mhbell Posted May 22, 2017 Share Posted May 22, 2017 Just downloaded and installed on Vbox OB Revenge based on Arch. it uses the Calamares Installer. It is kind of Neat. It has a menu on the background telling what key combinations to use for different things. Mel 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 22, 2017 Share Posted May 22, 2017 Interesting, I will have to check it out in virt/qemu. Does it use custom repos with AUR enabled or vanilla sources? Basically is it simply an installer for Archlinux or is there more. I seen a mention of the Revenge tool. Quote Link to comment Share on other sites More sharing options...
saturnian Posted May 22, 2017 Share Posted May 22, 2017 DistroWatch review from February: https://www.distrowatch.com/weekly.php?issue=20170227 Like securitybreach, I'm wondering about the repos. 1 Quote Link to comment Share on other sites More sharing options...
saturnian Posted May 22, 2017 Share Posted May 22, 2017 mhbell (or anyone else who has OBRevenge up and running), would you mind posting the contents of the /etc/pacman.conf file? Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 22, 2017 Share Posted May 22, 2017 I will when I get home but it will be about 6 hours from now as I am at work. I downloaded it this morning to try out in a VM. Quote Link to comment Share on other sites More sharing options...
mhbell Posted May 22, 2017 Author Share Posted May 22, 2017 I tried to copy and paste it, but it won't paste. Mel /etc/pacman.conf Quote Link to comment Share on other sites More sharing options...
mhbell Posted May 22, 2017 Author Share Posted May 22, 2017 (edited) I finally got it to work. I had to edit it in Leafpad and then copy and paste in this post. while in Vbox. Mel # # /etc/pacman.conf # # See the pacman.conf(5) manpage for option and repository directives # # GENERAL OPTIONS # [options] # The following paths are commented out with their default values listed. # If you wish to use different paths, uncomment and update the paths. #RootDir = / #DBPath = /var/lib/pacman/ #CacheDir = /var/cache/pacman/pkg/ #LogFile = /var/log/pacman.log #GPGDir = /etc/pacman.d/gnupg/ HoldPkg = pacman glibc #XferCommand = /usr/bin/curl -C - -f %u > %o #XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u #CleanMethod = KeepInstalled #UseDelta = 0.7 Architecture = auto # Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup #IgnorePkg = #IgnoreGroup = #NoUpgrade = #NoExtract = # Misc options #UseSyslog Color ILoveCandy #TotalDownload # We cannot check disk space from within a chroot environment #CheckSpace #VerbosePkgLists # By default, pacman accepts packages signed by keys that its local keyring # trusts (see pacman-key and its man page), as well as unsigned packages. SigLevel = Required DatabaseOptional LocalFileSigLevel = Optional #RemoteFileSigLevel = Required # NOTE: You must run `pacman-key --init` before first using pacman; the local # keyring can then be populated with the keys of all official Arch Linux # packagers with `pacman-key --populate archlinux`. # # REPOSITORIES # - can be defined here or included from another file # - pacman will search repositories in the order defined here # - local/custom mirrors can be added here or in separate files # - repositories listed first will take precedence when packages # have identical names, regardless of version number # - URLs will have $repo replaced by the name of the current repo # - URLs will have $arch replaced by the name of the architecture # # Repository entries are of the format: # [repo-name] # Server = ServerName # Include = IncludePath # # The header [repo-name] is crucial - it must be present and # uncommented to enable the repo. # # The testing repositories are disabled by default. To enable, uncomment the # repo name header and Include lines. You can add preferred servers immediately # after the header, and they will be used before the default mirrors. #[testing] #Include = /etc/pacman.d/mirrorlist [core] Include = /etc/pacman.d/mirrorlist [extra] Include = /etc/pacman.d/mirrorlist #[community-testing] #Include = /etc/pacman.d/mirrorlist [community] Include = /etc/pacman.d/mirrorlist [revenge_repo] SigLevel = Optional TrustAll Server = https://raw.github.c...po/master/$arch Server = https://downloads.so...enge_repo/$arch Server = ftp://ftp.heanet.ie/mirrors/sourceforge/r/re/revenge-repo/revenge_repo/$arch [multilib] Include = /etc/pacman.d/mirrorlist # An example of a custom package repository. See the pacman manpage for # tips on creating your own repositories. #[custom] #SigLevel = Optional TrustAll #Server = file:///home/custompkgs Edited May 22, 2017 by mhbell 1 Quote Link to comment Share on other sites More sharing options...
