NEW UPDATES Debian
debian updates sunrat bruno v.t. eric layton
1335 replies to this topic
#1326 OFFLINE   sunrat
sunrat
  • 5,323 posts
Posted 20 September 2017 - 07:07 PM
Debian Security Advisory DSA-3980-1                   security@debian.org
https://www.debian.org/security/                     Salvatore Bonaccorso
September 20, 2017                    https://www.debian.org/security/faq
Package        : apache2
CVE ID         : CVE-2017-9798
Debian Bug     : 876109
Hanno Boeck discovered that incorrect parsing of Limit directives of
.htaccess files by the Apache HTTP Server could result in memory
disclosure.
For the oldstable distribution (jessie), this problem has been fixed
in version 2.4.10-10+deb8u11.
For the stable distribution (stretch), this problem has been fixed in
version 2.4.25-3+deb9u3.
Debian Security Advisory DSA-3981-1                   security@debian.org
Package        : linux
CVE ID         : CVE-2017-7518 CVE-2017-7558 CVE-2017-10661 CVE-2017-11600
                 CVE-2017-12134 CVE-2017-12146 CVE-2017-12153 CVE-2017-12154
                 CVE-2017-14106 CVE-2017-14140 CVE-2017-14156 CVE-2017-14340
                 CVE-2017-14489 CVE-2017-14497 CVE-2017-1000111 CVE-2017-1000112
                 CVE-2017-1000251 CVE-2017-1000252 CVE-2017-1000370 CVE-2017-1000371
                 CVE-2017-1000380
Debian Bug     : 866511 875881
Several vulnerabilities have been discovered in the Linux kernel that
may lead to privilege escalation, denial of service or information
leaks.
CVE-2017-7518
    Andy Lutomirski discovered that KVM is prone to an incorrect debug
    exception (#DB) error occurring while emulating a syscall
    instruction. A process inside a guest can take advantage of this
    flaw for privilege escalation inside a guest.
CVE-2017-7558 (stretch only)
    Stefano Brivio of Red Hat discovered that the SCTP subsystem is
    prone to a data leak vulnerability due to an out-of-bounds read
    flaw, allowing to leak up to 100 uninitialized bytes to userspace.
CVE-2017-10661 (jessie only)
    Dmitry Vyukov of Google reported that the timerfd facility does
    not properly handle certain concurrent operations on a single file
    descriptor.  This allows a local attacker to cause a denial of
    service or potentially execute arbitrary code.
CVE-2017-11600
    Bo Zhang reported that the xfrm subsystem does not properly
    validate one of the parameters to a netlink message. Local users
    with the CAP_NET_ADMIN capability can use this to cause a denial
    of service or potentially to execute arbitrary code.
CVE-2017-12134 / #866511 / XSA-229
    Jan H. Schoenherr of Amazon discovered that when Linux is running
    in a Xen PV domain on an x86 system, it may incorrectly merge
    block I/O requests.  A buggy or malicious guest may trigger this
    bug in dom0 or a PV driver domain, causing a denial of service or
    potentially execution of arbitrary code.
    This issue can be mitigated by disabling merges on the underlying
    back-end block devices, e.g.:
        echo 2 > /sys/block/nvme0n1/queue/nomerges
CVE-2017-12146 (stretch only)
    Adrian Salido of Google reported a race condition in access to the
    "driver_override" attribute for platform devices in sysfs. If
    unprivileged users are permitted to access this attribute, this
    might allow them to gain privileges.
CVE-2017-12153
    bo Zhang reported that the cfg80211 (wifi) subsystem does not
    properly validate the parameters to a netlink message. Local users
    with the CAP_NET_ADMIN capability (in any user namespace with a
    wifi device) can use this to cause a denial of service.
CVE-2017-12154
    Jim Mattson of Google reported that the KVM implementation for
    Intel x86 processors did not correctly handle certain nested
    hypervisor configurations. A malicious guest (or nested guest in a
    suitable L1 hypervisor) could use this for denial of service.
