abarbarian Posted February 15, 2015 Share Posted February 15, 2015 (edited) On my fresh install of Arch FF has been buggy since I installed. This has happened before I installed any add-ons and after I installed add-ons. FF takes about five seconds to fire up, that is whether it is being buggy or not.This is a very long start up time for my pc and set up.Last time I ran Arch FF started very quickly on this same pc. FF would freeze sometimes with content showing and sometimes with just a white page showing. Also it would not close down with the usual top right button.Closing them via the dock icon works though. I ran top to see what was going on. Can anyone tell me why I have three USERS showing in top ? As you can see it seems there are two FF's running.If I try to kill them they do not go away always. If I close FF via the dock item they still show up on top. Here is a shot of FF running properly. As you can see only one FF and it is using less memory and cpu than before.I must have gremlins in the pc as it is hit or miss if FF behaves. All other programs seem to work very well including mpv and vlc. Any ideas as to what is going on folks ?? Edited February 15, 2015 by abarbarian Quote Link to comment Share on other sites More sharing options...
ebrke Posted February 15, 2015 Share Posted February 15, 2015 (edited) Well, your 3 users would be yourself, root, and dbus. FF always takes 3 to 5 seconds to start on both my machines, but that's not new for me, so no help to you. I found a few very vague things at this link, but nothing definitive: http://kb.mozillazin...g/Firefox_hangs Hope someone comes along with some ideas. Edited February 15, 2015 by ebrke Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted February 15, 2015 Share Posted February 15, 2015 Solution to Firefox problems --> Chromium/Chrome. 1 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 15, 2015 Author Share Posted February 15, 2015 Well, your 3 users would be yourself, root, and dbus. FF always takes 3 to 5 seconds to start on both my machines, but that's not new for me, so no help to you. I found a few very vague things at this link, but nothing definitive: http://kb.mozillazin...g/Firefox_hangs Hope someone comes along with some ideas. Ta. Top on my pc usually shows two users. I installed chromium and it froze on me too after a while. We just had a x-org update in Arch and that seems to have solved the problem.If only it had come sooner, would;d have saved me uninstalling FF and reinstalling and dumping add-ons that may not have been involved etc etc. Hey ho at least I have my usual pc set up, sort of working in some mysterious fashion. 2 Quote Link to comment Share on other sites More sharing options...
ebrke Posted February 16, 2015 Share Posted February 16, 2015 Well, your 3 users would be yourself, root, and dbus. FF always takes 3 to 5 seconds to start on both my machines, but that's not new for me, so no help to you. I found a few very vague things at this link, but nothing definitive: http://kb.mozillazin...g/Firefox_hangs Hope someone comes along with some ideas. Ta. Top on my pc usually shows two users. I'd guess that that dbus daemon isn't always running, so you're at 2 users. That's what I see usually. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted February 16, 2015 Share Posted February 16, 2015 Dbus should always be running as: D-Bus is enabled automatically when using systemd because dbus is a dependency of systemd. https://wiki.archlin...index.php/D-Bus I wouldn't pay attention to the amount of users as top counts every instance of root and user. I just checked and mine shows 15 users even though it only root and user: If you are worried about it, I would suggest using htop or glances as they provide better info than top imo. Glad to hear that the new Xorg fixed your issue but I am kind of skeptical as the update didn't come with anything related to that. The new version comes with the following changes: following ustream, xf86-video-modesetting is now provided with xorg-server package. These packages are deprecated and moved to AUR, some are replaced by modesetting driver: xf86-video-ast, xf86-video-cirrus, xf86-video-geode, xf86-video-mga, xf86-video-sisimedia, xf86-video-v4l] Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 16, 2015 Author Share Posted February 16, 2015 OK folks thanks for the help and info. No idea why the pc is behaving itself but is definitely better after that x-org update. Maybe the update re set some config or some such.Like I said I am happy that it seems to work ok. 1 Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted February 16, 2015 Share Posted February 16, 2015 It was FM (fsckin' magic), maybe? Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 16, 2015 Author Share Posted February 16, 2015 It was FM (fsckin' magic), maybe? Aye I seem to use a lot of that. 1 Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted February 16, 2015 Share Posted February 16, 2015 It was FM (fsckin' magic), maybe? Aye I seem to use a lot of that. Whatever works. 1 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 16, 2015 Author Share Posted February 16, 2015 (edited) Well it ain't fixed. It was working ok for a couple of hours and then Any ideas folks ?? :'( An more bafflement, increased memory decreased cpu.Oooooops look like I forgot to include the picture here. Edited February 17, 2015 by abarbarian Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted February 17, 2015 Share Posted February 17, 2015 I had so many memory and cpu issues with FF the last year or so; it's why I went to Chromium full time. Just got tired of FF's hoggish behaviors. You could try running FF in safe mode and see how it behaves. Or you could disable your extensions/plugins one-by-one to find the one that's causing problems. Or you could wipe your FF profile directory and start fresh with a newly installed FF. I tried all of those and never did resolve my FF issues. 1 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 17, 2015 Author Share Posted February 17, 2015 Ta Eric. I deleted all the FF folders and files I could find after I uninstalled it and did a fresh install. Srill the same multiple FF's showwing in htop. Progress however as it seems I can now watch some videos on-line like this, http://www.freemoviescinema.com/animation/220-codehunters-2007-astonishing-capsule-anime-film Not all videos are watchable on all sites though. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted February 17, 2015 Share Posted February 17, 2015 I am with Eric, I left FireFox for Chrome/Chromium years ago as FF became a buggy mess. There were always memory leaks and high cpu usage with FF, so I left it alone and never looked back. Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted February 17, 2015 Share Posted February 17, 2015 Looks like you'll be needing some more of that FM, matey. 1 Quote Link to comment Share on other sites More sharing options...
