Another Unionfs Implementation     AUR:kernel26-pentium-m 2.6.32.2-1     ming 0.4.2-2     initscripts-splashygnunet-qt 0.8.1-1wally 2.3.1-1     sane-dev 1.0.21-3puppet 0.25.2-1 machinarium 3-2quanta 3.5.10-1sink 0.0.1a-1     Thanks
#6 OFFLINE   securitybreach
  • 23,098 posts
Posted 10 January 2010 - 10:53 PM
Updates for Sat, 10 Jan 2010:Main: i686i686      Core      inetutils      1.7-1      A collection of common network programs            i686      Core     kernel26-lts     2.6.27.43-1     The Linux Kernel and modules - stable longtime supported kernel package suitable for servers          i686      Core     kernel26-lts-headers     2.6.27.43-1     Header files and scripts for building modules for kernel26-ltsi686      Community      blobwars      1.14_1-1      Platform action game featuring a variety of different weaponry and multiple objectivesi686      Community     kid3     1.3-1     An MP3, Ogg/Vorbis and FLAC tag editor for KDE     i686      Community     ogmrip     0.13.3-2     Libraries and GTK2 interface for DVD ripping using mencoder     i686      Community     pympd     0.08.1-1     A Rhythmbox-like PyGTK+ client for Music Player Daemon     i686      Community     krecipes     2.0alpha5-1     A tool designed to make organizing your personal recipes collection fast and easy.          i686      Extra      freeglut    2.6.0-1        Provides functionality for small OpenGL programsX86_64x86_64     Core      inetutils      1.7-1      A collection of common network programs            x86_64     Core     kernel26-lts     2.6.27.43-1     The Linux Kernel and modules - stable longtime supported kernel package suitable for servers    x86_64     Core     kernel26-lts-headers     2.6.27.43-1     Header files and scripts for building modules for kernel26-ltsx86_64     Community      e-modules-extra-svn      44918-1      Extra gadgets for e17            x86_64     Community     e-svn     44948-1     Enlightenment window manager DR17 (aka e17)          x86_64     Community     ecore-svn     44945-1     Ecore is an abstraction layer for e17          x86_64     Community     edje-svn     44912-1     A graphical design and layout library based on Evas          x86_64     Community     eet-svn     44906-1     A data storage and compression library          x86_64     Community     efreet-svn     44905-1     freedesktop.org specifications for e17          x86_64     Community     eina-svn     44898-1     E17 file chunk reading/writing library          x86_64     Community     entrance-svn     44929-1     e17 login manager          x86_64     Community     evas-svn     44940-1     A hardware-accelerated canvas API for X-Windows          x86_64     Community     blobwars     1.14_1-1     Platform action game featuring a variety of different weaponry and multiple objectives     x86_64     Community     kid3     1.3-1     An MP3, Ogg/Vorbis and FLAC tag editor for KDE     x86_64     Community     ogmrip     0.13.3-2     Libraries and GTK2 interface for DVD ripping using mencoder    x86_64     Community     pympd     0.08.1-1     A Rhythmbox-like PyGTK+ client for Music Player Daemon     x86_64     Community     speakup     3.1.3-4     Kernel-based screenreader for the Linux console     cbrannon     x86_64        Extra                    freeglut    2.6.0-1        Provides functionality for small OpenGL programsAUR:firefox-pgo-minefield-smp 100108-1cherrytree 0.8.2-1yasat 207-1faangband 1.0.3-1kernel26-fedora-devel-pae 2.6.32.3-1kernel26-fedora-pae 2.6.32.3-1libjpeg6 6b-9     lrcshow-x 1.3.3-1     swiftfox-i686 3.5.7-1swiftfox-prescott 3.5.7-1     Thanks
#7 OFFLINE   securitybreach
  • 23,098 posts
Posted 12 January 2010 - 12:08 AM
Updates for Sum, 11 Jan 2010:Main: i686i686        Core     nfs-utils 1.2.1-3       Support programs for Network File Systemsi686      Community      acerhk  0.5.35-17      Acer hotkey driver        i686     Community     tcpflow     0.21-4     Captures data transmitted as part of TCP connections then stores the data conveniently      i686     Community     clive     2.2.8-1     Video extraction/download tool for youtube and other websites.     i686     Community     nfoview     1.8-1     Simple GTK-based NFO file and CP437 ASCII art viewer      i686      Extra      amarok      2.2.2-1      A media player for KDE        i686     Extra     live-media     2010.01.11-1     A set of C++ libraries for multimedia streaming     giovanni i686     Extra     seamonkey     2.0.2-1     SeaMonkey internet suite      i686     Extra     strigi     0.7.1-1     Fast crawling desktop search engine with Qt4 GUI      i686     Extra     qtcurve-gtk2     1.0.1-1     A configurable set of widget styles for KDE and Gtk      i686     Extra     qtcurve-kde4     1.0.1-1     A configurable set of widget styles for KDE and Gtk      i686     Extra     deluge     1.2.0-1     A bittorrent client written with python and pygtk      i686     Extra     cdrdao     1.2.3-1     Records audio/data CD-Rs in disk-at-once (DAO) mode      i686     Extra     cdrkit     1.1.10-1     Suite of programs for CD/DVD recording, ISO image creation, and audio CD extraction      i686     Extra     transfig     3.2.5c-1     Format conversion utility that can be used with xfig      i686     Extra     xfig     3.2.5b-2     An interactive drawing tool      i686     Extra     gtk     1.2.10-10     The GTK+ toolkit      any      Extra      python-mako      0.2.5-1      Hyperfast and lightweight templating for the Python platform.        any      Community      pygments      1.2.2-1      Python syntax highlighter      foutrelis  any     Community     perl--arch     1.0.25-1  Arch-specific Perl modules.      any     Community     perl--common     1.0.3-1  common Perl modules.      any     Community     powerpill     17.0-3     A wrapper for pacman that speeds up package retrieval by using aria2c for concurrent/segmented downloads.      any      Community      reflector      5.0-2      A script to retrieve and filter the latest mirrorlist from the MirrorStatus page.        any      Community      youtube-dl      2010.01.06-1      A small command-line program to download videos from YouTube.com      X86_64x86_64  Core     nfs-utils 1.2.1-3       Support programs for Network File Systemsx86_64      Community      kaudiocreator      1.2.81-1      A program for ripping and encoding Audio-CDs, encoding files from disk        x86_64     Community     kcoloredit     2.0.0-4     A usefull tool that makes more easy and fun edit and create color      x86_64     Community     kfax     3.3.6-1     A fax file viewer for the KDE project      x86_64     Community     kgraphviewer     2.0.2-4     A Graphviz dot graph file viewer for KDE      x86_64     Community     kiconedit     4.3.3-1     Icon Editor      x86_64     Community     kpovmodeler     1.1.3-3     A graphical editor for povray scenes      x86_64     Community     tcpflow     0.21-4     Captures data transmitted as part of TCP connections then stores the data conveniently      x86_64     Community     clive     2.2.8-1     Video extraction/download tool for youtube and other websites.     x86_64     Community     nfoview     1.8-1     Simple GTK-based NFO file and CP437 ASCII art viewer      x86_64      Extra      live-media      2010.01.11-1      A set of C++ libraries for multimedia streaming      giovanni  x86_64     Extra     seamonkey     2.0.2-1     SeaMonkey internet suite     jgc x86_64     Extra     strigi     0.7.1-1     Fast crawling desktop search engine with Qt4 GUI      x86_64     Extra     cdrdao     1.2.3-1     Records audio/data CD-Rs in disk-at-once (DAO) mode      x86_64     Extra     cdrkit     1.1.10-1     Suite of programs for CD/DVD recording, ISO image creation, and audio CD extraction      x86_64     Extra     deluge     1.2.0-1     A bittorrent client written with python and pygtk      x86_64     Extra     qtcurve-gtk2     1.0.1-1     A configurable set of widget styles for KDE and Gtk      x86_64     Extra     qtcurve-kde4     1.0.1-1     A configurable set of widget styles for KDE and Gtk     pierre x86_64     Extra     transfig     3.2.5c-1     Format conversion utility that can be used with xfig      x86_64     Extra     xfig     3.2.5b-2     An interactive drawing tool      x86_64     Extra     gtk     1.2.10-10     The GTK+ toolkit      x86_64     Extra     kmldonkey     2.0.2-4     An MLDonkey frontend for KDE      AUR:memaker 1.5-4     nginx-unstable 0.8.32-1editra 0.5.32-1     jpen 2.100101-1     alchemy 008-1     sentinella 0.5.0-1     libsysactivity 0.3.1-1     firefox-pgo-minefield-smpsge 030809-1     linapple 1.1b-2 Thanks
#8 OFFLINE   securitybreach
  • 23,098 posts
Posted 14 January 2010 - 12:45 AM
Updates for Wed, 13 Jan 2010:Main: Anyany      Community      perl--arch      1.0.34-1      's Arch-specific Perl modules.            any     Community     dot2tex     2.8.7-1     Graphviz to LaTeX converter          any     Community     limewire     5.4.6-1     A popular gnutella client          any     Core     mkinitcpio     0.5.28-1     Advanced, modular initramfs image creation utility          i686i686    Core    rp-pppoe 3.10-2        Roaring Penguin's Point-to-Point Protocol over Ethernet clienti686      Community      clang      2.6-6.1      C language family frontend for LLVM            i686     Community     clang-analyzer     2.6-6.1     A source code analysis framework          i686     Community     llvm     2.6-6.1     Low Level Virtual Machine          i686     Community     llvm-ocaml     2.6-6.1     OCaml bindings for LLVM          i686     Community     dvdstyler     1.7.4_3-3     Cross-platform DVD authoring application          i686     Community     emprint-svn     42925-2     screenshot module for e17          i686     Community     engrave-svn     40228-4     A library for editing the contents of an edje .eet file.          i686     Community     exml-svn     40505-3     Xml parser for e17.          i686     Community     cherokee     0.99.39-2     A very fast, flexible and easy to configure Web Server          i686     Community     cinelerra-cv     20100111-1     A complete audio and video production environment for Linux.          i686     Community     ffmpeg2theora     0.25-1     A simple converter to create Ogg Theora files          i686     Community     ffmpegthumbnailer     2.0.0-2     Lightweight video thumbnailer that can be used by file managers.          i686     Community     libquicktime     1.1.4-1     A library for reading and writing quicktime files.          i686     Community     mlt     0.4.10-2     An open source multimedia framework          i686     Community     wxsvg     1.0.2-2     C++ library to create, manipulate and render SVG files          i686     Community     chuck     1.2.1.3-2     Concurrent, on-the-fly audio programming language.          i686     Community     gkrellm     2.3.4-1     System monitor package for GTK2          i686     Community     kdesvn     1.5.0-1     A pure C++ SVN-client for KDE         i686     Community     blackbox     0.70.1-8     A window manager for X11          i686     Community     libconfig     1.4.1-1     C/C++ Configuration File Library          i686     Community     xbmc     9.11-5     XBMC Media Center          i686      Extra      amarok      2.2.2-2      A media player for KDE            i686     Extra     muse     1.0-1     A MIDI/Audio sequencer with recording and editing capabilities          i686     Extra     qca     2.0.2-2     Qt Cryptographic Architecture     pierre     i686     Extra     qca-ossl     2.0.0-2     Qt Cryptographic Architecture     andrea     i686     Extra     avidemux-cli     2.5.2-1     A graphical tool to edit video (filter/re-encode/split)          i686     Extra     avidemux-gtk     2.5.2-1     A graphical tool to edit video (filter/re-encode/split) - GTK GUI          i686     Extra     avidemux-qt     2.5.2-1     A graphical tool to edit video (filter/re-encode/split) - QT GUI          i686     Extra     audacious-plugins     2.2-4     Plugins for Audacious          i686     Extra     cmus     2.2.0-10     A very feature-rich ncurses-based music player          i686     Extra     ffmpeg     20100108-2     Complete and free Internet live audio and video broadcasting solution for Linux/Unix          i686     Extra     gstreamer0.10-ugly     0.10.13-3     GStreamer Multimedia Framework Ugly plugin libraries          i686     Extra     gstreamer0.10-ugly-plugins     0.10.13-3     GStreamer Multimedia Framework Ugly Plugins (gst-plugins-ugly)          i686     Extra     motion     3.2.11.1-2     A software motion detector. It grabs images from video4linux devices and/or from webcams.          i686     Extra     mpd     0.15.7-1     Music daemon that plays MP3, FLAC, and Ogg Vorbis files     andrea     i686     Extra     mplayer     30286-1     A movie player for linux     hugo     i686     Extra     opencore-amr     0.1.2-1     Open source implementation of the Adaptive Multi Rate (AMR) speech codec          i686     Extra     opencv     2.0.0-3     Intel® Open Source Computer Vision Library          i686     Extra     sox     14.3.0-2     The Swiss Army knife of sound processing tools          i686     Extra     telepathy-qt4     0.2.1-1     A library for Qt-based Telepathy clients.          i686     Extra     transcode     1.1.5-2     A video/DVD ripper and encoder for the terminal/console.          i686     Extra     vlc     1.0.4-2     A multi-platform MPEG, VCD/DVD, and DivX player          i686     Extra     vlc-plugin     1.0.4-2     VLC mozilla browser plugin          i686     Extra     x264     20100i686    Core    i686    Extra     xine-lib     1.1.17-2     A free video player for Unix          X86_64x86_64    Core    rp-pppoe 3.10-2        Roaring Penguin's Point-to-Point Protocol over Ethernet client107-1     free library for encoding H264/AVC video streams      x86_64      Community      chuck      1.2.1.3-2      Concurrent, on-the-fly audio programming language.            x86_64     Community     dvdstyler     1.7.4_3-3     Cross-platform DVD authoring application          x86_64     Community     emprint-svn     42925-2     screenshot module for e17          x86_64     Community     engrave-svn     40228-4     A library for editing the contents of an edje .eet file.          x86_64     Community     exml-svn     40505-3     Xml parser for e17.          x86_64     Community     cherokee     0.99.39-2     A very fast, flexible and easy to configure Web Server          x86_64     Community     cinelerra-cv     20100111-1     A complete audio and video production environment for Linux.          x86_64     Community     ffmpeg2theora     0.25-1     A simple converter to create Ogg Theora files          x86_64     Community     ffmpegthumbnailer     2.0.0-2     Lightweight video thumbnailer that can be used by file managers.          x86_64     Community     libquicktime     1.1.4-1     A library for reading and writing quicktime files.          x86_64     Community     mlt     0.4.10-2     An open source multimedia framework          x86_64     Community     wxsvg     1.0.2-2     C++ library to create, manipulate and render SVG files          x86_64     Community     gkrellm     2.3.4-1     System monitor package for GTK2          x86_64     Community     kdesvn     1.5.0-1     A pure C++ SVN-client for KDE          x86_64     Community     blackbox     0.70.1-8     A window manager for X11          x86_64     Community     libconfig     1.4.1-1     C/C++ Configuration File Library          x86_64     Community     xbmc     9.11-5     XBMC Media Center          x86_64      Extra      muse      1.0-1      A MIDI/Audio sequencer with recording and editing capabilities            x86_64     Extra     qca     2.0.2-2     Qt Cryptographic Architecture          x86_64     Extra     qca-ossl     2.0.0-2     Qt Cryptographic Architecture     andrea     x86_64     Extra     avidemux-cli     2.5.2-1     A graphical tool to edit video (filter/re-encode/split)          x86_64     Extra     avidemux-gtk     2.5.2-1     A graphical tool to edit video (filter/re-encode/split) - GTK GUI          x86_64     Extra     avidemux-qt     2.5.2-1     A graphical tool to edit video (filter/re-encode/split) - QT GUI          x86_64     Extra     audacious-plugins     2.2-4     Plugins for Audacious          x86_64     Extra     cmus     2.2.0-10     A very feature-rich ncurses-based music player          x86_64     Extra     ffmpeg     20100108-2     Complete and free Internet live audio and video broadcasting solution for Linux/Unix          x86_64     Extra     gstreamer0.10-ugly     0.10.13-3     GStreamer Multimedia Framework Ugly plugin libraries          x86_64     Extra     gstreamer0.10-ugly-plugins     0.10.13-3     GStreamer Multimedia Framework Ugly Plugins (gst-plugins-ugly)          x86_64     Extra     motion     3.2.11.1-2     A software motion detector. It grabs images from video4linux devices and/or from webcams.          x86_64     Extra     mpd     0.15.7-1     Music daemon that plays MP3, FLAC, and Ogg Vorbis files     andrea     x86_64     Extra     mplayer     30286-1     A movie player for linux     hugo     x86_64     Extra     opencore-amr     0.1.2-1     Open source implementation of the Adaptive Multi Rate (AMR) speech codec          x86_64     Extra     opencv     2.0.0-3     Intel® Open Source Computer Vision Library          x86_64     Extra     sox     14.3.0-2     The Swiss Army knife of sound processing tools          x86_64     Extra     telepathy-qt4     0.2.1-1     A library for Qt-based Telepathy clients.          x86_64     Extra     transcode     1.1.5-2     A video/DVD ripper and encoder for the terminal/console.          x86_64     Extra     vlc     1.0.4-2     A multi-platform MPEG, VCD/DVD, and DivX player          x86_64     Extra     vlc-plugin     1.0.4-2     VLC mozilla browser plugin          x86_64     Extra     x264     20100107-1     free library for encoding H264/AVC video streams          x86_64     Extra     xine-lib     1.1.17-2     A free video player for Unix          AUR:chromium-codecs-ffmpeg-nonfree-bin calibre 0.6.33-1gecode 3.2.2-10acroread-ja 9.3-1opale 1.0-1bin32-acroread-ja 9.2-1pino 0.1.3-1nicovideo-dl 0.0.20091209-1python-wnck 2.29.1-1blueproximity 1.2.5-1Thanks
#9 OFFLINE   securitybreach
  • 23,098 posts
Posted 15 January 2010 - 02:49 AM
Updates for Thurs, 14 Jan 2010:Main: Anyany     Extra     texlive-langextra     2009.15878-3     TeX Live - Bundle of all extra language support          any     Extra     texlive-langgreek     2009.16179-1     TeX Live - Fonts and support for typesetting Greek          any     Extra     texlive-latex3     2009.16491-1     TeX Live - LaTeX3 packages          any     Extra     texlive-latexextra     2009.16666-1     TeX Live - Large collection of add-on packages for LaTeX          any     Extra     texlive-music     2009.15878-2     TeX Live - Music typesetting packages          any     Extra     texlive-pictures     2009.16576-1     TeX Live - Packages for drawings graphics          any     Extra     texlive-plainextra     2009.16629-1     TeX Live - A collection of add-on packages and macros for plain TeX          any     Extra     texlive-pstricks     2009.16633-1     TeX Live - Additional PSTricks packages          any     Extra     texlive-publishers     2009.16512-1     TeX Live - LaTeX classes and packages for specific publishers          any     Extra     texlive-science     2009.16539-1     TeX Live - Typesetting for natural and computer sciences          any      Extra      texlive-langcyrillic      2009.16188-1      TeX Live - Fonts and macro packages to typeset Cyrillic texts            i686i686     Community     haskell-x11     1.5.0.0-1     A Haskell binding to the X11 graphics library.          i686     Community     haskell-x11-xft     0.3-11     Bindings to the Xft, X Free Type interface library, and some Xrender parts          i686     Community     cabal-install     0.8.0-1.1     The command-line interface for Cabal and Hackage.          i686     Community     haskell-http     4000.0.9-1.1     A library for client-side HTTP          i686      Extra      haskell-regex-posix      0.94.1-1.1      The posix regex backend for regex-base            i686     Extra     haskell-utf8-string     0.3.6-2.1     Support for reading and writing UTF8 Strings          i686     Extra     haskell-zlib     0.5.2.0-2.1     Compression and decompression in the gzip and zlib formats          i686     Extra     claws-mail     3.7.4-1     A GTK+ based e-mail client.          i686     Extra     claws-mail-extra-plugins     3.7.4-1     Extra plugins for claws-mail          i686     Extra     libchamplain     0.4.3-1     C library aimed to provide a Gtk+ widget to display rasterized maps          i686     Extra     vlc     1.0.4-3     A multi-platform MPEG, VCD/DVD, and DivX player          i686     Extra     vlc-plugin     1.0.4-3     VLC mozilla browser plugin          i686     Community     yaws     1.87-1     Yet Another Web Server -- The pure Erlang HTTP server/framework          i686     Extra     erlang     R13B03-1     A small concurrent functional programming language developed by Ericsson.          i686     Extra     ghc     6.12.1-2     The Glasgow Haskell Compiler          2010-01-1i686     Extra     haskell-dataenc     0.13.0.2-2.1     Monad transformer library          i686     Extra     haskell-hashed-storage     0.3.9-3.1     Hashed file storage support code.          i686     Extra     haskell-haskeline     0.6.2.2-2     A command-line interface for user input, written in Haskell.          i686     Extra     haskell-html     1.0.1.2-2     HTML combinator library          i686     Extra     haskell-mmap     0.4.1-2.1     Memory mapped files for POSIX and Windows          i686     Extra     haskell-parsec     3.0.1-2.1     Monadic parser combinators          i686     Extra     haskell-regex-base     0.93.1-2.1     Interface API for regex-posix,pcre,parsec,tdfa,dfa          i686     Extra     haskell-regex-compat     0.92-2.1     X86_64x86_64     Community     haskell-x11     1.5.0.0-1     A Haskell binding to the X11 graphics library.          x86_64     Community     haskell-x11-xft     0.3-11     Bindings to the Xft, X Free Type interface library, and some Xrender parts          x86_64     Community     yaws     1.87-1     Yet Another Web Server -- The pure Erlang HTTP server/framework          x86_64     Community     cabal-install     0.8.0-1.1     The command-line interface for Cabal and Hackage.          x86_64     Community     haskell-http     4000.0.9-1.1     A library for client-side HTTP          x86_64     Extra     ghc     6.12.1-2     The Glasgow Haskell Compiler          x86_64     Extra     haskell-dataenc     0.13.0.2-2.1     Monad transformer library          x86_64     Extra     haskell-hashed-storage     0.3.9-3.1     Hashed file storage support code.          x86_64     Extra     haskell-haskeline     0.6.2.2-2     A command-line interface for user input, written in Haskell.          x86_64     Extra     haskell-html     1.0.1.2-2.1     HTML combinator library          x86_64     Extra     haskell-mmap     0.4.1-2.1     Memory mapped files for POSIX and Windows          x86_64     Extra     haskell-parsec     3.0.1-2.1     Monadic parser combinators          x86_64     Extra     haskell-regex-base     0.93.1-2.1     Interface API for regex-posix,pcre,parsec,tdfa,dfa          x86_64     Extra     haskell-regex-compat     0.92-2.1              x86_64     Extra     haskell-regex-posix     0.94.1-1.1     The posix regex backend for regex-base          x86_64     Extra     haskell-utf8-string     0.3.6-2.1     Support for reading and writing UTF8 Strings          x86_64     Extra     haskell-zlib     0.5.2.0-2.1     Compression and decompression in the gzip and zlib formats          x86_64     Extra     erlang     R13B03-1     A small concurrent functional programming language developed by Ericsson.          x86_64     Extra     claws-mail     3.7.4-1     A GTK+ based e-mail client.          x86_64     Extra     claws-mail-extra-plugins     3.7.4-1     Extra plugins for claws-mail          x86_64     Extra     libchamplain     0.4.3-1     C library aimed to provide a Gtk+ widget to display rasterized maps          x86_64     Extra     vlc     1.0.4-3     A multi-platform MPEG, VCD/DVD, and DivX player          x86_64     Extra     vlc-plugin     1.0.4-3     VLC mozilla browser plugin     AUR:transmission-svn-gtk 9940-1nodejs 0.1.25-1     Fri, 15 nodejs-git 0.1.24-38     New! Fri, 15 fbsplash-theme-natural-arch 1.0.0-2bootsplash-fb 1.0.0-2     chromium-codecs-ffmpeg-nonfree-bin 36264-1google-chrome-dev 4.0.295.0-1 wm-session-git 20100113-1ttf-meguri 20100114-1 ttf-komatuna 20100114-1     Thanks