CVE-2017-14106
    Andrey Konovalov discovered that a user-triggerable division by
    zero in the tcp_disconnect() function could result in local denial
    of service.
CVE-2017-14140
    Otto Ebeling reported that the move_pages() system call performed
    insufficient validation of the UIDs of the calling and target
    processes, resulting in a partial ASLR bypass. This made it easier
    for local users to exploit vulnerabilities in programs installed
    with the set-UID permission bit set.
CVE-2017-14156
    "sohu0106" reported an information leak in the atyfb video driver.
    A local user with access to a framebuffer device handled by this
    driver could use this to obtain sensitive information.
CVE-2017-14340
    Richard Wareing discovered that the XFS implementation allows the
    creation of files with the "realtime" flag on a filesystem with no
    realtime device, which can result in a crash (oops). A local user
    with access to an XFS filesystem that does not have a realtime
    device can use this for denial of service.
CVE-2017-14489
    ChunYu Wang of Red Hat discovered that the iSCSI subsystem does not
    properly validate the length of a netlink message, leading to
    memory corruption. A local user with permission to manage iSCSI
    devices can use this for denial of service or possibly to execute
    arbitrary code.
CVE-2017-14497 (stretch only)
    Benjamin Poirier of SUSE reported that vnet headers are not
    properly handled within the tpacket_rcv() function in the raw
    packet (af_packet) feature. A local user with the CAP_NET_RAW
    capability can take advantage of this flaw to cause a denial of
    service (buffer overflow, and disk and memory corruption) or have
    other impact.
CVE-2017-1000111
    Andrey Konovalov of Google reported a race condition in the raw
    packet (af_packet) feature. Local users with the CAP_NET_RAW
    capability can use this for denial of service or possibly to
CVE-2017-1000112
    Andrey Konovalov of Google reported a race condition flaw in the
    UDP Fragmentation Offload (UFO) code. A local user can use this
    flaw for denial of service or possibly to execute arbitrary code.
CVE-2017-1000251 / #875881
    Armis Labs discovered that the Bluetooth subsystem does not
    properly validate L2CAP configuration responses, leading to a
    stack buffer overflow. This is one of several vulnerabilities
    dubbed "Blueborne". A nearby attacker can use this to cause a
    denial of service or possibly to execute arbitrary code on a
    system with Bluetooth enabled.
CVE-2017-1000252 (stretch only)
    Jan H. Schoenherr of Amazon reported that the KVM implementation
    for Intel x86 processors did not correctly validate interrupt
    injection requests. A local user with permission to use KVM could
CVE-2017-1000370
    The Qualys Research Labs reported that a large argument or
    environment list can result in ASLR bypass for 32-bit PIE binaries.
CVE-2017-1000371
    orenvironment list can result in a stack/heap clash for 32-bit
    PIE binaries.
CVE-2017-1000380
    Alexander Potapenko of Google reported a race condition in the ALSA
    (sound) timer driver, leading to an information leak. A local user
    with permission to access sound devices could use this to obtain
Debian disables unprivileged user namespaces by default, but if they
are enabled (via the kernel.unprivileged_userns_clone sysctl) then
CVE-2017-11600, CVE-2017-14497 and CVE-2017-1000111 can be exploited
by any local user.
For the oldstable distribution (jessie), these problems have been fixed
in version 3.16.43-2+deb8u5.
For the stable distribution (stretch), these problems have been fixed in
version 4.9.30-2+deb9u5.
#1327 OFFLINE   sunrat
sunrat
  • 5,323 posts
Posted 22 September 2017 - 06:13 PM
Debian Security Advisory DSA-3982-1                   security@debian.org
September 21, 2017                    https://www.debian.org/security/faq
Package        : perl
CVE ID         : CVE-2017-12837 CVE-2017-12883
Debian Bug     : 875596 875597
Multiple vulnerabilities were discovered in the implementation of the
Perl programming language. The Common Vulnerabilities and Exposures
project identifies the following problems:
CVE-2017-12837
    Jakub Wilk reported a heap buffer overflow flaw in the regular
    expression compiler, allowing a remote attacker to cause a denial of
    service via a specially crafted regular expression with the
    case-insensitive modifier.
