Pictutorials Graphic tutorials created by our members:
Contributions to this thread are welcome, you are invited to post them Here and one of the moderators will move it up here ( and index it ) if we see it fit for this thread.INDEX:- Configure media sources and install programs (Thunderbird) in Mandriva 2008- configure display resolution (1280x800) in Mandriva 2008 running in VirtualBox- VirtualBox How-To ( Slideshow ). . . Installing Slackware 12.0 ( Virtualbox slideshow ). . . Installing D Small Linux 3.4 ( Virtualbox slideshow ). . . Installing FreeSpire 2.0 ( Virtualbox slideshow ). . . Installing PCLos 2007 ( Virtualbox slideshow ). . . Installing Wolvix 1.1.0 ( Virtualbox slideshow ). . . Installing Debian 4.0 ( Virtualbox slideshow ). . . Installing gOS ( Virtualbox slideshow ). . . Installing VectorLinux 5.9 Gold ( Virtualbox slideshow ). . . Installing PCLinuxOS Gnome ( Virtualbox slideshow ). . . Installing DreamLinux 3.0 ( Virtualbox slideshow ). . . Installing VectorLinux 5.9 soho Live preview ( Virtualbox slideshow ). . . Installing Paldo ( Virtualbox slideshow ). . . Installing Blag 90001 ( Virtualbox slideshow ). . . Installing KiwiLinux ( Virtualbox slideshow ). . . Installing Xandros 4.0 ( Virtualbox slideshow ). . . Installing Slackware 12.2 ( Virtualbox slideshow ). . . Installing Debian 5.0 Lenny ( Virtualbox slideshow )- Install Mandriva One 2008 in VirtualBox ( on a Windows host )
Pictutorials
Started by
Bruno
, Oct 29 2007 03:31 PM
8 replies to this topic
#1 OFFLINE
Posted 29 October 2007 - 03:31 PM
One Page Linux Manual ~ Yo Linux ~ Great Linux Links ~ www.brunolinux.com
My Hometown ~ Registered Linux User #299965 ~ LFS User #11450
#2 OFFLINE
Posted 29 October 2007 - 03:46 PM
HOWTO Configure media sources and install programs (Thunderbird) in Mandriva 2008Open the Mandriva Control Center:
First, choose "Distribution Sources" (when you do this for the first time, things might look a bit different from the below screen shots... but the "drill" is the same):
Yes:
Next, you choose the mirror location... when in doubt, Netherlands and nluug is a splendid choice. ( NOTE: Mirror is out of sync please choose ftp.free.fr )
Now you should have repositories pretty much like in the below pic (your numbering'll most likely go from 0-1 to 0-12):
What was the... ah, Thunderbird! Back to control center main menu, and "Manage Software":
Either serch for "Thunderbird" (the package is called "mozilla-thunderbird") or find it "manually"; Networking -> Mail. "Tick" the box... the green ball appears. Click "Apply" to start download/install.
That's it, really. You'll find Thunderbird in Start Menu in "Internet". Oh: when you install software this way, every single program you install will be kept up-to-date automatically.
Yes:
Edited by Bruno, 17 November 2008 - 03:57 AM.
Updated to avoid sync problems . . .
#3 OFFLINE
Posted 29 October 2007 - 04:01 PM
HOWTO configure display resolution (1280x800) in Mandriva 2008 running in VirtualBox
Hit the "Configure your computer" icon (see above)... root password prompt:
Choose "Hardware", and, once in there, "Set up the graphical server":
First, let's configure "Monitor": Choose (unlike I
) "Flat panel 1280x800":
Next, resolution... Choose "24 bits", hit the "resolution bar" (yours saying, "1024x768")... goes something like:
Which resolution to choose? None of the above; I would choose the "native" resolution, 1280x800, and run Mandriva "Full screen" without any "VBox controls" visible. When you start "VirtualMandy", hit <right Ctrl> + <F> to go full screen, and whenver you want to have access to controls while using your Mandy, hit <right ctrl> + <Home>. To get 1280x800, in the above list, choose "Other"... there you have it:
Bach in the "Graphical Server Main Menu" (your settings should now be "Flat Panel, 1280x800" and "1280x800, 24bpp"), choose "Test". If everything is OK, you'll see rather a psychedelic full screen display of all the colours of a rainbow. In that case, accept new settings.
Exit the Control center. Log out. Log back in. New resolution should now be in use.
