Guest LilBambi Posted September 21, 2013 Share Posted September 21, 2013 The streams crossed: Mixpanel shows iOS 7 adoption rate now surpasses iOS 6 - tuaw Quote Link to comment Share on other sites More sharing options...
ross549 Posted September 21, 2013 Share Posted September 21, 2013 That's insane. Adam Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted September 30, 2013 Share Posted September 30, 2013 I upgraded to iOS 7 on my 4S and it's working very well. I like much of it, dislike some of it. But overall, it's worked out well so far. Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted October 24, 2013 Share Posted October 24, 2013 Even people who don't connect their computers have upgraded to iOS 7 with no issues. However, I have had some oddities with iOS 7 since I upgraded. Mail app crashes frequently Some Apps crash more frequently than before Sometimes the phone itself will lock up and I will have to restart it - (happens MUCH more than with iOS 6) Some things that were expected with upgrading to iOS 7 on a 4S: Battery time is greatly reduced - have to charge the phone much more frequently. Quote Link to comment Share on other sites More sharing options...
ross549 Posted October 24, 2013 Share Posted October 24, 2013 It may be beneficial to do a full backup, restore and restore from backup. I have found that upgrading in place does not seem to do as well as it could. My sister has an iPhone 4, and she has said it is slower now. If you are having battery issues, I would recommend at looking into background app refresh and see if you can shut some non-essentials off. That background refreshing wakes up the radio which would be a big factor in the reduction of battery life. Adam Quote Link to comment Share on other sites More sharing options...
Guest LilBambi Posted October 27, 2013 Share Posted October 27, 2013 Yes, believe it or not, I turn off wifi, bluetooth, and close apps (backgrounded) often, also went into background app refresh area in the settings to turn off all I didn't need to have on there too. I did that the first day I had it upgraded. Even with all that, it is still not what it was before the upgrade. But I went in knowing that would be the case. It's not bad, don't get me wrong. It's just no where near as good as it was with iOS 6. Since I did the full upgrade via iTunes to 7.0.3, things have been MUCH more stable ... so far. It was 7.0.2 that was the problem, I think. It was not flaky when I first upgrade to iOS 7, but started to be after upgrading (full upgrade via iTunes that time too) to 7.0.2. So I am happy. It is working great now. Let's hope it stays that way! Quote Link to comment Share on other sites More sharing options...