#10 OFFLINE   securitybreach
  • 23,098 posts
Posted 15 January 2010 - 11:38 PM
Updates for Fri, 15 Jan 2010:Main: Anyany      Community      atool      0.37.0-3      A script for managing file archives of various types            any     Community     bar     1.4-1     A script for showing progress bars.          any     Community     dot2tex     2.8.7-1     Graphviz to LaTeX converter          any     Community     griffith     0.10-2     Movie collection manager application          any     Community     jbidwatcher     2.1pre5-1     A Java-based application allowing you to monitor auctions you're not part of, submit bids, snipe, and track your auction-site experience.          any     Community     jedit     4.3-1     Java based extensible text editor          any     Community     openttd-opengfx     0.2.0-2     Free graphics set for openttd          any     Community     openttd-opensfx     0.2.1-2     Free sound set for openttd          any     Community     ruby-htmlentities     4.2.0-2     A fast and liberal HTML parser for Ruby.          any     Community     vim-surround     1.34-4     A Vim plugin that provides mappings to easily delete, change, and add paired "surroundings"          any     Community     xcursor-bluecurve     0.1.1-1     Redhat's Bluecurve X mouse cursor theme          any     Community     postgrey     1.32-2     a Postfix policy server implementing greylisting          any     Community     wanderlust     2.15.9-1     Mail/News reader supporting IMAP4rev1 for emacs.          any     Community     perl--common     1.0.5-1     's common Perl modules.      i686i686      Core      expat      2.0.1-5      An XML Parser library written in C            i686     Core     xfsprogs     3.1.0-1     XFS filesystem utilities          i686      Community      qbittorrent      2.0.7-1      A bittorrent client written in C++ / Qt4 using the good libtorrent library            i686     Community     recoll     1.13.01-1     Full text search tool based on Xapian backend          i686     Community     amaya     11.3.1-1     W3C's Editor/Browser          i686     Community     checkinstall     1.6.2-1     spy for 'make install' and build rpm or deb          i686     Community     freewrl     1.22.6-1     VRML viewer          i686     Community     xfe     1.32.1-1     X File Explorer (Xfe) is an MS-Explorer like file manager for X.          i686     Community     gmerlin-avdecoder     1.0.1-1     Media decoding library          i686     Community     picard     0.12.1-2     Next generation MusicBrainz tagging application (QT4 interface)          i686      Extra      getmail      4.16.0-1      A POP3 mail retriever with reliable Maildir and command delivery.            i686     Extra     libxfcegui4     4.6.2-1     Various gtk widgets for Xfce          i686     Extra     amarok     2.2.2-3     A media player for KDE          i686     Extra     samba     3.4.4-1.1     Tools to access a server's filespace and printers via SMB          i686     Extra     smbclient     3.4.4-1.1     Tools to access a server's filespace and printers via SMB          i686     Extra     live-media     2010.01.13-1     A set of C++ libraries for multimedia streaming          i686     Extra     mpc     0.19-1     Minimalist command line interface to MPD          i686     Extra     ncmpc     0.16-1     A ncurses (command line) interface for MPD          i686     Extra     openbox     3.4.10-2     A window manager for the X11 windowing system          i686     Extra     synergy     1.3.1-7     Share a single mouse and keyboard between multiple pcs          i686     Extra     xvidcap     1.1.7-2     A small tool to capture things going on on an X-Windows display to either individual frames or an MPEG video          i686     Extra     xfsdump     3.0.4-1     Additional XFS filesystem utilities          i686     Extra     haskell-network     2.2.1.7-1.1     Networking-related facilities          i686     Extra     openoffice-base-beta     3.2.0_ooo320_m9-1     OpenOffice.org - a free multiplatform and multilingual office suite - testing branch leeding to next stable release          i686     Extra     openoffice-base-devel     3.3_dev300_m69-1     OpenOffice.org - a free multiplatform and multilingual office suite - developement branch          i686     Extra     openoffice-sdk-beta     3.2.0_ooo320_m9-1     OpenOffice.org SDK - development files for beta branch pkg          i686     Extra     openoffice-sdk-devel     3.3_dev300_m69-1     OpenOffice.org SDK - development files - for devel branch pkg          X86_64x86_64      Core      expat      2.0.1-5      An XML Parser library written in C            x86_64     Core     xfsprogs     3.1.0-1     XFS filesystem utilities          x86_64      Community      qbittorrent      2.0.7-1      A bittorrent client written in C++ / Qt4 using the good libtorrent library            x86_64     Community     recoll     1.13.01-1     Full text search tool based on Xapian backend          x86_64     Community     amaya     11.3.1-1     W3C's Editor/Browser          x86_64     Community     checkinstall     1.6.2-1     spy for 'make install' and build rpm or deb          x86_64     Community     freewrl     1.22.6-1     VRML viewer          x86_64     Community     xfe     1.32.1-1     X File Explorer (Xfe) is an MS-Explorer like file manager for X.          x86_64     Community     gmerlin-avdecoder     1.0.1-1     Media decoding library          x86_64     Community     picard     0.12.1-2     Next generation MusicBrainz tagging application (QT4 interface)          x86_64      Extra      getmail      4.16.0-1      A POP3 mail retriever with reliable Maildir and command delivery.            x86_64     Extra     libxfcegui4     4.6.2-1     Various gtk widgets for Xfce          x86_64     Extra     amarok     2.2.2-3     A media player for KDE          x86_64     Extra     live-media     2010.01.13-1     A set of C++ libraries for multimedia streaming          x86_64     Extra     mpc     0.19-1     Minimalist command line interface to MPD          x86_64     Extra     ncmpc     0.16-1     A ncurses (command line) interface for MPD          x86_64     Extra     openbox     3.4.10-2     A window manager for the X11 windowing system          x86_64     Extra     synergy     1.3.1-7     Share a single mouse and keyboard between multiple pcs          x86_64     Extra     xvidcap     1.1.7-2     A small tool to capture things going on on an X-Windows display to either individual frames or an MPEG video          x86_64     Extra     xfsdump     3.0.4-1     Additional XFS filesystem utilities          x86_64     Extra     haskell-network     2.2.1.7-1.1     Networking-related facilities          x86_64     Extra     openoffice-base-beta     3.2.0_ooo320_m9-1     OpenOffice.org - a free multiplatform and multilingual office suite - testing branch leeding to next stable release          x86_64     Extra     openoffice-base-devel     3.3_dev300_m69-1     OpenOffice.org - a free multiplatform and multilingual office suite - developement branch          x86_64     Extra     openoffice-sdk-beta     3.2.0_ooo320_m9-1     OpenOffice.org SDK - development files for beta branch pkg          x86_64     Extra     openoffice-sdk-devel     3.3_dev300_m69-1     OpenOffice.org SDK - development files - for devel branch pkg          AUR:stockfish 1.6.2-1 wt-git 20100116-1ocp 0.1.18-2     huck-jack 1.2.1.3-2     archey 0.1-7     bashstyle 7.9-1     eagle 5.7.0-1     guayadeque 0.2.3-1louderbox 0.1.0-1     qutecom-hg 464-1 Thanks
#11 OFFLINE   securitybreach
  • 23,098 posts
Posted 17 January 2010 - 02:10 PM
I did not have a chance to update the post yesterday so here isUpdates for Sat, 16 Jan 2010:Main: Anyany      Community      rai-qt      0.3.2-3      This script uses kdialog to generate a list of italian rai's channels            any     Extra     perl-libwww     5.833-3     A set of Perl modules which provides a simple and consistent API to the WWW.          any     Community-Testing     python-sqlalchemy     0.5.7-1     Python SQL toolkit and Object Relational Mapper          any     Core     filesystem     2010.01-1     Base filesystem          any     Community     perl--common     1.0.6-1     's common Perl modules.          i686i686        Core            rfkill 0.3-3    Tool to query and set the rfkill state of wireless devicesi686      Community      blogilo      1.0-4      A free software blogging client for KDE focused on simplicity and usability            i686     Community     kdesvn     1.5.1-1     A pure C++ SVN-client for KDE          i686     Community     sleuthkit     3.1.0-1     File system and media management forensic analysis tools (supports NTFS, FAT, UFS1/2, FFS, Ext2 and Ext3)          i686     Community     qtractor     0.4.4-1     Audio/MIDI multitrack sequencer          i686     Community     slv2     0.6.6-1     Library for LV2 hosts          i686     Community     lv2core     3.0-1     LV2: Successor to the LADSPA audio plug-in standard          i686     Community     freevo     1.9.0-2     Freevo is an open-source home theatre PC platform based on Linux and a number of open-source audio/video tools.          i686     Community     surfraw     2.2.6-1     Shell Users' Revolutionary Front Rage Against the Web          i686     Community     haskell-x11-xft     0.3-12.1     Bindings to the Xft, X Free Type interface library, and some Xrender parts          i686     Community     qmmp     0.3.2-1     Qt4 based audio-player          i686     Community     xmonad     0.9.1-1     A lightweight X11 tiled window manager written in Haskell          i686     Community     xmonad-contrib     0.9.1-1     Add-ons for xmonad          i686     Community     freewrl     1.22.6-3     VRML viewer          i686     Community     pulseaudio     0.9.21-3     A networked sound server          i686      Extra      dhclient      4.1.0.p1-2      dhclient is standalone client from the dhcp package            i686     Extra     dhcp     4.1.0.p1-2     A DHCP server, client, and relay agent          i686     Extra     python-urwid     0.9.9-1     Urwid is a curses-based user interface library.          i686     Extra     gajim     0.13.2-1     Jabber client written in PyGTK          i686     Extra     mplayer     30325-1     A movie player for linux          i686     Extra     kdelibs3     3.5.10-8     KDE3 Core Libraries          i686     Extra     haskell-mtl     1.1.0.2-1.1     Monad transformer library          i686     Extra     libraw1394     2.0.5-1     Provides an API to the Linux IEEE1394 (FireWire) driver X86_64x86_64  Core            rfkill 0.3-3    Tool to query and set the rfkill state of wireless devicesx86_64      Community      qtractor      0.4.4-1      Audio/MIDI multitrack sequencer            x86_64     Community     slv2     0.6.6-1     Library for LV2 hosts          x86_64     Community     sleuthkit     3.1.0-1     File system and media management forensic analysis tools (supports NTFS, FAT, UFS1/2, FFS, Ext2 and Ext3)          x86_64     Community     kdesvn     1.5.1-1     A pure C++ SVN-client for KDE          x86_64     Community     lv2core     3.0-1     LV2: Successor to the LADSPA audio plug-in standard          x86_64     Community     xmonad-contrib     0.9.1-1     Add-ons for xmonad          x86_64     Community     xmonad     0.9.1-1     A lightweight X11 tiled window manager written in Haskell          x86_64     Community     freevo     1.9.0-2     Freevo is an open-source home theatre PC platform based on Linux and a number of open-source audio/video tools.          x86_64     Community     surfraw     2.2.6-1     Shell Users' Revolutionary Front Rage Against the Web          x86_64     Community     qmmp     0.3.2-1     Qt4 based audio-player          x86_64     Community     haskell-x11-xft     0.3-12     Bindings to the Xft, X Free Type interface library, and some Xrender parts          x86_64     Community     freewrl     1.22.6-3     VRML viewer          x86_64     Community     pulseaudio     0.9.21-3     A networked sound server          x86_64      Extra      dhclient      4.1.0.p1-2      dhclient is standalone client from the dhcp package            x86_64     Extra     dhcp     4.1.0.p1-2     A DHCP server, client, and relay agent          x86_64     Extra     python-urwid     0.9.9-1     Urwid is a curses-based user interface library.          x86_64     Extra     gajim     0.13.2-1     Jabber client written in PyGTK          x86_64     Extra     mplayer     30325-1     A movie player for linux          x86_64     Extra     kdelibs3     3.5.10-8     KDE3 Core Libraries          x86_64     Extra     haskell-mtl     1.1.0.2-1.1     Monad transformer library          x86_64     Extra     libraw1394     2.0.5-1     Provides an API to the Linux IEEE1394 (FireWire) driver          AUR:perl-catalyst-plugin-session-state-stash 0.13-1perl-capture-tiny 0.06-1perl-catalyst-plugin-unicode-encoding 0.8-1     perl-ansicolor 2.02-1     perl-version 0.79-1     tucnak2 2.31-1     rmdupe 1.0.1-1     yasst 20100112-1     somatic-icon-theme 0.2-3 junit-devel 4.8.1-1 Thanks
#12 OFFLINE   securitybreach
  • 23,098 posts
Posted 18 January 2010 - 02:37 AM
Updates for Sun, 17 Jan 2010:Main: Anyany      Community      perl-xyne-arch      1.0.40-1      Xyne's Arch-specific Perl modules.           any      Community      rai-qt      0.3.2-3      This script uses kdialog to generate a list of italian rai's channels            i686i686      Community      lesspipe      1.70-4      an input filter for the pager less            i686     Community     python-html5lib     0.11.1-3     A HTML parser/tokenizer based on the WHATWG HTML5 spec          i686     Community     blogilo     1.0-4     A free software blogging client for KDE focused on simplicity and usability          i686     Community     kdesvn     1.5.1-1     A pure C++ SVN-client for KDE         i686     Community     sleuthkit     3.1.0-1     File system and media management forensic analysis tools (supports NTFS, FAT, UFS1/2, FFS, Ext2 and Ext3) i686     Community     qtractor     0.4.4-1     Audio/MIDI multitrack sequencer          i686     Community     slv2     0.6.6-1     Library for LV2 hosts          i686     Community     lv2core     3.0-1     LV2: Successor to the LADSPA audio plug-in standard          i686      Extra      xfconf      4.6.1-3      xfconf.. thingie            i686     Extra     dhclient     4.1.0.p1-2     dhclient is standalone client from the dhcp package          i686     Extra     dhcp     4.1.0.p1-2     A DHCP server, client, and relay agent          i686     Extra     python-urwid     0.9.9-1     Urwid is a curses-based user interface library.      X86_64x86_64      Community      lesspipe      1.70-4      an input filter for the pager less            x86_64     Community     python-html5lib     0.11.1-3     A HTML parser/tokenizer based on the WHATWG HTML5 spec          x86_64     Community     blogilo     1.0-4     A free software blogging client for KDE focused on simplicity and usability          x86_64     Community     qtractor     0.4.4-1     Audio/MIDI multitrack sequencer          x86_64     Community     slv2     0.6.6-1     Library for LV2 hosts          x86_64     Community     sleuthkit     3.1.0-1     File system and media management forensic analysis tools (supports NTFS, FAT, UFS1/2, FFS, Ext2 and Ext3)         x86_64     Community     kdesvn     1.5.1-1     A pure C++ SVN-client for KDE         x86_64     Community     lv2core     3.0-1     LV2: Successor to the LADSPA audio plug-in standard          x86_64      Extra      xfconf      4.6.1-3      xfconf.. thingie            x86_64     Extra     dhclient     4.1.0.p1-2     dhclient is standalone client from the dhcp package          x86_64     Extra     dhcp     4.1.0.p1-2     A DHCP server, client, and relay agent          x86_64     Extra     python-urwid     0.9.9-1     Urwid is a curses-based user interface library.          AUR:newlan 1.0.0.7-1     haskell-iteratee 0.3.1-1haskell-regular-xmlpickler 0.1-1haskell-serialport 0.3.0-1     0haskell-mps 2009.11.7-1     haskell-acme-dont 1.1-1     haskell-monadrandom 0.1.4-1bacteria 1.1-1     haskell-sdl 0.5.9-1haskell-netsnmp 0.1.6-1Thanks
#13 OFFLINE   securitybreach
  • 23,098 posts
Posted 18 January 2010 - 09:13 PM
Updates for Mon, 18 Jan 2010:Main: Anyany      Community      perl--arch      1.0.41-1  Xyne's Arch-specific Perl modules.            any     Community     asciidoc     8.5.3-1     Text document format for short documents, articles, books and UNIX man pages          any        Extra    perl-libwww 5.834-1i686i686      Core      zlib      1.2.3.4-4      compression library implementing the deflate compression method found in gzip and PKZIP            i686     Core     psmisc     22.10-1     Miscellaneous procfs tools          i686     Core     iproute2     2.6.31-1     IP Routing Utilities          i686      Community      json-glib      0.10.0-1      JSON library built on GLib            i686     Community     unrtf     0.21.1-1     Command-line program which converts RTF documents to other formats     i686     Community     aspell-pl     20100118-1     Polish dictionary for aspell         i686     Community     ekg2     20100117-1     ncurses based Jabber, Gadu-Gadu, Tlen and IRC client          i686     Community     rlwrap     0.35-1     A 'readline wrapper'          i686     Community     gtk-rezlooks-engine     0.6-9     Clean looking gtk theme engine based on the cairo-enabled CVS clearlooks engine code.          i686     Community     atanks     4.2-2     Atomic Tanks          i686     Community     go     4623-2     Google Go compiler and tools          i686     Community     opensips     1.6.1-1     An Open Source SIP Server able to act as a SIP proxy, registrar, location server, redirect server ...          i686     Community     knemo     0.6.1-1     The KDE Network Monitor          i686     Community     freevo     1.9.0-3     Freevo is an open-source home theatre PC platform based on Linux and a number of open-source audio/video tools.          i686      Extra      rasqal      0.9.17-1      a free C library that handles Resource Description Framework (RDF) query syntaxes, query construction and query execution returning result bindings            i686     Extra     redland     1.0.10-1     Library that provides a high-level interface to RDF data          i686     Extra     telepathy-haze     0.3.2-3     A telepathy-backend to use libpurple (Pidgin) protocols.          i686     Extra     filelight     1.9rc3-1     A KDE program that creates a complex, but data-rich graphical representation of the files and directories on your computer.          i686     Extra     biopython     1.53-1     Freely available Python tools for computational molecular biology          i686     Extra     allegro     4.4.0.1-1     Portable library mainly aimed at video game and multimedia programming          i686     Extra     devil     1.7.8-4     Library for reading several different image formats          i686     Extra     liquidwar     5.6.4-4     A unique multiplayer wargame          i686     Extra     acct     6.5.1-1     A set of utilities which reports and summarizes data about user connect times and process execution statistics          i686     Extra     fsarchiver     0.6.5-1     A safe and flexible file-system backup and deployment tool          i686     Extra     httrack     3.43.9-1     An easy-to-use offline browser utility.          i686     Extra     pure-ftpd     1.0.27-1     A fast, production quality, standards-conformant FTP server          X86_64x86_64      Core      zlib      1.2.3.4-4      compression library implementing the deflate compression method found in gzip and PKZIP            x86_64     Core     psmisc     22.10-1     Miscellaneous procfs tools          x86_64     Core     iproute2     2.6.31-1     IP Routing Utilities          x86_64      Community      json-glib      0.10.0-1      JSON library built on GLib            x86_64     Community     unrtf     0.21.1-1     Command-line program which converts RTF documents to other formats     x86_64     Community     aspell-pl     20100118-1     Polish dictionary for aspell          x86_64     Community     ekg2     20100117-1     ncurses based Jabber, Gadu-Gadu, Tlen and IRC client          x86_64     Community     rlwrap     0.35-1     A 'readline wrapper'          x86_64     Community     gtk-rezlooks-engine     0.6-9     Clean looking gtk theme engine based on the cairo-enabled CVS clearlooks engine code.          x86_64     Community     atanks     4.2-2     Atomic Tanks          x86_64     Community     haskell-x11-xft     0.3-12.1     Bindings to the Xft, X Free Type interface library, and some Xrender parts          x86_64     Community     go     4623-2     Google Go compiler and tools          x86_64     Community     opensips     1.6.1-1     An Open Source SIP Server able to act as a SIP proxy, registrar, location server, redirect server ...          x86_64     Community     freevo     1.9.0-3     Freevo is an open-source home theatre PC platform based on Linux and a number of open-source audio/video tools.      x86_64      Extra      rasqal      0.9.17-1      a free C library that handles Resource Description Framework (RDF) query syntaxes, query construction and query execution returning result bindings            x86_64     Extra     redland     1.0.10-1     Library that provides a high-level interface to RDF data          x86_64     Extra     telepathy-haze     0.3.2-3     A telepathy-backend to use libpurple (Pidgin) protocols.          x86_64     Extra     filelight     1.9rc3-1     A KDE program that creates a complex, but data-rich graphical representation of the files and directories on your computer.          x86_64     Extra     allegro     4.4.0.1-1     Portable library mainly aimed at video game and multimedia programming          x86_64     Extra     devil     1.7.8-4     Library for reading several different image formats          x86_64     Extra     liquidwar     5.6.4-4     A unique multiplayer wargameAUR:flickcurl 1.16-1     Tue, 19 collectd 4.9.1-1     Tue, 19 nautilus-elementary 7-1 shotwell 0.4.3-1     reva 9.0.9-3     xbmc-pulse 9.11-6fio 1.36-1     hcfpcimodem-utils 1.20full-1davmail-x86_64 3.6.2-3pybgsetter 0.3-1 Thanks
#14 OFFLINE   securitybreach
  • 23,098 posts
Posted 20 January 2010 - 12:52 AM