CVE-2017-12883
    Jakub Wilk reported a buffer over-read flaw in the regular
    expression parser, allowing a remote attacker to cause a denial of
    service or information leak.
in version 5.20.2-3+deb8u9.
version 5.24.1-3+deb9u2.
For the testing distribution (buster), these problems have been fixed
in version 5.26.0-8.
For the unstable distribution (sid), these problems have been fixed in
version 5.26.0-8.
Debian Security Advisory DSA-3983-1                   security@debian.org
https://www.debian.org/security/                       Moritz Muehlenhoff
September 22, 2017                    https://www.debian.org/security/faq
Package        : samba
CVE ID         : CVE-2017-12150 CVE-2017-12151 CVE-2017-12163
Multiple security issues have been discoverd in Samba, a SMB/CIFS file,
print, and login server for Unix:
CVE-2017-12150
    Stefan Metzmacher discovered multiple code paths where SMB signing
    was not enforced.
CVE-2017-12151
    Stefan Metzmacher discovered that tools using libsmbclient did not
    enforce encryption when following DFS redirects, which could allow a
    man-in-the-middle attacker to read or modify connections which were
    meant to be encrypted.
CVE-2017-12163
    Yihan Lian and Zhibin Hu discovered that insufficient range checks
    in the processing of SMB1 write requests could result in disclosure
    of server memory.
in version 2:4.2.14+dfsg-0+deb8u8.
version 2:4.5.8+dfsg-2+deb9u2.
#1328 OFFLINE   sunrat
sunrat
  • 5,323 posts
Posted 26 September 2017 - 07:31 PM
Debian Security Advisory DSA-3984-1                   security@debian.org
https://www.debian.org/security/                           Florian Weimer
September 26, 2017                    https://www.debian.org/security/faq
Package        : git
Debian Bug     : 876854
joernchen discovered that the git-cvsserver subcommand of Git, a
distributed version control system, suffers from a shell command
injection vulnerability due to unsafe use of the Perl backtick
operator.  The git-cvsserver subcommand is reachable from the
git-shell subcommand even if CVS support has not been configured
(however, the git-cvs package needs to be installed).
In addition to fixing the actual bug, this update removes the
cvsserver subcommand from git-shell by default.  Refer to the updated
documentation for instructions how to reenable in case this CVS
functionality is still needed.
in version 1:2.1.4-2.1+deb8u5.
version 1:2.11.0-3+deb9u2.
For the unstable distribution (sid), this problem has been fixed in
version 1:2.14.2-1.
#1329 OFFLINE   sunrat
sunrat
  • 5,323 posts
Posted 28 September 2017 - 08:23 PM
Debian Security Advisory DSA-3985-1                   security@debian.org
https://www.debian.org/security/                          Michael Gilbert
September 28, 2017                    https://www.debian.org/security/faq
Package        : chromium-browser
CVE ID         : CVE-2017-5111 CVE-2017-5112 CVE-2017-5113 CVE-2017-5114
                 CVE-2017-5115 CVE-2017-5116 CVE-2017-5117 CVE-2017-5118
                 CVE-2017-5119 CVE-2017-5120 CVE-2017-5121 CVE-2017-5122
Several vulnerabilities have been discovered in the chromium web browser.
CVE-2017-5111
    Luat Nguyen discovered a use-after-free issue in the pdfium library.
CVE-2017-5112
    Tobias Klein discovered a buffer overflow issue in the webgl
    library.
CVE-2017-5113
    A buffer overflow issue was discovered in the skia library.
CVE-2017-5114
    Ke Liu discovered a memory issue in the pdfium library.
CVE-2017-5115
    Marco Giovannini discovered a type confusion issue in the v8
    javascript library.
CVE-2017-5116
    Guang Gong discovered a type confusion issue in the v8 javascript
    library.
CVE-2017-5117
    Tobias Klein discovered an uninitialized value in the skia library.
CVE-2017-5118
    WenXu Wu discovered a way to bypass the Content Security Policy.
