securitybreach Posted May 8, 2015 Share Posted May 8, 2015 Ok, I'll start: On Archlinux (obviously) running a Samsung 840 EVO SSD: comhack@Cerberus ~ % systemd-analyzeStartup finished in 2.296s (kernel) + 886ms (userspace) = 3.183s comhack@Cerberus ~ % systemd-analyze blame 17.083s updatedb.service 7.119s logrotate.service 4.642s man-db.service 1.232s pgl.service 289ms monitorix.service 241ms systemd-modules-load.service 228ms alsa-restore.service 228ms lm_sensors.service 226ms systemd-logind.service 223ms catalyst-hook.service 220ms dev-sda1.device 217ms network.service 216ms cpupower.service 216ms urxvtd@comhack.service 210ms systemd-user-sessions.service 132ms systemd-fsck@dev-disk-by\x2duuid-c30db2b6\x2d90d1\x2d41f1\x2d9d75\x2d6659c0fde970.service 127ms systemd-fsck@dev-disk-by\x2duuid-3067b591\x2d934e\x2d4c73\x2da4a7\x2de5d9da6c267a.service 114ms systemd-fsck@dev-disk-by\x2duuid-cb0d6b0f\x2d1c2a\x2d46c8\x2d99eb\x2dbbe4e1bcb1b5.service 95ms systemd-fsck@dev-disk-by\x2duuid-3fc84665\x2d73ed\x2d46ed\x2da4c6\x2d31d4ce2bc1b7.service 64ms backup2.mount 45ms systemd-fsck@dev-disk-by\x2duuid-7609a908\x2db7a1\x2d4242\x2dab4c\x2d3ee3cc538afb.service 44ms MEDIA.mount 43ms udisks2.service 36ms systemd-udevd.service 34ms Various.mount 32ms colord.service 26ms user@1000.service 25ms systemd-udev-trigger.service 24ms systemd-journald.service 22ms polkit.service 18ms backup.mount 18ms shadow.service 17ms systemd-tmpfiles-setup-dev.service 17ms systemd-vconsole-setup.service 17ms kmod-static-nodes.service 16ms systemd-fsck@dev-disk-by\x2duuid-86a184ad\x2d40b3\x2d46c3\x2db405\x2de7e06fb57ad6.service 16ms systemd-remount-fs.service 15ms systemd-tmpfiles-clean.service 14ms dev-hugepages.mount At one point, I was at a 1.8 second boot but I have added more drives and more services since then. These commands only work with systemd but since most distros use systemd, this shouldn't be an issue. That said, I do not know how this is done on sysinit but if anyone knows; feel free to post their boot stats too. Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 9, 2015 Share Posted May 9, 2015 vtel57@ericsbane06~:$ % systemd-analyze vtel57@ericsbane06~:$ wtf? -bash: fg: %: no such job 2 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 9, 2015 Author Share Posted May 9, 2015 Well Slackers are behind the times.... Heck even Debian has moved to the dark side 1 Quote Link to comment Share on other sites More sharing options...