Updates for Tues, 19 Jan 2010:Main: Anyany      Community      hsoconnect      1.2.18-4      HSO command line connection utility            any     Extra     lxde-icon-theme     0.0.1-1     LXDE default default icon theme based on nuoveXT2          any     Extra     papyon     0.4.4-1     papyon is the library behind the msn connection manager : telepathy-butterfly.          any     Extra     python-chardet     1.0.1-2     Python module for character encoding auto-detection          any     Community     perl--arch     1.0.42-1     Xyne's Arch-specific Perl modules.          i686i686      Community      recordmydesktop      0.3.8.1-2      Produces a OGG encapsulated Theora/Vorbis recording of your desktop            i686     Community     xbmc     9.11-8     XBMC Media Center          i686     Community     atanks     4.3-1     Atomic Tanks          i686     Community     go     2010_01_13-1     Google Go compiler and tools (release version)          i686     Community     dmd     1.055-1     The Digital Mars D compiler.          i686     Community     libphobos     1.055-1     Runtime library for the D programming language          i686     Community     qbittorrent     2.1.0-1     A bittorrent client written in C++ / Qt4 using the good libtorrent library          i686     Community     xmonad     0.9.1-2     A lightweight X11 tiled window manager written in Haskell          i686     Community     xmonad-contrib     0.9.1-2     Add-ons for xmonad          i686      Extra      lxde-common      0.5.0-1      Common files of the LXDE Desktop            i686     Extra     lxpanel     0.5.4.1-1     Panel of the LXDE Desktop          i686     Extra     lxsession-lite     0.4.1-1     Session manager of the LXDE Desktop (light version)          i686     Extra     smartmontools     5.39-1     Control and monitor S.M.A.R.T. enabled ATA and SCSI Hard Drives.          i686     Extra     telepathy-farsight     0.0.13-1     A telepathy-backend to use stream engine.          i686     Extra     farsight2     0.0.17-1     Audio/Video conference software for Instant Messengers          i686     Extra     python-telepathy     0.15.14-1     Python libraries for use in Telepathy clients and connection managers          i686     Extra     samba     3.4.5-1.1     Tools to access a server's filespace and printers via SMB          i686     Extra     smbclient     3.4.5-1.1     Tools to access a server's filespace and printers via SMB          i686     Extra     telepathy-butterfly     0.5.4-1     A MSN connection manager for Telepathy          i686     Extra     wicd     1.7.0-1     New and alternative wireless/wired network management utility          i686     Extra     haskell-deepseq     1.1.0.0-1     Fully evaluate data structures          i686     Extra     haskell-haskell-src     1.0.1.3-1     Facilities for manipulating Haskell source code: an abstract syntax, lexer, parser and pretty-printer.          i686     Extra     haskell-hunit     1.2.2.1-1     A unit testing framework for Haskell          i686     Extra     haskell-parallel     2.2.0.1-1     Parallel programming library          i686     Extra     haskell-quickcheck     2.1.0.3-1     Automatic testing of Haskell programs          i686     Extra     haskell-stm     2.1.1.2-1     A modular composable concurrency abstraction.          i686     Extra     haskell-xhtml     3000.2.0.1-2     Combinators for producing XHTML 1.0, including the Strict, Transitional and Frameset variants.          i686     Extra     openoffice-base-beta     3.2.0_ooo320_m10-1     OpenOffice.org - a free multiplatform and multilingual office suite - testing branch leeding to next stable release          i686     Extra     openoffice-sdk-beta     3.2.0_ooo320_m10-1     OpenOffice.org SDK - development files for beta branch pkg          i686     Extra     haskell-extensible-exceptions     0.1.1.0-2     Extensible exceptions          i686     Extra     haskell-haskeline     0.6.2.2-3     A command-line interface for user input, written in Haskell.          i686     Extra     haskell-terminfo     0.3.0.2-2     Haskell bindings to the terminfo library.          X86_64x86_64      Community      recordmydesktop      0.3.8.1-2      Produces a OGG encapsulated Theora/Vorbis recording of your desktop            x86_64     Community     xbmc     9.11-8     XBMC Media Center          x86_64     Community     knemo     0.6.1-1     The KDE Network Monitor          x86_64     Community     atanks     4.3-1     Atomic Tanks          x86_64     Community     go     2010_01_13-1     Google Go compiler and tools (release version)          x86_64     Community     qbittorrent     2.1.0-1     A bittorrent client written in C++ / Qt4 using the good libtorrent library          x86_64     Community     xmonad     0.9.1-2     A lightweight X11 tiled window manager written in Haskell          x86_64     Community     xmonad-contrib     0.9.1-2     Add-ons for xmonad          x86_64      Extra      lxde-common      0.5.0-1      Common files of the LXDE Desktop            x86_64     Extra     lxpanel     0.5.4.1-1     Panel of the LXDE Desktop          x86_64     Extra     lxsession-lite     0.4.1-1     Session manager of the LXDE Desktop (light version)          x86_64     Extra     telepathy-farsight     0.0.13-1     A telepathy-backend to use stream engine.          x86_64     Extra     acct     6.5.1-1     A set of utilities which reports and summarizes data about user connect times and process execution statistics          x86_64     Extra     biopython     1.53-1     Freely available Python tools for computational molecular biology          x86_64     Extra     farsight2     0.0.17-1     Audio/Video conference software for Instant Messengers          x86_64     Extra     fsarchiver     0.6.5-1     A safe and flexible file-system backup and deployment tool          x86_64     Extra     httrack     3.43.9-1     An easy-to-use offline browser utility.          x86_64     Extra     pure-ftpd     1.0.27-1     A fast, production quality, standards-conformant FTP server          x86_64     Extra     samba     3.4.5-1.1     Tools to access a server's filespace and printers via SMB     tpowa     x86_64     Extra     smartmontools     5.39-1     Control and monitor S.M.A.R.T. enabled ATA and SCSI Hard Drives.          x86_64     Extra     smbclient     3.4.5-1.1     Tools to access a server's filespace and printers via SMB     tpowa     x86_64     Extra     telepathy-butterfly     0.5.4-1     A MSN connection manager for Telepathy          x86_64     Extra     python-telepathy     0.15.14-1     Python libraries for use in Telepathy clients and connection managers          x86_64     Extra     wicd     1.7.0-1     New and alternative wireless/wired network management utility          x86_64     Extra     haskell-deepseq     1.1.0.0-1     Fully evaluate data structures          x86_64     Extra     haskell-haskell-src     1.0.1.3-1     Facilities for manipulating Haskell source code: an abstract syntax, lexer, parser and pretty-printer.          x86_64     Extra     haskell-hunit     1.2.2.1-1     A unit testing framework for Haskell          x86_64     Extra     haskell-parallel     2.2.0.1-1     Parallel programming library          x86_64     Extra     haskell-quickcheck     2.1.0.3-1     Automatic testing of Haskell programs          x86_64     Extra     haskell-stm     2.1.1.2-1     A modular composable concurrency abstraction.          x86_64     Extra     haskell-xhtml     3000.2.0.1-2     Combinators for producing XHTML 1.0, including the Strict, Transitional and Frameset variants.          x86_64     Extra     openoffice-base-beta     3.2.0_ooo320_m10-1     OpenOffice.org - a free multiplatform and multilingual office suite - testing branch leeding to next stable release          x86_64     Extra     openoffice-sdk-beta     3.2.0_ooo320_m10-1     OpenOffice.org SDK - development files for beta branch pkg          x86_64     Extra     haskell-extensible-exceptions     0.1.1.0-2     Extensible exceptions          x86_64     Extra     haskell-haskeline     0.6.2.2-3     A command-line interface for user input, written in Haskell.          x86_64     Extra     haskell-terminfo     0.3.0.2-2     Haskell bindings to the terminfo library. AUR:vim-blogit 1.4.3-1     ifreebudget 2.0.22-1bitflu 0.96-1     firefox-testing-src 3.6rc2-1 perl-moosex-method-signatures 0.29-1gedit-classbrowser 0.2.1-1quantlib-python 0.9.9-1     zynjacku 5-2     mda-lv2-svn 2245-1lv2vocoder 1-4 Thanks
#15 OFFLINE   securitybreach
  • 23,098 posts
Posted 01 February 2010 - 12:53 AM
Updates for Sun, 31 Jan 2010:Anyany     Core     wireless-regdb     2009.11.25-1     Central Regulatory Domain Database any      Community      postgrey      1.32-3      a Postfix policy server implementing greylisting                any     Extra     xorg-util-macros     1.5.0-1     X.Org Autotools macros          any     Extra     poppler-data     0.4.0-1     Encoding data for the poppler PDF rendering library                   i686i686      Core      bash      4.1.002-2      The GNU Bourne Again shell            i686     Core     dialog     1.1_20100119-1     A tool to display dialog boxes from shell scripts          i686     Core     pacman-mirrorlist     20100131-1     Arch Linux mirror list for use by pacman          i686     Core     kernel26-lts     2.6.27.45-1     The Linux Kernel and modules - stable longtime supported kernel package suitable for servers          i686     Core     kernel26-lts-headers     2.6.27.45-1     Header files and scripts for building modules for kernel26-lts          i686     Core     kernel26     2.6.32.7-1     The Linux Kernel and modules          i686     Core     kernel26-firmware     2.6.32.7-1     The included firmware files of the Linux Kernel          i686     Core     kernel26-headers     2.6.32.7-1     Header files and scripts for building modules for kernel26          i686     Core     pciutils     3.1.6-1     PCI bus configuration space access library and tools          i686      Community      vuze      4.3.1.0-1      BitTorrent client with GUI, written in Java, formerly known as Azureus            i686     Community     php52     5.2.12-3     A high-level scripting language          i686     Community     recoll     1.13.02-1     Full text search tool based on Xapian backend          i686     Community     libpaper     1.1.23-4     Library for handling paper characteristics          i686     Community     mozplugger     1.13.1-1     A Mozilla & Firefox multimedia plugin.          i686     Community     qbittorrent     2.1.2-1     A bittorrent client written in C++ / Qt4 using the good libtorrent library          i686      Extra      gtklp      1.2.7-1      Tools to use and administrate CUPS            i686     Extra     i8kutils     1.33-1     Dell Inspiron/Latitude kernel driver and utilities          i686     Extra     weechat     0.3.1.1-1     Fast, light and extensible IRC client (curses UI)     giovanni     i686     Extra     digikam     1.1.0-1     Digital photo management application for kde          i686     Extra     dnsmasq     2.52-1     Lightweight, easy to configure DNS forwarder and DHCP server          i686     Extra     ecl     9.12.3-1     Embeddable Common Lisp     juergen     i686     Extra     enscript     1.6.5-1     Convert ASCII files to PostScript suitable for printing          i686     Extra     davfs2     1.4.5-1     File system driver that allows you to mount a WebDAV server as a local disk drive.          i686     Extra     ardour     2.8.6-1     A multichannel hard disk recorder and digital audio workstation          i686     Extra     banshee     1.5.3-1     Music management and playback for GNOME          i686     Extra     cpufrequtils     007-1     Userspace tools for the kernel cpufreq subsystem          i686     Extra     libdrm     2.4.17-3     Userspace interface to kernel DRM services          i686     Extra     nouveau-drm     0.0.15_20100116-1     nvidia opensource X driver          i686     Extra     xf86-video-nouveau     0.0.15_git20100117-1     Open Source 3D acceleration driver for nVidia cards (experimental)          i686     Extra     gksu     2.0.2-2     A graphical frontend for su          i686     Extra     fsarchiver     0.6.7-1     A safe and flexible file-system backup and deployment tool          i686     Extra     libx11     1.3.3-1     X11 client-side library          i686     Extra     pdns-recursor     3.1.7.2-1     PowerDNS recursor          i686     Extra     polkit-gnome     0.96-1     PolicyKit integration for the GNOME desktop          i686     Extra     xorg-server     1.7.4.901-1     X.Org X servers          i686     Extra     gdb     7.0.1-2     The GNU Debugger          i686     Extra     libelf     0.8.13-1     libelf is a free ELF object file access library          i686     Extra     libtasn1     2.4-1     The ASN.1 library used in GNUTLS          i686     Extra     polkit     0.96-1     Application development toolkit for controlling system-wide privileges          i686     Extra     pycairo     1.8.8-1     Python bindings for the cairo graphics library          i686     Extra     hplip     3.9.12-4     Drivers for HP DeskJet, OfficeJet, Photosmart, Business Inkjet and some LaserJet.          i686     Extra     pm-utils     1.2.6.1-4     Utilities and scripts for suspend and hibernate power management          i686     Extra     python-imaging     1.1.7-1     PIL. Provides image processing capabilities for python          i686     Extra     sane     1.0.20-5     Scanner Access Now Easy          i686     Extra     zsnes     1.51-7     Super Nintendo emulator          i686     Extra     dosfstools     3.0.9-1     DOS filesystem utilities          i686     Extra     k3b     1.70.0beta1-1     Feature-rich and easy to handle CD burning application          i686     Extra     seamonkey     2.0.2-2     SeaMonkey internet suite          i686     Extra     ffmpeg     20100108-3     Complete and free Internet live audio and video broadcasting solution for Linux/Unix          i686     Extra     live-media     2010.01.22-1     A set of C++ libraries for multimedia streaming  x86_64x86_64      Core      bash      4.1.002-2      The GNU Bourne Again shell            x86_64     Core     dialog     1.1_20100119-1     A tool to display dialog boxes from shell scripts          x86_64     Core     pacman-mirrorlist     20100131-1     Arch Linux mirror list for use by pacman          x86_64     Core     kernel26-lts     2.6.27.45-1     The Linux Kernel and modules - stable longtime supported kernel package suitable for servers          x86_64     Core     kernel26-lts-headers     2.6.27.45-1     Header files and scripts for building modules for kernel26-lts          x86_64     Core     kernel26     2.6.32.7-1     The Linux Kernel and modules          x86_64     Core     kernel26-firmware     2.6.32.7-1     The included firmware files of the Linux Kernel          x86_64     Core     kernel26-headers     2.6.32.7-1     Header files and scripts for building modules for kernel26          x86_64     Core     pciutils     3.1.6-1     PCI bus configuration space access library and tools          x86_64      Community      vuze      4.3.1.0-1      BitTorrent client with GUI, written in Java, formerly known as Azureus            x86_64     Community     php52     5.2.12-3     A high-level scripting language          x86_64     Community     recoll     1.13.02-1     Full text search tool based on Xapian backend          x86_64     Community     libpaper     1.1.23-4     Library for handling paper characteristics          x86_64     Community     mozplugger     1.13.1-1     A Mozilla & Firefox multimedia plugin.          x86_64     Community     qbittorrent     2.1.2-1     A bittorrent client written in C++ / Qt4 using the good libtorrent library          x86_64      Extra      gtklp      1.2.7-1      Tools to use and administrate CUPS            x86_64     Extra     i8kutils     1.33-1     Dell Inspiron/Latitude kernel driver and utilities          x86_64     Extra     weechat     0.3.1.1-1     Fast, light and extensible IRC client (curses UI)     giovanni     x86_64     Extra     digikam     1.1.0-1     Digital photo management application for kde          x86_64     Extra     dnsmasq     2.52-1     Lightweight, easy to configure DNS forwarder and DHCP server          x86_64     Extra     ecl     9.12.3-1     Embeddable Common Lisp     juergen     x86_64     Extra     enscript     1.6.5-1     Convert ASCII files to PostScript suitable for printing          x86_64     Extra     libmysqlclient     5.1.43-1     MySQL client libraries          x86_64     Extra     mysql     5.1.43-1     A fast SQL database server          x86_64     Extra     mysql-clients     5.1.43-1     MySQL client tools          x86_64     Extra     davfs2     1.4.5-1     File system driver that allows you to mount a WebDAV server as a local disk drive.          x86_64     Extra     ardour     2.8.6-1     A multichannel hard disk recorder and digital audio workstation          x86_64     Extra     banshee     1.5.3-1     Music management and playback for GNOME          x86_64     Extra     cpufrequtils     007-1     Userspace tools for the kernel cpufreq subsystem          x86_64     Extra     libdrm     2.4.17-3     Userspace interface to kernel DRM services          x86_64     Extra     nouveau-drm     0.0.15_20100116-1     nvidia opensource X driver          x86_64     Extra     xf86-video-nouveau     0.0.15_git20100117-1     Open Source 3D acceleration driver for nVidia cards (experimental)          x86_64     Extra     gksu     2.0.2-2     A graphical frontend for su          x86_64     Extra     fsarchiver     0.6.7-1     A safe and flexible file-system backup and deployment tool          x86_64     Extra     libx11     1.3.3-1     X11 client-side library          x86_64     Extra     pdns-recursor     3.1.7.2-1     PowerDNS recursor          x86_64     Extra     polkit-gnome     0.96-1     PolicyKit integration for the GNOME desktop          x86_64     Extra     xorg-server     1.7.4.901-1     X.Org X servers          x86_64     Extra     gdb     7.0.1-2     The GNU Debugger          x86_64     Extra     libelf     0.8.13-1     libelf is a free ELF object file access library          x86_64     Extra     libtasn1     2.4-1     The ASN.1 library used in GNUTLS          x86_64     Extra     polkit     0.96-1     Application development toolkit for controlling system-wide privileges          x86_64     Extra     pycairo     1.8.8-1     Python bindings for the cairo graphics library          x86_64     Extra     hplip     3.9.12-4     Drivers for HP DeskJet, OfficeJet, Photosmart, Business Inkjet and some LaserJet.          x86_64     Extra     pm-utils     1.2.6.1-4     Utilities and scripts for suspend and hibernate power management          x86_64     Extra     python-imaging     1.1.7-1     PIL. Provides image processing capabilities for python          x86_64     Extra     sane     1.0.20-5     Scanner Access Now Easy          x86_64     Extra     dosfstools     3.0.9-1     DOS filesystem utilities          x86_64     Extra     k3b     1.70.0beta1-1     Feature-rich and easy to handle CD burning application          x86_64     Extra     seamonkey     2.0.2-2     SeaMonkey internet suite          x86_64     Extra     ffmpeg     20100108-3     Complete and free Internet live audio and video broadcasting solution for Linux/Unix          x86_64     Extra     live-media     2010.01.22-1     A set of C++ libraries for multimedia streaming    AURthebutterflyeffect m5-1xcursor-dmz 0.4.1-1 gtg 0.2.1-1     minicomputer 1.4-1     cairo-cleartype 1.8.8-3emusic-dlm 4.1.4-2     389-ds-base 1.2.5-2     pidgin-gfire-svn 335-1389-admin 1.1.10-1     389-adminutil 1.1.9-1     Thanks
#16 OFFLINE   securitybreach
  • 23,098 posts
Posted 02 February 2010 - 02:02 AM
Updates for Mon, 1 Feb 2010:Anyany      Extra      eigen      2.0.11-1      A lightweight C++ template library for vector and matrix math, a.k.a. linear algebra.            any     Extra     culmus     0.104-1     A collection of Type1 and TrueType Hebrew fonts          any     Extra     perl-exiftool     8.09-1     Reader and rewriter of EXIF informations that supports raw files          any     Extra     perl-io-socket-ssl     1.31-1     Nearly transparent SSL encapsulation for IO::Socket::INET          any     Extra     perl-test-pod     1.41-1     Check for POD errors in files          any     Extra     perl-yaml     0.71-1     Perl/CPAN Module YAML : YAML Aint Markup Language tm               any     Extra     perl-anyevent     5.24-1     Framework for multiple event loops          any     Community     tange-icon-theme     0.26-5     Ubuntu's twist on the Tango icon theme          any     Community     arch-firefox-search     0.7-6     Firefox Arch search engines (AUR, Pkgs, BBS, Wiki, etc.)          any     Community     phpldapadmin     1.2.0.5-1     A PHP and hence web-based tool to administrate LDAP over the WWW          any     Community     murrine-themes-collection     20100201-1     A collection of Murrine GTK2 themes          i686i686      Core      cryptsetup      1.1.0-1      Userspace setup tool for transparent encryption of block devices using the Linux 2.6 cryptoapi            i686     Core     device-mapper     2.02.60-2     Device mapper userspace library and tools          i686     Core     dmraid     1.0.0.rc16-1     Device mapper RAID interface          i686     Core     lilo     22.8-4     A bootloader for Linux          i686     Core     lvm2     2.02.60-2     Logical Volume Manager 2 utilities          i686     Core     pcmciautils     016-1     Utilities for inserting and removing PCMCIA cards          i686     Core     udev     151-2     The userspace dev tools (udev)          i686     Core     udev-compat     151-2     The userspace dev tools (udev) - additional rules for older kernels          i686      Community      medit      0.9.4-10      A GTK text editor            i686     Community     qbittorrent     2.1.2-2     A bittorrent client written in C++ / Qt4 using the good libtorrent library          i686     Community     recoll     1.13.02-2     Full text search tool based on Xapian backend          i686     Community     python-sympy     0.6.6-2     Symbolic manipulation package (Computer Algebra System), written in pure Python          i686      Extra      di      4.19-1      A disk information utility, displaying everything (and more) that your df command does            i686     Extra     facile     1.1-11     A Functional Constraint Library          i686     Extra     deskbar-applet     2.28.0-2     An all-in-one search bar for the GNOME panel          i686     Extra     stunnel     4.30-1     A program that allows you to encrypt arbitrary TCP connections inside SSL.          i686     Extra     xterm     255-1     X Terminal Emulator          i686     Extra     libmysqlclient     5.1.43-1     MySQL client libraries          i686     Extra     mysql     5.1.43-1     A fast SQL database server          i686     Extra     mysql-clients     5.1.43-1     MySQL client tools          i686     Extra     r     2.10.1-1     R is a language and environment for statistical computing and graphics          i686     Extra     socat     1.7.1.2-1     Relay for bidirectional data transfer via socket, pty, pipe, file and more          i686     Extra     elinks     0.11.7-2     An advanced and well-established feature-rich text mode web browser.          i686     Extra     perl-mail-spf     2.007-1     Perl module that provides SPF support          i686     Extra     perl-mailtools     2.06-1     Perl module that provides email tools          i686     Extra     perl-net-dns     0.66-1     Perl Module: Interface to the DNS resolver.          i686     Extra     perl-timedate     1.20-1     Date formating subroutines          i686     Extra     perl-xml-twig     3.34-1     A module for easy processing of XML          i686     Extra     pyxdg     0.19-1     Python library to access freedesktop.org standards.          i686     Extra     perl-date-manip     6.05-1     Date::Manip - date manipulation routines          i686     Extra     perl-dbd-sqlite     1.29-1     Self-contained RDBMS in a DBI driver          i686     Extra     perl-digest-hmac     1.02-1     Perl Module: Keyed-Hashing for Message Authentication.          i686     Extra     perl-error     0.17016-1     Perl/CPAN Error module - Error/exception handling in an OO-ish way          i686     Extra     perl-event-execflow     0.64-1     Framework for perl-events          i686     Extra     perl-gtk2-ex-formfactory     0.66-1     Framework for perl-gtk2 development          i686     Extra     gparted     0.5.1-2     A Partition Magic clone, frontend to GNU Parted          i686     Extra     parted     2.1-1     A program for creating, destroying, resizing, checking and copying partitions          i686     Extra     ocaml     3.11.2-1     A functional language with OO extensions          i686     Extra     oprofile     0.9.6-1     a system-wide profiler for Linux systems, capable of profiling all running code at low overhead.          i686     Extra     muse     1.0.1-1     A MIDI/Audio sequencer with recording and editing capabilities          i686     Extra     nmap     5.21-1     A network exploration tool and security/port scanner          i686     Extra     monotone     0.46-1     A modern distributed version control system, like hg, darcs, or git          i686     Extra     cfitsio     3240-1     A library of C and Fortran subroutines for reading and writing data files in FITS (Flexible Image Transport System) data format.          