#4 OFFLINE
Posted 29 October 2007 - 04:02 PM
i sure do like this virtualbox (VB) program. i guess it's called an emulator. i'm really fascinated with running multiple operating systems and since discovering this outstanding program i've been in emulation heaven. as you can see from these screenshots i have quite a few os's installed. i'm running VB on mandriva linux 2007.1 which makes this my host os. each of the other distros are called guests and run in a "virtual machine". VB runs on the 3 major platforms windows, mac, linux. i only know it on linux so i don't know how well it functions on the other platforms but the reviews are good. a big feature not yet supported is 3d acceleration because VB is limited to a generic graphics driver.other than that all of the distros shown in my screenshots are fully functioning. it isn't hard to get started. there are only a few decisions to make when creating a virtual machine and each option is explained very well in the user documentation. these slideshows show how i set up my virtual machines and also how i learn to install and use some of the distros. it is in my opinion the best way to explore a different environment or to have access to something that is only available on another os.VirtualBox How-To ( Slideshow ) Installing Slackware 12.0 ( Virtualbox slideshow )Installing D Small Linux 3.4 ( Virtualbox slideshow ) Installing FreeSpire 2.0 ( Virtualbox slideshow ) Installing PCLos 2007 ( Virtualbox slideshow ) Installing Wolvix 1.1.0 ( Virtualbox slideshow )Installing Debian 4.0 ( Virtualbox slideshow )Installing gOS ( Virtualbox slideshow )Installing VectorLinux 5.9 Gold ( Virtualbox slideshow )Installing PCLinuxOS Gnome ( Virtualbox slideshow )Installing DreamLinux 3.0 ( Virtualbox slideshow )Installing VectorLinux 5.9 soho Live preview ( Virtualbox slideshow )Installing Paldo ( Virtualbox slideshow )Installing Blag 90001 ( Virtualbox slideshow )Installing KiwiLinux ( Virtualbox slideshow )Installing Xandros 4.0 ( Virtualbox slideshow )Installing Slackware 12.2 ( Virtualbox slideshow )Installing Debian 5.0 Lenny ( Virtualbox slideshow )
steve
I'm a pc, running GNU/Linux.
#5 OFFLINE
Posted 29 October 2007 - 05:28 PM
HOWTO install Mandriva One 2008 in VirtualBox (part 1)So we have a Windows install ( the host ), we will install Vitualization software and load Mandriva Linux as guestWhat you need:- Mandrive One 2008, shaken, not stirred:http://www.mandriva....n/download.html- VirtualBox (here for "normal", 32-bit Windows):http://www.virtualbo...5.0_Win_x86.msiOff we go, then:During the installation of VirtualBox, don’t be surprised if you get a few “are you sure you want to do this?” messages. Just click Continue Anyway when they pop up.Launch VirtualBox and click the New button.
OK... I stole the above pic from the net... let's move to my pics:
Give your virtual machine a name... and choose "Linux 2.6" for "OS type":
Next, choose how much RAM you are willing to give for "the guest"... you can change this (and pretty much every other setting) later:
Next, you're going to create the "virtual hard disk". Choose "New":
Click "Next":
Next: Choose "Dynamically expanding image":
Next, you choose the location and (maximum) size of your virtual HD. Pay attention here: the "Select" button is the yellowish folder icon. If the "default" location isn't kosher, use it to navigate to a location of your choice. Use the slider to change size... I'd choose something between 10-15 GB.
Time to confirm (or change) your virtual HD settings:http://img529.imageshack.us/img529/757/kuvakaappauscreatenewviil1.th.pngChoose "Next":http://img529.imageshack.us/img529/2798/kuvakaappauscreatenewvirk1.th.png
Click "Next":
#6 OFFLINE
Posted 29 October 2007 - 05:37 PM
HOWTO install Mandriva One 2008 in VirtualBox (part 2)Summary; if kosher, choose "Finish":
Back where we started... only, this time you have the "Mandy entry" in menu:
OK... now you need the actual install media... click on "CD-DVD-ROM"... gets you here:
If you have burned a CD, the above scenario, "Host CD-DVD Drive" is for you. Me, I don't like to burn disks unless I absolutely have to, so I use the .iso image on my HD instead:
Almost ready for OS install... you might want to enable "Audio" and "USB" before installing the guest OS, though:
Ready? Good... here goes... click on "Start":
Questions... language, location, keyboard setup, time:
After a "Mandvertisment" screen... Houston, we have a desktop:
Good moment to open Firefox and check that net is working... working? Good, let's install; double click on the "Live Install" icon:http://img136.imageshack.us/img136/5812/kuvakaappaus149kq0.th.pngChoose "Use free space":http://img136.imageshack.us/img136/4572/kuvakaappaus150wy8.th.png
#7 OFFLINE
Posted 29 October 2007 - 06:20 PM
HOWTO install Mandriva One 2008 in VirtualBox (part3)Installing now... time for coffee:
Next, the bootloader (GRUB)... go with the defaults:
NOW:
The easy way to do this is to click the (X) [close] button... VirtualBox window, top right:
This closes Virtual Mandy... before you start it again, let's remove the CD/image from the equation:
CD drive/image unticked, start the virtual machine; this time it boots from "virtual" HD:
More questions... net connection:
http://img89.imageshack.us/img89/6159/kuvakaappaus158yu1.th.png
NOW:
#8 OFFLINE
Posted 29 October 2007 - 06:29 PM
HOWTO install Mandriva One 2008 in VirtualBox (part4)
Root password, user account(s):
Pay no attention... your net probably works just fine:
FINALLY... just log in:http://img233.imageshack.us/img233/1006/kuvakaappaus167cw5.th.pngA pleasant surprise: the VirtualBox guest additions are "there" without my having to install them. That's a first! Douze points! This means you can move stuff between host and guest OS using clipboard... or you can set up "shared" folders... plus, you can get full screen resolution. Me, I prefer "one step down; my (Ubuntu) host uses 1280x1024, so I set guests to 1152×864:http://img100.imageshack.us/img100/1806/kuvakaappaus176gu4.th.png
#9 OFFLINE
Posted 16 March 2011 - 12:59 PM
Force reorder time stamp: 1259 - Wednesday 16 March, 2011
This topic is locked
