rbdietz Posted April 29, 2005 Share Posted April 29, 2005 http://www23.tomshardware.com/index.htmlSimply select the desired models and a benchmark, and the appropriate chart appears. The two CPUs are displayed in the diagrams as specially marked red bars. Shown at the very bottom is also some important additional information: the absolute and relative difference between the two models. If you click on any of the bars on the chart, a pop-up window appears with data about that particular test configuration we used. Color highlighting added.Added this one to my bookmarks. Quote Link to comment Share on other sites More sharing options...
henderrob Posted April 29, 2005 Share Posted April 29, 2005 Thanks, I had some fun doing comparisons. Quote Link to comment Share on other sites More sharing options...
Rons Posted April 29, 2005 Share Posted April 29, 2005 rbdietz - thanks for info. Quote Link to comment Share on other sites More sharing options...
lewmur Posted May 1, 2005 Share Posted May 1, 2005 http://www23.tomshardware.com/index.htmlColor highlighting added.Added this one to my bookmarks. <{POST_SNAPBACK}> Now if I only understood which benchmark to use for which applications. And, as to be expected, the latest chips weren't included. I'm curious about the new llow end entry from AMD. The 1.8Ghz Duron. How, for instance, does it stack up against a Sempron 2000+ which, I believe, runs at about 1.6Ghz? Quote Link to comment Share on other sites More sharing options...
SonicDragon Posted May 1, 2005 Share Posted May 1, 2005 Very cool site. Thanks for the link.Obviously a lot of work has gone into making that site available. Thanks Tom for keeping up such a great site Quote Link to comment Share on other sites More sharing options...
henderrob Posted May 1, 2005 Share Posted May 1, 2005 (edited) Now if I only understood which benchmark to use for which applications. And, as to be expected, the latest chips weren't included. I'm curious about the new llow end entry from AMD. The 1.8Ghz Duron. How, for instance, does it stack up against a Sempron 2000+ which, I believe, runs at about 1.6Ghz?<{POST_SNAPBACK}> I think that Sempron's are faster than Duron's due to their being renamed Athlon Thoroughbred CPU's. They use Socket A and have a 256 bit on die cache. The Sempron 3000 has a 512 bit cache and the 3100+ uses socket 754 and has the same Hyper Transport bus that the socket 754 AMD 64's. Edited May 1, 2005 by henderrob Quote Link to comment Share on other sites More sharing options...
lewmur Posted May 4, 2005 Share Posted May 4, 2005 I think that Sempron's are faster than Duron's due to their being renamed Athlon Thoroughbred CPU's..<{POST_SNAPBACK}> I know they are faster. That wasn't the question. The question was how much faster is the Sempron 2000, the low end of that line, than the Duron 1.8ghz, the high end of its line? There is a BIG difference in price. Does the performance difference match the price difference? And the Duron 1.8ghz is new and I haven't seen any benchmarks on it. Quote Link to comment Share on other sites More sharing options...