i686     Extra     latex2rtf     2.0.0-1     LaTeX to RTF converter          i686     Extra     haskell-network     2.2.1.7-2     Networking-related facilities          i686     Extra     haskell-parsec     3.0.1-3     Monadic parser combinators          i686     Extra     haskell-regex-compat     0.92-3               i686     Extra     haskell-regex-posix     0.94.1-2     The posix regex backend for regex-base          i686     Extra     gdb     7.0.1-3     The GNU Debugger          x86_64x86_64      Core      cryptsetup      1.1.0-1      Userspace setup tool for transparent encryption of block devices using the Linux 2.6 cryptoapi            x86_64     Core     device-mapper     2.02.60-2     Device mapper userspace library and tools          x86_64     Core     dmraid     1.0.0.rc16-1     Device mapper RAID interface          x86_64     Core     lilo     22.8-4     A bootloader for Linux          x86_64     Core     lvm2     2.02.60-2     Logical Volume Manager 2 utilities          x86_64     Core     pcmciautils     016-1     Utilities for inserting and removing PCMCIA cards          x86_64     Core     udev     151-2     The userspace dev tools (udev)          x86_64     Core     udev-compat     151-2     The userspace dev tools (udev) - additional rules for older kernels          x86_64      Community      lib32-glib2      2.22.4-1      Common C routines used by GTK+ 2.4 and other libs            x86_64     Community     lib32-libpng     1.4.0-2     A collection of routines used to create PNG format graphics files          x86_64     Community     lib32-libtasn1     2.4-1     The ASN.1 library used in GNUTLS          x86_64     Community     lib32-pcre     8.01-1     A library that implements Perl 5-style regular expressions          x86_64     Community     lib32-zlib     1.2.3.7-2     A compression/decompression Library          x86_64     Community     medit     0.9.4-10     A GTK text editor          x86_64     Community     qbittorrent     2.1.2-2     A bittorrent client written in C++ / Qt4 using the good libtorrent library          x86_64     Community     recoll     1.13.02-2     Full text search tool based on Xapian backend          x86_64     Community     python-sympy     0.6.6-2     Symbolic manipulation package (Computer Algebra System), written in pure Python          x86_64      Extra      di      4.19-1      A disk information utility, displaying everything (and more) that your df command does            x86_64     Extra     facile     1.1-11     A Functional Constraint Library          x86_64     Extra     deskbar-applet     2.28.0-2     An all-in-one search bar for the GNOME panel          x86_64     Extra     stunnel     4.30-1     A program that allows you to encrypt arbitrary TCP connections inside SSL.          x86_64     Extra     xterm     255-1     X Terminal Emulator          x86_64     Extra     r     2.10.1-1     R is a language and environment for statistical computing and graphics          x86_64     Extra     socat     1.7.1.2-1     Relay for bidirectional data transfer via socket, pty, pipe, file and more          x86_64     Extra     elinks     0.11.7-2     An advanced and well-established feature-rich text mode web browser.          x86_64     Extra     perl-mail-spf     2.007-1     Perl module that provides SPF support          x86_64     Extra     perl-mailtools     2.06-1     Perl module that provides email tools          x86_64     Extra     perl-net-dns     0.66-1     Perl Module: Interface to the DNS resolver.          x86_64     Extra     perl-timedate     1.20-1     Date formating subroutines          x86_64     Extra     perl-xml-twig     3.34-1     A module for easy processing of XML          x86_64     Extra     pyxdg     0.19-1     Python library to access freedesktop.org standards.          x86_64     Extra     perl-date-manip     6.05-1     Date::Manip - date manipulation routines          x86_64     Extra     perl-dbd-sqlite     1.29-1     Self-contained RDBMS in a DBI driver          x86_64     Extra     perl-digest-hmac     1.02-1     Perl Module: Keyed-Hashing for Message Authentication.          x86_64     Extra     perl-error     0.17016-1     Perl/CPAN Error module - Error/exception handling in an OO-ish way          x86_64     Extra     perl-event-execflow     0.64-1     Framework for perl-events          x86_64     Extra     perl-gtk2-ex-formfactory     0.66-1     Framework for perl-gtk2 development          x86_64     Extra     gparted     0.5.1-2     A Partition Magic clone, frontend to GNU Parted          x86_64     Extra     parted     2.1-1     A program for creating, destroying, resizing, checking and copying partitions          x86_64     Extra     ocaml     3.11.2-1     A functional language with OO extensions          x86_64     Extra     oprofile     0.9.6-1     a system-wide profiler for Linux systems, capable of profiling all running code at low overhead.          x86_64     Extra     muse     1.0.1-1     A MIDI/Audio sequencer with recording and editing capabilities          x86_64     Extra     nmap     5.21-1     A network exploration tool and security/port scanner          x86_64     Extra     monotone     0.46-1     A modern distributed version control system, like hg, darcs, or git          x86_64     Extra     cfitsio     3240-1     A library of C and Fortran subroutines for reading and writing data files in FITS (Flexible Image Transport System) data format. AUR python-numpy 1.4.0-1 bloodfrontier 0.85-2     fortune-mod-br 20080530-1vim-winmanager 2.3-3 perltidy 20090616-1     pd-extended-svn 13105-1eaccelerator 0.9.6-rc2   ooc-gtksourceview-git 20100201-1 ocaml-core 0.6.0-2   gtk2hs-darcs 20100201-1  Thanks
#17 OFFLINE   securitybreach
  • 23,098 posts
Posted 03 February 2010 - 02:26 AM
Updates for Tues, 2 Feb 2010:Anyany Community phoronix-test-suite 2.4.0-1 The most comprehensive testing and benchmarking platform available for Linux any Community perl-log-log4perl 1.26-1 Log4j implementation in Perl any Community firefox-spell-ru 0.4.3-2 Russian spellchecker dictionary for Firefox any Community impressive 0.10.2-1 A fancy PDF presentation program (previously known as KeyJNote). any Community openbox-themes 1.0.2-1 Various themes for the Openbox window manager      any Extra                 i8kmon 1.33-1 Tk-based daemon for i8kutils and Dell Inspiron/Latitude notebooks i686i686 Core xfsprogs 3.1.1-1 XFS filesystem utilities i686 Core dhcpcd 5.1.5-1 RFC2131 compliant DHCP client daemon i686 Core mdadm 3.1.1-1 A tool for managing/monitoring Linux md device arrays, also known as Software RAID i686 Community eet-svn 45669-1 A data storage and compression library i686 Community puzzles 8853-1 Simon Tatham's Portable Puzzle Collection i686 Community windowlab 1.39-1 A small and simple window manager. i686 Community mms_client 0.0.3-4 mms protocol download utility i686 Community gstreamermm 0.10.6-1 C++ interface for GStreamer i686 Community subtitleeditor 0.36.0-1 A GTK+2 tool to edit subtitles for GNU/Linux/*BSD i686 Community texmaker 1.9.9-1 Free cross-platform latex editor i686 Community vuze 4.3.1.2-1 BitTorrent client with GUI, written in Java, formerly known as Azureus i686 Community libyaml 0.1.3-1 YAML 1.1 library i686 Community python-yaml 3.09-1 Python bindings for YAML, using fast libYAML library i686 Community nginx 0.7.65-1 lightweight HTTP server and IMAP/POP3 proxy server i686 Community schroot 1.3.2_1-2 Allows users to execute shell commands under different root filesystems. (Successor to dchroot). i686 Community sysprof 1.0.12-7 A sampling CPU profiler that uses a Linux kernel module to profile the entire system i686 Community sysprof-module 1.0.12-7 A sampling CPU profiler that uses a Linux kernel module to profile the entire system i686 Community haskell-http 4000.0.9-2 A library for client-side HTTP i686 Extra lm_sensors 3.1.2-1 Collection of user space tools for general SMBus access and hardware monitoring eric i686 Extra oprofile 0.9.6-2 a system-wide profiler for Linux systems, capable of profiling all running code at low overhead i686 Extra ratpoison 1.4.5-2 A simple keystroke-driven window manager i686 Extra wmii 3.6-4 Next generation WMI (Window Manager Improved 2) i686 Extra claws-mail 3.7.5-1 A GTK+ based e-mail client. andyrtr i686 Extra claws-mail-extra-plugins 3.7.5-1 Extra plugins for claws-mail andyrtr i686 Extra libchamplain 0.4.4-1 C library aimed to provide a Gtk+ widget to display rasterized maps andyrtr i686 Extra texmacs 1.0.7.3-1 GNU TeXmacs is a free scientific text editor, which was both inspired by TeX and GNU Emacs. WYSIWYG editor TeX-fonts and CAS-interface (Giac, GTybalt, Macaulay 2, Maxima, Octave, Pari, Qcl, R and Yacas) in one. i686 Extra qtcurve-gtk2 1.0.2-1 A configurable set of widget styles for KDE and Gtk i686 Extra kismet 2010_01_R1-1 802.11b sniffing software i686 Extra glew 1.5.2-1 A cross-platform C/C++ extension loading library i686 Extra glproto 1.4.11-1 X11 OpenGL extension wire protocol jgc i686 Extra libmysqlclient 5.1.42-2 MySQL client libraries i686 Extra lighttpd 1.4.25-2 a secure, fast, compliant and very flexible web-server i686 Extra mysql 5.1.42-2 A fast SQL database server i686 Extra mysql-clients 5.1.42-2 MySQL client tools x86_64 x86_64 Core xfsprogs 3.1.1-1 XFS filesystem utilities x86_64 Core dhcpcd 5.1.5-1 RFC2131 compliant DHCP client daemon x86_64 Core mdadm 3.1.1-1 A tool for managing/monitoring Linux md device arrays, also known as Software RAID x86_64 Community puzzles 8853-1 Simon Tatham's Portable Puzzle Collection x86_64 Community windowlab 1.39-1 A small and simple window manager. x86_64 Community mms_client 0.0.3-4 mms protocol download utility x86_64 Community gstreamermm 0.10.6-1 C++ interface for GStreamer x86_64 Community subtitleeditor 0.36.0-1 A GTK+2 tool to edit subtitles for GNU/Linux/*BSD x86_64 Community texmaker 1.9.9-1 Free cross-platform latex editor x86_64 Community vuze 4.3.1.2-1 BitTorrent client with GUI, written in Java, formerly known as Azureus x86_64 Community libyaml 0.1.3-1 YAML 1.1 library x86_64 Community python-yaml 3.09-1 Python bindings for YAML, using fast libYAML library x86_64 Community nginx 0.7.65-1 lightweight HTTP server and IMAP/POP3 proxy server x86_64 Community schroot 1.3.2_1-2 Allows users to execute shell commands under different root filesystems. (Successor to dchroot). x86_64 Community sysprof 1.0.12-7 A sampling CPU profiler that uses a Linux kernel module to profile the entire system x86_64 Community sysprof-module 1.0.12-7 A sampling CPU profiler that uses a Linux kernel module to profile the entire system x86_64 Community haskell-http 4000.0.9-2 A library for client-side HTTP x86_64 Extra lm_sensors 3.1.2-1 Collection of user space tools for general SMBus access and hardware monitoring eric x86_64 Extra oprofile 0.9.6-2 a system-wide profiler for Linux systems, capable of profiling all running code at low overhead x86_64 Extra ratpoison 1.4.5-2 A simple keystroke-driven window manager x86_64 Extra wmii 3.6-4 Next generation WMI (Window Manager Improved 2) x86_64 Extra claws-mail 3.7.5-1 A GTK+ based e-mail client. andyrtr x86_64 Extra claws-mail-extra-plugins 3.7.5-1 Extra plugins for claws-mail andyrtr x86_64 Extra libchamplain 0.4.4-1 C library aimed to provide a Gtk+ widget to display rasterized maps andyrtr x86_64 Extra texmacs 1.0.7.3-1 GNU TeXmacs is a free scientific text editor, which was both inspired by TeX and GNU Emacs. WYSIWYG editor TeX-fonts and CAS-interface (Giac, GTybalt, Macaulay 2, Maxima, Octave, Pari, Qcl, R and Yacas) in one. x86_64 Extra qtcurve-gtk2 1.0.2-1 A configurable set of widget styles for KDE and Gtk x86_64 Extra kismet 2010_01_R1-1 802.11b sniffing software x86_64 Extra glew 1.5.2-1 A cross-platform C/C++ extension loading library x86_64 Extra glproto 1.4.11-1 X11 OpenGL extension wire protocol jgc x86_64 Extra libmysqlclient 5.1.42-2 MySQL client libraries x86_64 Extra lighttpd 1.4.25-2 a secure, fast, compliant and very flexible web-server x86_64 Extra mysql 5.1.42-2 A fast SQL database server x86_64 Extra mysql-clients 5.1.42-2 MySQL client tools AUR vagalume 0.8.2-2qipmsg 0.9.5-3 pidgin-latex 1.3.4-1cclive 0.5.9-1 kernel26-ck 2.6.32.7-2 nted 1.9.18-1transmission-svn-gtk 10089-1simple-icon-theme 2.2.5-1mpdris-svn 29-1 fcgiwrap 20100203-1 Thanks
#18 OFFLINE   securitybreach
  • 23,098 posts
Posted 04 February 2010 - 12:38 AM
Updates for Wed, 3 Feb 2010:Anyany      Community      dina-font      2.89-3      A monospace bitmap font, primarily aimed at programmers.            any     Community     xcursor-jimmac     2.0-5     Jimmac (Jimmac0) cursor theme          any     Community     xcursor-polar     1.4-7     Polar XCursor Theme          any     Community     xcursor-premium     0.3-6     Premium X Cursor Theme          any     Community     xcursor-simpleandsoft     0.2-4     A simple and soft X cursor theme          any     Community     xcursor-vanilla-dmz     0.4-5     Vanilla DMZ cursor theme          any     Community     xcursor-vanilla-dmz-aa     0.4-5     Vanilla DMZ AA cursor theme          any     Community     xcursor-chameleon-anthracite     0.5-3     Chameleon X Cursor Theme (anthracite flavour)          any     Community     xcursor-flatbed     0.2-1     Flatbed XCursor Theme          any     Community     xcursor-grounation     0.3-6     Grounation XCursor Theme          any     Community     xcursor-pinux     0.3-8     Pinux's Tux Cursors Theme i686i686    Core    inetutils    1.7-2   A collection of common network programsi686      Community      texmaker      1.9.9-2      Free cross-platform latex editor            i686     Community     eiciel     0.9.6-2     GNOME file ACL editor          i686     Community     gtweakui     0.4.0-3     A collection of front ends to various gconf configurations.          i686     Community     ico2xpm     1.2-1     A utility which converts Windows icons into X pixmaps          i686     Community     cuneiform     0.8.0-2     Linux port of an OCR system developed in Russia. Supports more than 20 languages.          i686     Community     dvdstyler     1.8.0-1     Cross-platform DVD authoring application          i686     Community     rss-glx     0.9.0-3     The Really Slick Screensavers port to GLX     cprimier     i686     Community     uzbl-browser     2010.02.02-1     A complete browser experience based on uzbl-core          i686     Community     uzbl-core     2010.02.02-1     Webpage interface component meant for integration with other tools and scripts          i686     Community     uzbl-tabbed     2010.02.02-1     Tabbing manager providing multiple uzbl-browser instances in 1 window          i686     Community     dwm     5.7.2-2     A dynamic window manager for X          i686     Community     abyssws     2.6-1     Abyss Web Server X1 - a compact full-featured web server          i686     Community     haskell-http     4000.0.9-3     A library for client-side HTTP          i686      Extra      quodlibet      2.2-1      An audio player written in pygtk            i686     Extra     php     5.3.1-5     An HTML-embedded scripting language     pierre     i686     Extra     php-apache     5.3.1-5     Apache SAPI for PHP          i686     Extra     php-cgi     5.3.1-5     CGI and FCGI SAPI for PHP          i686     Extra     php-curl     5.3.1-5     curl module for PHP          i686     Extra     php-enchant     5.3.1-5     enchant module for PHP          i686     Extra     php-gd     5.3.1-5     gd module for PHP          i686     Extra     php-gmp     5.3.1-5     gmp module for PHP          i686     Extra     php-intl     5.3.1-5     intl module for PHP          i686     Extra     php-ldap     5.3.1-5     ldap module for PHP          i686     Extra     php-mcrypt     5.3.1-5     mcrypt module for PHP          i686     Extra     php-odbc     5.3.1-5     ODBC modules for PHP          i686     Extra     php-pear     5.3.1-5     PHP Extension and Application Repository          i686     Extra     php-pgsql     5.3.1-5     PostgreSQL modules for PHP          i686     Extra     php-pspell     5.3.1-5     pspell module for PHP          i686     Extra     php-snmp     5.3.1-5     snmp module for PHP          i686     Extra     php-sqlite     5.3.1-5     sqlite3 module for PHP          i686     Extra     php-tidy     5.3.1-5     tidy module for PHP          i686     Extra     php-xsl     5.3.1-5     xsl module for PHP          i686     Extra     strigi     0.7.2-1     Fast crawling desktop search engine with Qt4 GUI          i686     Extra     aria2     1.8.2-1     Download utility that supports HTTP(S), FTP, BitTorrent, and Metalink          i686     Extra     cscope     15.7a-2     A developers tool for browsing program code          i686     Extra     wine     1.1.37-2     A compatibility layer for running Windows programs          i686     Extra     openoffice-base-beta     3.2.0_ooo320_m12-1     OpenOffice.org - a free multiplatform and multilingual office suite - testing branch leeding to next stable release          i686     Extra     openoffice-sdk-beta     3.2.0_ooo320_m12-1     OpenOffice.org SDK - development files for beta branch pkg          i686     Extra     speedcrunch     0.10.1-2     Simple but powerful calculator using Qt          i686     Extra     diffstat     1.51-1     Display a histogram of diff changes          i686     Extra     devicekit-disks     009-4     Disk Management Service     x86_64 x86_64    Core    inetutils    1.7-2   A collection of common network programsx86_64      Community      texmaker      1.9.9-2      Free cross-platform latex editor            x86_64     Community     eiciel     0.9.6-2     GNOME file ACL editor          x86_64     Community     gtweakui     0.4.0-3     A collection of front ends to various gconf configurations.          x86_64     Community     ico2xpm     1.2-1     A utility which converts Windows icons into X pixmaps          x86_64     Community     cuneiform     0.8.0-2     Linux port of an OCR system developed in Russia. Supports more than 20 languages.          x86_64     Community     dvdstyler     1.8.0-1     Cross-platform DVD authoring application          x86_64     Community     rss-glx     0.9.0-3     The Really Slick Screensavers port to GLX     cprimier     x86_64     Community     uzbl-browser     2010.02.02-1     A complete browser experience based on uzbl-core          x86_64     Community     uzbl-core     2010.02.02-1     Webpage interface component meant for integration with other tools and scripts          x86_64     Community     uzbl-tabbed     2010.02.02-1     Tabbing manager providing multiple uzbl-browser instances in 1 window          x86_64     Community     dwm     5.7.2-2     A dynamic window manager for X          x86_64     Community     haskell-http     4000.0.9-3     A library for client-side HTTP          x86_64      Extra      quodlibet      2.2-1      An audio player written in pygtk            x86_64     Extra     php     5.3.1-5     An HTML-embedded scripting language     pierre     x86_64     Extra     php-apache     5.3.1-5     Apache SAPI for PHP          x86_64     Extra     php-cgi     5.3.1-5     CGI and FCGI SAPI for PHP          x86_64     Extra     php-curl     5.3.1-5     curl module for PHP          x86_64     Extra     php-enchant     5.3.1-5     enchant module for PHP          x86_64     Extra     php-gd     5.3.1-5     gd module for PHP          x86_64     Extra     php-gmp     5.3.1-5     gmp module for PHP          x86_64     Extra     php-intl     5.3.1-5     intl module for PHP          x86_64     Extra     php-ldap     5.3.1-5     ldap module for PHP          x86_64     Extra     php-mcrypt     5.3.1-5     mcrypt module for PHP          x86_64     Extra     php-odbc     5.3.1-5     ODBC modules for PHP          x86_64     Extra     php-pear     5.3.1-5     PHP Extension and Application Repository          x86_64     Extra     php-pgsql     5.3.1-5     PostgreSQL modules for PHP          x86_64     Extra     php-pspell     5.3.1-5     pspell module for PHP          x86_64     Extra     php-snmp     5.3.1-5     snmp module for PHP          x86_64     Extra     php-sqlite     5.3.1-5     sqlite3 module for PHP          x86_64     Extra     php-tidy     5.3.1-5     tidy module for PHP          x86_64     Extra     php-xsl     5.3.1-5     xsl module for PHP          x86_64     Extra     strigi     0.7.2-1     Fast crawling desktop search engine with Qt4 GUI          x86_64     Extra     aria2     1.8.2-1     Download utility that supports HTTP(S), FTP, BitTorrent, and Metalink          x86_64     Extra     cscope     15.7a-2     A developers tool for browsing program code          x86_64     Extra     openoffice-base-beta     3.2.0_ooo320_m12-1     OpenOffice.org - a free multiplatform and multilingual office suite - testing branch leeding to next stable release          x86_64     Extra     openoffice-sdk-beta     3.2.0_ooo320_m12-1     OpenOffice.org SDK - development files for beta branch pkg          x86_64     Extra     speedcrunch     0.10.1-2     Simple but powerful calculator using Qt          x86_64     Extra     diffstat     1.51-1     Display a histogram of diff changes          x86_64     Extra     devicekit-disks     009-4     Disk Management Service          AUR wine-wc 1.1.37-2     ignaz_downloader 0.9.0-1kcheckgmail 0.6.0-1gohufont 1.1-1     spectrum-git 20100203-3publictransport-plasmoid 0.6.5-1qrencode 3.1.1-1     openvas-client 3.0.0-2     openvas-scanner 3.0.1-2iozone 3_331-1     Thanks
#19 OFFLINE   securitybreach
  • 23,098 posts
Posted 05 February 2010 - 12:24 AM
