samba problems , again! argh!!
samba
1 reply to this topic
#1 OFFLINE   crp
crp
  • 3,065 posts
Posted 17 May 2015 - 08:40 PM
samba 3.6.6 on Debian Wheezy.
Trying to join the machine to a Windows2008r2 AD.
the machine is currently serving as fileserver for some users.
tried net join  -U duper%5HaveLefT -d5
debug results:
INFO: Current debug levels:
  all: 5
  tdb: 5
  printdrivers: 5
  lanman: 5
  smb: 5
  rpc_parse: 5
  rpc_srv: 5
  rpc_cli: 5
  passdb: 5
  sam: 5
  auth: 5
  winbind: 5
  vfs: 5
  idmap: 5
  quota: 5
  acls: 5
  locking: 5
  msdfs: 5
  dmapi: 5
  registry: 5
lp_load_ex: refreshing parameters
Initialising global parameters
rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
  all: 5
  tdb: 5
  printdrivers: 5
  lanman: 5
  smb: 5
  rpc_parse: 5
  rpc_srv: 5
  rpc_cli: 5
  passdb: 5
  sam: 5
  auth: 5
  winbind: 5
  vfs: 5
  idmap: 5
  quota: 5
  acls: 5
  locking: 5
  msdfs: 5
  dmapi: 5
  registry: 5
params.c:pm_process() - Processing configuration file "/etc/samba/smb.conf"
Processing section "[global]"
doing parameter idmap gid = 16777216-33554431
WARNING: The "idmap gid" option is deprecated
doing parameter passwd chat = *New*password* %n\n *ReType*new*password* %n\n *passwd*changed*\n
doing parameter obey pam restrictions = yes
doing parameter preserve case = yes
doing parameter delete user from group script = /usr/sbin/userdel '%u' '%g'
doing parameter time server = no
doing parameter dns proxy = no
doing parameter netbios name = CCSOO
handle_netbios_name: set global_myname to: CCSOO
doing parameter cups options = raw
doing parameter printing = lprng
doing parameter idmap uid = 16777216-33554431
WARNING: The "idmap uid" option is deprecated
doing parameter disable netbios = no
doing parameter logon script = %G.bat
doing parameter winbind refresh tickets = no
doing parameter security = ADS
doing parameter machine password timeout = 120
doing parameter add machine script = /usr/sbin/useradd -d /dev/null -g sambamachines -c 'Samba Machine Account' -s /dev/null -M '%u'
doing parameter short preserve case = yes
doing parameter delete user script = /usr/sbin/userdel '%u'
doing parameter server schannel = no
doing parameter max log size = 1000
doing parameter winbind nss info = no
doing parameter log file = /var/log/samba/samba.log
doing parameter printer = Aficio-MP-4500
doing parameter load printers = yes
doing parameter guest account = smbguest
doing parameter passwd chat timeout = 120
doing parameter delete group script = /usr/sbin/groupdel '%g'
doing parameter username level = 6
doing parameter socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
doing parameter wins server = 192.168.1.218
doing parameter client use spnego = no
doing parameter follow symlinks = no
doing parameter null passwords = no
WARNING: The "null passwords" option is deprecated
doing parameter domain master = no
doing parameter winbind trusted domains only = yes
doing parameter winbind use default domain = yes
doing parameter passdb backend = tdbsam
doing parameter template shell = /dev/null
doing parameter client plaintext auth = no
doing parameter bind interfaces only = yes
doing parameter pam password change = no
doing parameter enable spoolss = yes
doing parameter domain logons = yes
doing parameter name resolve order = wins lmhosts bcast
doing parameter client signing = yes
doing parameter hostname lookups = no
doing parameter remote browse sync = 192.168.102.255
doing parameter client schannel = no
doing parameter passwd program = /usr/bin/passwd '%u'
doing parameter allow hosts = 127. 192.168.102. 192.168.1.
