Firefox Addons - What Are Your Favs?
15 replies to this topic
#1 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,009 posts
Posted 12 April 2017 - 08:49 PM
What cool addons do you use in your Firefox? Here are mine...
#2 OFFLINE   Ed_P
Ed_P
  • 3,076 posts
Posted 12 April 2017 - 11:51 PM
With Firefox dropping support for add-ons what WebExtensions will you replace your's with?
"From Firefox 57 onwards, WebExtensions will be the only supported extension type, and Firefox will not load other types."
https://developer.mo...-US/Add-ons/SDK
Edited by Ed_P, 12 April 2017 - 11:55 PM.
Ed
#3 OFFLINE   abarbarian
  • 5,274 posts
Posted 13 April 2017 - 09:27 AM
Well I have not set up my temporary os (only been using it for almost a year)  so have not added all the add-ons/extessions I normally use.
X-Marks is the most useful one I have which I only use for bookmarks.
:breakfast:
Install ARCH
"I did and I'm really happy"
#4 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,009 posts
Posted 13 April 2017 - 11:05 AM
Most of the ones you see there are already the newer type extensions, I believe. Regardless, since I'm running Firefox ESR 52.0.2 (64 bit) in Slackware, it'll be some time before I ever see v57.x on my system.
#5 OFFLINE   raymac46
  • 3,194 posts
Posted 13 April 2017 - 11:11 AM
These are mine:
Registered Linux User 445659
#6 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,009 posts
Posted 13 April 2017 - 11:46 AM
That "Disable Anti-Adblock" looks interesting.
#7 OFFLINE   raymac46
  • 3,194 posts
Posted 13 April 2017 - 02:08 PM
Actually if you don't like the anti-adblock stuff, the best way is to use Greasemonkey and Host Anti-Adblock Killer.
https://reek.github....adblock-killer/
This works a fair bit of the time to convince a website that you are NOT using Adblock Plus when you are.
As much as I like Google Chrome, I have to admit that Firefox and its Extensions work better at anti-adblock. The whole thing is sort of like a war - tanks vs machine guns vs antitank missiles.
Edited by raymac46, 13 April 2017 - 02:22 PM.
#8 OFFLINE   Ed_P
Ed_P
  • 3,076 posts
Posted 14 April 2017 - 01:56 AM
I'm running Firefox 51.0.1 in Slackware since 52 ESR dropped support for my Java plugin.   And I don't see my moving past that for a long time.
Edited by Ed_P, 14 April 2017 - 01:58 AM.
Ed
#9 OFFLINE   abarbarian
  • 5,274 posts
Posted 14 April 2017 - 08:30 AM
View Postraymac46, on 13 April 2017 - 11:11 AM, said:
These are mine:
I had RoboForm but it would not work in MX-16. Luckily I had kept MX-15 running so I was able to gather all my passwords and transfer them to KeePass. Did me a favor really as I think KeePass will be better for my needs.  :breakfast:
Install ARCH
    Nocturnal Slacker
  • 21,009 posts
Posted 14 April 2017 - 11:50 AM
I swore off all things Java many moons ago, so I didn't have that issue that you had above when I went to 52.x. :)
#11 OFFLINE   burninbush
burninbush
    Multithreader
  • 1,278 posts
Posted 14 April 2017 - 01:05 PM
I see my list on those above -- but would recommend Down Them All for anybody who downloads big iso files, etc.  It (transparently) starts up a scheme that breaks the file into 4 segments and gets them all at the same time.  Won't hurt anything if you only connect to a service that gives you full bandwidth on a single connection.  Some sites won't allow multiple connections, again not a problem.
I also add Title Save and the great Hide Tab Bar With Only One Tab -- recovers the wasted space that layout feature uses.
#12 OFFLINE   ebrke
ebrke
    Board Bigwig
  • 2,670 posts
Posted 14 April 2017 - 01:14 PM
Here it's AdblockPlus, Better Privacy, NoScript, Self-Destructing Cookies.
Registered Linux User 344759
#13 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,009 posts
Posted 14 April 2017 - 03:10 PM
Self-destructing Cookies is a hand little tool. I use it mostly because it's an easy way to protect some cookies (logins) that I don't want to ever get dumped. I set FF to dump all cookie and history when I close it, so it's handy to have SDC protect the cookies I want to save with just one clicky. :)
#14 OFFLINE   crp
crp
    Board Bigwig
  • 2,992 posts
Posted 16 April 2017 - 02:03 PM
No Script still tops my list .
Down-Them-All
ublock origin
ghostery
video download helper
screengrab
grammerly
actually realized it was pretty easy to tell which ones i liked most as i made donations for these (except grammerly).
#15 OFFLINE   sunrat
sunrat
  • 5,233 posts
Posted 04 May 2017 - 08:14 AM
I just installed the AntiAdblock killer script for Greasemonkey. Interestingly it needs to be activated to work with uBlock Origin, and while in the UBO settings I noticed that it can block Disconnect tracking lists as well! I used Disconnect for a while and don't recall problems with it but if you can use the one extension to do the job of two, I call that a win!
selectivecookiedelete does basically the same thing as Self-Destructing Cookies afaik.
uBlock Origin is a better ad blocker than AdBlock Plus using vastly less resources. Comparison - https://github.com/g...ciency-compared
I thought I was a conservative extension user. Turns out I have more than anyone else has posted so far. :rolleyes:   edit - except Eric. :whistling:
#16 OFFLINE   V.T. Eric Layton
    Nocturnal Slacker
  • 21,009 posts
Posted 04 May 2017 - 03:10 PM
Well, you can scratch Lastpass and Xmarks off my list above. I was having issues with a recent Lastpass update, so I aced both of their extensions and started using FF's built-in sync. :)