Updates for Thur, 4 Feb 2010:Anyany      Community      dina-font      2.89-5      A monospace bitmap font, primarily aimed at programmers.            any     Community     torcs-data     1.3.1-3     A 3D racing cars simulator using OpenGL          any     Extra     translate-toolkit     1.5.3-1     A toolkit to convert between various different translation formats, help process and validate localisations          any     Extra     python-logilab-astng     0.19.3-1     Extend python's abstract syntax tree          i686i686      Core      libmpc      0.8.1-1      Library for the arithmetic of complex numbers with arbitrarily high precision            i686     Core     libtool     2.2.6b-2     A generic library support script          i686      Community      dvdstyler      1.8.0-1.1      Cross-platform DVD authoring application            i686     Community     freetds     0.82-3     Library for accessing Sybase and MS SQL Server databases          i686     Community     gyachi     1.2.3-1     An improved fork of the GyachE Yahoo! client          i686     Community     torcs     1.3.1-4     A 3D racing cars simulator using OpenGL          i686     Community     vala     0.7.10-1     Compiler for the GObject type system          i686     Community     apvlv     0.0.9.3-1     A PDF Viewer which behaves like Vim          i686     Community     jogl     1.1.1-6     OpenGL bindings for java          i686     Community     exim     4.69-3     A Message Transfer Agent          i686     Community     python-scipy     0.7.1-4     SciPy (pronounced 'Sigh Pie') is open-source software for mathematics, science, and engineering.          i686     Community     leafnode     1.11.7-3     implements a store & forward NNTP proxy (client and server) with IPv4 and IPv6     i686     Community     musepack-tools     435-1     Musepack decoder/encoder          i686     Community     ngspice     20-1     Mixed-level/Mixed-signal circuit simulator based on Spice3f5, Ciber1b1, and Xspice.     i686     Community     quassel     0.5.2-1     QT4 irc client with a separated core          i686     Community     libcuefile     453-1     A library to work with CUE files          i686     Community     libreplaygain     453-1     A library to adjust audio gain          i686     Community     stunnel     4.31-1     A program that allows you to encrypt arbitrary TCP connections inside SSL. i686      Extra      at      3.1.12-1      AT and batch delayed command scheduling utility and daemon.            i686     Extra     maxima     5.20.1-2     Maxima - a sophisticated computer algebra system          i686     Extra     terminal     0.4.4-1     A modern terminal emulator primarly for the Xfce desktop environment          i686     Extra     tango-icon-theme     0.8.90-1     The Tango Desktop Project exists to create a consistent user experience     i686     Extra     mercurial     1.4.3-1     A scalable distributed SCM tool          i686     Extra     sbcl     1.0.35-1     Steel Bank Common Lisp          i686     Extra     libedit     20090923_3.0-1     Berkeley-style licensed command line editor library          i686     Extra     libmtp     1.0.2-1     library implementation of the Media Transfer Protocol          i686     Extra     python-numpy     1.4.0-1     Scientific tools for Python          i686     Extra     libassuan     2.0.0-1     Libassuan is the IPC library used by some GnuPG related software          x86_64 x86_64      Core      libmpc      0.8.1-1      Library for the arithmetic of complex numbers with arbitrarily high precision      x86_64     Core     libtool     2.2.6b-2     A generic library support script          x86_64      Community      freetds      0.82-3      Library for accessing Sybase and MS SQL Server databases            x86_64     Community     gyachi     1.2.3-1     An improved fork of the GyachE Yahoo! client          x86_64     Community     torcs     1.3.1-4     A 3D racing cars simulator using OpenGL          x86_64     Community     vala     0.7.10-1     Compiler for the GObject type system          x86_64     Community     apvlv     0.0.9.3-1     A PDF Viewer which behaves like Vim          x86_64     Community     jogl     1.1.1-6     OpenGL bindings for java          x86_64     Community     exim     4.69-3     A Message Transfer Agent          x86_64     Community     python-scipy     0.7.1-4     SciPy (pronounced 'Sigh Pie') is open-source software for mathematics, science, and engineering.          x86_64     Community     leafnode     1.11.7-3     implements a store & forward NNTP proxy (client and server) with IPv4 and IPv6     x86_64     Community     ngspice     20-1     Mixed-level/Mixed-signal circuit simulator based on Spice3f5, Ciber1b1, and Xspice.     x86_64     Community     quassel     0.5.2-1     QT4 irc client with a separated core          x86_64     Community     libcuefile     453-1     A library to work with CUE files          x86_64     Community     libreplaygain     453-1     A library to adjust audio gain          x86_64     Community     musepack-tools     435-1     Musepack decoder/encoder          x86_64     Community     stunnel     4.31-1     A program that allows you to encrypt arbitrary TCP connections inside SSL.     x86_64      Extra      at      3.1.12-1      AT and batch delayed command scheduling utility and daemon.            x86_64     Extra     maxima     5.20.1-2     Maxima - a sophisticated computer algebra system          x86_64     Extra     terminal     0.4.4-1     A modern terminal emulator primarly for the Xfce desktop environment          x86_64     Extra     tango-icon-theme     0.8.90-1     The Tango Desktop Project exists to create a consistent user experience          x86_64     Extra     mercurial     1.4.3-1     A scalable distributed SCM tool          x86_64     Extra     sbcl     1.0.35-1     Steel Bank Common Lisp          x86_64     Extra     libedit     20090923_3.0-1     Berkeley-style licensed command line editor library          x86_64     Extra     libmtp     1.0.2-1     library implementation of the Media Transfer Protocol          x86_64     Extra     python-numpy     1.4.0-1     Scientific tools for Python          x86_64     Extra     libassuan     2.0.0-1     Libassuan is the IPC library used by some GnuPG related software          AUR qbzr 0.18-1 fortune-mod-bashfr 2-4tuxmath 1.7.2-2     crack-attack 1.1.14-5planeshift 0.5.1-1juffed 0.8-1     openttd-beta 1.0.0_beta4-1     haskell-editline 0.2.1.0-1     libstdc++-doc 20100204-1pms-svn 386-1   Thanks
#20 OFFLINE   securitybreach
  • 23,098 posts
Posted 06 February 2010 - 12:25 PM
Updates for Fri, 5 Feb 2010:Anyany      Community      bzrtools      2.1.0-1      Useful collection of utilities (all plugins, right now) for bzr.            any     Community     jgoodies-looks     2.1.4-4     Free high-fidelity Windows and multi-platform appearance for Swing          any     Community     python-pypdf     1.12-4     A Pure-Python library built as a PDF toolkit          any     Community     python-pyx     0.10-4     Python library for the creation of PostScript and PDF files          any     Community     autojump     8-1     A faster way to navigate your filesystem from the command line     dgriffiths     any     Community     bbdb     2.35-3     A rolodex-like database for Emacs          any     Community     python-sphinx     0.6.4-1     Python documentation generator          any     Community     perl--arch     1.2.15-1     's Arch-specific Perl modules.          any     Community     pacpan     4.0-4     A tool for creating Perl packages for Pacman from CPAN.          any     Community     perl--common     1.0.12-1     's common Perl modules.          any      Extra      eric      4.4.1-1      A full-featured Python IDE that is written in PyQt4 using the QScintilla2 editor widget            any     Extra     perl-soap-lite     0.710.10-1     Client and server side SOAP implementation          any     Extra     vim-colorsamplerpack     8.03-1     Different colorschemes for vim          any     Extra     bash-completion     1.1-3     Programmable completion for the bash shell          any     Extra     quodlibet-plugins     2.2-1     Various plugins for QuodLibet         i686i686      Community      skrooge      0.6.0-1      Personal finances manager for KDE4, allowing you to keep track of your incomes and expenses            i686     Community     glom     1.13.2-1     An easy-to-use database designer and user interface          i686     Community     conkeror-git     20100206-1     A highly programmable web browser based on Mozilla XULRunner.          i686     Community     python-scipy     0.7.1-5     SciPy (pronounced 'Sigh Pie') is open-source software for mathematics, science, and engineering.          i686     Community     gnote     0.7.1-2     Experimental port of Tomboy to C++          i686     Community     python-jinja     2.2.1-1     A simple pythonic template language written in Python     i686     Community     exim     4.69-4     A Message Transfer Agent          i686     Community     iasl     20100121-1     Intel ACPI Source Language compiler          i686     Community     ffmpeg2theora     0.26-1     A simple converter to create Ogg Theora files         i686     Community     rtorrent     0.8.6-2     Ncurses BitTorrent client based on libTorrent         i686     Community     xmlrpc-c     1858-1     This library provides a modular implementation of XML-RPC for C and C++          i686     Community     panflute     0.6.1-1     Music player interface and panel applet - successor to music-applet          i686     Community     cuneiform     0.8.0-2.1     Linux port of an OCR system developed in Russia. Supports more than 20 languages.          i686     Community     cross-arm-elf-gcc-base     4.4.3-1     The GNU Compiler Collection          i686     Community     grsync     1.0.0-1     GTK GUI for rsync          i686     Community     ejabberd     2.1.2-2     An erlang jabber server          i686     Community     gtk2hs     0.10.1-5     A GTK+2 binding for Haskell          i686     Community     sdlmame     0.136u2-1     A port of the popular Multiple Arcade Machine Emulator using SDL with OpenGL support.          i686     Community     quassel     0.5.2-2     QT4 irc client with a separated core          i686      Extra      perl-fcgi      0.68-1      Fast CGI            i686     Extra     gweled     0.7-6     Bejewled Game (aka Diamond Mine)          i686     Extra     perl-crypt-ssleay     0.57-3     OpenSSL glue that provides LWP https support          i686     Extra     perl-io-stringy     2.110-7     I/O on in-core objects like strings/arrays          i686     Extra     perl-mime-tools     5.427-2     Parses streams to create MIME entities          i686     Extra     perl-xml-sax     0.96-2     Simple API for XML          i686     Extra     amarok     2.2.2-4     A media player for KDE          i686     Extra     perl-math-round     0.06-3     Perl extension for rounding numbers          i686     Extra     perl-net-upnp     1.4.2-1     Perl Module UPnP          i686     Extra     perl-xml-namespacesupport     1.09-5     Generic namespace helpers (ported from SAX2)          i686     Extra     dosbox     0.73-3     An emulator with builtin DOS for running DOS Games     i686     Extra     mrtg     2.16.3-1     Multi Router Traffic Grapher.          i686     Extra     libid3tag     0.15.1b-4     library for id3 tagging          i686     Extra     xaos     3.5-3     A fast portable real-time interactive fractal zoomer         i686     Extra     shared-mime-info     0.71-1     Freedesktop.org Shared MIME Info          i686     Extra     soundtouch     1.5.0-1     An audio processing library     i686     Extra     libjpeg     8-2     Library of JPEG support functions          i686     Extra     ettercap     NG_0.7.3-14     A network sniffer/interceptor/logger for ethernet LANs - console          i686     Extra     deluge     1.2.0-2     A bittorrent client written with python and pygtk          i686     Extra     lame     3.98.2-3     An MP3 encoder and graphical frame analyzer          i686     Extra     mplayer     30519-1     A movie player for linux          i686     Extra     myththemes     0.22-2     Themes for MythTV          i686     Extra     libvdpau     0.4-1     Nvidia VDPAU library          i686     Extra     mythplugins-mytharchive     0.22-1     MythTV plugin that lets you create DVDs from or archive your recorded shows          i686     Extra     mythplugins-mythbrowser     0.22-1     Mini web browser for MythTV          i686     Extra     mythplugins-mythflix     0.22-1     Netflix access plugin for MythTV          i686     Extra     mythplugins-mythgallery     0.22-1     Image gallery plugin for MythTV          i686     Extra     mythplugins-mythgame     0.22-1     Game emulator module for MythTV          i686     Extra     mythplugins-mythmovies     0.22-1     Local movie listings via MythTV          i686     Extra     mythplugins-mythmusic     0.22-1     Music playing plugin for MythTV          i686     Extra     mythplugins-mythnews     0.22-1     News checking plugin for MythTV          i686     Extra     mythplugins-mythvideo     0.22-1     Video playback and browsing plugin for MythTV          i686     Extra     mythplugins-mythweather     0.22-1     Weather checking plugin for MythTV          i686     Extra     mythplugins-mythweb     0.22-1     Web interface for MythTV's backend          i686     Extra     mythplugins-mythzoneminder     0.22-1     Allows for viewing of CCTV cameras through zoneminder          i686     Extra     nitrogen     1.5.1-1     Background browser and setter for X windows          i686     Extra     libassuan     1.0.5-2     Libassuan is the IPC library used by some GnuPG related software      x86_64 x86_64      Community      skrooge      0.6.0-1      Personal finances manager for KDE4, allowing you to keep track of your incomes and expenses            x86_64     Community     glom     1.13.2-1     An easy-to-use database designer and user interface          x86_64     Community     conkeror-git     20100206-1     A highly programmable web browser based on Mozilla XULRunner.          x86_64     Community     python-scipy     0.7.1-5     SciPy (pronounced 'Sigh Pie') is open-source software for mathematics, science, and engineering.          x86_64     Community     gnote     0.7.1-2     Experimental port of Tomboy to C++          x86_64     Community     python-jinja     2.2.1-1     A simple pythonic template language written in Python     foutrelis     x86_64     Community     exim     4.69-4     A Message Transfer Agent          x86_64     Community     iasl     20100121-1     Intel ACPI Source Language compiler          x86_64     Community     ffmpeg2theora     0.26-1     A simple converter to create Ogg Theora files     x86_64     Community     rtorrent     0.8.6-2     Ncurses BitTorrent client based on libTorrent         x86_64     Community     xmlrpc-c     1858-1     This library provides a modular implementation of XML-RPC for C and C++          x86_64     Community     panflute     0.6.1-1     Music player interface and panel applet - successor to music-applet          x86_64     Community     cross-arm-elf-gcc-base     4.4.3-1     The GNU Compiler Collection          x86_64     Community     grsync     1.0.0-1     GTK GUI for rsync          x86_64     Community     ejabberd     2.1.2-2     An erlang jabber server          x86_64     Community     gtk2hs     0.10.1-5     A GTK+2 binding for Haskell          x86_64     Community     sdlmame     0.136u2-1     A port of the popular Multiple Arcade Machine Emulator using SDL with OpenGL support.          x86_64     Community     quassel     0.5.2-2     QT4 irc client with a separated core          x86_64      Extra      perl-fcgi      0.68-1      Fast CGI            x86_64     Extra     gweled     0.7-6     Bejewled Game (aka Diamond Mine)          x86_64     Extra     perl-crypt-ssleay     0.57-3     OpenSSL glue that provides LWP https support          x86_64     Extra     perl-io-stringy     2.110-7     I/O on in-core objects like strings/arrays          x86_64     Extra     perl-mime-tools     5.427-2     Parses streams to create MIME entities          x86_64     Extra     perl-xml-sax     0.96-2     Simple API for XML          x86_64     Extra     amarok     2.2.2-4     A media player for KDE          x86_64     Extra     perl-math-round     0.06-3     Perl extension for rounding numbers          x86_64     Extra     perl-net-upnp     1.4.2-1     Perl Module UPnP          x86_64     Extra     perl-xml-namespacesupport     1.09-5     Generic namespace helpers (ported from SAX2)          x86_64     Extra     dosbox     0.73-3     An emulator with builtin DOS for running DOS Games          x86_64     Extra     mrtg     2.16.3-1     Multi Router Traffic Grapher.          x86_64     Extra     libid3tag     0.15.1b-4     library for id3 tagging          x86_64     Extra     xaos     3.5-3     A fast portable real-time interactive fractal zoomer         x86_64     Extra     shared-mime-info     0.71-1     Freedesktop.org Shared MIME Info          x86_64     Extra     soundtouch     1.5.0-1     An audio processing library     x86_64     Extra     libjpeg     8-2     Library of JPEG support functions          x86_64     Extra     ettercap     NG_0.7.3-14     A network sniffer/interceptor/logger for ethernet LANs - console          x86_64     Extra     deluge     1.2.0-2     A bittorrent client written with python and pygtk          x86_64     Extra     lame     3.98.2-3     An MP3 encoder and graphical frame analyzer          x86_64     Extra     mplayer     30519-1     A movie player for linux          x86_64     Extra     myththemes     0.22-2     Themes for MythTV          x86_64     Extra     libvdpau     0.4-1     Nvidia VDPAU library          x86_64     Extra     mythplugins-mytharchive     0.22-1     MythTV plugin that lets you create DVDs from or archive your recorded shows          x86_64     Extra     mythplugins-mythbrowser     0.22-1     Mini web browser for MythTV          x86_64     Extra     mythplugins-mythflix     0.22-1     Netflix access plugin for MythTV          x86_64     Extra     mythplugins-mythgallery     0.22-1     Image gallery plugin for MythTV          x86_64     Extra     mythplugins-mythgame     0.22-1     Game emulator module for MythTV          x86_64     Extra     mythplugins-mythmovies     0.22-1     Local movie listings via MythTV          x86_64     Extra     mythplugins-mythmusic     0.22-1     Music playing plugin for MythTV          x86_64     Extra     mythplugins-mythnews     0.22-1     News checking plugin for MythTV          x86_64     Extra     mythplugins-mythvideo     0.22-1     Video playback and browsing plugin for MythTV          x86_64     Extra     mythplugins-mythweather     0.22-1     Weather checking plugin for MythTV          x86_64     Extra     mythplugins-mythweb     0.22-1     Web interface for MythTV's backend          x86_64     Extra     mythplugins-mythzoneminder     0.22-1     Allows for viewing of CCTV cameras through zoneminder          x86_64     Extra     nitrogen     1.5.1-1     Background browser and setter for X windows          x86_64     Extra     libassuan     1.0.5-2     Libassuan is the IPC library used by some GnuPG related software          AUR daimonin 0.9.7.1-3yafray 0.0.9-4     sportstracker 4.1.1-1 rsound-git 20100206-1rsound 0.2-1     notify-osd 0.9.25-1mygui 3.0.0-1     wkhtmltopdf-static 0.9.1-1grappling_hook_demo 1-1love 0.6.1-1     Thanks
#21 OFFLINE   securitybreach
  • 23,098 posts
Posted 06 February 2010 - 09:31 PM
Updates for Sat, 6 Feb 2010:Anyany      Community      perl-xml-namespacesupport      1.10-1      Gen namespace helpers (ported from SAX2)            any     Community     bzrtools     2.1.0-1     Useful collection of utilities (all plugins, right now) for bzr.          any     Community     jgoodies-looks     2.1.4-4     Free high-fidelity Windows and multi-platform appearance for Swing          any     Community     python-pypdf     1.12-4     A Pure-Python library built as a PDF toolkit          any     Community     python-pyx     0.10-4     Python library for the creation of PostScript and PDF files          any      Extra      itext      5.0.1-1      Java Library for creating and manipulating PDFs on the fly            any     Extra     system-config-printer-common     1.1.16-1     Pygtk CUPS Configuration          any     Extra     system-config-printer-gnome     1.1.16-1     A CUPS printer configuration tool and status applet - GTK frontend          any     Extra          4.4.1-1     A full-featured Python IDE that is written in PyQt4 using the QScintilla2 editor widget          any     Extra     perl-soap-lite     0.710.10-1     Client and server side SOAP implementation          any     Extra     vim-colorsamplerpack     8.03-1     Different colorschemes for vim          any     Extra     bash-completion     1.1-3     Programmable completion for the bash shell     i686i686      Community      perl-xml-libxml      1.70-1      Interface to the libxml library            i686     Community     perl-xml-libxslt     1.70-1     Interface to the gnome libxslt library          i686     Community     skrooge     0.6.0-1     Personal finances manager for KDE4, allowing you to keep track of your incomes and expenses          i686     Community     glom     1.13.2-1     An easy-to-use database designer and user interface     jlichtblau     i686     Community     conkeror-git     20100206-1     A highly programmable web browser based on Mozilla XULRunner.          i686     Community     python-scipy     0.7.1-5     SciPy (pronounced 'Sigh Pie') is open-source software for mathematics, science, and engineering.          i686     Community     gnote     0.7.1-2     Experimental port of Tomboy to C++          i686     Community     python-jinja     2.2.1-1     A simple pythonic template language written in Python          i686      Extra      gtk-qt-engine      1.1-2      A GTK engine which makes your GTK2 Apps match your QT theme            i686     Extra     mythplugins-mytharchive     0.22-2     MythTV plugin that lets you create DVDs from or archive your recorded shows          i686     Extra     mythplugins-mythbrowser     0.22-2     Mini web browser for MythTV          i686     Extra     mythplugins-mythflix     0.22-2     Netflix access plugin for MythTV          i686     Extra     mythplugins-mythgallery     0.22-2     Image gallery plugin for MythTV          i686     Extra     mythplugins-mythgame     0.22-2     Game emulator module for MythTV          i686     Extra     mythplugins-mythmovies     0.22-2     Local movie listings via MythTV          i686     Extra     mythplugins-mythmusic     0.22-2     Music playing plugin for MythTV          i686     Extra     mythplugins-mythnews     0.22-2     News checking plugin for MythTV          i686     Extra     mythplugins-mythvideo     0.22-2     Video playback and browsing plugin for MythTV          i686     Extra     mythplugins-mythweather     0.22-2     Weather checking plugin for MythTV          i686     Extra     mythplugins-mythweb     0.22-2     Web interface for MythTV's backend          i686     Extra     mythplugins-mythzoneminder     0.22-2     Allows for viewing of CCTV cameras through zoneminder          i686     Extra     deskbar-applet     2.28.0-3     An all-in-one search bar for the GNOME panel          i686     Extra     mythtv     0.22-6     A Homebrew PVR project          i686     Extra     perl-time-hires     1.9719-1     Perl module: high resolution time, sleep, and alarm          i686     Extra     pycups     1.9.48-1     Python CUPS Bindings          i686     Extra     xmlto     0.0.23-1     Convert xml to many other formats          i686     Extra     libdaemon     0.14-1     A lightweight C library which eases the writing of UNIX daemons          i686     Extra     python-lxml     2.2.4-2     Python binding for the libxml2 and libxslt libraries          i686     Extra     perl-fcgi     0.68-1     Fast CGI          i686     Extra     gweled     0.7-6     Bejewled Game (aka Diamond Mine)          i686     Extra     perl-crypt-ssleay     0.57-3     OpenSSL glue that provides LWP https support          i686     Extra     perl-io-stringy     2.110-7     I/O on in-core objects like strings/arrays          i686     Extra     perl-mime-tools     5.427-2     Parses streams to create MIME entities          i686     Extra     perl-xml-sax     0.96-2     Simple API for XML          i686     Extra     amarok     2.2.2-4     A media player for KDE          i686     Extra     perl-math-round     0.06-3     Perl extension for rounding numbers          i686     Extra     perl-net-upnp     1.4.2-1     Perl Module UPnP          i686     Extra     perl-xml-namespacesupport     1.09-5     Gen namespace helpers (ported from SAX2)          i686     Extra     dosbox     0.73-3     An emulator with builtin DOS for running DOS Games          i686     Extra     mrtg     2.16.3-1     Multi Router Traffic Grapher.          i686     Extra     libid3tag     0.15.1b-4     library for id3 tagging          i686     Extra     xaos     3.5-3     A fast portable real-time interactive fractal zoomer          i686     Extra     shared-mime-info     0.71-1     Freedesktop.org Shared MIME Info          i686     Extra     soundtouch     1.5.0-1     An audio processing library      x86_64 x86_64      Community      perl-xml-libxml      1.70-1      Interface to the libxml library            x86_64     Community     perl-xml-libxslt     1.70-1     Interface to the gnome libxslt library          x86_64     Community     skrooge     0.6.0-1     Personal finances manager for KDE4, allowing you to keep track of your incomes and expenses          x86_64     Community     glom     1.13.2-1     An easy-to-use database designer and user interface          x86_64     Community     conkeror-git     20100206-1     A highly programmable web browser based on Mozilla XULRunner.          x86_64     Community     python-scipy     0.7.1-5     SciPy (pronounced 'Sigh Pie') is open-source software for mathematics, science, and engineering.          x86_64     Community     gnote     0.7.1-2     Experimental port of Tomboy to C++          x86_64     Community     python-jinja     2.2.1-1     A simple pythonic template language written in Python          x86_64      Extra      gtk-qt-engine      1.1-2      A GTK engine which makes your GTK2 Apps match your QT theme            x86_64     Extra     mythplugins-mytharchive     0.22-2     MythTV plugin that lets you create DVDs from or archive your recorded shows          x86_64     Extra     mythplugins-mythbrowser     0.22-2     Mini web browser for MythTV          x86_64     Extra     mythplugins-mythflix     0.22-2     Netflix access plugin for MythTV          x86_64     Extra     mythplugins-mythgallery     0.22-2     Image gallery plugin for MythTV          x86_64     Extra     mythplugins-mythgame     0.22-2     Game emulator module for MythTV          x86_64     Extra     mythplugins-mythmovies     0.22-2     Local movie listings via MythTV          x86_64     Extra     mythplugins-mythmusic     0.22-2     Music playing plugin for MythTV          x86_64     Extra     mythplugins-mythnews     0.22-2     News checking plugin for MythTV          x86_64     Extra     mythplugins-mythvideo     0.22-2     Video playback and browsing plugin for MythTV          x86_64     Extra     mythplugins-mythweather     0.22-2     Weather checking plugin for MythTV          x86_64     Extra     mythplugins-mythweb     0.22-2     Web interface for MythTV's backend          x86_64     Extra     mythplugins-mythzoneminder     0.22-2     Allows for viewing of CCTV cameras through zoneminder          x86_64     Extra     deskbar-applet     2.28.0-3     An all-in-one search bar for the GNOME panel          x86_64     Extra     mythtv     0.22-6     A Homebrew PVR project          x86_64     Extra     perl-time-hires     1.9719-1     Perl module: high resolution time, sleep, and alarm          x86_64     Extra     pycups     1.9.48-1     Python CUPS Bindings          x86_64     Extra     libdaemon     0.14-1     A lightweight C library which eases the writing of UNIX daemons          x86_64     Extra     xmlto     0.0.23-1     Convert xml to many other formats          x86_64     Extra     python-lxml     2.2.4-2     Python binding for the libxml2 and libxslt libraries          x86_64     Extra     perl-fcgi     0.68-1     Fast CGI          x86_64     Extra     gweled     0.7-6     Bejewled Game (aka Diamond Mine)          x86_64     Extra     perl-crypt-ssleay     0.57-3     OpenSSL glue that provides LWP https support          x86_64     Extra     perl-io-stringy     2.110-7     I/O on in-core objects like strings/arrays          x86_64     Extra     perl-mime-tools     5.427-2     Parses streams to create MIME entities          x86_64     Extra     perl-xml-sax     0.96-2     Simple API for XML          x86_64     Extra     amarok     2.2.2-4     A media player for KDE          x86_64     Extra     perl-math-round     0.06-3     Perl extension for rounding numbers          x86_64     Extra     perl-net-upnp     1.4.2-1     Perl Module UPnP          x86_64     Extra     perl-xml-namespacesupport     1.09-5     Gen namespace helpers (ported from SAX2)          x86_64     Extra     dosbox     0.73-3     An emulator with builtin DOS for running DOS Games          x86_64     Extra     mrtg     2.16.3-1     Multi Router Traffic Grapher.          x86_64     Extra     libid3tag     0.15.1b-4     library for id3 tagging      x86_64     Extra     xaos     3.5-3     A fast portable real-time interactive fractal zoomerx86_64     Extra     shared-mime-info     0.71-1     Freedesktop.org Shared MIME Info          x86_64     Extra     soundtouch     1.5.0-1     An audio processing library     AUR rsound-git 20100206-1 amule-adnza-svn 272-1vlc-nox 1.0.5-1     util-vserver 0.30.216_pre2864-1kernel26-grsecurity 2.6.32.7-2pytomtom 0.4.2-1     pidgin-gfire-svn 344-1ps_mem 2.1-1     gnomeradio 1.8-5 virtualbox_bin_unstable 3.1.4_BETA2-1     Thanks