sunrat Posted May 9, 2015 Share Posted May 9, 2015 roger@brain:~$ systemd-analyzeStartup finished in 3.738s (kernel) + 4.535s (userspace) = 8.274s My system is at least 5 years older than yours, SB. My SSD is OCZ Vertex2 120GB about 4 years old. A bit of system info would help to put it in context. roger@brain:~$ inxi -v 2 System: Host: brain Kernel: 4.0.1-towo.2-siduction-amd64 x86_64 (64 bit) Desktop: KDE 4.14.3 Distro: siduction 13.2.0 December - kde - (201312310241) Machine: Mobo: Gigabyte model: EP45-UD3R v: x.x Bios: Award v: F3 date: 09/18/2008 CPU: Dual core Intel Core2 Duo E8500 (-MCP-) speed/max: 2000/3166 MHz Graphics: Card: NVIDIA GF114 [GeForce GTX 560 Ti] Display Server: X.Org 1.16.4 drivers: nouveau (unloaded: fbdev,vesa) Resolution: 1920x1080@59.93hz GLX Renderer: Gallium 0.4 on NVCE GLX Version: 3.0 Mesa 10.4.2 Network: Card: Atheros TP-Link TL-WN821N v3 802.11n [Atheros AR7010+AR9287] driver: ath9k_htc Drives: HDD Total Size: 3595.7GB (52.4% used) ID-1: model: OCZ ID-2: model: WDC_WD1001FALS ID-3: model: WDC_WD3200KS ID-4: model: Elements_10B8 ID-5: model: MHW2160BH Info: Processes: 181 Uptime: 3 days Memory: 1239.5/3956.9MB Client: Shell (bash) inxi: 2.2.19 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 9, 2015 Author Share Posted May 9, 2015 8 seconds still isn't bad at all. Here is my inxi on this machine: Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 9, 2015 Share Posted May 9, 2015 Well Slackers are behind the times.... Heck even Debian has moved to the dark side Slackers are like cats and old people; they don't like change. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 10, 2015 Author Share Posted May 10, 2015 Well Slackers are behind the times.... Heck even Debian has moved to the dark side Slackers are like cats and old people; they don't like change. Well we know who to blame for that one.... good ole Pat Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 10, 2015 Share Posted May 10, 2015 Blame? I think you mean "thank." Pat V. 1 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 14, 2015 Share Posted May 14, 2015 $ systemd-analyze Startup finished in 6.745s (kernel) + 16.193s (userspace) = 22.939s $ inxi -v 2 System: Host: ************** Kernel: 4.0.1-1-ARCH x86_64 (64 bit) Desktop: WindowMaker 0.95.6 Distro: Arch Linux Machine: Mobo: ASUSTeK model: M2N32-SLI DELUXE v: 1.XX Bios: Phoenix v: ASUS M2N32-SLI DELUXE 5002 date: 03/18/2010 CPU: Quad core AMD Phenom II X4 965 (-MCP-) speed: 803 MHz (max) Graphics: Card-1: NVIDIA GF104 [GeForce GTX 460] Card-2: NVIDIA GF104 [GeForce GTX 460] Display Server: X.Org 1.17.1 driver: nvidia Resolution: 1920x1200, 1920x1080 GLX Renderer: GeForce GTX 460/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 349.16 Network: Card-1: NVIDIA MCP55 Ethernet driver: forcedeth Card-2: NVIDIA MCP55 Ethernet driver: forcedeth Card-3: Realtek RTL8187 Wireless Adapter driver: rtl8187 Drives: HDD Total Size: 360.1GB (3.0% used) ID-1: model: MKNSSDCR120GB ID-2: model: MKNSSDCR240GB Info: Processes: 112 Uptime: 27 min Memory: 787.4/3956.4MB Client: Shell (bash) inxi: 2.2.19 My problem is the cpu only runs at 800MHz I can run it at 3.4MHz but am not able to govern it, it is a bios problem. I also have done no tweaking of the Arch install so the results show an out of the box install. I may buy a new mobo and ram to get running at optimum as I have some newer games to play as I am nearly at the end of all the older games I can play at maximum graphics resolution. 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 14, 2015 Author Share Posted May 14, 2015 $ systemd-analyze Startup finished in 6.745s (kernel) + 16.193s (userspace) = 22.939s It is still not that bad at all. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 14, 2015 Share Posted May 14, 2015 $ systemd-analyze Startup finished in 6.745s (kernel) + 16.193s (userspace) = 22.939s It is still not that bad at all. Yeah it is still quicker than Windows 7 which I run on the same pc. 1 Quote Link to comment Share on other sites More sharing options...
