nghump Posted February 17, 2005 Share Posted February 17, 2005 (edited) This may be an old question, if it is please direct me toward the resolution.I have purchase XP Professional. I want to backup the CD. There is one file that prevents me from making a viable copy. That file is BATANG.TT_. I can copy the entire CD except for this one file. Nero has identified this as a copyrighted file. My concern is that in repeatedly using this CD to load XP I may scratch it and have to purchase it again. I have actually loaded XP several times becuase I am trying to set a raid1 (mirrored) disk. I have not beem succesful as yet. Can someone direct me as to how I can make a useable backup of this CD?Thanks in advance for any help. Edited February 17, 2005 by nghump Quote Link to comment Share on other sites More sharing options...
nlinecomputers Posted February 17, 2005 Share Posted February 17, 2005 Nero should copy the disk just fine. It will tell you that copying the disk for anything other then a backup is illegal but it should copy it just fine. I use backups off all my disks in shop just for that reason. The file you show is just a font file in compressed form. Are you sure your disk isn't already damaged or perhaps dirty. You can clean it with lint free cloth using cirular motions so that you don't scratch across the tracks. Quote Link to comment Share on other sites More sharing options...
rbdietz Posted February 17, 2005 Share Posted February 17, 2005 (edited) You can clean it with lint free cloth using cirular motions so that you don't scratch across the tracks.<{POST_SNAPBACK}> The advice I've always seen says, 'do NOT clean CDs using a circular motion.'http://www.google.com/search?q=%2Bcd+clean...cular%22+motionEdited by Bob DietzAlso see more autoritive -National Institute of Standards and Technology (NIST):Care and Handling of CDs and DVDs —A Guide for Librarians and Archivists (50 pg PDF) (1 pg PDF summary) Edited February 17, 2005 by rbdietz Quote Link to comment Share on other sites More sharing options...
James M. Fisher Posted February 17, 2005 Share Posted February 17, 2005 I've never had a problem copying an XP disk (or any other disk for that matter). Are you doing a straight copy of the CD (the correct way), or are you copying the CD's files to your hard drive, then use burning software to create a CD (incorrect way)? Quote Link to comment Share on other sites More sharing options...