#22 OFFLINE   securitybreach
  • 23,098 posts
Posted 08 February 2010 - 01:16 AM
Updates for Sun, 7 Feb 2010:Anyany      Community      hgsvn      0.1.8-1      A set of scripts to work locally on Subversion checkouts using Mercurial            any     Extra     python-gdata     2.0.7-1     Python client library for Google data APIsany      Extra      autoconf2.13      2.13-1      A GNU tool for automatically configuring source code (Legacy 2.1x version)            i686i686      Community      zim      0.43-2      A WYSIWYG text editor that aims at bringing the concept of a wiki to the desktop.            i686     Community     snort     2.8.3.2-1     A lightweight network intrusion detection system          i686     Community     exim     4.71-1.1     A Message Transfer Agent          i686     Community     gecko-mediaplayer     0.9.9-1     Browser plugin that uses gnome-mplayer to play media in a web browser          i686     Community     gnome-mplayer     0.9.9-1     A simple MPlayer GUI          i686     Community     duff     0.4-3     A command-line utility for quickly finding duplicates in a given set of files          i686     Community     ejabberd     2.1.2-3     An erlang jabber server          i686     Community     musepack-tools     435-2     Musepack decoder/encoder          i686     Community     dmd     1.056-1     The Digital Mars D compiler.          i686     Community     libphobos     1.056-1     Runtime library for the D programming language          i686     Community     ekg2     20100206-1     ncurses based Jabber, Gadu-Gadu, Tlen and IRC client          i686      Extra      spamassassin-spamc      3.3.0-1      Standalone C Client to spamassassin.            i686     Extra     wine     1.1.38-1     A compatibility layer for running Windows programs          i686     Extra     fetchmail     6.3.14-1     A remote-mail retrieval utility          i686     Extra     mplayer     30325-2     A movie player for linux          i686     Extra     hwdetect     2010.02-1     Hardware detection script with loading modules and mkinitcpio.conf / rc.conf support          i686     Extra     lighttpd     1.4.26-1     a secure, fast, compliant and very flexible web-server          i686     Extra     spamassassin     3.3.0-1     A mail filter to identify spam.          i686     Extra     ardour     2.8.7-1     A multichannel hard disk recorder and digital audio workstation          i686     Extra     perl-date-manip     6.07-3     Date::Manip - date manipulation routines          i686     Extra     xulrunner     1.9.2-4     Mozilla Runtime Environment          i686     Extra     john     1.7.3.4-1     John The Ripper - A fast password cracker. Additional patches (NTLM, MySQL, Kerberos V5, etc.) included.          x86_64x86_64      Community      zim      0.43-2      A WYSIWYG text editor that aims at bringing the concept of a wiki to the desktop.            x86_64     Community     snort     2.8.3.2-1     A lightweight network intrusion detection system          x86_64     Community     exim     4.71-1.1     A Message Transfer Agent          x86_64     Community     gecko-mediaplayer     0.9.9-1     Browser plugin that uses gnome-mplayer to play media in a web browser          x86_64     Community     gnome-mplayer     0.9.9-1     A simple MPlayer GUI          x86_64     Community     duff     0.4-3     A command-line utility for quickly finding duplicates in a given set of files          x86_64     Community     ejabberd     2.1.2-3     An erlang jabber server          x86_64     Community     musepack-tools     435-2     Musepack decoder/encoder          x86_64     Community     ekg2     20100206-1     ncurses based Jabber, Gadu-Gadu, Tlen and IRC client          x86_64      Extra      spamassassin-spamc      3.3.0-1      Standalone C Client to spamassassin.            x86_64     Extra     fetchmail     6.3.14-1     A remote-mail retrieval utility          x86_64     Extra     mplayer     30325-2     A movie player for linux          x86_64     Extra     hwdetect     2010.02-1     Hardware detection script with loading modules and mkinitcpio.conf / rc.conf support          x86_64     Extra     lighttpd     1.4.26-1     a secure, fast, compliant and very flexible web-server          x86_64     Extra     spamassassin     3.3.0-1     A mail filter to identify spam.          x86_64     Extra     ardour     2.8.7-1     A multichannel hard disk recorder and digital audio workstation          x86_64     Extra     perl-date-manip     6.07-3     Date::Manip - date manipulation routines          x86_64     Extra     xulrunner     1.9.2-4     Mozilla Runtime Environment          x86_64     Extra     john     1.7.3.4-1     John The Ripper - A fast password cracker. Additional patches (NTLM, MySQL, Kerberos V5, etc.) included.     AUR chromium-browser-bin LATEST-17     facebook-google-sync 3-1openc6 0.9.9-2     qscite 0.5_svn190-1pymotw 1.113-1     chromium-browser-svn perl-crypt-dh 0.06-1 bin32-wine 1.1.38-1     playitslowly 1.2.1-2     midimon 0.3-1Thanks
#23 OFFLINE   securitybreach
  • 23,098 posts
Posted 08 February 2010 - 10:48 PM
Updates for Mon, 8 Feb 2010:Anyany Community devede 3.16.0-1     A program to create VideoDVDs and CDsi686i686 Community fotoxx 9.5-1 A program for improving image files made with a digital camera i686 Community printoxx 2.3-3 Adjusting images on a sheet of paper for printing i686 Community cherokee 0.99.42-2 A very fast, flexible and easy to configure Web Server i686 Community cinelerra-cv 20100208-1 A complete audio and video production environment for Linux. i686 Community dvdstyler 1.8.0-2 Cross-platform DVD authoring application i686 Community ffmpegthumbnailer 2.0.0-4 Lightweight video thumbnailer that can be used by file managers. i686 Community libquicktime 1.1.4-3 A library for reading and writing quicktime files. i686 Community mlt 0.4.10-3 An open source multimedia framework spupykin i686 Community wxsvg 1.0.2-3 C++ library to create, manipulate and render SVG files i686 Community google-gadgets-common 0.11.2-1 Desktop widgets from Google (common files) i686 Community google-gadgets-gtk 0.11.2-1 Desktop widgets from Google (GTK+ front-end) i686 Community google-gadgets-qt 0.11.2-1 Desktop widgets from Google (Qt front-end) i686 Extra openbox 3.4.11-1 A window manager for the X11 windowing system i686 Extra hwdetect 2010.02-2 Hardware detection script with loading modules and mkinitcpio.conf / rc.conf support i686 Extra gparted 0.5.1-3 A Partition Magic clone, frontend to GNU Parted i686 Extra subversion 1.6.9-2 Replacement for CVS, another versioning system (svn) i686 Extra avidemux-cli 2.5.2-2 A graphical tool to edit video (filter/re-encode/split) i686 Extra avidemux-gtk 2.5.2-2 A graphical tool to edit video (filter/re-encode/split) - GTK GUI i686 Extra avidemux-qt 2.5.2-2 A graphical tool to edit video (filter/re-encode/split) - QT GUI i686 Extra chromium 4.0.249.78-3 An open-source browser project that aims to build a safer, faster, and more stable way for all users to experience the web i686 Extra cmus 2.2.0-11 A very feature-rich ncurses-based music player aaron i686 Extra ffmpeg 30526-1 Complete and free Internet live audio and video broadcasting solution for Linux/Unix i686 Extra gstreamer0.10-ugly 0.10.13-4 GStreamer Multimedia Framework Ugly plugin libraries i686 Extra gstreamer0.10-ugly-plugins 0.10.13-4 GStreamer Multimedia Framework Ugly Plugins (gst-plugins-ugly) i686 Extra mplayer 30526-1 A movie player for linux i686 Extra vlc 1.0.5-2 A multi-platform MPEG, VCD/DVD, and DivX player i686 Extra vlc-plugin 1.0.5-2 VLC mozilla browser plugin i686 Extra x264 20100207-1 free library for encoding H264/AVC video streams i686 Extra zope-interface 3.5.3-1 Separate distribution of the zope.interface package used in Zope 3. i686 Extra go-openoffice 3.2.0.5-1 OpenOffice.org - go-oo.org enhanced version of SUN's office suite i686 Extra licq 1.3.8-1 Advanced graphical ICQ clone and more for Unix x86_64x86_64      Community      zim      0.43-2      A WYSIWYG text editor that aims at bringing the concept of a wiki to the desktop.            x86_64     Community     snort     2.8.3.2-1     A lightweight network intrusion detection system          x86_64     Community     exim     4.71-1.1     A Message Transfer Agent          x86_64     Community     gecko-mediaplayer     0.9.9-1     Browser plugin that uses gnome-mplayer to play media in a web browser          x86_64     Community     gnome-mplayer     0.9.9-1     A simple MPlayer GUI          x86_64     Community     duff     0.4-3     A command-line utility for quickly finding duplicates in a given set of files          x86_64     Community     ejabberd     2.1.2-3     An erlang jabber server          x86_64     Community     musepack-tools     435-2     Musepack decoder/encoder          x86_64     Community     ekg2     20100206-1     ncurses based Jabber, Gadu-Gadu, Tlen and IRC client          x86_64      Extra      spamassassin-spamc      3.3.0-1      Standalone C Client to spamassassin.            x86_64     Extra     fetchmail     6.3.14-1     A remote-mail retrieval utility          x86_64     Extra     mplayer     30325-2     A movie player for linux          x86_64     Extra     hwdetect     2010.02-1     Hardware detection script with loading modules and mkinitcpio.conf / rc.conf support          x86_64     Extra     lighttpd     1.4.26-1     a secure, fast, compliant and very flexible web-server          x86_64     Extra     spamassassin     3.3.0-1     A mail filter to identify spam.          x86_64     Extra     ardour     2.8.7-1     A multichannel hard disk recorder and digital audio workstation          x86_64     Extra     perl-date-manip     6.07-3     Date::Manip - date manipulation routines          x86_64     Extra     xulrunner     1.9.2-4     Mozilla Runtime Environment          x86_64     Extra     john     1.7.3.4-1     John The Ripper - A fast password cracker. Additional patches (NTLM, MySQL, Kerberos V5, etc.) included.  AURzynaddsubfx-lash 2.4.0-1irssi-xmpp 0.50-1 lib32-sdl_image 1.2.10-2 firefox-pgo-minefield 100207-1 firefox-pgo-minefield-smp 100204-1firefox-pgo-beta 3.6-1firefox-pgo 3.6-1tweetdeck 0_33.0-1dikt 2a-1 daloradius 0.9.8-1Thanks
#24 OFFLINE   securitybreach
  • 23,098 posts
Posted 10 February 2010 - 12:20 AM
Updates for Tues, 9 Feb 2010:There are tons of updates today because KDE 4.4 went stable. The list quite long, so here goes.... Anyany   Community   scala   2.7.7-2   A Java-interoperable language with object-oriented and functional features      any Community gnuhtml2latex 0.3-2 A Perl script that converts html files to latex any   Extra   kde-l10n-ar   4.4.0-1   Arabic Localization for KDE      any Extra kde-l10n-bg 4.4.0-1 Bulgarian Localization for KDE any Extra kde-l10n-ca 4.4.0-1 Catalan Localization for KDE any Extra kde-l10n-ca@valencia 4.4.0-1 Catalan (Valencian) Localization for KDE any Extra kde-l10n-cs 4.4.0-1 Czech Localization for KDE any Extra kde-l10n-csb 4.4.0-1 Kashubian Localization for KDE any Extra kde-l10n-da 4.4.0-1 Danish Localization for KDE any Extra kde-l10n-de 4.4.0-1 German Localization for KDE any Extra kde-l10n-el 4.4.0-1 Greek Localization for KDE any Extra kde-l10n-en_gb 4.4.0-1 British English Localization for KDE any Extra kde-l10n-eo 4.4.0-1 Esperanto Localization for KDE any Extra kde-l10n-es 4.4.0-1 Spanish Localization for KDE any Extra kde-l10n-et 4.4.0-1 Estonian Localization for KDE any Extra kde-l10n-eu 4.4.0-1 Basque Localization for KDE any Extra kde-l10n-fi 4.4.0-1 Finnish Localization for KDE any Extra kde-l10n-fr 4.4.0-1 French Localization for KDE any Extra kde-l10n-fy 4.4.0-1 Frisian Localization for KDE any Extra kde-l10n-ga 4.4.0-1 Irish Gaelic Localization for KDE any Extra kde-l10n-gl 4.4.0-1 Galician Localization for KDE any Extra kde-l10n-gu 4.4.0-1 Gujarati Localization for KDE any Extra kde-l10n-he 4.4.0-1 Hebrew Localization for KDE any Extra kde-l10n-hi 4.4.0-1 Hindi Localization for KDE any Extra kde-l10n-hr 4.4.0-1 Croatian Localization for KDE any Extra kde-l10n-hu 4.4.0-1 Hungarian Localization for KDE any Extra kde-l10n-id 4.4.0-1 Indonesian Localization for KDE any Extra kde-l10n-is 4.4.0-1 Icelandic Localization for KDE any Extra kde-l10n-it 4.4.0-1 Italian Localization for KDE any Extra kde-l10n-ja 4.4.0-1 Japanese Localization for KDE any Extra kde-l10n-kk 4.4.0-1 Kazakh Localization for KDE any Extra kde-l10n-km 4.4.0-1 Khmer Localization for KDE any Extra kde-l10n-kn 4.4.0-1 Kannada Localization for KDE any Extra kde-l10n-ko 4.4.0-1 Korean Localization for KDE any Extra kde-l10n-lt 4.4.0-1 Lithuanian Localization for KDE any Extra kde-l10n-lv 4.4.0-1 Latvian Localization for KDE any Extra kde-l10n-mai 4.4.0-1 Maithili Localization for KDE any Extra kde-l10n-mk 4.4.0-1 Macedonian Localization for KDE any Extra kde-l10n-ml 4.4.0-1 Malayalam Localization for KDE any Extra kde-l10n-nb 4.4.0-1 Norwegian Bokmal Localization for KDE any Extra kde-l10n-nds 4.4.0-1 Low Saxon Localization for KDE any Extra kde-l10n-nl 4.4.0-1 Dutch Localization for KDE any Extra kde-l10n-nn 4.4.0-1 Norwegian Nynorsk Localization for KDE any Extra kde-l10n-pa 4.4.0-1 Panjabi/Punjabi Localization for KDE any Extra kde-l10n-pl 4.4.0-1 Polish Localization for KDE any Extra kde-l10n-pt 4.4.0-1 Portuguese Localization for KDE any Extra kde-l10n-pt_br 4.4.0-1 Brazilian Portuguese Localization for KDE any Extra kde-l10n-ro 4.4.0-1 Romanian Localization for KDE any Extra kde-l10n-ru 4.4.0-1 Russian Localization for KDE any Extra kde-l10n-si 4.4.0-1 Sinhala Localization for KDE any Extra kde-l10n-sk 4.4.0-1 Slovak Localization for KDE any Extra kde-l10n-sl 4.4.0-1 Slovenian Localization for KDE any   Extra   kde-l10n-sr   4.4.0-1   Serbian Localization for KDE      any Extra kde-l10n-sv 4.4.0-1 Swedish Localization for KDE any Extra kde-l10n-tg 4.4.0-1 Tajik Localization for KDE any Extra kde-l10n-tr 4.4.0-1 Turkish Localization for KDE any Extra kde-l10n-uk 4.4.0-1 Ukrainian Localization for KDE any Extra kde-l10n-wa 4.4.0-1 Walloon Localization for KDE any Extra kde-l10n-zh_cn 4.4.0-1 Chinese Simplified Localization for KDE any Extra kde-l10n-zh_tw 4.4.0-1 Chinese Traditional Localization for KDE any Extra kde-meta-kdeaccessibility 4.4-3 Meta package for kdeaccessibility any Extra kde-meta-kdeadmin 4.4-3 Meta package for kdeadmin any Extra kde-meta-kdeartwork 4.4-3 Meta package for kdeartwork any Extra kde-meta-kdebase 4.4-3 Meta package for kdebase any Extra kde-meta-kdeedu 4.4-3 Meta package for kdeedu any Extra kde-meta-kdegames 4.4-3 Meta package for kdegames any Extra kde-meta-kdegraphics 4.4-3 Meta package for kdegraphics any Extra kde-meta-kdemultimedia 4.4-3 Meta package for kdemultimedia any Extra kde-meta-kdenetwork 4.4-3 Meta package for kdenetwork any Extra kde-meta-kdepim 4.4-3 Meta package for kdepim any Extra kde-meta-kdeplasma-addons 4.4-3 Meta package for kdeplasma-addons any Extra kde-meta-kdesdk 4.4-3 Meta package for kdesdk any Extra kde-meta-kdetoys 4.4-3 Meta package for kdetoys any Extra kde-meta-kdeutils 4.4-3 Meta package for kdeutils any Extra kde-meta-kdewebdev 4.4-3 Meta package for kdewebdev any Extra oxygen-icons 4.4.0-1 The Oxygen Icon Theme any Extra oxygen-icons-svg 4.4.0-1 The Oxygen Icon Theme (Scalable Vector Graphics) any Extra qt-doc 4.6.1-1 The Qt gui toolkit documentation any Extra shared-desktop-ontologies 0.2-1 Ontologies necessary for the Nepomuk semantic desktop. i686i686  Core   kernel26   2.6.32.8-1   The Linux Kernel and modules      i686 Core kernel26-firmware 2.6.32.8-1 The included firmware files of the Linux Kernel i686 Core kernel26-headers 2.6.32.8-1 Header files and scripts for building modules for kernel26 i686 Core wpa_supplicant 0.6.10-1 A utility providing key negotiation for WPA wireless networks i686  Community   gimpshop   2.2.11-7   A modified Gimp that features menu layouts and naming conventions similar to those in Photoshop.      i686 Community pwsafe 0.2.0-5 A commandline program for managing encrypted password databases i686 Community sgmltools-lite 3.0.3-2 SGML processing tools (sucessor to the obsolete SGMLtools) i686 Community uucp 1.07-2 Taylor UUCP is a free implementation of UUCP and is the standard UUCP used on the GNU system i686 Community blueman 1.21-3 GTK+ bluetooth manager i686 Community bsdiff 4.3-5 bsdiff and bspatch are tools for building and applying patches to binary files. i686 Community fgetty 0.6-5 A mingetty stripped of the printfs i686 Community freetds 0.82-4 Library for accessing Sybase and MS SQL Server databases i686 Community libacpi 0.2-2.1 general purpose lib to gather ACPI data i686 Community librsync 0.9.7-5 A free software library that implements the rsync remote-delta algorithm (rdiff) foutrelis i686 Community lomoco 1.0-6 Logitech USB mouse configuration program i686 Community tcllib 1.11.1-1.1 Set of pure-Tcl extensions. i686 Community bwm-ng 0.6-3 A small and simple console-based live bandwidth monitor i686 Community qtcreator 1.3.1-1 Lightweight, cross-platform integrated development environment i686 Community perl-gtk2-mozembed 0.08-2 Interface to the Mozilla embedding widget i686 Community exim 4.71-1.2 A Message Transfer Agent angvp i686  Extra   soprano   2.3.73-2   A library which provides a highly usable object-oriented C++/Qt4 framework for RDF data      i686 Extra curl 7.20.0-1 An URL retrival utility and library i686 Extra wpa_supplicant_gui 0.6.10-1 A qt frontend to wpa_supplicant i686 Extra mercurial 1.4.3-2 A scalable distributed SCM tool i686 Extra jhead 2.90-1 EXIF JPEG info parser and thumbnail remover i686 Extra kdelibs 4.4.0-3 KDE Core Libraries i686 Extra akonadi 1.3.1-1 PIM layer, which provides an asynchronous API to access all kind of PIM data i686 Extra libv4l 0.6.4-1 Userspace library for Video 4 Linux (1 and 2) i686 Extra kdeartwork-colorschemes 4.4.0-1 KDE color schemes i686 Extra kdeartwork-desktopthemes 4.4.0-1 KDE desktop themes i686 Extra kdeartwork-emoticons 4.4.0-1 KDE emoticons i686 Extra kdeartwork-iconthemes 4.4.0-1 KDE icon themes i686 Extra kdeartwork-kscreensaver 4.4.0-1 KDE screensaver i686 Extra kdeartwork-sounds 4.4.0-1 KDE sounds i686 Extra kdeartwork-styles 4.4.0-1 KDE styles i686 Extra kdeartwork-wallpapers 4.4.0-1 KDE wallpapers i686 Extra kdeartwork-weatherwallpapers 4.4.0-1 KDE weather wallpapers i686 Extra kdebase-dolphin 4.4.0-3 File Manager i686 Extra kdebase-kappfinder 4.4.0-3 Menu Updating Tool i686 Extra kdebase-kdepasswd 4.4.0-3 Change Password i686 Extra kdebase-kdialog 4.4.0-3 a utility for displaying dialog boxes from shell scripts i686 Extra kdebase-kfind 4.4.0-3 Find Files/Folders i686 Extra kdebase-kinfocenter 4.4.0-3 Info Center i686 Extra kdebase-konqueror 4.4.0-3 KDE File Manager & Web Browser i686 Extra kdebase-konsole 4.4.0-3 Terminal i686 Extra kdebase-kwrite 4.4.0-3 Text Editor i686 Extra kdebase-lib 4.4.0-3 KDE libraries for the basic desktop applications i686 Extra kdebase-plasma 4.4.0-3 Display the contents of folders (User´s home folder as default) i686 Extra kdebase-runtime 4.4.0-3 KDE Base Runtime Environment i686 Extra kdebase-workspace 4.4.0-3 KDE Base Workspace i686 Extra kdebindings-csharp 4.4.0-2 KDE bindings for mono i686 Extra kdebindings-python 4.4.0-2 KDE bindings for python i686 Extra kdebindings-ruby 4.4.0-2 KDE bindings for ruby i686 Extra kdebindings-smoke 4.4.0-2 Language independent library for Qt and KDE bindings i686 Extra kdeedu-blinken 4.4.0-2 A memory enhancement game i686 Extra kdeedu-cantor 4.4.0-2 KDE Frontend to Mathematical Software i686 Extra kdeedu-data 4.4.0-2 Data for KDE Educational Software i686 Extra kdeedu-kalgebra 4.4.0-2 Math Expression Solver and Plotter i686 Extra kdeedu-kalzium 4.4.0-2 KDE Periodic Table of Elements i686 Extra kdeedu-kanagram 4.4.0-2 KDE Letter Order Game i686 Extra kdeedu-kbruch 4.4.0-2 Practice exercises with fractions i686 Extra kdeedu-kgeography 4.4.0-2 A Geography Learning Program i686 Extra kdeedu-khangman 4.4.0-2 KDE Hangman Game i686 Extra kdeedu-kig 4.4.0-2 Explore Geometric Constructions i686 Extra kdeedu-kiten 4.4.0-2 Japanese Reference and Study Tool i686 Extra kdeedu-klettres 4.4.0-2 a KDE program to learn the alphabet i686 Extra kdeedu-kmplot 4.4.0-2 Function Plotter i686 Extra kdeedu-kstars 4.4.0-2 Desktop Planetarium i686 Extra kdeedu-ktouch 4.4.0-2 Touch Typing Tutor i686 Extra kdeedu-kturtle 4.4.0-2 Educational Programming Environment i686  Extra   kdeedu-kturtle   4.4.0-2   Educational Programming Environment      i686 Extra kdeedu-kwordquiz 4.4.0-2 A flashcard and vocabulary learning program i686 Extra kdeedu-libkdeedu 4.4.0-2 Support library for KDE Educational Software i686 Extra kdeedu-marble 4.4.0-2 Desktop Globe i686 Extra kdeedu-parley 4.4.0-2 Vocabulary Trainer i686 Extra kdeedu-rocs 4.4.0-2 Graph Theory Tool for Professors and Students. i686 Extra kdeedu-step 4.4.0-2 Simulate physics experiments i686 Extra kdegames-bomber 4.4.0-1 Arcade Bombing Game i686 Extra kdegames-bovo 4.4.0-1 Five-in-a-row Board Game i686 Extra kdegames-granatier 4.4.0-1 Granatier i686 Extra kdegames-kapman 4.4.0-1 Eat pills escaping ghosts i686 Extra kdegames-katomic 4.4.0-1 Sokoban-like Logic Game i686 Extra kdegames-kbattleship 4.4.0-1 Battleship Game i686 Extra kdegames-kblackbox 4.4.0-1 Blackbox Logic Game i686 Extra kdegames-kblocks 4.4.0-1 Falling Blocks Game i686 Extra kdegames-kbounce 4.4.0-1 Ball Bouncing Game i686 Extra kdegames-kbreakout 4.4.0-1 Breakout-like Game i686 Extra kdegames-kdiamond 4.4.0-1 Three-in-a-row game i686 Extra kdegames-kfourinline 4.4.0-1 Four-in-a-row Board Game i686 Extra kdegames-kgoldrunner 4.4.0-1 A game of action and puzzle-solving i686 Extra kdegames-kigo 4.4.0-1 Go Board Game i686 Extra kdegames-killbots 4.4.0-1 Killbots i686 Extra kdegames-kiriki 4.4.0-1 Yahtzee-like Dice Game i686 Extra kdegames-kjumpingcube 4.4.0-1 Territory Capture Game i686 Extra kdegames-klines 