securitybreach Posted October 23, 2014 Share Posted October 23, 2014 Changes to Intel microcode updates 2014-10-22 - Thomas Bächler Microcode on Intel CPUs is no longer loaded automatically, as it needs to be loaded very early in the boot process. This requires adjustments in the bootloader. If you have an Intel CPU, please follow the instructions in the wiki. https://www.archlinu...crocodeupdates/ 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted October 23, 2014 Author Share Posted October 23, 2014 Unless your running an Intel Haswell processor, you should not really worry about this. This is only for updating the firmware for your processor. Most people will not need to do anything at all. I have an i5 (ivybridge) and I do nto even have the intel-ucode installed. Quote Link to comment Share on other sites More sharing options...
saturnian Posted October 24, 2014 Share Posted October 24, 2014 From inxi -bA: CPU: Single core Intel Celeron 900 (-UP-) speed: 2194 MHz (max) So, I don't have to worry about it on this computer? Quote Link to comment Share on other sites More sharing options...
securitybreach Posted October 24, 2014 Author Share Posted October 24, 2014 After researching, it looks like only the (i5/i7) haswell line really needs microcode updates. I have an ivybridge i5 and I did not have intel-ucode installed so I didn't worry about it. Unless you have a known issue with your cpu, then you probably will not have to worry about updating your microcode. These microcode instructions are in a way the firmware of a CPU. The first version of the CPU-firmware you use is stored on your motherboard/bios. You can update the cpu-firmware by flashing your bios or by loading the latest version of CPU-microcode during every boot process. A regular user (like i am) usually won't notice the small bugfixes a microcode update applies. Please don't panic. Your machine won't die if your CPU-microcode is out of date! If you haven't used the intel-ucode package before you probably won't need it now. https://en.wikipedia.org/wiki/Haswell_(microarchitecture) 1 Quote Link to comment Share on other sites More sharing options...
saturnian Posted October 25, 2014 Share Posted October 25, 2014 thank you! Quote Link to comment Share on other sites More sharing options...