CVE-2017-5119
    Another uninitialized value was discovered in the skia library.
CVE-2017-5120
    Xiaoyin Liu discovered a way downgrade HTTPS connections during
    redirection.
CVE-2017-5121
    Jordan Rabet discovered an out-of-bounds memory access in the v8
    javascript library.
CVE-2017-5122
    Choongwoo Han discovered an out-of-bounds memory access in the v8
    javascript library.
version 61.0.3163.100-1~deb9u1.
For the testing distribution (buster), these problems will be fixed soon.
version 61.0.3163.100-1.
#1330 OFFLINE   sunrat
sunrat
  • 5,323 posts
Posted 30 September 2017 - 07:28 PM
Debian Security Advisory DSA-3986-1                   security@debian.org
September 29, 2017                    https://www.debian.org/security/faq
Package        : ghostscript
CVE ID         : CVE-2017-9611 CVE-2017-9612 CVE-2017-9726 CVE-2017-9727
                 CVE-2017-9739 CVE-2017-9835 CVE-2017-11714
Debian Bug     : 869907 869910 869913 869915 869916 869917 869977
Several vulnerabilities were discovered in Ghostscript, the GPL
PostScript/PDF interpreter, which may result in denial of service if a
specially crafted Postscript file is processed.
in version 9.06~dfsg-2+deb8u6.
version 9.20~dfsg-3.2+deb9u1.
Debian Security Advisory DSA-3987-1                   security@debian.org
Package        : firefox-esr
CVE ID         : CVE-2017-7793 CVE-2017-7805 CVE-2017-7810 CVE-2017-7814
                 CVE-2017-7818 CVE-2017-7819 CVE-2017-7823 CVE-2017-7824
Several security issues have been found in the Mozilla Firefox web
browser: Multiple memory safety errors, use-after-frees, buffer
overflows and other implementation errors may lead to the execution of
arbitrary code, denial of service, cross-site scripting or bypass of
the phishing and malware protection feature.
in version 52.4.0esr-1~deb8u1.
version 52.4.0esr-1~deb9u1.
Debian Security Advisory DSA-3988-1                   security@debian.org
September 30, 2017                    https://www.debian.org/security/faq
Package        : libidn2-0
CVE ID         : CVE-2017-14062
Debian Bug     : 873902
An integer overflow vulnerability was discovered in decode_digit() in
libidn2-0, the GNU library for Internationalized Domain Names (IDNs),
allowing a remote attacker to cause a denial of service against an
application using the library (application crash).
in version 0.10-2+deb8u1.
version 0.16-1+deb9u1.
For the testing distribution (buster), this problem has been fixed
in version 2.0.2-4.
version 2.0.2-4.
#1331 OFFLINE   sunrat
sunrat
  • 5,323 posts
Posted 06 October 2017 - 06:55 PM
Debian Security Advisory DSA-3989-1                   security@debian.org
October 02, 2017                      https://www.debian.org/security/faq
Package        : dnsmasq
CVE ID         : CVE-2017-14491 CVE-2017-14492 CVE-2017-14493 CVE-2017-14494
                 CVE-2017-14495 CVE-2017-14496
Felix Wilhelm, Fermin J. Serna, Gabriel Campana, Kevin Hamacher, Ron
Bowes and Gynvael Coldwind of the Google Security Team discovered
several vulnerabilities in dnsmasq, a small caching DNS proxy and
DHCP/TFTP server, which may result in denial of service, information
leak or the execution of arbitrary code.
in version 2.72-3+deb8u2.
version 2.76-5+deb9u1.
Debian Security Advisory DSA-3990-1                   security@debian.org
October 03, 2017                      https://www.debian.org/security/faq
Package        : asterisk
CVE ID         : CVE-2017-14603
Klaus-Peter Junghann discovered that insufficient validation of RTCP
packets in Asterisk may result in an information leak. Please see the
upstream advisory at
http://downloads.ast...T-2017-008.html for
additional details.
in version 1:11.13.1~dfsg-2+deb8u4.
version 1:13.14.1~dfsg-2+deb9u2.