4.4.0-1 Tactical Game i686 Extra kdegames-kmahjongg 4.4.0-1 Mahjongg Solitaire i686 Extra kdegames-kmines 4.4.0-1 Minesweeper-like Game i686 Extra kdegames-knetwalk 4.4.0-1 Network Construction Game i686 Extra kdegames-kolf 4.4.0-1 Miniature Golf i686 Extra kdegames-kollision 4.4.0-1 A simple ball dodging game i686 Extra kdegames-konquest 4.4.0-1 Galactic Strategy Game i686 Extra kdegames-kpat 4.4.0-1 Patience Card Game i686 Extra kdegames-kreversi 4.4.0-1 Reversi Board Game i686 Extra kdegames-ksame 4.4.0-1 Board Game i686 Extra kdegames-kshisen 4.4.0-1 Shisen-Sho Mahjongg-like Tile Game i686 Extra kdegames-ksirk 4.4.0-1 World Domination Strategy Game i686 Extra kdegames-kspaceduel 4.4.0-1 Space Arcade Game i686 Extra kdegames-ksquares 4.4.0-1 Connect the dots to create squares i686 Extra kdegames-ksudoku 4.4.0-1 KSudoku, Sudoku game & more for KDE i686 Extra kdegames-ktron 4.4.0-1 Tron-like Game i686 Extra kdegames-ktuberling 4.4.0-1 Picture Game for Children i686 Extra kdegames-kubrick 4.4.0-1 A 3-D game based on Rubik´s Cube i686 Extra kdegames-libkdegames 4.4.0-1 KDE game library i686 Extra kdegames-libkmahjongg 4.4.0-1 Library used for loading and rendering of Mahjongg tilesets. i686 Extra kdegames-lskat 4.4.0-1 Card Game i686 Extra kdegames-palapeli 4.4.0-1 Jigsaw puzzle game i686 Extra kdegraphics-gwenview 4.4.0-1 A simple image viewer i686 Extra kdegraphics-kamera 4.4.0-1 Configure Kamera i686 Extra kdegraphics-kcolorchooser 4.4.0-1 Color Chooser i686 Extra kdegraphics-kgamma 4.4.0-1 A monitor calibration tool i686  Extra   kdegraphics-kolourpaint   4.4.0-1   Paint Program      i686 Extra kdegraphics-kruler 4.4.0-1 Screen Ruler i686 Extra kdegraphics-ksnapshot 4.4.0-1 Screen Capture Program i686 Extra kdegraphics-libs 4.4.0-1 Support library for KDE Graphics Software i686 Extra kdegraphics-okular 4.4.0-1 Document Viewer i686 Extra kdemultimedia-dragonplayer 4.4.0-1 Video Player i686 Extra kdemultimedia-juk 4.4.0-1 Music Player i686 Extra kdemultimedia-kioslave 4.4.0-1 Audio CD Browser i686 Extra kdemultimedia-kmix 4.4.0-1 Sound Mixer i686 Extra kdemultimedia-kscd 4.4.0-1 CD Player i686 Extra kdemultimedia-mplayerthumbs 4.4.0-1 Video Files (MPlayerThumbs) i686 Extra kdenetwork-filesharing 4.4.0-1 Konqueror properties dialog plugin to share a directory with the local network i686 Extra kdenetwork-kdnssd 4.4.0-1 Network Services i686 Extra kdenetwork-kget 4.4.0-1 Download Manager i686 Extra kdenetwork-kopete 4.4.0-1 Instant Messenger i686 Extra kdenetwork-kppp 4.4.0-1 Internet Dial-Up Tool i686 Extra kdenetwork-krdc 4.4.0-1 Remote Desktop Client i686 Extra kdenetwork-krfb 4.4.0-1 Desktop Sharing i686 Extra kdepim-akonadiconsole 4.4.0-1 Akonadi Management and Debugging Console i686 Extra kdepim-akregator 4.4.0-1 A Feed Reader for KDE i686 Extra kdepim-blogilo 4.4.0-1 A KDE Blogging Client i686 Extra kdepim-console 4.4.0-1 Command line tool for accessing calendar files i686 Extra kdepim-kaddressbook 4.4.0-1 Contact Manager i686 Extra kdepim-kalarm 4.4.0-1 Personal Alarm Scheduler i686 Extra kdepim-kjots 4.4.0-1 Note Taker i686 Extra kdepim-kleopatra 4.4.0-1 Certificate Manager and Unified Crypto GUI i686 Extra kdepim-kmail 4.4.0-1 Mail Client i686 Extra kdepim-knode 4.4.0-1 News Reader i686 Extra kdepim-knotes 4.4.0-1 Popup Notes i686 Extra kdepim-kontact 4.4.0-1 Personal Information Manager i686 Extra kdepim-korganizer 4.4.0-1 Calendar and Scheduling Program i686 Extra kdepim-kresources 4.4.0-1 KDE PIM resources i686 Extra kdepim-ktimetracker 4.4.0-1 Personal Time Tracker i686 Extra kdepim-libkdepim 4.4.0-1 Library for KDE PIM i686 Extra kdepim-runtime 4.4.0-1 KDE PIM Runtime Environment i686 Extra kdepim-wizards 4.4.0-1 KDE Groupware Wizard i686 Extra kdepimlibs 4.4.0-1 KDE PIM Libraries i686 Extra kdeplasma-addons-applets-bball 4.4.0-1 A bouncy ball for plasma i686 Extra kdeplasma-addons-applets-binary-clock 4.4.0-1 Time displayed in binary format i686 Extra kdeplasma-addons-applets-blackboard 4.4.0-1 Black Board i686 Extra kdeplasma-addons-applets-bubblemon 4.4.0-1 A pretty bubble that monitors your system. i686 Extra kdeplasma-addons-applets-calculator 4.4.0-1 Calculate simple sums i686 Extra kdeplasma-addons-applets-charselect 4.4.0-1 View, select, and copy characters from a font collection i686 Extra kdeplasma-addons-applets-comic 4.4.0-1 View comic strips from the Internet i686 Extra kdeplasma-addons-applets-dict 4.4.0-1 Look up the meaning of words and their translation into different languages i686 Extra kdeplasma-addons-applets-eyes 4.4.0-1 XEyes clone i686 Extra kdeplasma-addons-applets-fifteenpuzzle 4.4.0-1 Put the pieces in order i686 Extra kdeplasma-addons-applets-filewatcher 4.4.0-1 Watch for changes in specified files i686 Extra kdeplasma-addons-applets-frame 4.4.0-1 Display your favorite pictures i686 Extra kdeplasma-addons-applets-fuzzy-clock 4.4.0-1 Time displayed in a less precise format i686  Extra   kdeplasma-addons-applets-incomingmsg   4.4.0-1   Notification of new messages      i686 Extra kdeplasma-addons-applets-kdeobservatory 4.4.0-1 Visualize the KDE ecosystem i686 Extra kdeplasma-addons-applets-kimpanel 4.4.0-1 A gen input method panel for Oriental languages i686 Extra kdeplasma-addons-applets-knowledgebase 4.4.0-1 Opendesktop Knowledgebase i686 Extra kdeplasma-addons-applets-kolourpicker 4.4.0-1 Pick a color from the desktop i686 Extra kdeplasma-addons-applets-konqprofiles 4.4.0-1 List and launch Konqueror profiles i686 Extra kdeplasma-addons-applets-konsoleprofiles 4.4.0-1 List and launch Konsole profiles i686 Extra kdeplasma-addons-applets-lancelot 4.4.0-1 Launcher to start applications i686 Extra kdeplasma-addons-applets-leavenote 4.4.0-1 Leave notes for users while they are away i686 Extra kdeplasma-addons-applets-life 4.4.0-1 Life i686 Extra kdeplasma-addons-applets-luna 4.4.0-1 Display moon phases for your location i686 Extra kdeplasma-addons-applets-magnifique 4.4.0-1 A magnification glass for the Plasma desktop i686 Extra kdeplasma-addons-applets-mediaplayer 4.4.0-1 Widget that can play video and sound i686 Extra kdeplasma-addons-applets-microblog 4.4.0-1 Update and view your microblog status. i686 Extra kdeplasma-addons-applets-news 4.4.0-1 Show news from various sources i686 Extra kdeplasma-addons-applets-notes 4.4.0-1 Desktop sticky notes i686 Extra kdeplasma-addons-applets-nowplaying 4.4.0-1 Displays currently playing audio i686 Extra kdeplasma-addons-applets-opendesktop 4.4.0-1 Communicate using the Social Desktop i686 Extra kdeplasma-addons-applets-opendesktop-activities 4.4.0-1 Stay informed with the Social Desktop i686 Extra kdeplasma-addons-applets-paste 4.4.0-1 Paste text snippets i686 Extra kdeplasma-addons-applets-pastebin 4.4.0-1 Paste text/images to a remote server i686 Extra kdeplasma-addons-applets-plasmaboard 4.4.0-1 A virtual, on-screen keyboard i686 Extra kdeplasma-addons-applets-previewer 4.4.0-1 Quickly preview a variety of files i686 Extra kdeplasma-addons-applets-qalculate 4.4.0-1 A powerful mathematical equation solver i686 Extra kdeplasma-addons-applets-rememberthemilk 4.4.0-1 Remember The Milk Todo list applet i686 Extra kdeplasma-addons-applets-rssnow 4.4.0-1 Show news from various sources i686 Extra kdeplasma-addons-applets-showdashboard 4.4.0-1 Show the Plasma widget dashboard above other windows i686 Extra kdeplasma-addons-applets-showdesktop 4.4.0-1 Show the Plasma desktop i686 Extra kdeplasma-addons-applets-spellcheck 4.4.0-1 Fast spell checking i686 Extra kdeplasma-addons-applets-systemloadviewer 4.4.0-1 Tiny CPU/RAM/Swap monitor i686 Extra kdeplasma-addons-applets-timer 4.4.0-1 Countdown over a specified time period i686 Extra kdeplasma-addons-applets-unitconverter 4.4.0-1 Plasmoid for converting units i686 Extra kdeplasma-addons-applets-weather 4.4.0-1 Displays Weather information i686 Extra kdeplasma-addons-applets-weatherstation 4.4.0-1 Weather reports with an LCD display style i686 Extra kdeplasma-addons-applets-webslice 4.4.0-1 Show a part of a webpage i686 Extra kdeplasma-addons-libs 4.4.0-1 Plasma Addon Library i686 Extra kdeplasma-addons-runners-audioplayercontrol 4.4.0-1 Allows to control MPRIS audio players i686 Extra kdeplasma-addons-runners-browserhistory 4.4.0-1 Searches in Konqueror´s history i686 Extra kdeplasma-addons-runners-contacts 4.4.0-1 Finds entries in your address book i686 Extra kdeplasma-addons-runners-converter 4.4.0-1 Convert values to different units i686 Extra kdeplasma-addons-runners-katesessions 4.4.0-1 Matches Kate Sessions i686 Extra kdeplasma-addons-runners-konquerorsessions 4.4.0-1 Matches Konqueror Sessions i686 Extra kdeplasma-addons-runners-konsolesessions 4.4.0-1 Matches Konsole Sessions i686 Extra kdeplasma-addons-runners-kopete 4.4.0-1 Kopete Contact runner i686 Extra kdeplasma-addons-runners-mediawiki 4.4.0-1 Search on KDE´s TechBase i686 Extra kdeplasma-addons-runners-spellchecker 4.4.0-1 Check the spelling of a word i686 Extra kdeplasma-addons-wallpapers-mandelbrot 4.4.0-1 Mandelbrot i686 Extra kdeplasma-addons-wallpapers-marble 4.4.0-1 Globe i686 Extra kdeplasma-addons-wallpapers-pattern 4.4.0-1 Pattern i686 Extra kdeplasma-addons-wallpapers-virus 4.4.0-1 Virus i686  Extra   kdeplasma-addons-wallpapers-weather   4.4.0-1   Weather      i686 Extra kdeplasma-applets-networkmanagement 1073182-1 KDE4 Network Management and plasmoid i686 Extra kdesdk-cervisia 4.4.0-1 CVS Frontend i686 Extra kdesdk-kapptemplate 4.4.0-1 KDE Template Generator i686 Extra kdesdk-kate 4.4.0-1 Advanced Text Editor i686 Extra kdesdk-kbugbuster 4.4.0-1 KDE Bug Management i686 Extra kdesdk-kcachegrind 4.4.0-1 Visualization of Performance Profiling Data i686 Extra kdesdk-kdeaccounts-plugin 4.4.0-1 KDE Repository Accounts i686 Extra kdesdk-kdepalettes 4.4.0-1 Palettes for the Gimp that match the KDE standard color palette i686 Extra kdesdk-kioslave 4.4.0-1 KDED Subversion Module i686 Extra kdesdk-kmtrace 4.4.0-1 A KDE tool to assist with malloc debugging using glibc´s "mtrace" functionality i686 Extra kdesdk-kompare 4.4.0-1 Diff/Patch Frontend i686 Extra kdesdk-kpartloader 4.4.0-1 A test application for KParts i686 Extra kdesdk-kprofilemethod 4.4.0-1 Macros helping to profile i686 Extra kdesdk-kstartperf 4.4.0-1 Startup time measurement tool for KDE applications i686 Extra kdesdk-kuiviewer 4.4.0-1 Qt Designer UI File Viewer i686 Extra kdesdk-lokalize 4.4.0-1 Computer-Aided Translation System i686 Extra kdesdk-poxml 4.4.0-1 Translates DocBook XML files using gettext po files i686 Extra kdesdk-scripts 4.4.0-1 KDE SDK scripts i686 Extra kdesdk-strigi-analyzer 4.4.0-1 Strigi-Analyzer for KDE SDK i686 Extra kdesdk-umbrello 4.4.0-1 UML Modeller i686 Extra kdetoys-amor 4.4.0-1 On-Screen Creature i686 Extra kdetoys-kteatime 4.4.0-1 Tea Cooker i686 Extra kdetoys-ktux 4.4.0-1 KTux i686 Extra kdetoys-kweather 4.4.0-1 A weather reporting panel applet i686 Extra kdeutils-ark 4.4.0-1 Archiving Tool i686 Extra kdeutils-kcalc 4.4.0-1 Scientific Calculator i686 Extra kdeutils-kcharselect 4.4.0-1 Character Selector i686 Extra kdeutils-kdelirc 4.4.0-1 Configure your remote controls for use with applications i686 Extra kdeutils-kdf 4.4.0-1 View Disk Usage i686 Extra kdeutils-kfloppy 4.4.0-1 Floppy Formatter i686 Extra kdeutils-kgpg 4.4.0-1 A GnuPG frontend i686 Extra kdeutils-ktimer 4.4.0-1 Countdown Launcher i686 Extra kdeutils-kwallet 4.4.0-1 Wallet Management Tool i686 Extra kdeutils-okteta 4.4.0-1 Hex Editor i686 Extra kdeutils-printer-applet 4.4.0-1 System tray icon for managing print jobs i686 Extra kdeutils-superkaramba 4.4.0-1 An engine for cool desktop eyecandy. i686 Extra kdeutils-sweeper 4.4.0-1 System Cleaner i686 Extra kdewebdev-kfilereplace 4.4.0-1 Search & Replace Tool i686 Extra kdewebdev-kimagemapeditor 4.4.0-1 HTML Image Map Editor i686 Extra kdewebdev-klinkstatus 4.4.0-1 Link Checker i686 Extra kdewebdev-kommander 4.4.0-1 Executor for Kommander dialogs i686 Extra kipi-plugins 1.1.0-1 libkipi plugins for digikam and kde apps i686 Extra ktorrent 3.3.4-1 A BitTorrent program for KDE i686 Extra libiodbc 3.52.7-3 Independent Open DataBase Connectivity for Linux i686 Extra libmsn 4.1-1 A reusable, open-source, fully documented library for connecting to Microsoft's MSN i686 Extra libssh 0.4.0-1 Library for accessing ssh client services through C libraries i686 Extra modemmanager 0.3-1 Mobile broadband modem management service i686 Extra mythplugins-mytharchive 0.22-3 MythTV plugin that lets you create DVDs from or archive your recorded shows i686 Extra mythplugins-mythbrowser 0.22-3 Mini web browser for MythTV i686  Extra   mythplugins-mythflix   0.22-3   Netflix access plugin for MythTV      i686 Extra mythplugins-mythgallery 0.22-3 Image gallery plugin for MythTV i686 Extra mythplugins-mythgame 0.22-3 Game emulator module for MythTV i686 Extra mythplugins-mythmovies 0.22-3 Local movie listings via MythTV i686 Extra mythplugins-mythmusic 0.22-3 Music playing plugin for MythTV i686 Extra mythplugins-mythnews 0.22-3 News checking plugin for MythTV i686 Extra mythplugins-mythvideo 0.22-3 Video playback and browsing plugin for MythTV i686 Extra mythplugins-mythweather 0.22-3 Weather checking plugin for MythTV i686 Extra mythplugins-mythweb 0.22-3 Web interface for MythTV's backend i686 Extra mythplugins-mythzoneminder 0.22-3 Allows for viewing of CCTV cameras through zoneminder i686 Extra mythtv 0.22-7 A Homebrew PVR project i686 Extra network-manager-applet 0.7.999-1 GNOME frontends to NetWorkmanager i686 Extra networkmanager 0.7.999-2 Network Management daemon i686 Extra networkmanager-openconnect 0.7.999-1 NetworkManager VPN integration for openconnect i686 Extra networkmanager-openvpn 0.7.999-1 NetworkManager VPN plugin for OpenVPN i686 Extra networkmanager-pptp 0.7.999-1 NetworkManager VPN plugin for pptp i686 Extra networkmanager-vpnc 0.7.999-1 NetworkManager VPN plugin for vpnc i686 Extra partitionmanager 1.0.1-2 A KDE 4 utility that allows you to manage disks, partitions, and file systems. i686 Extra phonon 4.3.80-2 The multimedia API for KDE4 i686 Extra phonon-gstreamer 4.3.80-2 Phonon Gstreamer backend i686 Extra phonon-xine 4.3.80-2 Phonon Xine backend i686 Extra polkit-kde 0.95.1-1 KDE PolicyKit Authentication Agent i686 Extra polkit-qt 0.95.1-1 A library that allows developers to access PolicyKit API with a nice Qt-style API i686 Extra pyqt 4.7.0-2 A set of Python bindings for the Qt toolkit i686 Extra qscintilla 2.4.1-1 A port to Qt4 of Neil Hodgson's Scintilla C++ editor class i686 Extra qt 4.6.1-1 A cross-platform application and UI framework i686 Extra qtcurve-kde4 1.0.2-1 A configurable set of widget styles for KDE and Gtk i686 Extra sip 4.10.0-1 A tool that makes it easy to create Python bindings for C and C++ libraries i686 Extra stellarium 0.10.3-1 A stellarium with great graphics and a nice database of sky-objects i686 Extra virtuoso 6.1.0-1 A scalable cross-platform server that combines SQL/RDF/XML Data Management with Web Application Server and Web Services Platform functionality i686 Extra arora 0.10.2-3 A cross platform web browser built using Qt and WebKit dgriffiths i686 Extra attica 0.1.2-1 A library to access Open Collaboration Service providers i686 Extra digikam 1.1.0-2 Digital photo management application for kde i686 Extra k3b 1.70.0beta1-2 Feature-rich and easy to handle CD burning application i686 Extra k9copy 2.3.4-2 A small utility which allows the copy of DVD under Linux i686 Extra kaffeine 1.0pre3-1 KDE media player i686 Extra kdeaccessibility-colorschemes 4.4.0-1 KDE Accessibility color schemes i686 Extra kdeaccessibility-iconthemes 4.4.0-1 KDE Accessibility icon themes i686 Extra kdeaccessibility-kmag 4.4.0-1 Screen Magnifier i686 Extra kdeaccessibility-kmousetool 4.4.0-1 Clicks the mouse for you, reducing the effects of RSI i686 Extra kdeaccessibility-kmouth 4.4.0-1 Speech Synthesizer Frontend i686 Extra kdeadmin-kcron 4.4.0-1 Configure and schedule tasks i686 Extra kdeadmin-ksystemlog 4.4.0-1 System log viewer tool i686 Extra kdeadmin-kuser 4.4.0-1 User Manager i686 Extra kdeadmin-system-config-printer-kde 4.4.0-1 Configure local and remote Printers i686 Extra rxvt-unicode 9.07-1 An unicode enabled rxvt-clone terminal emulator (urxvt) x86_64x86_64   Core   kernel26   2.6.32.8-1   The Linux Kernel and modules      x86_64 Core kernel26-firmware 2.6.32.8-1 The included firmware files of the Linux Kernel x86_64 Core kernel26-headers 2.6.32.8-1 Header files and scripts for building modules for kernel26 x86_64 Core wpa_supplicant 0.6.10-1 A utility providing key negotiation for WPA wireless networks x86_64   Community   gimpshop   2.2.11-7   A modified Gimp that features menu layouts and naming conventions similar to those in Photoshop.      x86_64 Community pwsafe 0.2.0-5 A commandline program for managing encrypted password databases x86_64 Community sgmltools-lite 3.0.3-2 SGML processing tools (sucessor to the obsolete SGMLtools) x86_64 Community uucp 1.07-2 Taylor UUCP is a free implementation of UUCP and is the standard UUCP used on the GNU system x86_64 Community blueman 1.21-3 GTK+ bluetooth manager x86_64 Community bsdiff 4.3-5 bsdiff and bspatch are tools for building and applying patches to binary files. x86_64 Community fgetty 0.6-5 A mingetty stripped of the printfs x86_64 Community freetds 0.82-4 Library for accessing Sybase and MS SQL Server databases x86_64 Community librsync 0.9.7-5 A free software library that implements the rsync remote-delta algorithm (rdiff) foutrelis x86_64 Community lomoco 1.0-6 Logitech USB mouse configuration program x86_64 Community bwm-ng 0.6-3 A small and simple console-based live bandwidth monitor x86_64 Community perl-gtk2-mozembed 0.08-2 Interface to the Mozilla embedding widget x86_64 Community qtcreator 1.3.1-1 Lightweight, cross-platform integrated development environment x86_64   Extra   kbluetooth   0.4.1-1   A collection of Bluetooth utilities and modules for KDE based on BlueZ      x86_64 Extra soprano 2.3.73-2 A library which provides a highly usable object-oriented C++/Qt4 framework for RDF data x86_64 Extra curl 7.20.0-1 An URL retrival utility and library x86_64 Extra wpa_supplicant_gui 0.6.10-1 A qt frontend to wpa_supplicant x86_64 Extra mercurial 1.4.3-2 A scalable distributed SCM tool x86_64 Extra jhead 2.90-1 EXIF JPEG info parser and thumbnail remover x86_64 Extra kdelibs 4.4.0-3 KDE Core Libraries x86_64 Extra akonadi 1.3.1-1 PIM layer, which provides an asynchronous API to access all kind of PIM data x86_64 Extra libv4l 0.6.4-1 Userspace library for Video 4 Linux (1 and 2) x86_64 Extra kdeartwork-colorschemes 4.4.0-1 KDE color schemes x86_64 Extra kdeartwork-desktopthemes 4.4.0-1 KDE desktop themes x86_64 Extra kdeartwork-emoticons 4.4.0-1 KDE emoticons x86_64 Extra kdeartwork-iconthemes 4.4.0-1 KDE icon themes x86_64 Extra kdeartwork-kscreensaver 4.4.0-1 KDE screensaver x86_64 Extra kdeartwork-sounds 4.4.0-1 KDE sounds x86_64 Extra kdeartwork-styles 4.4.0-1 KDE styles x86_64 Extra kdeartwork-wallpapers 4.4.0-1 KDE wallpapers x86_64 Extra kdeartwork-weatherwallpapers 4.4.0-1 KDE weather wallpapers x86_64 Extra kdebase-dolphin 4.4.0-3 File Manager x86_64 Extra kdebase-kappfinder 4.4.0-3 Menu Updating Tool x86_64 Extra kdebase-kdepasswd 4.4.0-3 Change Password x86_64 Extra kdebase-kdialog 4.4.0-3 a utility for displaying dialog boxes from shell scripts x86_64 Extra kdebase-kfind 4.4.0-3 Find Files/Folders x86_64 Extra kdebase-kinfocenter 4.4.0-3 Info Center x86_64 Extra kdebase-konqueror 4.4.0-3 KDE File Manager & Web Browser x86_64 Extra kdebase-konsole 4.4.0-3 Terminal x86_64 Extra kdebase-kwrite 4.4.0-3 Text Editor x86_64 Extra kdebase-lib 4.4.0-3 KDE libraries for the basic desktop applications x86_64 Extra kdebase-plasma 4.4.0-3 Display the contents of folders (User´s home folder as default) x86_64 Extra kdebase-runtime 4.4.0-3 KDE Base Runtime Environment x86_64 Extra kdebase-workspace 4.4.0-3 KDE Base Workspace x86_64 Extra kdebindings-csharp 4.4.0-2 KDE bindings for mono x86_64 Extra kdebindings-python 4.4.0-2 KDE bindings for python x86_64 Extra kdebindings-ruby 4.4.0-2 KDE bindings for ruby x86_64 Extra kdebindings-smoke 4.4.0-2 Language independent library for Qt and KDE bindings x86_64 Extra kdeedu-blinken 4.4.0-2 A memory enhancement game x86_64 Extra kdeedu-cantor 4.4.0-2 KDE Frontend to Mathematical Software x86_64 Extra kdeedu-data 4.4.0-2 Data for KDE Educational Software x86_64 Extra kdeedu-kalgebra 4.4.0-2 Math Expression Solver and Plotter x86_64 Extra kdeedu-kalzium 4.4.0-2 KDE Periodic Table of Elements x86_64 Extra kdeedu-kanagram 4.4.0-2 KDE Letter Order Game x86_64 Extra kdeedu-kbruch 4.4.0-2 Practice exercises with fractions x86_64 Extra kdeedu-kgeography 4.4.0-2 A Geography Learning Program x86_64 Extra kdeedu-khangman 4.4.0-2 KDE Hangman Game x86_64 Extra kdeedu-kig 4.4.0-2 Explore Geometric Constructions x86_64 Extra kdeedu-kiten 4.4.0-2 Japanese Reference and Study Tool x86_64 Extra kdeedu-klettres 4.4.0-2 a KDE program to learn the alphabet x86_64 Extra kdeedu-kmplot 4.4.0-2 Function Plotter x86_64 Extra kdeedu-kstars 4.4.0-2 Desktop Planetarium x86_64 Extra kdeedu-ktouch 4.4.0-2 Touch Typing Tutor x86_64 Extra kdeedu-kturtle 4.4.0-2 Educational Programming Environment x86_64 Extra kdeedu-kwordquiz 4.4.0-2 A flashcard and vocabulary learning program x86_64 Extra kdeedu-libkdeedu 4.4.0-2 Support library for KDE Educational Software x86_64 Extra kdeedu-marble 4.4.0-2 Desktop Globe x86_64 Extra kdeedu-parley 4.4.0-2 Vocabulary Trainer x86_64 Extra kdeedu-rocs 4.4.0-2 Graph Theory Tool for Professors and Students. x86_64 Extra kdeedu-step 4.4.0-2 Simulate physics experiments x86_64 Extra kdegames-bomber 4.4.0-1 Arcade Bombing Game x86_64 Extra kdegames-bovo 4.4.0-1 Five-in-a-row Board Game x86_64 Extra kdegames-granatier 4.4.0-1 Granatier x86_64 Extra kdegames-kapman 4.4.0-1 Eat pills escaping ghosts x86_64 Extra kdegames-katomic 4.4.0-1 Sokoban-like Logic Game x86_64 Extra kdegames-kbattleship 4.4.0-1 Battleship Game x86_64 Extra kdegames-kblackbox 4.4.0-1 Blackbox Logic Game x86_64 Extra kdegames-kblocks 4.4.0-1 Falling Blocks Game x86_64 Extra kdegames-kbounce 4.4.0-1 Ball Bouncing Game x86_64 Extra kdegames-kbreakout 4.4.0-1 Breakout-like Game x86_64 Extra kdegames-kdiamond 4.4.0-1 Three-in-a-row game x86_64 Extra kdegames-kfourinline 4.4.0-1 Four-in-a-row Board Game x86_64 Extra kdegames-kgoldrunner 4.4.0-1 A game of action and puzzle-solving x86_64 Extra kdegames-kigo 4.4.0-1 Go Board Game x86_64 Extra kdegames-killbots 4.4.0-1 Killbots x86_64 Extra kdegames-kiriki 4.4.0-1 Yahtzee-like Dice Game x86_64 Extra kdegames-kjumpingcube 4.4.0-1 Territory Capture Game x86_64 Extra kdegames-klines 4.4.0-1 Tactical Game x86_64 Extra kdegames-kmahjongg 4.4.0-1 Mahjongg Solitaire x86_64 Extra kdegames-kmines 4.4.0-1 Minesweeper-like Game x86_64 Extra kdegames-knetwalk 4.4.0-1 Network Construction Game x86_64 Extra kdegames-kolf 4.4.0-1 Miniature Golf x86_64 Extra kdegames-kollision 4.4.0-1 A simple ball dodging game x86_64 Extra kdegames-konquest 4.4.0-1 Galactic Strategy Game x86_64 Extra kdegames-kpat 4.4.0-1 Patience Card Game x86_64 Extra kdegames-kreversi 4.4.0-1 Reversi Board Game x86_64 Extra kdegames-ksame 4.4.0-1 Board Game x86_64 Extra kdegames-kshisen 4.4.0-1 Shisen-Sho Mahjongg-like Tile Game x86_64 Extra kdegames-ksirk 4.4.0-1 World Domination Strategy Game x86_64 Extra kdegames-kspaceduel 4.4.0-1 Space Arcade Game x86_64 Extra kdegames-ksquares 4.4.0-1 Connect the dots to create squares x86_64 Extra kdegames-ksudoku 4.4.0-1 KSudoku, Sudoku game & more for KDE x86_64 Extra kdegames-ktron 4.4.0-1 Tron-like Game x86_64 Extra kdegames-ktuberling 4.4.0-1 Picture Game for Children x86_64 Extra kdegames-kubrick 4.4.0-1 A 3-D game based on Rubik´s Cube O 2x86_64 Extra kdegames-libkdegames 4.4.0-1 KDE game library x86_64 Extra kdegames-libkmahjongg 4.4.0-1 Library used for loading and rendering of Mahjongg tilesets. x86_64 Extra kdegames-lskat 4.4.0-1 Card Game x86_64 Extra kdegames-palapeli 4.4.0-1 Jigsaw puzzle game x86_64 Extra kdegraphics-gwenview 4.4.0-1 A simple image viewer x86_64 Extra kdegraphics-kamera 4.4.0-1 Configure Kamera x86_64 Extra kdegraphics-kcolorchooser 4.4.0-1 Color Chooser x86_64 Extra kdegraphics-kgamma 4.4.0-1 A monitor calibration tool x86_64 Extra kdegraphics-kolourpaint 4.4.0-1 Paint Program x86_64 Extra kdegraphics-kruler 4.4.0-1 Screen Ruler x86_64 Extra kdegraphics-ksnapshot 4.4.0-1 Screen Capture Program x86_64 Extra kdegraphics-libs 4.4.0-1 Support library for KDE Graphics