John Paul Posted August 26, 2005 Share Posted August 26, 2005 (edited) I just got the PCLos 9 and burned it. During boot-up it spent about a minute going through variations of: khubd timed out ep0in and: khubd timed out ep0out .It eventually booted and works fine, but is there something that needs to be changed?Thanks,John Edited August 26, 2005 by John Paul Quote Link to comment Share on other sites More sharing options...
BarryB Posted August 26, 2005 Share Posted August 26, 2005 JohnDo your usb hubs function properly, I think there is an issue with internal usb hubs and modules with some of the 2.6 kernels.. Quote Link to comment Share on other sites More sharing options...
John Paul Posted August 26, 2005 Author Share Posted August 26, 2005 I didn't try any USB devices in while in Linux excpet I tried to setup the printers and it said it couldn't install whatever was needed.In PCLos 8 I used a USB memory stick just fine though. Thanks,John Quote Link to comment Share on other sites More sharing options...
linuxdude32 Posted August 27, 2005 Share Posted August 27, 2005 Does it take longer to bootup? Does the problem disappear if you have no USB devices connected? Probably nothing to worry about according to this post:http://www.mail-archive.com/linux-usb-user...t/msg13712.html Quote Link to comment Share on other sites More sharing options...
John Paul Posted August 27, 2005 Author Share Posted August 27, 2005 It does take longer to boot than PCLOS 8 did.The only USB devices connected were two printers and a USB HDD but none were on.Thanks,John Quote Link to comment Share on other sites More sharing options...
ikerekes Posted August 27, 2005 Share Posted August 27, 2005 I got those messages quite a bit until I figured that my via based mobo likes only the acpi=off nolapic boot code. (faulty bios) Quote Link to comment Share on other sites More sharing options...