Debian Security Advisory DSA-3991-1                   security@debian.org
Package        : qemu
CVE ID         : CVE-2017-9375 CVE-2017-12809 CVE-2017-13672 CVE-2017-13711
                 CVE-2017-14167
Multiple vulnerabilities were found in in qemu, a fast processor emulator:
CVE-2017-9375
    Denial of service via memory leak in USB XHCI emulation.
CVE-2017-12809
    Denial of service in the CDROM device drive emulation.
CVE-2017-13672
    Denial of service in VGA display emulation.
CVE-2017-13711
    Denial of service in SLIRP networking support.
CVE-2017-14167
    Incorrect validation of multiboot headers could result in the
version 1:2.8+dfsg-6+deb9u3.
Debian Security Advisory DSA-3992-1                   security@debian.org
October 06, 2017                      https://www.debian.org/security/faq
Package        : curl
CVE ID         : CVE-2017-1000100 CVE-2017-1000101 CVE-2017-1000254
Debian Bug     : 871554 871555 877671
Several vulnerabilities have been discovered in cURL, an URL transfer
library. The Common Vulnerabilities and Exposures project identifies the
following problems:
CVE-2017-1000100
    Even Rouault reported that cURL does not properly handle long file
    names when doing an TFTP upload. A malicious HTTP(S) server can take
    advantage of this flaw by redirecting a client using the cURL
    library to a crafted TFTP URL and trick it to send private memory
    contents to a remote server over UDP.
CVE-2017-1000101
    Brian Carpenter and Yongji Ouyang reported that cURL contains a flaw
    in the globbing function that parses the numerical range, leading to
    an out-of-bounds read when parsing a specially crafted URL.
CVE-2017-1000254
    Max Dymond reported that cURL contains an out-of-bounds read flaw in
    the FTP PWD response parser. A malicious server can take advantage
    of this flaw to effectively prevent a client using the cURL library
    to work with it, causing a denial of service.
in version 7.38.0-4+deb8u6.
version 7.52.1-5+deb9u1.
Debian Security Advisory DSA-3993-1                   security@debian.org
Package        : tor
CVE ID         : CVE-2017-0380
It was discovered that the Tor onion service could leak sensitive
information to log files if the "SafeLogging" option is set to "0".
The oldstable distribution (jessie) is not affected.
version 0.2.9.12-1.
#1332 OFFLINE   sunrat
sunrat
  • 5,323 posts
Posted 08 October 2017 - 06:18 PM
Debian Security Advisory DSA-3994-1                   security@debian.org
https://www.debian.org/security/                        Yves-Alexis Perez
October 07, 2017                      https://www.debian.org/security/faq
Package        : nautilus
CVE ID         : CVE-2017-14604
Debian Bug     : 860268
Christian Boxdörfer discovered a vulnerability in the handling of
FreeDesktop.org .desktop files in Nautilus, a file manager for the GNOME
desktop environment. An attacker can craft a .desktop file intended to run
malicious commands but displayed as a innocuous document file in Nautilus. An
user would then trust it and open the file, and Nautilus would in turn execute
the malicious content. Nautilus protection of only trusting .desktop files with
executable permission can be bypassed by shipping the .desktop file inside a
tarball.
For the oldstable distribution (jessie), this problem has not been fixed yet.
version 3.22.3-1+deb9u1.
in version 3.26.0-1.
version 3.26.0-1.
#1333 OFFLINE   sunrat
sunrat
  • 5,323 posts
Posted 11 October 2017 - 06:43 PM
Debian Security Advisory DSA-3995-1                   security@debian.org
October 10, 2017                      https://www.debian.org/security/faq
Package        : libxfont
CVE ID         : CVE-2017-13720 CVE-2017-13722
Two vulnerabilities were found in libXfont, the X11 font rasterisation
library, which could result in denial of service or memory disclosure.
in version 1:1.5.1-1+deb8u1.
version 1:2.0.1-3+deb9u1.