Software x86_64 Extra kdegraphics-okular 4.4.0-1 Document Viewer x86_64 Extra kdemultimedia-dragonplayer 4.4.0-1 Video Player x86_64 Extra kdemultimedia-juk 4.4.0-1 Music Player x86_64 Extra kdemultimedia-kioslave 4.4.0-1 Audio CD Browser x86_64 Extra kdemultimedia-kmix 4.4.0-1 Sound Mixer x86_64 Extra kdemultimedia-kscd 4.4.0-1 CD Player x86_64 Extra kdemultimedia-mplayerthumbs 4.4.0-1 Video Files (MPlayerThumbs) x86_64 Extra kdenetwork-filesharing 4.4.0-1 Konqueror properties dialog plugin to share a directory with the local network x86_64 Extra kdenetwork-kdnssd 4.4.0-1 Network Services x86_64 Extra kdenetwork-kget 4.4.0-1 Download Manager x86_64 Extra kdenetwork-kopete 4.4.0-1 Instant Messenger x86_64 Extra kdenetwork-kppp 4.4.0-1 Internet Dial-Up Tool x86_64 Extra kdenetwork-krdc 4.4.0-1 Remote Desktop Client x86_64 Extra kdenetwork-krfb 4.4.0-1 Desktop Sharing x86_64 Extra kdepim-akonadiconsole 4.4.0-1 Akonadi Management and Debugging Console x86_64 Extra kdepim-akregator 4.4.0-1 A Feed Reader for KDE x86_64 Extra kdepim-blogilo 4.4.0-1 A KDE Blogging Client x86_64 Extra kdepim-console 4.4.0-1 Command line tool for accessing calendar files x86_64 Extra kdepim-kaddressbook 4.4.0-1 Contact Manager x86_64 Extra kdepim-kalarm 4.4.0-1 Personal Alarm Scheduler x86_64 Extra kdepim-kjots 4.4.0-1 Note Taker x86_64 Extra kdepim-kleopatra 4.4.0-1 Certificate Manager and Unified Crypto GUI x86_64 Extra kdepim-kmail 4.4.0-1 Mail Client x86_64 Extra kdepim-knode 4.4.0-1 News Reader x86_64 Extra kdepim-knotes 4.4.0-1 Popup Notes x86_64 Extra kdepim-kontact 4.4.0-1 Personal Information Manager x86_64 Extra kdepim-korganizer 4.4.0-1 Calendar and Scheduling Program x86_64 Extra kdepim-kresources 4.4.0-1 KDE PIM resources x86_64 Extra kdepim-ktimetracker 4.4.0-1 Personal Time Tracker x86_64 Extra kdepim-libkdepim 4.4.0-1 Library for KDE PIM x86_64 Extra kdepim-runtime 4.4.0-1 KDE PIM Runtime Environment x86_64 Extra kdepim-wizards 4.4.0-1 KDE Groupware Wizard x86_64 Extra kdepimlibs 4.4.0-1 KDE PIM Libraries x86_64 Extra kdeplasma-addons-applets-bball 4.4.0-1 A bouncy ball for plasma x86_64 Extra kdeplasma-addons-applets-binary-clock 4.4.0-1 Time displayed in binary format x86_64 Extra kdeplasma-addons-applets-blackboard 4.4.0-1 Black Board x86_64 Extra kdeplasma-addons-applets-bubblemon 4.4.0-1 A pretty bubble that monitors your system. x86_64 Extra kdeplasma-addons-applets-calculator 4.4.0-1 Calculate simple sums x86_64 Extra kdeplasma-addons-applets-charselect 4.4.0-1 View, select, and copy characters from a font collection x86_64 Extra kdeplasma-addons-applets-comic 4.4.0-1 View comic strips from the Internet x86_64 Extra kdeplasma-addons-applets-dict 4.4.0-1 Look up the meaning of words and their translation into different languages x86_64 Extra kdeplasma-addons-applets-eyes 4.4.0-1 XEyes clone x86_64 Extra kdeplasma-addons-applets-fifteenpuzzle 4.4.0-1 Put the pieces in order x86_64 Extra kdeplasma-addons-applets-filewatcher 4.4.0-1 Watch for changes in specified files x86_64 Extra kdeplasma-addons-applets-frame 4.4.0-1 Display your favorite pictures x86_64 Extra kdeplasma-addons-applets-fuzzy-clock 4.4.0-1 Time displayed in a less precise format x86_64 Extra kdeplasma-addons-applets-incomingmsg 4.4.0-1 Notification of new messages x86_64 Extra kdeplasma-addons-applets-kdeobservatory 4.4.0-1 Visualize the KDE ecosystem x86_64 Extra kdeplasma-addons-applets-kimpanel 4.4.0-1 A gen input method panel for Oriental languages x86_64 Extra kdeplasma-addons-applets-knowledgebase 4.4.0-1 Opendesktop Knowledgebase x86_64 Extra kdeplasma-addons-applets-kolourpicker 4.4.0-1 Pick a color from the desktop x86_64 Extra kdeplasma-addons-applets-konqprofiles 4.4.0-1 List and launch Konqueror profiles x86_64 Extra kdeplasma-addons-applets-konsoleprofiles 4.4.0-1 List and launch Konsole profiles x86_64 Extra kdeplasma-addons-applets-lancelot 4.4.0-1 Launcher to start applications x86_64 Extra kdeplasma-addons-applets-leavenote 4.4.0-1 Leave notes for users while they are away x86_64 Extra kdeplasma-addons-applets-life 4.4.0-1 Life x86_64 Extra kdeplasma-addons-applets-luna 4.4.0-1 Display moon phases for your location x86_64 Extra kdeplasma-addons-applets-magnifique 4.4.0-1 A magnification glass for the Plasma desktop x86_64 Extra kdeplasma-addons-applets-mediaplayer 4.4.0-1 Widget that can play video and sound x86_64 Extra kdeplasma-addons-applets-microblog 4.4.0-1 Update and view your microblog status. x86_64 Extra kdeplasma-addons-applets-news 4.4.0-1 Show news from various sources x86_64 Extra kdeplasma-addons-applets-notes 4.4.0-1 Desktop sticky notes x86_64 Extra kdeplasma-addons-applets-nowplaying 4.4.0-1 Displays currently playing audio x86_64 Extra kdeplasma-addons-applets-opendesktop 4.4.0-1 Communicate using the Social Desktop x86_64 Extra kdeplasma-addons-applets-opendesktop-activities 4.4.0-1 Stay informed with the Social Desktop x86_64 Extra kdeplasma-addons-applets-paste 4.4.0-1 Paste text snippets x86_64 Extra kdeplasma-addons-applets-pastebin 4.4.0-1 Paste text/images to a remote server x86_64 Extra kdeplasma-addons-applets-plasmaboard 4.4.0-1 A virtual, on-screen keyboard x86_64 Extra kdeplasma-addons-applets-previewer 4.4.0-1 Quickly preview a variety of files x86_64 Extra kdeplasma-addons-applets-qalculate 4.4.0-1 A powerful mathematical equation solver x86_64 Extra kdeplasma-addons-applets-rememberthemilk 4.4.0-1 Remember The Milk Todo list applet x86_64 Extra kdeplasma-addons-applets-rssnow 4.4.0-1 Show news from various sources x86_64 Extra kdeplasma-addons-applets-showdashboard 4.4.0-1 Show the Plasma widget dashboard above other windows x86_64 Extra kdeplasma-addons-applets-showdesktop 4.4.0-1 Show the Plasma desktop x86_64 Extra kdeplasma-addons-applets-spellcheck 4.4.0-1 Fast spell checking x86_64 Extra kdeplasma-addons-applets-systemloadviewer 4.4.0-1 Tiny CPU/RAM/Swap monitor x86_64 Extra kdeplasma-addons-applets-timer 4.4.0-1 Countdown over a specified time period x86_64 Extra kdeplasma-addons-applets-unitconverter 4.4.0-1 Plasmoid for converting units x86_64 Extra kdeplasma-addons-applets-weather 4.4.0-1 Displays Weather information x86_64 Extra kdeplasma-addons-applets-weatherstation 4.4.0-1 Weather reports with an LCD display style x86_64 Extra kdeplasma-addons-applets-webslice 4.4.0-1 Show a part of a webpage x86_64 Extra kdeplasma-addons-libs 4.4.0-1 Plasma Addon Library x86_64 Extra kdeplasma-addons-runners-audioplayercontrol 4.4.0-1 Allows to control MPRIS audio players (it is able to search through Amarok´s collection, too) x86_64 Extra kdeplasma-addons-runners-browserhistory 4.4.0-1 Searches in Konqueror´s history x86_64 Extra kdeplasma-addons-runners-contacts 4.4.0-1 Finds entries in your address book x86_64 Extra kdeplasma-addons-runners-converter 4.4.0-1 Convert values to different units x86_64 Extra kdeplasma-addons-runners-katesessions 4.4.0-1 Matches Kate Sessions x86_64 Extra kdeplasma-addons-runners-konquerorsessions 4.4.0-1 Matches Konqueror Sessions x86_64 Extra kdeplasma-addons-runners-konsolesessions 4.4.0-1 Matches Konsole Sessions x86_64 Extra kdeplasma-addons-runners-kopete 4.4.0-1 Kopete Contact runner x86_64 Extra kdeplasma-addons-runners-mediawiki 4.4.0-1 Search on KDE´s TechBase O 86_64 Extra kdeplasma-addons-runners-spellchecker 4.4.0-1 Check the spelling of a word x86_64 Extra kdeplasma-addons-wallpapers-mandelbrot 4.4.0-1 Mandelbrot x86_64 Extra kdeplasma-addons-wallpapers-marble 4.4.0-1 Globe x86_64 Extra kdeplasma-addons-wallpapers-pattern 4.4.0-1 Pattern x86_64 Extra kdeplasma-addons-wallpapers-virus 4.4.0-1 Virus x86_64 Extra kdeplasma-addons-wallpapers-weather 4.4.0-1 Weather x86_64 Extra kdeplasma-applets-networkmanagement 1073182-1 KDE4 Network Management and plasmoid x86_64 Extra kdesdk-cervisia 4.4.0-1 CVS Frontend x86_64 Extra kdesdk-kapptemplate 4.4.0-1 KDE Template Generator x86_64 Extra kdesdk-kate 4.4.0-1 Advanced Text Editor x86_64 Extra kdesdk-kbugbuster 4.4.0-1 KDE Bug Management x86_64 Extra kdesdk-kcachegrind 4.4.0-1 Visualization of Performance Profiling Data x86_64 Extra kdesdk-kdeaccounts-plugin 4.4.0-1 KDE Repository Accounts x86_64 Extra kdesdk-kdepalettes 4.4.0-1 Palettes for the Gimp that match the KDE standard color palette x86_64 Extra kdesdk-kioslave 4.4.0-1 KDED Subversion Module x86_64 Extra kdesdk-kmtrace 4.4.0-1 A KDE tool to assist with malloc debugging using glibc´s "mtrace" functionality x86_64 Extra kdesdk-kompare 4.4.0-1 Diff/Patch Frontend x86_64 Extra kdesdk-kpartloader 4.4.0-1 A test application for KParts x86_64 Extra kdesdk-kprofilemethod 4.4.0-1 Macros helping to profile x86_64 Extra kdesdk-kstartperf 4.4.0-1 Startup time measurement tool for KDE applications x86_64 Extra kdesdk-kuiviewer 4.4.0-1 Qt Designer UI File Viewer x86_64 Extra kdesdk-lokalize 4.4.0-1 Computer-Aided Translation System x86_64 Extra kdesdk-poxml 4.4.0-1 Translates DocBook XML files using gettext po files x86_64 Extra kdesdk-scripts 4.4.0-1 KDE SDK scripts x86_64 Extra kdesdk-strigi-analyzer 4.4.0-1 Strigi-Analyzer for KDE SDK x86_64 Extra kdesdk-umbrello 4.4.0-1 UML Modeller x86_64 Extra kdetoys-amor 4.4.0-1 On-Screen Creature x86_64 Extra kdetoys-kteatime 4.4.0-1 Tea Cooker x86_64 Extra kdetoys-ktux 4.4.0-1 KTux x86_64 Extra kdetoys-kweather 4.4.0-1 A weather reporting panel applet x86_64 Extra kdeutils-ark 4.4.0-1 Archiving Tool x86_64 Extra kdeutils-kcalc 4.4.0-1 Scientific Calculator x86_64 Extra kdeutils-kcharselect 4.4.0-1 Character Selector x86_64 Extra kdeutils-kdelirc 4.4.0-1 Configure your remote controls for use with applications x86_64 Extra kdeutils-kdf 4.4.0-1 View Disk Usage x86_64 Extra kdeutils-kfloppy 4.4.0-1 Floppy Formatter x86_64 Extra kdeutils-kgpg 4.4.0-1 A GnuPG frontend x86_64 Extra kdeutils-ktimer 4.4.0-1 Countdown Launcher x86_64 Extra kdeutils-kwallet 4.4.0-1 Wallet Management Tool x86_64 Extra kdeutils-okteta 4.4.0-1 Hex Editor x86_64 Extra kdeutils-printer-applet 4.4.0-1 System tray icon for managing print jobs x86_64 Extra kdeutils-superkaramba 4.4.0-1 An engine for cool desktop eyecandy. x86_64 Extra kdeutils-sweeper 4.4.0-1 System Cleaner x86_64 Extra kdewebdev-kfilereplace 4.4.0-1 Search & Replace Tool x86_64 Extra kdewebdev-kimagemapeditor 4.4.0-1 HTML Image Map Editor x86_64 Extra kdewebdev-klinkstatus 4.4.0-1 Link Checker x86_64 Extra kdewebdev-kommander 4.4.0-1 Executor for Kommander dialogs x86_64 Extra kipi-plugins 1.1.0-1 libkipi plugins for digikam and kde apps tpowa x86_64 Extra ktorrent 3.3.4-1 A BitTorrent program for KDE ronald x86_64 Extra libiodbc 3.52.7-3 Independent Open DataBase Connectivity for Linux x86_64 Extra libmsn 4.1-1 A reusable, open-source, fully documented library for connecting to Microsoft's MSN x86_64 Extra libssh 0.4.0-1 Library for accessing ssh client services through C libraries x86_64 Extra modemmanager 0.3-1 Mobile broadband modem management service x86_64 Extra mythplugins-mytharchive 0.22-3 MythTV plugin that lets you create DVDs from or archive your recorded shows x86_64 Extra mythplugins-mythbrowser 0.22-3 Mini web browser for MythTV x86_64 Extra mythplugins-mythflix 0.22-3 Netflix access plugin for MythTV x86_64 Extra mythplugins-mythgallery 0.22-3 Image gallery plugin for MythTV x86_64 Extra mythplugins-mythgame 0.22-3 Game emulator module for MythTV x86_64 Extra mythplugins-mythmovies 0.22-3 Local movie listings via MythTV x86_64 Extra mythplugins-mythmusic 0.22-3 Music playing plugin for MythTV x86_64 Extra mythplugins-mythnews 0.22-3 News checking plugin for MythTV x86_64 Extra mythplugins-mythvideo 0.22-3 Video playback and browsing plugin for MythTV x86_64 Extra mythplugins-mythweather 0.22-3 Weather checking plugin for MythTV x86_64 Extra mythplugins-mythweb 0.22-3 Web interface for MythTV's backend x86_64 Extra mythplugins-mythzoneminder 0.22-3 Allows for viewing of CCTV cameras through zoneminder x86_64 Extra mythtv 0.22-7 A Homebrew PVR project x86_64 Extra network-manager-applet 0.7.999-1 GNOME frontends to NetWorkmanager x86_64 Extra networkmanager 0.7.999-2 Network Management daemon x86_64 Extra networkmanager-openconnect 0.7.999-1 NetworkManager VPN integration for openconnect ibiru x86_64 Extra networkmanager-openvpn 0.7.999-1 NetworkManager VPN plugin for OpenVPN ibiru x86_64 Extra networkmanager-pptp 0.7.999-1 NetworkManager VPN plugin for pptp ibiru x86_64 Extra networkmanager-vpnc 0.7.999-1 NetworkManager VPN plugin for vpnc ibiru x86_64 Extra partitionmanager 1.0.1-2 A KDE 4 utility that allows you to manage disks, partitions, and file systems. tpowa x86_64 Extra phonon 4.3.80-2 The multimedia API for KDE4 x86_64 Extra phonon-gstreamer 4.3.80-2 Phonon Gstreamer backend x86_64 Extra phonon-xine 4.3.80-2 Phonon Xine backend x86_64 Extra polkit-kde 0.95.1-1 KDE PolicyKit Authentication Agent x86_64 Extra polkit-qt 0.95.1-1 A library that allows developers to access PolicyKit API with a nice Qt-style API x86_64 Extra pyqt 4.7.0-2 A set of Python bindings for the Qt toolkit x86_64 Extra qscintilla 2.4.1-1 A port to Qt4 of Neil Hodgson's Scintilla C++ editor class x86_64 Extra qt 4.6.1-1 A cross-platform application and UI framework x86_64 Extra qtcurve-kde4 1.0.2-1 A configurable set of widget styles for KDE and Gtk x86_64 Extra sip 4.10.0-1 A tool that makes it easy to create Python bindings for C and C++ libraries x86_64 Extra stellarium 0.10.3-1 A stellarium with great graphics and a nice database of sky-objects ronald x86_64 Extra virtuoso 6.1.0-1 A scalable cross-platform server that combines SQL/RDF/XML Data Management with Web Application Server and Web Services Platform functionality x86_64 Extra arora 0.10.2-3 A cross platform web browser built using Qt and WebKit dgriffiths x86_64 Extra attica 0.1.2-1 A library to access Open Collaboration Service providers x86_64 Extra digikam 1.1.0-2 Digital photo management application for kde tpowa x86_64 Extra k3b 1.70.0beta1-2 Feature-rich and easy to handle CD burning application tpowa x86_64 Extra k9copy 2.3.4-2 A small utility which allows the copy of DVD under Linux x86_64 Extra kaffeine 1.0pre3-1 KDE media player tpowa x86_64 Extra kdeaccessibility-colorschemes 4.4.0-1 KDE Accessibility color schemes x86_64 Extra kdeaccessibility-iconthemes 4.4.0-1 KDE Accessibility icon themes x86_64 Extra kdeaccessibility-kmag 4.4.0-1 Screen Magnifier x86_64 Extra kdeaccessibility-kmousetool 4.4.0-1 Clicks the mouse for you, reducing the effects of RSI x86_64 Extra kdeaccessibility-kmouth 4.4.0-1 Speech Synthesizer Frontend x86_64 Extra kdeadmin-kcron 4.4.0-1 Configure and schedule tasks x86_64 Extra kdeadmin-ksystemlog 4.4.0-1 System log viewer tool x86_64 Extra kdeadmin-kuser 4.4.0-1 User Manager x86_64 Extra kdeadmin-system-config-printer-kde 4.4.0-1 Configure local and remote Printers x86_64 Extra rxvt-unicode 9.07-1 An unicode enabled rxvt-clone terminal emulator (urxvt) AURsshmenu 3.18-4 qbittorrent-nogui 2.1.4-1 libtorrent-rasterbar-dev 0.15-1 dockbarx-shinybar-theme 1.3-1dockbarx-bzr 138-2 indicator-applet 0.3.2-2dpkg 1.14.28-2 rekonq-git 20100209-1indicator-me 0.2.3-1ido 0.1.0-1If you made it this far then you can understand the reason I do not go in depth with release notes and such. Getting this many updates in a day is not common but it does tend to happen with a "rolling" distro.I am glad I do not KDE though. Man what a bunch of packages.
#25 OFFLINE   securitybreach
  • 23,098 posts
Posted 10 February 2010 - 10:02 PM
Updates for Wed, 10 Feb 2010: Anyany Community perl--arch 2010.02.10.4-1 Xyne's Arch-specific Perl modules. any Community perl--common 2010.02.09.2-1 Xyne's common Perl modules. any Community pygments 1.2.2-2 Python syntax highlighter any Community python-sphinx 0.6.4-2 Python documentation generator any Community perl-log-log4perl 1.27-1 Log4j implementation in Perl any Extra archlinux-artwork 1.6-1 Official logos, icons, CD labels and other artwork for Arch Linux i686i686 Community libasyncns 0.8-1 A C library for Linux/Unix for executing name service queries asynchronously i686 Community kphotoalbum 4.1.1-3 KDE Photo Album, picture collection manager i686 Community guake 0.4.1-1 Guake is a drop-down terminal for Gnome Desktop Environment i686 Community python-jinja 2.3-1 A simple pythonic template language written in Python i686 Community wkhtmltopdf 0.9.1-3 Simple shell utility to convert html to pdf using the webkit rendering engine, and qt i686 Extra mythplugins-mytharchive 0.22-4 MythTV plugin that lets you create DVDs from or archive your recorded shows i686 Extra mythplugins-mythbrowser 0.22-4 Mini web browser for MythTV i686 Extra mythplugins-mythflix 0.22-4 Netflix access plugin for MythTV i686 Extra mythplugins-mythgallery 0.22-4 Image gallery plugin for MythTV i686 Extra mythplugins-mythgame 0.22-4 Game emulator module for MythTV i686 Extra mythplugins-mythmovies 0.22-4 Local movie listings via MythTV i686 Extra mythplugins-mythmusic 0.22-4 Music playing plugin for MythTV i686 Extra mythplugins-mythnews 0.22-4 News checking plugin for MythTV i686 Extra mythplugins-mythvideo 0.22-4 Video playback and browsing plugin for MythTV i686 Extra mythplugins-mythweather 0.22-4 Weather checking plugin for MythTV i686 Extra mythplugins-mythweb 0.22-4 Web interface for MythTV's backend i686 Extra mythplugins-mythzoneminder 0.22-4 Allows for viewing of CCTV cameras through zoneminder i686 Extra postgresql 8.4.2-2 A sophisticated object-relational DBMS i686 Extra mythtv 0.22-8 A Homebrew PVR project i686 Extra polkit-kde 0.95.1-2 KDE PolicyKit Authentication Agent i686 Extra unrar 3.9.8-1 The RAR uncompression program i686 Extra usbview 1.1-2 USB Viewer i686 Extra whois 5.0.1-1 The whois client by Marco d'Itri i686 Extra obex-data-server 0.4.5-1 A D-Bus service providing high-level OBEX client and server side functionality i686 Extra source-highlight 3.1.3-1 Convert source code to syntax highlighted document i686 Extra srm 1.2.10-1 A secure replacement for rm(1) that overwrites data before unlinking i686 Extra mpck 0.19-1 Reads MP3 files and tries to determine if they are correct i686 Extra mtools 4.0.12-1 A collection of utilities to access MS-DOS disks i686 Extra live-media 2010.02.10-1 A set of C++ libraries for multimedia streaming i686 Extra kdepim-akonadiconsole 4.4.0-2 Akonadi Management and Debugging Console i686 Extra kdepim-akregator 4.4.0-2 A Feed Reader for KDE i686 Extra kdepim-blogilo 4.4.0-2 A KDE Blogging Client i686 Extra kdepim-console 4.4.0-2 Command line tool for accessing calendar files i686 Extra kdepim-kaddressbook 4.4.0-2 Contact Manager i686 Extra kdepim-kalarm 4.4.0-2 Personal Alarm Scheduler i686 Extra kdepim-kjots 4.4.0-2 Note Taker i686 Extra kdepim-kleopatra 4.4.0-2 Certificate Manager and Unified Crypto GUI i686 Extra kdepim-kmail 4.4.0-2 Mail Client i686 Extra kdepim-knode 4.4.0-2 News Reader i686 Extra kdepim-knotes 4.4.0-2 Popup Notes i686 Extra kdepim-kontact 4.4.0-2 Personal Information Manager i686 Extra kdepim-korganizer 4.4.0-2 Calendar and Scheduling Program i686 Extra kdepim-kresources 4.4.0-2 KDE PIM resources i686 Extra kdepim-ktimetracker 4.4.0-2 Personal Time Tracker i686 Extra kdepim-libkdepim 4.4.0-2 Library for KDE PIM i686 Extra kdepim-wizards 4.4.0-2 KDE Groupware Wizard i686 Extra pyqt3 3.18.1-4 A set of Python bindings for the Qt3 toolkit i686 Extra k9copy 2.3.5-1 A small utility which allows the copy of DVD under Linux i686 Extra lcab 1.0b12-2 A program to make Microsoft cabinet files i686 Extra libebml 0.7.8-2 Extensible Binary Meta Language library i686 Extra help2man 1.37.1-1 Conversion tool to create man files i686 Extra enca 1.13-1 Charset analyser and converter i686 Extra gif2png 2.5.2-1 A GIF to PNG image format converter i686 Extra ocrad 0.19-1 An Optical Character Recognition program i686 Extra python-qscintilla 2.4.2-1 Python bindings for QScintilla2 i686 Extra proftpd 1.3.2c-2 A high-performance, scalable FTP server dgriffiths i686 Extra qscintilla 2.4.2-1 A port to Qt4 of Neil Hodgson's Scintilla C++ editor class x86_64x86_64 Community kphotoalbum 4.1.1-3 KDE Photo Album, picture collection manager x86_64 Community libasyncns 0.8-1 A C library for Linux/Unix for executing name service queries asynchronously x86_64 Community guake 0.4.1-1 Guake is a drop-down terminal for Gnome Desktop Environment x86_64 Community python-jinja 2.3-1 A simple pythonic template language written in Python x86_64 Community wkhtmltopdf 0.9.1-3 Simple shell utility to convert html to pdf using the webkit rendering engine, and qt x86_64 Extra mythplugins-mytharchive 0.22-4 MythTV plugin that lets you create DVDs from or archive your recorded shows x86_64 Extra mythplugins-mythbrowser 0.22-4 Mini web browser for MythTV x86_64 Extra mythplugins-mythflix 0.22-4 Netflix access plugin for MythTV x86_64 Extra mythplugins-mythgallery 0.22-4 Image gallery plugin for MythTV x86_64 Extra mythplugins-mythgame 0.22-4 Game emulator module for MythTV x86_64 Extra mythplugins-mythmovies 0.22-4 Local movie listings via MythTV x86_64 Extra mythplugins-mythmusic 0.22-4 Music playing plugin for MythTV x86_64 Extra mythplugins-mythnews 0.22-4 News checking plugin for MythTV x86_64 Extra mythplugins-mythvideo 0.22-4 Video playback and browsing plugin for MythTV x86_64 Extra mythplugins-mythweather 0.22-4 Weather checking plugin for MythTV x86_64 Extra mythplugins-mythweb 0.22-4 Web interface for MythTV's backend x86_64 Extra mythplugins-mythzoneminder 0.22-4 Allows for viewing of CCTV cameras through zoneminder x86_64 Extra postgresql 8.4.2-2 A sophisticated object-relational DBMS x86_64 Extra mythtv 0.22-8 A Homebrew PVR project x86_64 Extra polkit-kde 0.95.1-2 KDE PolicyKit Authentication Agent x86_64 Extra unrar 3.9.8-1 The RAR uncompression program x86_64 Extra usbview 1.1-2 USB Viewer x86_64 Extra whois 5.0.1-1 The whois client by Marco d'Itri x86_64 Extra obex-data-server 0.4.5-1 A D-Bus service providing high-level OBEX client and server side functionality x86_64 Extra source-highlight 3.1.3-1 Convert source code to syntax highlighted document x86_64 Extra srm 1.2.10-1 A secure replacement for rm(1) that overwrites data before unlinking x86_64 Extra mpck 0.19-1 Reads MP3 files and tries to determine if they are correct x86_64 Extra mtools 4.0.12-1 A collection of utilities to access MS-DOS disks x86_64 Extra live-media 2010.02.10-1 A set of C++ libraries for multimedia streaming x86_64 Extra kdepim-akonadiconsole 4.4.0-2 Akonadi Management and Debugging Console x86_64 Extra kdepim-akregator 4.4.0-2 A Feed Reader for KDE x86_64 Extra kdepim-blogilo 4.4.0-2 A KDE Blogging Client x86_64 Extra kdepim-console 4.4.0-2 Command line tool for accessing calendar files x86_64 Extra kdepim-kaddressbook 4.4.0-2 Contact Manager x86_64 Extra kdepim-kalarm 4.4.0-2 Personal Alarm Scheduler x86_64 Extra kdepim-kjots 4.4.0-2 Note Taker x86_64 Extra kdepim-kleopatra 4.4.0-2 Certificate Manager and Unified Crypto GUI x86_64 Extra kdepim-kmail 4.4.0-2 Mail Client x86_64 Extra kdepim-knode 4.4.0-2 News Reader x86_64 Extra kdepim-knotes 4.4.0-2 Popup Notes x86_64 Extra kdepim-kontact 4.4.0-2 Personal Information Manager x86_64 Extra kdepim-korganizer 4.4.0-2 Calendar and Scheduling Program x86_64 Extra kdepim-kresources 4.4.0-2 KDE PIM resources x86_64 Extra kdepim-ktimetracker 4.4.0-2 Personal Time Tracker x86_64 Extra kdepim-libkdepim 4.4.0-2 Library for KDE PIM x86_64 Extra kdepim-wizards 4.4.0-2 KDE Groupware Wizard x86_64 Extra pyqt3 3.18.1-4 A set of Python bindings for the Qt3 toolkit x86_64 Extra k9copy 2.3.5-1 A small utility which allows the copy of DVD under Linux x86_64 Extra lcab 1.0b12-2 A program to make Microsoft cabinet files x86_64 Extra libebml 0.7.8-2 Extensible Binary Meta Language library x86_64 Extra help2man 1.37.1-1 Conversion tool to create man files x86_64 Extra enca 1.13-1 Charset analyser and converter x86_64 Extra gif2png 2.5.2-1 A GIF to PNG image format converter x86_64 Extra ocrad 0.19-1 An Optical Character Recognition program x86_64 Extra python-qscintilla 2.4.2-1 Python bindings for QScintilla2 x86_64 Extra proftpd 1.3.2c-2 A high-performance, scalable FTP server dgriffiths x86_64 Extra qscintilla 2.4.2-1 A port to Qt4 of Neil Hodgson's Scintilla C++ editor class AURuget 1.5.0.1-1gray-matter-svn 1590-1grub2-efi 1.97.2-1 pychess-svn 1608-1 perl-audio-jackminimix 0.02-1 libnih 1.0.1-2 gnome-mplayer-svn 1647-1 gecko-mediaplayer-svn 367-1 epidermis 0.5-1 perl-net-opensoundcontrol 0.05-1Thanks
Also tagged with one or more of these keywords: arch linux, updates, securitybreach
