saturnian Posted July 27, 2016 Share Posted July 27, 2016 Hm. I'm thinking maybe I should stop using packer in Arch... I went to pull in updates today and saw something I've never seen before: $ packer -Syu [sudo] password for steve: Before today, this is what I had been seeing: $ packer -Syu root Password: Now, when I get the sudo prompt, if I enter my user password I'm then asked for the root password, and then things proceed normally. If I press Enter instead of providing my user password at the sudo prompt, I get the sudo prompt again. So I press Enter again, and get the the sudo prompt again. I do this a third time, and then I get the root prompt! So I enter the root password, and things proceed normally: $ packer -Syu [sudo] password for steve: [sudo] password for steve: [sudo] password for steve: root Password: :: Synchronizing package databases... Not sure what's going on here, but this doesn't seem right. I think packer is broken (???). Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 27, 2016 Share Posted July 27, 2016 As far as I know packer has always asked for the user sudo password but something could of changed with your /etc/sudoers file as well, which would cause that. Personally I have been using pacaur for years without any issues and it only uses the root password (well besides when it runs makepkg). Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 27, 2016 Share Posted July 27, 2016 Of course, it depends on how your /etc/sudoers is setup as I have mine set to ask for the root password when I or an app invokes sudo: Quote Link to comment Share on other sites More sharing options...
saturnian Posted July 27, 2016 Author Share Posted July 27, 2016 This is so weird, because I've been updating with packer the same way all along, but I haven't seen that sudo prompt before. Well, back when I was kinda new to Arch I was getting root access with su and then running packer -Syu, but someone here corrected me on that, and since then I've been running packer -Syu as normal user and then entering the root password when prompted for it. I really don't even use sudo in Arch. My /etc/sudoers file was last modified 4-10-16. Prior to today, I last updated my Arch installation on 7-19-16. I didn't get the sudo prompt then. In /var/log/pacman.log I see: [2016-07-19 17:45] [ALPM] upgraded fakeroot (1.20.2-1 -> 1.21-1) Oh, and: [2016-07-19 17:46] [ALPM] upgraded sudo (1.8.16-1 -> 1.8.17.p1-1) Hm... Oh, and I have only one AUR package installed, by the way: # pacman -Qm packer 20160325-1 I guess in my case I probably have no need for packer or any other AUR helper... 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted July 28, 2016 Share Posted July 28, 2016 # pacman -Qm packer 20160325-1 I guess in my case I probably have no need for packer or any other AUR helper... If that the case, you do not need an AUR helper. Quote Link to comment Share on other sites More sharing options...
