Disk Speed Test (Read/Write): SSD Performance in Linux
ssd benchtest speed linux nvme
38 replies to this topic
#26 OFFLINE   securitybreach
  • 23,734 posts
Posted 12 August 2018 - 08:29 PM
View PostV.T. Eric Layton, on 12 August 2018 - 08:25 PM, said:
Ah... many things I have to learn, I s'pose. If I remember correctly, there are already some SSD threads around here that explain a lot of it. :)
Just follow this as it covers TRIM and such: https://wiki.archlin...lid_state_drive
#27 OFFLINE   abarbarian
  • 5,607 posts
Posted 13 August 2018 - 04:41 AM
I had forgotten that you need to do some background reading before you installed and migrated to a ssd. I found the following articles very helpful as starter information when I made the transition as they contain clear and step by step information which was very helpful to a novice user like myself. They are well worth the ten or so minutes they need to read them.
http://www.linux-mag...uning-Your-SSD
http://www.linux-mag...ting-to-an-SSD
Re-reading the above made me realise that I had missed out on getting clued up on the "lazytime" mount option so I am off to investigate. I may very well not need it as Arch can utilise a systemd unit for trim which runs at default once a week and I have already set this up.
I also have not set up several of the optimisations for ssd's so I'll be investigating them as well. I think I have set up my Windows to run properly on a ssd but I will check that out also just to be sure.
Solid state drives make everything run faster and more smoothly, but you can squeeze out even more performance with some practical optimization steps.
all of the above links are a tad old but almost all the information is still relevant.
I started this thread as a bit of fun however whilst it has been fun it has also led to discovery of more useful information. You can just pop a ssd in your pc and do a basic set up and run with it quite happily or you can scratch that geeky itch and fine tune it to gain every last little bit of advantage from it.
I also think I have solved the mystery of why my nvme drive was posting slower write results than other folks ssd's. My drive was almost full which will have some impact. I also leave my pc on 24/7 as I run Boinc for the WCG which results in a load of reads and writes 24/7 this will also have an impact. I have set up the systemd unit to run at the default weekly time so it may be beneficial for me to set this to run more frequently.
Happy speeding folks and don't burn out that old grey cell :harhar:
Install ARCH
"I did and I'm really happy"
#28 OFFLINE   abarbarian
  • 5,607 posts
Posted 13 August 2018 - 07:25 AM
I may be wrong here but I do not think Eric's Slackware uses systemd so he will not be able to use the service.timer for trim. He should be able to set up a cron job with fstrim. It seems this is a much better way than utilising the "discard" option in fstab.
I have just made some changes to my fstab,
#/dev/nvme0n1p4 LABEL=ArchRoot
UUID=facb8acb-8d5d-4d91-8630-31a781a95d44	/			 ext4		  rw,relatime,lazytime,data=ordered	0 1
I added the "lazytime" option after extensive reading on the subject. My trim is done via systemd. An I think I am going to change from UUID to part-UUID later on after I have had a much needed cup of tea.
If anyone spots faults with my fstab entry do let me know. :breakfast:
Install ARCH
#29 OFFLINE   securitybreach
  • 23,734 posts
Posted 13 August 2018 - 07:36 AM
Looks good to me but I have never heard of or used the "lazytime" option....
#30 OFFLINE   abarbarian
  • 5,607 posts
Posted 13 August 2018 - 12:22 PM
Never heard of lazytime :w00t: Blimey and I thought you were right at the cutting edge. Guess we will have to change your nickname from Minute Man to Missed It Man :Laughing: As an x hippy I am familiar with all aspects of lazytime :laugh:
Install ARCH
#31 OFFLINE   securitybreach
  • 23,734 posts
Posted 13 August 2018 - 12:52 PM
Well glancing over https://lwn.net/Articles/621046/, it seems to be just a convenience and to stay POSIX compliant but not really required.
Relatime works well enough for most systems, but there are still those who would like better atime tracking without paying the performance penalty for it. Some users also dislike the fact that relatime, for all its value, causes the system to not be fully compliant with the POSIX specification.
#32 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,438 posts
Posted 13 August 2018 - 01:09 PM
"Lazytime"? Sounds like a wonderful thing to me. ;)
I have a tee shirt that says this...
#33 OFFLINE   raymac46
  • 3,718 posts
Posted 13 August 2018 - 05:44 PM
This is handy to get the schedulers set properly if you have both an SSD and an HDD in your system.
Gksudo gedit/etc/udev/rules.d/60-schedulers.rules
# set noop scheduler for non-rotating disks
ACTION=="add|change", KERNEL=="sd[a-z]", ATTR{queue/rotational}=="0", ATTR{queue/scheduler}="noop"
# set cfq scheduler for rotating disks
ACTION=="add|change", KERNEL=="sd[a-z]", ATTR{queue/rotational}=="1", ATTR{queue/scheduler}="cfq"
Registered Linux User 445659
#34 OFFLINE   abarbarian
  • 5,607 posts
Posted 14 August 2018 - 06:08 AM
This whole I/O thing is pretty hard to pin down.
Arch seems to use cfq as a default for everything. Finding information for hdd's is variable and hard to pin down. Optimisation for ssd's depends on who wrote the information and when . I can find no clear advice in my searching. I did however find that nvme's do not require an I/O scheduler to be set.
PCIe devices (Nvme ssd drives) have their own large internal queues along with fast service and do not require or benefit from setting an I/O scheduler.
Mind you I did find some info that suggests that you can set a scheduler for nvme's and it will provide benefits, as it was a specialist case I got lost in all the fine detail and will stick with no scheduler for my nvme. :laugh:
Install ARCH
#35 OFFLINE   abarbarian
  • 5,607 posts
Posted 14 August 2018 - 06:16 AM
From the horses mouth it seems that there may be benefits other than just POSIX compliance.
https://lwn.net/Articles/620086/
Enabling lazytime and disabling the default realtime will result in fewer extra disk writes,
n.b.: because of the many wins of this mode, we may want to enable lazytime updates by default in the future.
I realised that I had altered fstab to include lazytime and relatime which is pretty dumb. So I have altered it to the below.
UUID=facb8acb-8d5d-4d91-8630-31a781a95d44 / ext4 rw,lazytime,data=ordered 0 1
If anyone spots a flaw in the fstab entry please do tell.
:breakfast:
Install ARCH
#36 OFFLINE   securitybreach
  • 23,734 posts
Posted 14 August 2018 - 06:38 AM
:breakfast:
Thanks, I will check it out then.
#37 OFFLINE   sunrat
sunrat
  • 5,617 posts
Posted 14 August 2018 - 08:42 AM
I just use noatime.
On a side note, lazytime reminds me of a funny:
"What are you doing tomorrow?"
"Nothing"
"But that's what you did today."
"I didn't finish."
:D
#38 OFFLINE   raymac46
  • 3,718 posts
Posted 14 August 2018 - 08:44 AM
I think you are right about PCI based SSDs not needing I/O schedulers. This scheduler ruleset is strictly for SATA based drives.
#39 OFFLINE   abarbarian
  • 5,607 posts
Posted Yesterday, 03:32 AM
$ cat /sys/block/nvme0n1/queue/scheduler
[none] mq-deadline kyber bfq
$ cat /sys/block/sd?/queue/scheduler
noop deadline [cfq]
noop deadline [cfq]
noop deadline [cfq]
noop deadline [cfq]
It is the default on Arch and Arch looks to use cfq for ssd's and hdd's as a default. :breakfast:
Install ARCH
Also tagged with one or more of these keywords: ssd, benchtest, speed, linux, nvme
