Agent007 Posted May 31, 2003 Share Posted May 31, 2003 hi all,Sometime back I had mentioned shutting down the NTPD daemon for security reasons and running a cron that will sync the time. Following is the procedure. Btw, u will require r00t access to configure this. CONFIGURATION:-Put loopback address in the /etc/ntp.conf file (if this file does notexist make a new one)Entries in /etc/ntp.confserver 127.0.0.1run the follwing from the promptFirst Sync# ntpdate 137.92.140.80# ntpdate 137.92.140.80Since we want to put the sync in a crontab and not use the NTPD servicewe need to do the following# touch /usr/local/bin/ntpupdate.sh# vi /usr/local/bin/ntpupdate.shAppend the following lines in this file#First Full Syncntpdate 137.92.140.80#Second Full Syncntpdate 193.79.237.14Write and save the fileMake the file executable# chmod +x /usr/local/bin/ntpupdate.shPut Crontab entries to run it in a scheduled fashion# crontab -eappend the following30 9 * * * /usr/local/bin/ntpupdate.shwrite and save the file The above will sync time everyday at 9:30 amwith the above public ntp serversPS:- IP Address 192.79.237.14 and 137.92.140.80 are public NTP servers Quote Link to comment Share on other sites More sharing options...