Debian Security Advisory DSA-3996-1                   security@debian.org
Package        : ffmpeg
CVE ID         : CVE-2017-14054 CVE-2017-14055 CVE-2017-14056
                 CVE-2017-14057 CVE-2017-14058 CVE-2017-14059
CVE-2017-14169 CVE-2017-14170 CVE-2017-14171
CVE-2017-14222 CVE-2017-14223 CVE-2017-14225
                 CVE-2017-14767
Several vulnerabilities have been discovered in the FFmpeg multimedia
framework, which could result in denial of service or potentially the
execution of arbitrary code if malformed Real, MV, RL2, ASF, Apple HLS,
Phantom Cine, MXF, NSV, MOV or RTP H.264 files/streams are processed.
version 7:3.2.8-1~deb9u1.
Debian Security Advisory DSA-3997-1                   security@debian.org
Package        : wordpress
CVE ID         : CVE-2017-14718 CVE-2017-14719 CVE-2017-14720 CVE-2017-14721
                 CVE-2017-14722 CVE-2017-14723 CVE-2017-14724 CVE-2017-14725
                 CVE-2017-14726 CVE-2017-14990
Debian Bug     : 876274 877629
Several vulnerabilities were discovered in Wordpress, a web blogging tool.
They would allow remote attackers to exploit path-traversal issues, perform SQL
injections and various cross-site scripting attacks.
in version 4.1+dfsg-1+deb8u15.
version 4.7.5+dfsg-2+deb9u1.
in version 4.8.2+dfsg-2.
Debian Security Advisory DSA-3998-1                   security@debian.org
October 11, 2017                      https://www.debian.org/security/faq
Package        : nss
CVE ID         : CVE-2017-7805
Martin Thomson discovered that nss, the Mozilla Network Security Service
library, is prone to a use-after-free vulnerability in the TLS 1.2
implementation when handshake hashes are generated. A remote attacker
can take advantage of this flaw to cause an application using the nss
library to crash, resulting in a denial of service, or potentially to
in version 2:3.26-1+debu8u3.
version 2:3.26.2-1.1+deb9u1.
in version 2:3.33-1.
version 2:3.33-1.
#1334 OFFLINE   sunrat
sunrat
  • 5,323 posts
Posted 16 October 2017 - 05:57 PM
Debian Security Advisory DSA-3999-1                   security@debian.org
October 16, 2017                      https://www.debian.org/security/faq
Package        : wpa
CVE ID         : CVE-2017-13077 CVE-2017-13078 CVE-2017-13079 CVE-2017-13080
                 CVE-2017-13081 CVE-2017-13082 CVE-2017-13086 CVE-2017-13087
                 CVE-2017-13088
Mathy Vanhoef of the imec-DistriNet research group of KU Leuven discovered
multiple vulnerabilities in the WPA protocol, used for authentication in
wireless networks. Those vulnerabilities applies to both the access point
(implemented in hostapd) and the station (implemented in wpa_supplicant).
An attacker exploiting the vulnerabilities could force the vulnerable system to
reuse cryptographic session keys, enabling a range of cryptographic attacks
against the ciphers used in WPA1 and WPA2.
More information can be found in the researchers's paper, Key Reinstallation
Attacks: Forcing Nonce Reuse in WPA2.
CVE-2017-13077: reinstallation of the pairwise key in the Four-way handshake
CVE-2017-13078: reinstallation of the group key in the Four-way handshake
CVE-2017-13079: reinstallation of the integrity group key in the Four-way
                handshake
CVE-2017-13080: reinstallation of the group key in the Group Key handshake
CVE-2017-13081: reinstallation of the integrity group key in the Group Key
                handshake
CVE-2017-13082: accepting a retransmitted Fast BSS Transition Reassociation
                Request and reinstalling the pairwise key while processing it
CVE-2017-13086: reinstallation of the Tunneled Direct-Link Setup (TDLS) PeerKey
                (TPK) key in the TDLS handshake
CVE-2017-13087: reinstallation of the group key (GTK) when processing a
                Wireless Network Management (WNM) Sleep Mode Response frame
CVE-2017-13088: reinstallation of the integrity group key (IGTK) when
                processing a Wireless Network Management (WNM) Sleep Mode
                Response frame
in version 2.3-1+deb8u5.
version 2:2.4-1+deb9u1.
in version 2:2.4-1.1.
version 2:2.4-1.1.