burninbush Posted May 16, 2015 Share Posted May 16, 2015 I have some questions about this idea of boot times; counting from what? Surely not from flipping the power switch on -- just getting through POST takes 8 - 10 seconds on either of my desktops (quad-core 3ghz AMD II boxes). I have always assumed that was due to the number of partitions on my disks -- 13 total. From hitting Enter at the grub choice takes another 12 - 14 seconds to get to a text login, and then KDE another 15 seconds. Doesn't some large portion of the kernel have to be running to enable system-analyze to even measure times? I have an older SSD here (220 mb/second) that I have also tested with -- it boots faster than the hard disks, but not by much -- IMO, the only parts of bootup where it makes a difference is when the disk light is on, which anybody can see is not nearly the whole bootup process. Any info appreciated. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 16, 2015 Author Share Posted May 16, 2015 Actually it is measured from the point of hitting enter on your boot manager to your login. The system-analyze is a built in systemd command that is available on any distro running systemd (most all of them now). You can make your bios post a lot faster by changing the option in your bios to silent or whatever your bios calls it. Trust me, I have 6 harddrives in this machine and my post takes less than 2 seconds. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 16, 2015 Author Share Posted May 16, 2015 You can also use this to tell you which service takes how long and such: systemd-analyze blame [ comhack@Cerberus ~ % systemd-analyze blame 243ms dev-sda1.device 193ms systemd-modules-load.service 164ms network.service 136ms systemd-fsck@dev-disk-by\x2duuid-c30db2b6\x2d90d1\x2d41f1\x2d9d75\x2d6659c0fde970.servi 115ms systemd-fsck@dev-disk-by\x2duuid-3067b591\x2d934e\x2d4c73\x2da4a7\x2de5d9da6c267a.servi 113ms systemd-fsck@dev-disk-by\x2duuid-cb0d6b0f\x2d1c2a\x2d46c8\x2d99eb\x2dbbe4e1bcb1b5.servi 86ms systemd-fsck@dev-disk-by\x2duuid-3fc84665\x2d73ed\x2d46ed\x2da4c6\x2d31d4ce2bc1b7.servi 86ms monitorix.service 68ms backup2.mount 62ms MEDIA.mount 57ms lm_sensors.service 56ms urxvtd@comhack.service 55ms systemd-logind.service 50ms catalyst-hook.service 48ms systemd-fsck@dev-disk-by\x2duuid-86a184ad\x2d40b3\x2d46c3\x2db405\x2de7e06fb57ad6.servi 46ms udisks2.service 45ms systemd-user-sessions.service 45ms cpupower.service 45ms systemd-fsck@dev-disk-by\x2duuid-7609a908\x2db7a1\x2d4242\x2dab4c\x2d3ee3cc538afb.servi 42ms Various.mount 35ms systemd-udevd.service 34ms systemd-tmpfiles-clean.service 32ms systemd-journald.service 24ms colord.service 21ms polkit.service 20ms systemd-sysctl.service 20ms user@1000.service 19ms systemd-udev-trigger.service 15ms alsa-restore.service 15ms systemd-tmpfiles-setup-dev.service 14ms backup.mount 14ms systemd-vconsole-setup.service 13ms old\x2dhome.mount 12ms tmp.mount 10ms systemd-remount-fs.service 10ms kmod-static-nodes.service 9ms systemd-tmpfiles-setup.service 8ms shadow.service` Quote Link to comment Share on other sites More sharing options...
burninbush Posted May 17, 2015 Share Posted May 17, 2015 Actually it is measured from the point of hitting enter on your boot manager to your login. The system-analyze is a built in systemd command that is available on any distro running systemd (most all of them now). You can make your bios post a lot faster by changing the option in your bios to silent or whatever your bios calls it. Trust me, I have 6 harddrives in this machine and my post takes less than 2 seconds. ?? Can you give me a hint where I might find that, or what it is called? Went through every setting on both boxes this morning and except for disable splash screen I see nothing like that. These mobos are about 2 years old. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 17, 2015 Author Share Posted May 17, 2015 Look for an entry labeled 'power-on self test', 'startup diagnostic', or the like. If you find such an entry, disable it. Alternatively, look for an option called 'Fast Boot' or 'Quick Boot'; Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 20, 2015 Share Posted May 20, 2015 Actually it is measured from the point of hitting enter on your boot manager to your login. The system-analyze is a built in systemd command that is available on any distro running systemd (most all of them now). You can make your bios post a lot faster by changing the option in your bios to silent or whatever your bios calls it. Trust me, I have 6 harddrives in this machine and my post takes less than 2 seconds. ?? Can you give me a hint where I might find that, or what it is called? Went through every setting on both boxes this morning and except for disable splash screen I see nothing like that. These mobos are about 2 years old. Which bios are you using ? As Josh says "Quick" boot may be an option an maybe you can turn of any logos that appear or floppy boot seek or kvm if you do not use it or any of the , boot from keyboard/network type stuff, in other words disable or turn of any of the bios stuff you never use. Quote Link to comment Share on other sites More sharing options...