doing parameter remote announce = 192.168.102.255 192.168.1.255
doing parameter local master = no
doing parameter realm = fask.COM
doing parameter workgroup = fask
doing parameter os level = 33
doing parameter server signing = no
doing parameter printcap name = cups
doing parameter winbind separator = @
doing parameter winbind offline logon = yes
doing parameter allow trusted domains = yes
doing parameter add group script = /usr/sbin/groupadd '%g'
doing parameter nt pipe support = yes
doing parameter add user to group script = /usr/sbin/useradd -d /dev/null -c 'Samba User Account' -s /dev/null -g '%g' '%u'
doing parameter nt status support = yes
doing parameter logon drive = m:
doing parameter interfaces = 127.0.0.1/8 192.168.102.0/24
doing parameter username map = /etc/samba/smbusers
doing parameter encrypt passwords = yes
doing parameter public = yes
doing parameter logon home = \\%L\homes\%u
doing parameter wins proxy = no
doing parameter password level = 6
WARNING: The "password level" option is deprecated
doing parameter server string = Occidentel server
doing parameter winbind nested groups = no
doing parameter unix password sync = yes
doing parameter logon path = \\%L\profiles\%u
doing parameter add user script = /usr/sbin/useradd -d /dev/null -c 'Samba User Account' -s /dev/null '%u'
doing parameter preferred master = no
doing parameter winbind cache time = 360
pm_process() returned Yes
Substituting charset 'UTF-8' for LOCALE
Netbios name list:-
my_netbios_names[0]="CCSOO"
interpret_interface: Adding interface 127.0.0.1/8
added interface 127.0.0.1/8 ip=127.0.0.1 bcast=127.255.255.255 netmask=255.0.0.0
interpret_interface: using netmask value 24 from config file on interface eth0
added interface eth0 ip=192.168.102.251 bcast=192.168.102.255 netmask=255.255.255.0
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
Opening cache file at /var/run/samba/gencache.tdb
Opening cache file at /var/run/samba/gencache_notrans.tdb
sitename_fetch: Returning sitename for fask.COM: "Default-First-Site-Name"
saf_fetch: failed to find server for "fask.COM" domain
get_dc_list: preferred server list: ", *"
name fask.COM#1C found.
get_dc_list: returning 1 ip addresses in an ordered list
get_dc_list: 192.168.1.218:389
ads_try_connect: sending CLDAP request to 192.168.1.218 (realm: fask.COM)
Successfully contacted LDAP server 192.168.1.218
Invalid configuration.  Exiting....
ADS join did not work, falling back to RPC...
name fask#1B found.
namecache_status_fetch: key NBT/fask#1B.20.192.168.1.218 -> fask-SERVER01
Connecting to host=fask-SERVER01
Connecting to 192.168.1.218 at port 445
Connecting to 192.168.1.218 at port 139
Socket options:
	SO_KEEPALIVE = 0
	SO_REUSEADDR = 0
	SO_BROADCAST = 0
	TCP_NODELAY = 1
	TCP_KEEPCNT = 9
	TCP_KEEPIDLE = 7200
	TCP_KEEPINTVL = 75
	IPTOS_LOWDELAY = 0
	IPTOS_THROUGHPUT = 0
	SO_SNDBUF = 16384
	SO_RCVBUF = 16384
	SO_SNDLOWAT = 1
	SO_RCVLOWAT = 1
	SO_SNDTIMEO = 0
	SO_RCVTIMEO = 0
	TCP_QUICKACK = 1
Bind RPC Pipe: host fask-SERVER01 auth_type 0, auth_level 1
rpc_api_pipe: host fask-SERVER01
rpc_read_send: data_to_read: 52
check_bind_response: accepted!
rpc_read_send: data_to_read: 32
rpc_read_send: data_to_read: 80
rpc command function failed! (NT_STATUS_NOT_SUPPORTED)
name fask#1B found.
Socket options:
	SO_KEEPALIVE = 0
	SO_REUSEADDR = 0
	SO_BROADCAST = 0
	TCP_NODELAY = 1
	TCP_KEEPCNT = 9
	TCP_KEEPIDLE = 7200
	TCP_KEEPINTVL = 75
	IPTOS_LOWDELAY = 0
	SO_SNDBUF = 16384
	SO_RCVBUF = 16384
	SO_SNDLOWAT = 1
	SO_RCVLOWAT = 1
	SO_SNDTIMEO = 0
	SO_RCVTIMEO = 0
	TCP_QUICKACK = 1
cli_session_setup: NT1 session setup failed: NT_STATUS_INVALID_PARAMETER
failed session setup with NT_STATUS_INVALID_PARAMETER
Could not connect to server fask-SERVER01
Connection failed: NT_STATUS_INVALID_PARAMETER
return code = 1
i've so far spent hours looking for solutions but have come up empty. Anyone here able to figure out what the problem is?
#2 OFFLINE   securitybreach
  • 23,331 posts
Posted 19 May 2015 - 01:18 PM
Sorry man I have not used Samba in almost a decade as I do not network windows machines with Linux very much and when I do, I use NFS along with Window's Unix services.
https://technet.micr...y/cc732891.aspx
Also tagged with one or more of these keywords: samba