#1335 OFFLINE   sunrat
sunrat
  • 5,323 posts
Posted 19 October 2017 - 06:25 PM
Debian Security Advisory DSA-4000-1                   security@debian.org
October 17, 2017                      https://www.debian.org/security/faq
Package        : xorg-server
CVE ID         : CVE-2017-12176 CVE-2017-12177 CVE-2017-12178 CVE-2017-12179
                 CVE-2017-12180 CVE-2017-12181 CVE-2017-12182 CVE-2017-12183
                 CVE-2017-12184 CVE-2017-12185 CVE-2017-12186 CVE-2017-12187
                 CVE-2017-13721 CVE-2017-13723
Several vulnerabilities have been discovered in the X.Org X server. An
attacker who's able to connect to an X server could cause a denial of
service or potentially the execution of arbitrary code.
in version 2:1.16.4-1+deb8u2.
version 2:1.19.2-1+deb9u2.
Debian Security Advisory DSA-4001-1                   security@debian.org
https://www.debian.org/security/                       Sebastien Delafond
October 19, 2017                      https://www.debian.org/security/faq
Package        : yadifa
CVE ID         : CVE-2017-14339
Debian Bug     : 876315
It was discovered that YADIFA, an authoritative DNS server, did not
sufficiently check its input. This allowed a remote attacker to cause
a denial-of-service by forcing the daemon to enter an infinite loop.
version 2.2.3-1+deb9u1.
Debian Security Advisory DSA-4002-1                   security@debian.org
Package        : mysql-5.5
CVE ID         : CVE-2017-10268 CVE-2017-10378 CVE-2017-10379 CVE-2017-10384
Debian Bug     : 878402
Several issues have been discovered in the MySQL database server. The
vulnerabilities are addressed by upgrading MySQL to the new upstream
version 5.5.58, which includes additional changes, such as performance
improvements, bug fixes, new features, and possibly incompatible
changes. Please see the MySQL 5.5 Release Notes and Oracle's Critical
Patch Update advisory for further details:
https://dev.mysql.co...ews-5-5-58.html
http://www.oracle.co...17-3236626.html
in version 5.5.58-0+deb8u1.
Debian Security Advisory DSA-4003-1                   security@debian.org
Package        : libvirt
CVE ID         : CVE-2017-1000256
Debian Bug     : 878799
Daniel P. Berrange reported that Libvirt, a virtualisation abstraction
library, does not properly handle the default_tls_x509_verify (and
related) parameters in qemu.conf when setting up TLS clients and servers
in QEMU, resulting in TLS clients for character devices and disk devices
having verification turned off and ignoring any errors while validating
the server certificate.
More informations in https://security.lib.../2017/0002.html .
version 3.0.0-4+deb9u1.
version 3.8.0-3.
#1336 OFFLINE   sunrat
sunrat
  • 5,323 posts
Posted 20 October 2017 - 05:41 PM
Debian Security Advisory DSA-4004-1                   security@debian.org
October 20, 2017                      https://www.debian.org/security/faq
Package        : jackson-databind
CVE ID         : CVE-2017-7525
Debian Bug     : 870848
Liao Xinxi discovered that jackson-databind, a Java library used to
parse JSON and other data formats, did not properly validate user
input before attemtping deserialization. This allowed an attacker to
perform code execution by providing maliciously crafted input.
in version 2.4.2-2+deb8u1.
version 2.8.6-1+deb9u1.
Debian Security Advisory DSA-4005-1                   security@debian.org
Package        : openjfx
CVE ID         : CVE-2017-10086 CVE-2017-10114
Two unspecified vulnerabilities were discovered in OpenJFX, a rich client
application platform for Java.
version 8u141-b14-3~deb9u1.
Also tagged with one or more of these keywords: debian, updates, sunrat, bruno, v.t. eric layton