raymac46 Posted May 22, 2017 Share Posted May 22, 2017 Sort of looks like the Antergos model - use the Arch repos mostly and have a separate Revenge repo for specific needs/features. Quote Link to comment Share on other sites More sharing options...
saturnian Posted May 22, 2017 Share Posted May 22, 2017 Yep. Except in my Antergos installation, the default had the antergos repo above the core, extra, and community repos. I've since moved the antergos repo to the end, like where the revenge_repo is there. Hm, Antergos also had multilib enabled, but I commented that one out. Here's the default /etc/pacman.conf I had in Antergos: # # /etc/pacman.conf # # See the pacman.conf(5) manpage for option and repository directives # # GENERAL OPTIONS # [options] # The following paths are commented out with their default values listed. # If you wish to use different paths, uncomment and update the paths. #RootDir = / #DBPath = /var/lib/pacman/ #CacheDir = /var/cache/pacman/pkg/ #LogFile = /var/log/pacman.log #GPGDir = /etc/pacman.d/gnupg/ #HookDir = /etc/pacman.d/hooks/ HoldPkg = pacman glibc #XferCommand = /usr/bin/curl -C - -f %u > %o #XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u #CleanMethod = KeepInstalled #UseDelta = 0.7 Architecture = auto # Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup #IgnorePkg = #IgnoreGroup = #NoUpgrade = #NoExtract = # Misc options #UseSyslog #Color #TotalDownload CheckSpace #VerbosePkgLists # By default, pacman accepts packages signed by keys that its local keyring # trusts (see pacman-key and its man page), as well as unsigned packages. SigLevel = Required DatabaseOptional LocalFileSigLevel = Optional #RemoteFileSigLevel = Required # NOTE: You must run `pacman-key --init` before first using pacman; the local # keyring can then be populated with the keys of all official Arch Linux # packagers with `pacman-key --populate archlinux`. # # REPOSITORIES # - can be defined here or included from another file # - pacman will search repositories in the order defined here # - local/custom mirrors can be added here or in separate files # - repositories listed first will take precedence when packages # have identical names, regardless of version number # - URLs will have $repo replaced by the name of the current repo # - URLs will have $arch replaced by the name of the architecture # # Repository entries are of the format: # [repo-name] # Server = ServerName # Include = IncludePath # # The header [repo-name] is crucial - it must be present and # uncommented to enable the repo. # # The testing repositories are disabled by default. To enable, uncomment the # repo name header and Include lines. You can add preferred servers immediately # after the header, and they will be used before the default mirrors. #[antergos-staging] #SigLevel = PackageRequired #Server = [url="http://mirrors.antergos.com/$repo/$arch/"]http://mirrors.anter...om/$repo/$arch/[/url] [antergos] SigLevel = PackageRequired Include = /etc/pacman.d/antergos-mirrorlist #[testing] #Include = /etc/pacman.d/mirrorlist [core] Include = /etc/pacman.d/mirrorlist [extra] Include = /etc/pacman.d/mirrorlist #[community-testing] #Include = /etc/pacman.d/mirrorlist [community] Include = /etc/pacman.d/mirrorlist # If you want to run 32 bit applications on your x86_64 system, # enable the multilib repositories as required here. #[multilib-testing] #Include = /etc/pacman.d/mirrorlist [multilib] Include = /etc/pacman.d/mirrorlist # An example of a custom package repository. See the pacman manpage for # tips on creating your own repositories. #[custom] #SigLevel = Optional TrustAll #Server = file:///home/custompkgs Quote Link to comment Share on other sites More sharing options...