sunrat Posted February 18, 2015 Share Posted February 18, 2015 I find Chrome uses way more memory than FF especially if you have a lot of tabs open. Chrome starts a new process for each tab. IMO they are both OK, and I do use both for different things, eg. Chrome is better for Google spreadsheet editing. 1 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 20, 2015 Author Share Posted February 20, 2015 Well I found this, https://addons.mozilla.org/en-US/firefox/addon/open-livestreamer/# http://livestreamer.tanuki.se/en/latest/cli.html#cli-livestreamerrc https://www.archlinux.org/packages/community/any/livestreamer/ Which is Livestreamer with a FF add-on using mpv. So I installed it and set it up by creating a "~/.livestreamerrc" like this, # Player optionsplayer=mpv --cache 2048 player-no-close player-continuous-http ringbuffer-size 30M No idea if it works as all the sites I have tried to play video on seem to work now, I guess with HTML5 as they work with Livestreamer disabled or enabled. So I seem to have video on the web with out Adobe. When I play video in FF I still have multiple FF's showing in htop but now they are using cpu wheras not playing video multople FF's show but do not use so much cpu. Bafled I am but at least I can watch vids on the net. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted February 20, 2015 Share Posted February 20, 2015 http://www.linuxatemyram.com/ Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 26, 2015 Author Share Posted February 26, 2015 Looks like top and htop report things differently. I get the linuxatemyram bit but why is htop showing FF as using cpu on multiple instances. By the way FF seems to be running much better since xorg stuff has and some updates here in archland. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted February 26, 2015 Share Posted February 26, 2015 I get the linuxatemyram bit but why is htop showing FF as using cpu on multiple instances. Those are probably threads. Enable "Hide user threads" in Setup -> Display Options and those should go away. Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted February 26, 2015 Share Posted February 26, 2015 Erik, life's too short, mate. Let it go... 1 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 26, 2015 Author Share Posted February 26, 2015 I get the linuxatemyram bit but why is htop showing FF as using cpu on multiple instances. Those are probably threads. Enable "Hide user threads" in Setup -> Display Options and those should go away. Neat I have never got around to exploring the set up options. I have a clock and less FF's now. 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted February 27, 2015 Share Posted February 27, 2015 There is a version of htop in the AUR called htop-temperature https://aur.archlinu...op-temperature/ that lets you display your processor temperatures in htop: Look at bottom of the top right. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 27, 2015 Author Share Posted February 27, 2015 Well I can not get any changes to stick. Htop does not have any config files on home,has an empty folder in ~/.config. Htop-temperature has a ~/.config but changes I make do not stick. An the temperature feature shows a title but no temps. :'( Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 27, 2015 Author Share Posted February 27, 2015 Managed to get some changes to stick by altering the config file. That is enough fiddling with stuff that does not work properly for now. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 28, 2015 Author Share Posted February 28, 2015 Bizarrely I do not seem to have FF running according to htop. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted February 28, 2015 Share Posted February 28, 2015 Did you search for it? F3 and type firefox It's probably just further down in the list Quote Link to comment Share on other sites More sharing options...
abarbarian Posted February 28, 2015 Author Share Posted February 28, 2015 Ain't down the list as you can tell from the picture. FF seems to have adopted the features of a Tardis. It keeps popping in and out of the picture I made a few changes to the htop config file which showed up when I installed the Temp version maybe that has something to do with it. # Beware! This file is rewritten by htop when settings are changed in the interface.# The parser is also very primitive, and not human-friendly. fields=0 48 17 18 38 39 40 2 46 47 49 1 sort_key=46 sort_direction=1 hide_threads=0 hide_kernel_threads=1 hide_userland_threads=1 shadow_other_users=0 show_thread_names=1 highlight_base_name=1 highlight_megabytes=0 highlight_threads=1 tree_view=0 header_margin=1 detailed_cpu_time=0 cpu_count_from_zero=0 update_process_names=0 account_guest_in_cpu_meter=0 color_scheme=0 delay=15 left_meters=AllCPUs Memory Swap left_meter_modes=1 1 1 right_meters=Tasks LoadAverage Uptime Temperature Clock right_meter_modes=2 2 2 2 4 You know me I just can not resist fiddling. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted March 1, 2015 Author Share Posted March 1, 2015 Fiddled with the config of htop again, I think the results are neat meself. 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted March 2, 2015 Share Posted March 2, 2015 Where is the temperature value? Quote Link to comment Share on other sites More sharing options...
