SueD Posted May 30, 2007 Share Posted May 30, 2007 I installed Mandriva Spring a few days ago, and after reading all that I can here and at the wiki, I think I've got everything running as it should...except for my video card. I have an nvidia geforce 6200 but I can't get it configured. Halp! Quote Link to comment Share on other sites More sharing options...
striker Posted May 30, 2007 Share Posted May 30, 2007 What' s the exact problem Sue, can you elaborate a bit ? You see, the list with graphics card drivers was cleaned up and now only refers to the actual chipset used on the specific cards.But let' s first listen to what the exact problem is... Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 30, 2007 Share Posted May 30, 2007 One additional querstion to the ones Striker already asked: did you install "dkms-nvidia" ? Bruno Quote Link to comment Share on other sites More sharing options...
SueD Posted May 30, 2007 Author Share Posted May 30, 2007 Well first off, my card isn't in thehardware list and it keeps pointing to the 7950. The installer says it's got drivers for it and would I like to install them...I say yes after making sure nothing else is installed...nada, zip, zilch...it doesn't work. After some fiddling, I now have dkms-2.0.16-1mdv2007.1.naarch, dkms-minimal-2.0.16-1mdv2007.1.noarch, and dkms-nvidia97xx-1.0-9755.1mdv2007.2.i586. I'm not 100% sure but I think that's what I've got in PCLos Final too.I apologize if I'm not explaining things right. Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 30, 2007 Share Posted May 30, 2007 Hi Sue . . . can you show me: # ls -al /usr/src# uname -r# cat /etc/X11/xorg.conf Bruno Quote Link to comment Share on other sites More sharing options...
SueD Posted May 30, 2007 Author Share Posted May 30, 2007 [root@localhost sue]# ls -al /usr/srctotal 5drwxr-xr-x 5 root root 1024 May 29 16:04 ./drwxr-xr-x 13 root root 1024 May 28 15:07 ../lrwxrwxrwx 1 root root 18 May 28 20:11 linux -> linux-2.6.17-13mdv/drwxr-xr-x 8 root root 1024 May 28 20:11 linux-2.6.17-13mdv/drwxr-xr-x 2 root root 1024 May 29 16:04 nvidia97xx-9755/drwxr-xr-x 3 root root 1024 May 28 08:07 rpm/ [root@localhost sue]# uname -r2.6.17-14mdv [root@localhost sue]# cat /etc/X11/xorg.conf# File generated by XFdrake (rev 142098)# **********************************************************************# Refer to the xorg.conf man page for details about the format of# this file.# **********************************************************************Section "Files" ModulePath "/usr/lib/xorg/modules/extensions/nvidia97xx" ModulePath "/usr/lib/xorg/modules" # font server independent of the X server to render fonts. FontPath "unix/:-1" # minimal fonts to allow X to run without xfs FontPath "/usr/share/fonts/misc:unscaled"EndSectionSection "Extensions" Option "Composite"EndSectionSection "ServerFlags" #DontZap # disable <Crtl><Alt><BS> (server abort) #DontZoom # disable <Crtl><Alt><KP_+>/<KP_-> (resolution switching) AllowMouseOpenFail # allows the server to start up even if the mouse does not workEndSectionSection "Module" Load "dbe" # Double-Buffering Extension Load "v4l" # Video for Linux Load "extmod" Load "type1" Load "freetype" Load "glx" # 3D layerEndSectionSection "InputDevice" Identifier "Keyboard1" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "us" Option "XkbOptions" "compose:rwin"EndSectionSection "InputDevice" Identifier "Mouse1" Driver "mouse" Option "Protocol" "ExplorerPS/2" Option "Device" "/dev/mouse"EndSectionSection "Monitor" Identifier "monitor1" VendorName "Plug'n Play" ModelName "Acer AL1706" HorizSync 30-83 VertRefresh 55-75 # Monitor preferred modeline (60.0 Hz vsync, 64.0 kHz hsync, ratio 5/4) ModeLine "1280x1024" 108 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync # TV fullscreen mode or DVD fullscreen output. # 768x576 @ 79 Hz, 50 kHz hsync ModeLine "768x576" 50.00 768 832 846 1000 576 590 595 630 # 768x576 @ 100 Hz, 61.6 kHz hsync ModeLine "768x576" 63.07 768 800 960 1024 576 578 590 616EndSectionSection "Device" Identifier "device1" VendorName "nVidia Corporation" BoardName "NVIDIA GeForce FX - GeForce 7950" Driver "nv" Option "DPMS" Option "AddARGBGLXVisuals"EndSectionSection "Screen" Identifier "screen1" Device "device1" Monitor "monitor1" DefaultColorDepth 24 Subsection "Display" Depth 8 Modes "1024x768" "832x624" "800x600" "640x480" "480x360" "320x240" EndSubsection Subsection "Display" Depth 15 Modes "1024x768" "832x624" "800x600" "640x480" "480x360" "320x240" EndSubsection Subsection "Display" Depth 16 Modes "1024x768" "832x624" "800x600" "640x480" "480x360" "320x240" EndSubsection Subsection "Display" Depth 24 Modes "1024x768" "832x624" "800x600" "640x480" "480x360" "320x240" EndSubsectionEndSectionSection "ServerLayout" Identifier "layout1" InputDevice "Keyboard1" "CoreKeyboard" InputDevice "Mouse1" "CorePointer" Screen "screen1"EndSectionI'm in no hurry. This has eluded me for a few days....another day or so won't matter. Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 30, 2007 Share Posted May 30, 2007 I can see what is wrong . . . you have the kernel-source for the 2.6.17-13 kernel and you are running the 2.6.17-14 kernel . . . . so that is why the dkms-nvidia package can not compile at boot.Please install the "kernel-source-stripped-2.6.17.14mdv" from the MCC . . . and next make a backup of your xorg.conf file # cp /etc/X11/xorg.conf /etc/X11/xorg.conf-BACKUP And edit the /etc/X11/xorg.conf file . . . this part: Section "Device" Identifier "device1" VendorName "nVidia Corporation" BoardName "NVIDIA GeForce FX - GeForce 7950" Driver "nvidia" Option "DPMS" Option "AddARGBGLXVisuals"EndSectionFinally reboot and you will see in the boot-messages that the dkms-nvidia will compile during boot ( you see dots, like this: . . . . . . . . . . . . . . . . )Next you should see the nvidia splash and all should be fine. Bruno Quote Link to comment Share on other sites More sharing options...
striker Posted May 30, 2007 Share Posted May 30, 2007 Saw something else Bruno ... Subsection "Display"Depth 24Modes "1024x768" "832x624" "800x600" "640x480" "480x360" "320x240"EndSubsectionEndSectionI would change it to:Subsection "Display"Depth 24Modes "1280x1024" "1024x768" "832x624" "800x600" "640x480" "480x360" "320x240"EndSubsectionEndSectionAcc. to : http://www.acerpanam.com/synapse/forms/por...s=&areaid=7 Quote Link to comment Share on other sites More sharing options...
SueD Posted May 30, 2007 Author Share Posted May 30, 2007 It didn't work. I can't get "nvidia" to stick in the xorg.conf file. And it still shows the card as NVIDIA GeForce FX - GeForce 7950...mine's a 6200. Does that make a difference?Striker, is that really necessary since I never have the resolution at 1280x1024? Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 31, 2007 Share Posted May 31, 2007 Hi SueThat is shows the card as "NVIDIA GeForce FX - GeForce 7950" is not very important . . . but an you show the result of ls -al /var/lib/dkms And maybe do # updatedb ( takes a while to finish. If the command returns an error please install "mlocate" ) # locate libglx.so Bruno Quote Link to comment Share on other sites More sharing options...
striker Posted May 31, 2007 Share Posted May 31, 2007 name='SueD' date='May 30 2007, 11:57 PM' post='228091'It didn't work. I can't get "nvidia" to stick in the xorg.conf file. And it still shows the card as NVIDIA GeForce FX - GeForce 7950...mine's a 6200. Does that make a difference?Sue, please read this:http://wiki.mandriva.com/en/Releases/Mandr...list_cleaned_upIt'll explain it all. FWIW : I have a Geforce FX5200 in the machine and it's handled by Spring as a 7950 too : it works, no fear !Striker, is that really necessary since I never have the resolution at 1280x1024?Well, if you want the best out of it yes, it's the native resolution of your Acer. If you don't set it to that, the resultant picture is of less quality, that's how LCD's work. OTOH : If you're used to it, go ahead. It won't blow up the Acer. Quote Link to comment Share on other sites More sharing options...
SueD Posted May 31, 2007 Author Share Posted May 31, 2007 [sue@localhost ~]$ ls -al /var/lib/dkmstotal 3drwxr-xr-x 2 root root 1024 May 30 18:18 ./drwxr-xr-x 22 root root 1024 May 31 05:51 ../-rw-r--r-- 1 root root 6 Feb 28 03:27 dkms_dbversion [root@localhost sue]# locate libglx.so/usr/lib/xorg/modules/extensions/libglx.so/usr/lib/xorg/modules/extensions/nvidia97xx/libglx.s/usr/lib/xorg/modules/extensions/nvidia97xx/libglx.so.1.0.9755 Sue, please read this:http://wiki.mandriva.com/en/Releases/Mandr...list_cleaned_upIt'll explain it all. FWIW : I have a Geforce FX5200 in the machine and it's handled by Spring as a 7950 too : it works, no fear !Well, if you want the best out of it yes, it's the native resolution of your Acer. If you don't set it to that, the resultant picture is of less quality, that's how LCD's work. OTOH : If you're used to it, go ahead. It won't blow up the Acer. Ahh, ok, that does make sense now. Thanks Striker. And I will add that setting. If I can get used to it, I'll keep it. If not, no big whoop...I'll just go back to what I'm used to. Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 31, 2007 Share Posted May 31, 2007 [sue@localhost ~]$ ls -al /var/lib/dkmstotal 3drwxr-xr-x 2 root root 1024 May 30 18:18 ./drwxr-xr-x 22 root root 1024 May 31 05:51 ../-rw-r--r-- 1 root root 6 Feb 28 03:27 dkms_dbversion There are things missing there Sue . . . . . . can you have a look in the MCC if dkms-nvidia is installed ? Bruno Quote Link to comment Share on other sites More sharing options...
SueD Posted May 31, 2007 Author Share Posted May 31, 2007 There are things missing there Sue . . . . . . can you have a look in the MCC if dkms-nvidia is installed ? BrunoIt's not installed because it's not there. Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 31, 2007 Share Posted May 31, 2007 - Do you have the Mandriva non-free source configured in the MCC ?? ( Or alternatively the PLF non-free )- How did you install the nvidia drivers ? Bruno Quote Link to comment Share on other sites More sharing options...
SueD Posted May 31, 2007 Author Share Posted May 31, 2007 - Do you have the Mandriva non-free source configured in the MCC ?? ( Or alternatively the PLF non-free )- How did you install the nvidia drivers ? BrunoI have the non-free enabled and the non-free updates enabled and updates checked off.How did I install them? Good gawd, I can't remember (it's been a few days since doing it) but I'm almost sure I did it through the MCC. Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 31, 2007 Share Posted May 31, 2007 I can't remember (it's been a few days since doing it) but I'm almost sure I did it through the MCC. You should be able to find them with a "green tick" if they are installed.Maybe add the PLF sources and look if they have dmks-nvidia for you.Here is how to add the source: # urpmi.addmedia --update plf-free ftp://distrib-coffee.ipsl.jussieu.fr/pub/linux/plf/mandriva/2007.1/free/release/binary/i586/ with media_info/hdlist.cz # urpmi.addmedia --update plf-nonfree ftp://distrib-coffee.ipsl.jussieu.fr/pub/linux/plf/mandriva/2007.1/non-free/release/binary/i586/ with media_info/hdlist.cz If you use the PLF ones you better dig in the MCC first ad uninstall all other nvidia packages. Bruno Quote Link to comment Share on other sites More sharing options...
SueD Posted May 31, 2007 Author Share Posted May 31, 2007 I'm confused. Am I looking for dkms-nvidia or dkms-nvidia97xx1.0-1mdv2007.1.i586? Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 31, 2007 Share Posted May 31, 2007 The "dkms-nvidia97xx1.0-1mdv2007.1.i586" is the better one because that is the official Mandriva one :DB) Bruno Quote Link to comment Share on other sites More sharing options...
SueD Posted May 31, 2007 Author Share Posted May 31, 2007 Installation failed, some files are missing:- ftp://ftp.nluug.nl/pub/os/Linux/distr/Man...2007.1.i586.rpmYou may want to update your media database.Error(s) reported:...retrieving failed: wget failed: exited with 1 Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 31, 2007 Share Posted May 31, 2007 Okay . . . close the MCC and do: # urpmi.update -a . . . after that try again Bruno Quote Link to comment Share on other sites More sharing options...
SueD Posted May 31, 2007 Author Share Posted May 31, 2007 [root@localhost sue]# urpmi.update -aurpmi database locked Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 31, 2007 Share Posted May 31, 2007 [root@localhost sue]# urpmi.update -aurpmi database lockedMCC must be closed while running this command. Did you close it? Quote Link to comment Share on other sites More sharing options...
SueD Posted May 31, 2007 Author Share Posted May 31, 2007 MCC must be closed while running this command. Did you close it?Duh! Thanks Eric. Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 31, 2007 Share Posted May 31, 2007 No worries... happens to us all from time to time. Quote Link to comment Share on other sites More sharing options...
striker Posted May 31, 2007 Share Posted May 31, 2007 I have seen this too, you may guess where ... Quote Link to comment Share on other sites More sharing options...
Urmas Posted May 31, 2007 Share Posted May 31, 2007 Quote Link to comment Share on other sites More sharing options...
striker Posted May 31, 2007 Share Posted May 31, 2007 Quote Link to comment Share on other sites More sharing options...
SueD Posted May 31, 2007 Author Share Posted May 31, 2007 [sue@localhost ~]$ ls -al /var/lib/dkmstotal 4drwxr-xr-x 3 root root 1024 May 31 16:21 ./drwxr-xr-x 22 root root 1024 May 31 05:51 ../-rw-r--r-- 1 root root 6 Feb 28 03:27 dkms_dbversiondrwxrwxr-x 3 root root 1024 May 31 16:22 nvidia97xx/Better? Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 31, 2007 Share Posted May 31, 2007 Yep, much better . . . now change the xorg.conf file back to Driver "nvidia" and reboot . . . . chances are that it works now. Bruno Quote Link to comment Share on other sites More sharing options...
